楼主 #1 2020-07-23 12:57:17
kingreid
已发帖子: 57
发现个问题 v3s 网络不是每次都能正确获取IP
重启有时不能正确获取IP
楼主 #2 2020-07-23 13:07:25
kingreid
已发帖子: 57
Re: 发现个问题 v3s 网络不是每次都能正确获取IP
[    2.952472] systemd[1]: Expecting device dev-ttyS0.device...
[    3.237578] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.719839] systemd-udevd[96]: starting version 215
[    4.879314] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    5.325725] systemd-journald[83]: Received request to flush runtime journal from PID 1
[    7.654572] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=-1)
[    7.673036] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    7.684349] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
有时候启动 没有下面的内容
[   22.248938] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
#3 2020-07-23 13:08:36
拔插网线之后是不是就可以了?
楼主 #4 2020-07-23 13:14:18
kingreid
已发帖子: 57
好像也不行 分配不了IP地址
#5 2020-07-23 13:51:42
阿黄
已发帖子: 299
好像是没有拿到mac地址
楼主 #6 2020-07-23 13:59:39
kingreid
已发帖子: 57
有的时候行  有的时候不行  显示dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx就可以了
楼主 #7 2020-07-23 14:34:12
kingreid
已发帖子: 57
设了静态IP地址 ping不通网络
