楼主 #1 2020-09-21 18:50:58
henman
已发帖子: 23
有没有人关注过cpu性能?我发现v3s的1.2G,比不过mips的600m,有没有高手来看看我是不是做错了?
我做了个频繁浮点的运算,代码如下:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <malloc.h>
#include <time.h>
#include <string.h>
int main(int argc, char* argv[])
        //ok
        //double x=2, z=2;
        //int a=1, b=3;
        //while(z>1e-15)
        //      z = z*a/b;
        //      x += z;
        //      a++;
        //      b+=2;
        //printf("x %.13f\n", x);
        clock_t ttBegin = clock();
        int i;
        int DISPCNT;
        if (argc < 2)
                DISPCNT = 10000;
                DISPCNT = atoi(argv[1]);
        printf("DISPCNT %d\n", DISPCNT);
        int ARRSIZE = DISPCNT + 100;
        char* x = (char*)malloc(ARRSIZE);
        char* z = (char*)malloc(ARRSIZE);
        //const int ARRSIZE=10100, DISPCNT=10000; //定义数组大小,显示位数
        //char x[ARRSIZE], z[ARRSIZE]; //x[0] x[1] . x[2] x[3] x[4] .... x[ARRSIZE-1]
        int a=1, b=3, c, d, Run=1, Cnt=0;
        memset(x,0,ARRSIZE);
        memset(z,0,ARRSIZE);
        x[1] = 2;
        z[1] = 2;
        clock_t ttLastPrint = 0;
        while(Run && (++Cnt<200000000))
                clock_t ttCurr = clock();
#if __linux__ == 1
                if (ttCurr - ttLastPrint > 1000000)
#else
                if (ttCurr - ttLastPrint > 1000)
                        printf("Cnt %d\n", Cnt);
                        ttLastPrint = ttCurr;
                //z*=a;
                d = 0;
                for(i=ARRSIZE-1; i>0; i--)
                        c = z[i]*a + d;
                        z[i] = c % 10;
                        d = c / 10;
                //z/=b;
                d = 0;
                for(i=0; i<ARRSIZE; i++)
                        c = z[i]+d*10;
                        z[i] = c / b;
                        d = c % b;
                //x+=z;
                Run = 0;
                        c = x[i] + z[i];
                        x[i] = c%10;
                        x[i-1] += c/10;
                        Run |= z[i];
                a++;
                b+=2;
        clock_t ttEnd = clock();
        clock_t ttTotal = ttEnd - ttBegin;
#if __linux__ == 1
        printf("%lu.%03lu秒\n", ttTotal / 1000000, (ttTotal % 1000000) / 1000);
#else
        printf("%lu.%03lu秒\n", ttTotal / 1000, ttTotal % 1000);
        char s[4 * 1024];
        memset(s, 0, sizeof(s));
        sprintf(s + strlen(s), "计算了 %d 次\r\n", Cnt);
        //sprintf(s + strlen(s), "Pi=%d%d.\r\n", x[0], x[1]);
        //for(i=0; i<DISPCNT; i++)
        //      if(i && ((i%100)==0))
        //              sprintf(s + strlen(s), "\r\n");
        //      sprintf(s + strlen(s), "%d", (int)x[i+2]);
        //printf("%s\n", s);
结论如下:
虚拟机:x86,2.6G
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.8/lto-wrapper
Target: i686-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04.4' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-i386/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-i386 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-i386 --with-arch-directory=i386 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-targets=all --enable-multiarch --disable-werror --with-arch-32=i686 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.4)
gcc main.c
DISPCNT 5000
Cnt 6735
Cnt 13493
2.496秒
gcc -O2 main.c
DISPCNT 5000
Cnt 12608
1.331秒
rts3905n,mips,600M
rsdk-linux-gcc -v
COLLECT_GCC=/root/sdb1/rts3903_sdk_v3.2/toolchain/rsdk-6.4.1-5281-EL-4.9-u1.0-m32fut-190408p1/bin/mips-linux-uclibc-xgcc
COLLECT_LTO_WRAPPER=/root/sdb1/rts3903_sdk_v3.2/toolchain/rsdk-6.4.1-5281-EL-4.9-u1.0-m32fut-190408p1/bin/../libexec/gcc/mips-linux-uclibc/6.4.1/lto-wrapper
Target: mips-linux-uclibc
Configured with: Realtek SDK Builder release 5
Thread model: posix
gcc version 6.4.1 20180425 (Realtek RSDK-6.4.1 Build 3058)
rsdk-linux-gcc main.c
DISPCNT 5000
Cnt 701
Cnt 1393
Cnt 2092
Cnt 2782
Cnt 3476
Cnt 4169
Cnt 4865
Cnt 5557
Cnt 6253
Cnt 6954
Cnt 7656
Cnt 8354
Cnt 9062
Cnt 9771
Cnt 10481
Cnt 11189
Cnt 11901
Cnt 12617
Cnt 13328
Cnt 14048
Cnt 14770
Cnt 15492
Cnt 16222
24.210秒
rsdk-linux-gcc -O2 main.c
DISPCNT 5000
Cnt 1710
Cnt 3390
Cnt 5092
Cnt 6786
Cnt 8498
Cnt 10236
Cnt 11968
Cnt 13736
Cnt 15500
9.880秒
v3s,cortex-a7,1.2G,带硬浮点fpv4-sp-d16
arm-linux-gnueabihf-gcc -v
使用内建 specs。
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/../libexec/gcc/arm-linux-gnueabihf/6.3.1/lto-wrapper
目标:arm-linux-gnueabihf
配置为:'/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/snapshots/gcc.git~linaro-6.3-2017.05/configure' SHELL=/bin/bash --with-mpc=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/builds/destdir/x86_64-unknown-linux-gnu --with-mpfr=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/builds/destdir/x86_64-unknown-linux-gnu --with-gmp=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/builds/destdir/x86_64-unknown-linux-gnu --with-gnu-as --with-gnu-ld --disable-libmudflap --enable-lto --enable-shared --without-included-gettext --enable-nls --disable-sjlj-exceptions --enable-gnu-unique-object --enable-linker-build-id --disable-libstdcxx-pch --enable-c99 --enable-clocale=gnu --enable-libstdcxx-debug --enable-long-long --with-cloog=no --with-ppl=no --with-isl=no --disable-multilib --with-float=hard --with-fpu=vfpv3-d16 --with-mode=thumb --with-tune=cortex-a9 --with-arch=armv7-a --enable-threads=posix --enable-multiarch --enable-libstdcxx-time=yes --enable-gnu-indirect-function --with-build-sysroot=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/sysroots/arm-linux-gnueabihf --with-sysroot=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/builds/destdir/x86_64-unknown-linux-gnu/arm-linux-gnueabihf/libc --enable-checking=release --disable-bootstrap --enable-languages=c,c++,fortran,lto --build=x86_64-unknown-linux-gnu --host=x86_64-unknown-linux-gnu --target=arm-linux-gnueabihf --prefix=/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabihf/_build/builds/destdir/x86_64-unknown-linux-gnu
线程模型:posix
gcc 版本 6.3.1 20170404 (Linaro GCC 6.3-2017.05)
arm-linux-gnueabihf-gcc -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -O2 main.c
DISPCNT 5000
Cnt 1698
Cnt 3410
Cnt 5127
Cnt 6852
Cnt 8581
Cnt 10310
Cnt 12054
Cnt 13804
Cnt 15560
9.776秒
arm-linux-gnueabihf-gcc -O2 main.c
DISPCNT 5000
Cnt 593
Cnt 1197
Cnt 1810
Cnt 2434
Cnt 3068
Cnt 3707
Cnt 4359
Cnt 5031
Cnt 5711
Cnt 6402
Cnt 7104
Cnt 7816
Cnt 8550
Cnt 9308
Cnt 10081
Cnt 10871
Cnt 11680
Cnt 12512
Cnt 13367
Cnt 14247
Cnt 15154
Cnt 16094
22.868秒
arm-linux-gnueabi-gcc -static main.c //由于系统库不一致,所以加了-static参数
DISPCNT 5000
Cnt 195
Cnt 389
Cnt 584
Cnt 779
Cnt 974
Cnt 1170
Cnt 1366
^C   //太慢了,不等了
arm-linux-gnueabi-gcc -static -O2 main.c //由于系统库不一致,所以加了-static参数
DISPCNT 5000
Cnt 595
Cnt 1199
Cnt 1811
Cnt 2433
Cnt 3067
Cnt 3703
Cnt 4352
Cnt 5020
Cnt 5696
Cnt 6380
Cnt 7075
Cnt 7781
Cnt 8506
Cnt 9255
Cnt 10016
Cnt 10792
Cnt 11588
Cnt 12401
Cnt 13233
Cnt 14086
Cnt 14964
Cnt 15872
Cnt 16810
23.350秒
arm-linux-gnueabi-gcc -static -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=fpv4-sp-d16 -mfloat-abi=soft -O2 main.c
DISPCNT 5000
Cnt 1612
Cnt 3235
Cnt 4863
Cnt 6498
Cnt 8135
Cnt 9781
Cnt 11432
Cnt 13087
Cnt 14748
Cnt 16414
10.410秒
楼主 #2 2020-09-21 18:52:16
henman
已发帖子: 23
Re: 有没有人关注过cpu性能?我发现v3s的1.2G,比不过mips的600m,有没有高手来看看我是不是做错了?
这个1.2G的主频是不是太虚了。。。还是说我哪里没搞好?
楼主 #3 2020-09-21 19:09:42
henman
已发帖子: 23
再贴两个海思的。
hi3518ev200,arm926,600m
arm-hisiv300-linux-gcc -v
COLLECT_GCC=arm-hisiv300-linux-gcc
COLLECT_LTO_WRAPPER=/opt/hisi-linux/x86-arm/arm-hisiv300-linux/bin/../libexec/gcc/arm-hisiv300-linux-uclibcgnueabi/4.8.3/lto-wrapper
Target: arm-hisiv300-linux-uclibcgnueabi
Configured with: '../gcc~linaro-4.8-2013.12/configure' --host=i386-redhat-linux --build=i386-redhat-linux --target=arm-hisiv300-linux-uclibcgnueabi --prefix=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/arm-hisiv300-linux --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-arch=armv5te --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-lto --enable-symvers=gnu --enable-__cxa_atexit --enable-nls --enable-clocale=gnu --enable-extra-hisi-multilibs --with-sysroot=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/arm-hisiv300-linux/target --with-build-sysroot=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/arm-hisiv300-linux/target --with-gmp=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-mpfr=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-mpc=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-ppl=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-cloog=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-libelf=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --enable-libgomp --disable-libitm --enable-poison-system-directories --with-libelf=/home/sying/wucaiyuan_toolchain/v300/uclibc_gcc4.8_linaro_toolchain_optimized/install/host_lib --with-pkgversion=Hisilicon_v300 --with-bugurl=http://www.hisilicon.com/cn/service/claim.html
Thread model: posix
gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300)
arm-hisiv300-linux-gcc main.c
DISPCNT 5000
Cnt 369
Cnt 739
Cnt 16483
Cnt 16903
43.490秒
arm-hisiv300-linux-gcc -O2 main.c
DISPCNT 5000
Cnt 667
Cnt 1343
Cnt 15760
Cnt 16626
22.560秒
hi3516ev200,cortex-a7,900m,浮点运算能力未知
arm-himix100-linux-gcc -v
COLLECT_GCC=arm-himix100-linux-gcc
COLLECT_LTO_WRAPPER=/opt/hisi-linux/x86-arm/arm-himix100-linux/host_bin/../libexec/gcc/arm-linux-uclibceabi/6.3.0/lto-wrapper
Target: arm-linux-uclibceabi
Configured with: /home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/src/gcc-6.3.0/configure --host=i386-redhat-linux --build=i386-redhat-linux --target=arm-linux-uclibceabi --prefix=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/install --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-lto --enable-symvers=gnu --enable-__cxa_atexit --disable-libatomic --disable-nls --enable-clocale=gnu --enable-extra-hisi-multilibs --with-sysroot=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/install/target --with-build-sysroot=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/install/target --with-gmp=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/obj/host-libs/usr --with-mpfr=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/obj/host-libs/usr --with-mpc=/home/sying/SDK_CPU_UNIFIED/build/script/arm-himix100-linux/arm_himix100_build_dir/obj/host-libs/usr --disable-libgomp --disable-libquadmath --disable-fixed-point --disable-libsanitizer --disable-libitm --enable-poison-system-directories --with-pkgversion='HC&C V100R002C00B032_20190114'
Thread model: posix
gcc version 6.3.0 (HC&C V100R002C00B032_20190114)
arm-himix100-linux-gcc main.c
DISPCNT 5000
Cnt 656
Cnt 1316
Cnt 15596
Cnt 16374
23.940秒
arm-himix100-linux-gcc -O2 main.c
DISPCNT 5000
Cnt 1435
Cnt 2921
Cnt 13228
Cnt 15279
9.850秒
arm-himix100-linux-gcc -mcpu=cortex-a7 -mfloat-abi=softfp -mfpu=neon-vfpv4 -O2 main.c
DISPCNT 5000
Cnt 3806
Cnt 7654
Cnt 11535
Cnt 15447
4.420秒
#4 2020-09-21 19:46:31
已发帖子: 635
arm-linux-gnueabi-gcc -static -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=fpv4-sp-d16 -mfloat-abi=soft这里有问题。应该是-mfloat-abi=hard
#5 2020-09-21 19:48:33
已发帖子: 635
还有就是单拿浮点来运算评估不出cpu运算能力。
#6 2020-09-21 22:13:35
阿黄
已发帖子: 299
关注
#7 2020-09-21 22:17:56
tpu
已发帖子: 38
微凉VeiLiang 说:
float-abi参数只控制如何传参数等,对性能基本上没影响的。
楼主 #8 2020-09-22 09:33:16
henman
已发帖子: 23
和一群小伙伴探讨了挺久的,又得到了一个工具,量化flops。
 *          Linpack 100x100 Benchmark In C/C++ For PCs
 *                 Original Source from NETLIB
 *  Translated to C by Bonnie Toy 5/88 (modified on 2/25/94  to fix
 *  a problem with daxpy for unequal increments or equal increments
 *  not equal to 1. Jack Dongarra)
 *  To obtain rolled source BLAS, add -DROLL to the command lines.
 *  To obtain unrolled source BLAS, add -DUNROLL to the command lines.
 *  You must specify one of -DSP or -DDP to compile correctly.
 *  You must specify one of -DROLL or -DUNROLL to compile correctly.
 *                   Changes in this version
 *  1. Function prototypes are declared and function headers have
 *     embedded parameter types to produce code for C and C++
 *  2. Arrays aa and a are declared as [200*200] and [200*201] to
 *     allow compilation with prototypes.
 *  3. Function second changed (compiler dependent).
 *  4. Timing method changed due to inaccuracy of PC clock (see below).
 *  5. Additional date function included (compiler dependent).
 *  6. Additional code used as a standard for a series of benchmarks:-
 *       Automatic run time calibration rather than fixed parameters
 *       Initial calibration with display to show linearity
 *       Results displayed at reasonable rate for viewing (5 seconds)
 *       Facilities for typing in details of system used etc.
 *       Compiler details in code in case .exe files used elsewhere
 *       Results appended to a text file (Linpack.txt)
 *  Roy Longbottom  101323.2241@compuserve.com    14 September 1996
 *                             Timing
 *  The PC timer is updated at about 18 times per second or resolution of
 *  0.05 to 0.06 seconds which is similar to the time taken by the main
 *  time consuming function dgefa on a 100 MHz Pentium. Thus there is no
 *  point in running the dgefa/dges1 combination three times as in the
 *  original version. Main timing for the latter, in the loop run NTIMES,
 *  executes matgen/dgefa, summing the time taken by matgen within the
 *  loop for later deduction from the total time. On a modern PC this sum
 *  can be based on a random selection of 0 or 0.05/0.06. This version
 *  executes the single pass once and the main timing loop five times,
 *  calculating the matgen overhead separately.
 *                    Example of Output
 * Rolled Double Precision Linpack Benchmark - PC Version in 'C/C++'
 * Compiler     Watcom C/C++ 10.5 Win 386
 * Optimisation -zp4 -otexan -fp5 -5r -dDP -dROLL
 * norm resid      resid           machep         x[0]-1          x[n-1]-1
 *  0.4   7.41628980e-014  1.00000000e-015 -1.49880108e-014 -1.89848137e-014
* Times are reported for matrices of order          100
* 1 pass times for array with leading dimension of  201
*     dgefa      dgesl      total     Mflops       unit      ratio
*   0.06000    0.00000    0.06000      11.44     0.1748     1.0714
* Calculating matgen overhead
*       10 times   0.11 seconds
*       20 times   0.22 seconds
*       40 times   0.44 seconds
*       80 times   0.87 seconds
*      160 times   1.76 seconds
*      320 times   3.52 seconds
*      640 times   7.03 seconds
* Overhead for 1 matgen      0.01098 seconds
* Calculating matgen/dgefa passes for 5 seconds
*       10 times   0.71 seconds
*       20 times   1.38 seconds
*       40 times   2.80 seconds
*       80 times   5.66 seconds
*      Passes used         70
*  This is followed by output of the normal data for dgefa, dges1,
*  total, Mflops, unit and ratio with five sets of results for each.
*                Example from output file Linpack.txt
* LINPACK BENCHMARK FOR PCs 'C/C++'    n @ 100
* Month run         9/1996
* PC model          Escom
* CPU               Pentium
* Clock MHz         100
* Cache             256K
* Options           Neptune chipset
* OS/DOS            Windows 95
* OptLevel          -zp4 -otexan -fp5 -5r -dDP -dROLL
* Run by            Roy Longbottom
* From              UK
* Mail              101323.2241@compuserve.com
* Rolling            Rolled
* Precision          Double
* norm. resid                     0.4
* resid               7.41628980e-014
* machep              1.00000000e-015             (8.88178420e-016 NON OPT)
* x[0]-1             -1.49880108e-014
* x[n-1]-1           -1.89848137e-014
* matgen 1 seconds            0.01051
* matgen 2 seconds            0.01050
* Repetitions                      70
* Leading dimension               201
* 1 pass seconds              0.06000   0.00000   0.06000
* Repeat seconds              0.06092   0.00157   0.06249     10.99
* Repeat seconds              0.06077   0.00157   0.06234     11.01
* Average                                                     10.99
* Leading dimension               200
* Repeat seconds              0.05936   0.00157   0.06093     11.27
* Repeat seconds              0.05864   0.00157   0.06021     11.40
* Average                                                     11.32
*                     Examples of Results
*  Precompiled codes were produced via a Watcom C/C++ 10.5 compiler.
*  Versions are available for DOS, Windows 3/95 and NT/Win 95. Both
*  non-optimised and optimised programs are available. The latter has
*  options as in the above example. Although these options can place
*  functions in-line, in this case, daxpy is not in-lined. Optimisation
*  reduces 18 instructions in the loop in this function to the following:
*               L85         fld     st(0)
*                           fmul    qword ptr [edx]
*                           add     eax,00000008H
*                           add     edx,00000008H
*                           fadd    qword ptr -8H[eax]
*                           inc     ebx
*                           fstp    qword ptr -8H[eax]
*                           cmp     ebx,esi
*                           jl      L85
*  Results produced are not consistent between runs but produce similar
*  speeds when executing at a particular dimension (see above). An example
*  of other results is 11.4/10.5 Mflops. Most typical double precision
*  rolled results are:
*                               Opt   No Opt                        Version/
*               MHz    Cache  Mflops  Mflops  Make/Options            Via
*   AM80386DX    40     128K    0.53    0.36  Clone                  Win/W95
*   80486DX2     66     128K    2.5     1.9   Escom SIS chipset      Win/W95
*   80486DX2     66     128K    2.3     1.9   Escom SIS chipset       NT/W95
*   80486DX2     66     128K    2.8     2.0   Escom SIS chipset      Dos/Dos
*   Pentium     100     256K    11      4.2   Escom Neptune chipset  Win/W95
*   Pentium     100     256K    11      5.5   Escom Neptune chipset   NT/W95
*   Pentium     100     256K    12      4.4   Escom Neptune chipset  Dos/Dos
*   Pentium Pro 200     256K    48     19     Dell XPS Pro200n        NT/NT
*  The results are as produced when compiled as Linpack.cpp. Compiling as
*  Linpack.c gives similar speeds but the code is a little different.
#define ROLL
#define SP
#ifdef SP
#define REAL float
#define ZERO 0.0
#define ONE 1.0
#define PREC "Single "
#ifdef DP
#define REAL double
#define ZERO 0.0e0
#define ONE 1.0e0
#define PREC "Double "
#ifdef ROLL
#define ROLLING "Rolled "
#ifdef UNROLL
#define ROLLING "Unrolled "
#define NTIMES 10
#include <stdio.h>
#include <math.h>
//#include "conio.h"
#include <stdio.h>
#include <stdlib.h>
static REAL atime[9][15];
static int this_month;
static int this_year;
void print_time (int row);
void matgen (REAL a[], int lda, int n, REAL b[], REAL *norma);
void dgefa (REAL a[], int lda, int n, int ipvt[], int *info);
void dgesl (REAL a[],int lda,int n,int ipvt[],REAL b[],int job);
void dmxpy (int n1, REAL y[], int n2, int ldm, REAL x[], REAL m[]);
void daxpy (int n, REAL da, REAL dx[], int incx, REAL dy[], int incy);
REAL epslon (REAL x);
int idamax (int n, REAL dx[], int incx);
void dscal (int n, REAL da, REAL dx[], int incx);
REAL ddot (int n, REAL dx[], int incx, REAL dy[], int incy);
/* TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME */
#if 1
#include <time.h>  /* for following time functions only */
REAL second()
REAL secs;
clock_t Time;
Time = clock();
secs = (REAL)Time / (REAL)CLOCKS_PER_SEC;
return secs ;
/* DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE */
#if 1
#include <time.h>   /* for following date functions only */
void what_date()
time_t *t,timer;
struct tm *tm;
timer =  time(t);
tm = localtime(&timer);
this_month = tm->tm_mon;
this_year = tm->tm_year;
return;
main ()
static REAL aa[200*200],a[200*201],b[200],x[200];
REAL cray,ops,total,norma,normx;
REAL resid,residn,eps,t1,tm2,epsn,x1,x2;
REAL mflops;
static int ipvt[200],n,i,j,ntimes,info,lda,ldaa;
int Endit, pass, loop;
REAL overhead1, overhead2, time1, time2;
FILE    *outfile;
char *compiler, *options, general[9][80] = {" "};
outfile = fopen("Linpack.txt","a+");
if (outfile == NULL)
printf ("Cannot open results file \n\n");
printf("Press any key\n");
Endit = getchar();
exit (0);
*           Enter details of compiler and options used                 *
compiler = "INSERT COMPILER NAME HERE";
options  = "INSERT OPTIMISATION OPTIONS HERE";
/* Include -dDP or -dSP and -dROLL or -dUNROLL */
lda = 201;
ldaa = 200;
cray = .056;
n = 100;
fprintf(stdout,ROLLING);fprintf(stdout,PREC);
fprintf(stdout,"Precision Linpack Benchmark - PC Version in 'C/C++'\n\n");
fprintf(stdout,"Compiler     %s\n",compiler);
fprintf(stdout,"Optimisation %s\n\n",options);
ops = (2.0e0*(n*n*n))/3.0 + 2.0*(n*n);
matgen(a,lda,n,b,&norma);
t1 = second();
dgefa(a,lda,n,ipvt,&info);
atime[0][0] = second() - t1;
t1 = second();
dgesl(a,lda,n,ipvt,b,0);
atime[1][0] = second() - t1;
total = atime[0][0] + atime[1][0];
/*     compute a residual to verify results.  */
for (i = 0; i < n; i++) {
x[i] = b[i];
b[i] = -b[i];
dmxpy(n,b,n,lda,x,a);
resid = 0.0;
normx = 0.0;
resid = (resid > fabs((double)b[i]))
? resid : fabs((double)b[i]);
normx = (normx > fabs((double)x[i]))
? normx : fabs((double)x[i]);
eps = epslon(ONE);
residn = resid/( n*norma*normx*eps );
epsn = eps;
x1 = x[0] - 1;
x2 = x[n-1] - 1;
printf("norm resid      resid           machep");
printf("         x[0]-1          x[n-1]-1\n");
printf("%6.1f %17.8e%17.8e%17.8e%17.8e\n\n",
(double)residn, (double)resid, (double)epsn,
(double)x1, (double)x2);
fprintf(stderr,"Times are reported for matrices of order        %5d\n",n);
fprintf(stderr,"1 pass times for array with leading dimension of%5d\n\n",lda);
fprintf(stderr,"      dgefa      dgesl      total     Mflops       unit");
fprintf(stderr,"      ratio\n");
atime[2][0] = total;
if (total > 0.0)
atime[3][0] = ops/(1.0e6*total);
atime[4][0] = 2.0/atime[3][0];
atime[3][0] = 0.0;
atime[4][0] = 0.0;
atime[5][0] = total/cray;
print_time(0);
*       Calculate overhead of executing matgen procedure              *
fprintf (stderr,"\nCalculating matgen overhead\n");
pass = -20;
loop = NTIMES;
do
time1 = second();
pass = pass + 1;
for ( i = 0 ; i < loop ; i++)
time2 = second();
overhead1 = (time2 - time1);
fprintf (stderr,"%10d times %6.2f seconds\n", loop, overhead1);
if (overhead1 > 5.0)
pass = 0;
if (pass < 0)
if (overhead1 < 0.1)
loop = loop * 10;
loop = loop * 2;
while (pass < 0);
overhead1 = overhead1 / (double)loop;
fprintf (stderr,"Overhead for 1 matgen %12.5f seconds\n\n", overhead1);
*           Calculate matgen/dgefa passes for 5 seconds                *
fprintf (stderr,"Calculating matgen/dgefa passes for 5 seconds\n");
pass = -20;
ntimes = NTIMES;
do
time1 = second();
pass = pass + 1;
for ( i = 0 ; i < ntimes ; i++)
dgefa(a,lda,n,ipvt,&info );
time2 = second() - time1;
fprintf (stderr,"%10d times %6.2f seconds\n", ntimes, time2);
if (time2 > 5.0)
pass = 0;
if (pass < 0)
if (time2 < 0.1)
ntimes = ntimes * 10;
ntimes = ntimes * 2;
while (pass < 0);
ntimes =  5.0 * (double)ntimes / time2;
if (ntimes == 0) ntimes = 1;
fprintf (stderr,"Passes used %10d \n\n", ntimes);
fprintf(stderr,"Times for array with leading dimension of%4d\n\n",lda);
*                              Execute 5 passes                        *
tm2 = ntimes * overhead1;
atime[3][6] = 0;
for (j=1 ; j<6 ; j++)
t1 = second();
for (i = 0; i < ntimes; i++)
atime[0][j] = (second() - t1 - tm2)/ntimes;
t1 = second();
atime[1][j] = (second() - t1)/ntimes;
total       = atime[0][j] + atime[1][j];
atime[2][j] = total;
atime[3][j] = ops/(1.0e6*total);
atime[4][j] = 2.0/atime[3][j];
atime[5][j] = total/cray;
atime[3][6] = atime[3][6] + atime[3][j];
print_time(j);
atime[3][6] = atime[3][6] / 5.0;
fprintf (stderr,"Average                          %11.2f\n",
(double)atime[3][6]);
fprintf (stderr,"\nCalculating matgen2 overhead\n");
time1 = second();
matgen(aa,ldaa,n,b,&norma);
time2 = second();
overhead2 = (time2 - time1);
overhead2 = overhead2 / (double)loop;
fprintf (stderr,"Overhead for 1 matgen %12.5f seconds\n\n", overhead2);
fprintf(stderr,"Times for array with leading dimension of%4d\n\n",ldaa);
tm2 = ntimes * overhead2;
atime[3][12] = 0;
for (j=7 ; j<12 ; j++)
t1 = second();
dgefa(aa,ldaa,n,ipvt,&info  );
t1 = second();
dgesl(aa,ldaa,n,ipvt,b,0);
atime[3][12] = atime[3][12] + atime[3][j];
print_time(j);
atime[3][12] = atime[3][12] / 5.0;
(double)atime[3][12]);
*           Use minimum average as overall Mflops rating               *
mflops = atime[3][6];
if (atime[3][12] < mflops) mflops = atime[3][12];
fprintf(stderr,"\n");
fprintf(stderr,ROLLING);fprintf(stderr,PREC);
fprintf(stderr," Precision %11.2f Mflops \n\n",mflops);
what_date();
*             Type details of hardware, software etc.                  *
printf ("Enter the following data which will be "
"appended to file Linpack.txt \n\n");
printf ("PC Supplier/model ?\n                    ");
scanf ("%[^\n]", general[1]);
fflush (stdin);
printf ("CPU               ?\n                    ");
scanf ("%[^\n]", general[2]);
fflush (stdin);
printf ("Clock MHz         ?\n                    ");
scanf ("%[^\n]", general[3]);
fflush (stdin);
printf ("Cache             ?\n                    ");
scanf ("%[^\n]", general[4]);
fflush (stdin);
printf ("Chipset/options   ?\n                    ");
scanf ("%[^\n]", general[5]);
fflush (stdin);
printf ("OS/DOS version    ?\n                    ");
scanf ("%[^\n]", general[6]);
fflush (stdin);
printf ("Your name         ?\n                    ");
scanf ("%[^\n]", general[7]);
fflush (stdin);
printf ("Where from        ?\n                    ");
scanf ("%[^\n]", general[8]);
fflush (stdin);
printf ("Mail address      ?\n                    ");
scanf ("%[^\n]", general[0]);
fflush (stdin);
*              Add results to output file LLloops.txt                  *
fprintf (outfile, "----------------- ----------------- --------- "
"--------- ---------\n");
fprintf (outfile, "LINPACK BENCHMARK FOR PCs 'C/C++'    n @ 100\n\n");
fprintf (outfile, "Month run         %d/%d\n", this_month, this_year);
fprintf (outfile, "PC model          %s\n", general[1]);
fprintf (outfile, "CPU               %s\n", general[2]);
fprintf (outfile, "Clock MHz         %s\n", general[3]);
fprintf (outfile, "Cache             %s\n", general[4]);
fprintf (outfile, "Options           %s\n", general[5]);
fprintf (outfile, "OS/DOS            %s\n", general[6]);
fprintf (outfile, "Compiler          %s\n", compiler);
fprintf (outfile, "OptLevel          %s\n", options);
fprintf (outfile, "Run by            %s\n", general[7]);
fprintf (outfile, "From              %s\n", general[8]);
fprintf (outfile, "Mail              %s\n\n", general[0]);
fprintf(outfile, "Rolling            %s\n",ROLLING);
fprintf(outfile, "Precision          %s\n",PREC);
fprintf(outfile, "norm. resid        %16.1f\n",(double)residn);
fprintf(outfile, "resid              %16.8e\n",(double)resid);
fprintf(outfile, "machep             %16.8e\n",(double)epsn);
fprintf(outfile, "x[0]-1             %16.8e\n",(double)x1);
fprintf(outfile, "x[n-1]-1           %16.8e\n",(double)x2);
fprintf(outfile, "matgen 1 seconds   %16.5f\n",overhead1);
fprintf(outfile, "matgen 2 seconds   %16.5f\n",overhead2);
fprintf(outfile, "Repetitions        %16d\n",ntimes);
fprintf(outfile, "Leading dimension  %16d\n",lda);
fprintf(outfile, "                              dgefa     dgesl "
"    total    Mflops\n");
fprintf(outfile, "1 pass seconds     %16.5f %9.5f %9.5f\n",
atime[0][0], atime[1][0], atime[2][0]);
for (i=1 ; i<6 ; i++)
fprintf(outfile, "Repeat seconds     %16.5f %9.5f %9.5f %9.2f\n",
atime[0][i], atime[1][i], atime[2][i], atime[3][i]);
fprintf(outfile, "Average            %46.2f\n",atime[3][6]);
fprintf(outfile, "Leading dimension  %16d\n",ldaa);
for (i=7 ; i<12 ; i++)
fprintf(outfile, "Average            %46.2f\n\n",atime[3][12]);
fclose (outfile);
printf("\nPress any key\n");
Endit = getchar();
fprintf(stderr,"%11.5f%11.5f%11.5f%11.2f%11.4f%11.4f\n",   (double)atime[0][row],
(double)atime[1][row], (double)atime[2][row], (double)atime[3][row],
(double)atime[4][row], (double)atime[5][row]);
return;
/* We would like to declare a[][lda], but c does not allow it.  In this
  function, references to a[i][j] are written a[lda*i+j].  */
int init, i, j;
init = 1325;
*norma = 0.0;
for (j = 0; j < n; j++) {
init = 3125*init % 65536;
a[lda*j+i] = (init - 32768.0)/16384.0;
*norma = (a[lda*j+i] > *norma) ? a[lda*j+i] : *norma;
/* alternative for some compilers
  if (fabs(a[lda*j+i]) > *norma) *norma = fabs(a[lda*j+i]);
b[i] = 0.0;
b[i] = b[i] + a[lda*j+i];
return;
void dgefa(REAL a[], int lda, int n, int ipvt[], int *info)
  dgefa factors a double precision matrix by gaussian elimination.
  dgefa is usually called by dgeco, but it can be called
  directly with a saving in time if  rcond  is not needed.
  (time for dgeco) = (1 + 9/n)*(time for dgefa) .
  on entry
  a       REAL precision[n][lda]
  the matrix to be factored.
  lda     integer
  the leading dimension of the array  a .
  n       integer
  the order of the matrix  a .
  on return
  a       an upper triangular matrix and the multipliers
  which were used to obtain it.
  the factorization can be written  a = l*u  where
  l  is a product of permutation and unit lower
  triangular matrices and  u  is upper triangular.
  ipvt    integer[n]
  an integer vector of pivot indices.
  info    integer
  = 0  normal value.
  = k  if  u[k][k] .eq. 0.0 .  this is not an error
  condition for this subroutine, but it does
  indicate that dgesl or dgedi will divide by zero
  if called.  use  rcond  in dgeco for a reliable
  indication of singularity.
  linpack. this version dated 08/14/78 .
  cleve moler, university of new mexico, argonne national lab.
  functions
  blas daxpy,dscal,idamax
/*     internal variables       */
REAL t;
int j,k,kp1,l,nm1;
/*     gaussian elimination with partial pivoting       */
*info = 0;
nm1 = n - 1;
if (nm1 >=  0) {
for (k = 0; k < nm1; k++) {
kp1 = k + 1;
/* find l = pivot index */
l = idamax(n-k,&a[lda*k+k],1) + k;
ipvt[k] = l;
/* zero pivot implies this column already
  triangularized */
if (a[lda*k+l] != ZERO) {
/* interchange if necessary */
if (l != k) {
t = a[lda*k+l];
a[lda*k+l] = a[lda*k+k];
a[lda*k+k] = t;
/* compute multipliers */
t = -ONE/a[lda*k+k];
dscal(n-(k+1),t,&a[lda*k+k+1],1);
/* row elimination with column indexing */
for (j = kp1; j < n; j++) {
t = a[lda*j+l];
if (l != k) {
a[lda*j+l] = a[lda*j+k];
a[lda*j+k] = t;
daxpy(n-(k+1),t,&a[lda*k+k+1],1,
&a[lda*j+k+1],1);
else {
*info = k;
ipvt[n-1] = n-1;
if (a[lda*(n-1)+(n-1)] == ZERO) *info = n-1;
return;
void dgesl(REAL a[],int lda,int n,int ipvt[],REAL b[],int job )
  dgesl solves the double precision system
  a * x = b  or  trans(a) * x = b
  using the factors computed by dgeco or dgefa.
  on entry
  a       double precision[n][lda]
  the output from dgeco or dgefa.
  lda     integer
  n       integer
  ipvt    integer[n]
  the pivot vector from dgeco or dgefa.
  b       double precision[n]
  the right hand side vector.
  job     integer
  = 0         to solve  a*x = b ,
  = nonzero   to solve  trans(a)*x = b  where
  trans(a)  is the transpose.
  on return
  b       the solution vector  x .
  error condition
  a division by zero will occur if the input factor contains a
  zero on the diagonal.  technically this indicates singularity
  but it is often caused by improper arguments or improper
  setting of lda .  it will not occur if the subroutines are
  called correctly and if dgeco has set rcond .gt. 0.0
  or dgefa has set info .eq. 0 .
  to compute  inverse(a) * c  where  c  is a matrix
  with  p  columns
  dgeco(a,lda,n,ipvt,rcond,z)
  if (!rcond is too small){
  for (j=0,j<p,j++)
  dgesl(a,lda,n,ipvt,c[j][0],0);
  functions
  blas daxpy,ddot
REAL t;
int k,kb,l,nm1;
nm1 = n - 1;
if (job == 0) {
/* job = 0 , solve  a * x = b
  first solve  l*y = b         */
if (nm1 >= 1) {
l = ipvt[k];
t = b[l];
if (l != k){
b[l] = b[k];
b[k] = t;
daxpy(n-(k+1),t,&a[lda*k+k+1],1,&b[k+1],1 );
/* now solve  u*x = y */
for (kb = 0; kb < n; kb++) {
k = n - (kb + 1);
b[k] = b[k]/a[lda*k+k];
t = -b[k];
daxpy(k,t,&a[lda*k+0],1,&b[0],1 );
else {
/* job = nonzero, solve  trans(a) * x = b
  first solve  trans(u)*y = b                  */
for (k = 0; k < n; k++) {
t = ddot(k,&a[lda*k+0],1,&b[0],1);
b[k] = (b[k] - t)/a[lda*k+k];
/* now solve trans(l)*x = y     */
if (nm1 >= 1) {
for (kb = 1; kb < nm1; kb++) {
k = n - (kb+1);
b[k] = b[k] + ddot(n-(k+1),&a[lda*k+k+1],1,&b[k+1],1);
l = ipvt[k];
if (l != k) {
t = b[l];
b[l] = b[k];
b[k] = t;
return;
void daxpy(int n, REAL da, REAL dx[], int incx, REAL dy[], int incy)
  constant times a vector plus a vector.
  jack dongarra, linpack, 3/11/78.
int i,ix,iy,m,mp1;
mp1 = 0;
m = 0;
if(n <= 0) return;
if (da == ZERO) return;
if(incx != 1 || incy != 1) {
/* code for unequal increments or equal increments
  not equal to 1                                       */
ix = 0;
iy = 0;
if(incx < 0) ix = (-n+1)*incx;
if(incy < 0)iy = (-n+1)*incy;
for (i = 0;i < n; i++) {
dy[iy] = dy[iy] + da*dx[ix];
ix = ix + incx;
iy = iy + incy;
return;
/* code for both increments equal to 1 */
#ifdef ROLL
dy[i] = dy[i] + da*dx[i];
#ifdef UNROLL
m = n % 4;
if ( m != 0) {
for (i = 0; i < m; i++)
if (n < 4) return;
for (i = m; i < n; i = i + 4) {
dy[i+1] = dy[i+1] + da*dx[i+1];
dy[i+2] = dy[i+2] + da*dx[i+2];
dy[i+3] = dy[i+3] + da*dx[i+3];
return;
REAL ddot(int n, REAL dx[], int incx, REAL dy[], int incy)
  forms the dot product of two vectors.
REAL dtemp;
int i,ix,iy,m,mp1;
mp1 = 0;
m = 0;
dtemp = ZERO;
if(n <= 0) return(ZERO);
  not equal to 1                                       */
ix = 0;
iy = 0;
if (incx < 0) ix = (-n+1)*incx;
if (incy < 0) iy = (-n+1)*incy;
dtemp = dtemp + dx[ix]*dy[iy];
ix = ix + incx;
iy = iy + incy;
return(dtemp);
#ifdef ROLL
for (i=0;i < n; i++)
dtemp = dtemp + dx[i]*dy[i];
return(dtemp);
#ifdef UNROLL
m = n % 5;
if (m != 0) {
if (n < 5) return(dtemp);
for (i = m; i < n; i = i + 5) {
dtemp = dtemp + dx[i]*dy[i] +
dx[i+1]*dy[i+1] + dx[i+2]*dy[i+2] +
dx[i+3]*dy[i+3] + dx[i+4]*dy[i+4];
return(dtemp);
void dscal(int n, REAL da, REAL dx[], int incx)
/*     scales a vector by a constant.
int i,m,mp1,nincx;
mp1 = 0;
m = 0;
if(n <= 0)return;
if(incx != 1) {
/* code for increment not equal to 1 */
nincx = n*incx;
for (i = 0; i < nincx; i = i + incx)
dx[i] = da*dx[i];
return;
/* code for increment equal to 1 */
#ifdef ROLL
dx[i] = da*dx[i];
#ifdef UNROLL
m = n % 5;
if (m != 0) {
dx[i] = da*dx[i];
if (n < 5) return;
for (i = m; i < n; i = i + 5){
dx[i] = da*dx[i];
dx[i+1] = da*dx[i+1];
dx[i+2] = da*dx[i+2];
dx[i+3] = da*dx[i+3];
dx[i+4] = da*dx[i+4];
int idamax(int n, REAL dx[], int incx)
  finds the index of element having max. absolute value.
REAL dmax;
int i, ix, itemp;
if( n < 1 ) return(-1);
if(n ==1 ) return(0);
if(incx != 1) {
ix = 1;
dmax = fabs((double)dx[0]);
ix = ix + incx;
for (i = 1; i < n; i++) {
if(fabs((double)dx[ix]) > dmax)  {
itemp = i;
dmax = fabs((double)dx[ix]);
ix = ix + incx;
else {
itemp = 0;
if(fabs((double)dx[i]) > dmax) {
itemp = i;
dmax = fabs((double)dx[i]);
return (itemp);
  estimate unit roundoff in quantities of size x.
REAL a,b,c,eps;
  this program should function properly on all systems
  satisfying the following two assumptions,
  1.  the base used in representing dfloating point
  numbers is not a power of three.
  2.  the quantity  a  in statement 10 is represented to
  the accuracy used in dfloating point variables
  that are stored in memory.
  the statement number 10 and the go to 10 are intended to
  force optimizing compilers to generate code satisfying
  assumption 2.
  under these assumptions, it should be true that,
  a  is not exactly equal to four-thirds,
  b  has a zero for its last bit or digit,
  c  is not exactly equal to one,
  eps  measures the separation of 1.0 from
  the next larger dfloating point number.
  the developers of eispack would appreciate being informed
  about any systems where these assumptions do not hold.
this routine is one of the auxiliary routines used by eispack iii
to avoid machine dependencies.
this version dated 4/6/83.
a = 4.0e0/3.0e0;
eps = ZERO;
while (eps == ZERO) {
b = a - ONE;
c = b + b + b;
eps = fabs((double)(c-ONE));
return(eps*fabs((double)x));
/* We would like to declare m[][ldm], but c does not allow it.  In this
  function, references to m[i][j] are written m[ldm*i+j].  */
  purpose:
  multiply matrix m times vector x and add the result to vector y.
  parameters:
  n1 integer, number of elements in vector y, and number of rows in
  matrix m
  y double [n1], vector of length n1 to which is added
  the product m*x
  n2 integer, number of elements in vector x, and number of columns
  in matrix m
  ldm integer, leading dimension of array m
  x double [n2], vector of length n2
  m double [ldm][n2], matrix of n1 rows and n2 columns
int j,i,jmin;
/* cleanup odd vector */
j = n2 % 2;
if (j >= 1) {
j = j - 1;
for (i = 0; i < n1; i++)
y[i] = (y[i]) + x[j]*m[ldm*j+i];
/* cleanup odd group of two vectors */
j = n2 % 4;
if (j >= 2) {
j = j - 1;
y[i] = ( (y[i])
+ x[j-1]*m[ldm*(j-1)+i]) + x[j]*m[ldm*j+i];
/* cleanup odd group of four vectors */
j = n2 % 8;
if (j >= 4) {
j = j - 1;
y[i] = ((( (y[i])
+ x[j-3]*m[ldm*(j-3)+i])
+ x[j-2]*m[ldm*(j-2)+i])
/* cleanup odd group of eight vectors */
j = n2 % 16;
if (j >= 8) {
j = j - 1;
y[i] = ((((((( (y[i])
+ x[j-7]*m[ldm*(j-7)+i]) + x[j-6]*m[ldm*(j-6)+i])
+ x[j-5]*m[ldm*(j-5)+i]) + x[j-4]*m[ldm*(j-4)+i])
+ x[j-3]*m[ldm*(j-3)+i]) + x[j-2]*m[ldm*(j-2)+i])
+ x[j-1]*m[ldm*(j-1)+i]) + x[j]  *m[ldm*j+i];
/* main loop - groups of sixteen vectors */
jmin = (n2%16)+16;
for (j = jmin-1; j < n2; j = j + 16) {
y[i] = ((((((((((((((( (y[i])
+ x[j-15]*m[ldm*(j-15)+i])
+ x[j-14]*m[ldm*(j-14)+i])
+ x[j-13]*m[ldm*(j-13)+i])
+ x[j-12]*m[ldm*(j-12)+i])
+ x[j-11]*m[ldm*(j-11)+i])
+ x[j-10]*m[ldm*(j-10)+i])
+ x[j- 9]*m[ldm*(j- 9)+i])
+ x[j- 8]*m[ldm*(j- 8)+i])
+ x[j- 7]*m[ldm*(j- 7)+i])
+ x[j- 6]*m[ldm*(j- 6)+i])
+ x[j- 5]*m[ldm*(j- 5)+i])
+ x[j- 4]*m[ldm*(j- 4)+i])
+ x[j- 3]*m[ldm*(j- 3)+i])
+ x[j- 2]*m[ldm*(j- 2)+i])
+ x[j- 1]*m[ldm*(j- 1)+i])
+ x[j]   *m[ldm*j+i];
return;
楼主 #9 2020-09-22 09:38:06
henman
已发帖子: 23
然后侧重的比较了v3s和3516ev200,最后发现,3516ev200的浮点运算性能,真的是v3s的两倍还多一点。两个工具测算出来的比例是一样的。我觉得这个可能它们的fpu是不一样的。3516ev200的参数是-mfpu=neon-vfpv4,而v3s的参数是-mfpu=fpv4-sp-d16。
另外我还试过用海思的gcc编译,在全志上面跑,反正怎么折腾,全志的浮点性能就是起不来。
当然cpu性能不能光看浮点运算,但算法型的程序确实挺依赖浮点运算的。
至于针对主频的测试工具我还没有找到合适的。不知道有没有小伙伴有类似的技术或者代码?
#10 2020-09-22 14:56:25
Blueskull
已发帖子: 458
A7强制NEON和VFPv4,你试试全志开这个选项能不能跑。
#11 2020-09-22 15:17:33
hameyou
已发帖子: 208
可能是哪里没设置好吧,如果果真是这样,V3S的1.2G真是太虚了
#12 2020-09-22 15:46:41
已发帖子: 850
https://whycan.com/t_3148.html这是之前sysbench的测试结果,同样是1G频率,v3s竟然比pizerow还要慢,要知道pizerow可是arm11架构的
楼主 #13 2020-09-22 18:22:18
henman
已发帖子: 23
又做了一个实验,硬件不变,换了内核以及工具链,这个表现比海思好一些了:D,到底是为什么呢?
环境:
gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02)
Linux sun8i 3.4.39 #5 Tue Sep 22 18:06:11 CST 2020 armv7l GNU/Linux
arm-linux-gnueabi-gcc -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=fpv4-sp-d16 -mfloat-abi=soft -static -O2  main.c
结果:
DISPCNT 5000
Cnt 3997
Cnt 8040
Cnt 12118
Cnt 16227
4.210秒
#14 2020-09-23 00:03:01
zzm24
已发帖子: 122
我特意测试了一下,主线linux 4.13.16
/opt/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -O3 main.c
# ./a.out 5000
DISPCNT 5000
Cnt 4303
Cnt 8659
Cnt 13060
3.870秒
怀疑就是 -mfloat-abi=soft的问题,但是gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf无法使用-mfloat-abi=soft,所以无法测试
#15 2020-09-23 10:52:35
已发帖子: 850
树莓派zero的950mhz测试结果,由于pizero的硬浮点是VFPv2,比v3s落后,没有可比性参考一下即可
最近编辑记录 kekemuyu (2020-09-23 10:53:08)
#16 2020-09-23 11:04:34
yomkk
用手边的A20板子试了下, 频率 1.080GHz, 分别用带浮点和不带浮点两种方式跑了下。
user@M2:~$ gcc float_benchmark.c  -static -mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -O2
user@M2:~$ ./a.out 5000
DISPCNT 5000
Cnt 4683
Cnt 9442
Cnt 14255
3.547秒
DISPCNT 5000
Cnt 510
Cnt 1022
Cnt 1538
Cnt 15704
Cnt 16280
Cnt 16860
31.143秒
最近编辑记录 yomkk (2020-09-23 11:10:44)
#17 2020-09-24 08:34:28
linac
rts3905n是什么东东? 有datasheet吗? 难道有FPU?
不然的话,都用浮点库,性能比A7快这么多?
楼主 #18 2020-09-24 18:44:38
henman
已发帖子: 23
rts3905n是瑞昱的一款mips,主频600m。原厂说是硬浮点,默认开启,无需填写编译参数。
我现在都搞不懂v3s的性能到底是怎么了。我最近一直在编译3.4版本的内核,反正每次启动新内核我都会做一次测试,性能基本都在Cnt 4000的水平,暂时还摸不到性能下降的规律。
#19 2024-01-30 17:02:22
dsp2000
已发帖子: 28
@henman
现在确认性能了吗?
#20 2024-08-30 17:59:19
dsp2000
已发帖子: 28
ARM CortexTM-A7 MP1 Processor
 Thumb-2 Technology
 Support NEON Advanced SIMD(Single Instruction Multiple Data)instruction for acceleration of media and signal processing functions
 Support Large Physical Address Extensions(LPAE)
 VFPv4 Floating Point Unit
 32KB L1 Instruction cache and 32KB L1 Data cache
 128KB L2 cache
