楼主 # 2021-07-09 21:23:49
liuy
关于如何将f1c100s/f1c200s linux中将RGB引脚交换为BGR
根据f1c100s的数据手册,TCON0_Control_Register BIT23是 Swap RED and BLUE data at FIFO1
路径 linux/drivers/gpu/drm/sun4i/sun4i_tcon.c 添加如下语句
static void sun4i_tcon_channel_set_status(struct sun4i_tcon *tcon, int channel,
					  bool enabled)
	struct clk *clk;
	switch (channel) {
	case 0:
		regmap_update_bits(tcon->regs, SUN4I_TCON0_CTL_REG,
				   SUN4I_TCON0_CTL_TCON_ENABLE,
				   enabled ? SUN4I_TCON0_CTL_TCON_ENABLE : 0);
		regmap_update_bits(tcon->regs, SUN4I_TCON0_CTL_REG,BIT(23),BIT(23));//SWAP R、B引脚
		clk = tcon->dclk;
		break;
	case 1:
		WARN_ON(!tcon->quirks->has_channel_1);
		regmap_update_bits(tcon->regs, SUN4I_TCON1_CTL_REG,
				   SUN4I_TCON1_CTL_TCON_ENABLE,
				   enabled ? SUN4I_TCON1_CTL_TCON_ENABLE : 0);
		clk = tcon->sclk1;
		break;
	default:
		DRM_WARN("Unknown channel... doing nothing\n");
		return;
	if (enabled)
		clk_prepare_enable(clk);
		clk_disable_unprepare(clk);
#1 2021-07-09 21:31:13
已发帖子: 2,442
Re: 关于如何将f1c100s/f1c200s linux中将RGB引脚交换为BGR
感谢楼主分享宝贵经验!
#2 2021-07-12 10:51:57
thindcna
已发帖子: 22
问了很多人,没人知道。 谢谢你
