楼主 #1 2020-12-14 09:12:00
Kevincoooool
已发帖子: 39
全志H3点亮ST7789VW 240*240屏
记录一下第一次尝试用linux点亮spi屏幕的过程,一共尝试了0.96 ST7735S(80160) \1.8 st7735R(128160) \1.14 st7789v(135240) \1.3 st7789vw (240240)这几个屏幕,有个奇怪的现象就是必须要接SPI0的CS引脚到显示屏上才能正常显示。
设备树(sun8i-h3-nanopi-neo-air.dts)中禁用其他SPI节点和使能ST7789VW节点:
在最后加上以下代码,st7735r和st7735s也调试过可用,7735超过48M显示的颜色就不正常了,7789vw可以96M正常显示,原始的IO口是
DC PA1 RESET PG11 BL PA0
我改成了
DC PA1 RESET PA2 BL PA0
同时禁用hdmi,防止开机从hdmi显示
&spi0{
    spidev0:spi@0{
      status="disable";
    st7789vw: st7789vw@0{
    compatible = "sitronix,st7789vw";
    reg = <0>;
    spi-max-frequency = <96000000>;
    buswidth = <8>;
    rotate = <0>;
    fps = <60>;
    rgb;
    dc-gpios = <&pio 0 1 GPIO_ACTIVE_HIGH>;  /* PA1 */
    reset-gpios = <&pio 0 2 GPIO_ACTIVE_HIGH>; /* PA2*/
    led-gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;  /* PA0 */
    debug = <0x00>;
    // st7735r: st7735r@0{
    //     compatible = "sitronix,st7735r";
    //     reg = <0>;
    //     status = "okay";
    //     spi-max-frequency = <36000000>;
    //     spi-cpol;
    //     spi-cpha;
    //     rotate = <90>;
    //     fps = <60>;
    //     buswidth = <8>;
    //     dc-gpios = <&pio 0 1 GPIO_ACTIVE_HIGH>;  /* PA1 */
    //     reset-gpios = <&pio 0 2 GPIO_ACTIVE_HIGH>; /* PA2*/
    //     led-gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;  /* PA0 */
    //     debug = <0x0>;
    // st7735s: st7735s@0{
    //         compatible = "sitronix,st7735s";
    //         reg = <0>;
    //         status = "okay";
    //         spi-cpol;
    //         spi-cpha;
    //         rotate = <0>;
    //         fps = <60>;
    //         buswidth = <8>;
    //         reset-gpios = <&pio 0 2 GPIO_ACTIVE_HIGH>; /* PA2 */
    //         debug = <0x0>;
&hdmi {
  status = "disable";
修改初始化函数
原始的初始化没有复位显示屏,在初始化中添加
par->fbtftops.reset(par);
write_reg(par, PVGAMCTRL, 0xD0, 0x04, 0x0D, 0x11, 0x13, 0x2B, 0x3F, 0x54, 0x4C, 0x18, 0x0D, 0x0B, 0x1F, 0x23);
write_reg(par, NVGAMCTRL, 0xD0, 0x04, 0x0C, 0x11, 0x13, 0x2C, 0x3F, 0x44, 0x51, 0x2F, 0x1F, 0x1F, 0x20, 0x23);
static int init_display(struct fbtft_par *par)
    // /* turn off sleep mode */
    write_reg(par, MIPI_DCS_EXIT_SLEEP_MODE);
    mdelay(120);
    write_reg(par, MIPI_DCS_SET_ADDRESS_MODE, 0x0);
    write_reg(par, MIPI_DCS_SET_PIXEL_FORMAT, MIPI_DCS_PIXEL_FMT_16BIT);
    write_reg(par, PORCTRL, 0x0C, 0x0C, 0x00, 0x33, 0x33);
    write_reg(par, GCTRL, 0x35);
    write_reg(par, VCOMS, 0x19);
    write_reg(par, LCMCTRL, 0x2C);
    write_reg(par, VDVVRHEN, 0x01);
    write_reg(par, VRHS, 0x12);
    write_reg(par, VDVS, 0x20);
    write_reg(par, FRCTRL2, 0x0F);
    write_reg(par, PWCTRL1, 0xA4, 0xA1);
    write_reg(par, MIPI_DCS_ENTER_INVERT_MODE);
    write_reg(par, MIPI_DCS_SET_DISPLAY_ON);
    mdelay(120);
使用1.14(135*240)ips屏幕的注意修改函数set_addr_win
原始的函数没有纠正偏移量,增加以下代码(只有135*240的需要增加,其他的屏不需要):
switch(par->info->var.rotate)
        case   0: xs+=53;xe+=53;ys+=40;ye+=40;
                 break;
        case  90: xs+=40;xe+=40;ys+=53;ye+=53;
                 break;
        case 180: xs+=53;xe+=53;ys+=40;ye+=40;
                 break;
        case 270: xs+=40;xe+=40;ys+=53;ye+=53;
                 break;
        default :
                 break;
把驱动编译进内核
最原始的内核没有ST7789VW,只有ST7789V,所以把st7789v.c复制粘贴改名为st7789vw.c,相应驱动做一下修改,并且修改fbtft目录下的Kconfig和Makefile,这里我增加了ST7789VW和ST7735S的驱动
config FB_TFT_ST7789VW
    tristate "FB driver for the ST7789VW LCD Controller"
    depends on FB_TFT
    help
      This enables generic framebuffer support for the Sitronix ST7789VW
      display controller. The controller is intended for small color
      displays with a resolution of up to 240x240 pixels.
      Say Y if you have such a display that utilizes this controller.
再到menuconfig使能此驱动,
make menuconfig ARCH=arm CROSS_COMPILE=arm-linux- -j80
Device Drivers  --->
    [ * ] Staging drivers  --->
        < * >   Support for small TFT LCD display modules  --->
            < * >   FB driver for the ST7789VW LCD Controller
编译内核 设备树 下载重启看效果
make zImage dtbs ARCH=arm CROSS_COMPILE=arm-linux- -j80
网络更新内核
scp arch/arm/boot/zImage root@192.168.137.83:/boot
网络更新设备树
scp arch/arm/boot/dts/sun8i-h3-nanopi-neo-air.dtb root@192.168.137.83:/boot
实际效果
1.3寸 240*240 IPS效果:
显示
播放视频
mplayer badapple_320_240_15fps.avi -vo fbdev
视屏
运行QT
apt-get update && apt-get install git
git clone https://github.com/friendlyarm/matrix.git
cd matrix/demo/nanopi-status
./build.sh
./run.sh /dev/fb_st7789vw
QT
