楼主 #1 2021-02-28 19:35:42
Aaron
求助:v3s能ping百度却无法ping通localhost
开发板:荔枝派Zero
环境:linux主线5.11
问题:能ping通www.baidu.com,电脑也能ping通板子,板子却ping不通电脑,localhost、127.0.0.1都ping不通。
附:解决这个主要是用ffmpeg和ffserver推流出现http://127.0.0.1:8090/feed1.ffm: Connection timed out的问题,现在在电脑浏览器能打开ffserver的stat网页,但推出来的视频流一直是0kb,播放器也一直在转圈圈加载,所以感觉是这方面的问题。万分感谢。
# ifconfig
eth0      Link encap:Ethernet  HWaddr 9E:83:1D:37:F7:62
          inet addr:192.168.1.114  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:11 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1290 (1.2 KiB)  TX bytes:1866 (1.8 KiB)
          Interrupt:45
wlan0     Link encap:Ethernet  HWaddr 84:20:96:AB:33:1D
          inet addr:192.168.0.127  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:2181 errors:0 dropped:2188 overruns:0 frame:0
          TX packets:133 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:238345 (232.7 KiB)  TX bytes:24048 (23.4 KiB)
# ping www.baidu.com
PING www.baidu.com (180.101.49.12): 56 data bytes
64 bytes from 180.101.49.12: seq=0 ttl=53 time=21.069 ms
64 bytes from 180.101.49.12: seq=1 ttl=53 time=19.687 ms
^C
--- www.baidu.com ping statistics ---
3 packets transmitted, 2 packets received, 33% packet loss
round-trip min/avg/max = 19.687/20.378/21.069 ms
# ping localhost
PING localhost (127.0.0.1): 56 data bytes
^C
--- localhost ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
# ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1): 56 data bytes
^C
--- 127.0.0.1 ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
# /etc/nsswitch.conf
passwd:         files
group:          files
shadow:         files
hosts:          files dns
networks:       files dns
protocols:      files
services:       files
ethers:         files
rpc:            files
# cat /etc/hosts
127.0.0.1	localhost
127.0.1.1	root
# cat /etc/hostname
root
#2 2021-02-28 19:44:36
已发帖子: 3,389
Re: 求助:v3s能ping百度却无法ping通localhost
ifconfig lo up
试一试这个
楼主 #3 2021-02-28 19:50:15
Aaron
ifconfig lo up
试一试这个
谢谢谢谢,可以了,ffmpeg也可以推流了。
抱歉哈,没系统学过linux,刚查了下才知道lo是环回,有点傻了。再次感谢。
#4 2021-02-28 19:54:20
已发帖子: 3,389
瞎蒙的, 能帮到你我也非常开森
