页次: 1
上面的是开发板的音频设备
上面是开发板的mic和耳机原理图
请问各位大神怎样录音和播放声音??
v3s bsp 声卡还没解决,大神们都没办法了,是不是没有声卡驱动?如何查看内核有没有声卡驱动?
最近编辑记录 zhuacai (2021-02-21 21:13:46)
这样试试
amixer cset numid=1,iface=MIXER,name='Master Playback Volume' 63
amixer cset numid=17,iface=MIXER,name='Speaker Function' 0
aplay /root/2.wav
这样试试
aplay /root/2.wav
没有amixer 只有tinymix
# tinymix contents
Number of controls: 17
ctl type num name value
0 INT 1 Master Playback Volume 0 (range 0->63)
1 INT 1 Line Volume 24 (range 0->31)
2 INT 1 MIC1_G boost stage output mixer control 3 (range 0->7)
3 INT 1 MIC2_G boost stage output mixer control 3 (range 0->7)
4 INT 1 MIC1 boost AMP gain control 4 (range 0->7)
5 INT 1 MIC2 boost AMP gain control 4 (range 0->7)
6 INT 1 ADC input gain ctrl 3 (range 0->7)
7 BOOL 1 Audio headphone out Off
8 BOOL 1 Audio speaker out Off
9 BOOL 1 Audio main mic Off
10 BOOL 1 Audio sub mic Off
11 ENUM 1 Audio record source , mic1mic2headsetmicmic3linein
12 BOOL 1 Audio noise reduced Off
13 BOOL 1 Audio linein Off
14 BOOL 1 Audio capture route switch Off
15 BOOL 1 Audio clear path Off
16 ENUM 1 Speaker Function headset, spkheadset-spk
# tinymix set 1 24;tinymix set 16 1;tinyplay 14_00.wav
failed to open for pcm 0,0
failed to open for pcm 0,0是没有声卡驱吗?
最近编辑记录 zhuacai (2021-02-22 10:41:35)
没有使能导致的?
10 BOOL 1 Audio sub mic Off没有使能导致的?
以上使能了不是报错
应该需要在内核中使能驱动,v3s没搞过,我只能猜一猜。
底层用的什么,ALSA?然后你make menuconfig看看是不是打开了?
实在不行dmesg把内核错误信息贴一下,好让别的高手判断问题。
alsa在内核已打开了
下面是启动信息请大神帮忙看看是什么问题播放没有声音?
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 84a94703bad64632614d7c383e4ed8fae32e1644
fel flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x80000000
rtc[7] value = 0x00000004
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 360 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
dram size =64
card boot number = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2014-12-10 21:20:39
[mmc]: ***Try SD card 0***
[mmc]: SD/MMC Card: 4bit, capacity: 30728MB
[mmc]: vendor: Man 006f0303 Snr aa00334c
[mmc]: product: CBADS
[mmc]: revision: 1.0
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000ac000.
sum=360afe50
src_sum=360afe50
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
[ 0.310]
U-Boot 2011.09-rc1-00000-g84a9470-dirty (Apr 12 2020 - 09:03:08) Allwinner Technology
[ 0.319]version: 1.1.0
[ 0.322]uboot commit : 84a94703bad64632614d7c383e4ed8fae32e1644
[ 0.332]pmbus: ready
[url]http://www.csgsm.com[/url] 18144070918 [url]http://cstx.taobao.com[/url]
not set main pmu id
axp_probe error
[ 0.373]PMU: pll1 408 Mhz,PLL6=600 Mhz
AXI=204 Mhz,AHB=204 Mhz, APB1=102 Mhz
set power on vol to default
dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
find power_sply to end
vbus exist
no battery, limit to dc
no key input
dram_para_set start
dram_para_set end
[ 0.504]DRAM: 64 MiB
relocation Offset is: 0309c000
save config for small mem_size
workmode = 0
storage type = 1
MMC: 0
[ 0.603][mmc]: mmc driver ver 2015-04-13 14:50:00
[ 0.608][mmc]: get sdc_phy_wipe fail.
[ 0.612][mmc]: get sdc0 sdc_erase fail.
[ 0.616][mmc]: get sdc_f_max fail,use default 50000000Hz
[ 0.621][mmc]: get sdc_ex_dly_used fail,use default dly
[ 0.626][mmc]: SUNXI SD/MMC: 0
[ 0.638][mmc]: *Try SD card 0*
[ 0.673][mmc]: CID 0x6f030343 0x42414453 0x10aa0033 0x4c012599
[ 0.678][mmc]: mmc clk 50000000
[ 0.682][mmc]: SD/MMC Card: 4bit, capacity: 30728MB
[ 0.687][mmc]: boot0 capacity: 0KB,boot1 capacity: 0KB
[ 0.692][mmc]: ***SD/MMC 0 init OK!!!***
[ 0.697][mmc]: erase_grp_size:0x1WrBlk * 0x200 = 0x200 Byte
[ 0.702][mmc]: secure_feature 0x0
[ 0.706][mmc]: secure_removal_type 0x0
[ 0.710]sunxi flash init ok
In: serial
Out: serial
Err: serial
-total partitions:5-
-name- -start- -size-
bootloader : 100000 800000
env : 900000 80000
boot : 980000 800000
system : 1180000 20000000
UDISK : 21180000 0
base bootcmd=run bootcmd_mmc_linux
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run bootcmd_mmc_linux
Net: eth0Warning: failed to set MAC address
WORK_MODE_BOOT
board_status_probe
adver not need show
sunxi_bmp_logo_display
** Unable to read "bootlogo.bmp" from sunxi_flash 0:1 **
sunxi bmp info error : unable to open logo file bootlogo.bmp
[ 0.792][mmc]: blkcnt should not be 0
read bootlogo partition fail,start_block=0x0,rblock=0x0 ,ret=0
Not a JPG file ?
parse_header failed
Use decode 2x1 sampling
sunxi_read_bootlogo: jpg convert argb
[ 0.810]Hit any key to stop autoboot: 0
## Booting kernel from Legacy Image at 40007800 ...
Image Name: Linux-3.4.39
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3842672 Bytes = 3.7 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
para err in disp_ioctl, cmd = 0xa,screen id = 1
[ 2.269][mmc]: MMC Device 2 not found
[ 2.273][mmc]: mmc not find,so not exit
reload config to 0x43000000
[ 2.277]
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.39 (root@f86a38b1f09d) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #68 Tue Feb 16 09:46:58 UTC 2021
[ 0.000000] Machine: sun8i
[ 0.000000] ion_reserve_common: ion reserve: [0x42e00000, 0x44000000]!
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c078d928, node_mem_map c07cb000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16256 pages, LIFO batch:3
[ 0.000000] script_init enter!
[ 0.000000] script_init exit!
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p7 init=/init loglevel=8 partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:UDISK@mmcblk0p1 mac_addr= uid=8882f574-3e53-45 fb_base=0x43e80000
[ 0.000000] Memory: 64MB = 64MB total
[ 0.000000] Memory: 38340k/38340k available, 27196k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06d9000 (6980 kB)
[ 0.000000] .init : 0xc06d9000 - 0xc0705000 ( 176 kB)
[ 0.000000] .data : 0xc0706000 - 0xc078e060 ( 545 kB)
[ 0.000000] .bss : 0xc078e084 - 0xc07ca1c0 ( 241 kB)
[ 0.000000] NR_IRQS:544
[ 0.000000] 524 ahb1 set parent pll_periph0d2
[ 0.000000] Architected local timer running at 24.00MHz.
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000264] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[ 0.000312] pid_max: default: 32768 minimum: 301
[ 0.000573] Mount-cache hash table entries: 512
[ 0.001456] CPU: Testing write buffer coherency: ok
[ 0.001827] Setting up static identity map for 0x4050a550 - 0x4050a5a8
[ 0.002892] devtmpfs: initialized
[ 0.006560] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006925] pinctrl core: initialized pinctrl subsystem
[ 0.007792] NET: Registered protocol family 16
[ 0.008570] DMA: preallocated 128 KiB pool for atomic coherent allocations
[ 0.008662] script_sysfs_init success
[ 0.008739] sunxi_dump_init success
[ 0.010398] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[ 0.012148] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[ 0.013527] tsc2003 device registered
[ 0.014101] [sunxi-module]: [sunxi-module.0] probe success
[ 0.014185] script config pll_isp to 360 Mhz
[ 0.014236] Not Found clk pll_video in script
[ 0.014265] script config pll_ve to 360 Mhz
[ 0.014303] Not Found clk pll_periph0 in script
[ 0.014323] Not Found clk pll_de in script
[ 0.014339] sunxi_default_clk_init
[ 0.014355] try to set pll6ahb1 to 200000000
[ 0.014377] Error not get clk pll6ahb1
[ 0.014404] Error not get clk pll6ahb1try to set ahb1 to 200000000
[ 0.014445] try to set apb1 to 100000000
[ 0.015117] ===fe3o4==== sunxi_root_procfs_attach ret:0
[ 0.029124] bio: create slab <bio-0> at 0
[ 0.029566] pwm module init!
[ 0.032647] ion_mem.size = 18874368
[ 0.033676] SCSI subsystem initialized
[ 0.034120] usbcore: registered new interface driver usbfs
[ 0.034283] usbcore: registered new interface driver hub
[ 0.034522] usbcore: registered new device driver usb
[ 0.034776] twi_chan_cfg()341 - [twi0] has no twi_speed!
[ 0.034801] twi_chan_cfg()352 - [twi0] has no twi_regulator.
[ 0.034828] twi_chan_cfg()341 - [twi1] has no twi_speed!
[ 0.034851] twi_chan_cfg()352 - [twi1] has no twi_regulator.
[ 0.035796] Linux video capture interface: v2.00
[ 0.036249] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.037874] cfg80211: Calling CRDA to update world regulatory domain
[ 0.040076] Switching to clocksource arch_sys_counter
[ 0.059339] NET: Registered protocol family 2
[ 0.059841] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060792] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.060902] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.060969] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.060993] TCP: reno registered
[ 0.061018] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.061063] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.061572] NET: Registered protocol family 1
[ 0.062147] RPC: Registered named UNIX socket transport module.
[ 0.062174] RPC: Registered udp transport module.
[ 0.062193] RPC: Registered tcp transport module.
[ 0.062212] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.062864] [pm]aw_pm_init!
[ 0.062890] standby_mode = 1.
[ 0.062908] wakeup src cnt is : 3.
[ 0.063008] sunxi_reg_init enter
[ 0.065602] VFS: Disk quotas dquot_6.5.2
[ 0.065723] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.066519] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.067132] NTFS driver 2.1.30 [Flags: R/W].
[ 0.067314] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.067764] msgmni has been set to 74
[ 0.070338] io scheduler noop registered
[ 0.070366] io scheduler deadline registered
[ 0.070520] io scheduler cfq registered (default)
[ 0.070701] [DISP]disp_module_init
[ 0.071483] cmdline,disp=
[ 0.071790] rotation_sw module is config as no used
[ 0.071847] [DISP] disp_get_rotation_sw,line:78:disp 0 out of range? g_rot_sw=0
[ 0.071880] [DISP] disp_init_connections,line:289:NULL pointer: 0, 0
[ 0.072047] fb_para.width = 0,fb_para.height = 0,fb_para.buffer_num = 2
[ 0.072076] [DISP] display_fb_request,line:1142:invalid paras xres(0), yres(0) bpp(32)
[ 0.075910] [DISP] lcd_clk_config,line:888:disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
[ 0.075956] clk real:pll(168000000),clk(42000000),dclk(4200000) dsi_rate(0)
[ 0.076253] Division by zero in kernel.
[ 0.076270] Backtrace:
[ 0.076337] [<c0013490>] (dump_backtrace+0x0/0x110) from [<c0503268>] (dump_stack+0x18/0x1c)
[ 0.076368] r6:c29a2178 r5:c29a2080 r4:00000000 r3:c0718480
[ 0.076432] [<c0503250>] (dump_stack+0x0/0x1c) from [<c00135b8>] (__div0+0x18/0x20)
[ 0.076482] [<c00135a0>] (__div0+0x0/0x20) from [<c01c7030>] (Ldiv0+0x8/0x10)
[ 0.076538] [<c0209748>] (disp_al_lcd_cfg+0x0/0x148) from [<c01fb71c>] (disp_lcd_enable+0x188/0x2bc)
[ 0.076567] r7:00000000 r6:00001630 r5:c2996400 r4:c29a2000
[ 0.076633] [<c01fb594>] (disp_lcd_enable+0x0/0x2bc) from [<c01f71fc>] (disp_device_attached_and_enable+0x120/0x20c)
[ 0.076664] r7:00000000 r6:00000000 r5:00000001 r4:c01fb594
[ 0.076724] [<c01f70dc>] (disp_device_attached_and_enable+0x0/0x20c) from [<c01f73d8>] (bsp_disp_device_switch+0x28/0x70)
[ 0.076780] [<c01f73b0>] (bsp_disp_device_switch+0x0/0x70) from [<c01eeeb4>] (start_work+0x16c/0x1f4)
[ 0.076836] [<c01eed48>] (start_work+0x0/0x1f4) from [<c0042264>] (process_one_work+0x1e0/0x338)
[ 0.076889] [<c0042084>] (process_one_work+0x0/0x338) from [<c0043044>] (worker_thread+0x1c0/0x2c8)
[ 0.076941] [<c0042e84>] (worker_thread+0x0/0x2c8) from [<c00468f4>] (kthread+0x94/0xa0)
[ 0.076987] [<c0046860>] (kthread+0x0/0xa0) from [<c0031bf8>] (do_exit+0x0/0x660)
[ 0.077013] r6:c0031bf8 r5:c0046860 r4:c2831ed8
[ 0.077043] Division by zero in kernel.
[ 0.077057] Backtrace:
[ 0.077101] [<c0013490>] (dump_backtrace+0x0/0x110) from [<c0503268>] (dump_stack+0x18/0x1c)
[ 0.077129] r6:c29a2178 r5:c29a2080 r4:00000000 r3:c0718480
[ 0.077191] [<c0503250>] (dump_stack+0x0/0x1c) from [<c00135b8>] (__div0+0x18/0x20)
[ 0.077238] [<c00135a0>] (__div0+0x0/0x20) from [<c01c7030>] (Ldiv0+0x8/0x10)
[ 0.077288] [<c0209748>] (disp_al_lcd_cfg+0x0/0x148) from [<c01fb71c>] (disp_lcd_enable+0x188/0x2bc)
[ 0.077318] r7:00000000 r6:00001630 r5:c2996400 r4:c29a2000
[ 0.077381] [<c01fb594>] (disp_lcd_enable+0x0/0x2bc) from [<c01f71fc>] (disp_device_attached_and_enable+0x120/0x20c)
[ 0.077412] r7:00000000 r6:00000000 r5:00000001 r4:c01fb594
[ 0.077472] [<c01f70dc>] (disp_device_attached_and_enable+0x0/0x20c) from [<c01f73d8>] (bsp_disp_device_switch+0x28/0x70)
[ 0.077526] [<c01f73b0>] (bsp_disp_device_switch+0x0/0x70) from [<c01eeeb4>] (start_work+0x16c/0x1f4)
[ 0.077579] [<c01eed48>] (start_work+0x0/0x1f4) from [<c0042264>] (process_one_work+0x1e0/0x338)
[ 0.077630] [<c0042084>] (process_one_work+0x0/0x338) from [<c0043044>] (worker_thread+0x1c0/0x2c8)
[ 0.077679] [<c0042e84>] (worker_thread+0x0/0x2c8) from [<c00468f4>] (kthread+0x94/0xa0)
[ 0.077723] [<c0046860>] (kthread+0x0/0xa0) from [<c0031bf8>] (do_exit+0x0/0x660)
[ 0.077750] r6:c0031bf8 r5:c0046860 r4:c2831ed8
[ 0.077817] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[ 0.078089] [DISP]disp_module_init finish
[ 0.078872] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[ 0.078915] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[ 0.079664] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 0.079695] sw_uart_pm()890 - uart0 clk is already enable
[ 0.079736] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[ 0.176773] console [ttyS0] enabled
[ 1.115248] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 1.124551] [NAND]nand init start, spinand_used_flag is 0
[ 1.130691] spinand_cache_level err! 0spinand_capacity_level err! 0
[ 1.137729] [NAND]spinand driver is disabled
[ 1.143092] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[ 1.151289] spi spi0: master is unqueued, this is deprecated
[ 1.159317] usbcore: registered new interface driver rtl8192cu
[ 1.166109] usbcore: registered new interface driver rndis_wlan
[ 1.172928] usbcore: registered new interface driver rt2500usb
[ 1.179603] usbcore: registered new interface driver rt73usb
[ 1.186138] usbcore: registered new interface driver rt2800usb
[ 1.192816] usbcore: registered new interface driver asix
[ 1.199018] usbcore: registered new interface driver qf9700
[ 1.205408] usbcore: registered new interface driver cdc_ether
[ 1.212049] [DISP] disp_lcd_pwm_enable,line:1023:pwm device hdl is NULL
[ 1.219608] usbcore: registered new interface driver net1080
[ 1.226087] usbcore: registered new interface driver rndis_host
[ 1.232864] usbcore: registered new interface driver cdc_subset
[ 1.239584] usbcore: registered new interface driver zaurus
[ 1.246031] usbcore: registered new interface driver cdc_ncm
[ 1.252437] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.279881] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.288922] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[ 1.297604] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[ 1.320069] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[ 1.326715] ehci_irq: highspeed device connect
[ 1.333038] hub 1-0:1.0: USB hub found
[ 1.337278] hub 1-0:1.0: 1 port detected
[ 1.342553] sunxi-ehci sunxi-ehci.1: remove, state 1
[ 1.348143] usb usb1: USB disconnect, device number 1
[ 1.355398] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[ 1.371844] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.398898] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.407548] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[ 1.416118] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[ 1.485218] hub 1-0:1.0: USB hub found
[ 1.489458] hub 1-0:1.0: 1 port detected
[ 1.494635] sunxi-ohci sunxi-ohci.1: remove, state 1
[ 1.500295] usb usb1: USB disconnect, device number 1
[ 1.507039] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[ 1.523470] Initializing USB Mass Storage driver...
[ 1.529125] usbcore: registered new interface driver usb-storage
[ 1.535924] USB Mass Storage support registered.
[ 1.541220] usbcore: registered new interface driver ums-cypress
[ 1.548031] usbcore: registered new interface driver ums_eneub6250
[ 1.555095] usbcore: registered new interface driver ums-freecom
[ 1.561960] usbcore: registered new interface driver ums-isd200
[ 1.568698] usbcore: registered new interface driver ums-jumpshot
[ 1.575686] usbcore: registered new interface driver ums-realtek
[ 1.582548] usbcore: registered new interface driver ums-sddr09
[ 1.589288] usbcore: registered new interface driver ums-sddr55
[ 1.596021] usbcore: registered new interface driver ums-usbat
[ 1.603257] file system registered
[ 1.610176] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.617901] android_usb gadget: Number of LUNs=1
[ 1.623114] lun0: LUN: removable file: (no medium)
[ 1.629516] android_usb gadget: android_usb ready
[ 1.635466] mousedev: PS/2 mouse device common for all mice
[ 1.641942] sunxikbd_script_init: key para not found, used default para.
[ 1.651353] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.659121] uvcvideo: Adding mapping Brightness to control 00000000-0000-0000-0000-000000000101/2.
[ 1.669236] uvcvideo: Adding mapping Contrast to control 00000000-0000-0000-0000-000000000101/3.
[ 1.679115] uvcvideo: Adding mapping Hue to control 00000000-0000-0000-0000-000000000101/6.
[ 1.688504] uvcvideo: Adding mapping Saturation to control 00000000-0000-0000-0000-000000000101/7.
[ 1.698574] uvcvideo: Adding mapping Sharpness to control 00000000-0000-0000-0000-000000000101/8.
[ 1.708546] uvcvideo: Adding mapping Gamma to control 00000000-0000-0000-0000-000000000101/9.
[ 1.718130] uvcvideo: Adding mapping Backlight Compensation to control 00000000-0000-0000-0000-000000000101/1.
[ 1.729370] uvcvideo: Adding mapping Gain to control 00000000-0000-0000-0000-000000000101/4.
[ 1.738858] uvcvideo: Adding mapping Power Line Frequency to control 00000000-0000-0000-0000-000000000101/5.
[ 1.749904] uvcvideo: Adding mapping Hue, Auto to control 00000000-0000-0000-0000-000000000101/16.
[ 1.759979] uvcvideo: Adding mapping Exposure, Auto to control 00000000-0000-0000-0000-000000000001/2.
[ 1.770449] uvcvideo: Adding mapping Exposure, Auto Priority to control 00000000-0000-0000-0000-000000000001/3.
[ 1.781793] uvcvideo: Adding mapping Exposure (Absolute) to control 00000000-0000-0000-0000-000000000001/4.
[ 1.792743] uvcvideo: Adding mapping White Balance Temperature, Auto to control 00000000-0000-0000-0000-000000000101/11.
[ 1.804959] uvcvideo: Adding mapping White Balance Temperature to control 00000000-0000-0000-0000-000000000101/10.
[ 1.816591] uvcvideo: Adding mapping White Balance Component, Auto to control 00000000-0000-0000-0000-000000000101/13.
[ 1.828611] uvcvideo: Adding mapping White Balance Blue Component to control 00000000-0000-0000-0000-000000000101/12.
[ 1.840534] uvcvideo: Adding mapping White Balance Red Component to control 00000000-0000-0000-0000-000000000101/12.
[ 1.852365] uvcvideo: Adding mapping Focus (absolute) to control 00000000-0000-0000-0000-000000000001/6.
[ 1.863030] uvcvideo: Adding mapping Focus, Auto to control 00000000-0000-0000-0000-000000000001/8.
[ 1.873206] uvcvideo: Adding mapping Zoom, Absolute to control 00000000-0000-0000-0000-000000000001/11.
[ 1.883772] uvcvideo: Adding mapping Zoom, Continuous to control 00000000-0000-0000-0000-000000000001/12.
[ 1.894535] uvcvideo: Adding mapping Privacy to control 00000000-0000-0000-0000-000000000001/17.
[ 1.904572] usbcore: registered new interface driver uvcvideo
[ 1.911072] USB Video Class driver (v1.0.8_SONiX_v2.6.36.04)
[ 1.917654] sunxi cedar version 0.1
[ 1.921793] [cedar]: install start!!!
[ 1.926325] [cedar]: install end!!!
[ 1.930347] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[ 1.937684] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[ 1.949164] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[ 1.956763] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[ 1.963040] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[ 1.972508] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Mar 18 2020 at 19:15:10
[ 1.984052] [mmc]: get mmc0's sdc_power failed
[ 1.989101] [mmc]: get mmc1's sdc_power failed
[ 1.994149] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[ 2.002783] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.013941] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.024703] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.034636] [mmc]: sdc0 power_supply is null
[ 2.044004] sunxi_leds_fetch_sysconfig_para leds is not used in config
[ 2.051402] =========script_get_err============
[ 2.056878] usbcore: registered new interface driver usbhid
[ 2.063209] usbhid: USB HID core driver
[ 2.067559] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.078516] usbcore: registered new interface driver snd-usb-audio
[ 2.087189] [audiocodec] mic1_mic3_used type err!
[ 2.092666] script_get_item return type err, consider it no ldo
[ 2.099306] script_get_item return audio_pa_ctrl type err
[ 2.107165] asoc: sndcodec <-> sunxi-codec mapping ok
[ 2.114419] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[ 2.125399] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[ 2.135331] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 52, RTO !!
[ 2.143584] [DAUDIO0] driver not init,just return.
[ 2.149203] Netfilter messages via NETLINK v0.30.
[ 2.154533] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 52, RTO !!
[ 2.162801] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.173097] nfnl_acct: registering with nfnetlink.
[ 2.178586] nf_conntrack version 0.5.0 (599 buckets, 2396 max)
[ 2.187867] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.198651] ctnetlink v0.93: registering with nfnetlink.
[ 2.204781] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.212620] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.220763] *******************Try sdio*******************
[ 2.227182] xt_time: kernel timezone is -0000
[ 2.232133] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 5, RTO !!
[ 2.240325] ip_set: protocol 6
[ 2.243760] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 5, RTO !!
[ 2.252739] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 5, RTO !!
[ 2.261093] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.267070] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 5, RTO !!
[ 2.275241] *******************Try sd *******************
[ 2.281786] arp_tables: (C) 2002 David S. Miller
[ 2.287087] TCP: cubic registered
[ 2.291245] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.301600] NET: Registered protocol family 10
[ 2.308298] IPv6 over IPv4 tunneling driver
[ 2.313367] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.324943] NET: Registered protocol family 17
[ 2.330592] ThumbEE CPU extension supported.
[ 2.336700] Registering SWP/SWPB emulation handler
[ 2.343179] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.355705] =====ctp_fetch_sysconfig_para=====.
[ 2.360980] ctp_fetch_sysconfig_para: ctp_unused.
[ 2.366355] =========script_get_item_err============
[ 2.371945] goodix_ts_init: ctp_fetch_sysconfig_para err.
[ 2.379359] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 12:33:37 UTC (45217)
[ 2.391308] [rf_pm]: Did not config module_power0 in sys_config
[ 2.397969] [rf_pm]: Did not config module_power1 in sys_config
[ 2.404678] [rf_pm]: Did not config module_power2 in sys_config
[ 2.411344] [rf_pm]: Did not config module_power3 in sys_config
[ 2.417981] [rf_pm]: mod has no chip_en gpio
[ 2.422786] [rf_pm]: failed to fetch lpo_use_apclk
[ 2.428156] [rf_pm]: regulator on.
[ 2.431989] [wifi_pm]: no wifi used in configuration
[ 2.437564]
[ 2.437571] *****Mar 18 2020 19:15:26 EAGLE DRIVER VER:75be56bfbaf7*****
[ 2.437586]
[ 2.448685] @@@@@@@@@@@@@@@V3S LINUX @@@@@@@@@@@@@@@@@@@
[ 2.455019] struct PIO_Struct size : 36[mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 2.482412] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[ 2.492994] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[ 2.503611] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[ 2.514174] mmc0: new high speed SDHC card at address b368
[ 2.521012] mmcblk0: mmc0:b368 CBADS 30.0 GiB
[ 2.528175] mmcblk0: p1 p2 p3 < p5 p6 p7 >
[ 2.535630] mmcblk mmc0:b368: Card claimed for testing.
[ 2.541575] mmc0:b368: CBADS 30.0 GiB
[ 2.545865] *******************sd init ok*******************
[ 3.970061] ####################EASY BOARD####################
[ 3.976612] =======================================================
[ 3.983662] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.990703] =======================================================
[ 3.997734] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[ 4.008488] [wifi_pm]: set wl_reg_on 1 !
[ 4.112994] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.124316] [mmc]: sdc1 power_supply is null
[ 4.150057] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.182384] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.191436] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.199675] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.212577] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.224871] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 4.233009] *******************Try sdio*******************
[ 4.239969] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.248909] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.257844] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.266779] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.274912] *******************Try sd *******************
[ 4.281797] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.290834] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.299866] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.308904] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.317134] *******************Try mmc*******************
[ 4.323217] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.334504] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 4.342656] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.352872] [mmc]: sdc1 power_supply is null
[ 4.360369] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.371664] [mmc]: sdc1 power_supply is null
[ 4.390051] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.422633] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.431939] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.440181] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.453187] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.465760] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 4.473896] *******************Try sdio*******************
[ 4.481140] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.490340] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.499540] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.508743] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.516875] *******************Try sd *******************
[ 4.524024] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.533330] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.542633] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.551937] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.560167] *******************Try mmc*******************
[ 4.561905] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.577797] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 4.585944] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.596151] [mmc]: sdc1 power_supply is null
[ 4.603662] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.614960] [mmc]: sdc1 power_supply is null
[ 4.640048] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.673165] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.683004] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.691246] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.704514] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.717641] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 4.725776] *******************Try sdio*******************
[ 4.733555] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.743295] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.753035] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.762775] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.770906] *******************Try sd *******************
[ 4.778570] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.788405] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.798245] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.808080] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 4.816310] *******************Try mmc*******************
[ 4.822393] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.834515] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 4.842663] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.852869] [mmc]: sdc1 power_supply is null
[ 4.860362] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.871656] [mmc]: sdc1 power_supply is null
[ 4.890051] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.922633] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.931938] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52, RTO !!
[ 4.940180] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.953184] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 4.965756] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8, RTO !!
[ 4.973891] *******************Try sdio*******************
[ 4.981133] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.990332] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 4.999533] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 5.008736] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5, RTO !!
[ 5.016868] *******************Try sd *******************
[ 5.024013] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 5.033319] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 5.042622] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 5.052213] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55, RTO !!
[ 5.060463] *******************Try mmc*******************
[ 5.062180] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 5.078122] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1, RTO !!
[ 5.086277] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 5.096493] [mmc]: sdc1 power_supply is null
[ 5.120074] esp_sdio_init ------ RETRY ------
[ 5.125155] =======================================================
[ 5.132212] ==== Dislaunching Wi-Fi driver! (Powered by Rockchip) ====
[ 5.139531] =======================================================
[ 5.146575] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(01/22/2016),Drv: 2.26) exit.
[ 5.157319] [wifi_pm]: set wl_reg_on 0 !
[ 5.261749] eagle sdio can not power up!
[ 5.266149] ALSA device list:
[ 5.269476] #0: audiocodec
[ 5.274532] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
[ 5.284481] EXT4-fs (mmcblk0p7): couldn't mount as ext2 due to feature incompatibilities
[ 5.332112] EXT4-fs (mmcblk0p7): recovery complete
[ 5.339111] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 5.348311] VFS: Mounted root (ext4 filesystem) on device 179:7.
[ 5.356296] devtmpfs: mounted
[ 5.360164] Freeing init memory: 176K
[ 5.364346] Failed to execute /init. Attempting defaults...
[ 5.522256] EXT4-fs (mmcblk0p7): re-mounted. Opts: data=ordered
Starting logging: OK
Starting mdev...
Starting sshd: OK
modprobe: FATAL: Module videobuf-core not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module videobuf-dma-contig not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module cci not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module vfe_os not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module vfe_subdev not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module ar0330_mipi not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module gc0308 not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module vfe_v4l2 not found in directory /lib/modules/3.4.39
modprobe: FATAL: Module fbtft_device not found in directory /lib/modules/3.4.39
========= Run hwtest =========
LCD : Yes
ACM : No
NET : No
assert(fbdev.c:32): : No such file or directory
* [url=http://www.csgsm.com]www.csgsm.com[/url] cstx.taobao.com *
Support By cstx 2357481431@qq.com
V3S login: PageSize:4096,PageMask:0xFFFFF000
addr_start:01C20000,addr_offset:0x00000800
gpio_map:B6F11000
PIO:0xB6F11800
QScreenLinuxFb::connect: No such file or directory
Error opening framebuffer device /dev/fb0
: driver cannot connect
页次: 1
