楼主 #1 2021-03-28 15:48:59
fcode
V3S mmc1使用RTL8189FTV SDIO wifi不能下载固件
目前在调试RTL8189FTV insmod之后出现如下问题:
# insmod  8189fs.ko
[   29.013275] 8189fs: loading out-of-tree module taints kernel.
[   29.039736] RTW: module init start
[   29.043156] RTW: rtl8189fs v5.7.8_34044.20190614
[   29.047867] RTW: build time: Mar 28 2021 15:27:03
[   29.052621] RTW: rtw_inetaddr_notifier_register
[   29.067822] RTW: == SDIO Card Info ==
[   29.071490] RTW:   card: c3a4b800
[   29.074798] RTW:   clock: 50000000 Hz
[   29.078557] RTW:   timing spec: sd high-speed
[   29.082922] RTW:   sd3_bus_mode: FALSE
[   29.086691] RTW:   func num: 1
[   29.089742] RTW:   func1: c3bbc800 (*)
[   29.093484] RTW: ================
[   29.096811] RTW: CHIP TYPE: RTL8188F
[   29.104208] RTW: rtw_hal_config_rftype RF_Type is 0 TotalTxPath is 1
[   29.110693] RTW: Chip Version Info: CHIP_8188F_Normal_Chip_SMIC_B_CUT_1T1R_RomVer(0)
[   29.121363] RTW: SetHwReg: hci_sus_state=1
[   29.130129] RTW: SetHwReg: bMacPwrCtrlOn=1
[   29.134229] RTW: SetHwReg: hci_sus_state=2
[   29.152135] RTW: sdio_power_on_check: val_mix:0x0000063f, res:0x0000063f
[   29.158917] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
[   29.169463] RTW: sdio_power_on_check: 0x1B8 test Pass.
[   29.174707] RTW: EEPROM type is E-FUSE
[   29.180384] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
[   29.339271] RTW: hal_ReadEFuse_WiFi: data end at address=0x98
[   29.354537] RTW: HW EFUSE
[   29.357262] RTW: 0x000: 29 81 03 CC  00 00 50 00  00 00 04 CC  0A 0C 00 00
[   29.364332] RTW: 0x010: 24 25 26 26  26 26 29 28  28 2A 2A 02  FF FF FF FF
[   29.371422] RTW: 0x020: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.378501] RTW: 0x030: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.385577] RTW: 0x040: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.392641] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.399716] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.406805] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.413871] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.420948] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.428025] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.435089] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  20 33 1C 00  00 00 00 FF
[   29.442163] RTW: 0x0C0: FF 02 00 10  00 FF 00 FF  00 00 FF FF  FF FF FF FF
[   29.449238] RTW: 0x0D0: 3E 10 01 12  23 FF FF FF  20 04 4C 02  79 F1 21 02
[   29.456333] RTW: 0x0E0: 0C 00 22 04  00 08 00 32  FF 21 02 0C  00 22 2A 01
[   29.463398] RTW: 0x0F0: 01 00 00 00  00 00 00 00  00 00 00 00  02 00 FF FF
[   29.470474] RTW: 0x100: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
[   29.477550] RTW: 0x110: 00 EB 00 6E  01 00 00 00  00 FF 00 0A  E2 9B AA 86
[   29.484613] RTW: 0x120: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.491687] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.498763] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.505836] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.512901] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.519975] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.527051] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.534116] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.541190] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.548265] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.555329] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.562403] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.569478] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.576553] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   29.583650] RTW: hal_com_config_channel_plan chplan:0x20
[   29.702237] RTW: kfree Pwr Trim flag:1
[   29.706065] RTW: bb_gain:0
[   29.713460] RTW: rtl8188f_FirmwareDownload((null)) tmp_ps=3
[   29.719111] RTW: rtl8188f_FirmwareDownload fw: FW_NIC, size: 20306
[   29.725290] RTW: rtl8188f_FirmwareDownload: fw_ver=e fw_subver=0000 sig=0x88f1, Month=06, Date=07, Hour=17, Minute=18
[   29.735918] RTW: rtl8188f_FirmwareDownload(): Shift for fw header!
[   29.742091] RTW: rtl8188f_FirmwareDownload by IO write!
[   29.750006] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.759389] RTW: ERROR sd_write32: (-110) addr=0x11004 val=0x000004bc
[   29.766062] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.772384] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=0
[   29.779559] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.786947] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=1
[   29.794123] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.800821] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=2
[   29.808052] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.815110] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=3
[   29.822354] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.829870] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=4
[   29.837125] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.843445] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=5
[   29.850619] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.858005] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=6
[   29.865180] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.872032] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=7
[   29.879151] RTW: ERROR sd_write32: FAIL!(-110) addr=0x11004 val=0x000004bc, try_cnt=8
[   29.887009] ====>_BlockWrite 101 i:1
[   29.890581] ====>_WriteFW 230
[   29.896617] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.902929] RTW: ERROR sd_write32: (-110) addr=0x11004 val=0x000004bc
[   29.909519] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   29.917912] RTW: ERROR sd_write32: (-110) addr=0x11004, val=0x4bc, try_cnt=0
[   29.924968] RTW: [dvobj:c381d000][ERROR] continual_io_error:9 > 8
[   29.931141] RTW: ERROR sd_write32: (-110) addr=0x11004 val=0x000004bc, try_cnt=0
[   29.938555] ====>_BlockWrite 101 i:1
[   29.942126] ====>_WriteFW 230
[   29.945104] RTW: _8051Reset8188: Finish
[   29.948957] RTW: _FWFreeToGo: Polling FW ready Fail! (1, 10ms), REG_MCUFWDL:0x00000000
[   29.956879] RTW: rtl8188f_FirmwareDownload fail. write_fw:2, 220ms
[   29.963052] RTW:  <=== rtl8188f_FirmwareDownload()
[   29.967858] RTW: hal_read_mac_hidden_rpt Fail! (0, 260ms), fwdl:0, id:0xfd
[   29.974738] RTW: SetHwReg: bMacPwrCtrlOn=0
[   29.978846] RTW: SetHwReg: hci_sus_state=3
[   29.982947] RTW: SetHwReg: hci_sus_state=0
[   29.987051] RTW: rtw_hal_read_chip_info in 870 ms
[   29.991793] RTW: rtw_init_primary_adapter Failed!
[   29.999137] RTW: module init ret=0
没有头绪请各位指点,谢谢。
#2 2021-03-28 16:49:06
所在地: 你猜
已发帖子: 3,381
Re: V3S mmc1使用RTL8189FTV SDIO wifi不能下载固件
检查该组 mmc在 ①dts有没有开启, ②引脚有没有被其他功能,如gpio/led等复用
楼主 #3 2021-03-28 17:40:12
fcode
WIFI所在的mmc1可以正常读写TF卡,所以感觉很奇怪
