楼主 #1 2020-05-09 20:51:46
缥缈九哥
已发帖子: 93
添加AL9V576的CHAR驱动到基于linux-2.6.27的9G9260开发板--缥缈九哥
1,修改drivers/char/Makefile文件
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  vi drivers/char/Makefile
在第102行添加:
obj-$(CONFIG_FY_AL9V576) += al9v576.o
2, 修改drivers/char/Kconfig文件
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  vi drivers/char/Kconfig
在第1123行添加:
config FY_AL9V576
  tristate "AverLogic AL9V576 MPEG-4/2/1 A/V Encoder"
  depends on MACH_9G9260EK
  help
    If you say yes here you get support for the
    AverLogic AL9V576 MPEG-4/2/1 A/V Encoder.
    This driver can also be built as a module. If so, the module
    will be called al9v576.
config FY_AL9V576_DEBUG
  boolean "AL9V576 Encoder debug messages"
  depends on MACH_9G9260EK && FY_AL9V576
  help
    Select this if you want AL9V576 debug messages
3,编译配置内核
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  make menuconfig
进入配置菜单添加驱动到内核:
    System Type  --->
 Atmel AT91 System-on-Chip  --->
 [*] Atmel AT91SAM9260-EK / AT91SAM9XE Evaluation Kit
 [*]   9G9260-EK Evaluation Kit
    Device Drivers  --->
 Character devices  --->
 <M> AverLogic AL9V576 MPEG-4/2/1 A/V Encoder
 [*]   AL9V576 Encoder debug messages
4,修改arch/arm/mach-at91/board-sam9260ek.c文件
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  vi arch/arm/mach-at91/board-sam9260ek.c
在头文件列表后添加:
  #include <mach/at91sam9260.h>
  #include <mach/at91sam9260_matrix.h>
  #include <mach/at91sam9_smc.h>
 在static void __init ek_board_init(void)内部添加:
  #if defined(CONFIG_MACH_9G9260EK)
   /* al9v576 */
   at91_add_device_al9v576();
 在static void __init ek_board_init(void)前面添加:
  #define AL9V576_BASE AT91_CHIPSELECT_0
  #define AL9V576_SIZE SZ_1K
  static struct resource al9v576_resources[] =
    .start = AL9V576_BASE,
    .end = AL9V576_BASE + AL9V576_SIZE - 1,
    .flags = IORESOURCE_MEM,
  static struct platform_device al9v576_driver =
   .name  = "al9v576",
   .id   = 0,
   .dev  =
    .platform_data = NULL,
   .resource = al9v576_resources,
   .num_resources = ARRAY_SIZE(al9v576_resources),
  static struct sam9_smc_config __initdata al9v576_smc_config =
   .ncs_read_setup  = 0x01,
   .nrd_setup   = 0x02,
   .ncs_write_setup = 0x01,
   .nwe_setup   = 0x02,
   .ncs_read_pulse  = 0x08,
   .nrd_pulse   = 0x06,
   .ncs_write_pulse = 0x08,
   .nwe_pulse   = 0x06,
   .read_cycle   = 0x12,
   .write_cycle  = 0x12,
   .mode    = AT91_SMC_READMODE | AT91_SMC_WRITEMODE | AT91_SMC_EXNWMODE_DISABLE,
   .tdf_cycles   = 0x08,
  static __init void at91_add_device_al9v576(void)
   unsigned long csa;
   csa = at91_sys_read(AT91_MATRIX_EBICSA);
   at91_sys_write(AT91_MATRIX_EBICSA, csa | AT91_MATRIX_VDDIOMSEL_3_3V);
   /* setup bus-width (8 or 16) */
  #if defined(CONFIG_AL9V576_BUSWIDTH_16)
    al9v576_smc_config.mode |= AT91_SMC_DBW_16;
  #else
    al9v576_smc_config.mode |= AT91_SMC_DBW_8;
   /* configure chip-select 0 (AL9V576) */
   sam9_smc_configure(0, &al9v576_smc_config);
   platform_device_register(&al9v576_driver);
5,添加drivers/char/al9v576.h文件
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  vi drivers/char/al9v576.h
添加的源码见附件。
6,添加drivers/char/al9v576.c文件
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260#  vi drivers/char/al9v576.c
添加的源码见附件。
7, 编译内核生成驱动
附件:
(保密)
