楼主 #1 2021-01-06 16:34:40
18842634439
hi3516 移动监测 sample_ive_md 例程程序梳理
sample_ive_md 程序梳理
     step 1: start vi vpss venc vo
     SAMPLE_COMM_IVE_StartViVpssVencVo
         SAMPLE_COMM_VI_GetSensorInfo
         SAMPLE_COMM_VI_GetComboDevBySensor
         SAMPLE_COMM_VI_GetSizeBySensor
             step  1: Init vb
        SAMPLE_COMM_IVE_VbInit
            SAMPLE_COMM_SYS_GetPicSize
            COMMON_GetPicBufferSize
            SAMPLE_COMM_SYS_Init
             step 2: Start vi
        SAMPLE_COMM_VI_SetParam
        SAMPLE_COMM_VI_StartVi
             step 3: Start vpss
        SAMPLE_COMM_IVE_StartVpss
            /*config vpss*/
            stVpssGrpAttr与astVpssChnAttr属性参数配置(结构体详见 VIO_ATTR_S.txt)
            SAMPLE_COMM_VPSS_Start
              step 4: Bind vpss to vi
         SAMPLE_COMM_VI_Bind_VPSS
         //Set vi frame
         HI_MPI_VI_GetChnAttr
         HI_MPI_VI_SetChnAttr
             step 5: Start Vo
         SAMPLE_COMM_IVE_StartVo
             SAMPLE_COMM_VO_StartDev
             SAMPLE_COMM_VO_HdmiStart
                 SAMPLE_COMM_VO_HdmiConvertSync
                 HI_MPI_HDMI_Init
                 HI_MPI_HDMI_Open
                 HI_MPI_HDMI_GetAttr
                 HI_MPI_HDMI_SetAttr
                 HI_MPI_HDMI_Start
             SAMPLE_COMM_VO_GetWH
             HI_MPI_VO_SetDisplayBufLen
             SAMPLE_COMM_VO_StartLayer
             SAMPLE_COMM_VO_StartChn
             SAMPLE_COMM_VO_StartMipiTx
             step 6: Start Venc
        SAMPLE_COMM_VENC_GetGopAttr        //VENC_GOPMODE_NORMALP
        SAMPLE_COMM_VENC_Start
                 step 1:  Creat Encode Chnl
            SAMPLE_COMM_VENC_Creat
                SAMPLE_COMM_VI_GetFrameRateBySensor
                 //Create Venc Channel
                stVencChnAttr参数配置
                /* the attribute of the venc chnl */
                typedef struct hiVENC_CHN_ATTR_S {
                    VENC_ATTR_S     stVencAttr;                   /* the attribute of video encoder */
                    VENC_RC_ATTR_S  stRcAttr;                     /* the attribute of rate  ctrl */
                    VENC_GOP_ATTR_S stGopAttr;                    /* the attribute of gop */
                    } VENC_CHN_ATTR_S;
                HI_MPI_VENC_CreateChn
                SAMPLE_COMM_VENC_CloseReEncode
                    HI_MPI_VENC_GetChnAttr
                    HI_MPI_VENC_GetRcParam
                    HI_MPI_VENC_SetRcParam
                 step 2:  Start Recv Venc Pictures
            HI_MPI_VENC_StartRecvFrame    //开启编码通道接收输入图像 允许指定接收帧数,超出指定的帧数后自动停止接收图像。
        SAMPLE_COMM_VENC_StartGetStream
            pthread_create(&gs_VencPid, 0, SAMPLE_COMM_VENC_GetVencStreamProc, (HI_VOID*)&gs_stPara);
        SAMPLE_COMM_VENC_Stop
        SAMPLE_COMM_IVE_StopVo
        SAMPLE_COMM_VI_UnBind_VPSS
        SAMPLE_COMM_IVE_StopVpss
        SAMPLE_COMM_VI_StopVi
        SAMPLE_COMM_SYS_Exit
     step 2: Init Md
     SAMPLE_IVE_Md_Init
         SAMPLE_COMM_IVE_CreateImage
         SAMPLE_COMM_IVE_CreateMemInfo
         //Set attr info
         HI_IVS_MD_Init
      step 3: Create work thread
    snprintf(acThreadName, 16, "IVE_MdProc");
    prctl(PR_SET_NAME, (unsigned long)acThreadName, 0,0,0);
    pthread_create(&s_hMdThread, 0, SAMPLE_IVE_MdProc, (HI_VOID *)&s_stMd);
        //Create chn
        HI_IVS_MD_CreateChn
        HI_MPI_VPSS_GetChnFrame    //用户获取一帧通道图像    ,用户从通道获取一帧处理完成的图像    mpp手册720页
        SAMPLE_COMM_IVE_DmaImage    //DMA帧信息以提供图像
            //fill src
            //fill dst
            HI_MPI_IVE_DMA    //创建直接内存访问任务,支持 快速拷贝 、 间隔拷贝 、 内存填充 可 实现数据从一块内存 快速拷 贝 到另一块内存 ,或者从一块内存有规律的拷贝一些数据到另一块内存,或者 对 一块内存 进行 填充 操作
                            //IVE_DMA_MODE_DIRECT_COPY    快速拷贝模式
            HI_MPI_IVE_Query
        HI_IVS_MD_Process    //移动侦测处理    HiIVS 15页
        SAMPLE_COMM_IVE_BlobToRect
         //Draw rect
         SAMPLE_COMM_VGS_FillRect
             HI_MPI_VGS_BeginJob    //启动一个job
             HI_MPI_VGS_AddCoverTask    //往一个已经启动的job添加打COVER task。
             HI_MPI_VGS_EndJob    //提交一个job。
         HI_MPI_VO_SendFrame    //将视频图像送入指定视频输出通道显示。
    SAMPLE_PAUSE();
    SAMPLE_IVE_Md_Uninit
    SAMPLE_COMM_IVE_StopViVpssVencVo
typedef struct hiSAMPLE_IVE_MD_S
    IVE_SRC_IMAGE_S astImg[SAMPLE_IVE_MD_IMAGE_NUM];    //#define SAMPLE_IVE_MD_IMAGE_NUM 2
    IVE_DST_MEM_INFO_S stBlob;
    MD_ATTR_S stMdAttr;
    SAMPLE_RECT_ARRAY_S stRegion;
}SAMPLE_IVE_MD_S;
/* Definition of the IVE_IMAGE_S. Added by Tan Bing, 2013-7-22. */
typedef struct hiIVE_IMAGE_S {
    HI_U64 au64PhyAddr[3];   /* RW;The physical address of the image */
    HI_U64 au64VirAddr[3];   /* RW;The virtual address of the image */
    HI_U32 au32Stride[3];    /* RW;The stride of the image */
    HI_U32 u32Width;         /* RW;The width of the image */
    HI_U32 u32Height;        /* RW;The height of the image */
    IVE_IMAGE_TYPE_E enType; /* RW;The type of the image */
} IVE_IMAGE_S;
* Definition of the IVE_MEM_INFO_S.This struct special purpose for input or ouput, such as Hist, CCL, ShiTomasi.
* Added by Chen Quanfu, 2013-7-23.
typedef struct hiIVE_MEM_INFO_S {
    HI_U64 u64PhyAddr; /* RW;The physical address of the memory */
    HI_U64 u64VirAddr; /* RW;The virtual address of the memory */
    HI_U32 u32Size;    /* RW;The size of memory */
} IVE_MEM_INFO_S;
* Definition of md attribute
typedef struct hiMD_ATTR_S {
    MD_ALG_MODE_E enAlgMode;         /* Md algorithm mode */
    IVE_SAD_MODE_E enSadMode;        /* Sad mode */
    IVE_SAD_OUT_CTRL_E enSadOutCtrl; /* Sad output ctrl */
    HI_U32 u32Width;                 /* Image width */
    HI_U32 u32Height;                /* Image height */
    HI_U16 u16SadThr;                /* Sad thresh */
    IVE_CCL_CTRL_S stCclCtrl;        /* Ccl ctrl */
    IVE_ADD_CTRL_S stAddCtrl;        /* Add ctrl */
} MD_ATTR_S;
typedef struct hiSAMPLE_RECT_ARRAY_S
    HI_U16 u16Num;
    SAMPLE_IVE_RECT_S astRect[IVE_RECT_NUM];
} SAMPLE_RECT_ARRAY_S;
typedef struct hiSAMPLE_IVE_RECT_S
    POINT_S astPoint[4];
} SAMPLE_IVE_RECT_S;
