基于官方19.07版本,修改了uboot为2020.01
[ 0.000000] Linux version 4.14.187 (njatech@njatech-virtual-machine) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11150-a2c9fc9)) #0 SMP PREEMPT Sun Jul 26 20:39:09 2020
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c0c44fc0, node_mem_map c3f3b000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] random: get_random_bytes called from start_kernel+0x88/0x3c0 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s30732 r8192 d22516 u61440
[ 0.000000] pcpu-alloc: s30732 r8192 d22516 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=squashfs
[ 0.000000] Memory: 54012K/65536K available (5430K kernel code, 278K rwdata, 1500K rodata, 2048K init, 243K bss, 11524K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0xc0008000 - 0xc074daa8 (7447 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0c00000 (2048 kB)
[ 0.000000] .data : 0xc0c00000 - 0xc0c458c0 ( 279 kB)
[ 0.000000] .bss : 0xc0c4c1cc - 0xc0c88fd0 ( 244 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000413] Console: colour dummy device 80x30
[ 0.000455] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000473] pid_max: default: 32768 minimum: 301
[ 0.000613] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000627] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001210] CPU: Testing write buffer coherency: ok
[ 0.001650] /cpus/cpu@0 missing clock-frequency property
[ 0.001675] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.040124] Setting up static identity map for 0x40200000 - 0x40200060
[ 0.060119] Hierarchical SRCU implementation.
[ 0.100221] smp: Bringing up secondary CPUs ...
[ 0.100246] smp: Brought up 1 node, 1 CPU
[ 0.100256] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.100263] CPU: All CPU(s) started in HYP mode.
[ 0.100269] CPU: Virtualization extensions available.
[ 0.103693] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.104338] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.104375] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.104546] pinctrl core: initialized pinctrl subsystem
[ 0.105664] NET: Registered protocol family 16
[ 0.106148] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.107299] No ATAGs?
[ 0.162746] SCSI subsystem initialized
[ 0.162839] libata version 3.00 loaded.
[ 0.163172] usbcore: registered new interface driver usbfs
[ 0.163241] usbcore: registered new interface driver hub
[ 0.165524] usbcore: registered new device driver usb
[ 0.166258] pps_core: LinuxPPS API ver. 1 registered
[ 0.166278] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.166420] PTP clock support registered
[ 0.167733] Advanced Linux Sound Architecture Driver Initialized.
[ 0.172669] clocksource: Switched to clocksource arch_sys_counter
[ 0.199212] NET: Registered protocol family 2
[ 0.199949] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.199983] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.200007] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.200146] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.200193] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.200443] NET: Registered protocol family 1
[ 0.200928] kvm [1]: 8-bit VMID
[ 0.201480] kvm [1]: vgic interrupt IRQ16
[ 0.201553] kvm [1]: Hyp mode initialized successfully
[ 0.204613] No memory allocated for crashlog
[ 0.205504] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.222257] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.223279] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.249738] io scheduler noop registered
[ 0.249761] io scheduler deadline registered
[ 0.250022] io scheduler cfq registered (default)
[ 0.250852] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.255429] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.272541] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.277574] console [ttyS0] disabled
[ 0.299220] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[ 0.866128] console [ttyS0] enabled
[ 0.882107] loop: module loaded
[ 0.895232] random: fast init done
[ 0.899368] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.904614] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.910536] Creating 4 MTD partitions on "spi0.0":
[ 0.915462] 0x000000000000-0x000000100000 : "uboot"
[ 0.921994] 0x000000100000-0x000000110000 : "dtb"
[ 0.928895] 0x000000110000-0x000000510000 : "kernel"
[ 0.935996] 0x000000510000-0x000001000000 : "rootfs"
[ 0.943179] mtd: device 3 (rootfs) set to be root filesystem
[ 0.949428] 1 squashfs-split partitions found on MTD device rootfs
[ 0.955973] 0x0000008b0000-0x000001000000 : "rootfs_data"
[ 0.965226] libphy: Fixed MDIO Bus: probed
[ 0.971056] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.977085] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.982982] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[ 0.992293] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.998260] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 1.005565] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 1.011224] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 1.018507] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 1.023487] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 1.030287] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address 36:71:e4:bf:14:94
[ 1.041109] libphy: stmmac: probed
[ 1.045853] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 1.052831] libphy: mdio_mux: probed
[ 1.056457] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 1.062891] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 1.071012] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.078256] ehci-platform: EHCI generic platform driver
[ 1.083991] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.089615] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.097707] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 1.132677] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.139017] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.145851] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.153082] usb usb1: Product: EHCI Host Controller
[ 1.157957] usb usb1: Manufacturer: Linux 4.14.187 ehci_hcd
[ 1.163535] usb usb1: SerialNumber: 1c1a000.usb
[ 1.168997] hub 1-0:1.0: USB hub found
[ 1.173191] hub 1-0:1.0: 1 port detected
[ 1.178353] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.185091] ohci-platform: OHCI generic platform driver
[ 1.190690] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.197520] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.205684] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.276915] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.286277] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.293538] usb usb2: Product: Generic Platform OHCI controller
[ 1.299454] usb usb2: Manufacturer: Linux 4.14.187 ohci_hcd
[ 1.305037] usb usb2: SerialNumber: 1c1a400.usb
[ 1.310530] hub 2-0:1.0: USB hub found
[ 1.314718] hub 2-0:1.0: 1 port detected
[ 1.320117] usbcore: registered new interface driver usb-storage
[ 1.327464] mousedev: PS/2 mouse device common for all mice
[ 1.335348] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.342150] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.347813] i2c /dev entries driver
[ 1.354764] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.422916] sunxi-mmc 1c0f000.mmc: base:0xc4a25000 irq:23
[ 1.439166] NET: Registered protocol family 10
[ 1.456074] Segment Routing with IPv6
[ 1.459841] NET: Registered protocol family 17
[ 1.464950] can: controller area network core (rev 20170425 abi 9)
[ 1.471237] NET: Registered protocol family 29
[ 1.475935] 8021q: 802.1Q VLAN Support v1.8
[ 1.480298] Registering SWP/SWPB emulation handler
[ 1.491632] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:06:47 UTC (407)
[ 1.500332] vcc3v0: disabling
[ 1.503439] vcc3v3: disabling
[ 1.506410] vcc5v0: disabling
[ 1.509376] ALSA device list:
[ 1.512341] No soundcards found.
[ 1.520808] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 1.530348] Freeing unused kernel memory: 2048K
[ 1.679330] random: crng init done
[ 1.857439] init: Console is alive
[ 1.861166] init: - watchdog -
[ 2.014279] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.021315] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.039278] init: - preinit -
[ 2.644465] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[ 2.655757] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 2.663746] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ 2.672345] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.763920] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 5.772514] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 5.905951] jffs2: notice: (721) jffs2_build_xattr_subsystem: complete building xattr subsystem, 3 of xdatum (0 unchecked, 1 orphan) and 7 of xref (1 dead, 0 orphan) found.
[ 5.928084] mount_root: switching to jffs2 overlay
[ 5.960261] overlayfs: upper fs does not support tmpfile.
[ 5.983826] urandom-seed: Seeding with /etc/urandom.seed
[ 6.067733] procd: - early -
[ 6.070763] procd: - watchdog -
[ 6.830489] procd: - watchdog -
[ 6.834117] procd: - ubus -
[ 6.890657] procd: - init -
[ 7.306177] kmodloader: loading kernel modules from /etc/modules.d/*
[ 7.331367] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.363180] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.389027] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[ 7.411567] urngd: v1.0.2 started.
[ 7.503342] xt_time: kernel timezone is -0000
[ 7.526031] PPP generic driver version 2.4.2
[ 7.535590] NET: Registered protocol family 24
[ 7.555138] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.803469] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[ 12.840109] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 12.882915] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ 12.920471] br-lan: port 1(eth0) entered blocking state
[ 12.935996] br-lan: port 1(eth0) entered disabled state
[ 12.954319] device eth0 entered promiscuous mode
[ 13.023517] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 15.123700] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 15.132320] br-lan: port 1(eth0) entered blocking state
[ 15.137642] br-lan: port 1(eth0) entered forwarding state
[ 15.211540] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes readyroot@OpenWrt:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 3840 3840 0 100% /rom
tmpfs 28028 84 27944 0% /tmp
/dev/mtdblock4 7488 388 7100 5% /overlay
overlayfs:/overlay 7488 388 7100 5% /
tmpfs 512 0 512 0% /dev
openwrt-sunxi-cortexa7-sun8i-v3s-licheepi-zero-squashfs-spiflash_img.gz
最近编辑记录 阿黄 (2020-07-29 21:34:20)
优秀,求分享编译教程
占楼
最近编辑记录 阿黄 (2020-07-29 21:53:25)
请问楼主, openwrt 怎么移植?
你wan口网络怎么配置
大佬,能否分享一下spi flash的固件编译方法?
