楼主 #1 2020-10-27 20:46:07
hacker
根文件系统通过网络NFS挂载不成功,求助
用的是Orange Pi Win Plus,全志A64  开发环境为Ubuntu16.04  现在想通过tftp 下载内核和dtb,通过NFS挂载根文件系统。目前完成前半部分,但NFS挂载根文件系统一直不成功。。
    uboot启动log
U-Boot SPL 2020.10 (Oct 24 2020 - 18:25:06 +0800)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.3(debug):v2.3-842-gbd260fc
NOTICE:  BL31: Built : 18:21:47, Oct 24 2020
NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689)
NOTICE:  BL31: Found U-Boot DTB at 0x4094690, model: OrangePi Win/Win Plus
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP803 on RSB
INFO:    PMIC: dcdc1 voltage: 3.300V
INFO:    PMIC: dcdc5 voltage: 1.500V
INFO:    PMIC: dcdc6 voltage: 1.100V
INFO:    PMIC: dldo1 voltage: 3.300V
INFO:    PMIC: dldo2 voltage: 3.300V
INFO:    PMIC: dldo3 voltage: 3.300V
INFO:    PMIC: dldo4 voltage: 3.300V
INFO:    PMIC: fldo1 voltage: 1.200V
INFO:    PMIC: Enabling DC SW
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 843419 was applied
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
WARNING: BL31: cortex_a53: CPU workaround for 1530924 was missing!
NOTICE:  PSCI: System suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
alloc space exhausted
U-Boot 2020.10 (Oct 24 2020 - 18:25:06 +0800) Allwinner Technology
CPU:   Allwinner A64 (SUN50I)
Model: OrangePi Win/Win Plus
DRAM:  2 GiB
Loading Environment from FAT... OK
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
eth0: ethernet@1c30000
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
    uboot版本是2020.10,烧录在SD卡中,在uboot命令行下可以ping通服务器,uboot命令行printenv log如下
=> printenv
arch=arm
autoload=no
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=fel mmc0 usb0 pxe dhcp
bootargs=console=ttyS0,115200 root=/dev/nfs rw nfsroot=192.168.1.110:/work/nfs_root ip=192.168.1.105:192.168.1.110:192.168.1.253:255.255.255.0::eth0:off
bootcmd=tftp 0x40080000 Image; tftp 0x4FA00000 sun50i-a64-orangepi-win.dtb; booti 0x40080000 - 0x4FA00000
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=2
bootfile=boot.scr.uimg
bootfstype=fat
bootm_size=0xa000000
cpu=armv8
dfu_alt_info_ram=kernel ram 0x40080000 0x1000000;fdt ram 0x4FA00000 0x100000;ramdisk ram 0x4FE00000 0x4000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
dnsip=202.120.127.220
efi_dtb_prefixes=/ /dtb/ /dtb/current/
ethact=ethernet@1c30000
ethaddr=02:ba:35:13:ea:da
fdt_addr_r=0x4FA00000
fdtcontroladdr=b9f38fb0
fdtfile=allwinner/sun50i-a64-orangepi-win.dtb
fileaddr=41000000
filesize=2198
gatewayip=192.168.1.253
ipaddr=192.168.1.105
kernel_addr_r=0x40080000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmc_bootdev=0
netmask=255.255.255.0
partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system};
preboot=usb start
pxefile_addr_r=0x4FD00000
ramdisk_addr_r=0x4FE00000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x4FC00000
serial#=92c001ba3513eada
serverip=192.168.1.110
soc=sunxi
stderr=serial,vidconsole
stdin=serial,usbkbd
stdout=serial,vidconsole
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b
uuid_gpt_system=b921b045-1df0-41c3-af44-4c6f280d3fae
Environment size: 4696/131068 bytes
在uboot中通过nfs命令可以下载文件
=> nfs 0x41000000 192.168.1.110:/work/nfs_root/test
Using ethernet@1c30000 device
File transfer via NFS from server 192.168.1.110; our IP address is 192.168.1.105
Filename '/work/nfs_root/test'.
Load address: 0x41000000
Loading: ##
done
Bytes transferred = 8600 (2198 hex)
在另一台虚拟机中可以成功挂载我服务器中的共享文件夹的内容,服务器中共享文件夹的内容如下
root@book-virtual-machine:/work/nfs_root# ls
bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  srv  sys  test  tmp  usr  var
这样足以说明我内核中nfs配置和 服务器中NFS的搭建没问题吧。。
这是设置bootargs的命令:setenv bootargs 'console=ttyS0,115200 root=/dev/nfs rw nfsroot=192.168.1.110:/work/nfs_root ip=192.168.1.105:192.168.1.110:192.168.1.253:255.255.255.0::eth0:off'
启动后log如下:
=> boot
TFTP from server 192.168.1.110; our IP address is 192.168.1.105
Filename 'Image'.
Load address: 0x40080000
Loading: #################################################################
         ###T ##############################################################
         755.9 KiB/s
done
Bytes transferred = 15683592 (ef5008 hex)
Filename 'sun50i-a64-orangepi-win.dtb'.
Load address: 0x4fa00000
Loading: ###
         1023.4 KiB/s
done
Bytes transferred = 36702 (8f5e hex)
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
EHCI failed to shut down host controller.
   Loading Device Tree to 0000000049ff4000, end 0000000049ffff5d ... OK
[  111.584802] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[  111.593062] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 5.3.13+ #11
[  111.599144] Hardware name: OrangePi Win/Win Plus (DT)
[  111.604186] Call trace:
[  111.606640]  dump_backtrace+0x0/0x150
[  111.610301]  show_stack+0x14/0x20
[  111.613613]  dump_stack+0xb4/0xdc
[  111.616927]  panic+0x150/0x32c
[  111.619979]  mount_block_root+0x1a0/0x290
[  111.623983]  mount_root+0x144/0x178
[  111.627468]  prepare_namespace+0x13c/0x184
[  111.631559]  kernel_init_freeable+0x250/0x278
[  111.635913]  kernel_init+0x10/0x108
[  111.639398]  ret_from_fork+0x10/0x18
[  111.642972] SMP: stopping secondary CPUs
[  111.646890] Kernel Offset: disabled
[  111.650374] CPU features: 0x0002,24002004
[  111.654374] Memory Limit: none
[  111.657430] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) ]---
根文件系统是armbian SDK中的,另外我也尝试挂之前自己做的根文件系统两者都挂不上去。。我也尝试了这个帖子的方法https://whycan.com/t_1766.html
希望晕哥和各位大神帮帮小弟。。
#2 2020-10-27 21:14:08
孤星泪
已发帖子: 235
Re: 根文件系统通过网络NFS挂载不成功,求助
先挂tf卡根文件系统,确定linux协议栈和服务器能否ping通,然后命令行挂载nfs,都可以之后再转nfs根文件系统
