楼主 # 2021-07-17 12:17:45
tigger
已发帖子: 172
全志D1开发板添加基于中断的 gpio-key 按键驱动
修改 output/build/linux-origin_master/arch/riscv/boot/dts/board.dts:
在
        reg_usb1_vbus: usb1-vbus {
                regulator-name = "usb1-vbus";
                regulator-min-microvolt = <5000000>;
                regulator-max-microvolt = <5000000>;
                regulator-enable-ramp-delay = <1000>;
                gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
                enable-active-high;
后面添加:
gpio_keys {
        compatible = "gpio-keys";
        pinctrl-names = "default";
        #address-cells = <1>;
        #size-cells = <0>;
        autorepeat;
        button@0 {
                label = "Key back";
                linux,code = <KEY_BACK>;
                gpios = <&pio 3 10 GPIO_ACTIVE_LOW>; /* PD10 */
linux 配置文件 ./output/build/linux-origin_master/.config:
# Linux/riscv 5.4.61 Kernel Configuration
CONFIG_CC_VERSION_TEXT="riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0"
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=80100
CONFIG_CLANG_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_IRQ_WORK=y
CONFIG_THREAD_INFO_IN_TASK=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_BUILD_SALT=""
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_MSI_IOMMU=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TINY_SRCU=y
# end of RCU Subsystem
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# end of Scheduler features
CONFIG_ARCH_SUPPORTS_INT128=y
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
# CONFIG_RT_GROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CHECKPOINT_RESTORE=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
# CONFIG_BLK_DEV_INITRD is not set
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_SYSCTL_EXCEPTION_TRACE=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_HAVE_FUTEX_CMPXCHG=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_BPF_SYSCALL=y
# CONFIG_USERFAULTFD is not set
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
# CONFIG_PERF_EVENTS is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
# CONFIG_PROFILING is not set
# end of General setup
CONFIG_64BIT=y
CONFIG_RISCV=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=24
CONFIG_MMU=y
CONFIG_ZONE_DMA32=y
CONFIG_VA_BITS=39
CONFIG_PA_BITS=56
CONFIG_PAGE_OFFSET=0xffffffe000000000
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_SYS_SUPPORTS_HUGETLBFS=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_CSUM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_PGTABLE_LEVELS=3
CONFIG_SUNXI_SOC_NAME=""
# SoC selection
# CONFIG_SOC_SIFIVE is not set
CONFIG_RISCV_SUNXI=y
CONFIG_ARCH_SUNXI=y
# CONFIG_FPGA_V4_PLATFORM is not set
# CONFIG_FPGA_V7_PLATFORM is not set
CONFIG_EVB_PLATFORM=y
CONFIG_ARCH_SUN20I=y
CONFIG_ARCH_SUN20IW1=y
CONFIG_ARCH_SUN20IW1P1=y
# end of SoC selection
# Platform type
# CONFIG_ARCH_RV32I is not set
CONFIG_ARCH_RV64I=y
# CONFIG_CMODEL_MEDLOW is not set
CONFIG_CMODEL_MEDANY=y
CONFIG_MODULE_SECTIONS=y
# CONFIG_MAXPHYSMEM_2GB is not set
CONFIG_MAXPHYSMEM_128GB=y
# CONFIG_SMP is not set
CONFIG_TUNE_GENERIC=y
CONFIG_RISCV_ISA_C=y
CONFIG_FPU=y
CONFIG_VECTOR=y
# end of Platform type
# Kernel features
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_SCHED_HRTICK=y
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
# end of Kernel features
# Boot options
CONFIG_CMDLINE=""
# end of Boot options
# CPU Power Management
# CPU Idle
# CONFIG_CPU_IDLE is not set
# end of CPU Idle
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_TIMES=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_CPUFREQ_DUMMY is not set
CONFIG_RISCV_ALLWINNER_SUN50I_CPUFREQ_NVMEM=y
# end of CPU Frequency scaling
# end of CPU Power Management
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_SUSPEND_SKIP_SYNC is not set
CONFIG_PM_SLEEP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
# end of Power management options
# General architecture-dependent options
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_HAVE_ASM_MODVERSIONS=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_LTO_NONE=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_RELA=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_ARCH_MMAP_RND_BITS=18
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_HAVE_COPY_THREAD_TLS=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_64BIT_TIME=y
# CONFIG_REFCOUNT_FULL is not set
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
# end of GCOV-based kernel profiling
CONFIG_PLUGIN_HOSTCC=""
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# CONFIG_BLK_INLINE_ENCRYPTION is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLK_MQ_VIRTIO=y
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_HAS_MMIOWB=y
# CONFIG_GKI_HIDDEN_DRM_CONFIGS is not set
# CONFIG_GKI_HIDDEN_REGMAP_CONFIGS is not set
# CONFIG_GKI_HIDDEN_CRYPTO_CONFIGS is not set
# CONFIG_GKI_HIDDEN_SND_CONFIGS is not set
# CONFIG_GKI_HIDDEN_SND_SOC_CONFIGS is not set
# CONFIG_GKI_HIDDEN_MMC_CONFIGS is not set
# CONFIG_GKI_HIDDEN_GPIO_CONFIGS is not set
# CONFIG_GKI_HIDDEN_QCOM_CONFIGS is not set
# CONFIG_GKI_HIDDEN_MEDIA_CONFIGS is not set
# CONFIG_GKI_HIDDEN_VIRTUAL_CONFIGS is not set
# CONFIG_GKI_LEGACY_WEXT_ALLCONFIG is not set
# CONFIG_GKI_HIDDEN_USB_CONFIGS is not set
# CONFIG_GKI_HIDDEN_SOC_BUS_CONFIGS is not set
# CONFIG_GKI_HIDDEN_RPMSG_CONFIGS is not set
# CONFIG_GKI_HIDDEN_GPU_CONFIGS is not set
# CONFIG_GKI_HIDDEN_IRQ_CONFIGS is not set
# CONFIG_GKI_HIDDEN_HYPERVISOR_CONFIGS is not set
# CONFIG_GKI_HACKS_TO_FIX is not set
# CONFIG_GKI_OPT_FEATURES is not set
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y
CONFIG_HAVE_MEMBLOCK_NODE_MAP=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_PHYS_ADDR_T_64BIT=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
# end of Memory Management options
CONFIG_NET=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_UNIX_DIAG=y
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_INTERFACE is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_NET_KEY=y
# CONFIG_NET_KEY_MIGRATE is not set
# CONFIG_XDP_SOCKETS is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_FIB_TRIE_STATS=y
CONFIG_IP_MULTIPLE_TABLES=y
# CONFIG_IP_ROUTE_MULTIPATH is not set
# CONFIG_IP_ROUTE_VERBOSE is not set
# CONFIG_IP_PNP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
CONFIG_NET_IP_TUNNEL=y
# CONFIG_IP_MROUTE is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_FOU is not set
# CONFIG_NET_FOU_IP_TUNNELS is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_INET_TUNNEL=y
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=y
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_IPV6_VTI is not set
CONFIG_IPV6_SIT=y
# CONFIG_IPV6_SIT_6RD is not set
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_6LOWPAN is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_NET_NCSI is not set
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# CONFIG_BPF_STREAM_PARSER is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
CONFIG_CAN=y
CONFIG_CAN_RAW=y
CONFIG_CAN_BCM=y
CONFIG_CAN_GW=y
# CONFIG_CAN_J1939 is not set
# CAN Device Drivers
# CONFIG_CAN_VCAN is not set
# CONFIG_CAN_VXCAN is not set
# CONFIG_CAN_SLCAN is not set
CONFIG_CAN_DEV=y
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
# CONFIG_CAN_MCP251X is not set
# end of CAN SPI interfaces
# CAN USB interfaces
# CONFIG_CAN_8DEV_USB is not set
# CONFIG_CAN_EMS_USB is not set
# CONFIG_CAN_ESD_USB2 is not set
# CONFIG_CAN_GS_USB is not set
# CONFIG_CAN_KVASER_USB is not set
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_PEAK_USB is not set
# CONFIG_CAN_UCAN is not set
# end of CAN USB interfaces
# CONFIG_CAN_DEBUG_DEVICES is not set
# end of CAN Device Drivers
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CFG80211 needs to be enabled for MAC80211
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
# CONFIG_FAILOVER is not set
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
CONFIG_FW_CACHE=y
# end of Firmware loader
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_DEVICES=y
CONFIG_REGMAP=y
CONFIG_REGMAP_MMIO=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
# end of Generic Driver Options
# Bus devices
# CONFIG_MOXTET is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_SUN50I_DE2_BUS is not set
# CONFIG_SUNXI_RSB is not set
CONFIG_SUNXI_MBUS=y
# CONFIG_SUNXI_NSI is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# CONFIG_GNSS is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# CONFIG_MTD_SUNXI_PARTS is not set
# Partition parsers
# end of Partition parsers
# User Modules And Translation Layers
# CONFIG_MTD_CHAR is not set
# CONFIG_MTD_BLOCK is not set
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# CONFIG_MTD_ONENAND is not set
# CONFIG_MTD_RAW_NAND is not set
# CONFIG_MTD_SPI_NAND is not set
# sunxi-nand
CONFIG_AW_MTD_SPINAND=y
# CONFIG_AW_MTD_RAWNAND is not set
CONFIG_AW_SPINAND_PHYSICAL_LAYER=y
CONFIG_AW_SPINAND_SECURE_STORAGE=y
# CONFIG_AW_SPINAND_PSTORE_MTD_PART is not set
# CONFIG_AW_SPINAND_ENABLE_PHY_CRC16 is not set
CONFIG_AW_SPINAND_SIMULATE_MULTIPLANE=y
# end of sunxi-nand
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# end of LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_SPI_NOR is not set
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_VIRTIO_BLK=y
# CONFIG_VIRTIO_BLK_SCSI is not set
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_HISI_HIKEY_USB is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# CONFIG_VOP_BUS is not set
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# end of Intel MIC & related support
# CONFIG_ECHO is not set
# CONFIG_MISC_RTSX_USB is not set
# CONFIG_SUNXI_RFKILL is not set
# CONFIG_SUNXI_ADDR_MGT is not set
# CONFIG_SUNXI_BOOTEVENT is not set
# sunxi Gorilla ESL platform
# CONFIG_SUNXI_GORILLA is not set
# end of sunxi Gorilla ESL platform
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_VIRTIO is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_IPVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_GENEVE is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_VIRTIO_NET is not set
# CONFIG_NLMON is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_ALACRITECH=y
CONFIG_NET_VENDOR_ALLWINNER=y
# CONFIG_SUN4I_EMAC is not set
CONFIG_SUNXI_GMAC=y
CONFIG_SUNXI_EXT_PHY=y
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AQUANTIA=y
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_AURORA=y
# CONFIG_AURORA_NB8800 is not set
CONFIG_NET_VENDOR_BROADCOM=y
# CONFIG_B44 is not set
# CONFIG_BCMGENET is not set
# CONFIG_SYSTEMPORT is not set
CONFIG_NET_VENDOR_CADENCE=y
# CONFIG_MACB is not set
CONFIG_NET_VENDOR_CAVIUM=y
CONFIG_NET_VENDOR_CORTINA=y
# CONFIG_GEMINI_ETHERNET is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_GOOGLE=y
CONFIG_NET_VENDOR_HUAWEI=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
CONFIG_NET_VENDOR_MARVELL=y
# CONFIG_MVMDIO is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
CONFIG_NET_VENDOR_MICROCHIP=y
# CONFIG_ENC28J60 is not set
# CONFIG_ENCX24J600 is not set
CONFIG_NET_VENDOR_MICROSEMI=y
CONFIG_NET_VENDOR_NATSEMI=y
CONFIG_NET_VENDOR_NETRONOME=y
CONFIG_NET_VENDOR_NI=y
# CONFIG_NI_XGE_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_8390=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_PENSANDO=y
CONFIG_NET_VENDOR_QUALCOMM=y
# CONFIG_QCA7000_SPI is not set
# CONFIG_QCOM_EMAC is not set
# CONFIG_RMNET is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
CONFIG_NET_VENDOR_SAMSUNG=y
# CONFIG_SXGBE_ETH is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SOLARFLARE=y
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
# CONFIG_STMMAC_ETH is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
# CONFIG_WIZNET_W5100 is not set
# CONFIG_WIZNET_W5300 is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MSCC_MIIM is not set
# CONFIG_MDIO_OCTEON is not set
# CONFIG_MDIO_SUN4I is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# MII PHY device drivers
# CONFIG_ADIN_PHY is not set
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_MICROCHIP_PHY is not set
# CONFIG_MICROCHIP_T1_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_NXP_TJA11XX_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_WIRELESS_WDS is not set
CONFIG_WLAN_VENDOR_ADMTEK=y
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
CONFIG_WLAN_VENDOR_ATMEL=y
CONFIG_WLAN_VENDOR_BROADCOM=y
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
CONFIG_WLAN_VENDOR_INTERSIL=y
# CONFIG_HOSTAP is not set
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_WLAN_VENDOR_REALTEK=y
CONFIG_WLAN_VENDOR_RSI=y
CONFIG_WLAN_VENDOR_ST=y
CONFIG_WLAN_VENDOR_TI=y
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_WLAN_VENDOR_QUANTENNA=y
# CONFIG_XR829_WLAN is not set
# CONFIG_SPARD_WLAN_SUPPORT is not set
# CONFIG_BCMDHD is not set
# CONFIG_AIC_WLAN_SUPPORT is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# CONFIG_INPUT_SENSORINIT is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_SUN4I_LRADC is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
CONFIG_KEYBOARD_SUNXI=y
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# CONFIG_RMI4_CORE is not set
CONFIG_INPUT_SENSOR=y
# CONFIG_SENSORS_SC7A20 is not set
# CONFIG_SENSORS_MIR3DA is not set
# CONFIG_STK3X1X is not set
# CONFIG_SUNXI_TPADC is not set
CONFIG_SUNXI_GPADC=y
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
# CONFIG_NULL_TTY is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
CONFIG_SERIAL_EARLYCON_RISCV_SBI=y
# CONFIG_SERIAL_SAMSUNG is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_SPRD is not set
CONFIG_SERIAL_SUNXI=y
# CONFIG_SERIAL_SUNXI_DMA is not set
CONFIG_SERIAL_SUNXI_CONSOLE=y
# CONFIG_SERIAL_SUNXI_EARLYCON is not set
# end of Serial drivers
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_TTY_PRINTK is not set
CONFIG_HVC_DRIVER=y
# CONFIG_HVC_RISCV_SBI is not set
CONFIG_VIRTIO_CONSOLE=m
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# CONFIG_SUNXI_BS83B16C is not set
# end of Character devices
# CONFIG_RANDOM_TRUST_BOOTLOADER is not set
CONFIG_DUMP_REG=y
CONFIG_DUMP_REG_MISC=y
# CONFIG_SUNXI_G2D is not set
# CONFIG_SUNXI_DI is not set
# CONFIG_SUNXI_SYS_INFO is not set
# CONFIG_SUNXI_SMC is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
# CONFIG_I2C_MUX_PCA954x is not set
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_MV64XXX is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_SUNXI=y
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
# CONFIG_SPI_MEM is not set
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
# CONFIG_SPI_SUN4I is not set
# CONFIG_SPI_SUN6I is not set
# CONFIG_SPI_MXIC is not set
CONFIG_SPI_SUNXI=y
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
# CONFIG_PPS is not set
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
# Allwinner SOC PINCTRL DRIVER
CONFIG_PINCTRL_SUNXI=y
# CONFIG_PINCTRL_SUNXI_DEBUGFS is not set
# CONFIG_PINCTRL_SUNXI_TEST is not set
# CONFIG_PINCTRL_SUN8IW15P1 is not set
# CONFIG_PINCTRL_SUN8IW15P1_R is not set
CONFIG_PINCTRL_SUN8IW20=y
# CONFIG_PINCTRL_SUN50IW9 is not set
# CONFIG_PINCTRL_SUN50IW9_R is not set
# CONFIG_PINCTRL_SUN50IW10P1 is not set
# CONFIG_PINCTRL_SUN50IW10P1_R is not set
# CONFIG_PINCTRL_SUN50IW12 is not set
# CONFIG_PINCTRL_SUN50IW12_R is not set
# CONFIG_PINCTRL_SUN4I_A10 is not set
# CONFIG_PINCTRL_SUN5I is not set
# CONFIG_PINCTRL_SUN6I_A31 is not set
# CONFIG_PINCTRL_SUN6I_A31_R is not set
# CONFIG_PINCTRL_SUN8I_A23 is not set
# CONFIG_PINCTRL_SUN8I_A33 is not set
# CONFIG_PINCTRL_SUN8I_A83T is not set
# CONFIG_PINCTRL_SUN8I_A83T_R is not set
# CONFIG_PINCTRL_SUN8I_A23_R is not set
# CONFIG_PINCTRL_SUN8I_H3 is not set
# CONFIG_PINCTRL_SUN8I_H3_R is not set
# CONFIG_PINCTRL_SUN8I_V3S is not set
# CONFIG_PINCTRL_SUN9I_A80 is not set
# CONFIG_PINCTRL_SUN9I_A80_R is not set
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_A100 is not set
# CONFIG_PINCTRL_SUN50I_A100_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
# CONFIG_PINCTRL_SUN50I_H6 is not set
# CONFIG_PINCTRL_SUN50I_H6_R is not set
# end of Allwinner SOC PINCTRL DRIVER
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
# CONFIG_DEBUG_GPIO is not set
# CONFIG_GPIO_SYSFS is not set
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_SUNXI is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_BS83B16C is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# end of MFD GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_W1 is not set
# CONFIG_POWER_AVS is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_POWER_SUPPLY_HWMON=y
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_AS370 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_STATISTICS=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
# CONFIG_CPU_THERMAL is not set
# CONFIG_CLOCK_THERMAL is not set
CONFIG_THERMAL_EMULATION=y
# CONFIG_THERMAL_MMIO is not set
# CONFIG_QORIQ_THERMAL is not set
CONFIG_SUNXI_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_SUNXI_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP2101_I2C is not set
# CONFIG_MFD_AXP20X_I2C is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
# CONFIG_MFD_SYSCON is not set
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
CONFIG_SUNXI_REGULATOR_PWM=y
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_GPIO is not set
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_RC_CORE=y
CONFIG_RC_MAP=y
# CONFIG_LIRC is not set
CONFIG_RC_DECODERS=y
CONFIG_IR_NEC_DECODER=y
CONFIG_IR_RC5_DECODER=y
# CONFIG_IR_RC6_DECODER is not set
# CONFIG_IR_JVC_DECODER is not set
# CONFIG_IR_SONY_DECODER is not set
# CONFIG_IR_SANYO_DECODER is not set
# CONFIG_IR_SHARP_DECODER is not set
# CONFIG_IR_MCE_KBD_DECODER is not set
# CONFIG_IR_XMP_DECODER is not set
# CONFIG_IR_IMON_DECODER is not set
# CONFIG_IR_RCMM_DECODER is not set
CONFIG_RC_DEVICES=y
# CONFIG_RC_ATI_REMOTE is not set
# CONFIG_IR_HIX5HD2 is not set
# CONFIG_IR_IMON is not set
# CONFIG_IR_IMON_RAW is not set
# CONFIG_IR_MCEUSB is not set
# CONFIG_IR_REDRAT3 is not set
# CONFIG_IR_STREAMZAP is not set
# CONFIG_IR_IGORPLUGUSB is not set
# CONFIG_IR_IGUANA is not set
# CONFIG_IR_TTUSBIR is not set
# CONFIG_RC_LOOPBACK is not set
# CONFIG_IR_GPIO_CIR is not set
# CONFIG_IR_SUNXI is not set
CONFIG_IR_RX_SUNXI=y
CONFIG_IR_TX_SUNXI=y
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
# CONFIG_RC_XBOX_DVD is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
# CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
# CONFIG_MEDIA_CONTROLLER is not set
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2=y
CONFIG_VIDEO_V4L2_I2C=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=y
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
# CONFIG_USB_M5602 is not set
# CONFIG_USB_STV06XX is not set
# CONFIG_USB_GL860 is not set
# CONFIG_USB_GSPCA_BENQ is not set
# CONFIG_USB_GSPCA_CONEX is not set
# CONFIG_USB_GSPCA_CPIA1 is not set
# CONFIG_USB_GSPCA_DTCS033 is not set
# CONFIG_USB_GSPCA_ETOMS is not set
# CONFIG_USB_GSPCA_FINEPIX is not set
# CONFIG_USB_GSPCA_JEILINJ is not set
# CONFIG_USB_GSPCA_JL2005BCD is not set
# CONFIG_USB_GSPCA_KINECT is not set
# CONFIG_USB_GSPCA_KONICA is not set
# CONFIG_USB_GSPCA_MARS is not set
# CONFIG_USB_GSPCA_MR97310A is not set
# CONFIG_USB_GSPCA_NW80X is not set
# CONFIG_USB_GSPCA_OV519 is not set
# CONFIG_USB_GSPCA_OV534 is not set
# CONFIG_USB_GSPCA_OV534_9 is not set
# CONFIG_USB_GSPCA_PAC207 is not set
# CONFIG_USB_GSPCA_PAC7302 is not set
# CONFIG_USB_GSPCA_PAC7311 is not set
# CONFIG_USB_GSPCA_SE401 is not set
# CONFIG_USB_GSPCA_SN9C2028 is not set
# CONFIG_USB_GSPCA_SN9C20X is not set
# CONFIG_USB_GSPCA_SONIXB is not set
# CONFIG_USB_GSPCA_SONIXJ is not set
# CONFIG_USB_GSPCA_SPCA500 is not set
# CONFIG_USB_GSPCA_SPCA501 is not set
# CONFIG_USB_GSPCA_SPCA505 is not set
# CONFIG_USB_GSPCA_SPCA506 is not set
# CONFIG_USB_GSPCA_SPCA508 is not set
# CONFIG_USB_GSPCA_SPCA561 is not set
# CONFIG_USB_GSPCA_SPCA1528 is not set
# CONFIG_USB_GSPCA_SQ905 is not set
# CONFIG_USB_GSPCA_SQ905C is not set
# CONFIG_USB_GSPCA_SQ930X is not set
# CONFIG_USB_GSPCA_STK014 is not set
# CONFIG_USB_GSPCA_STK1135 is not set
# CONFIG_USB_GSPCA_STV0680 is not set
# CONFIG_USB_GSPCA_SUNPLUS is not set
# CONFIG_USB_GSPCA_T613 is not set
# CONFIG_USB_GSPCA_TOPRO is not set
# CONFIG_USB_GSPCA_TOUPTEK is not set
# CONFIG_USB_GSPCA_TV8532 is not set
# CONFIG_USB_GSPCA_VC032X is not set
# CONFIG_USB_GSPCA_VICAM is not set
# CONFIG_USB_GSPCA_XIRLINK_CIT is not set
# CONFIG_USB_GSPCA_ZC3XX is not set
# CONFIG_USB_PWC is not set
# CONFIG_VIDEO_CPIA2 is not set
# CONFIG_USB_ZR364XX is not set
# CONFIG_USB_STKWEBCAM is not set
# CONFIG_USB_S2255 is not set
# Webcam, TV (analog/digital) USB devices
# CONFIG_VIDEO_EM28XX is not set
# CONFIG_V4L_PLATFORM_DRIVERS is not set
# CONFIG_SUNXI_PLATFORM_DRIVERS is not set
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_CYPRESS_FIRMWARE is not set
CONFIG_VIDEOBUF2_CORE=y
CONFIG_VIDEOBUF2_V4L2=y
CONFIG_VIDEOBUF2_MEMOPS=y
CONFIG_VIDEOBUF2_VMALLOC=y
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
CONFIG_MEDIA_SUBDRV_AUTOSELECT=y
CONFIG_VIDEO_IR_I2C=y
# I2C Encoders, decoders, sensors and other helper chips
# Audio decoders, processors and mixers
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
# CONFIG_VIDEO_MSP3400 is not set
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_UDA1342 is not set
# CONFIG_VIDEO_WM8775 is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# CONFIG_VIDEO_SONY_BTF_MPX is not set
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_SAA7110 is not set
# CONFIG_VIDEO_SAA711X is not set
# CONFIG_VIDEO_TVP514X is not set
# CONFIG_VIDEO_TVP5150 is not set
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_TW2804 is not set
# CONFIG_VIDEO_TW9903 is not set
# CONFIG_VIDEO_TW9906 is not set
# CONFIG_VIDEO_TW9910 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
# CONFIG_VIDEO_CX25840 is not set
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_THS8200 is not set
# Camera sensor devices
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV6650 is not set
# CONFIG_VIDEO_OV5695 is not set
# CONFIG_VIDEO_OV772X is not set
# CONFIG_VIDEO_OV7640 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_OV7740 is not set
# CONFIG_VIDEO_OV9640 is not set
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9T112 is not set
# CONFIG_VIDEO_MT9V011 is not set
# CONFIG_VIDEO_MT9V111 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_VIDEO_RJ54N1 is not set
# Lens drivers
# Flash devices
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_I2C is not set
# end of I2C Encoders, decoders, sensors and other helper chips
# SPI helper chips
# end of SPI helper chips
# Media SPI Adapters
# end of Media SPI Adapters
# Customise DVB Frontends
# Tools to develop new frontends
# end of Customise DVB Frontends
CONFIG_VIDEO_ENCODER_DECODER_SUNXI=y
# CONFIG_VIDEO_GOOGLE_DECODER_SUNXI is not set
# Graphics support
# CONFIG_DRM is not set
# CONFIG_DRM_DP_CEC is not set
# ARM devices
# end of ARM devices
# ACP (Audio CoProcessor) Configuration
# end of ACP (Audio CoProcessor) Configuration
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
# Video support for sunxi
# CONFIG_FB_CONSOLE_SUNXI is not set
CONFIG_DISP2_SUNXI=y
CONFIG_SUNXI_DISP2_FB_DISABLE_ROTATE=y
# CONFIG_SUNXI_DISP2_FB_ROTATION_SUPPORT is not set
# CONFIG_SUNXI_DISP2_FB_DECOMPRESS_LZMA is not set
# CONFIG_HDMI_DISP2_SUNXI is not set
CONFIG_HDMI2_DISP2_SUNXI=y
CONFIG_AW_PHY=y
# CONFIG_DEFAULT_PHY is not set
# CONFIG_HDMI_EP952_DISP2_SUNXI is not set
# CONFIG_HDMI2_HDCP_SUNXI is not set
# CONFIG_HDMI2_CEC_SUNXI is not set
# CONFIG_HDMI2_FREQ_SPREAD_SPECTRUM is not set
# CONFIG_TV_DISP2_SUNXI is not set
# CONFIG_VDPO_DISP2_SUNXI is not set
# CONFIG_EDP_DISP2_SUNXI is not set
# CONFIG_DISP2_SUNXI_BOOT_COLORBAR is not set
CONFIG_DISP2_SUNXI_DEBUG=y
# CONFIG_DISP2_SUNXI_COMPOSER is not set
# CONFIG_DISP2_LCD_ESD_DETECT is not set
# CONFIG_LCD_FB is not set
# CONFIG_LCD_FB_ENABLE_DEFERRED_IO is not set
# LCD panels select
# CONFIG_LCD_SUPPORT_GG1P4062UTSW is not set
# CONFIG_LCD_SUPPORT_DX0960BE40A1 is not set
# CONFIG_LCD_SUPPORT_TFT720X1280 is not set
# CONFIG_LCD_SUPPORT_FD055HD003S is not set
CONFIG_LCD_SUPPORT_HE0801A068=y
# CONFIG_LCD_SUPPORT_ILI9341 is not set
# CONFIG_LCD_SUPPORT_LH219WQ1 is not set
# CONFIG_LCD_SUPPORT_LS029B3SX02 is not set
# CONFIG_LCD_SUPPORT_LT070ME05000 is not set
# CONFIG_LCD_SUPPORT_S6D7AA0X01 is not set
# CONFIG_LCD_SUPPORT_T27P06 is not set
# CONFIG_LCD_SUPPORT_TFT720x1280 is not set
# CONFIG_LCD_SUPPORT_WTQ05027D01 is not set
# CONFIG_LCD_SUPPORT_H245QBN02 is not set
# CONFIG_LCD_SUPPORT_ST7789V is not set
# CONFIG_LCD_SUPPORT_ST7796S is not set
# CONFIG_LCD_SUPPORT_ST7701S is not set
# CONFIG_LCD_SUPPORT_T30P106 is not set
# CONFIG_LCD_SUPPORT_TO20T20000 is not set
# CONFIG_LCD_SUPPORT_FRD450H40014 is not set
# CONFIG_LCD_SUPPORT_S2003T46G is not set
CONFIG_LCD_SUPPORT_WILLIAMLCD=y
CONFIG_LCD_SUPPORT_LQ101R1SX03=y
CONFIG_LCD_SUPPORT_INET_DSI_PANEL=y
# CONFIG_LCD_SUPPORT_WTL096601G03 is not set
# CONFIG_LCD_SUPPORT_RT13QV005D is not set
# CONFIG_LCD_SUPPORT_ST7789V_CPU is not set
CONFIG_LCD_SUPPORT_CC08021801_310_800X1280=y
# CONFIG_LCD_SUPPORT_JD9366AB_3 is not set
# CONFIG_LCD_SUPPORT_TFT08006 is not set
# end of LCD panels select
# Display engine feature select
CONFIG_DISP2_SUNXI_SUPPORT_SMBL=y
CONFIG_DISP2_SUNXI_SUPPORT_ENAHNCE=y
# end of Display engine feature select
# end of Video support for sunxi
# end of Frame buffer Devices
# Backlight & LCD device support
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=y
# CONFIG_BACKLIGHT_PWM is not set
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# end of Backlight & LCD device support
# Console display driver support
CONFIG_VGA_CONSOLE=y
# CONFIG_VGACON_SOFT_SCROLLBACK is not set
CONFIG_DUMMY_CONSOLE=y
CONFIG_DUMMY_CONSOLE_COLUMNS=80
CONFIG_DUMMY_CONSOLE_ROWS=25
# CONFIG_FRAMEBUFFER_CONSOLE is not set
# end of Console display driver support
# CONFIG_LOGO is not set
# end of Graphics support
# CONFIG_SOUND is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_AUREAL is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
# CONFIG_HID_ITE is not set
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LENOVO is not set
# CONFIG_HID_LOGITECH is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
# CONFIG_HID_REDRAGON is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MONTEREY is not set
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NINTENDO is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_USB_CONN_GPIO is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
# CONFIG_USB_MON is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_SUNXI=y
# CONFIG_USB_EHCI_HCD_PLATFORM is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_SUNXI=y
# CONFIG_USB_OHCI_HCD_PLATFORM is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
CONFIG_USB_SUNXI_HCD=y
CONFIG_USB_SUNXI_HCI=y
CONFIG_USB_SUNXI_EHCI0=y
CONFIG_USB_SUNXI_EHCI1=y
CONFIG_USB_SUNXI_OHCI0=y
CONFIG_USB_SUNXI_OHCI1=y
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=y
CONFIG_REALTEK_AUTOPM=y
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_USBAT=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
CONFIG_USB_STORAGE_ALAUDA=y
CONFIG_USB_STORAGE_ONETOUCH=y
CONFIG_USB_STORAGE_KARMA=y
CONFIG_USB_STORAGE_CYPRESS_ATACB=y
CONFIG_USB_STORAGE_ENE_UB6250=y
CONFIG_USB_UAS=y
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
# CONFIG_USB_CDNS3 is not set
# CONFIG_USB_MUSB_HDRC is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
# CONFIG_NOP_USB_XCEIV is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
CONFIG_USB_SUNXI_UDC0=y
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
CONFIG_USB_LIBCOMPOSITE=y
CONFIG_USB_U_SERIAL=y
CONFIG_USB_F_SERIAL=y
CONFIG_USB_F_MASS_STORAGE=y
CONFIG_USB_F_FS=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_UEVENT=y
CONFIG_USB_CONFIGFS_SERIAL=y
# CONFIG_USB_CONFIGFS_ACM is not set
# CONFIG_USB_CONFIGFS_OBEX is not set
# CONFIG_USB_CONFIGFS_NCM is not set
# CONFIG_USB_CONFIGFS_ECM is not set
# CONFIG_USB_CONFIGFS_ECM_SUBSET is not set
# CONFIG_USB_CONFIGFS_RNDIS is not set
# CONFIG_USB_CONFIGFS_EEM is not set
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
# CONFIG_USB_CONFIGFS_F_LB_SS is not set
CONFIG_USB_CONFIGFS_F_FS=y
# CONFIG_USB_CONFIGFS_F_ACC is not set
# CONFIG_USB_CONFIGFS_F_HID is not set
# CONFIG_USB_CONFIGFS_F_UVC is not set
# CONFIG_USB_CONFIGFS_F_PRINTER is not set
CONFIG_USB_SUNXI_USB=y
CONFIG_USB_SUNXI_USB_MANAGER=y
CONFIG_USB_SUNXI_USB_DEBUG=y
CONFIG_USB_SUNXI_USB_ADB=y
# CONFIG_TYPEC is not set
CONFIG_USB_ROLE_SWITCH=y
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
CONFIG_MMC_SUNXI_V4P1X=y
CONFIG_MMC_SUNXI_V4P00X=y
CONFIG_MMC_SUNXI_V4P10X=y
CONFIG_MMC_SUNXI_V4P5X=y
CONFIG_MMC_SUNXI_V5P3X=y
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_HSQ is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
# CONFIG_RTC_DRV_SUN6I is not set
CONFIG_RTC_DRV_SUNXI=y
# CONFIG_SUNXI_REBOOT_FLAG is not set
# CONFIG_SUNXI_RTC_BOOTCOUNT is not set
# CONFIG_SUNXI_RTC_POWEROFF_ALARM is not set
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
CONFIG_DMA_SUN6I=y
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_SELFTESTS is not set
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VFIO is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO=y
# CONFIG_VIRTIO_MENU is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
CONFIG_STAGING=y
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
# CONFIG_R8712U is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# end of Speakup console speech
# CONFIG_STAGING_MEDIA is not set
# Android
# CONFIG_ASHMEM is not set
CONFIG_ION=y
CONFIG_ION_SYSTEM_HEAP=y
CONFIG_ION_CMA_HEAP=y
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
# CONFIG_FB_TFT is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_PI433 is not set
# Gasket devices
# end of Gasket devices
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_USB_WUSB_CBAF is not set
# CONFIG_UWB is not set
# CONFIG_EXFAT_FS is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_COMMON_CLK_DEBUG is not set
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
# CONFIG_CLK_SIFIVE is not set
# CONFIG_CLK_SUNXI is not set
CONFIG_SUNXI_CCU=y
CONFIG_SUN8IW20_CCU=y
CONFIG_SUN8IW20_R_CCU=y
# CONFIG_SUN8I_A83T_CCU is not set
# CONFIG_SUN8I_DE2_CCU is not set
# CONFIG_SUN8I_R_CCU is not set
CONFIG_SUNXI_RTC_CCU=y
# end of Common Clock Framework
# CONFIG_HWSPINLOCK is not set
# CONFIG_HWSPINLOCK_SUNXI is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
# CONFIG_SUN4I_TIMER is not set
# CONFIG_SUN50I_TIMER is not set
# CONFIG_SUNXI_TIMER is not set
# CONFIG_SUNXI_TIMER_TEST is not set
# CONFIG_MTK_TIMER is not set
CONFIG_RISCV_TIMER=y
# end of Clock Source drivers
# CONFIG_MAILBOX is not set
CONFIG_IOMMU_IOVA=y
CONFIG_IOMMU_API=y
# CONFIG_IOMMU_LIMIT_IOVA_ALIGNMENT is not set
CONFIG_IOMMU_SUPPORT=y
# Generic IOMMU Pagetable Support
# end of Generic IOMMU Pagetable Support
# CONFIG_IOMMU_DEBUGFS is not set
# CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
CONFIG_OF_IOMMU=y
CONFIG_IOMMU_DMA=y
CONFIG_SUNXI_IOMMU=y
CONFIG_SUNXI_IOMMU_DEBUG=y
CONFIG_SUNXI_IOMMU_TESTS=y
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
CONFIG_RPMSG=y
# CONFIG_RPMSG_CHAR is not set
# CONFIG_RPMSG_SUNXI_AMP is not set
CONFIG_RPMSG_VIRTIO=y
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SUNXI_SRAM=y
CONFIG_SUNXI_SID=y
CONFIG_SUNXI_RISCV_SUSPEND=y
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
# CONFIG_PM_DEVFREQ is not set
# CONFIG_EXTCON is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
# CONFIG_PWM_SIFIVE is not set
# CONFIG_PWM_SUN4I is not set
CONFIG_PWM_SUNXI_GROUP=y
# IRQ chip support
CONFIG_IRQCHIP=y
# CONFIG_AL_FIC is not set
CONFIG_SIFIVE_PLIC=y
# CONFIG_SUNXI_WAKEUPGEN is not set
# CONFIG_SUN8I_NMI is not set
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
# CONFIG_GENERIC_PHY is not set
# CONFIG_PHY_SUN6I_MIPI_DPHY is not set
# CONFIG_PHY_SUN9I_USB is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_DP is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# CONFIG_RAS is not set
# Android
CONFIG_ANDROID=y
# CONFIG_ANDROID_BINDER_IPC is not set
# end of Android
# CONFIG_LIBNVDIMM is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_SUNXI_SID=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# end of Device Drivers
# File systems
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
CONFIG_EXT4_FS_POSIX_ACL=y
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
# CONFIG_FS_DAX is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# CONFIG_INCREMENTAL_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_NTFS_FS is not set
# end of DOS/FAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_PROC_CHILDREN=y
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_HUGETLBFS is not set
CONFIG_MEMFD_CREATE=y
CONFIG_ARCH_HAS_GIGANTIC_PAGE=y
CONFIG_CONFIGFS_FS=y
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
CONFIG_UBIFS_FS=y
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_UBIFS_FS_AUTHENTICATION is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
# CONFIG_NFS_FS is not set
# CONFIG_NFSD is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# CONFIG_UNICODE is not set
# end of File systems
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_ACOMP2=y
# CONFIG_CRYPTO_MANAGER is not set
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Public-key cryptography
# CONFIG_CRYPTO_RSA is not set
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
# CONFIG_CRYPTO_ECRDSA is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_SEQIV is not set
# CONFIG_CRYPTO_ECHAINIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CFB is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
# CONFIG_CRYPTO_ESSIV is not set
# Hash modes
# CONFIG_CRYPTO_CMAC is not set
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_XXHASH is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_LIB_DES=y
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_LZO=y
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
CONFIG_CRYPTO_ZSTD=y
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_DRBG_MENU is not set
# CONFIG_CRYPTO_JITTERENTROPY is not set
CONFIG_CRYPTO_USER_API=y
CONFIG_CRYPTO_USER_API_HASH=y
CONFIG_CRYPTO_USER_API_SKCIPHER=y
CONFIG_CRYPTO_USER_API_RNG=y
CONFIG_CRYPTO_USER_API_AEAD=y
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
CONFIG_CRYPTO_DEV_SUNXI=y
# CONFIG_CRYPTO_DEV_VIRTIO is not set
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# Certificates for signature checking
# end of Certificates for signature checking
# Library routines
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
# CONFIG_CRC_CCITT is not set
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
CONFIG_CRC7=y
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
CONFIG_XXHASH=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=y
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_SG_DMA_LENGTH=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_ARCH_HAS_DMA_WRITE_COMBINE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
CONFIG_ARCH_HAS_DMA_PREP_COHERENT=y
CONFIG_ARCH_HAS_DMA_COHERENT_TO_PFN=y
CONFIG_DMA_REMAP=y
CONFIG_DMA_DIRECT_REMAP=y
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=16
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_DQL=y
CONFIG_NLATTR=y
# CONFIG_IRQ_POLL is not set
CONFIG_LIBFDT=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DYNAMIC_DEBUG_CORE is not set
# end of printk and dmesg options
# Compile-time checks and compiler options
CONFIG_DEBUG_INFO=y
# CONFIG_DEBUG_INFO_REDUCED is not set
# CONFIG_DEBUG_INFO_SPLIT is not set
# CONFIG_DEBUG_INFO_DWARF4 is not set
# CONFIG_DEBUG_INFO_BTF is not set
# CONFIG_GDB_SCRIPTS is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=2048
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_INSTALL is not set
CONFIG_OPTIMIZE_INLINING=y
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_KASAN_STACK=1
# end of Memory Debugging
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# end of Debug Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHEDSTATS is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_STACKTRACE is not set
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_PREEMPTIRQ_EVENTS is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_HWLAT_TRACER is not set
# CONFIG_ENABLE_DEFAULT_TRACERS is not set
# CONFIG_FTRACE_SYSCALLS is not set
# CONFIG_TRACER_SNAPSHOT is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_BITFIELD is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_STACKINIT is not set
# CONFIG_TEST_MEMINIT is not set
# CONFIG_MEMTEST is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_SAMPLES is not set
# CONFIG_UBSAN is not set
CONFIG_UBSAN_ALIGNMENT=y
# end of Kernel hacking
执行命令:
rm output/build/linux-origin_master/.stamp_built ;make;
用 win32diskimager 把 output/images/sdcard.img 烧录到TF卡,启动。
buildroot .config 配置(已包含 evtest):
# Buildroot -g51c4355 Configuration
BR2_HAVE_DOT_CONFIG=y
BR2_HOST_GCC_AT_LEAST_4_9=y
BR2_HOST_GCC_AT_LEAST_5=y
BR2_HOST_GCC_AT_LEAST_6=y
BR2_HOST_GCC_AT_LEAST_7=y
# Target options
BR2_ARCH_IS_64=y
BR2_ARCH_HAS_MMU_MANDATORY=y
# BR2_arcle is not set
# BR2_arceb is not set
# BR2_arm is not set
# BR2_armeb is not set
# BR2_aarch64 is not set
# BR2_aarch64_be is not set
# BR2_csky is not set
# BR2_i386 is not set
# BR2_m68k is not set
# BR2_microblazeel is not set
# BR2_microblazebe is not set
# BR2_mips is not set
# BR2_mipsel is not set
# BR2_mips64 is not set
# BR2_mips64el is not set
# BR2_nds32 is not set
# BR2_nios2 is not set
# BR2_or1k is not set
# BR2_powerpc is not set
# BR2_powerpc64 is not set
# BR2_powerpc64le is not set
BR2_riscv=y
# BR2_s390x is not set
# BR2_sh is not set
# BR2_sparc is not set
# BR2_sparc64 is not set
# BR2_x86_64 is not set
# BR2_xtensa is not set
BR2_ARCH_HAS_TOOLCHAIN_BUILDROOT=y
BR2_ARCH_NEEDS_GCC_AT_LEAST_4_8=y
BR2_ARCH_NEEDS_GCC_AT_LEAST_4_9=y
BR2_ARCH_NEEDS_GCC_AT_LEAST_5=y
BR2_ARCH_NEEDS_GCC_AT_LEAST_6=y
BR2_ARCH_NEEDS_GCC_AT_LEAST_7=y
BR2_ARCH="riscv64"
BR2_ENDIAN="LITTLE"
BR2_GCC_TARGET_ABI="lp64d"
BR2_BINFMT_SUPPORTS_SHARED=y
BR2_READELF_ARCH_NAME="RISC-V"
BR2_BINFMT_ELF=y
BR2_RISCV_ISA_RVI=y
BR2_RISCV_ISA_RVM=y
BR2_RISCV_ISA_RVA=y
BR2_RISCV_ISA_RVF=y
BR2_RISCV_ISA_RVD=y
BR2_riscv_g=y
# BR2_riscv_custom is not set
# BR2_RISCV_32 is not set
BR2_RISCV_64=y
# BR2_RISCV_ABI_LP64 is not set
# BR2_RISCV_ABI_LP64F is not set
BR2_RISCV_ABI_LP64D=y
# Build options
# Commands
BR2_WGET="wget --passive-ftp -nd -t 3"
BR2_SVN="svn --non-interactive"
BR2_BZR="bzr"
BR2_GIT="git"
BR2_CVS="cvs"
BR2_LOCALFILES="cp"
BR2_SCP="scp"
BR2_HG="hg"
BR2_ZCAT="gzip -d -c"
BR2_BZCAT="bzcat"
BR2_XZCAT="xzcat"
BR2_LZCAT="lzip -d -c"
BR2_TAR_OPTIONS=""
BR2_DEFCONFIG="/home/book/Buildroot/guanfang/buildroot-2021.02.1/configs/hifive_unleashed_defconfig"
BR2_DL_DIR="$(TOPDIR)/dl"
BR2_HOST_DIR="$(BASE_DIR)/host"
# Mirrors and Download locations
BR2_PRIMARY_SITE=""
BR2_BACKUP_SITE="http://sources.buildroot.net"
BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub"
BR2_GNU_MIRROR="http://ftpmirror.gnu.org"
BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org"
BR2_CPAN_MIRROR="http://cpan.metacpan.org"
BR2_JLEVEL=0
# BR2_CCACHE is not set
# BR2_ENABLE_DEBUG is not set
BR2_STRIP_strip=y
BR2_STRIP_EXCLUDE_FILES=""
BR2_STRIP_EXCLUDE_DIRS=""
# BR2_OPTIMIZE_0 is not set
# BR2_OPTIMIZE_1 is not set
# BR2_OPTIMIZE_2 is not set
# BR2_OPTIMIZE_3 is not set
# BR2_OPTIMIZE_G is not set
BR2_OPTIMIZE_S=y
# BR2_OPTIMIZE_FAST is not set
# BR2_STATIC_LIBS is not set
BR2_SHARED_LIBS=y
# BR2_SHARED_STATIC_LIBS is not set
BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk"
BR2_GLOBAL_PATCH_DIR=""
# Advanced
BR2_COMPILER_PARANOID_UNSAFE_PATH=y
# BR2_FORCE_HOST_BUILD is not set
# BR2_REPRODUCIBLE is not set
# BR2_PER_PACKAGE_DIRECTORIES is not set
# Security Hardening Options
# BR2_PIC_PIE is not set
BR2_SSP_NONE=y
# BR2_SSP_REGULAR is not set
# BR2_SSP_STRONG is not set
# BR2_SSP_ALL is not set
BR2_RELRO_NONE=y
# BR2_RELRO_PARTIAL is not set
# BR2_RELRO_FULL is not set
BR2_FORTIFY_SOURCE_NONE=y
# BR2_FORTIFY_SOURCE_1 is not set
# BR2_FORTIFY_SOURCE_2 is not set
# Toolchain
BR2_TOOLCHAIN=y
BR2_TOOLCHAIN_USES_GLIBC=y
# BR2_TOOLCHAIN_BUILDROOT is not set
BR2_TOOLCHAIN_EXTERNAL=y
# Toolchain External Options
BR2_TOOLCHAIN_EXTERNAL_CUSTOM=y
BR2_TOOLCHAIN_EXTERNAL_DOWNLOAD=y
# BR2_TOOLCHAIN_EXTERNAL_PREINSTALLED is not set
BR2_TOOLCHAIN_EXTERNAL_GLIBC=y
BR2_PACKAGE_HAS_TOOLCHAIN_EXTERNAL=y
BR2_PACKAGE_PROVIDES_TOOLCHAIN_EXTERNAL="toolchain-external-custom"
BR2_TOOLCHAIN_EXTERNAL_PREFIX="$(ARCH)-unknown-linux-gnu"
BR2_TOOLCHAIN_EXTERNAL_URL="https://weidongshan.coding.net/p/Tina-D1/d/Toolchain/git/raw/master/riscv64-glibc-gcc-thead_20200702.tar.xz"
BR2_TOOLCHAIN_EXTERNAL_REL_BIN_PATH="bin"
BR2_TOOLCHAIN_EXTERNAL_CUSTOM_PREFIX="$(ARCH)-unknown-linux-gnu"
# BR2_TOOLCHAIN_EXTERNAL_GCC_10 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_9 is not set
BR2_TOOLCHAIN_EXTERNAL_GCC_8=y
# BR2_TOOLCHAIN_EXTERNAL_GCC_7 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_6 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_5 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_9 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_8 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_7 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_6 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_5 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_4 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_4_3 is not set
# BR2_TOOLCHAIN_EXTERNAL_GCC_OLD is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_10 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_9 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_8 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_7 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_6 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_5 is not set
BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_4=y
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_3 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_2 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_1 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_0 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_20 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_19 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_18 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_17 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_16 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_15 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_13 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_12 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_11 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_10 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_9 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_8 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_7 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_6 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_5 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_4 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_3 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_2 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_1 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_0 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_19 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_18 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_17 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_16 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_15 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_13 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_12 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_11 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_10 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_9 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_8 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_7 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_6 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_5 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_4 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_3 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_2 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_1 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_0 is not set
# BR2_TOOLCHAIN_EXTERNAL_HEADERS_REALLY_OLD is not set
# BR2_TOOLCHAIN_EXTERNAL_CUSTOM_UCLIBC is not set
BR2_TOOLCHAIN_EXTERNAL_CUSTOM_GLIBC=y
# BR2_TOOLCHAIN_EXTERNAL_CUSTOM_MUSL is not set
BR2_TOOLCHAIN_EXTERNAL_HAS_SSP=y
BR2_TOOLCHAIN_EXTERNAL_HAS_SSP_STRONG=y
BR2_TOOLCHAIN_EXTERNAL_INET_RPC=y
BR2_TOOLCHAIN_EXTERNAL_CXX=y
# BR2_TOOLCHAIN_EXTERNAL_DLANG is not set
BR2_TOOLCHAIN_EXTERNAL_FORTRAN=y
BR2_TOOLCHAIN_EXTERNAL_OPENMP=y
# BR2_TOOLCHAIN_EXTERNAL_GDB_SERVER_COPY is not set
# Toolchain Generic Options
BR2_TOOLCHAIN_SUPPORTS_ALWAYS_LOCKFREE_ATOMIC_INTS=y
BR2_TOOLCHAIN_SUPPORTS_VARIADIC_MI_THUNK=y
BR2_TOOLCHAIN_HAS_NATIVE_RPC=y
BR2_USE_WCHAR=y
BR2_ENABLE_LOCALE=y
BR2_INSTALL_LIBSTDCPP=y
BR2_TOOLCHAIN_HAS_FORTRAN=y
BR2_TOOLCHAIN_HAS_THREADS=y
BR2_TOOLCHAIN_HAS_THREADS_DEBUG=y
BR2_TOOLCHAIN_HAS_THREADS_NPTL=y
BR2_TOOLCHAIN_HAS_SSP=y
BR2_TOOLCHAIN_HAS_SSP_STRONG=y
BR2_TOOLCHAIN_HAS_UCONTEXT=y
BR2_TOOLCHAIN_HAS_OPENMP=y
BR2_TOOLCHAIN_SUPPORTS_PIE=y
# BR2_TOOLCHAIN_GLIBC_GCONV_LIBS_COPY is not set
BR2_TOOLCHAIN_EXTRA_LIBS="lib64xthead lib64vxthead"
BR2_TOOLCHAIN_HAS_FULL_GETTEXT=y
BR2_USE_MMU=y
BR2_TARGET_OPTIMIZATION="-Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead"
BR2_TARGET_LDFLAGS=""
# BR2_ECLIPSE_REGISTER is not set
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_20=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST="5.4"
BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y
BR2_TOOLCHAIN_GCC_AT_LEAST_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST="8"
BR2_TOOLCHAIN_HAS_MNAN_OPTION=y
BR2_TOOLCHAIN_HAS_SYNC_1=y
BR2_TOOLCHAIN_HAS_SYNC_2=y
BR2_TOOLCHAIN_HAS_SYNC_4=y
BR2_TOOLCHAIN_HAS_SYNC_8=y
BR2_TOOLCHAIN_HAS_LIBATOMIC=y
BR2_TOOLCHAIN_HAS_ATOMIC=y
# System configuration
BR2_ROOTFS_SKELETON_DEFAULT=y
# BR2_ROOTFS_SKELETON_CUSTOM is not set
BR2_TARGET_GENERIC_HOSTNAME="buildroot"
BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot"
BR2_TARGET_GENERIC_PASSWD_SHA256=y
# BR2_TARGET_GENERIC_PASSWD_SHA512 is not set
BR2_TARGET_GENERIC_PASSWD_METHOD="sha-256"
BR2_INIT_BUSYBOX=y
# BR2_INIT_SYSV is not set
# BR2_INIT_OPENRC is not set
# BR2_INIT_SYSTEMD is not set
# BR2_INIT_NONE is not set
# BR2_ROOTFS_DEVICE_CREATION_STATIC is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set
BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV=y
BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt"
# BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set
# BR2_ROOTFS_MERGED_USR is not set
BR2_TARGET_ENABLE_ROOT_LOGIN=y
BR2_TARGET_GENERIC_ROOT_PASSWD=""
BR2_SYSTEM_BIN_SH_BUSYBOX=y
# bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
# BR2_SYSTEM_BIN_SH_NONE is not set
BR2_TARGET_GENERIC_GETTY=y
BR2_TARGET_GENERIC_GETTY_PORT="ttyS0"
BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP=y
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 is not set
BR2_TARGET_GENERIC_GETTY_BAUDRATE="0"
BR2_TARGET_GENERIC_GETTY_TERM="vt100"
BR2_TARGET_GENERIC_GETTY_OPTIONS=""
BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y
BR2_SYSTEM_DHCP="eth0"
BR2_SYSTEM_DEFAULT_PATH="/bin:/sbin:/usr/bin:/usr/sbin"
BR2_ENABLE_LOCALE_PURGE=y
BR2_ENABLE_LOCALE_WHITELIST="C en_US"
BR2_GENERATE_LOCALE=""
# BR2_SYSTEM_ENABLE_NLS is not set
# BR2_TARGET_TZ_INFO is not set
BR2_ROOTFS_USERS_TABLES=""
BR2_ROOTFS_OVERLAY=""
BR2_ROOTFS_POST_BUILD_SCRIPT="board/Neza/d1/post-build.sh"
BR2_ROOTFS_POST_FAKEROOT_SCRIPT=""
BR2_ROOTFS_POST_IMAGE_SCRIPT="support/scripts/genimage.sh"
BR2_ROOTFS_POST_SCRIPT_ARGS="-c board/Neza/d1/genimage.cfg"
# Kernel
BR2_LINUX_KERNEL=y
# BR2_LINUX_KERNEL_LATEST_VERSION is not set
# BR2_LINUX_KERNEL_LATEST_CIP_VERSION is not set
# BR2_LINUX_KERNEL_LATEST_CIP_RT_VERSION is not set
# BR2_LINUX_KERNEL_CUSTOM_VERSION is not set
# BR2_LINUX_KERNEL_CUSTOM_TARBALL is not set
BR2_LINUX_KERNEL_CUSTOM_GIT=y
# BR2_LINUX_KERNEL_CUSTOM_HG is not set
# BR2_LINUX_KERNEL_CUSTOM_SVN is not set
BR2_LINUX_KERNEL_CUSTOM_REPO_URL="https://gitee.com/weidongshan/NezaD1-linuxkernel.git"
BR2_LINUX_KERNEL_CUSTOM_REPO_VERSION="origin/master"
BR2_LINUX_KERNEL_VERSION="origin/master"
BR2_LINUX_KERNEL_PATCH=""
BR2_LINUX_KERNEL_USE_DEFCONFIG=y
# BR2_LINUX_KERNEL_USE_ARCH_DEFAULT_CONFIG is not set
# BR2_LINUX_KERNEL_USE_CUSTOM_CONFIG is not set
BR2_LINUX_KERNEL_DEFCONFIG="sun20iw1p1_d1"
BR2_LINUX_KERNEL_CONFIG_FRAGMENT_FILES=""
BR2_LINUX_KERNEL_CUSTOM_LOGO_PATH=""
BR2_LINUX_KERNEL_IMAGE=y
# BR2_LINUX_KERNEL_IMAGEGZ is not set
# BR2_LINUX_KERNEL_VMLINUX is not set
# BR2_LINUX_KERNEL_IMAGE_TARGET_CUSTOM is not set
BR2_LINUX_KERNEL_GZIP=y
# BR2_LINUX_KERNEL_LZ4 is not set
# BR2_LINUX_KERNEL_LZMA is not set
# BR2_LINUX_KERNEL_LZO is not set
# BR2_LINUX_KERNEL_XZ is not set
# BR2_LINUX_KERNEL_ZSTD is not set
BR2_LINUX_KERNEL_DTS_SUPPORT=y
# BR2_LINUX_KERNEL_DTB_IS_SELF_BUILT is not set
BR2_LINUX_KERNEL_INTREE_DTS_NAME="board"
BR2_LINUX_KERNEL_CUSTOM_DTS_PATH=""
# BR2_LINUX_KERNEL_DTB_KEEP_DIRNAME is not set
# BR2_LINUX_KERNEL_DTB_OVERLAY_SUPPORT is not set
# BR2_LINUX_KERNEL_INSTALL_TARGET is not set
BR2_LINUX_KERNEL_NEEDS_HOST_OPENSSL=y
BR2_LINUX_KERNEL_NEEDS_HOST_LIBELF=y
# Linux Kernel Extensions
# BR2_LINUX_KERNEL_EXT_RTAI is not set
# BR2_LINUX_KERNEL_EXT_EV3DEV_LINUX_DRIVERS is not set
# BR2_LINUX_KERNEL_EXT_FBTFT is not set
# BR2_LINUX_KERNEL_EXT_AUFS is not set
# Linux Kernel Tools
# BR2_PACKAGE_LINUX_TOOLS_CPUPOWER is not set
# BR2_PACKAGE_LINUX_TOOLS_GPIO is not set
# BR2_PACKAGE_LINUX_TOOLS_IIO is not set
# BR2_PACKAGE_LINUX_TOOLS_PCI is not set
# BR2_PACKAGE_LINUX_TOOLS_PERF is not set
# selftests needs BR2_PACKAGE_BUSYBOX_SHOW_OTHERS and a toolchain w/ dynamic library
# BR2_PACKAGE_LINUX_TOOLS_TMON is not set
# Target packages
BR2_PACKAGE_BUSYBOX=y
BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config"
BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES=""
# BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set
# BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set
# BR2_PACKAGE_BUSYBOX_WATCHDOG is not set
BR2_PACKAGE_SKELETON=y
BR2_PACKAGE_HAS_SKELETON=y
BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv"
BR2_PACKAGE_SKELETON_INIT_COMMON=y
BR2_PACKAGE_SKELETON_INIT_SYSV=y
# Audio and video applications
# BR2_PACKAGE_ALSA_UTILS is not set
# BR2_PACKAGE_ATEST is not set
# BR2_PACKAGE_AUMIX is not set
# BR2_PACKAGE_BLUEZ_ALSA is not set
# BR2_PACKAGE_DVBLAST is not set
# BR2_PACKAGE_DVDAUTHOR is not set
# BR2_PACKAGE_DVDRW_TOOLS is not set
# BR2_PACKAGE_ESPEAK is not set
# BR2_PACKAGE_FAAD2 is not set
BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y
# BR2_PACKAGE_FFMPEG is not set
# BR2_PACKAGE_FLAC is not set
# BR2_PACKAGE_FLITE is not set
# BR2_PACKAGE_FLUID_SOUNDFONT is not set
# BR2_PACKAGE_FLUIDSYNTH is not set
# BR2_PACKAGE_GMRENDER_RESURRECT is not set
# BR2_PACKAGE_GSTREAMER1 is not set
# BR2_PACKAGE_JACK1 is not set
# BR2_PACKAGE_JACK2 is not set
BR2_PACKAGE_KODI_ARCH_SUPPORTS=y
# kodi needs python w/ .py modules, a uClibc or glibc toolchain w/ C++, threads, wchar, dynamic library, gcc >= 4.8
# kodi needs an OpenGL EGL backend with OpenGL support
# BR2_PACKAGE_LAME is not set
# BR2_PACKAGE_MADPLAY is not set
# BR2_PACKAGE_MIMIC is not set
# BR2_PACKAGE_MINIMODEM is not set
# miraclecast needs systemd and a glibc toolchain w/ threads and wchar
# BR2_PACKAGE_MJPEGTOOLS is not set
# BR2_PACKAGE_MODPLUGTOOLS is not set
# BR2_PACKAGE_MOTION is not set
# BR2_PACKAGE_MPD is not set
# BR2_PACKAGE_MPD_MPC is not set
# BR2_PACKAGE_MPG123 is not set
# BR2_PACKAGE_MPV is not set
# BR2_PACKAGE_MULTICAT is not set
# BR2_PACKAGE_MUSEPACK is not set
# BR2_PACKAGE_NCMPC is not set
# BR2_PACKAGE_OPUS_TOOLS is not set
BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y
# BR2_PACKAGE_PULSEAUDIO is not set
# BR2_PACKAGE_SOX is not set
# BR2_PACKAGE_SQUEEZELITE is not set
# BR2_PACKAGE_TSTOOLS is not set
# BR2_PACKAGE_TWOLAME is not set
# BR2_PACKAGE_UDPXY is not set
# BR2_PACKAGE_UPMPDCLI is not set
# BR2_PACKAGE_V4L2GRAB is not set
# BR2_PACKAGE_V4L2LOOPBACK is not set
# BR2_PACKAGE_VLC is not set
# BR2_PACKAGE_VORBIS_TOOLS is not set
# BR2_PACKAGE_WAVPACK is not set
# BR2_PACKAGE_YAVTA is not set
# BR2_PACKAGE_YMPD is not set
# Compressors and decompressors
# BR2_PACKAGE_BROTLI is not set
# BR2_PACKAGE_BZIP2 is not set
# BR2_PACKAGE_LRZIP is not set
# BR2_PACKAGE_LZIP is not set
# BR2_PACKAGE_LZOP is not set
# BR2_PACKAGE_P7ZIP is not set
# BR2_PACKAGE_PIGZ is not set
# BR2_PACKAGE_PIXZ is not set
# BR2_PACKAGE_UNRAR is not set
# BR2_PACKAGE_XZ is not set
# BR2_PACKAGE_ZIP is not set
# BR2_PACKAGE_ZSTD is not set
# Debugging, profiling and benchmark
# BR2_PACKAGE_BABELTRACE2 is not set
# BR2_PACKAGE_BLKTRACE is not set
# BR2_PACKAGE_BONNIE is not set
# BR2_PACKAGE_CACHE_CALIBRATOR is not set
# clinfo needs an OpenCL provider
# BR2_PACKAGE_COREMARK is not set
# BR2_PACKAGE_COREMARK_PRO is not set
# dacapo needs OpenJDK
# BR2_PACKAGE_DHRYSTONE is not set
# BR2_PACKAGE_DIEHARDER is not set
# BR2_PACKAGE_DMALLOC is not set
# BR2_PACKAGE_DROPWATCH is not set
# BR2_PACKAGE_DSTAT is not set
# BR2_PACKAGE_DT is not set
# BR2_PACKAGE_DUMA is not set
# BR2_PACKAGE_FIO is not set
BR2_PACKAGE_GDB_ARCH_SUPPORTS=y
# BR2_PACKAGE_GDB is not set
# BR2_PACKAGE_IOZONE is not set
# BR2_PACKAGE_KTAP is not set
# BR2_PACKAGE_LATENCYTOP is not set
# BR2_PACKAGE_LMBENCH is not set
BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTP_TESTSUITE is not set
# BR2_PACKAGE_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_LTTNG_MODULES is not set
# BR2_PACKAGE_LTTNG_TOOLS is not set
# BR2_PACKAGE_MEMSTAT is not set
# BR2_PACKAGE_NETPERF is not set
# BR2_PACKAGE_NETSNIFF_NG is not set
# BR2_PACKAGE_NMON is not set
# BR2_PACKAGE_PAX_UTILS is not set
# BR2_PACKAGE_PV is not set
# BR2_PACKAGE_RAMSMP is not set
# BR2_PACKAGE_RAMSPEED is not set
# BR2_PACKAGE_SPIDEV_TEST is not set
# BR2_PACKAGE_STRACE is not set
# BR2_PACKAGE_STRESS is not set
# BR2_PACKAGE_STRESS_NG is not set
# sysdig needs a glibc or uclibc toolchain w/ C++, threads, gcc >= 4.8, dynamic library, a Linux kernel, and luajit or lua 5.1 to be built
# BR2_PACKAGE_TINYMEMBENCH is not set
# BR2_PACKAGE_TRACE_CMD is not set
# BR2_PACKAGE_UCLIBC_NG_TEST is not set
# BR2_PACKAGE_VMTOUCH is not set
# BR2_PACKAGE_WHETSTONE is not set
# Development tools
# BR2_PACKAGE_BINUTILS is not set
# BR2_PACKAGE_BITWISE is not set
# BR2_PACKAGE_BSDIFF is not set
# BR2_PACKAGE_CHECK is not set
# BR2_PACKAGE_CPPUNIT is not set
# BR2_PACKAGE_CUKINIA is not set
# BR2_PACKAGE_CUNIT is not set
# BR2_PACKAGE_CVS is not set
# BR2_PACKAGE_CXXTEST is not set
# BR2_PACKAGE_FLEX is not set
# BR2_PACKAGE_GETTEXT is not set
BR2_PACKAGE_PROVIDES_HOST_GETTEXT="host-gettext-tiny"
# BR2_PACKAGE_GIT is not set
# BR2_PACKAGE_GIT_CRYPT is not set
# BR2_PACKAGE_GPERF is not set
# BR2_PACKAGE_JO is not set
# BR2_PACKAGE_JQ is not set
# BR2_PACKAGE_LIBTOOL is not set
# BR2_PACKAGE_MAKE is not set
# BR2_PACKAGE_PKGCONF is not set
# BR2_PACKAGE_SUBVERSION is not set
# BR2_PACKAGE_TREE is not set
# Filesystem and flash utilities
# BR2_PACKAGE_ABOOTIMG is not set
# BR2_PACKAGE_AUFS_UTIL is not set
# BR2_PACKAGE_AUTOFS is not set
# BR2_PACKAGE_BTRFS_PROGS is not set
# BR2_PACKAGE_CIFS_UTILS is not set
# BR2_PACKAGE_CPIO is not set
# BR2_PACKAGE_CRAMFS is not set
# BR2_PACKAGE_CURLFTPFS is not set
# BR2_PACKAGE_DAVFS2 is not set
# BR2_PACKAGE_DOSFSTOOLS is not set
# BR2_PACKAGE_E2FSPROGS is not set
# BR2_PACKAGE_E2TOOLS is not set
# BR2_PACKAGE_ECRYPTFS_UTILS is not set
# BR2_PACKAGE_EROFS_UTILS is not set
# BR2_PACKAGE_EXFAT is not set
# BR2_PACKAGE_EXFAT_UTILS is not set
# BR2_PACKAGE_EXFATPROGS is not set
# BR2_PACKAGE_F2FS_TOOLS is not set
# BR2_PACKAGE_FLASHBENCH is not set
# BR2_PACKAGE_FSCRYPTCTL is not set
# BR2_PACKAGE_FUSE_OVERLAYFS is not set
# BR2_PACKAGE_FWUP is not set
# BR2_PACKAGE_GENEXT2FS is not set
# BR2_PACKAGE_GENPART is not set
# BR2_PACKAGE_GENROMFS is not set
# BR2_PACKAGE_IMX_USB_LOADER is not set
# BR2_PACKAGE_MMC_UTILS is not set
# BR2_PACKAGE_MTD is not set
# BR2_PACKAGE_MTOOLS is not set
# BR2_PACKAGE_NFS_UTILS is not set
# BR2_PACKAGE_NILFS_UTILS is not set
# BR2_PACKAGE_NTFS_3G is not set
# BR2_PACKAGE_SP_OOPS_EXTRACT is not set
# BR2_PACKAGE_SQUASHFS is not set
# BR2_PACKAGE_SSHFS is not set
# BR2_PACKAGE_UDFTOOLS is not set
# BR2_PACKAGE_UNIONFS is not set
# BR2_PACKAGE_XFSPROGS is not set
# Fonts, cursors, icons, sounds and themes
# Cursors
# BR2_PACKAGE_COMIX_CURSORS is not set
# BR2_PACKAGE_OBSIDIAN_CURSORS is not set
# Fonts
# BR2_PACKAGE_BITSTREAM_VERA is not set
# BR2_PACKAGE_CANTARELL is not set
# BR2_PACKAGE_DEJAVU is not set
# BR2_PACKAGE_FONT_AWESOME is not set
# BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
# BR2_PACKAGE_INCONSOLATA is not set
# BR2_PACKAGE_LIBERATION is not set
# BR2_PACKAGE_WQY_ZENHEI is not set
# Icons
# BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set
# BR2_PACKAGE_HICOLOR_ICON_THEME is not set
# Sounds
# BR2_PACKAGE_SOUND_THEME_BOREALIS is not set
# BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set
# Themes
# Games
# BR2_PACKAGE_ASCII_INVADERS is not set
# BR2_PACKAGE_CHOCOLATE_DOOM is not set
# BR2_PACKAGE_FLARE_ENGINE is not set
# BR2_PACKAGE_FROTZ is not set
# BR2_PACKAGE_GNUCHESS is not set
# BR2_PACKAGE_LBREAKOUT2 is not set
# BR2_PACKAGE_LTRIS is not set
# minetest needs X11 and an OpenGL provider
# BR2_PACKAGE_OPENTYRIAN is not set
# BR2_PACKAGE_PRBOOM is not set
# BR2_PACKAGE_SL is not set
# solarus needs OpenGL and a toolchain w/ C++, gcc >= 4.9, NPTL, dynamic library, and luajit or lua 5.1
# BR2_PACKAGE_STELLA is not set
# BR2_PACKAGE_XORCURSES is not set
# Graphic libraries and applications (graphic/text)
# Graphic applications
# cage needs udev, mesa3d w/ EGL and GLES support
# cog needs wpewebkit and a toolchain w/ threads
# BR2_PACKAGE_FSWEBCAM is not set
# BR2_PACKAGE_GHOSTSCRIPT is not set
# glmark2 needs an OpenGL or an openGL ES and EGL backend
# glslsandbox-player needs a toolchain w/ threads and an openGL ES and EGL driver
# BR2_PACKAGE_GNUPLOT is not set
# BR2_PACKAGE_JHEAD is not set
# BR2_PACKAGE_LIBVA_UTILS is not set
BR2_PACKAGE_NETSURF_ARCH_SUPPORTS=y
# BR2_PACKAGE_NETSURF is not set
# BR2_PACKAGE_PNGQUANT is not set
# BR2_PACKAGE_RRDTOOL is not set
# stellarium needs Qt5 and an OpenGL provider
# BR2_PACKAGE_TESSERACT_OCR is not set
# Graphic libraries
# BR2_PACKAGE_CEGUI is not set
# BR2_PACKAGE_DIRECTFB is not set
# BR2_PACKAGE_FB_TEST_APP is not set
# BR2_PACKAGE_FBDUMP is not set
# BR2_PACKAGE_FBGRAB is not set
# BR2_PACKAGE_FBTERM is not set
# BR2_PACKAGE_FBV is not set
# BR2_PACKAGE_FREERDP is not set
# BR2_PACKAGE_GRAPHICSMAGICK is not set
# BR2_PACKAGE_IMAGEMAGICK is not set
# BR2_PACKAGE_LINUX_FUSION is not set
# BR2_PACKAGE_MESA3D is not set
# BR2_PACKAGE_OCRAD is not set
# ogre needs X11 and an OpenGL provider
# BR2_PACKAGE_PSPLASH is not set
# BR2_PACKAGE_SDL is not set
# BR2_PACKAGE_SDL2 is not set
# Other GUIs
# BR2_PACKAGE_QT5 is not set
# tekui needs a Lua interpreter and a toolchain w/ threads, dynamic library
# BR2_PACKAGE_WESTON is not set
# BR2_PACKAGE_XORG7 is not set
# BR2_PACKAGE_APITRACE is not set
# vte needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_XKEYBOARD_CONFIG is not set
# Hardware handling
# Firmware
# BR2_PACKAGE_ARMBIAN_FIRMWARE is not set
# BR2_PACKAGE_B43_FIRMWARE is not set
# BR2_PACKAGE_LINUX_FIRMWARE is not set
# BR2_PACKAGE_MURATA_CYW_FW is not set
# BR2_PACKAGE_ODROIDC2_FIRMWARE is not set
# BR2_PACKAGE_QCOM_DB410C_FIRMWARE is not set
# BR2_PACKAGE_RCW_SMARC_SAL28 is not set
# BR2_PACKAGE_UX500_FIRMWARE is not set
# BR2_PACKAGE_WILC1000_FIRMWARE is not set
# BR2_PACKAGE_WILINK_BT_FIRMWARE is not set
# BR2_PACKAGE_ZD1211_FIRMWARE is not set
# BR2_PACKAGE_18XX_TI_UTILS is not set
# BR2_PACKAGE_ACPICA is not set
# BR2_PACKAGE_ACPID is not set
# BR2_PACKAGE_ACPITOOL is not set
# BR2_PACKAGE_AER_INJECT is not set
# BR2_PACKAGE_ALTERA_STAPL is not set
# BR2_PACKAGE_APCUPSD is not set
# BR2_PACKAGE_AVRDUDE is not set
# BR2_PACKAGE_BCACHE_TOOLS is not set
# BR2_PACKAGE_BRICKD is not set
# BR2_PACKAGE_BRLTTY is not set
# BR2_PACKAGE_CC_TOOL is not set
# BR2_PACKAGE_CDRKIT is not set
# BR2_PACKAGE_CRYPTSETUP is not set
# BR2_PACKAGE_CWIID is not set
# BR2_PACKAGE_DAHDI_LINUX is not set
# BR2_PACKAGE_DAHDI_TOOLS is not set
# BR2_PACKAGE_DBUS is not set
# BR2_PACKAGE_DFU_UTIL is not set
# BR2_PACKAGE_DMRAID is not set
# BR2_PACKAGE_DT_UTILS is not set
# BR2_PACKAGE_DTV_SCAN_TABLES is not set
# BR2_PACKAGE_DUMP1090 is not set
# BR2_PACKAGE_DVB_APPS is not set
# BR2_PACKAGE_DVBSNOOP is not set
# BR2_PACKAGE_EDID_DECODE is not set
# edid-decode needs a toolchain w/ C++, gcc >= 4.7
BR2_PACKAGE_EUDEV=y
BR2_PACKAGE_PROVIDES_UDEV="eudev"
# BR2_PACKAGE_EUDEV_RULES_GEN is not set
BR2_PACKAGE_EUDEV_ENABLE_HWDB=y
# BR2_PACKAGE_EVEMU is not set
BR2_PACKAGE_EVTEST=y
# BR2_PACKAGE_FAN_CTRL is not set
# BR2_PACKAGE_FCONFIG is not set
BR2_PACKAGE_FLASHROM_ARCH_SUPPORTS=y
# BR2_PACKAGE_FLASHROM is not set
# BR2_PACKAGE_FMTOOLS is not set
# BR2_PACKAGE_FXLOAD is not set
# BR2_PACKAGE_GPM is not set
# BR2_PACKAGE_GPSD is not set
# BR2_PACKAGE_GPTFDISK is not set
# BR2_PACKAGE_GVFS is not set
# BR2_PACKAGE_HWDATA is not set
# BR2_PACKAGE_HWLOC is not set
# BR2_PACKAGE_INPUT_EVENT_DAEMON is not set
# BR2_PACKAGE_IOSTAT is not set
# BR2_PACKAGE_IPMITOOL is not set
# BR2_PACKAGE_IRDA_UTILS is not set
# BR2_PACKAGE_KBD is not set
# BR2_PACKAGE_LCDPROC is not set
# BR2_PACKAGE_LIBIEC61850 is not set
# BR2_PACKAGE_LIBUBOOTENV is not set
# BR2_PACKAGE_LIBUIO is not set
# BR2_PACKAGE_LINUX_BACKPORTS is not set
# BR2_PACKAGE_LINUX_SERIAL_TEST is not set
# BR2_PACKAGE_LINUXCONSOLETOOLS is not set
# BR2_PACKAGE_LIRC_TOOLS is not set
# BR2_PACKAGE_LM_SENSORS is not set
# BR2_PACKAGE_LSHW is not set
# BR2_PACKAGE_LSSCSI is not set
# BR2_PACKAGE_LSUIO is not set
# BR2_PACKAGE_LUKSMETA is not set
# BR2_PACKAGE_LVM2 is not set
# BR2_PACKAGE_MBPFAN is not set
# BR2_PACKAGE_MDADM is not set
# BR2_PACKAGE_MDEVD is not set
# BR2_PACKAGE_MEMTESTER is not set
# BR2_PACKAGE_MEMTOOL is not set
# BR2_PACKAGE_MINICOM is not set
# BR2_PACKAGE_NANOCOM is not set
# BR2_PACKAGE_NEARD is not set
# BR2_PACKAGE_NVIDIA_MODPROBE is not set
# BR2_PACKAGE_NVME is not set
# BR2_PACKAGE_OFONO is not set
# BR2_PACKAGE_OPEN2300 is not set
# BR2_PACKAGE_OPENFPGALOADER is not set
# BR2_PACKAGE_OPENIPMI is not set
# BR2_PACKAGE_OPENOCD is not set
# BR2_PACKAGE_PARTED is not set
# BR2_PACKAGE_PCIUTILS is not set
# BR2_PACKAGE_PDBG is not set
# BR2_PACKAGE_PICOCOM is not set
# BR2_PACKAGE_POWERTOP is not set
# BR2_PACKAGE_PPS_TOOLS is not set
# BR2_PACKAGE_RASPI_GPIO is not set
# BR2_PACKAGE_READ_EDID is not set
# BR2_PACKAGE_RNG_TOOLS is not set
# BR2_PACKAGE_RS485CONF is not set
# BR2_PACKAGE_RTC_TOOLS is not set
# BR2_PACKAGE_RTL8188EU is not set
# BR2_PACKAGE_RTL8189FS is not set
# BR2_PACKAGE_RTL8723BS is not set
# BR2_PACKAGE_RTL8723BU is not set
# BR2_PACKAGE_RTL8821AU is not set
# BR2_PACKAGE_SANE_BACKENDS is not set
# BR2_PACKAGE_SDPARM is not set
# BR2_PACKAGE_SETSERIAL is not set
# BR2_PACKAGE_SG3_UTILS is not set
# BR2_PACKAGE_SIGROK_CLI is not set
# BR2_PACKAGE_SISPMCTL is not set
# BR2_PACKAGE_SMARTMONTOOLS is not set
# BR2_PACKAGE_SMSTOOLS3 is not set
# BR2_PACKAGE_SPI_TOOLS is not set
# BR2_PACKAGE_SREDIRD is not set
# BR2_PACKAGE_STATSERIAL is not set
# BR2_PACKAGE_STM32FLASH is not set
# BR2_PACKAGE_SYSSTAT is not set
# targetcli-fb depends on Python
# ti-sgx-um needs the ti-sgx-km driver
# BR2_PACKAGE_TI_UIM is not set
# BR2_PACKAGE_TI_UTILS is not set
# BR2_PACKAGE_TIO is not set
# BR2_PACKAGE_TRIGGERHAPPY is not set
# BR2_PACKAGE_UBOOT_TOOLS is not set
# BR2_PACKAGE_UBUS is not set
# BR2_PACKAGE_UCCP420WLAN is not set
BR2_PACKAGE_HAS_UDEV=y
# BR2_PACKAGE_UDISKS is not set
# BR2_PACKAGE_UHUBCTL is not set
# BR2_PACKAGE_UMTPRD is not set
# BR2_PACKAGE_UPOWER is not set
# BR2_PACKAGE_USB_MODESWITCH is not set
# BR2_PACKAGE_USB_MODESWITCH_DATA is not set
# BR2_PACKAGE_USBMOUNT is not set
# BR2_PACKAGE_USBUTILS is not set
# BR2_PACKAGE_W_SCAN is not set
# BR2_PACKAGE_WIPE is not set
# BR2_PACKAGE_XORRISO is not set
# BR2_PACKAGE_XR819_XRADIO is not set
# Interpreter languages and scripting
# BR2_PACKAGE_4TH is not set
# BR2_PACKAGE_ENSCRIPT is not set
BR2_PACKAGE_HOST_ERLANG_ARCH_SUPPORTS=y
# BR2_PACKAGE_EXECLINE is not set
# BR2_PACKAGE_FICL is not set
# BR2_PACKAGE_HASERL is not set
# BR2_PACKAGE_JIMTCL is not set
# BR2_PACKAGE_LUA is not set
BR2_PACKAGE_PROVIDES_HOST_LUAINTERPRETER="host-lua"
# BR2_PACKAGE_MICROPYTHON is not set
BR2_PACKAGE_HOST_MONO_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_OPENJDK_BIN_ARCH_SUPPORTS=y
# BR2_PACKAGE_PERL is not set
# BR2_PACKAGE_PHP is not set
# BR2_PACKAGE_PYTHON is not set
# BR2_PACKAGE_PYTHON3 is not set
# BR2_PACKAGE_QUICKJS is not set
# BR2_PACKAGE_RUBY is not set
# BR2_PACKAGE_TCL is not set
# Libraries
# Audio/Sound
# BR2_PACKAGE_ALSA_LIB is not set
# BR2_PACKAGE_ALURE is not set
# BR2_PACKAGE_AUBIO is not set
# BR2_PACKAGE_BCG729 is not set
# BR2_PACKAGE_CAPS is not set
# BR2_PACKAGE_LIBAO is not set
# BR2_PACKAGE_LIBASPLIB is not set
# BR2_PACKAGE_LIBBROADVOICE is not set
# BR2_PACKAGE_LIBCDAUDIO is not set
# BR2_PACKAGE_LIBCDDB is not set
# BR2_PACKAGE_LIBCDIO is not set
# BR2_PACKAGE_LIBCDIO_PARANOIA is not set
# BR2_PACKAGE_LIBCODEC2 is not set
# BR2_PACKAGE_LIBCUE is not set
# BR2_PACKAGE_LIBCUEFILE is not set
# BR2_PACKAGE_LIBEBUR128 is not set
# BR2_PACKAGE_LIBG7221 is not set
# BR2_PACKAGE_LIBGSM is not set
# BR2_PACKAGE_LIBID3TAG is not set
# BR2_PACKAGE_LIBILBC is not set
# BR2_PACKAGE_LIBLO is not set
# BR2_PACKAGE_LIBMAD is not set
# BR2_PACKAGE_LIBMODPLUG is not set
# BR2_PACKAGE_LIBMPD is not set
# BR2_PACKAGE_LIBMPDCLIENT is not set
# BR2_PACKAGE_LIBREPLAYGAIN is not set
# BR2_PACKAGE_LIBSAMPLERATE is not set
# BR2_PACKAGE_LIBSIDPLAY2 is not set
# BR2_PACKAGE_LIBSILK is not set
# BR2_PACKAGE_LIBSNDFILE is not set
# BR2_PACKAGE_LIBSOUNDTOUCH is not set
# BR2_PACKAGE_LIBSOXR is not set
# BR2_PACKAGE_LIBVORBIS is not set
# BR2_PACKAGE_MP4V2 is not set
BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENAL is not set
# BR2_PACKAGE_OPENCORE_AMR is not set
# BR2_PACKAGE_OPUS is not set
# BR2_PACKAGE_OPUSFILE is not set
# BR2_PACKAGE_PORTAUDIO is not set
# BR2_PACKAGE_SBC is not set
# BR2_PACKAGE_SPANDSP is not set
# BR2_PACKAGE_SPEEX is not set
# BR2_PACKAGE_SPEEXDSP is not set
# BR2_PACKAGE_TAGLIB is not set
# BR2_PACKAGE_TINYALSA is not set
# BR2_PACKAGE_TREMOR is not set
# BR2_PACKAGE_VO_AACENC is not set
# Compression and decompression
# BR2_PACKAGE_LIBARCHIVE is not set
# BR2_PACKAGE_LIBMSPACK is not set
# BR2_PACKAGE_LIBSQUISH is not set
# BR2_PACKAGE_LIBZIP is not set
# BR2_PACKAGE_LZ4 is not set
# BR2_PACKAGE_LZO is not set
# BR2_PACKAGE_MINIZIP is not set
# BR2_PACKAGE_SNAPPY is not set
# BR2_PACKAGE_SZIP is not set
# BR2_PACKAGE_ZLIB is not set
BR2_PACKAGE_PROVIDES_HOST_ZLIB="host-libzlib"
# BR2_PACKAGE_ZZIPLIB is not set
# Crypto
# BR2_PACKAGE_BEARSSL is not set
# BR2_PACKAGE_BEECRYPT is not set
BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y
# BR2_PACKAGE_BOTAN is not set
# BR2_PACKAGE_CA_CERTIFICATES is not set
# BR2_PACKAGE_CRYPTODEV is not set
# BR2_PACKAGE_GCR is not set
# BR2_PACKAGE_GNUTLS is not set
# BR2_PACKAGE_LIBARGON2 is not set
# BR2_PACKAGE_LIBASSUAN is not set
# BR2_PACKAGE_LIBGCRYPT is not set
BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBGPG_ERROR is not set
BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="riscv64-unknown-linux-gnu"
# BR2_PACKAGE_LIBGPGME is not set
# BR2_PACKAGE_LIBKCAPI is not set
# BR2_PACKAGE_LIBKSBA is not set
# BR2_PACKAGE_LIBMCRYPT is not set
# BR2_PACKAGE_LIBMHASH is not set
# BR2_PACKAGE_LIBNSS is not set
# BR2_PACKAGE_LIBOLM is not set
# BR2_PACKAGE_LIBP11 is not set
# BR2_PACKAGE_LIBSCRYPT is not set
# BR2_PACKAGE_LIBSECRET is not set
# BR2_PACKAGE_LIBSHA1 is not set
# BR2_PACKAGE_LIBSODIUM is not set
# BR2_PACKAGE_LIBSSH is not set
# BR2_PACKAGE_LIBSSH2 is not set
# BR2_PACKAGE_LIBTOMCRYPT is not set
# BR2_PACKAGE_LIBUECC is not set
# BR2_PACKAGE_MBEDTLS is not set
# BR2_PACKAGE_NETTLE is not set
BR2_PACKAGE_LIBOPENSSL_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENSSL is not set
BR2_PACKAGE_PROVIDES_HOST_OPENSSL="host-libopenssl"
# BR2_PACKAGE_PKCS11_HELPER is not set
# BR2_PACKAGE_RHASH is not set
# BR2_PACKAGE_TINYDTLS is not set
# BR2_PACKAGE_TPM2_PKCS11 is not set
# BR2_PACKAGE_TPM2_TSS is not set
# BR2_PACKAGE_TROUSERS is not set
# BR2_PACKAGE_USTREAM_SSL is not set
# BR2_PACKAGE_WOLFSSL is not set
# Database
# BR2_PACKAGE_BERKELEYDB is not set
# BR2_PACKAGE_GDBM is not set
# BR2_PACKAGE_HIREDIS is not set
# BR2_PACKAGE_KOMPEXSQLITE is not set
# BR2_PACKAGE_LEVELDB is not set
# BR2_PACKAGE_LIBGIT2 is not set
# BR2_PACKAGE_LIBMDBX is not set
# BR2_PACKAGE_LIBODB is not set
# BR2_PACKAGE_MYSQL is not set
# BR2_PACKAGE_POSTGRESQL is not set
# BR2_PACKAGE_REDIS is not set
# BR2_PACKAGE_ROCKSDB is not set
# BR2_PACKAGE_SQLCIPHER is not set
# BR2_PACKAGE_SQLITE is not set
# BR2_PACKAGE_UNIXODBC is not set
# Filesystem
# BR2_PACKAGE_GAMIN is not set
# BR2_PACKAGE_LIBCONFIG is not set
# BR2_PACKAGE_LIBCONFUSE is not set
# BR2_PACKAGE_LIBFUSE is not set
# BR2_PACKAGE_LIBFUSE3 is not set
# BR2_PACKAGE_LIBLOCKFILE is not set
# BR2_PACKAGE_LIBNFS is not set
# BR2_PACKAGE_LIBSYSFS is not set
# BR2_PACKAGE_LOCKDEV is not set
# BR2_PACKAGE_PHYSFS is not set
# Graphics
# BR2_PACKAGE_ASSIMP is not set
# at-spi2-atk depends on X.org
# at-spi2-core depends on X.org
# BR2_PACKAGE_ATK is not set
# BR2_PACKAGE_ATKMM is not set
# BR2_PACKAGE_BULLET is not set
# BR2_PACKAGE_CAIRO is not set
# BR2_PACKAGE_CAIROMM is not set
# chipmunk needs an OpenGL backend
# BR2_PACKAGE_EXEMPI is not set
# BR2_PACKAGE_EXIV2 is not set
# BR2_PACKAGE_FONTCONFIG is not set
# BR2_PACKAGE_FREETYPE is not set
# BR2_PACKAGE_GD is not set
# BR2_PACKAGE_GDK_PIXBUF is not set
# BR2_PACKAGE_GIFLIB is not set
# granite needs libgtk3 and a toolchain w/ wchar, threads
# BR2_PACKAGE_GRAPHITE2 is not set
# gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.9
# BR2_PACKAGE_HARFBUZZ is not set
# BR2_PACKAGE_IJS is not set
# BR2_PACKAGE_IMLIB2 is not set
# irrlicht needs X11 and an OpenGL provider
# BR2_PACKAGE_JASPER is not set
# BR2_PACKAGE_JBIG2DEC is not set
BR2_PACKAGE_JPEG=y
BR2_PACKAGE_LIBJPEG=y
# BR2_PACKAGE_JPEG_TURBO is not set
BR2_PACKAGE_HAS_JPEG=y
BR2_PACKAGE_PROVIDES_JPEG="libjpeg"
# BR2_PACKAGE_KMSXX is not set
# BR2_PACKAGE_LCMS2 is not set
# BR2_PACKAGE_LENSFUN is not set
# BR2_PACKAGE_LEPTONICA is not set
# BR2_PACKAGE_LIBART is not set
# BR2_PACKAGE_LIBDMTX is not set
# BR2_PACKAGE_LIBDRM is not set
# libepoxy needs an OpenGL and/or OpenGL EGL backend
# BR2_PACKAGE_LIBEXIF is not set
# libfm needs X.org and a toolchain w/ wchar, threads, C++, gcc >= 4.8
# BR2_PACKAGE_LIBFM_EXTRA is not set
# libfreeglut depends on X.org and needs an OpenGL backend
# BR2_PACKAGE_LIBFREEIMAGE is not set
# BR2_PACKAGE_LIBGEOTIFF is not set
# libglew depends on X.org and needs an OpenGL backend
# libglfw depends on X.org and needs an OpenGL backend
# libglu needs an OpenGL backend
# BR2_PACKAGE_LIBGTA is not set
# libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_LIBMEDIAART is not set
# BR2_PACKAGE_LIBMNG is not set
# BR2_PACKAGE_LIBPNG is not set
# BR2_PACKAGE_LIBQRENCODE is not set
# BR2_PACKAGE_LIBRAW is not set
# libsoil needs an OpenGL backend and a toolchain w/ dynamic library
# BR2_PACKAGE_LIBSVG is not set
# BR2_PACKAGE_LIBSVG_CAIRO is not set
# BR2_PACKAGE_LIBSVGTINY is not set
# BR2_PACKAGE_LIBVA is not set
# BR2_PACKAGE_LIBVIPS is not set
# libwpe needs a toolchain w/ C++, dynamic library and an OpenEGL-capable backend
# BR2_PACKAGE_MENU_CACHE is not set
# BR2_PACKAGE_OPENCV3 is not set
# BR2_PACKAGE_OPENJPEG is not set
# BR2_PACKAGE_PANGO is not set
# BR2_PACKAGE_PANGOMM is not set
# BR2_PACKAGE_PIPEWIRE is not set
# BR2_PACKAGE_PIXMAN is not set
# BR2_PACKAGE_POPPLER is not set
# BR2_PACKAGE_TIFF is not set
# BR2_PACKAGE_WAYLAND is not set
# BR2_PACKAGE_WEBP is not set
# wlroots needs udev, mesa3d w/ EGL and GLES support
# BR2_PACKAGE_WOFF2 is not set
# wpebackend-fdo needs a toolchain w/ C++, wchar, threads, dynamic library and an OpenEGL-capable Wayland backend
# BR2_PACKAGE_ZBAR is not set
# BR2_PACKAGE_ZXING_CPP is not set
# Hardware handling
# BR2_PACKAGE_ACSCCID is not set
# BR2_PACKAGE_C_PERIPHERY is not set
# BR2_PACKAGE_CCID is not set
# BR2_PACKAGE_DTC is not set
# BR2_PACKAGE_HACKRF is not set
# BR2_PACKAGE_HIDAPI is not set
# BR2_PACKAGE_JITTERENTROPY_LIBRARY is not set
# BR2_PACKAGE_LCDAPI is not set
# BR2_PACKAGE_LET_ME_CREATE is not set
# BR2_PACKAGE_LIBAIO is not set
# BR2_PACKAGE_LIBATASMART is not set
# BR2_PACKAGE_LIBBLOCKDEV is not set
# BR2_PACKAGE_LIBCEC is not set
# BR2_PACKAGE_LIBFREEFARE is not set
# BR2_PACKAGE_LIBFTDI is not set
# BR2_PACKAGE_LIBFTDI1 is not set
# BR2_PACKAGE_LIBGPHOTO2 is not set
# BR2_PACKAGE_LIBGPIOD is not set
# BR2_PACKAGE_LIBGUDEV is not set
# BR2_PACKAGE_LIBHID is not set
# BR2_PACKAGE_LIBIIO is not set
# BR2_PACKAGE_LIBINPUT is not set
# BR2_PACKAGE_LIBIQRF is not set
# BR2_PACKAGE_LIBLLCP is not set
# BR2_PACKAGE_LIBMBIM is not set
# BR2_PACKAGE_LIBNFC is not set
# BR2_PACKAGE_LIBPCIACCESS is not set
# BR2_PACKAGE_LIBPHIDGET is not set
# BR2_PACKAGE_LIBPRI is not set
# BR2_PACKAGE_LIBQMI is not set
# BR2_PACKAGE_LIBRAW1394 is not set
# BR2_PACKAGE_LIBRTLSDR is not set
# BR2_PACKAGE_LIBSERIAL is not set
# BR2_PACKAGE_LIBSERIALPORT is not set
# BR2_PACKAGE_LIBSIGROK is not set
# BR2_PACKAGE_LIBSIGROKDECODE is not set
# BR2_PACKAGE_LIBSOC is not set
# BR2_PACKAGE_LIBSS7 is not set
# BR2_PACKAGE_LIBUSB is not set
# BR2_PACKAGE_LIBUSBGX is not set
# BR2_PACKAGE_LIBV4L is not set
# BR2_PACKAGE_LIBXKBCOMMON is not set
# BR2_PACKAGE_MTDEV is not set
# BR2_PACKAGE_NEARDAL is not set
# BR2_PACKAGE_OWFS is not set
# BR2_PACKAGE_PCSC_LITE is not set
# BR2_PACKAGE_TSLIB is not set
# BR2_PACKAGE_UHD is not set
# BR2_PACKAGE_URG is not set
# Javascript
# BR2_PACKAGE_ANGULARJS is not set
# BR2_PACKAGE_BOOTSTRAP is not set
# BR2_PACKAGE_CHARTJS is not set
# BR2_PACKAGE_DATATABLES is not set
# BR2_PACKAGE_DUKTAPE is not set
# BR2_PACKAGE_EXPLORERCANVAS is not set
# BR2_PACKAGE_FLOT is not set
# BR2_PACKAGE_JQUERY is not set
# BR2_PACKAGE_JSMIN is not set
# BR2_PACKAGE_JSON_JAVASCRIPT is not set
# BR2_PACKAGE_JSZIP is not set
# BR2_PACKAGE_OPENLAYERS is not set
# BR2_PACKAGE_POPPERJS is not set
BR2_PACKAGE_SPIDERMONKEY_ARCH_SUPPORTS=y
# BR2_PACKAGE_SPIDERMONKEY is not set
# BR2_PACKAGE_VUEJS is not set
# JSON/XML
# BR2_PACKAGE_BENEJSON is not set
# BR2_PACKAGE_CJSON is not set
# BR2_PACKAGE_EXPAT is not set
# BR2_PACKAGE_JANSSON is not set
# BR2_PACKAGE_JOSE is not set
# BR2_PACKAGE_JSMN is not set
# BR2_PACKAGE_JSON_C is not set
# BR2_PACKAGE_JSON_FOR_MODERN_CPP is not set
# BR2_PACKAGE_JSON_GLIB is not set
# BR2_PACKAGE_JSONCPP is not set
# BR2_PACKAGE_LIBBSON is not set
# BR2_PACKAGE_LIBFASTJSON is not set
# BR2_PACKAGE_LIBJSON is not set
# BR2_PACKAGE_LIBROXML is not set
# BR2_PACKAGE_LIBUCL is not set
# BR2_PACKAGE_LIBXML2 is not set
# BR2_PACKAGE_LIBXMLPP is not set
# BR2_PACKAGE_LIBXMLRPC is not set
# BR2_PACKAGE_LIBXSLT is not set
# BR2_PACKAGE_LIBYAML is not set
# BR2_PACKAGE_MXML is not set
# BR2_PACKAGE_PUGIXML is not set
# BR2_PACKAGE_RAPIDJSON is not set
# BR2_PACKAGE_RAPIDXML is not set
# BR2_PACKAGE_RAPTOR is not set
# BR2_PACKAGE_TINYXML is not set
# BR2_PACKAGE_TINYXML2 is not set
# BR2_PACKAGE_VALIJSON is not set
# BR2_PACKAGE_XERCES is not set
# BR2_PACKAGE_YAJL is not set
# BR2_PACKAGE_YAML_CPP is not set
# Logging
# BR2_PACKAGE_GLOG is not set
# BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set
# BR2_PACKAGE_LIBLOGGING is not set
# BR2_PACKAGE_LOG4CPLUS is not set
# BR2_PACKAGE_LOG4CPP is not set
# BR2_PACKAGE_LOG4CXX is not set
# BR2_PACKAGE_OPENTRACING_CPP is not set
# BR2_PACKAGE_SPDLOG is not set
# BR2_PACKAGE_ZLOG is not set
# Multimedia
# BR2_PACKAGE_BITSTREAM is not set
# BR2_PACKAGE_DAV1D is not set
# BR2_PACKAGE_KVAZAAR is not set
# BR2_PACKAGE_LIBAACS is not set
# BR2_PACKAGE_LIBASS is not set
# BR2_PACKAGE_LIBBDPLUS is not set
# BR2_PACKAGE_LIBBLURAY is not set
BR2_PACKAGE_LIBCAMERA_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBCAMERA is not set
# BR2_PACKAGE_LIBDCADEC is not set
# BR2_PACKAGE_LIBDVBCSA is not set
# BR2_PACKAGE_LIBDVBPSI is not set
# BR2_PACKAGE_LIBDVBSI is not set
# BR2_PACKAGE_LIBDVDCSS is not set
# BR2_PACKAGE_LIBDVDNAV is not set
# BR2_PACKAGE_LIBDVDREAD is not set
# BR2_PACKAGE_LIBEBML is not set
# BR2_PACKAGE_LIBHDHOMERUN is not set
# BR2_PACKAGE_LIBMATROSKA is not set
# BR2_PACKAGE_LIBMMS is not set
# BR2_PACKAGE_LIBMPEG2 is not set
# BR2_PACKAGE_LIBOGG is not set
# BR2_PACKAGE_LIBOPUSENC is not set
# BR2_PACKAGE_LIBTHEORA is not set
# BR2_PACKAGE_LIBUDFREAD is not set
# BR2_PACKAGE_LIBVPX is not set
# BR2_PACKAGE_LIBYUV is not set
# BR2_PACKAGE_LIVE555 is not set
# BR2_PACKAGE_MEDIASTREAMER is not set
# BR2_PACKAGE_X264 is not set
# BR2_PACKAGE_X265 is not set
# Networking
# BR2_PACKAGE_AGENTPP is not set
# BR2_PACKAGE_AZMQ is not set
# BR2_PACKAGE_AZURE_IOT_SDK_C is not set
# BR2_PACKAGE_BATMAN_ADV is not set
# BR2_PACKAGE_BELLE_SIP is not set
# BR2_PACKAGE_C_ARES is not set
# BR2_PACKAGE_CGIC is not set
# BR2_PACKAGE_CPPZMQ is not set
# BR2_PACKAGE_CURLPP is not set
# BR2_PACKAGE_CZMQ is not set
# BR2_PACKAGE_DAQ is not set
# BR2_PACKAGE_DAVICI is not set
# BR2_PACKAGE_ENET is not set
# BR2_PACKAGE_FILEMQ is not set
# BR2_PACKAGE_FLICKCURL is not set
# BR2_PACKAGE_FREERADIUS_CLIENT is not set
# BR2_PACKAGE_GENSIO is not set
# BR2_PACKAGE_GEOIP is not set
# BR2_PACKAGE_GLIB_NETWORKING is not set
# BR2_PACKAGE_GRPC is not set
# BR2_PACKAGE_GSSDP is not set
# BR2_PACKAGE_GUPNP is not set
# BR2_PACKAGE_GUPNP_AV is not set
# BR2_PACKAGE_GUPNP_DLNA is not set
# BR2_PACKAGE_IBRCOMMON is not set
# BR2_PACKAGE_IBRDTN is not set
# BR2_PACKAGE_LIBCGI is not set
# BR2_PACKAGE_LIBCGICC is not set
# BR2_PACKAGE_LIBCOAP is not set
# BR2_PACKAGE_LIBCPPRESTSDK is not set
# BR2_PACKAGE_LIBCURL is not set
# BR2_PACKAGE_LIBDNET is not set
# BR2_PACKAGE_LIBEXOSIP2 is not set
# BR2_PACKAGE_LIBFCGI is not set
# BR2_PACKAGE_LIBGSASL is not set
# BR2_PACKAGE_LIBHTP is not set
# BR2_PACKAGE_LIBHTTPPARSER is not set
# BR2_PACKAGE_LIBHTTPSERVER is not set
# BR2_PACKAGE_LIBIDN is not set
# BR2_PACKAGE_LIBIDN2 is not set
# BR2_PACKAGE_LIBISCSI is not set
# BR2_PACKAGE_LIBKRB5 is not set
# BR2_PACKAGE_LIBLDNS is not set
# BR2_PACKAGE_LIBMAXMINDDB is not set
# BR2_PACKAGE_LIBMBUS is not set
# BR2_PACKAGE_LIBMEMCACHED is not set
# BR2_PACKAGE_LIBMICROHTTPD is not set
# BR2_PACKAGE_LIBMINIUPNPC is not set
# BR2_PACKAGE_LIBMNL is not set
# BR2_PACKAGE_LIBMODBUS is not set
# BR2_PACKAGE_LIBMODSECURITY is not set
# BR2_PACKAGE_LIBNATPMP is not set
# BR2_PACKAGE_LIBNDP is not set
# BR2_PACKAGE_LIBNET is not set
# BR2_PACKAGE_LIBNETCONF2 is not set
# BR2_PACKAGE_LIBNETFILTER_ACCT is not set
# BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set
# BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set
# BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set
# BR2_PACKAGE_LIBNETFILTER_LOG is not set
# BR2_PACKAGE_LIBNETFILTER_QUEUE is not set
# BR2_PACKAGE_LIBNFNETLINK is not set
# BR2_PACKAGE_LIBNFTNL is not set
# BR2_PACKAGE_LIBNICE is not set
# BR2_PACKAGE_LIBNIDS is not set
# BR2_PACKAGE_LIBNL is not set
# BR2_PACKAGE_LIBNPUPNP is not set
# BR2_PACKAGE_LIBOAUTH is not set
# BR2_PACKAGE_LIBOPING is not set
# BR2_PACKAGE_LIBOSIP2 is not set
# BR2_PACKAGE_LIBPAGEKITE is not set
# BR2_PACKAGE_LIBPCAP is not set
# BR2_PACKAGE_LIBPJSIP is not set
# BR2_PACKAGE_LIBRELP is not set
# BR2_PACKAGE_LIBRSYNC is not set
# BR2_PACKAGE_LIBSHAIRPLAY is not set
# BR2_PACKAGE_LIBSHOUT is not set
# BR2_PACKAGE_LIBSOCKETCAN is not set
# BR2_PACKAGE_LIBSOUP is not set
# BR2_PACKAGE_LIBSRTP is not set
# BR2_PACKAGE_LIBSTROPHE is not set
# BR2_PACKAGE_LIBTELNET is not set
# BR2_PACKAGE_LIBTIRPC is not set
# BR2_PACKAGE_LIBTORRENT is not set
# BR2_PACKAGE_LIBTORRENT_RASTERBAR is not set
# BR2_PACKAGE_LIBUEV is not set
# BR2_PACKAGE_LIBUHTTPD is not set
# BR2_PACKAGE_LIBUPNP is not set
# BR2_PACKAGE_LIBUPNPP is not set
# BR2_PACKAGE_LIBURIPARSER is not set
# BR2_PACKAGE_LIBUWSC is not set
# BR2_PACKAGE_LIBVNCSERVER is not set
# BR2_PACKAGE_LIBWEBSOCK is not set
# BR2_PACKAGE_LIBWEBSOCKETS is not set
# BR2_PACKAGE_LIBYANG is not set
# BR2_PACKAGE_LKSCTP_TOOLS is not set
# BR2_PACKAGE_MBUFFER is not set
# BR2_PACKAGE_MONGOOSE is not set
# BR2_PACKAGE_NANOMSG is not set
# BR2_PACKAGE_NEON is not set
# BR2_PACKAGE_NETOPEER2 is not set
# BR2_PACKAGE_NGHTTP2 is not set
# BR2_PACKAGE_NORM is not set
# BR2_PACKAGE_NSS_MYHOSTNAME is not set
# BR2_PACKAGE_NSS_PAM_LDAPD is not set
# BR2_PACKAGE_OMNIORB is not set
# BR2_PACKAGE_OPEN62541 is not set
# BR2_PACKAGE_OPENLDAP is not set
# BR2_PACKAGE_OPENMPI is not set
# BR2_PACKAGE_OPENPGM is not set
# BR2_PACKAGE_OPENZWAVE is not set
# BR2_PACKAGE_ORTP is not set
# BR2_PACKAGE_PAHO_MQTT_C is not set
# BR2_PACKAGE_PAHO_MQTT_CPP is not set
# BR2_PACKAGE_PISTACHE is not set
# BR2_PACKAGE_QDECODER is not set
# BR2_PACKAGE_QPID_PROTON is not set
# BR2_PACKAGE_RABBITMQ_C is not set
# BR2_PACKAGE_RESIPROCATE is not set
# BR2_PACKAGE_RESTCLIENT_CPP is not set
# BR2_PACKAGE_RTMPDUMP is not set
# BR2_PACKAGE_SLIRP is not set
# BR2_PACKAGE_SNMPPP is not set
# BR2_PACKAGE_SOFIA_SIP is not set
# BR2_PACKAGE_SYSREPO is not set
# BR2_PACKAGE_THRIFT is not set
# BR2_PACKAGE_USBREDIR is not set
# BR2_PACKAGE_WAMPCC is not set
# BR2_PACKAGE_WEBSOCKETPP is not set
# BR2_PACKAGE_ZEROMQ is not set
# BR2_PACKAGE_ZMQPP is not set
# BR2_PACKAGE_ZYRE is not set
# Other
# BR2_PACKAGE_APR is not set
# BR2_PACKAGE_APR_UTIL is not set
# BR2_PACKAGE_ARMADILLO is not set
# BR2_PACKAGE_ATF is not set
# BR2_PACKAGE_AVRO_C is not set
# BR2_PACKAGE_BCTOOLBOX is not set
# BR2_PACKAGE_BELR is not set
# BR2_PACKAGE_BOOST is not set
# BR2_PACKAGE_C_CAPNPROTO is not set
# BR2_PACKAGE_CAPNPROTO is not set
# BR2_PACKAGE_CCTZ is not set
# BR2_PACKAGE_CEREAL is not set
# BR2_PACKAGE_CLAPACK is not set
# BR2_PACKAGE_CMOCKA is not set
# BR2_PACKAGE_CPPCMS is not set
# BR2_PACKAGE_CRACKLIB is not set
# BR2_PACKAGE_DAWGDIC is not set
# BR2_PACKAGE_DING_LIBS is not set
# BR2_PACKAGE_EIGEN is not set
# BR2_PACKAGE_ELFUTILS is not set
# BR2_PACKAGE_ELL is not set
# BR2_PACKAGE_FFTW is not set
# BR2_PACKAGE_FLANN is not set
# BR2_PACKAGE_FLATBUFFERS is not set
# BR2_PACKAGE_FLATCC is not set
# BR2_PACKAGE_GCONF is not set
# BR2_PACKAGE_GFLAGS is not set
# BR2_PACKAGE_GLI is not set
# BR2_PACKAGE_GLIBMM is not set
# BR2_PACKAGE_GLM is not set
# BR2_PACKAGE_GMP is not set
BR2_PACKAGE_GOBJECT_INTROSPECTION_ARCH_SUPPORTS=y
# gobject-introspection needs python3
# BR2_PACKAGE_GSL is not set
# BR2_PACKAGE_GTEST is not set
BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y
# BR2_PACKAGE_JEMALLOC is not set
# BR2_PACKAGE_LAPACK is not set
BR2_PACKAGE_LIBABSEIL_CPP_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBABSEIL_CPP is not set
# BR2_PACKAGE_LIBARGTABLE2 is not set
# BR2_PACKAGE_LIBAVL is not set
# BR2_PACKAGE_LIBB64 is not set
# BR2_PACKAGE_LIBBACKTRACE is not set
BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBBSD is not set
# BR2_PACKAGE_LIBBYTESIZE is not set
# BR2_PACKAGE_LIBCAP is not set
# BR2_PACKAGE_LIBCAP_NG is not set
# BR2_PACKAGE_LIBCGROUP is not set
# BR2_PACKAGE_LIBCORRECT is not set
# BR2_PACKAGE_LIBCROSSGUID is not set
# BR2_PACKAGE_LIBCSV is not set
# BR2_PACKAGE_LIBDAEMON is not set
# BR2_PACKAGE_LIBEE is not set
# BR2_PACKAGE_LIBEV is not set
# BR2_PACKAGE_LIBEVDEV is not set
# BR2_PACKAGE_LIBEVENT is not set
# BR2_PACKAGE_LIBFFI is not set
# BR2_PACKAGE_LIBGEE is not set
# BR2_PACKAGE_LIBGEOS is not set
# BR2_PACKAGE_LIBGLIB2 is not set
# BR2_PACKAGE_LIBGLOB is not set
# BR2_PACKAGE_LIBICAL is not set
# BR2_PACKAGE_LIBITE is not set
# BR2_PACKAGE_LIBLINEAR is not set
# BR2_PACKAGE_LIBLOKI is not set
# BR2_PACKAGE_LIBNPTH is not set
BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y
# BR2_PACKAGE_LIBNSPR is not set
# BR2_PACKAGE_LIBPFM4 is not set
# BR2_PACKAGE_LIBPLIST is not set
# BR2_PACKAGE_LIBPTHREAD_STUBS is not set
# BR2_PACKAGE_LIBPTHSEM is not set
# BR2_PACKAGE_LIBPWQUALITY is not set
# BR2_PACKAGE_LIBSIGC is not set
BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSIGSEGV is not set
# BR2_PACKAGE_LIBSPATIALINDEX is not set
# BR2_PACKAGE_LIBTASN1 is not set
# BR2_PACKAGE_LIBTOMMATH is not set
# BR2_PACKAGE_LIBTPL is not set
# BR2_PACKAGE_LIBUBOX is not set
# BR2_PACKAGE_LIBUCI is not set
BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBURCU is not set
# BR2_PACKAGE_LIBUV is not set
# BR2_PACKAGE_LIGHTNING is not set
# BR2_PACKAGE_LINUX_PAM is not set
# BR2_PACKAGE_LIQUID_DSP is not set
# BR2_PACKAGE_LTTNG_LIBUST is not set
# BR2_PACKAGE_MATIO is not set
# BR2_PACKAGE_MPC is not set
# BR2_PACKAGE_MPDECIMAL is not set
# BR2_PACKAGE_MPFR is not set
# BR2_PACKAGE_MPIR is not set
# BR2_PACKAGE_MSGPACK is not set
# BR2_PACKAGE_ORC is not set
# BR2_PACKAGE_P11_KIT is not set
BR2_PACKAGE_POCO_ARCH_SUPPORTS=y
# BR2_PACKAGE_POCO is not set
BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y
# BR2_PACKAGE_PROTOBUF is not set
# BR2_PACKAGE_PROTOBUF_C is not set
# BR2_PACKAGE_QHULL is not set
# BR2_PACKAGE_QLIBC is not set
# BR2_PACKAGE_RIEMANN_C_CLIENT is not set
# BR2_PACKAGE_SHAPELIB is not set
# BR2_PACKAGE_SKALIBS is not set
# BR2_PACKAGE_SPHINXBASE is not set
# BR2_PACKAGE_TINYCBOR is not set
# BR2_PACKAGE_UVW is not set
# BR2_PACKAGE_XAPIAN is not set
# Security
# BR2_PACKAGE_LIBAPPARMOR is not set
# BR2_PACKAGE_LIBSELINUX is not set
# BR2_PACKAGE_LIBSEPOL is not set
# BR2_PACKAGE_SAFECLIB is not set
# Text and terminal handling
# BR2_PACKAGE_AUGEAS is not set
# BR2_PACKAGE_ENCHANT is not set
# BR2_PACKAGE_FMT is not set
# BR2_PACKAGE_FSTRCMP is not set
# BR2_PACKAGE_ICU is not set
# BR2_PACKAGE_INIH is not set
# BR2_PACKAGE_LIBCLI is not set
# BR2_PACKAGE_LIBEDIT is not set
# BR2_PACKAGE_LIBENCA is not set
# BR2_PACKAGE_LIBESTR is not set
# BR2_PACKAGE_LIBFRIBIDI is not set
# BR2_PACKAGE_LIBUNISTRING is not set
# BR2_PACKAGE_LINENOISE is not set
# BR2_PACKAGE_NCURSES is not set
# BR2_PACKAGE_NEWT is not set
# BR2_PACKAGE_ONIGURUMA is not set
# BR2_PACKAGE_PCRE is not set
# BR2_PACKAGE_PCRE2 is not set
# BR2_PACKAGE_POPT is not set
# BR2_PACKAGE_RE2 is not set
# BR2_PACKAGE_READLINE is not set
# BR2_PACKAGE_SLANG is not set
# BR2_PACKAGE_TCLAP is not set
# BR2_PACKAGE_UTF8PROC is not set
# Mail
# BR2_PACKAGE_DOVECOT is not set
# BR2_PACKAGE_EXIM is not set
# BR2_PACKAGE_FETCHMAIL is not set
# BR2_PACKAGE_HEIRLOOM_MAILX is not set
# BR2_PACKAGE_LIBESMTP is not set
# BR2_PACKAGE_MSMTP is not set
# BR2_PACKAGE_MUTT is not set
# Miscellaneous
# BR2_PACKAGE_AESPIPE is not set
# BR2_PACKAGE_BC is not set
BR2_PACKAGE_BITCOIN_ARCH_SUPPORTS=y
# BR2_PACKAGE_BITCOIN is not set
# BR2_PACKAGE_CLAMAV is not set
# BR2_PACKAGE_COLLECTD is not set
# BR2_PACKAGE_COLLECTL is not set
# domoticz needs lua 5.3 and a toolchain w/ C++, gcc >= 4.8, NPTL, wchar, dynamic library
# BR2_PACKAGE_EMPTY is not set
# BR2_PACKAGE_GNURADIO is not set
# BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set
# gqrx needs a toolchain w/ C++, threads, wchar, dynamic library
# gqrx needs qt5
# BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set
# BR2_PACKAGE_HAVEGED is not set
# BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set
# BR2_PACKAGE_MCRYPT is not set
# BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set
# BR2_PACKAGE_NETDATA is not set
# BR2_PACKAGE_PROJ is not set
# BR2_PACKAGE_QPDF is not set
# BR2_PACKAGE_SHARED_MIME_INFO is not set
# BR2_PACKAGE_SUNWAIT is not set
# BR2_PACKAGE_TASKD is not set
# BR2_PACKAGE_XUTIL_UTIL_MACROS is not set
# Networking applications
# BR2_PACKAGE_AIRCRACK_NG is not set
# BR2_PACKAGE_AOETOOLS is not set
# BR2_PACKAGE_APACHE is not set
# BR2_PACKAGE_ARGUS is not set
# BR2_PACKAGE_ARP_SCAN is not set
# BR2_PACKAGE_ARPTABLES is not set
# BR2_PACKAGE_ASTERISK is not set
# BR2_PACKAGE_ATFTP is not set
# BR2_PACKAGE_AVAHI is not set
# BR2_PACKAGE_AXEL is not set
# BR2_PACKAGE_BABELD is not set
# BR2_PACKAGE_BANDWIDTHD is not set
# BR2_PACKAGE_BATCTL is not set
# BR2_PACKAGE_BCUSDK is not set
# BR2_PACKAGE_BIND is not set
# BR2_PACKAGE_BIRD is not set
# BR2_PACKAGE_BLUEZ5_UTILS is not set
# BR2_PACKAGE_BMON is not set
# BR2_PACKAGE_BOINC is not set
# BR2_PACKAGE_BRCM_PATCHRAM_PLUS is not set
# BR2_PACKAGE_BRIDGE_UTILS is not set
# BR2_PACKAGE_BWM_NG is not set
# BR2_PACKAGE_C_ICAP is not set
# BR2_PACKAGE_CAN_UTILS is not set
# BR2_PACKAGE_CANNELLONI is not set
# BR2_PACKAGE_CASYNC is not set
# BR2_PACKAGE_CHRONY is not set
# BR2_PACKAGE_CIVETWEB is not set
# BR2_PACKAGE_CONNMAN is not set
# connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library
# BR2_PACKAGE_CONNTRACK_TOOLS is not set
# BR2_PACKAGE_CORKSCREW is not set
# BR2_PACKAGE_CRDA is not set
# BR2_PACKAGE_CTORRENT is not set
# BR2_PACKAGE_CUPS is not set
# BR2_PACKAGE_DANTE is not set
# BR2_PACKAGE_DARKHTTPD is not set
# BR2_PACKAGE_DEHYDRATED is not set
# BR2_PACKAGE_DHCPCD is not set
# BR2_PACKAGE_DHCPDUMP is not set
# BR2_PACKAGE_DNSMASQ is not set
# BR2_PACKAGE_DRBD_UTILS is not set
# BR2_PACKAGE_DROPBEAR is not set
# BR2_PACKAGE_EASYFRAMES is not set
# BR2_PACKAGE_EBTABLES is not set
# ejabberd needs erlang, toolchain w/ C++
# BR2_PACKAGE_ETHTOOL is not set
# BR2_PACKAGE_FAIFA is not set
# BR2_PACKAGE_FASTD is not set
# BR2_PACKAGE_FCGIWRAP is not set
# BR2_PACKAGE_FPING is not set
# BR2_PACKAGE_FREESWITCH is not set
# BR2_PACKAGE_FRR is not set
# BR2_PACKAGE_GERBERA is not set
# BR2_PACKAGE_GESFTPSERVER is not set
# BR2_PACKAGE_GLOOX is not set
# BR2_PACKAGE_GLORYTUN is not set
# gupnp-tools needs libgtk3
# BR2_PACKAGE_HANS is not set
BR2_PACKAGE_HAPROXY_ARCH_SUPPORTS=y
# BR2_PACKAGE_HAPROXY is not set
# BR2_PACKAGE_HIAWATHA is not set
# BR2_PACKAGE_HOSTAPD is not set
# BR2_PACKAGE_HTPDATE is not set
# BR2_PACKAGE_HTTPING is not set
# BR2_PACKAGE_I2PD is not set
# BR2_PACKAGE_IBRDTN_TOOLS is not set
# BR2_PACKAGE_IBRDTND is not set
# BR2_PACKAGE_IFMETRIC is not set
# BR2_PACKAGE_IFTOP is not set
BR2_PACKAGE_IFUPDOWN_SCRIPTS=y
# BR2_PACKAGE_IGD2_FOR_LINUX is not set
# BR2_PACKAGE_IGH_ETHERCAT is not set
# BR2_PACKAGE_IGMPPROXY is not set
# BR2_PACKAGE_INADYN is not set
# BR2_PACKAGE_IODINE is not set
# BR2_PACKAGE_IPERF is not set
# BR2_PACKAGE_IPERF3 is not set
# BR2_PACKAGE_IPROUTE2 is not set
# BR2_PACKAGE_IPSET is not set
# BR2_PACKAGE_IPTABLES is not set
# BR2_PACKAGE_IPTRAF_NG is not set
# BR2_PACKAGE_IPUTILS is not set
# BR2_PACKAGE_IRSSI is not set
# BR2_PACKAGE_IW is not set
# BR2_PACKAGE_IWD is not set
# BR2_PACKAGE_JANUS_GATEWAY is not set
# BR2_PACKAGE_KEEPALIVED is not set
# BR2_PACKAGE_KISMET is not set
# BR2_PACKAGE_KNOCK is not set
# BR2_PACKAGE_LEAFNODE2 is not set
# BR2_PACKAGE_LFT is not set
# BR2_PACKAGE_LFTP is not set
# BR2_PACKAGE_LIGHTTPD is not set
# BR2_PACKAGE_LINKNX is not set
# BR2_PACKAGE_LINKS is not set
# BR2_PACKAGE_LINPHONE is not set
# BR2_PACKAGE_LINUX_ZIGBEE is not set
# BR2_PACKAGE_LINUXPTP is not set
# BR2_PACKAGE_LLDPD is not set
# BR2_PACKAGE_LRZSZ is not set
# BR2_PACKAGE_LYNX is not set
# BR2_PACKAGE_MACCHANGER is not set
# BR2_PACKAGE_MEMCACHED is not set
# BR2_PACKAGE_MII_DIAG is not set
# BR2_PACKAGE_MINI_SNMPD is not set
# BR2_PACKAGE_MINIDLNA is not set
# BR2_PACKAGE_MINISSDPD is not set
BR2_PACKAGE_MJPG_STREAMER=y
# BR2_PACKAGE_MODEM_MANAGER is not set
BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y
# BR2_PACKAGE_MONGREL2 is not set
# BR2_PACKAGE_MONKEY is not set
# BR2_PACKAGE_MOSH is not set
# BR2_PACKAGE_MOSQUITTO is not set
# BR2_PACKAGE_MROUTED is not set
# BR2_PACKAGE_MRP is not set
# BR2_PACKAGE_MTR is not set
# BR2_PACKAGE_NBD is not set
# BR2_PACKAGE_NCFTP is not set
# BR2_PACKAGE_NDISC6 is not set
# BR2_PACKAGE_NETATALK is not set
# BR2_PACKAGE_NETCALC is not set
# BR2_PACKAGE_NETPLUG is not set
# BR2_PACKAGE_NETSNMP is not set
# BR2_PACKAGE_NETSTAT_NAT is not set
# BR2_PACKAGE_NETWORK_MANAGER is not set
# BR2_PACKAGE_NFACCT is not set
# BR2_PACKAGE_NFTABLES is not set
# BR2_PACKAGE_NGINX is not set
# BR2_PACKAGE_NGIRCD is not set
# BR2_PACKAGE_NGREP is not set
# BR2_PACKAGE_NLOAD is not set
# BR2_PACKAGE_NMAP is not set
# BR2_PACKAGE_NOIP is not set
# BR2_PACKAGE_NTP is not set
# BR2_PACKAGE_NUTTCP is not set
# BR2_PACKAGE_ODHCP6C is not set
# BR2_PACKAGE_ODHCPLOC is not set
# BR2_PACKAGE_OLSR is not set
# BR2_PACKAGE_OPEN_LLDP is not set
# BR2_PACKAGE_OPEN_PLC_UTILS is not set
# BR2_PACKAGE_OPENNTPD is not set
# BR2_PACKAGE_OPENOBEX is not set
# BR2_PACKAGE_OPENRESOLV is not set
# BR2_PACKAGE_OPENSSH is not set
# BR2_PACKAGE_OPENSWAN is not set
# BR2_PACKAGE_OPENVPN is not set
# BR2_PACKAGE_P910ND is not set
# BR2_PACKAGE_PARPROUTED is not set
# BR2_PACKAGE_PHIDGETWEBSERVICE is not set
# BR2_PACKAGE_PHYTOOL is not set
# BR2_PACKAGE_PIMD is not set
# BR2_PACKAGE_PIXIEWPS is not set
# BR2_PACKAGE_POUND is not set
# BR2_PACKAGE_PPPD is not set
# BR2_PACKAGE_PPTP_LINUX is not set
# BR2_PACKAGE_PRIVOXY is not set
# BR2_PACKAGE_PROFTPD is not set
# prosody needs the lua interpreter, dynamic library
# BR2_PACKAGE_PROXYCHAINS_NG is not set
# BR2_PACKAGE_PTPD is not set
# BR2_PACKAGE_PTPD2 is not set
# BR2_PACKAGE_PURE_FTPD is not set
# BR2_PACKAGE_PUTTY is not set
# BR2_PACKAGE_QUAGGA is not set
# rabbitmq-server needs erlang
# BR2_PACKAGE_RADVD is not set
# BR2_PACKAGE_REAVER is not set
# BR2_PACKAGE_REDIR is not set
# BR2_PACKAGE_RP_PPPOE is not set
# BR2_PACKAGE_RPCBIND is not set
# BR2_PACKAGE_RSH_REDONE is not set
# BR2_PACKAGE_RSYNC is not set
# BR2_PACKAGE_RTORRENT is not set
# BR2_PACKAGE_RTPTOOLS is not set
# BR2_PACKAGE_RYGEL is not set
# BR2_PACKAGE_S6_DNS is not set
# BR2_PACKAGE_S6_NETWORKING is not set
# BR2_PACKAGE_SAMBA4 is not set
# BR2_PACKAGE_SCONESERVER is not set
# BR2_PACKAGE_SER2NET is not set
# BR2_PACKAGE_SHADOWSOCKS_LIBEV is not set
# BR2_PACKAGE_SHAIRPORT_SYNC is not set
# BR2_PACKAGE_SHELLINABOX is not set
# BR2_PACKAGE_SMCROUTE is not set
# BR2_PACKAGE_SNGREP is not set
# BR2_PACKAGE_SNORT is not set
# BR2_PACKAGE_SOCAT is not set
# BR2_PACKAGE_SOCKETCAND is not set
# BR2_PACKAGE_SOFTETHER is not set
# BR2_PACKAGE_SPAWN_FCGI is not set
# BR2_PACKAGE_SPICE_PROTOCOL is not set
# BR2_PACKAGE_SQUID is not set
# BR2_PACKAGE_SSDP_RESPONDER is not set
# BR2_PACKAGE_SSHGUARD is not set
# BR2_PACKAGE_SSHPASS is not set
# BR2_PACKAGE_SSLH is not set
# BR2_PACKAGE_STRONGSWAN is not set
# BR2_PACKAGE_STUNNEL is not set
# BR2_PACKAGE_TCPDUMP is not set
# BR2_PACKAGE_TCPING is not set
# BR2_PACKAGE_TCPREPLAY is not set
# BR2_PACKAGE_THTTPD is not set
# BR2_PACKAGE_TINC is not set
# BR2_PACKAGE_TINYPROXY is not set
# BR2_PACKAGE_TINYSSH is not set
# BR2_PACKAGE_TOR is not set
# BR2_PACKAGE_TRACEROUTE is not set
# BR2_PACKAGE_TRANSMISSION is not set
# BR2_PACKAGE_TUNCTL is not set
# BR2_PACKAGE_TVHEADEND is not set
# BR2_PACKAGE_UACME is not set
# BR2_PACKAGE_UDPCAST is not set
# BR2_PACKAGE_UFTP is not set
# BR2_PACKAGE_UHTTPD is not set
# BR2_PACKAGE_ULOGD is not set
# BR2_PACKAGE_UNBOUND is not set
# BR2_PACKAGE_UREDIR is not set
# BR2_PACKAGE_USHARE is not set
# BR2_PACKAGE_USSP_PUSH is not set
# BR2_PACKAGE_VDE2 is not set
# BR2_PACKAGE_VDR is not set
# BR2_PACKAGE_VNSTAT is not set
# BR2_PACKAGE_VPNC is not set
# BR2_PACKAGE_VSFTPD is not set
# BR2_PACKAGE_VTUN is not set
# BR2_PACKAGE_WAVEMON is not set
# BR2_PACKAGE_WIREGUARD_LINUX_COMPAT is not set
# BR2_PACKAGE_WIREGUARD_TOOLS is not set
# BR2_PACKAGE_WIRELESS_REGDB is not set
# BR2_PACKAGE_WIRELESS_TOOLS is not set
# BR2_PACKAGE_WIRESHARK is not set
# BR2_PACKAGE_WPA_SUPPLICANT is not set
# BR2_PACKAGE_WPAN_TOOLS is not set
# BR2_PACKAGE_XINETD is not set
# BR2_PACKAGE_XL2TP is not set
# BR2_PACKAGE_XTABLES_ADDONS is not set
# BR2_PACKAGE_ZNC is not set
# Package managers
# Please note:
# - Buildroot does *not* generate binary packages,
# - Buildroot does *not* install any package database.
# It is up to you to provide those by yourself if you
# want to use any of those package managers.
# See the manual:
# http://buildroot.org/manual.html#faq-no-binary-packages
# BR2_PACKAGE_OPKG is not set
# Real-Time
# BR2_PACKAGE_XENOMAI is not set
# Security
# BR2_PACKAGE_APPARMOR is not set
# BR2_PACKAGE_CHECKPOLICY is not set
# BR2_PACKAGE_IMA_EVM_UTILS is not set
# BR2_PACKAGE_OPTEE_BENCHMARK is not set
# BR2_PACKAGE_OPTEE_CLIENT is not set
# BR2_PACKAGE_PAXTEST is not set
# BR2_PACKAGE_REFPOLICY is not set
# BR2_PACKAGE_RESTORECOND is not set
# BR2_PACKAGE_SELINUX_PYTHON is not set
# BR2_PACKAGE_SEMODULE_UTILS is not set
# setools needs python3
BR2_PACKAGE_URANDOM_SCRIPTS=y
# Shell and utilities
# Shells
# BR2_PACKAGE_MKSH is not set
# BR2_PACKAGE_ZSH is not set
# Utilities
# BR2_PACKAGE_AT is not set
# BR2_PACKAGE_CCRYPT is not set
# BR2_PACKAGE_DIALOG is not set
# BR2_PACKAGE_DTACH is not set
# BR2_PACKAGE_EASY_RSA is not set
# BR2_PACKAGE_FILE is not set
# BR2_PACKAGE_GNUPG is not set
# BR2_PACKAGE_GNUPG2 is not set
# BR2_PACKAGE_INOTIFY_TOOLS is not set
# BR2_PACKAGE_LOCKFILE_PROGS is not set
# BR2_PACKAGE_LOGROTATE is not set
# BR2_PACKAGE_LOGSURFER is not set
# BR2_PACKAGE_PDMENU is not set
# BR2_PACKAGE_PINENTRY is not set
# BR2_PACKAGE_QPRINT is not set
# BR2_PACKAGE_RANGER is not set
# BR2_PACKAGE_RTTY is not set
# BR2_PACKAGE_SCREEN is not set
# BR2_PACKAGE_SUDO is not set
# BR2_PACKAGE_TINI is not set
# BR2_PACKAGE_TMUX is not set
# BR2_PACKAGE_TTYD is not set
# BR2_PACKAGE_XMLSTARLET is not set
# BR2_PACKAGE_XXHASH is not set
# BR2_PACKAGE_YTREE is not set
# System tools
# BR2_PACKAGE_ACL is not set
# BR2_PACKAGE_ANDROID_TOOLS is not set
# BR2_PACKAGE_ATOP is not set
# BR2_PACKAGE_ATTR is not set
# BR2_PACKAGE_BUBBLEWRAP is not set
# BR2_PACKAGE_CGROUPFS_MOUNT is not set
# circus needs Python 3 and a toolchain w/ C++, threads
# BR2_PACKAGE_CPULOAD is not set
# BR2_PACKAGE_DAEMON is not set
# BR2_PACKAGE_DC3DD is not set
# BR2_PACKAGE_DDRESCUE is not set
# BR2_PACKAGE_DOCKER_COMPOSE is not set
# BR2_PACKAGE_EARLYOOM is not set
# BR2_PACKAGE_EMLOG is not set
# BR2_PACKAGE_FTOP is not set
# BR2_PACKAGE_GETENT is not set
# BR2_PACKAGE_GKRELLM is not set
# BR2_PACKAGE_HTOP is not set
# BR2_PACKAGE_IBM_SW_TPM2 is not set
BR2_PACKAGE_INITSCRIPTS=y
# iotop depends on python or python3
# BR2_PACKAGE_IPRUTILS is not set
# BR2_PACKAGE_IRQBALANCE is not set
# BR2_PACKAGE_KEYUTILS is not set
BR2_PACKAGE_KMOD=y
# BR2_PACKAGE_LIBOSTREE is not set
# BR2_PACKAGE_LXC is not set
# BR2_PACKAGE_MFOC is not set
# BR2_PACKAGE_MONIT is not set
# BR2_PACKAGE_MULTIPATH_TOOLS is not set
# BR2_PACKAGE_NCDU is not set
# netifrc needs openrc as init system
# BR2_PACKAGE_NUT is not set
# pamtester depends on linux-pam
# BR2_PACKAGE_POLKIT is not set
# BR2_PACKAGE_PROCRANK_LINUX is not set
# BR2_PACKAGE_PWGEN is not set
# BR2_PACKAGE_QUOTA is not set
# BR2_PACKAGE_QUOTATOOL is not set
# BR2_PACKAGE_RAUC is not set
# BR2_PACKAGE_S6 is not set
# BR2_PACKAGE_S6_LINUX_INIT is not set
# BR2_PACKAGE_S6_LINUX_UTILS is not set
# BR2_PACKAGE_S6_PORTABLE_UTILS is not set
# BR2_PACKAGE_S6_RC is not set
# BR2_PACKAGE_SCRUB is not set
# BR2_PACKAGE_SCRYPT is not set
# sdbusplus needs systemd and a toolchain w/ C++, gcc >= 7
# BR2_PACKAGE_SMACK is not set
# supervisor needs a python interpreter
# BR2_PACKAGE_SWUPDATE is not set
BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y
# BR2_PACKAGE_TPM_TOOLS is not set
# BR2_PACKAGE_TPM2_ABRMD is not set
# BR2_PACKAGE_TPM2_TOOLS is not set
# BR2_PACKAGE_TPM2_TOTP is not set
# BR2_PACKAGE_UNSCD is not set
BR2_PACKAGE_UTIL_LINUX=y
BR2_PACKAGE_UTIL_LINUX_LIBS=y
BR2_PACKAGE_UTIL_LINUX_LIBBLKID=y
# BR2_PACKAGE_UTIL_LINUX_LIBFDISK is not set
# BR2_PACKAGE_UTIL_LINUX_LIBMOUNT is not set
# BR2_PACKAGE_UTIL_LINUX_LIBSMARTCOLS is not set
# BR2_PACKAGE_UTIL_LINUX_LIBUUID is not set
# BR2_PACKAGE_UTIL_LINUX_BINARIES is not set
# BR2_PACKAGE_UTIL_LINUX_AGETTY is not set
# BR2_PACKAGE_UTIL_LINUX_BFS is not set
# BR2_PACKAGE_UTIL_LINUX_CAL is not set
# BR2_PACKAGE_UTIL_LINUX_CHFN_CHSH is not set
# BR2_PACKAGE_UTIL_LINUX_CHMEM is not set
# BR2_PACKAGE_UTIL_LINUX_CRAMFS is not set
# BR2_PACKAGE_UTIL_LINUX_EJECT is not set
# BR2_PACKAGE_UTIL_LINUX_FALLOCATE is not set
# BR2_PACKAGE_UTIL_LINUX_FDFORMAT is not set
# BR2_PACKAGE_UTIL_LINUX_FSCK is not set
# BR2_PACKAGE_UTIL_LINUX_HARDLINK is not set
# BR2_PACKAGE_UTIL_LINUX_HWCLOCK is not set
# BR2_PACKAGE_UTIL_LINUX_IPCRM is not set
# BR2_PACKAGE_UTIL_LINUX_IPCS is not set
# BR2_PACKAGE_UTIL_LINUX_KILL is not set
# BR2_PACKAGE_UTIL_LINUX_LAST is not set
# BR2_PACKAGE_UTIL_LINUX_LINE is not set
# BR2_PACKAGE_UTIL_LINUX_LOGGER is not set
# BR2_PACKAGE_UTIL_LINUX_LOGIN is not set
# BR2_PACKAGE_UTIL_LINUX_LOSETUP is not set
# BR2_PACKAGE_UTIL_LINUX_LSLOGINS is not set
# BR2_PACKAGE_UTIL_LINUX_LSMEM is not set
# BR2_PACKAGE_UTIL_LINUX_MESG is not set
# BR2_PACKAGE_UTIL_LINUX_MINIX is not set
# BR2_PACKAGE_UTIL_LINUX_MORE is not set
# BR2_PACKAGE_UTIL_LINUX_MOUNT is not set
# BR2_PACKAGE_UTIL_LINUX_MOUNTPOINT is not set
# BR2_PACKAGE_UTIL_LINUX_NEWGRP is not set
# BR2_PACKAGE_UTIL_LINUX_NOLOGIN is not set
# BR2_PACKAGE_UTIL_LINUX_NSENTER is not set
# BR2_PACKAGE_UTIL_LINUX_PG is not set
# BR2_PACKAGE_UTIL_LINUX_PARTX is not set
# BR2_PACKAGE_UTIL_LINUX_PIVOT_ROOT is not set
# BR2_PACKAGE_UTIL_LINUX_RAW is not set
# BR2_PACKAGE_UTIL_LINUX_RENAME is not set
# BR2_PACKAGE_UTIL_LINUX_RFKILL is not set
# BR2_PACKAGE_UTIL_LINUX_RUNUSER is not set
# BR2_PACKAGE_UTIL_LINUX_SCHEDUTILS is not set
# BR2_PACKAGE_UTIL_LINUX_SETPRIV is not set
# BR2_PACKAGE_UTIL_LINUX_SETTERM is not set
# BR2_PACKAGE_UTIL_LINUX_SU is not set
# BR2_PACKAGE_UTIL_LINUX_SULOGIN is not set
# BR2_PACKAGE_UTIL_LINUX_SWITCH_ROOT is not set
# BR2_PACKAGE_UTIL_LINUX_TUNELP is not set
# BR2_PACKAGE_UTIL_LINUX_UL is not set
# BR2_PACKAGE_UTIL_LINUX_UNSHARE is not set
# BR2_PACKAGE_UTIL_LINUX_UTMPDUMP is not set
# BR2_PACKAGE_UTIL_LINUX_UUIDD is not set
# BR2_PACKAGE_UTIL_LINUX_VIPW is not set
# BR2_PACKAGE_UTIL_LINUX_WALL is not set
# BR2_PACKAGE_UTIL_LINUX_WIPEFS is not set
# BR2_PACKAGE_UTIL_LINUX_WDCTL is not set
# BR2_PACKAGE_UTIL_LINUX_WRITE is not set
# BR2_PACKAGE_UTIL_LINUX_ZRAMCTL is not set
# BR2_PACKAGE_WATCHDOG is not set
# BR2_PACKAGE_XDG_DBUS_PROXY is not set
# Text editors and viewers
# BR2_PACKAGE_ED is not set
# BR2_PACKAGE_JOE is not set
# BR2_PACKAGE_MC is not set
# BR2_PACKAGE_MG is not set
# BR2_PACKAGE_MOST is not set
# BR2_PACKAGE_NANO is not set
# BR2_PACKAGE_UEMACS is not set
# Filesystem images
# BR2_TARGET_ROOTFS_AXFS is not set
# BR2_TARGET_ROOTFS_BTRFS is not set
# BR2_TARGET_ROOTFS_CLOOP is not set
# BR2_TARGET_ROOTFS_CPIO is not set
# BR2_TARGET_ROOTFS_CRAMFS is not set
# BR2_TARGET_ROOTFS_EROFS is not set
BR2_TARGET_ROOTFS_EXT2=y
# BR2_TARGET_ROOTFS_EXT2_2r0 is not set
# BR2_TARGET_ROOTFS_EXT2_2r1 is not set
# BR2_TARGET_ROOTFS_EXT2_3 is not set
BR2_TARGET_ROOTFS_EXT2_4=y
BR2_TARGET_ROOTFS_EXT2_GEN=4
BR2_TARGET_ROOTFS_EXT2_REV=1
BR2_TARGET_ROOTFS_EXT2_LABEL="rootfs"
BR2_TARGET_ROOTFS_EXT2_SIZE="60M"
BR2_TARGET_ROOTFS_EXT2_INODES=0
BR2_TARGET_ROOTFS_EXT2_RESBLKS=5
BR2_TARGET_ROOTFS_EXT2_MKFS_OPTIONS="-O ^64bit"
BR2_TARGET_ROOTFS_EXT2_NONE=y
# BR2_TARGET_ROOTFS_EXT2_GZIP is not set
# BR2_TARGET_ROOTFS_EXT2_BZIP2 is not set
# BR2_TARGET_ROOTFS_EXT2_LZ4 is not set
# BR2_TARGET_ROOTFS_EXT2_LZMA is not set
# BR2_TARGET_ROOTFS_EXT2_LZO is not set
# BR2_TARGET_ROOTFS_EXT2_XZ is not set
# BR2_TARGET_ROOTFS_F2FS is not set
# BR2_TARGET_ROOTFS_INITRAMFS is not set
# BR2_TARGET_ROOTFS_JFFS2 is not set
# BR2_TARGET_ROOTFS_ROMFS is not set
# BR2_TARGET_ROOTFS_SQUASHFS is not set
BR2_TARGET_ROOTFS_TAR=y
BR2_TARGET_ROOTFS_TAR_NONE=y
# BR2_TARGET_ROOTFS_TAR_GZIP is not set
# BR2_TARGET_ROOTFS_TAR_BZIP2 is not set
# BR2_TARGET_ROOTFS_TAR_LZ4 is not set
# BR2_TARGET_ROOTFS_TAR_LZMA is not set
# BR2_TARGET_ROOTFS_TAR_LZO is not set
# BR2_TARGET_ROOTFS_TAR_XZ is not set
BR2_TARGET_ROOTFS_TAR_OPTIONS=""
# BR2_TARGET_ROOTFS_UBI is not set
# BR2_TARGET_ROOTFS_UBIFS is not set
# BR2_TARGET_ROOTFS_YAFFS2 is not set
# Bootloaders
# BR2_TARGET_BAREBOX is not set
BR2_TARGET_OPENSBI=y
BR2_TARGET_OPENSBI_PLAT="thead/c910"
# BR2_TARGET_OPENSBI_LINUX_PAYLOAD is not set
BR2_TARGET_UBOOT=y
BR2_TARGET_UBOOT_BUILD_SYSTEM_KCONFIG=y
# BR2_TARGET_UBOOT_BUILD_SYSTEM_LEGACY is not set
# BR2_TARGET_UBOOT_LATEST_VERSION is not set
# BR2_TARGET_UBOOT_CUSTOM_VERSION is not set
# BR2_TARGET_UBOOT_CUSTOM_TARBALL is not set
BR2_TARGET_UBOOT_CUSTOM_GIT=y
# BR2_TARGET_UBOOT_CUSTOM_HG is not set
# BR2_TARGET_UBOOT_CUSTOM_SVN is not set
BR2_TARGET_UBOOT_CUSTOM_REPO_URL="https://gitee.com/weidongshan/NezaD1-u-boot-2018.git"
BR2_TARGET_UBOOT_CUSTOM_REPO_VERSION="origin/master"
BR2_TARGET_UBOOT_VERSION="origin/master"
BR2_TARGET_UBOOT_PATCH=""
BR2_TARGET_UBOOT_USE_DEFCONFIG=y
# BR2_TARGET_UBOOT_USE_CUSTOM_CONFIG is not set
BR2_TARGET_UBOOT_BOARD_DEFCONFIG="sun20iw1p1"
BR2_TARGET_UBOOT_CONFIG_FRAGMENT_FILES=""
BR2_TARGET_UBOOT_NEEDS_DTC=y
BR2_TARGET_UBOOT_NEEDS_PYTHON=y
# BR2_TARGET_UBOOT_NEEDS_PYTHON2 is not set
BR2_TARGET_UBOOT_NEEDS_PYTHON3=y
BR2_TARGET_UBOOT_NEEDS_PYLIBFDT=y
# BR2_TARGET_UBOOT_NEEDS_PYELFTOOLS is not set
BR2_TARGET_UBOOT_NEEDS_OPENSSL=y
# BR2_TARGET_UBOOT_NEEDS_LZOP is not set
BR2_TARGET_UBOOT_NEEDS_OPENSBI=y
# U-Boot binary format
# BR2_TARGET_UBOOT_FORMAT_AIS is not set
# BR2_TARGET_UBOOT_FORMAT_BIN is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_BIN is not set
# BR2_TARGET_UBOOT_FORMAT_NAND_BIN is not set
# BR2_TARGET_UBOOT_FORMAT_ELF is not set
# BR2_TARGET_UBOOT_FORMAT_IMG is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_IMG is not set
# BR2_TARGET_UBOOT_FORMAT_IMX is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_IMX is not set
# BR2_TARGET_UBOOT_FORMAT_ITB is not set
BR2_TARGET_UBOOT_FORMAT_CUSTOM=y
BR2_TARGET_UBOOT_FORMAT_CUSTOM_NAME="u-boot-sun20iw1p1.bin"
# BR2_TARGET_UBOOT_SPL is not set
BR2_TARGET_UBOOT_CUSTOM_DTS_PATH=""
BR2_TARGET_UBOOT_CUSTOM_MAKEOPTS=""
# Host utilities
# BR2_PACKAGE_HOST_ABOOTIMG is not set
# BR2_PACKAGE_HOST_AESPIPE is not set
# BR2_PACKAGE_HOST_ANDROID_TOOLS is not set
# BR2_PACKAGE_HOST_ASN1C is not set
# BR2_PACKAGE_HOST_BABELTRACE2 is not set
# BR2_PACKAGE_HOST_BTRFS_PROGS is not set
# BR2_PACKAGE_HOST_CHECKPOLICY is not set
# BR2_PACKAGE_HOST_CHECKSEC is not set
# BR2_PACKAGE_HOST_CMAKE is not set
# BR2_PACKAGE_HOST_CRAMFS is not set
# BR2_PACKAGE_HOST_CRYPTSETUP is not set
# BR2_PACKAGE_HOST_DBUS_PYTHON is not set
# BR2_PACKAGE_HOST_DFU_UTIL is not set
# BR2_PACKAGE_HOST_DOS2UNIX is not set
# BR2_PACKAGE_HOST_DOSFSTOOLS is not set
# BR2_PACKAGE_HOST_DOXYGEN is not set
BR2_PACKAGE_HOST_DTC=y
BR2_PACKAGE_HOST_E2FSPROGS=y
# BR2_PACKAGE_HOST_E2TOOLS is not set
# BR2_PACKAGE_HOST_ENVIRONMENT_SETUP is not set
# BR2_PACKAGE_HOST_EROFS_UTILS is not set
BR2_PACKAGE_HOST_EUDEV=y
# BR2_PACKAGE_HOST_EXFATPROGS is not set
# BR2_PACKAGE_HOST_F2FS_TOOLS is not set
# BR2_PACKAGE_HOST_FAKETIME is not set
# BR2_PACKAGE_HOST_FATCAT is not set
# BR2_PACKAGE_HOST_FWUP is not set
# BR2_PACKAGE_HOST_GENEXT2FS is not set
BR2_PACKAGE_HOST_GENIMAGE=y
# BR2_PACKAGE_HOST_GENPART is not set
# BR2_PACKAGE_HOST_GNUPG is not set
BR2_PACKAGE_HOST_GO_HOST_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_BOOTSTRAP_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_GPTFDISK is not set
# BR2_PACKAGE_HOST_IMAGEMAGICK is not set
# BR2_PACKAGE_HOST_IMX_MKIMAGE is not set
# BR2_PACKAGE_HOST_JQ is not set
# BR2_PACKAGE_HOST_JSMIN is not set
BR2_PACKAGE_HOST_KMOD=y
# BR2_PACKAGE_HOST_KMOD_GZ is not set
# BR2_PACKAGE_HOST_KMOD_XZ is not set
# BR2_PACKAGE_HOST_LIBP11 is not set
# BR2_PACKAGE_HOST_LPC3250LOADER is not set
# BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_HOST_MENDER_ARTIFACT is not set
# BR2_PACKAGE_HOST_MESON_TOOLS is not set
# BR2_PACKAGE_HOST_MKPASSWD is not set
# BR2_PACKAGE_HOST_MTD is not set
# BR2_PACKAGE_HOST_MTOOLS is not set
# BR2_PACKAGE_HOST_ODB is not set
# BR2_PACKAGE_HOST_OPENOCD is not set
# BR2_PACKAGE_HOST_OPKG_UTILS is not set
# BR2_PACKAGE_HOST_PARTED is not set
BR2_PACKAGE_HOST_PATCHELF=y
# BR2_PACKAGE_HOST_PIGZ is not set
# BR2_PACKAGE_HOST_PKGCONF is not set
# BR2_PACKAGE_HOST_PWGEN is not set
# BR2_PACKAGE_HOST_PYTHON is not set
# BR2_PACKAGE_HOST_PYTHON_CYTHON is not set
# BR2_PACKAGE_HOST_PYTHON_LXML is not set
# BR2_PACKAGE_HOST_PYTHON_SIX is not set
# BR2_PACKAGE_HOST_PYTHON_XLRD is not set
# BR2_PACKAGE_HOST_PYTHON3 is not set
BR2_PACKAGE_HOST_QEMU_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_SYSTEM_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_USER_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_QEMU is not set
# BR2_PACKAGE_HOST_QORIQ_RCW is not set
# BR2_PACKAGE_HOST_RAUC is not set
BR2_PACKAGE_HOST_RUSTC_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_RUSTC_ARCH="riscv64"
# BR2_PACKAGE_HOST_RUSTC is not set
BR2_PACKAGE_PROVIDES_HOST_RUSTC="host-rust-bin"
# BR2_PACKAGE_HOST_SAM_BA is not set
# BR2_PACKAGE_HOST_SDBUSPLUS is not set
# BR2_PACKAGE_HOST_SENTRY_CLI is not set
# BR2_PACKAGE_HOST_SQUASHFS is not set
# BR2_PACKAGE_HOST_SWIG is not set
BR2_PACKAGE_HOST_UBOOT_TOOLS=y
# BR2_PACKAGE_HOST_UBOOT_TOOLS_FIT_SUPPORT is not set
# BR2_PACKAGE_HOST_UBOOT_TOOLS_ENVIMAGE is not set
BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT=y
BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT_SOURCE="board/sifive/hifive-unleashed/boot.cmd"
BR2_PACKAGE_HOST_UTIL_LINUX=y
# BR2_PACKAGE_HOST_UTP_COM is not set
# BR2_PACKAGE_HOST_VBOOT_UTILS is not set
# BR2_PACKAGE_HOST_XORRISO is not set
# BR2_PACKAGE_HOST_ZIP is not set
# BR2_PACKAGE_HOST_ZSTD is not set
# Legacy config options
# Legacy options removed in 2021.02
# BR2_PACKAGE_MPD_AUDIOFILE is not set
# BR2_PACKAGE_AUDIOFILE is not set
# BR2_BINUTILS_VERSION_2_33_X is not set
# BR2_PACKAGE_LIBUPNP18 is not set
# BR2_PACKAGE_BOA is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IMX_SDMA is not set
# BR2_GDB_VERSION_8_2 is not set
# BR2_PACKAGE_HOST_RCW is not set
# BR2_KERNEL_HEADERS_5_9 is not set
# BR2_KERNEL_HEADERS_5_8 is not set
# BR2_powerpc_601 is not set
# BR2_PACKAGE_TI_SGX_LIBGBM is not set
# BR2_PACKAGE_IPSEC_TOOLS is not set
# Legacy options removed in 2020.11
# BR2_PACKAGE_OPENCV is not set
# BR2_PACKAGE_LIBCROCO is not set
# BR2_PACKAGE_BELLAGIO is not set
# BR2_PACKAGE_SYSTEMD_JOURNAL_GATEWAY is not set
# BR2_TARGET_UBOOT_BOOT_SCRIPT is not set
# BR2_TARGET_UBOOT_ENVIMAGE is not set
# BR2_PACKAGE_KISMET_CLIENT is not set
# BR2_PACKAGE_KISMET_DRONE is not set
# BR2_GCC_VERSION_7_X is not set
# BR2_PACKAGE_GST1_VALIDATE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_YADIF is not set
# BR2_PACKAGE_GQVIEW is not set
# BR2_PACKAGE_WESTON_IMX is not set
# BR2_KERNEL_HEADERS_5_7 is not set
# BR2_PACKAGE_TINYHTTPD is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_AIGLX is not set
# BR2_PACKAGE_AMD_CATALYST is not set
# BR2_PACKAGE_NVIDIA_TEGRA23 is not set
# BR2_GDB_VERSION_8_1 is not set
# Legacy options removed in 2020.08
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_AMD64 is not set
# BR2_KERNEL_HEADERS_5_6 is not set
# BR2_KERNEL_HEADERS_5_5 is not set
# BR2_BINUTILS_VERSION_2_31_X is not set
# BR2_PACKAGE_KODI_PERIPHERAL_STEAMCONTROLLER is not set
# Legacy options removed in 2020.05
# BR2_PACKAGE_WIRINGPI is not set
# BR2_PACKAGE_PYTHON_PYCRYPTO is not set
# BR2_PACKAGE_MTDEV2TUIO is not set
# BR2_PACKAGE_EZXML is not set
# BR2_PACKAGE_COLLECTD_LVM is not set
# BR2_PACKAGE_PYTHON_PYASN is not set
# BR2_PACKAGE_PYTHON_PYASN_MODULES is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_10K_QCA6174 is not set
# BR2_PACKAGE_QT5CANVAS3D is not set
# BR2_PACKAGE_KODI_LIBTHEORA is not set
# BR2_PACKAGE_CEGUI06 is not set
# BR2_GCC_VERSION_5_X is not set
# Legacy options removed in 2020.02
# BR2_PACKAGE_JAMVM is not set
# BR2_PACKAGE_CLASSPATH is not set
# BR2_PACKAGE_QT5_VERSION_5_6 is not set
# BR2_PACKAGE_CURL is not set
# BR2_PACKAGE_GSTREAMER is not set
# BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_GSTREAMER_PLUGINS is not set
# BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_NV_SAMPLE_APPS is not set
# BR2_PACKAGE_FREERDP_GSTREAMER is not set
# BR2_PACKAGE_OPENCV3_WITH_GSTREAMER is not set
# BR2_PACKAGE_OPENCV_WITH_GSTREAMER is not set
# BR2_PACKAGE_LIBPLAYER is not set
# BR2_GCC_VERSION_OR1K is not set
# BR2_PACKAGE_BLUEZ_UTILS is not set
# BR2_PACKAGE_GADGETFS_TEST is not set
# BR2_PACKAGE_FIS is not set
BR2_PACKAGE_REFPOLICY_POLICY_VERSION=""
# BR2_PACKAGE_CELT051 is not set
# BR2_PACKAGE_WIREGUARD is not set
# BR2_PACKAGE_PERL_NET_PING is not set
# BR2_PACKAGE_PERL_MIME_BASE64 is not set
# BR2_PACKAGE_PERL_DIGEST_MD5 is not set
# BR2_PACKAGE_ERLANG_P1_ICONV is not set
# BR2_KERNEL_HEADERS_5_3 is not set
# BR2_PACKAGE_PYTHON_SCAPY3K is not set
# BR2_BINUTILS_VERSION_2_30_X is not set
# BR2_PACKAGE_RPI_USERLAND_START_VCFILED is not set
# Legacy options removed in 2019.11
# BR2_PACKAGE_OPENVMTOOLS_PROCPS is not set
# BR2_PACKAGE_ALLJOYN is not set
# BR2_PACKAGE_ALLJOYN_BASE is not set
# BR2_PACKAGE_ALLJOYN_BASE_CONTROLPANEL is not set
# BR2_PACKAGE_ALLJOYN_BASE_NOTIFICATION is not set
# BR2_PACKAGE_ALLJOYN_BASE_ONBOARDING is not set
# BR2_PACKAGE_ALLJOYN_TCL_BASE is not set
# BR2_PACKAGE_ALLJOYN_TCL is not set
BR2_TOOLCHAIN_EXTRA_EXTERNAL_LIBS=""
# BR2_PACKAGE_PYTHON_PYSNMP_APPS is not set
# BR2_KERNEL_HEADERS_5_2 is not set
# BR2_TARGET_RISCV_PK is not set
# BR2_PACKAGE_SQLITE_STAT3 is not set
# BR2_KERNEL_HEADERS_5_1 is not set
# BR2_PACKAGE_DEVMEM2 is not set
# BR2_PACKAGE_USTR is not set
# BR2_PACKAGE_KODI_SCREENSAVER_PLANESTATE is not set
# BR2_PACKAGE_KODI_VISUALISATION_WAVEFORHUE is not set
# BR2_PACKAGE_KODI_AUDIODECODER_OPUS is not set
# BR2_PACKAGE_MESA3D_OSMESA is not set
# BR2_PACKAGE_HOSTAPD_DRIVER_RTW is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DBUS_NEW is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DBUS_OLD is not set
# Legacy options removed in 2019.08
# BR2_TARGET_TS4800_MBRBOOT is not set
# BR2_PACKAGE_LIBAMCODEC is not set
# BR2_PACKAGE_ODROID_SCRIPTS is not set
# BR2_PACKAGE_ODROID_MALI is not set
# BR2_PACKAGE_KODI_PLATFORM_AML is not set
# BR2_GCC_VERSION_6_X is not set
# BR2_GCC_VERSION_4_9_X is not set
# BR2_GDB_VERSION_7_12 is not set
# BR2_PACKAGE_XAPP_MKFONTDIR is not set
# BR2_GDB_VERSION_8_0 is not set
# BR2_KERNEL_HEADERS_4_20 is not set
# BR2_KERNEL_HEADERS_5_0 is not set
# Legacy options removed in 2019.05
# BR2_CSKY_DSP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_COMPOSITOR is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_IQA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_OPENCV is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_STEREO is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VCD is not set
# BR2_PACKAGE_LUNIT is not set
# BR2_PACKAGE_FFMPEG_FFSERVER is not set
# BR2_PACKAGE_LIBUMP is not set
# BR2_PACKAGE_SUNXI_MALI is not set
# BR2_BINUTILS_VERSION_2_29_X is not set
# BR2_BINUTILS_VERSION_2_28_X is not set
# BR2_PACKAGE_GST_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# Legacy options removed in 2019.02
# BR2_PACKAGE_QT is not set
# BR2_PACKAGE_QTUIO is not set
# BR2_PACKAGE_PINENTRY_QT4 is not set
# BR2_PACKAGE_POPPLER_QT is not set
# BR2_PACKAGE_OPENCV3_WITH_QT is not set
# BR2_PACKAGE_OPENCV_WITH_QT is not set
# BR2_PACKAGE_AMD_CATALYST_CCCLE is not set
# BR2_PACKAGE_SDL_QTOPIA is not set
# BR2_PACKAGE_PYTHON_PYQT is not set
# BR2_PACKAGE_LUACRYPTO is not set
# BR2_PACKAGE_TN5250 is not set
# BR2_PACKAGE_BOOST_SIGNALS is not set
# BR2_PACKAGE_FFTW_PRECISION_SINGLE is not set
# BR2_PACKAGE_FFTW_PRECISION_DOUBLE is not set
# BR2_PACKAGE_FFTW_PRECISION_LONG_DOUBLE is not set
# BR2_PACKAGE_LUA_5_2 is not set
# BR2_TARGET_GENERIC_PASSWD_MD5 is not set
# Legacy options removed in 2018.11
# BR2_TARGET_XLOADER is not set
# BR2_PACKAGE_TIDSP_BINARIES is not set
# BR2_PACKAGE_DSP_TOOLS is not set
# BR2_PACKAGE_GST_DSP is not set
# BR2_PACKAGE_BOOTUTILS is not set
# BR2_PACKAGE_EXPEDITE is not set
# BR2_PACKAGE_MESA3D_OPENGL_TEXTURE_FLOAT is not set
# BR2_KERNEL_HEADERS_4_10 is not set
# BR2_KERNEL_HEADERS_4_11 is not set
# BR2_KERNEL_HEADERS_4_12 is not set
# BR2_KERNEL_HEADERS_4_13 is not set
# BR2_KERNEL_HEADERS_4_15 is not set
# BR2_KERNEL_HEADERS_4_17 is not set
# BR2_PACKAGE_LIBNFTNL_XML is not set
# BR2_KERNEL_HEADERS_3_2 is not set
# BR2_KERNEL_HEADERS_4_1 is not set
# BR2_KERNEL_HEADERS_4_16 is not set
# BR2_KERNEL_HEADERS_4_18 is not set
# Legacy options removed in 2018.08
# BR2_PACKAGE_DOCKER_ENGINE_STATIC_CLIENT is not set
# BR2_PACKAGE_XPROTO_APPLEWMPROTO is not set
# BR2_PACKAGE_XPROTO_BIGREQSPROTO is not set
# BR2_PACKAGE_XPROTO_COMPOSITEPROTO is not set
# BR2_PACKAGE_XPROTO_DAMAGEPROTO is not set
# BR2_PACKAGE_XPROTO_DMXPROTO is not set
# BR2_PACKAGE_XPROTO_DRI2PROTO is not set
# BR2_PACKAGE_XPROTO_DRI3PROTO is not set
# BR2_PACKAGE_XPROTO_FIXESPROTO is not set
# BR2_PACKAGE_XPROTO_FONTCACHEPROTO is not set
# BR2_PACKAGE_XPROTO_FONTSPROTO is not set
# BR2_PACKAGE_XPROTO_GLPROTO is not set
# BR2_PACKAGE_XPROTO_INPUTPROTO is not set
# BR2_PACKAGE_XPROTO_KBPROTO is not set
# BR2_PACKAGE_XPROTO_PRESENTPROTO is not set
# BR2_PACKAGE_XPROTO_RANDRPROTO is not set
# BR2_PACKAGE_XPROTO_RECORDPROTO is not set
# BR2_PACKAGE_XPROTO_RENDERPROTO is not set
# BR2_PACKAGE_XPROTO_RESOURCEPROTO is not set
# BR2_PACKAGE_XPROTO_SCRNSAVERPROTO is not set
# BR2_PACKAGE_XPROTO_VIDEOPROTO is not set
# BR2_PACKAGE_XPROTO_WINDOWSWMPROTO is not set
# BR2_PACKAGE_XPROTO_XCMISCPROTO is not set
# BR2_PACKAGE_XPROTO_XEXTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86BIGFONTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DGAPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DRIPROTO is not set
# BR2_PACKAGE_XPROTO_XF86VIDMODEPROTO is not set
# BR2_PACKAGE_XPROTO_XINERAMAPROTO is not set
# BR2_PACKAGE_XPROTO_XPROTO is not set
# BR2_PACKAGE_XPROTO_XPROXYMANAGEMENTPROTOCOL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_OPENGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLES2 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_EGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_X11 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_WAYLAND is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_DISPMANX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_AUDIOMIXER is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_LAME is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MPG123 is not set
# BR2_GDB_VERSION_7_11 is not set
# BR2_GDB_VERSION_7_10 is not set
# Legacy options removed in 2018.05
# BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set
# BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set
# BR2_PACKAGE_TI_SGX_AM335X is not set
# BR2_PACKAGE_TI_SGX_AM437X is not set
# BR2_PACKAGE_TI_SGX_AM4430 is not set
# BR2_PACKAGE_TI_SGX_AM5430 is not set
# BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set
# BR2_PACKAGE_JANUS_ECHO_TEST is not set
# BR2_PACKAGE_JANUS_RECORDPLAY is not set
# BR2_PACKAGE_JANUS_SIP_GATEWAY is not set
# BR2_PACKAGE_JANUS_STREAMING is not set
# BR2_PACKAGE_JANUS_TEXT_ROOM is not set
# BR2_PACKAGE_JANUS_VIDEO_CALL is not set
# BR2_PACKAGE_JANUS_VIDEO_ROOM is not set
# BR2_PACKAGE_JANUS_MQTT is not set
# BR2_PACKAGE_JANUS_RABBITMQ is not set
# BR2_PACKAGE_JANUS_REST is not set
# BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set
# BR2_PACKAGE_JANUS_WEBSOCKETS is not set
# BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set
# BR2_PACKAGE_LIBTFDI_CPP is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set
# BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set
# BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set
# BR2_PACKAGE_JQUERY_UI_THEME_START is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set
# BR2_PACKAGE_TRANSMISSION_REMOTE is not set
# BR2_PACKAGE_LIBKCAPI_APPS is not set
# BR2_PACKAGE_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MENCODER is not set
# BR2_PACKAGE_LIBPLAYER_MPLAYER is not set
# BR2_PACKAGE_IQVLINUX is not set
# BR2_BINFMT_FLAT_SEP_DATA is not set
# BR2_bfin is not set
# BR2_PACKAGE_KODI_ADSP_BASIC is not set
# BR2_PACKAGE_KODI_ADSP_FREESURROUND is not set
# Legacy options removed in 2018.02
# BR2_KERNEL_HEADERS_3_4 is not set
# BR2_KERNEL_HEADERS_3_10 is not set
# BR2_KERNEL_HEADERS_3_12 is not set
# BR2_BINUTILS_VERSION_2_27_X is not set
# BR2_PACKAGE_EEPROG is not set
# BR2_PACKAGE_GNUPG2_GPGV2 is not set
# BR2_PACKAGE_IMX_GPU_VIV_APITRACE is not set
# BR2_PACKAGE_IMX_GPU_VIV_G2D is not set
# Legacy options removed in 2017.11
# BR2_PACKAGE_RFKILL is not set
# BR2_PACKAGE_UTIL_LINUX_RESET is not set
# BR2_PACKAGE_POLICYCOREUTILS_AUDIT2ALLOW is not set
# BR2_PACKAGE_POLICYCOREUTILS_RESTORECOND is not set
# BR2_PACKAGE_SEPOLGEN is not set
# BR2_PACKAGE_OPENOBEX_BLUEZ is not set
# BR2_PACKAGE_OPENOBEX_LIBUSB is not set
# BR2_PACKAGE_OPENOBEX_APPS is not set
# BR2_PACKAGE_OPENOBEX_SYSLOG is not set
# BR2_PACKAGE_OPENOBEX_DUMP is not set
# BR2_PACKAGE_AICCU is not set
# BR2_PACKAGE_UTIL_LINUX_LOGIN_UTILS is not set
# Legacy options removed in 2017.08
# BR2_TARGET_GRUB is not set
# BR2_PACKAGE_SIMICSFS is not set
# BR2_BINUTILS_VERSION_2_26_X is not set
BR2_XTENSA_OVERLAY_DIR=""
BR2_XTENSA_CUSTOM_NAME=""
# BR2_PACKAGE_HOST_MKE2IMG is not set
BR2_TARGET_ROOTFS_EXT2_BLOCKS=0
BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set
# BR2_STRIP_none is not set
# BR2_PACKAGE_BEECRYPT_CPP is not set
# BR2_PACKAGE_SPICE_CLIENT is not set
# BR2_PACKAGE_SPICE_GUI is not set
# BR2_PACKAGE_SPICE_TUNNEL is not set
# BR2_PACKAGE_INPUT_TOOLS is not set
# BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set
# BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set
# BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set
# BR2_GCC_VERSION_4_8_X is not set
# Legacy options removed in 2017.05
# BR2_PACKAGE_SUNXI_MALI_R2P4 is not set
# BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set
# BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set
# BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set
# BR2_PACKAGE_OPENOCD_FT2XXX is not set
# BR2_PACKAGE_KODI_RTMPDUMP is not set
# BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set
# BR2_PACKAGE_PORTMAP is not set
# BR2_BINUTILS_VERSION_2_25_X is not set
# BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set
BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0
# BR2_PACKAGE_SYSTEMD_KDBUS is not set
# BR2_PACKAGE_POLARSSL is not set
# BR2_NBD_CLIENT is not set
# BR2_NBD_SERVER is not set
# BR2_PACKAGE_GMOCK is not set
# BR2_KERNEL_HEADERS_4_8 is not set
# BR2_KERNEL_HEADERS_3_18 is not set
# BR2_GLIBC_VERSION_2_22 is not set
# Legacy options removed in 2017.02
# BR2_PACKAGE_PERL_DB_FILE is not set
# BR2_KERNEL_HEADERS_4_7 is not set
# BR2_KERNEL_HEADERS_4_6 is not set
# BR2_KERNEL_HEADERS_4_5 is not set
# BR2_KERNEL_HEADERS_3_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set
# BR2_UCLIBC_INSTALL_TEST_SUITE is not set
# BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set
# BR2_PACKAGE_MAKEDEVS is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set
# BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set
# BR2_PACKAGE_SNOWBALL_INIT is not set
# BR2_GDB_VERSION_7_9 is not set
# Legacy options removed in 2016.11
# BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set
# BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set
# BR2_PACKAGE_WVSTREAMS is not set
# BR2_PACKAGE_WVDIAL is not set
# BR2_PACKAGE_WEBKITGTK24 is not set
# BR2_PACKAGE_TORSMO is not set
# BR2_PACKAGE_SSTRIP is not set
# BR2_KERNEL_HEADERS_4_3 is not set
# BR2_KERNEL_HEADERS_4_2 is not set
# BR2_PACKAGE_KODI_ADDON_XVDR is not set
# BR2_PACKAGE_IPKG is not set
# BR2_GCC_VERSION_4_7_X is not set
# BR2_BINUTILS_VERSION_2_24_X is not set
# BR2_PACKAGE_WESTON_RPI is not set
# BR2_LINUX_KERNEL_TOOL_CPUPOWER is not set
# BR2_LINUX_KERNEL_TOOL_PERF is not set
# BR2_LINUX_KERNEL_TOOL_SELFTESTS is not set
# BR2_GCC_VERSION_4_8_ARC is not set
# BR2_KERNEL_HEADERS_4_0 is not set
# BR2_KERNEL_HEADERS_3_19 is not set
# BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set
# BR2_PACKAGE_ELEMENTARY is not set
# BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set
# Legacy options removed in 2016.08
# BR2_PACKAGE_EFL_JP2K is not set
# BR2_PACKAGE_SYSTEMD_COMPAT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set
# BR2_PACKAGE_LIBFSLVPUWRAP is not set
# BR2_PACKAGE_LIBFSLPARSER is not set
# BR2_PACKAGE_LIBFSLCODEC is not set
# BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set
# BR2_PTHREADS_OLD is not set
# BR2_BINUTILS_VERSION_2_23_X is not set
# BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set
# BR2_GDB_VERSION_7_8 is not set
# Legacy options removed in 2016.05
# BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set
# BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set
# BR2_x86_i386 is not set
# BR2_PACKAGE_QT5QUICK1 is not set
BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR=""
# BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set
# BR2_KERNEL_HEADERS_3_17 is not set
# BR2_GDB_VERSION_7_7 is not set
# BR2_PACKAGE_FOOMATIC_FILTERS is not set
# BR2_PACKAGE_SAMBA is not set
# BR2_PACKAGE_KODI_WAVPACK is not set
# BR2_PACKAGE_KODI_RSXS is not set
# BR2_PACKAGE_KODI_GOOM is not set
# BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set
# BR2_GCC_VERSION_4_5_X is not set
# BR2_PACKAGE_SQLITE_READLINE is not set
# Legacy options removed in 2016.02
# BR2_PACKAGE_DOVECOT_BZIP2 is not set
# BR2_PACKAGE_DOVECOT_ZLIB is not set
# BR2_PACKAGE_E2FSPROGS_FINDFS is not set
# BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set
# BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set
# BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set
# BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set
# BR2_PACKAGE_CUPS_PDFTOPS is not set
# BR2_KERNEL_HEADERS_3_16 is not set
# BR2_PACKAGE_PYTHON_PYXML is not set
# BR2_ENABLE_SSP is not set
# BR2_PACKAGE_DIRECTFB_CLE266 is not set
# BR2_PACKAGE_DIRECTFB_UNICHROME is not set
# BR2_PACKAGE_LIBELEMENTARY is not set
# BR2_PACKAGE_LIBEINA is not set
# BR2_PACKAGE_LIBEET is not set
# BR2_PACKAGE_LIBEVAS is not set
# BR2_PACKAGE_LIBECORE is not set
# BR2_PACKAGE_LIBEDBUS is not set
# BR2_PACKAGE_LIBEFREET is not set
# BR2_PACKAGE_LIBEIO is not set
# BR2_PACKAGE_LIBEMBRYO is not set
# BR2_PACKAGE_LIBEDJE is not set
# BR2_PACKAGE_LIBETHUMB is not set
# BR2_PACKAGE_INFOZIP is not set
# BR2_BR2_PACKAGE_NODEJS_0_10_X is not set
# BR2_BR2_PACKAGE_NODEJS_0_12_X is not set
# BR2_BR2_PACKAGE_NODEJS_4_X is not set
# Legacy options removed in 2015.11
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set
# BR2_PACKAGE_MEDIA_CTL is not set
# BR2_PACKAGE_SCHIFRA is not set
# BR2_PACKAGE_ZXING is not set
# BR2_PACKAGE_BLACKBOX is not set
# BR2_KERNEL_HEADERS_3_0 is not set
# BR2_KERNEL_HEADERS_3_11 is not set
# BR2_KERNEL_HEADERS_3_13 is not set
# BR2_KERNEL_HEADERS_3_15 is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set
# BR2_PACKAGE_KOBS_NG is not set
# BR2_PACKAGE_SAWMAN is not set
# BR2_PACKAGE_DIVINE is not set
# Legacy options removed in 2015.08
# BR2_PACKAGE_KODI_PVR_ADDONS is not set
# BR2_BINUTILS_VERSION_2_23_2 is not set
# BR2_BINUTILS_VERSION_2_24 is not set
# BR2_BINUTILS_VERSION_2_25 is not set
# BR2_PACKAGE_PERF is not set
# BR2_BINUTILS_VERSION_2_22 is not set
# BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set
# BR2_TARGET_UBOOT_NETWORK is not set
参考: 用韦老师的buildroot D1 SDK 编译 TF卡固件,加入mjpeg-streamer包,和uvc摄像头驱动, 电脑浏览器访问摄像头
https://whycan.com/t_6894.html
楼主 #2 2021-07-17 14:16:09
tigger
已发帖子: 172
Re: 全志D1开发板添加基于中断的 gpio-key 按键驱动
启动日志:
[32]HELLO! BOOT0 is starting!
[35]BOOT0 commit : 27369ab
[37]set pll start
[39]periph0 has been enabled
[42]set pll end
[43][pmu]: bus read error
[46]board init ok
[47]DRAM only have internal ZQ!!
[50]get_pmu_exist() = -1
[53]ddr_efuse_type: 0x0
[56][AUTO DEBUG] single rank and full DQ!
[60]ddr_efuse_type: 0x0
[63][AUTO DEBUG] rank 0 row = 15
[66][AUTO DEBUG] rank 0 bank = 8
[69][AUTO DEBUG] rank 0 page size = 2 KB
[73]DRAM BOOT DRIVE INFO: V0.24
[76]DRAM CLK = 792 MHz
[78]DRAM Type = 3 (2:DDR2,3:DDR3)
[81]DRAMC ZQ value: 0x7b7bfb
[84]DRAM ODT value: 0x42.
[86]ddr_efuse_type: 0x0
[89]DRAM SIZE =512 M
[92]DRAM simple test OK.
[95]dram size =512
[97]card no is 0
[98]sdcard 0 line count 4
[101][mmc]: mmc driver ver 2021-04-2 16:45
[110][mmc]: Wrong media type 0x0
[113][mmc]: ***Try SD card 0***
[121][mmc]: HSSDR52/SDR25 4 bit
[124][mmc]: 50000000 Hz
[127][mmc]: 1903 MB
[129][mmc]: ***SD/MMC 0 init OK!!!***
[182]Loading boot-pkg Succeed(index=0).
[186]Entry_name        = opensbi
[189]Entry_name        = u-boot
[192]Entry_name        = dtb
[195]mmc not para
[196]Jump to second Boot.
OpenSBI v0.6
   ____                    _____ ____ _____
  / __ \                  / ____|  _ \_   _|
 | |  | |_ __   ___ _ __ | (___ | |_) || |
 | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
 | |__| | |_) |  __/ | | |____) | |_) || |_
  \____/| .__/ \___|_| |_|_____/|____/_____|
        |_|
Platform Name          : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs     : 1
Current Hart           : 0
Firmware Base          : 0x40000400
Firmware Size          : 75 KB
Runtime SBI Version    : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0    : 0x0000000040000000-0x000000004001ffff (A)
PMP1    : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2    : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒[00.273][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
[00.279][mmc]: get sdc_type fail and use default host:tm1.
[00.285][mmc]: can't find node "mmc0",will add new node
[00.290][mmc]: fdt err returned <no error>
[00.293][mmc]: Using default timing para
[00.297][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.315][mmc]: card_caps:0x3000000a
[00.318][mmc]: host_caps:0x3000003f
[00.333]set disp.dev2_output_type fail. using defval=0
[00.352]Get bootloader and boot-resource partition number fail!
[00.380]out of usb burn from boot: not need burn key
[01.820]
[01.823][mmc]: MMC Device 2 not found
[01.826][mmc]: mmc 2 not find, so not exit
[    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[    0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #12 Sat Jul 17 11:24:34 CST 2021
[    0.000000] cma: Reserved 8 MiB at 0x000000005f800000
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040200000-0x000000005fffffff]
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000040200000-0x000000005fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000005fffffff]
[    0.000000] On node 0 totalpages: 130560
[    0.000000]   DMA32 zone: 1785 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 130560 pages, LIFO batch:31
[    0.000000] elf_hwcap is 0x20112d
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 128775
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4  init=/sbin/init partitions=ext4 cma=8M  gpt=1 androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(07/02/2021-02:37:09) mbr_offset=1556480 disp_reserve=4096000,0x000000005eb1b280 androidboot.dramsize=512
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000000] Sorting __ex_table...
[    0.000000] Memory: 492748K/522240K available (5098K kernel code, 617K rwdata, 1804K rodata, 176K init, 351K bss, 21300K reserved, 8192K cma-reserved)
[    0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
[    0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
[    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000021] riscv_timer_clockevent depends on broadcast, but no broadcast function available
[    0.000364] Console: colour dummy device 80x25
[    0.000398] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000413] pid_max: default: 32768 minimum: 301
[    0.000608] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.000627] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.002172] ASID allocator initialised with 65536 entries
[    0.002814] devtmpfs: initialized
[    0.014044] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
[    0.014763] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.014790] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[    0.015193] pinctrl core: initialized pinctrl subsystem
[    0.016328] NET: Registered protocol family 16
[    0.017760] DMA: preallocated 256 KiB pool for atomic allocations
[    0.055660] rtc_ccu: sunxi ccu init OK
[    0.062497] clock: sunxi ccu init OK
[    0.063344] clock: sunxi ccu init OK
[    0.087107] iommu: Default domain type: Translated
[    0.087281] sunxi iommu: irq = 80
[    0.088264] SCSI subsystem initialized
[    0.088528] usbcore: registered new interface driver usbfs
[    0.088650] usbcore: registered new interface driver hub
[    0.088722] usbcore: registered new device driver usb
[    0.088870] videodev: Linux video capture interface: v2.00
[    0.090071] pwm module init!
[    0.091497] input: sunxi-keyboard as /devices/virtual/input/input0
[    0.092636] clocksource: Switched to clocksource riscv_clocksource
[    0.103019] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    0.117057] thermal_sys: Registered thermal governor 'step_wise'
[    0.117530] NET: Registered protocol family 2
[    0.118355] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.118402] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.118466] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.118510] TCP: Hash tables configured (established 4096 bind 4096)
[    0.118642] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.118680] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.118898] NET: Registered protocol family 1
[    0.120718] workingset: timestamp_bits=62 max_order=17 bucket_order=0
[    0.129785] NET: Registered protocol family 38
[    0.129851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.129861] io scheduler mq-deadline registered
[    0.129867] io scheduler kyber registered
[    0.130935] [DISP]disp_module_init
[    0.131481] disp 5000000.disp: Adding to iommu group 0
[    0.132087] [DISP] disp_init,line:2385:
[    0.132093] smooth display screen:0 type:1 mode:4
[    0.166745] display_fb_request,fb_id:0
[    0.203906] [DISP]disp_module_init finish
[    0.205399] sunxi_sid_init()506 - insmod ok
[    0.205889] pwm-regulator: supplied by regulator-dummy
[    0.207009] disp_al_manager_apply ouput_type:1
[    0.207220] [DISP] lcd_clk_config,line:731:
[    0.207231] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[    0.207231]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[    0.207461] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[    0.289627] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[    0.290002] uart uart0: get regulator failed
[    0.290028] uart uart0: uart0 supply uart not found, using dummy regulator
[    0.290304] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[    0.290328] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[    0.920567] printk: console [ttyS0] enabled
[    0.925929] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[    0.937291] uart uart1: get regulator failed
[    0.942102] uart uart1: uart1 supply uart not found, using dummy regulator
[    0.950091] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
[    0.959843] misc dump reg init
[    0.973989] loop: module loaded
[    0.978546] libphy: Fixed MDIO Bus: probed
[    0.983152] CAN device driver interface
[    0.988409] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    0.999678] sunxi gmac driver's version: 1.0.0
[    1.004808] gmac-power0: NULL
[    1.008114] gmac-power1: NULL
[    1.011450] gmac-power2: NULL
[    1.015671] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022991] sunxi-ehci: EHCI SUNXI driver
[    1.027958] get ehci1-controller wakeup-source is fail.
[    1.033907] sunxi ehci1-controller don't init wakeup source
[    1.040153] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0007ccac0, 0x:ffffffd00406f000, irq_no:31
[    1.053683] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.066165] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.073441] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.083255] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
[    1.104657] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.113322] hub 1-0:1.0: USB hub found
[    1.117590] hub 1-0:1.0: 1 port detected
[    1.122713] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.129662] sunxi-ohci: OHCI SUNXI driver
[    1.134631] get ohci1-controller wakeup-source is fail.
[    1.140594] sunxi ohci1-controller don't init wakeup source
[    1.146841] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0007cd600
[    1.157270] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.169753] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.177003] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.186797] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
[    1.257519] hub 2-0:1.0: USB hub found
[    1.261786] hub 2-0:1.0: 1 port detected
[    1.267113] usbcore: registered new interface driver uas
[    1.273202] usbcore: registered new interface driver usb-storage
[    1.279994] usbcore: registered new interface driver ums-alauda
[    1.286677] usbcore: registered new interface driver ums-cypress
[    1.293456] usbcore: registered new interface driver ums-datafab
[    1.300229] usbcore: registered new interface driver ums_eneub6250
[    1.307200] usbcore: registered new interface driver ums-freecom
[    1.313977] usbcore: registered new interface driver ums-isd200
[    1.320679] usbcore: registered new interface driver ums-jumpshot
[    1.327555] usbcore: registered new interface driver ums-karma
[    1.334146] usbcore: registered new interface driver ums-onetouch
[    1.341047] usbcore: registered new interface driver ums-realtek
[    1.347833] usbcore: registered new interface driver ums-sddr09
[    1.354520] usbcore: registered new interface driver ums-sddr55
[    1.361205] usbcore: registered new interface driver ums-usbat
[    1.368226] sunxi_gpadc_init,1968, success
[    1.373487] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[    1.385558] sunxi-rtc 7090000.rtc: registered as rtc0
[    1.391320] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:09:55 UTC (595)
[    1.400382] sunxi-rtc 7090000.rtc: sunxi rtc probed
[    1.406194] i2c /dev entries driver
[    1.410223] IR NEC protocol handler initialized
[    1.415298] IR RC5(x/sz) protocol handler initialized
[    1.421647] usbcore: registered new interface driver uvcvideo
[    1.428084] USB Video Class driver (1.1.1)
[    1.432663] sunxi cedar version 1.1
[    1.436815] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.443082] VE: install start!!!
[    1.443082]
[    1.448574] VE: cedar-ve the get irq is 1
[    1.448574]
[    1.454893] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[    1.454893]
[    1.466467] VE: install end!!!
[    1.466467]
[    1.472794] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.484973] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    1.494914] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    1.501107] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    1.507436] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    1.513861] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    1.520283] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    1.526803] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    1.533323] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    1.539843] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    1.546722] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    1.552200] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    1.558807] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.569933] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    1.588661] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.612823] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    1.619128] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    1.629075] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    1.635268] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[    1.641604] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[    1.648029] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    1.654454] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    1.660977] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    1.667495] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    1.674016] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    1.680557] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    1.689333] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.701791] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.712963] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[    1.724664] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.736325] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.749000] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.760681] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    1.769211] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.776103] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.787655] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.794606] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.812745] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.827800] usbcore: registered new interface driver usbhid
[    1.834067] usbhid: USB HID core driver
[    1.840502] NET: Registered protocol family 10
[    1.846849] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.853606] Segment Routing with IPv6
[    1.857800] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.865162] NET: Registered protocol family 17
[    1.870178] NET: Registered protocol family 15
[    1.875147] can: controller area network core (rev 20170425 abi 9)
[    1.882142] NET: Registered protocol family 29
[    1.887126] can: raw protocol (rev 20170425)
[    1.891903] can: broadcast manager protocol (rev 20170425 t)
[    1.898237] can: netlink gateway (rev 20190810) max_hops=1
[    1.905834] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.913416] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.920194] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.929136] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.935917] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    1.947761] HDMI 2.0 driver init start!
[    1.952084] boot_hdmi=false
[    1.955253] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    1.962189] HDMI2.0 module init end
[    1.981247] twi twi2: twi2 supply twi not found, using dummy regulator
[    1.989101] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.000684] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.018020] sunxi_i2c_probe()2262 - [i2c2] probe success
[    2.033716] get ehci0-controller wakeup-source is fail.
[    2.039679] sunxi ehci0-controller don't init wakeup source
[    2.045930] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0007cc700, 0x:ffffffd005222000, irq_no:2e
[    2.059430] [sunxi-ehci0]: Not init ehci0
[    2.064338] get ohci0-controller wakeup-source is fail.
[    2.070305] sunxi ohci0-controller don't init wakeup source
[    2.076550] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0007cd240
[    2.086950] [sunxi-ohci0]: Not init ohci0
[    2.091586] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[    2.103343] mmc0: new high speed SD card at address 00c3
[    2.110325] mmcblk0: mmc0:00c3 E1161 1.86 GiB
[    2.119053] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[    2.128046] clk: Not disabling unused clocks
[    2.132862] alloc_fd: slot 0 not NULL!
[    2.141302] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    2.149591] GPT:223744 != 3898367
[    2.153293] GPT:Alternate GPT header not at the end of the disk.
[    2.160002] GPT:223744 != 3898367
[    2.163707] GPT: Use GNU Parted to correct GPT errors.
[    2.169502]  mmcblk0: p1 p2 p3 p4
[    2.180194] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    2.189311] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
[    2.197396] devtmpfs: mounted
[    2.200884] Freeing unused kernel memory: 176K
[    2.205856] This architecture does not have kernel memory protection.
[    2.213056] Run /sbin/init as init process
[    2.345158] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [    2.569470] udevd[122]: starting version 3.2.9
[    2.587187] random: udevd: uninitialized urandom read (16 bytes read)
[    2.595727] random: udevd: uninitialized urandom read (16 bytes read)
[    2.603370] random: udevd: uninitialized urandom read (16 bytes read)
[    2.640469] udevd[123]: starting eudev-3.2.9
done
Saving random seed: [    4.774512] urandom_read: 2 callbacks suppressed
[    4.774518] random: dd: uninitialized urandom read (512 bytes read)
OK
Starting network: [    5.060667] libphy: 4500000.eth: probed
[    5.065208] sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (4500000.eth-0:00)
udhcpc: started, v1.33.0
udhcpc: sending discover
[    5.372647] hdmi_hpd_sys_config_release
udhcpc: no lease, failing
FAIL
Welcome to Buildroot
buildroot login: root
evtest /dev/input/event 测试:
# evtest /dev/input/event
event0  event1
event0  event1
# evtest /dev/input/event1
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "gpio_keys"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 158 (KEY_BACK)
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    250
    Repeat code 1 (REP_PERIOD)
      Value     33
Properties:
Testing ... (interrupt to exit)
Event: time 625.881369, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 625.881369, -------------- SYN_REPORT ------------
Event: time 626.057362, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 626.057362, -------------- SYN_REPORT ------------
[   31.959779] random: fast init done
Event: time 626.889369, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 626.889369, -------------- SYN_REPORT ------------
Event: time 627.029362, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 627.029362, -------------- SYN_REPORT ------------
Event: time 627.581371, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 627.581371, -------------- SYN_REPORT ------------
Event: time 627.657363, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 627.657363, -------------- SYN_REPORT ------------
Event: time 627.769368, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 627.769368, -------------- SYN_REPORT ------------
Event: time 627.845363, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 627.845363, -------------- SYN_REPORT ------------
[   33.760669] usb1-vbus: disabling
Event: time 627.897374, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 627.897374, -------------- SYN_REPORT ------------
Event: time 628.025361, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 628.025361, -------------- SYN_REPORT ------------
Event: time 628.161365, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 628.161365, -------------- SYN_REPORT ------------
Event: time 628.257361, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 628.257361, -------------- SYN_REPORT ------------
Event: time 628.673365, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 628.673365, -------------- SYN_REPORT ------------
Event: time 628.929331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 628.929331, -------------- SYN_REPORT ------------
Event: time 628.969331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 628.969331, -------------- SYN_REPORT ------------
Event: time 629.009331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.009331, -------------- SYN_REPORT ------------
Event: time 629.049330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.049330, -------------- SYN_REPORT ------------
Event: time 629.089331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.089331, -------------- SYN_REPORT ------------
Event: time 629.129331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.129331, -------------- SYN_REPORT ------------
Event: time 629.169330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.169330, -------------- SYN_REPORT ------------
Event: time 629.209330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.209330, -------------- SYN_REPORT ------------
Event: time 629.249330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.249330, -------------- SYN_REPORT ------------
Event: time 629.289330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.289330, -------------- SYN_REPORT ------------
Event: time 629.329330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.329330, -------------- SYN_REPORT ------------
Event: time 629.369330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.369330, -------------- SYN_REPORT ------------
Event: time 629.409330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.409330, -------------- SYN_REPORT ------------
Event: time 629.449331, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.449331, -------------- SYN_REPORT ------------
Event: time 629.489330, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 629.489330, -------------- SYN_REPORT ------------
Event: time 629.489330, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 630.285364, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 630.285364, -------------- SYN_REPORT ------------
Event: time 630.405364, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 630.405364, -------------- SYN_REPORT ------------
Event: time 630.789367, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 630.789367, -------------- SYN_REPORT ------------
Event: time 630.897363, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 630.897363, -------------- SYN_REPORT ------------
楼主 #3 2021-07-17 14:26:08
tigger
已发帖子: 172
折腾了N种方法, 没有搞定设备树中配置PD10上拉,所以干脆先飞一个电阻到3V3, 否则按键一顿乱飞。
楼主 #4 2021-07-17 14:30:57
tigger
已发帖子: 172
# devmem 0x020000B4
0x00000000
读出 PD组上拉配置。PD10 是 00, 对应的含义是 pull up/down disabled。
给 PD10 写 11 (上拉):
# devmem 0x020000B4 32 0x00100000
读回寄存器配置:
# devmem 0x020000B4
0x00100000
楼主 #5 2021-07-17 14:51:57
tigger
已发帖子: 172
# devmem 0x020000B4
0x00100000
# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      sunxi-keyboard
/dev/input/event1:      gpio_keys
Select the device event number [0-1]: 1
Supported events:
      Value    250
      Value     33
Properties:
Event: time 458.109359, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 458.109359, -------------- SYN_REPORT ------------
Event: time 458.285356, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 458.285356, -------------- SYN_REPORT ------------
Event: time 458.721359, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 458.721359, -------------- SYN_REPORT ------------
Event: time 458.873352, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 458.873352, -------------- SYN_REPORT ------------
Event: time 459.153356, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 459.153356, -------------- SYN_REPORT ------------
Event: time 459.409324, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 459.409324, -------------- SYN_REPORT ------------
Event: time 459.449323, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 459.449323, -------------- SYN_REPORT ------------
Event: time 459.489323, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 459.489323, -------------- SYN_REPORT ------------
Event: time 459.529323, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
Event: time 459.529323, -------------- SYN_REPORT ------------
Event: time 459.569322, type 1 (EV_KEY), code 158 (KEY_BACK), value 2
虽然设备树没有配置上拉, 但是有 devmem助攻,还是挺好用的。
楼主 #6 2021-07-17 15:14:20
tigger
已发帖子: 172
dts这样配置:
        key_pins_pd10: key@0 {
                pins = "PD10";
                function = "gpio_in";
                drive-strength = <30>;
                bias-pull-up;
                power-source = <3300>;
        gpio_keys {
                compatible = "gpio-keys";
                pinctrl-names = "default";
                pinctrl-0 = <&key_pins_pd10>;
                #address-cells = <1>;
                #size-cells = <0>;
                autorepeat;
                button@0 {
                        label = "Key back";
                        linux,code = <KEY_BACK>;
                        gpios = <&pio 3 10 GPIO_ACTIVE_LOW>; /* PD10 */
完整board.dts文件:
 * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
 * fpga support.
/dts-v1/;
#include "sun20iw1p1.dtsi"
        compatible = "allwinner,d1", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
        aliases {
                dsp0 = &dsp0;
                dsp0_gpio_int= &dsp0_gpio_int;
        dsp0: dsp0 {
                compatible = "allwinner,sun20iw1-dsp";
        dsp0_gpio_int: dsp0_gpio_int {
                compatible = "allwinner,sun20iw1-dsp-gpio-int";
                pin-group = "PB", "PC", "PD", "PE";
                status = "disabled";
        reg_vdd_cpu: vdd-cpu {
                compatible = "sunxi-pwm-regulator";
                pwms = <&pwm 0 5000 0>;
                regulator-name = "vdd_cpu";
                regulator-min-microvolt = <810000>;
                regulator-max-microvolt = <1160000>;
                regulator-ramp-delay = <25>;
                regulator-always-on;
                regulator-boot-on;
        reg_usb1_vbus: usb1-vbus {
                regulator-name = "usb1-vbus";
                regulator-min-microvolt = <5000000>;
                regulator-max-microvolt = <5000000>;
                regulator-enable-ramp-delay = <1000>;
                gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
                enable-active-high;
        key_pins_pd10: key0@0 {
                allwinner,pins = "PD10";
                allwinner,function = "gpio_in";
                allwinner,muxsel = <14>;
                allwinner,drive = <3>;
                allwinner,pull = <1>;
                pins = "PD10";
                bias-pull-up;
                pins = "PD10";
                bias-pull-up;
        gpio_keys {
                #size-cells = <0>;
                autorepeat;
                button@0 {
                        label = "Key back";
&CPU0 {
        cpu-supply = <&reg_vdd_cpu>;
&pio {
        sdc0_pins_a: sdc0@0 {
                allwinner,pins = "PF0", "PF1", "PF2",
                                 "PF3", "PF4", "PF5";
                allwinner,function = "sdc0";
                allwinner,muxsel = <2>;
                function = "sdc0";
                bias-pull-up;
        sdc0_pins_b: sdc0@1 {
                function = "sdc0";
                bias-pull-up;
                power-source = <1800>;
        sdc0_pins_c: sdc0@2 {
        /* TODO: add jtag pin */
        sdc0_pins_d: sdc0@3 {
                pins = "PF2", "PF4";
                function = "uart0";
                drive-strength = <10>;
                bias-pull-up;
        sdc0_pins_e: sdc0@4 {
                pins = "PF0", "PF1", "PF3",
                        "PF5";
                function = "jtag";
                bias-pull-up;
        sdc1_pins_a: sdc1@0 {
                pins = "PG0", "PG1", "PG2",
                       "PG3", "PG4", "PG5";
                function = "sdc1";
                bias-pull-up;
        sdc1_pins_b: sdc1@1 {
        sdc2_pins_a: sdc2@0 {
                allwinner,pins = "PC2", "PC3", "PC4",
                                 "PC5", "PC6", "PC7";
                allwinner,function = "sdc2";
                allwinner,muxsel = <3>;
                function = "sdc2";
                bias-pull-up;
        sdc2_pins_b: sdc2@1 {
        wlan_pins_a:wlan@0 {
                pins = "PG11";
                function = "clk_fanout1";
        uart0_pins_a: uart0_pins@0 {  /* For nezha board */
                pins = "PB8", "PB9";
                function = "uart0";
                bias-pull-up;
        uart0_pins_b: uart0_pins@1 {  /* For nezha board */
        uart1_pins_a: uart1_pins@0 {  /* For EVB1 board */
                pins = "PG6", "PG7", "PG8", "PG9";
                function = "uart1";
                bias-pull-up;
        uart1_pins_b: uart1_pins {  /* For EVB1 board */
        uart2_pins_a: uart2_pins@0 {  /* For EVB1 board */
                pins = "PC0", "PC1";
                function = "uart2";
                bias-pull-up;
        uart2_pins_b: uart2_pins@1 {  /* For EVB1 board */
        uart3_pins_a: uart3_pins@0 {  /* For EVB1 board */
                pins = "PD10", "PD11";
                function = "uart3";
                muxsel = <5>;
                bias-pull-up;
        twi0_pins_a: twi0@0 {
                pins = "PB10", "PB11";  /*sck sda*/
                function = "twi0";
        twi0_pins_b: twi0@1 {
        twi1_pins_a: twi1@0 {
                pins = "PB4", "PB5";
                function = "twi1";
        twi1_pins_b: twi1@1 {
        twi2_pins_a: twi2@0 {
                pins = "PB0", "PB1";
                function = "twi2";
        twi2_pins_b: twi2@1 {
        twi3_pins_a: twi3@0 {
                pins = "PB6", "PB7";
                function = "twi3";
        twi3_pins_b: twi3@1 {
        gmac_pins_a: gmac@0 {
                pins = "PE0", "PE1", "PE2", "PE3",
                       "PE4", "PE5", "PE6", "PE7",
                       "PE8", "PE9", "PE10", "PE11",
                       "PE12", "PE13", "PE14", "PE15";
                function = "gmac0";
        gmac_pins_b: gmac@1 {
        dmic_pins_a: dmic@0 {
                /* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
                pins = "PE17", "PB11", "PB10", "PD17";
                function = "dmic";
                drive-strength = <20>;
                bias-disable;
        dmic_pins_b: dmic@1 {
                function = "io_disabled";
                bias-disable;
        daudio0_pins_a: daudio0@0 {
                pins = "PE17", "PE16", "PE15", "PE14", "PE13";
                function = "i2s0";
                bias-disable;
        daudio0_pins_b: daudio0_sleep@0 {
                bias-disable;
        daudio1_pins_a: daudio1@0 {
                pins = "PG11", "PG12", "PG13", "PG14", "PG15";
                function = "i2s1";
                bias-disable;
        daudio1_pins_b: daudio1_sleep@0 {
                bias-disable;
        daudio2_pins_a: daudio2@0 {
                /* I2S_PIN: MCLK, BCLK, LRCK */
                pins = "PB7", "PB5", "PB6";
                function = "i2s2";
                bias-disable;
        daudio2_pins_b: daudio2@1 {
                /* I2S_PIN: DOUT0 */
                pins = "PB4";
                function = "i2s2_dout";
                bias-disable;
        daudio2_pins_c: daudio2@2 {
                /* I2S_PIN: DIN0 */
                pins = "PB3";
                function = "i2s2_din";
                bias-disable;
        daudio2_pins_d: daudio2_sleep@0 {
                pins = "PB7", "PB5", "PB6", "PB4", "PB3";
                bias-disable;
        spdif_pins_a: spdif@0 {
                /* SPDIF_PIN: SPDIF_OUT */
                pins = "PB0";
                function = "spdif";
                bias-disable;
        spdif_pins_b: spdif_sleep@0 {
                pins = "PB0";
                bias-disable;
        spi0_pins_a: spi0@0 {
                pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
                function = "spi0";
                muxsel = <2>;
        spi0_pins_b: spi0@1 {
                pins = "PC3", "PC7", "PC6";
                function = "spi0";
                muxsel = <2>;
                bias-pull-up;   /* only CS should be pulled up */
        spi0_pins_c: spi0@2 {
                pins = "PC2", "PC3", "PC4", "PC5","PC6", "PC7";
                muxsel = <0>;
        spi1_pins_a: spi1@0 {
                pins = "PD11", "PD12", "PD13","PD14", "PD15"; /*clk mosi miso hold wp*/
                function = "spi1";
        spi1_pins_b: spi1@1 {
                pins = "PD10";
                function = "spi1";
                bias-pull-up;   // only CS should be pulled up
        spi1_pins_c: spi1@2 {
                pins = "PD10", "PD11", "PD12", "PD13","PD14", "PD15";
        ledc_pins_a: ledc@0 {
                pins = "PC0";
                function = "ledc";
        ledc_pins_b: ledc@1 {
                pins = "PC0";
        pwm0_pin_a: pwm0@0 {
                pins = "PD16";
                function = "pwm0";
                bias-pull-up;
        pwm0_pin_b: pwm0@1 {
                pins = "PD16";
                bias-disable;
        pwm2_pin_a: pwm2@0 {
                pins = "PD18";
                function = "pwm2";
                bias-pull-up;
        pwm2_pin_b: pwm2@1 {
                pins = "PD18";
        pwm7_pin_a: pwm7@0 {
                pins = "PD22";
                function = "pwm7";
                bias-pull-up;
        pwm7_pin_b: pwm7@1 {
                pins = "PD22";
        s_cir0_pins_a: s_cir@0 {
                pins = "PB12";
                function = "ir";
                bias-pull-up;
        s_cir0_pins_b: s_cir@1 {
                pins = "PB12";
        ir1_pins_a: ir1@0 {
                pins = "PB0";
                function = "ir";
                bias-pull-up;
        ir1_pins_b: ir1@1 {
                pins = "PB0";
&uart0 {
        pinctrl-0 = <&uart0_pins_a>;
        pinctrl-1 = <&uart0_pins_b>;
&uart1 {
        pinctrl-0 = <&uart1_pins_a>;
        pinctrl-1 = <&uart1_pins_b>;
&uart2 {
        pinctrl-0 = <&uart2_pins_a>;
        pinctrl-1 = <&uart2_pins_b>;
&uart3 {
        /*compatible = "allwinner,sun20iw1-dsp-uart";*/
        pinctrl-0 = <&uart3_pins_a>;
        pinctrl-1 = <&uart3_pins_a>;
&soc {
        card0_boot_para@2 {
                 * Avoid dtc compiling warnings.
                 * @TODO: Developer should modify this to the actual value
                reg = <0x0 0x2 0x0 0x0>;
                device_type = "card0_boot_para";
                card_ctrl = <0x0>;
                card_high_speed = <0x1>;
                card_line = <0x4>;
                pinctrl-0 = <&sdc0_pins_a>;
        card2_boot_para@3 {
                reg = <0x0 0x3 0x0 0x0>;
                device_type = "card2_boot_para";
                card_ctrl = <0x2>;
                card_line = <0x4>;
                pinctrl-0 = <&sdc2_pins_a>;
                /*pinctrl-0 = <&sdc0_pins_a>;*/
                /*sdc_ex_dly_used = <0x2>;*/
                sdc_io_1v8 = <0x1>;
                /*sdc_type = "tm4";*/
                sdc_tm4_hs200_max_freq = <150>;
                sdc_tm4_hs400_max_freq = <100>;
                sdc_ex_dly_used = <2>;
                /*sdc_tm4_win_th = <8>;*/
                /*sdc_dis_host_caps = <0x180>;*/
        rfkill: rfkill@0 {
                compatible    = "allwinner,sunxi-rfkill";
                chip_en;
                power_en;
                status        = "okay";
                wlan: wlan@0 {
                        compatible    = "allwinner,sunxi-wlan";
                        pinctrl-0 = <&wlan_pins_a>;
                        clock-names = "32k-fanout1";
                        clocks = <&ccu CLK_FANOUT1_OUT>;
                        wlan_busnum    = <0x1>;
                        wlan_regon    = <&pio PG 12 GPIO_ACTIVE_HIGH>;
                        wlan_hostwake  = <&pio PG 10 GPIO_ACTIVE_HIGH>;
                        /*wlan_power    = "VCC-3V3";*/
                        /*wlan_power_vol = <3300000>;*/
                        /*interrupt-parent = <&pio>;
                        interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
                        wakeup-source;
                bt: bt@0 {
                        compatible    = "allwinner,sunxi-bt";
                        /*bt_power_num = <0x01>;*/
                        /*bt_power      = "axp803-dldo1";*/
                        /*bt_io_regulator = "axp803-dldo1";*/
                        /*bt_io_vol = <3300000>;*/
                        /*bt_power_vol = <330000>;*/
                        bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
                        status        = "okay";
        btlpm: btlpm@0 {
                compatible  = "allwinner,sunxi-btlpm";
                uart_index  = <0x1>;
                bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
                bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
                status      = "okay";
        addr_mgt: addr_mgt@0 {
                compatible     = "allwinner,sunxi-addr_mgt";
                type_addr_wifi = <0x0>;
                type_addr_bt   = <0x0>;
                type_addr_eth  = <0x0>;
                status         = "okay";
&sdc2 {
        non-removable;
        bus-width = <4>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        no-sdio;
        no-sd;
        ctl-spec-caps = <0x308>;
        cap-mmc-highspeed;
        sunxi-power-save-mode;
        sunxi-dis-signal-vol-sw;
        mmc-bootpart-noacc;
        max-frequency = <150000000>;
        /*vmmc-supply = <&reg_dcdc1>;*/
        /*emmc io vol 3.3v*/
        /*vqmmc-supply = <&reg_aldo1>;*/
        /*emmc io vol 1.8v*/
        /*vqmmc-supply = <&reg_eldo1>;*/
&sdc0 {
        bus-width = <4>;
        cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
        /*non-removable;*/
        /*broken-cd;*/
        cd-inverted;
        /*data3-detect;*/
        /*card-pwr-gpios = <&pio PH 14 1 1 2 0xffffffff>;*/
        cd-used-24M;
        cap-sd-highspeed;
        /*sd-uhs-sdr50;*/
        /*sd-uhs-ddr50;*/
        /*sd-uhs-sdr104;*/
        no-sdio;
        no-mmc;
        /*sunxi-dis-signal-vol-sw;*/
        ctl-spec-caps = <0x8>;
        /*vqmmc33sw-supply = <&reg_dcdc1>;*/
        /*vdmmc33sw-supply = <&reg_dcdc1>;*/
        /*vqmmc18sw-supply = <&reg_eldo1>;*/
        /*vdmmc18sw-supply = <&reg_eldo1>;*/
&sdc1 {
        bus-width = <4>;
        no-mmc;
        no-sd;
        cap-sd-highspeed;
        /*sd-uhs-sdr12*/
        /*sd-uhs-sdr25;*/
        /*sd-uhs-sdr50;*/
        /*sd-uhs-ddr50;*/
        /*sd-uhs-sdr104;*/
        /*sunxi-power-save-mode;*/
        cap-sdio-irq;
        keep-power-in-suspend;
        ignore-pm-notify;
tvd configuration
used                   (create device, 0: do not create device, 1: create device)
agc_auto_enable        (0: agc manual mode,agc_manual_value is valid; 1: agc auto mode)
agc_manual_value       (agc manual value, default value is 64)
cagc_enable            (cagc        0: disable, 1: enable)
fliter_used            (3d fliter   0: disable, 1: enable)
support two PMU power  (tvd_power0, tvd_power1)
support two GPIO power (tvd_gpio0, tvd_gpio1)
NOTICE: If tvd need pmu power or gpio power,params need be configured under [tvd]
tvd_sw                 (the switch of all tvd driver.)
tvd_interface          (0: cvbs, 1: ypbpr,)
tvd_format             (0:TVD_PL_YUV420 , 1: MB_YUV420, 2: TVD_PL_YUV422)
tvd_system             (0:ntsc, 1:pal)
tvd_row                (total row number in multi channel mode 1-2)
tvd_column             (total column number in multi channel mode 1-2)
tvd_channelx_en        (0:disable, 1~4:position in multi channel mode,In single channel
                       mode,mean enable)
tvd_row*tvd_column is the total tvd channel number to be used in multichannel mode
|         1          |         2          |
|         3          |         4          |
&tvd {
        tvd_sw          = <1>;
        tvd_interface   = <0>;
        tvd_format      = <0>;
        tvd_system      = <1>;
        tvd_row         = <1>;
        tvd_column      = <1>;
        tvd_channel0_en = <1>;
        tvd_channel1_en = <0>;
        tvd_channel2_en = <0>;
        tvd_channel3_en = <0>;
        /*tvd_gpio0 = <&pio PD 22 GPIO_ACTIVE_HIGH>;*/
        /*tvd_gpio1 = <&pio PD 23 GPIO_ACTIVE_HIGH>;*/
        /*tvd_gpio2 = <&pio PD 24 GPIO_ACTIVE_HIGH>;*/
        /*      dc1sw-supply = <&reg_dc1sw>;*/
        /*      eldo3-supply = <&reg_eldo3>;*/
        /*tvd_power0      = "dc1sw"*/
        /*tvd_power1      = "eldo3"*/
&tvd0 {
        used                    = <1>;
        agc_auto_enable         = <1>;
        agc_manual_value        = <64>;
        cagc_enable             = <1>;
        fliter_used             = <1>;
/* Audio Driver modules */
&sunxi_rpaf_dsp0 {
/* if audiocodec is used, sdc0 and uart0 should be closed to enable PA. */
&codec {
        /* MIC and headphone gain setting */
        mic1gain        = <0x13>;
        mic2gain        = <0x13>;
        mic3gain        = <0x13>;
        /* ADC/DAC DRC/HPF func enabled */
        /* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */
        adcdrc_cfg      = <0x0>;
        adchpf_cfg      = <0x1>;
        dacdrc_cfg      = <0x0>;
        dachpf_cfg      = <0x0>;
        /* Volume about */
        digital_vol     = <0x00>;
        lineout_vol     = <0x1a>;
        headphonegain   = <0x03>;
        /* Pa enabled about */
        pa_level        = <0x01>;
        pa_pwr_level    = <0x01>;
        pa_msleep_time  = <0x78>;
        /* gpio-spk     = <&pio PF 2 GPIO_ACTIVE_HIGH>; */
        /* gpio-spk-pwr = <&pio PF 4 GPIO_ACTIVE_HIGH>; */
        /* regulator about */
        /* avcc-supply  = <&reg_aldo1>; */
        /* hpvcc-supply = <&reg_eldo1>; */
&sndcodec {
        hp_detect_case  = <0x01>;
        jack_enable     = <0x01>;
&dummy_cpudai {
        /* CMA config about */
        playback_cma    = <128>;
        capture_cma     = <256>;
&dmic {
        pinctrl-names   = "default","sleep";
        pinctrl-0       = <&dmic_pins_a>;
        pinctrl-1       = <&dmic_pins_b>;
&sounddmic {
&dmic_codec {
 * pcm_lrck_period      16/32/64/128/256
 *                      (set 0x20 for HDMI audio out)
 * slot_width_select    16bits/20bits/24bits/32bits
 * frametype            0 --> short frame = 1 clock width;
 *                      1 --> long frame = 2 clock width;
 * tdm_config           0 --> pcm
 *                      1 --> i2s
 *                      (set 0x01 for HDMI audio out)
 * mclk_div             0 --> not output
 *                      1/2/4/6/8/12/16/24/32/48/64/96/128/176/192
 *                      (set mclk as external codec clk source, freq is pll_audio/mclk_div)
 * pinctrl_used         0 --> I2S/PCM use for internal (e.g. HDMI)
 *                      1 --> I2S/PCM use for external audio
 * daudio_type:         0 --> external audio type
 *                      1 --> HDMI audio type
&daudio0 {
        mclk_div        = <0x01>;
        frametype       = <0x00>;
        tdm_config      = <0x01>;
        sign_extend     = <0x00>;
        msb_lsb_first   = <0x00>;
        pcm_lrck_period = <0x80>;
        slot_width_select = <0x20>;
        pinctrl-names   = "default", "sleep";
        pinctrl-0       = <&daudio0_pins_a>;
        pinctrl-1       = <&daudio0_pins_b>;
        pinctrl_used    = <0x0>;
 * simple-audio-card,name       name of sound card, e.g.
 *                              "snddaudio0" --> use for external audio
 *                              "sndhdmi" --> use for HDMI audio
 * sound-dai                    "snd-soc-dummy" --> use for I2S
 *                              "hdmiaudio" --> use for HDMI audio
 *                              "ac108" --> use for external audio of ac108
&sounddaudio0 {
        /* simple-audio-card,format = "i2s"; */
        /* simple-audio-card,frame-master = <&daudio0_master>; */
        /* simple-audio-card,bitclock-master = <&daudio0_master>; */
        /* simple-audio-card,bitclock-inversion; */
        /* simple-audio-card,frame-inversion; */
        daudio0_master: simple-audio-card,codec {
                /* sound-dai = <&ac108>; */
&daudio1 {
        mclk_div        = <0x01>;
        frametype       = <0x00>;
        pinctrl-0       = <&daudio1_pins_a>;
        pinctrl-1       = <&daudio1_pins_b>;
&sounddaudio1 {
        daudio1_master: simple-audio-card,codec {
&daudio2 {
        mclk_div        = <0x00>;
        frametype       = <0x00>;
        tx_data_mode    = <0x00>;
        rx_data_mode    = <0x00>;
        pcm_lrck_period = <0x20>;
        asrc_function_en  = <0x00>;
        /*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
        /*pinctrl-1       = <&daudio2_pins_d>;*/
        /* HDMI audio, no need pin */
        pinctrl-0;
        pinctrl-1;
        daudio_type     = <0x1>;
/* if HDMI audio is used, daudio2 should be enable. */
&hdmiaudio {
&sounddaudio2 {
        simple-audio-card,name = "sndhdmi";
        daudio2_master: simple-audio-card,codec {
                sound-dai = <&hdmiaudio>;
&spdif {
        pinctrl-0       = <&spdif_pins_a>;
        pinctrl-1       = <&spdif_pins_b>;
&soundspdif {
 *usb_port_type: usb mode. 0-device, 1-host, 2-otg.
 *usb_detect_type: usb hotplug detect mode. 0-none, 1-vbus/id detect, 2-id/dpdm detect.
 *usb_detect_mode: 0-thread scan, 1-id gpio interrupt.
 *usb_id_gpio: gpio for id detect.
 *usb_det_vbus_gpio: gpio for id detect. gpio or "axp_ctrl";
 *usb_wakeup_suspend:0-SUPER_STANDBY, 1-USB_STANDBY.
&usbc0 {
        device_type = "usbc0";
        usb_port_type = <0x2>;
        usb_detect_type = <0x1>;
        usb_detect_mode = <0>;
        usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
        enable-active-high;
        usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
        usb_wakeup_suspend = <0>;
        usb_serial_unique = <0>;
        usb_serial_number = "20080411";
        rndis_wceis = <1>;
&ehci0 {
        drvvbus-supply = <&reg_usb1_vbus>;
&ohci0 {
&usbc1 {
        device_type = "usbc1";
        usb_regulator_io = "nocare";
&ehci1 {
&ohci1 {
&twi0 {
        clock-frequency = <400000>;
        pinctrl-0 = <&twi0_pins_a>;
        pinctrl-1 = <&twi0_pins_b>;
        eeprom@50 {
                compatible = "atmel,24c16";
                reg = <0x50>;
&twi1 {
        pinctrl-0 = <&twi1_pins_a>;
        pinctrl-1 = <&twi1_pins_b>;
&twi2 {
        pinctrl-0 = <&twi2_pins_a>;
        pinctrl-1 = <&twi2_pins_b>;
        dmas = <&dma 45>, <&dma 45>;
        dma-names = "tx", "rx";
        /* pcf8574-usage:
         * only use gpio0~7, 0 means PP0.
         * pin set:
         * gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>;
         * interrupt set:
         * interrupt-parent = <&pcf8574>;
         * interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
        pcf8574: gpio@38 {
                compatible = "nxp,pcf8574";
                reg = <0x38>;
                gpio_base = <2020>;
                gpio-controller;
                #gpio-cells = <2>;
                interrupt-controller;
                #interrupt-cells = <2>;
                interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>;
        ctp@14 {
                compatible = "allwinner,goodix";
                device_type = "ctp";
                reg = <0x14>;
                ctp_name = "gt9xxnew_ts";
                ctp_twi_id = <0x2>;
                ctp_twi_addr = <0x14>;
                ctp_screen_max_x = <0x320>;
                ctp_screen_max_y = <0x500>;
                ctp_revert_x_flag = <0x0>;
                ctp_revert_y_flag = <0x0>;
                ctp_exchange_x_y_flag = <0x0>;
                ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
                ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
&twi3 {
        pinctrl-0 = <&twi3_pins_a>;
        pinctrl-1 = <&twi3_pins_b>;
&gmac0 {
        phy-mode = "rgmii";
        use_ephy25m = <1>;
        pinctrl-0 = <&gmac_pins_a>;
        pinctrl-1 = <&gmac_pins_b>;
        phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
        tx-delay = <3>; /*2~4*/
        rx-delay = <0>;
&spi0 {
        clock-frequency = <100000000>;
        pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
        pinctrl-1 = <&spi0_pins_c>;
        /*spi-supply = <&reg_dcdc1>;*/
        spi_slave_mode = <0>;
        spi0_cs_number = <1>;
        spi0_cs_bitmap = <1>;
        spi-nand@0 {
                compatible = "spi-nand";
                spi-max-frequency=<0x5F5E100>;
                reg = <0x0>;
                spi-rx-bus-width=<0x04>;
                spi-tx-bus-width=<0x04>;
                status="disabled";
&spi1 {
        pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
        pinctrl-1 = <&spi1_pins_c>;
        spi_board1@0 {
                device_type = "spi_board1";
                compatible = "rohm,dh2228fv";
                spi-max-frequency = <0x5f5e100>;
                reg = <0x0>;
                spi-rx-bus-width = <0x4>;
                spi-tx-bus-width = <0x4>;
&ledc {
        pinctrl-0 = <&ledc_pins_a>;
        pinctrl-1 = <&ledc_pins_b>;
        led_count = <12>;
        output_mode = "GRB";
        reset_ns = <84>;
        t1h_ns = <800>;
        t1l_ns = <320>;
        t0h_ns = <300>;
        t0l_ns = <800>;
        wait_time0_ns = <84>;
        wait_time1_ns = <84>;
        wait_data_time_ns = <600000>;
        status  = "okay";
&keyboard0 {
        key0 = <210 0x160>;
        wakeup-source;
disp init configuration
disp_mode             (0:screen0<screen0,fb0>)
screenx_output_type   (0:none; 1:lcd; 2:tv; 3:hdmi;5:vdpo)
screenx_output_mode   (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50)
                      (5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60)
screenx_output_format (for hdmi, 0:RGB 1:yuv444 2:yuv422 3:yuv420)
screenx_output_bits   (for hdmi, 0:8bit 1:10bit 2:12bit 2:16bit)
screenx_output_eotf   (for hdmi, 0:reserve 4:SDR 16:HDR10 18:HLG)
screenx_output_cs     (for hdmi, 0:undefined  257:BT709 260:BT601  263:BT2020)
screenx_output_dvi_hdmi (for hdmi, 0:undefined 1:dvi mode 2:hdmi mode)
screen0_output_range   (for hdmi, 0:default 1:full 2:limited)
screen0_output_scan    (for hdmi, 0:no data 1:overscan 2:underscan)
screen0_output_aspect_ratio  (for hdmi, 8-same as original picture 9-4:3 10-16:9 11-14:9)
fbx format            (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444)
fbx pixel sequence    (0:ARGB 1:BGRA 2:ABGR 3:RGBA)
fb0_scaler_mode_enable(scaler mode enable, used FE)
fbx_width,fbx_height  (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0)
lcdx_backlight        (lcd init backlight,the range:[0,256],default:197
lcdx_yy               (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50)
lcd0_contrast         (LCD contrast, 0~100)
lcd0_saturation       (LCD saturation, 0~100)
lcd0_hue              (LCD hue, 0~100)
framebuffer software rotation setting:
disp_rotation_used:   (0:disable; 1:enable,you must set fbX_width to lcd_y,
set fbX_height to lcd_x)
degreeX:              (X:screen index; 0:0 degree; 1:90 degree; 3:270 degree)
degreeX_Y:            (X:screen index; Y:layer index 0~15; 0:0 degree; 1:90 degree; 3:270 degree)
devX_output_type : config output type in bootGUI framework in UBOOT-2018.
                                   (0:none; 1:lcd; 2:tv; 4:hdmi;)
devX_output_mode : config output resolution(see include/video/sunxi_display2.h) of bootGUI framework in UBOOT-2018
devX_screen_id   : config display index of bootGUI framework in UBOOT-2018
devX_do_hpd      : whether do hpd detectation or not in UBOOT-2018
chn_cfg_mode     : Hardware DE channel allocation config. 0:single display with 6
                                   channel, 1:dual display with 4 channel in main display and 2 channel in second
                   display, 2:dual display with 3 channel in main display and 3 channel in second
                   in display.
&disp {
        disp_init_enable         = <1>;
        disp_mode                = <0>;
        screen0_output_type      = <1>;
        screen0_output_mode      = <4>;
        screen1_output_type      = <3>;
        screen1_output_mode      = <10>;
        screen1_output_format    = <0>;
        screen1_output_bits      = <0>;
        screen1_output_eotf      = <4>;
        screen1_output_cs        = <257>;
        screen1_output_dvi_hdmi  = <2>;
        screen1_output_range     = <2>;
        screen1_output_scan      = <0>;
        screen1_output_aspect_ratio = <8>;
        dev0_output_type         = <1>;
        dev0_output_mode         = <4>;
        dev0_screen_id           = <0>;
        dev0_do_hpd              = <0>;
        dev1_output_type         = <4>;
        dev1_output_mode         = <10>;
        dev1_screen_id           = <1>;
        dev1_do_hpd              = <1>;
        def_output_dev           = <0>;
        hdmi_mode_check          = <1>;
        fb0_format               = <0>;
        fb0_width                = <0>;
        fb0_height               = <0>;
        fb1_format               = <0>;
        fb1_width                = <0>;
        fb1_height               = <0>;
        chn_cfg_mode             = <1>;
        disp_para_zone           = <1>;
        /*VCC-LCD*/
        /*VCC-DSI*/
        /*VCC-PD*/
/*      dcdc1-supply = <&reg_dcdc1>;*/
;lcd0 configuration
;lcd_if:               0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_hv_if             0:Parallel RGB; 8:Serial RGB; 10:Dummy RGB; 11: RGB Dummy;12:CCIR656
;lcd_hv_clk_phase      0:0 degree;1:90 degree;2:180 degree;3:270 degree
;lcd_hv_sync_polarity  0:vs low,hs low; 1:vs high,hslow; 2:vs low,hs high; 3:vs high,hs high
;lcd_hv_syuv_seq       0:YUYV; 1:YVYU; 2:UYVY; 3:VYUY
;lcd_cpu_if            0:18bit/1 cycle parallel(RGB666); 4:16bit/1cycle parallel (RGB565)
;                      6:18bit/3 cycle parallel(RGB666); 7:16bit/2cycle parallel (RGB565)
;lcd_cpu_te            0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_dsi_if            0:video mode; 1: Command mode; 2:video burst mode
;lcd_dsi_te            0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_x:                lcd horizontal resolution
;lcd_y:                lcd vertical resolution
;lcd_width:            width of lcd in mm
;lcd_height:           height of lcd in mm
;lcd_dclk_freq:        in MHZ unit
;lcd_pwm_freq:         in HZ unit
;lcd_pwm_pol:          lcd backlight PWM polarity
;lcd_pwm_max_limit     lcd backlight PWM max limit(<=255)
;lcd_hbp:              hsync back porch(pixel) + hsync plus width(pixel);
;lcd_ht:               hsync total cycle(pixel)
;lcd_vbp:              vsync back porch(line) + vysnc plus width(line)
;lcd_vt:               vysnc total cycle(line)
;lcd_hspw:             hsync plus width(pixel)
;lcd_vspw:             vysnc plus width(pixel)
;lcd_lvds_if:          0:single link;  1:dual link
;lcd_lvds_colordepth:  0:8bit; 1:6bit
;lcd_lvds_mode:        0:NS mode; 1:JEIDA mode
;lcd_frm:              0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase:         0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
;                      8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en          lcd gamma correction enable
;lcd_bright_curve_en   lcd bright curve correction enable
;lcd_cmap_en           lcd color map function enable
;deu_mode              0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep:         Smart Backlight parameter, lcd gamma vale * 10;
;                      decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color           90:normal lcd screen 65:retina lcd screen(9.7inch)
;Pin setting for special function ie.LVDS, RGB data or vsync
;   name(donot care) = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for gpio:
;   lcd_gpio_X     = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for backlight enable pin
;   lcd_bl_en     = port:PD12<pin function><pull up or pull down><drive ability><output level>
;fsync setting, pulse to csi
;lcd_fsync_en          (0:disable fsync,1:enable)
;lcd_fsync_act_time    (active time of fsync, unit:pixel)
;lcd_fsync_dis_time    (disactive time of fsync, unit:pixel)
;lcd_fsync_pol         (0:positive;1:negative)
;gpio config: <&pio for cpu or &r_pio for cpus, port, port num, pio function,
pull up or pull down(default 0), driver level(default 1), data>
;For dual link lvds: use lvds2link_pins_a  and lvds2link_pins_b instead
;For rgb24: use rgb24_pins_a  and rgb24_pins_b instead
;For lvds1: use lvds1_pins_a  and lvds1_pins_b instead
;For lvds0: use lvds0_pins_a  and lvds0_pins_b instead
&lcd0 {
        lcd_used            = <1>;
        lcd_driver_name     = "tft08006";
        lcd_backlight       = <100>;
        lcd_if              = <4>;
        lcd_x               = <800>;
        lcd_y               = <1280>;
        lcd_width           = <52>;
        lcd_height          = <52>;
        lcd_dclk_freq       = <70>;
        lcd_pwm_used        = <1>;
        lcd_pwm_ch          = <2>;
        lcd_pwm_freq        = <1000>;
        lcd_pwm_pol         = <0>;
        lcd_pwm_max_limit   = <255>;
        lcd_hbp             = <32>;
        lcd_ht              = <868>;
        lcd_hspw            = <4>;
        lcd_vbp             = <12>;
        lcd_vt              = <1311>;
        lcd_vspw            = <4>;
        lcd_dsi_if          = <0>;
        lcd_dsi_lane        = <4>;
        lcd_lvds_if         = <0>;
        lcd_lvds_colordepth = <0>;
        lcd_lvds_mode       = <0>;
        lcd_frm             = <0>;
        lcd_hv_clk_phase    = <0>;
        lcd_hv_sync_polarity= <0>;
        lcd_io_phase        = <0x0000>;
        lcd_gamma_en        = <0>;
        lcd_bright_curve_en = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        lcd_fsync_act_time  = <1000>;
        lcd_fsync_dis_time  = <1000>;
        lcd_fsync_pol       = <0>;
        deu_mode            = <0>;
        lcdgamma4iep        = <22>;
        smart_color         = <90>;
        lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;
        pinctrl-0 = <&dsi4lane_pins_a>;
        pinctrl-1 = <&dsi4lane_pins_b>;
&hdmi {
        hdmi_used = <1>;
        hdmi_power_cnt = <0>;
        hdmi_cts_compatibility = <1>;
        hdmi_hdcp_enable = <1>;
        hdmi_hdcp22_enable = <0>;
        hdmi_cec_support = <1>;
        hdmi_cec_super_standby = <0>;
        ddc_en_io_ctrl = <0>;
        power_io_ctrl = <0>;
&pwm0 {
        pinctrl-names = "active", "sleep";
        pinctrl-0 = <&pwm0_pin_a>;
        pinctrl-1 = <&pwm0_pin_b>;
&pwm2 {
        pinctrl-0 = <&pwm2_pin_a>;
        pinctrl-1 = <&pwm2_pin_b>;
&pwm7 {
        pinctrl-0 = <&pwm7_pin_a>;
        pinctrl-1 = <&pwm7_pin_b>;
&rtp {
        allwinner,tp-sensitive-adjust = <0xf>;
        allwinner,filter-type = <0x1>;
        allwinner,ts-attached;
&gpadc {
        channel_num = <2>;
        channel_select = <3>;
        channel_data_select = <3>;
        channel_compare_select = <3>;
        channel_cld_select = <3>;
        channel_chd_select = <3>;
        channel0_compare_lowdata = <1700000>;
        channel0_compare_higdata = <1200000>;
        channel1_compare_lowdata = <460000>;
        channel1_compare_higdata = <1200000>;
&s_cir0 {
        pinctrl-0 = <&s_cir0_pins_a>;
        pinctrl-1 = <&s_cir0_pins_b>;
&ir1 {
        pinctrl-0 = <&ir1_pins_a>;
        pinctrl-1 = <&ir1_pins_b>;
[37]set pll start
[42]set pll end
[46]board init ok
[95]dram size =512
[96]card no is 0
[100][mmc]: mmc driver ver 2021-04-2 16:45
[122][mmc]: HSSDR52/SDR25 4 bit
[125][mmc]: 50000000 Hz
[127][mmc]: 1903 MB
[193]Entry_name        = dtb
[195]mmc not para
[197]Jump to second Boot.
OpenSBI v0.6
        |_|
Current Hart           : 0
PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒[00.274][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
[00.294][mmc]: Using default timing para
[00.298][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.334]set disp.dev2_output_type fail. using defval=0
[00.381]out of usb burn from boot: not need burn key
[01.821]
[01.824][mmc]: MMC Device 2 not found
[01.827][mmc]: mmc 2 not find, so not exit
[    0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #13 Sat Jul 17 15:09:03 CST 2021
[    0.000357] Console: colour dummy device 80x25
[    0.000391] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000406] pid_max: default: 32768 minimum: 301
[    0.000600] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.000619] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.002816] devtmpfs: initialized
[    0.014135] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
[    0.014858] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.014885] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[    0.015292] pinctrl core: initialized pinctrl subsystem
[    0.016418] NET: Registered protocol family 16
[    0.017858] DMA: preallocated 256 KiB pool for atomic allocations
[    0.055763] rtc_ccu: sunxi ccu init OK
[    0.062225] clock: sunxi ccu init OK
[    0.063071] clock: sunxi ccu init OK
[    0.087085] iommu: Default domain type: Translated
[    0.087240] sunxi iommu: irq = 80
[    0.088224] SCSI subsystem initialized
[    0.088489] usbcore: registered new interface driver usbfs
[    0.088598] usbcore: registered new interface driver hub
[    0.088671] usbcore: registered new device driver usb
[    0.088823] videodev: Linux video capture interface: v2.00
[    0.090034] pwm module init!
[    0.092646] clocksource: Switched to clocksource riscv_clocksource
[    0.102934] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    0.116955] thermal_sys: Registered thermal governor 'step_wise'
[    0.117423] NET: Registered protocol family 2
[    0.118241] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.118289] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.118351] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.118396] TCP: Hash tables configured (established 4096 bind 4096)
[    0.118527] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.118566] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.118782] NET: Registered protocol family 1
[    0.120559] workingset: timestamp_bits=62 max_order=17 bucket_order=0
[    0.129608] NET: Registered protocol family 38
[    0.129682] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.129692] io scheduler mq-deadline registered
[    0.129699] io scheduler kyber registered
[    0.130755] [DISP]disp_module_init
[    0.131295] disp 5000000.disp: Adding to iommu group 0
[    0.131897] [DISP] disp_init,line:2385:
[    0.131902] smooth display screen:0 type:1 mode:4
[    0.166170] display_fb_request,fb_id:0
[    0.203384] [DISP]disp_module_init finish
[    0.204805] sunxi_sid_init()506 - insmod ok
[    0.205299] pwm-regulator: supplied by regulator-dummy
[    0.206401] disp_al_manager_apply ouput_type:1
[    0.206613] [DISP] lcd_clk_config,line:731:
[    0.206625] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[    0.206625]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[    0.206877] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[    0.288935] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[    0.289311] uart uart0: get regulator failed
[    0.289337] uart uart0: uart0 supply uart not found, using dummy regulator
[    0.289603] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[    0.289627] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[    0.919862] printk: console [ttyS0] enabled
[    0.925291] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[    0.936687] uart uart1: get regulator failed
[    0.941481] uart uart1: uart1 supply uart not found, using dummy regulator
[    0.949464] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
[    0.959191] misc dump reg init
[    0.973342] loop: module loaded
[    0.977910] libphy: Fixed MDIO Bus: probed
[    0.982516] CAN device driver interface
[    0.987738] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    0.999008] sunxi gmac driver's version: 1.0.0
[    1.004135] gmac-power0: NULL
[    1.007473] gmac-power1: NULL
[    1.010794] gmac-power2: NULL
[    1.015002] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022319] sunxi-ehci: EHCI SUNXI driver
[    1.027315] get ehci1-controller wakeup-source is fail.
[    1.033276] sunxi ehci1-controller don't init wakeup source
[    1.039523] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0007ccac0, 0x:ffffffd00406f000, irq_no:31
[    1.053055] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[    1.065535] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    1.072813] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.082622] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
[    1.104667] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    1.113361] hub 1-0:1.0: USB hub found
[    1.117627] hub 1-0:1.0: 1 port detected
[    1.122749] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.129697] sunxi-ohci: OHCI SUNXI driver
[    1.134712] get ohci1-controller wakeup-source is fail.
[    1.140688] sunxi ohci1-controller don't init wakeup source
[    1.146928] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0007cd600
[    1.157356] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[    1.169837] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    1.177087] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.186879] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
[    1.257535] hub 2-0:1.0: USB hub found
[    1.261801] hub 2-0:1.0: 1 port detected
[    1.267135] usbcore: registered new interface driver uas
[    1.273234] usbcore: registered new interface driver usb-storage
[    1.280022] usbcore: registered new interface driver ums-alauda
[    1.286705] usbcore: registered new interface driver ums-cypress
[    1.293488] usbcore: registered new interface driver ums-datafab
[    1.300265] usbcore: registered new interface driver ums_eneub6250
[    1.307241] usbcore: registered new interface driver ums-freecom
[    1.314033] usbcore: registered new interface driver ums-isd200
[    1.320724] usbcore: registered new interface driver ums-jumpshot
[    1.327601] usbcore: registered new interface driver ums-karma
[    1.334191] usbcore: registered new interface driver ums-onetouch
[    1.341088] usbcore: registered new interface driver ums-realtek
[    1.347875] usbcore: registered new interface driver ums-sddr09
[    1.354564] usbcore: registered new interface driver ums-sddr55
[    1.361258] usbcore: registered new interface driver ums-usbat
[    1.368284] sunxi_gpadc_init,1968, success
[    1.373554] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[    1.385614] sunxi-rtc 7090000.rtc: registered as rtc0
[    1.391378] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:30 UTC (30)
[    1.400341] sunxi-rtc 7090000.rtc: sunxi rtc probed
[    1.406156] i2c /dev entries driver
[    1.410198] IR NEC protocol handler initialized
[    1.415275] IR RC5(x/sz) protocol handler initialized
[    1.421603] usbcore: registered new interface driver uvcvideo
[    1.428040] USB Video Class driver (1.1.1)
[    1.432617] sunxi cedar version 1.1
[    1.436779] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.443044] VE: install start!!!
[    1.443044]
[    1.448531] VE: cedar-ve the get irq is 1
[    1.448531]
[    1.454848] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[    1.454848]
[    1.466421] VE: install end!!!
[    1.466421]
[    1.472747] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.484916] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    1.494854] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    1.501048] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[    1.507379] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    1.513804] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    1.520224] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[    1.526745] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[    1.533266] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[    1.539784] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[    1.546663] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    1.552140] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[    1.558729] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.569855] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    1.588671] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.612841] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    1.619166] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
[    1.629108] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    1.635300] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[    1.641635] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[    1.648056] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    1.654479] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    1.661001] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    1.667518] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    1.674042] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    1.680586] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    1.689364] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.701819] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.712993] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[    1.724675] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.736337] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.749007] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.760689] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    1.769226] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.776107] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.787664] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[    1.794625] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.812718] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.827984] usbcore: registered new interface driver usbhid
[    1.834250] usbhid: USB HID core driver
[    1.840722] NET: Registered protocol family 10
[    1.847041] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.853804] Segment Routing with IPv6
[    1.858002] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.865356] NET: Registered protocol family 17
[    1.870376] NET: Registered protocol family 15
[    1.875345] can: controller area network core (rev 20170425 abi 9)
[    1.882337] NET: Registered protocol family 29
[    1.887321] can: raw protocol (rev 20170425)
[    1.892095] can: broadcast manager protocol (rev 20170425 t)
[    1.898430] can: netlink gateway (rev 20190810) max_hops=1
[    1.906025] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.913607] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.920386] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.929327] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[    1.936110] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    1.947926] HDMI 2.0 driver init start!
[    1.952249] boot_hdmi=false
[    1.955417] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    1.962360] HDMI2.0 module init end
[    1.981389] twi twi2: twi2 supply twi not found, using dummy regulator
[    1.989217] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.000783] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[    2.018136] sunxi_i2c_probe()2262 - [i2c2] probe success
[    2.033863] get ehci0-controller wakeup-source is fail.
[    2.039824] sunxi ehci0-controller don't init wakeup source
[    2.046075] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0007cc700, 0x:ffffffd005222000, irq_no:2e
[    2.059573] [sunxi-ehci0]: Not init ehci0
[    2.064484] get ohci0-controller wakeup-source is fail.
[    2.070454] sunxi ohci0-controller don't init wakeup source
[    2.076701] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0007cd240
[    2.087098] [sunxi-ohci0]: Not init ohci0
[    2.091735] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[    2.103492] mmc0: new high speed SD card at address 00c3
[    2.110481] mmcblk0: mmc0:00c3 E1161 1.86 GiB
[    2.119734] clk: Not disabling unused clocks
[    2.124544] alloc_fd: slot 0 not NULL!
[    2.133440] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    2.141726] GPT:223744 != 3898367
[    2.145432] GPT:Alternate GPT header not at the end of the disk.
[    2.152141] GPT:223744 != 3898367
[    2.155845] GPT: Use GNU Parted to correct GPT errors.
[    2.161638]  mmcblk0: p1 p2 p3 p4
[    2.172385] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    2.181508] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
[    2.189607] devtmpfs: mounted
[    2.193095] Freeing unused kernel memory: 176K
[    2.198068] This architecture does not have kernel memory protection.
[    2.205265] Run /sbin/init as init process
[    2.383912] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [    2.609496] udevd[122]: starting version 3.2.9
[    2.627203] random: udevd: uninitialized urandom read (16 bytes read)
[    2.635661] random: udevd: uninitialized urandom read (16 bytes read)
[    2.643336] random: udevd: uninitialized urandom read (16 bytes read)
[    2.681596] udevd[123]: starting eudev-3.2.9
done
Saving random seed: [    4.804493] urandom_read: 2 callbacks suppressed
[    4.804499] random: dd: uninitialized urandom read (512 bytes read)
OK
Starting network: [    5.092678] libphy: 4500000.eth: probed
[    5.097218] sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (4500000.eth-0:00)
[    5.380667] hdmi_hpd_sys_config_release
[    5.460657]
[    5.460657] insmod_device_driver
[    5.460657]
FAIL
buildroot login: [   33.760677] usb1-vbus: disabling
完全没有 gpio key 的启动记录了。
楼主 #7 2021-07-17 15:17:43
tigger
已发帖子: 172
Re: 全志D1开发板添加基于中断的 gpio-key 按键驱动
如果把
                pins = "PD10";
                bias-pull-up;
移到 pio 去
那么日志就是这样:
[    2.119206] sun8iw20-pinctrl 2000000.pinctrl: pin PD10 already requested by gpio_keys; cannot claim for 2000000.pinctrl:106
[    2.131670] sun8iw20-pinctrl 2000000.pinctrl: pin-106 (2000000.pinctrl:106) status -22
[    2.140524] gpio-keys gpio_keys: failed to get gpio: -22
[    2.146505] gpio-keys: probe of gpio_keys failed with error -22
[    2.154058] clk: Not disabling unused clocks
