楼主 # 2021-07-30 17:26:01
linux小白
已发帖子: 22
求助大佬,tina3.5下的codec的设备树配置
如题,有没有大佬知道tina3.5设备树(硬件荔枝派nano)下面,codec的节点是怎么样配置的,下面是我这边的配置,但是这个配置似乎有问题,所以系统启动时报了[    0.631099] failed to get gpio-spk and gpio_num这个错误
codec:codec@0x01c23c00 {
			compatible = "allwinner,sunxi-internal-codec";
			reg = <0x0 0x01c23c00 0x0 0x9c>;/*digital baseadress*/
			clocks = <&clk_pll_audio>, <&clk_codec>;
			gpio_shdn = <0>;
			headphonevol = <0x3b>;
			spkervol = <0x1b>;
			maingain = <0x4>;
			hp_dirused = <0x0>;
			pa_sleep_time = <0x15e>;
#1 2021-07-31 20:21:15
所在地: 你猜
已发帖子: 3,380
Re: 求助大佬,tina3.5下的codec的设备树配置
感觉应该是有一个 gpio-spk 控制功放? 驱动申请这个gpio失败,然后就报错?
#2 2021-08-02 14:36:03
jshxcn
已发帖子: 21
这个是我的设备树,没有引脚控制喇叭,可以有声音
            gpio-spk=<&pio 6 7 0>;
            /*gpio-spk = <&pio PB 1 1 1 1 1>;*/
            /*gpio_num = <2040>;*/
            /*gpio-spk = <0>;*/
            gpio_num = <0>;
            gpio_shdn = <0>;
            spkervol = <0x3b>;
            maingain = <0x4>;
            hp_dirused = <0x1>;
楼主 #3 2021-08-17 15:00:18
linux小白
已发帖子: 22
@jshxcn
我这边尝试一下,还是不行,还是不能识别到引脚,而且在系统启动时,还是报了引脚不能识别,不知设备树那边漏了什么
1.845580] sunxi-internal-codec codec: ASoC: DAPM unknown pin HPOUTR
[    1.852866] sunxi-internal-codec codec: ASoC: DAPM unknown pin HPOUTL
[    1.860022] sunxi-internal-codec codec: ASoC: DAPM unknown pin SPKL
[    1.867027] sunxi-internal-codec codec: ASoC: DAPM unknown pin SPKR
楼主 #4 2021-08-17 15:03:27
linux小白
已发帖子: 22
是的,系统启动时,都提示找不到引脚的配置,我感觉是设备树那里出了问题,但是又不知道怎么样设置,不知道大佬是否可以指点一、二
[    1.812277] sun3iw1p1-pinctrl pio: missing allwinner,pins property in node daudio0
[    1.821023] sun3iw1p1-pinctrl pio: missing allwinner,pins property in node daudio0
[    1.829434] [daudio]request pinctrl handle
[    1.833953] for audio failed
[    1.837390] sunxi-daudio: probe of daudio0 failed with error -22
[    1.845580] sunxi-internal-codec codec: ASoC: DAPM unknown pin HPOUTR
[    1.874025] sunxi-codec-machine sndcodec: ASoC: DAPM unknown pin External Speaker
[    1.882688] sunxi-internal-cpudai cpudai: ASoC: pcm constructor failed: -12
[    1.890430] sunxi-codec-machine sndcodec: ASoC: can't create pcm SUNXI-CODEC :-12
[    1.898823] sunxi-codec-machine sndcodec: ASoC: failed to instantiate card -12
楼主 #5 2021-08-18 18:17:38
linux小白
已发帖子: 22
@jshxcn
这样配置系统启动时候,提示了 /soc/codec@0x01c23c00: arguments longer than property,是不是有什么问题
