#1 2021-04-22 10:52:20 分享评论
无根浮萍
已发帖子: 60
【转】 Linux 系统Tick刨根究底
https://v2as.com/article/478a8ec2-efa3-4bc4-86a0-90cbd90ad766
1. Tick的作用
          操作系统,tick仿佛是人的脉搏,不停的向各个器官提供血液。 Tick在操作系统中,会进行调度,是分时调度最基础的组成部分。在学习Linux内核时,我只知道这个概念,却没能真正看到它是如何实现的。在经历了大约2个周的仔细阅读之后,终于能窥其全貌。
          jiffies的更新。
         kernel/time/timekeeping.c
void do_timer(unsigned long ticks)
        jiffies_64 += ticks;
        update_wall_time();
        calc_global_load(ticks);
kernel/time/tick-common.c
static void tick_periodic(int cpu)
        if (tick_do_timer_cpu == cpu) {
                write_seqlock(&jiffies_lock);
                /* Keep track of the next tick event */
                tick_next_period = ktime_add(tick_next_period, tick_period);
                do_timer(1);
                write_sequnlock(&jiffies_lock);
        update_process_times(user_mode(get_irq_regs()));
        profile_tick(CPU_PROFILING);
 * Event handler for periodic ticks
void tick_handle_periodic(struct clock_event_device *dev)
        int cpu = smp_processor_id();
        ktime_t next;
        tick_periodic(cpu);
        if (dev->mode != CLOCK_EVT_MODE_ONESHOT)
                return;
         * Setup the next period for devices, which do not have
         * periodic mode:
        next = ktime_add(dev->next_event, tick_period);
        for (;;) {
                if (!clockevents_program_event(dev, next, false))
                        return;
                 * Have to be careful here. If we're in oneshot mode,
                 * before we call tick_periodic() in a loop, we need
                 * to be sure we're using a real hardware clocksource.
                 * Otherwise we could get trapped in an infinite
                 * loop, as the tick_periodic() increments jiffies,
                 * when then will increment time, posibly causing
                 * the loop to trigger again and again.
                if (timekeeping_valid_for_hres())
                        tick_periodic(cpu);
                next = ktime_add(next, tick_period);
kernel/time/tick-broadcast.c
 * Set the periodic handler depending on broadcast on/off
void tick_set_periodic_handler(struct clock_event_device *dev, int broadcast)
        if (!broadcast)
                dev->event_handler = tick_handle_periodic;
                dev->event_handler = tick_handle_periodic_broadcast;
 * Setup the device for a periodic tick
void tick_setup_periodic(struct clock_event_device *dev, int broadcast)
        tick_set_periodic_handler(dev, broadcast);
        /* Broadcast setup ? */
        if (!tick_device_is_functional(dev))
                return;
        if ((dev->features & CLOCK_EVT_FEAT_PERIODIC) &&
            !tick_broadcast_oneshot_active()) {
                clockevents_set_mode(dev, CLOCK_EVT_MODE_PERIODIC);
        } else {
                unsigned long seq;
                ktime_t next;
                do {
                        seq = read_seqbegin(&jiffies_lock);
                        next = tick_next_period;
                } while (read_seqretry(&jiffies_lock, seq));
                clockevents_set_mode(dev, CLOCK_EVT_MODE_ONESHOT);
                for (;;) {
                                return;
 * Setup the tick device
static void tick_setup_device(struct tick_device *td,
                              struct clock_event_device *newdev, int cpu,
                              const struct cpumask *cpumask)
        ktime_t next_event;
        void (*handler)(struct clock_event_device *) = NULL;
        if (tick_device_uses_broadcast(newdev, cpu))
                return;
        if (td->mode == TICKDEV_MODE_PERIODIC)
                tick_setup_periodic(newdev, 0);
                tick_setup_oneshot(newdev, handler, next_event);
 * Check, if the new registered device should be used.
void tick_check_new_device(struct clock_event_device *newdev)
        struct clock_event_device *curdev;
        struct tick_device *td;
        int cpu;
        unsigned long flags;
        clockevents_exchange_device(curdev, newdev);
        tick_setup_device(td, newdev, cpu, cpumask_of(cpu));
        if (newdev->features & CLOCK_EVT_FEAT_ONESHOT)
                tick_oneshot_notify();
        raw_spin_unlock_irqrestore(&tick_device_lock, flags);
        return;
out_bc:
         * Can the new device be used as a broadcast device ?
        tick_install_broadcast_device(newdev);
      Tick的eventhandler是在clock_event_device的注册过程中设置的。
2. clock_event_device的注册继续沿着调用关系向下寻找。
kernel/time/clockevents.c
 * clockevents_register_device - register a clock event device
 * @dev:        device to register
void clockevents_register_device(struct clock_event_device *dev)
        BUG_ON(dev->mode != CLOCK_EVT_MODE_UNUSED);
        if (!dev->cpumask) {
                WARN_ON(num_possible_cpus() > 1);
                dev->cpumask = cpumask_of(smp_processor_id());
        raw_spin_lock_irqsave(&clockevents_lock, flags);
        list_add(&dev->list, &clockevent_devices);
        tick_check_new_device(dev);
        clockevents_notify_released();
        raw_spin_unlock_irqrestore(&clockevents_lock, flags);
void clockevents_config_and_register(struct clock_event_device *dev,
                                     u32 freq, unsigned long min_delta,
                                     unsigned long max_delta)
        dev->min_delta_ticks = min_delta;
        dev->max_delta_ticks = max_delta;
        clockevents_config(dev, freq);
        clockevents_register_device(dev);
还是基于我相对熟悉的Arm作为例子。
drivers/clocksource/arm_arch_timer.c
static void __cpuinit __arch_timer_setup(unsigned type,
                                       struct clock_event_device *clk)
        clk->features = CLOCK_EVT_FEAT_ONESHOT;
        if (type == ARCH_CP15_TIMER) {
                clk->features |= CLOCK_EVT_FEAT_C3STOP;
                clk->name = "arch_sys_timer";
                clk->rating = 450;
                clk->cpumask = cpumask_of(smp_processor_id());
                if (arch_timer_use_virtual) {
                        clk->irq = arch_timer_ppi[VIRT_PPI];
                        clk->set_mode = arch_timer_set_mode_virt;
                        clk->set_next_event = arch_timer_set_next_event_virt;
                } else {
                        clk->irq = arch_timer_ppi[PHYS_SECURE_PPI];
                        clk->set_mode = arch_timer_set_mode_phys;
                        clk->set_next_event = arch_timer_set_next_event_phys;
        } else {
                clk->features |= CLOCK_EVT_FEAT_DYNIRQ;
                clk->name = "arch_mem_timer";
                clk->rating = 400;
                clk->cpumask = cpu_all_mask;
                if (arch_timer_mem_use_virtual) {
                        clk->set_mode = arch_timer_set_mode_virt_mem;
                                arch_timer_set_next_event_virt_mem;
                } else {
                        clk->set_mode = arch_timer_set_mode_phys_mem;
                                arch_timer_set_next_event_phys_mem;
        clk->set_mode(CLOCK_EVT_MODE_SHUTDOWN, clk);
        clockevents_config_and_register(clk, arch_timer_rate, 0xf, 0x7fffffff);
static int __cpuinit arch_timer_setup(struct clock_event_device *clk)
        __arch_timer_setup(ARCH_CP15_TIMER, clk);
static int __init arch_timer_register(void)
        int err;
        int ppi;
        arch_timer_evt = alloc_percpu(struct clock_event_device);
        if (!arch_timer_evt) {
                err = -ENOMEM;
                goto out;
        /* Immediately configure the timer on the boot CPU */
        arch_timer_setup(this_cpu_ptr(arch_timer_evt));
out_unreg_notify:
        unregister_cpu_notifier(&arch_timer_cpu_nb);
out_free_irq:
                free_percpu_irq(arch_timer_ppi[VIRT_PPI], arch_timer_evt);
        else {
                free_percpu_irq(arch_timer_ppi[PHYS_SECURE_PPI],
                                arch_timer_evt);
                if (arch_timer_ppi[PHYS_NONSECURE_PPI])
                        free_percpu_irq(arch_timer_ppi[PHYS_NONSECURE_PPI],
                                        arch_timer_evt);
out_free:
        free_percpu(arch_timer_evt);
out:
        return err;
static void __init arch_timer_init(struct device_node *np)
        int i;
        if (arch_timers_present & ARCH_CP15_TIMER) {
                pr_warn("arch_timer: multiple nodes in dt, skipping\n");
                return;
        arch_timers_present |= ARCH_CP15_TIMER;
        for (i = PHYS_SECURE_PPI; i < MAX_TIMER_PPI; i++)
                arch_timer_ppi[i] = irq_of_parse_and_map(np, i);
        arch_timer_detect_rate(NULL, np);
         * If HYP mode is available, we know that the physical timer
         * has been configured to be accessible from PL1. Use it, so
         * that a guest can use the virtual timer instead.
         * If no interrupt provided for virtual timer, we'll have to
         * stick to the physical timer. It'd better be accessible…
        if (is_hyp_mode_available() || !arch_timer_ppi[VIRT_PPI]) {
                arch_timer_use_virtual = false;
                if (!arch_timer_ppi[PHYS_SECURE_PPI] ||
                    !arch_timer_ppi[PHYS_NONSECURE_PPI]) {
                        pr_warn("arch_timer: No interrupt available, giving up\n");
                        return;
        arch_timer_register();
        arch_timer_common_init();
CLOCKSOURCE_OF_DECLARE(armv7_arch_timer, "arm,armv7-timer", arch_timer_init);
CLOCKSOURCE_OF_DECLARE(armv8_arch_timer, "arm,armv8-timer", arch_timer_init);
    arch_timer_init对整个时钟进行设置。
#define CLOCKSOURCE_OF_DECLARE(name, compat, fn)                        \
        static const struct of_device_id __clksrc_of_table_##name       \
                __used __section(__clksrc_of_table)                     \
                 = { .compatible = compat,                              \
                     .data = (fn == (clocksource_of_init_fn)NULL) ? fn : fn }
CLOCKSOURCE_OF_DECLARE生成一个表项。
3. time_init
arch/arm64/kernel/time.c
void __init time_init(void)
        u32 arch_timer_rate;
        of_clk_init(NULL);
        clocksource_of_init();
        tick_setup_hrtimer_broadcast();
        arch_timer_rate = arch_timer_get_rate();
        if (!arch_timer_rate)
                panic("Unable to initialise architected timer.\n");
        /* Calibrate the delay loop directly */
        lpj_fine = arch_timer_rate / HZ;
drivers/clocksource/clksrc-of.c
void __init clocksource_of_init(void)
        struct device_node *np;
        const struct of_device_id *match;
        clocksource_of_init_fn init_func;
        for_each_matching_node_and_match(np, __clksrc_of_table, &match) {
                init_func = match->data;
                init_func(np);
4. 整个故事到了尾声, clocksource_of_init将遍历device tree所有的节点,如果找到和__clksrc_of_tablematch的, 就调用相应的函数。
device tree的一个Node:
timer {
                        compatible = "arm,armv8-timer";
                        interrupts = <0x1 0x2 0xff08 0x1 0x3 0xff08 0x1 0x4 0xff08 0x1 0x1 0xff08>;
                        clock-frequency = <0x124f800>;
