#1 2021-02-03 14:33:30
wangweigang0
累计积分: 16
f1c200s添加keyboard_gpio失败
按照 https://whycan.com/p_18258.html 帖子,在f1c200上添加个按键。启动失败,如下:
[    1.327722] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE2 already requested by 1c20800.pinctrl:130; cannot claim for gpio-keys
[    1.339344] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-130 (gpio-keys) status -22
[    1.346832] suniv-f1c100s-pinctrl 1c20800.pinctrl: could not request pin 130 (PE2) from group PE2  on device 1c20800.pinctrl
[    1.358115] gpio-keys gpio-keys: Error applying setting, reverse things back
[    1.365197] gpio-keys: probe of gpio-keys failed with error -22
按键是pe2。
设备树
dtsi添加
            key_pins: key-pins {
                pins = "PE2";
                function = "gpio_in";
                drive = <0>;
                pull = <1>;
dts添加
    gpio-keys {
        compatible = "gpio-keys";
        pinctrl-names = "default";
        pinctrl-0 = <&key_pins>;
        #address-cells = <1>;
        #size-cells = <0>;
        autorepeat;
        button@0 {
                label = "Key ENTER1";
                linux,code = <KEY_ENTER>;
                gpios = <&pio 4 2 GPIO_ACTIVE_LOW>; /* PE2 */
大神帮看看
最近编辑记录 wangweigang0 (2021-02-03 14:34:00)
#2 2021-02-03 14:43:57
raspberryman
累计积分: 381
Re: f1c200s添加keyboard_gpio失败
已经在别处被使用
#3 2021-02-03 14:47:31
wangweigang0
累计积分: 16
1_MyDriver.rar帮看下呗,这是设备树文件,我已经把用到的地方删掉了。
最近编辑记录 wangweigang0 (2021-02-03 14:49:17)
#4 2021-02-03 14:55:54
raspberryman
累计积分: 381
删掉这一句试一试
#5 2021-02-03 15:07:44
wangweigang0
累计积分: 16
删掉也不行。直接打印这个。 中间的错误2句。
[    1.325136] hub 1-0:1.0: USB hub found
[    1.329164] hub 1-0:1.0: 1 port detected
[    1.335440] gpio-keys gpio-keys: failed to get gpio: -16
[    1.340956] gpio-keys: probe of gpio-keys failed with error -16
[    1.347878] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.365371] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
#6 2021-02-03 15:10:04
歌以咏志
累计积分: 201
#define EBUSY           16      /* Device or resource busy */
https://www-numi.fnal.gov/offline_software/srt_public_context/WebDocs/Errors/unix_system_errors.html
很可能是别处占用了
#7 2021-02-03 15:16:22
wangweigang0
累计积分: 16
帮看下1楼的问题,我照着之前的帖子改的。不知道为什么也不好使。这个-16应该是获取不到gpio导致的吧。
