楼主 #1 2021-01-06 22:27:45
feng888
已发帖子: 59
V3S linux 4.14-y 分支,如何支持声卡?
U-Boot SPL 2017.01-rc2 (Jan 06 2021 - 14:51:53)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2017.01-rc2 (Jan 06 2021 - 14:51:53 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
## Loading init Ramdisk from Legacy Image at 41a00000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    5851759 Bytes = 5.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Loading Ramdisk to 4286b000, end 42dffa6f ... OK
   Loading Device Tree to 42865000, end 4286ae7f ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.14-licheepi-zero (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #1 SMP Wed Jan 6 22:01:58 CST 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 16 pages/cpu @c3f5f000 s33740 r8192 d23604 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk rw
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 49300K/65536K available (6144K kernel code, 282K rwdata, 1468K rodata, 1024K init, 263K bss, 16236K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
[    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
[    0.000000]       .data : 0xc0a00000 - 0xc0a46ba0   ( 283 kB)
[    0.000000]        .bss : 0xc0a4d754 - 0xc0a8f364   ( 264 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000019] Switching to timer-based delay loop, resolution 41ns
[    0.000181] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000423] Console: colour dummy device 80x30
[    0.000463] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000479] pid_max: default: 32768 minimum: 301
[    0.000607] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000621] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001271] CPU: Testing write buffer coherency: ok
[    0.001655] /cpus/cpu@0 missing clock-frequency property
[    0.001679] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002127] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002301] Hierarchical SRCU implementation.
[    0.002807] smp: Bringing up secondary CPUs ...
[    0.002821] smp: Brought up 1 node, 1 CPU
[    0.002830] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002837] CPU: All CPU(s) started in SVC mode.
[    0.003599] devtmpfs: initialized
[    0.006863] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007174] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007202] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007378] pinctrl core: initialized pinctrl subsystem
[    0.008376] NET: Registered protocol family 16
[    0.008815] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009857] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009874] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.021664] SCSI subsystem initialized
[    0.021894] usbcore: registered new interface driver usbfs
[    0.021974] usbcore: registered new interface driver hub
[    0.022068] usbcore: registered new device driver usb
[    0.022303] pps_core: LinuxPPS API ver. 1 registered
[    0.022314] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.022337] PTP clock support registered
[    0.022515] Advanced Linux Sound Architecture Driver Initialized.
[    0.024182] clocksource: Switched to clocksource arch_sys_counter
[    0.033335] NET: Registered protocol family 2
[    0.033944] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.033980] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.034003] TCP: Hash tables configured (established 1024 bind 1024)
[    0.034125] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.034247] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.034471] NET: Registered protocol family 1
[    0.035147] RPC: Registered named UNIX socket transport module.
[    0.035169] RPC: Registered udp transport module.
[    0.035174] RPC: Registered tcp transport module.
[    0.035180] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.035453] Unpacking initramfs...
[    0.421555] Freeing initrd memory: 5716K
[    0.423171] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.429201] NFS: Registering the id_resolver key type
[    0.429252] Key type id_resolver registered
[    0.429259] Key type id_legacy registered
[    0.433044] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.433064] io scheduler noop registered
[    0.433072] io scheduler deadline registered
[    0.433384] io scheduler cfq registered (default)
[    0.433397] io scheduler mq-deadline registered
[    0.433404] io scheduler kyber registered
[    0.433968] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.437415] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.496703] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.499591] console [ttyS0] disabled
[    0.519861] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    1.100533] console [ttyS0] enabled
[    1.107241] libphy: Fixed MDIO Bus: probed
[    1.111791] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.117682] dwmac-sun8i 1c30000.ethernet: No regulator found
[    1.123407] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    1.129631] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.135332] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.142548] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.148215] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.155439] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.160398] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.167363] libphy: stmmac: probed
[    1.176292] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.182829] ehci-platform: EHCI generic platform driver
[    1.188454] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.194067] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.202080] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    1.234204] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.241276] hub 1-0:1.0: USB hub found
[    1.245216] hub 1-0:1.0: 1 port detected
[    1.249711] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.256039] ohci-platform: OHCI generic platform driver
[    1.261585] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.268306] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.276242] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.349180] hub 2-0:1.0: USB hub found
[    1.353001] hub 2-0:1.0: 1 port detected
[    1.359194] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.368712] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.377644] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.384546] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.389099] i2c /dev entries driver
[    1.393935] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.402912] IR NEC protocol handler initialized
[    1.407537] IR RC5(x/sz) protocol handler initialized
[    1.412585] IR RC6 protocol handler initialized
[    1.417137] IR JVC protocol handler initialized
[    1.421661] IR Sony protocol handler initialized
[    1.426286] IR SANYO protocol handler initialized
[    1.430984] IR Sharp protocol handler initialized
[    1.435691] IR MCE Keyboard/mouse protocol handler initialized
[    1.441515] IR XMP protocol handler initialized
[    1.446710] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.514221] sunxi-mmc 1c0f000.mmc: base:0xc4981000 irq:23
[    1.574215] sunxi-mmc 1c10000.mmc: base:0xc4985000 irq:24
[    1.580537] usbcore: registered new interface driver usbhid
[    1.586195] usbhid: USB HID core driver
[    1.591773] NET: Registered protocol family 17
[    1.596468] Key type dns_resolver registered
[    1.600875] Registering SWP/SWPB emulation handler
[    1.614694] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.626069] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.631832] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.640955] hub 3-0:1.0: USB hub found
[    1.644919] hub 3-0:1.0: 1 port detected
[    1.649909] using random self ethernet address
[    1.654473] using random host ethernet address
[    1.659795] usb0: HOST MAC 46:e2:0d:ae:eb:98
[    1.664113] usb0: MAC 56:23:ab:1a:96:c3
[    1.668109] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.675625] g_cdc gadget: g_cdc ready
[    1.679668] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 02:22:00 UTC (8520)
[    1.688167] vcc5v0: disabling
[    1.691148] ALSA device list:
[    1.694110]   No soundcards found.
[    1.699508] Freeing unused kernel memory: 1024K
[    1.708668] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    1.724276] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    1.735057] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    1.745302] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    1.754544] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    1.766862] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    1.776985] mmc1: new high speed SDIO card at address 0001
Starting logging: OK
Starting network: OK
/ # [  212.884243] random: crng init done
