楼主 #1 2017-12-19 17:16:26
qianhao
已发帖子: 138
aplay播放wav没有声音
使用buildroot安装的alsa-utils.里面包含了 aplay这个应用。
# aplay /home/666.wav
Playing WAVE '/home/666.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
耳机有嗡嗡声  使用alsamixer最左边的
Card: V3s Audio Codec                                F1:  Help               |
| Chip:                                                F2:  System information |
| View: F3:[Playback] F4: Capture  F5: All             F6:  Select sound card  |
| Item: Headphone [dB gain: 0.00]                      Esc: Exit               |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |aa|        |aa|                    |
|      |aa|                    |aa|        |aa|        |aa|                    |
|      +--+         DAC        +--+        +--+        +--+        +--+        |
|      |MM|                    |MM|                    |MM|        |MM|        |
|      100                      43          64         100                     |
|  < Headphone >Headphone S    Mic1     Mic1 Boost      DAC     DAC Reverse    |
还是没有声音 。。。。。
#2 2017-12-19 17:31:39
已发帖子: 9,401
#3 2017-12-27 12:33:18
1066950103
已发帖子: 61
Re: aplay播放wav没有声音
qianhao 说:
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      |aa|                    |  |        |  |        |aa|                    |
|      100                      43          64         100                     |
还是没有声音 。。。。。
需要按M键开启 你目前只是设置的音量
