楼主 #1 2021-03-11 14:38:10
feng888
已发帖子: 59
自动挂载 sd卡脚本不稳定,时好时不行
自动挂载 sd卡脚本不稳定,时好时不行
#! /bin/sh
# debugging message
echo "MDEV=$1 : ACTION=$2 : SUBSYSTEM=$SUBSYSTEM : DEVPATH=$DEVPATH : DEVNAME=$DEVNAME" >> /dev/console
if [ "$1" == "" ]; then
    echo "parameter is none" > /tmp/error.txt
    exit 1
fi
MNT=$1
#if [ $(echo $1 | grep mmcblk) ]; then
#    if [ $(echo $1 | grep p[25]) ]; then
#        MNT=sdcard2
#    else
#        MNT=sdcard
#    fi
#elif [ $(echo $1 | grep sd) ]; then
#        MNT=nandcard2
#    else
#        MNT=nandcard
#    fi
#fi
# there is no ACTION, it is for initial population
if [ "$2" = "X" ]; then
    mounted=`mount | grep $1 | wc -l`
    if [ $mounted -ge 1 ]; then
        # mounted, assume the ACTION is remove
        #ACT=Xremove
        # only set add for initial population
        ACT=Xadd
        # not mounted, assume the ACTION is add
        ACT=Xadd
    fi
    ACT=$2
fi
if [ "$ACT" = "Xremove" ]; then
    # umount the device
    echo "$ACT /mnt/udisk" >> /tmp/mdev.log
    if ! umount -l "/mnt/udisk"; then
        exit 1
        rm -f "/mnt/udisk"
        echo "[Umount FS]: /dev/$1 -X-> /mnt/udisk" > /dev/console
    fi
    if ! rmdir "/mnt/udisk"; then
        exit 1
    fi
    # mount the device
    echo "par=$1,mounted=$mounted,MNT=$MNT" > /dev/console
        echo "device $1 is already mounted" > /dev/console
        exit 0
    fi
    if ! mkdir -p "/mnt/udisk"; then
        echo "mkdir -p /mnt/udisk err" > /dev/console
        exit 1
    fi
    if [ $(echo $1 | grep mtd) ]; then
        if mount -t jffs2 "/dev/$1" "/mnt/udisk"; then
            echo "[Mount JFFS2]: /dev/$1 --> /mnt/udisk" > /dev/console
        elif mount -t yaffs2 -o"inband-tags" "/dev/$1" "/mnt/$1"; then
            echo "[Mount YAFFS2]: /dev/$1 --> /mnt/udisk" > /dev/console
            echo "$ACT /mnt/$1" >> /tmp/mdev.log
        elif mount -t ubifs "/dev/$1" "/mnt/udisk"; then
            echo "[Mount UBIFS]: /dev/$1 --> /mnt/udisk" > /dev/console
            # failed to mount, clean up mountpoint
            echo "failed to mount, clean up mountpoint0" > /dev/console
                exit 1
            fi
        fi
        # try vfat only
        if mount -t vfat -o noatime,shortname=mixed,utf8 "/dev/$1" "/mnt/udisk"; then
#            ln -s /mnt/$1 /mnt/udisk
            echo "[Mount VFAT]: /dev/$1 --> /mnt/udisk" > /dev/console
            echo "failed to mount, clean up mountpoint" > /dev/console
                exit 1
            fi
            exit 1
        fi
    fi
fi
MDEV=mmcblk0p1 : ACTION=Xremove : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1 : DEVNAME=mmcblk0p1
[  822.870781] mmc0: host does not support reading read-only switch, assuming write-enable
[  822.880670] mmc0: new high speed SDHC card at address 0001
[  822.894261] mmcblk0: mmc0:0001 00000 29.8 GiB
[  822.907082]  mmcblk0: p1
MDEV=mmcblk0 : ACTION=Xadd : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0 : DEVNAME=mmcblk0
MDEV=mmcblk0p1 : ACTION=Xadd : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1 : DEVNAME=mmcblk0p1
par=mmcblk0,mounted=0,MNT=mmcblk0
par=mmcblk0p1,mounted=0,MNT=mmcblk0p1
[  823.064747] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  823.124543] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  824.164652] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  826.004244] mmc0: card 0001 removed
MDEV=mmcblk0 : ACTION=Xremove : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0 : DEVNAME=mmcblk0
[  830.390786] mmc0: host does not support reading read-only switch, assuming write-enable
[  830.400668] mmc0: new high speed SDHC card at address 0001
[  830.407732] mmcblk0: mmc0:0001 00000 29.8 GiB
[  830.434593]  mmcblk0: p1
[  831.444609] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  832.484669] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
