#1 2021-01-06 14:57:50
feng888
累计积分: 27
V3s 下载到sdram 启动系统,卡在这里,如何排查问题?
[  146.164081] mmc0: card 9b0e removed
U-Boot SPL 2017.01-rc2 (Jan 06 2021 - 14:51:53)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2017.01-rc2 (Jan 06 2021 - 14:51:53 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
## Loading init Ramdisk from Legacy Image at 41a00000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    10522913 Bytes = 10 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Loading Ramdisk to 423f6000, end 42dff121 ... OK
   Loading Device Tree to 423f0000, end 423f542d ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.10.15-licheepi-zero (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #4 SMP Wed Jan 6 14:17:39 CST 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 14 pages/cpu @c3f63000 s24716 r8192 d24436 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk rw
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 44880K/65536K available (6144K kernel code, 194K rwdata, 1232K rodata, 1024K init, 252K bss, 20656K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
[    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
[    0.000000]       .data : 0xc0a00000 - 0xc0a30a00   ( 195 kB)
[    0.000000]        .bss : 0xc0a32000 - 0xc0a7104c   ( 253 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000017] Switching to timer-based delay loop, resolution 41ns
[    0.000139] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000345] Console: colour dummy device 80x30
[    0.000383] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000397] pid_max: default: 32768 minimum: 301
[    0.000531] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000543] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001250] CPU: Testing write buffer coherency: ok
[    0.001653] /cpus/cpu@0 missing clock-frequency property
[    0.001677] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002034] Setting up static identity map for 0x40100000 - 0x40100058
[    0.002774] smp: Bringing up secondary CPUs ...
[    0.002793] smp: Brought up 1 node, 1 CPU
[    0.002801] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002808] CPU: All CPU(s) started in SVC mode.
[    0.003573] devtmpfs: initialized
[    0.006462] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006767] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.006922] pinctrl core: initialized pinctrl subsystem
[    0.007929] NET: Registered protocol family 16
[    0.008353] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009552] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009567] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021143] SCSI subsystem initialized
[    0.021429] usbcore: registered new interface driver usbfs
[    0.021489] usbcore: registered new interface driver hub
[    0.021582] usbcore: registered new device driver usb
[    0.021810] pps_core: LinuxPPS API ver. 1 registered
[    0.021819] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.021841] PTP clock support registered
[    0.022054] Advanced Linux Sound Architecture Driver Initialized.
[    0.023854] clocksource: Switched to clocksource arch_sys_counter
[    0.034761] NET: Registered protocol family 2
[    0.035368] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.035399] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.035423] TCP: Hash tables configured (established 1024 bind 1024)
[    0.035508] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.035555] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.035786] NET: Registered protocol family 1
[    0.036402] RPC: Registered named UNIX socket transport module.
[    0.036420] RPC: Registered udp transport module.
[    0.036426] RPC: Registered tcp transport module.
[    0.036432] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.036738] Unpacking initramfs...
[    0.682378] Freeing initrd memory: 10280K
[    0.684526] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.693335] NFS: Registering the id_resolver key type
[    0.693381] Key type id_resolver registered
[    0.693389] Key type id_legacy registered
[    0.697580] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.697601] io scheduler noop registered
[    0.697608] io scheduler deadline registered
[    0.697800] io scheduler cfq registered (default)
[    0.701986] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.773745] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.777191] console [ttyS0] disabled
[    0.797471] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[    1.357892] console [ttyS0] enabled
[    1.363040] libphy: Fixed MDIO Bus: probed
[    1.367448] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.374024] ehci-platform: EHCI generic platform driver
[    1.379328] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.385550] ohci-platform: OHCI generic platform driver
[    1.391250] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.400680] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.409600] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.416506] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.421040] i2c /dev entries driver
[    1.425921] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.435471] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.503895] sunxi-mmc 1c0f000.mmc: base:0xc485f000 irq:23
[    1.563877] sunxi-mmc 1c10000.mmc: base:0xc4863000 irq:24
[    1.570184] usbcore: registered new interface driver usbhid
[    1.575839] usbhid: USB HID core driver
[    1.581175] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.589237] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.596380] NET: Registered protocol family 17
[    1.600936] Key type dns_resolver registered
[    1.605450] Registering SWP/SWPB emulation handler
[    1.618639] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.626623] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.632389] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.641629] hub 1-0:1.0: USB hub found
[    1.645591] hub 1-0:1.0: 1 port detected
[    1.650280] using random self ethernet address
[    1.654833] using random host ethernet address
[    1.660228] usb0: HOST MAC aa:2e:ed:f2:83:84
[    1.664676] usb0: MAC 9e:4b:88:92:c1:3d
[    1.668576] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.676103] g_cdc gadget: g_cdc ready
[    1.682159] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.691336] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 03:51:52 UTC (13912)
[    1.699914] vcc5v0: disabling
[    1.702890] ALSA device list:
[    1.705913]   #0: V3s Audio Codec
[    1.710656] Freeing unused kernel memory: 1024K
[    1.718737] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    1.735121] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    1.746029] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    1.758618] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    1.771584] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    1.781723] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    1.792163] mmc1: new high speed SDIO card at address 0001
[    5.985494] random: fast init done
#2 2021-01-06 15:09:58
raspberryman
累计积分: 262
Re: V3s 下载到sdram 启动系统,卡在这里,如何排查问题?
没有提示错误,敲回车有反应吗?
#3 2021-01-06 15:42:10
feng888
累计积分: 27
raspberryman 说:
没有提示错误,敲回车有反应吗?
敲回车没反应,插入SD卡可以提示卡容量
#4 2021-01-06 16:15:53
raspberryman
累计积分: 262
看日志,ramfs解压正常,为什么没有运行初始化进程呢?
