楼主 #1 2021-04-11 09:04:16
所在地: 你猜
已发帖子: 3,381
全志 A33 官方 dragonboard SDK 建立 SSHD 服务器, 电脑通过WIFI连接A33 SSHD服务器 [分享]
①. 下载 dropbear 源码 dropbear-2020.81_src.tgz , 解压到任意目录, 修改Makefile的gcc路径:
比如的电脑gcc路径: /opt/A33/dragonboard/out/sun8iw5p1/dragonboard/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-gcc
那这样修改:
CC=/opt/A33/dragonboard/out/sun8iw5p1/dragonboard/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-gcc
AR=/opt/A33/dragonboard/out/sun8iw5p1/dragonboard/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-ar
RANLIB=/opt/A33/dragonboard/out/sun8iw5p1/dragonboard/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-ranlib
STRIP=/opt/A33/dragonboard/out/sun8iw5p1/dragonboard/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-strip
然后执行make 命令, 目录下面的drop 就是我们需要的文件
②. 新建WIFI配置文件 /etc/wpa_supplicant.conf
ctrl_interface_group=0
ap_scan=1
network={
ssid="whycan"
psk="13800138000"
联网:
wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf
获取ip:
dhcpc -i wlan0
③. 把步骤1生成dropbear可执行文件拷贝到根文件系统/usr/sbin/目录
建立: /etc/init.d/S50dropbear
#!/bin/sh
# Starts dropbear sshd.
# Allow a few customizations from a config file
test -r /etc/default/dropbear && . /etc/default/dropbear
start() {
        DROPBEAR_ARGS="$DROPBEAR_ARGS -R"
        # If /etc/dropbear is a symlink to /var/run/dropbear, and
        #   - the filesystem is RO (i.e. we can not rm the symlink),
        #     create the directory pointed to by the symlink.
        #   - the filesystem is RW (i.e. we can rm the symlink),
        #     replace the symlink with an actual directory
        if [ -L /etc/dropbear \
             -a "$(readlink /etc/dropbear)" = "/var/run/dropbear" ]
        then
                if rm -f /etc/dropbear >/dev/null 2>&1; then
                        mkdir -p /etc/dropbear
                        echo "No persistent location to store SSH host keys. New keys will be"
                        echo "generated at each boot. Are you sure this is what you want to do?"
                        mkdir -p "$(readlink /etc/dropbear)"
                fi
        fi
        printf "Starting dropbear sshd: "
        umask 077
        start-stop-daemon -S -q -p /var/run/dropbear.pid \
                --exec /usr/sbin/dropbear -- $DROPBEAR_ARGS
        [ $? = 0 ] && echo "OK" || echo "FAIL"
stop() {
        printf "Stopping dropbear sshd: "
        start-stop-daemon -K -q -p /var/run/dropbear.pid
restart() {
        stop
        start
case "$1" in
  start)
        start
  stop)
        stop
  restart|reload)
        restart
        echo "Usage: $0 {start|stop|restart}"
        exit 1
esac
exit $?
改变文件可执行属性: chmod +x /etc/init.d/S50dropbear
④. 重启dropbear:
/etc/init.d/S50dropbear restart
⑤. 如果需要变更密码请输入 passwd root
⑥. 客户端可以用ssh连接该服务器了
⑦. 板上备份文件
tar cvf /tmp/udisk/sshd_server_backup2.tar /etc/dropbear/ /etc/wpa_supplicant.conf /etc/init.d/S50dropbear /usr/sbin/dropbear /etc/passwd /etc/shadow
⑧. 打包到文件系统:
在这个目录下 /opt/A33/dragonboard/buildroot/target/dragonboard/rootfs/
mkdir /etc/dropbear/ -p
复制板上的 /etc/wpa_supplicant.conf /etc/init.d/S50dropbear /usr/sbin/dropbear /etc/passwd /etc/shadow 等文件
然后执行 build.sh 打包固件命令, 生成img即烧录文件.
#2 2021-04-20 10:24:59
无痕
已发帖子: 28
Re: 全志 A33 官方 dragonboard SDK 建立 SSHD 服务器, 电脑通过WIFI连接A33 SSHD服务器 [分享]
哇酷小儿大佬,我遇到问题,希望能跟你取得联系,私底下交流
