楼主 #1 2021-04-26 22:21:04
psst
已发帖子: 91
5.2内核找不到声卡,设备树有问题吗?
linux5.2 没有找到声卡。
[    0.000000] Linux version 5.2.0-licheepi-zero+ (psst@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #2 SMP Mon Apr 26 09:27:47 +08 2021
[    0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:512k(uboot),64k(dtb)ro,5120k(kernel)ro,-(rootfs) root=31:3 rw rootfstype=jffs2 init=/linuxrc vt.global_cursor_default=0
[    0.000000] Memory: 55056K/65536K available (6144K kernel code, 297K rwdata, 1696K rodata, 1024K init, 254K bss, 10480K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x300/0x48c with crng_init=0
[    0.000198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000434] Console: colour dummy device 80x30
[    0.000492] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000508] pid_max: default: 32768 minimum: 301
[    0.000670] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000686] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001516] CPU: Testing write buffer coherency: ok
[    0.002027] /cpus/cpu@0 missing clock-frequency property
[    0.002053] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002827] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003033] rcu: Hierarchical SRCU implementation.
[    0.003553] smp: Bringing up secondary CPUs ...
[    0.003573] smp: Brought up 1 node, 1 CPU
[    0.003583] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003590] CPU: All CPU(s) started in SVC mode.
[    0.004733] devtmpfs: initialized
[    0.008101] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008422] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008455] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008699] pinctrl core: initialized pinctrl subsystem
[    0.009753] NET: Registered protocol family 16
[    0.010439] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.011727] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.011745] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.035433] SCSI subsystem initialized
[    0.035717] usbcore: registered new interface driver usbfs
[    0.035775] usbcore: registered new interface driver hub
[    0.035896] usbcore: registered new device driver usb
[    0.036123] mc: Linux media interface: v0.10
[    0.036165] videodev: Linux video capture interface: v2.00
[    0.036386] Advanced Linux Sound Architecture Driver Initialized.
[    0.037709] clocksource: Switched to clocksource arch_sys_counter
[    0.049299] NET: Registered protocol family 2
[    0.050113] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.050153] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.050179] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.050204] TCP: Hash tables configured (established 1024 bind 1024)
[    0.050344] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.050395] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.050689] NET: Registered protocol family 1
[    0.052598] Initialise system trusted keyrings
[    0.052969] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.059231] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.089109] Key type asymmetric registered
[    0.089131] Asymmetric key parser 'x509' registered
[    0.089234] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.089247] io scheduler mq-deadline registered
[    0.089255] io scheduler kyber registered
[    0.090273] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.093974] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.159856] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.162141] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.163249] printk: console [ttyS0] disabled
[    0.183569] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    0.705803] printk: console [ttyS0] enabled
[    0.734594] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.746033] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.750852] 4 cmdlinepart partitions found on MTD device spi0.0
[    0.756767] Creating 4 MTD partitions on "spi0.0":
[    0.761587] 0x000000000000-0x000000080000 : "uboot"
[    0.767238] 0x000000080000-0x000000090000 : "dtb"
[    0.772554] 0x000000090000-0x000000590000 : "kernel"
[    0.778124] 0x000000590000-0x000001000000 : "rootfs"
[    0.784294] libphy: Fixed MDIO Bus: probed
[    0.789073] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.794874] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.801147] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    0.810636] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.817874] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.825088] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.830063] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.836844] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.842508] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.848412] libphy: stmmac: probed
[    0.852535] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.858888] libphy: mdio_mux: probed
[    0.862490] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    0.868887] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    0.876019] libphy: mdio_mux: probed
[    0.880057] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.886583] ehci-platform: EHCI generic platform driver
[    0.892147] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.897812] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.905737] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[    0.937706] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.944906] hub 1-0:1.0: USB hub found
[    0.948867] hub 1-0:1.0: 1 port detected
[    0.953483] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.959813] ohci-platform: OHCI generic platform driver
[    0.965352] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.972079] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.980062] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[    1.052784] hub 2-0:1.0: USB hub found
[    1.056617] hub 2-0:1.0: 1 port detected
[    1.063940] usbcore: registered new interface driver usb-storage
[    1.071589] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.076652] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.081362] i2c /dev entries driver
[    1.086207] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[    1.095825] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.104516] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.140404] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.147956] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.159358] usbcore: registered new interface driver usbhid
[    1.164936] usbhid: USB HID core driver
[    1.171487] Initializing XFRM netlink socket
[    1.175796] NET: Registered protocol family 17
[    1.180955] Registering SWP/SWPB emulation handler
[    1.186846] Loading compiled-in X.509 certificates
[    1.198326] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.209840] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.215604] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.224978] hub 3-0:1.0: USB hub found
[    1.229054] hub 3-0:1.0: 1 port detected
[    1.234457] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T02:41:01 UTC (9661)
[    1.242994] vcc3v0: disabling
[    1.245974] vcc5v0: disabling
[    1.249000] ALSA device list:
[    1.251968]   No soundcards found.
[    1.257786] random: fast init done
[    1.303592] random: crng init done
[    1.307460] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.321169] mmc0: new high speed SD card at address 1388
[    1.330836] mmcblk0: mmc0:1388 Stora 119 MiB
[    1.347209]  mmcblk0: p1
[    3.310384] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    3.318262] devtmpfs: mounted
[    3.322434] Freeing unused kernel memory: 1024K
[    3.327115] Run /linuxrc as init process
Starting syslogd: OK
sun8i-v3s.dtsi
codec: codec@01c22c00 {
			#sound-dai-cells = <0>;
			compatible = "allwinner,sun8i-v3s-codec";
			reg = <0x01c22c00 0x400>;
			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>;
			clock-names = "apb", "codec";
			resets = <&ccu RST_BUS_CODEC>;
			dmas = <&dma 15>, <&dma 15>;
			dma-names = "rx", "tx";
			allwinner,codec-analog-controls = <&codec_analog>;
			status = "disabled";
		codec_analog: codec-analog@01c23000 {
			compatible = "allwinner,sun8i-v3s-codec-analog";
			reg = <0x01c23000 0x4>;
sun8i-v3s-licheepi-zero-dock.dts
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
#2 2021-04-27 08:43:53
所在地: 你猜
已发帖子: 3,381
Re: 5.2内核找不到声卡,设备树有问题吗?
1. 驱动勾选了  "allwinner,sun8i-v3s-codec",  "allwinner,sun8i-v3s-codec-analog" ?
2. dtb确实用 sun8i-v3s-licheepi-zero-dock.dtb
3. 没烧错文件?kernel的编译日期是不是最新的?
4. 如果上面都没有问题, 就去驱动的 init( ) 函数里面加点调试代码。
#3 2021-04-27 08:59:08
JasonWoo
已发帖子: 84
dtsi里面status="disabled"
这个地方会不会有点问题?
#4 2021-04-27 10:49:49
unturned3
已发帖子: 268
JasonWoo 说:
这个地方会不会有点问题?
codec应该在sun8i-v3s-licheepi-zero-dock.dts 里被设置成 status="okay"了,应该不是这个问题。
&codec {
		"Headphone", "HP",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
楼主 #5 2021-04-27 16:48:52
psst
已发帖子: 91
dtb用的是 sun8i-v3s-licheepi-zero-dock.dtb,kernel反复烧写过很多次,声卡始终找不到,不知道啥原因?
5.2内核有适配过声卡吗?我看5.2的内核驱动跟4.13不一样,目前4.10 4.13都能找到声卡,5.2不行,不知道哪里导致的。
#6 2021-04-27 16:55:51
所在地: 你猜
已发帖子: 3,381
驱动的 init( ) 函数里面加调试代码。
#7 2021-04-27 17:05:26
xfdr0805
已发帖子: 297
支持  我用的5.10内核
