楼主 # 2021-07-30 18:49:49
xiaoqianxiansheng
已发帖子: 35
V3s 一直重复启动 boot 大佬帮忙看看
编译的zeta linux sdk 在荔枝派已经通过了。但是放到自己公司画的板子里面就一直重启boot
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 8
fel flag  = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x00000000
rtc[7] value = 0x00000000
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 408 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
boot0 commit : 8
DRAM CLK = 408 MHz
DRAM size = 64 MB
boot0 commit : 8
DRAM CLK = 408 MHz
DRAM size = 64 MB
就是一直打印这个。 画的板子 加入了axp203.检查了供电都正常。
下面的是荔枝派启动的打印
boot0 commit : 8
rtc[6] value = 0x80000000
rtc[7] value = 0x0000011c
DRAM CLK = 408 MHz
DRAM size = 64 MB
dram size =64
Succeed in reading Boot1 file head.
The size of uboot is 00034000.
Ready to disable icache.
Jump to secend Boot.
[      0.139]
U-Boot 2011.09-rc1 (Apr 08 2017 - 19:50:24) Allwinner Technology
[      0.146]version: 1.1.0
[      0.149]uboot commit : 8
[      0.154]pmbus:   ready
下面是 fex文件
;A23 PAD application
; port configuration:
; port_name = port:GPIO<mux><pull up/down><driver level><default value>
; mux: GPIO function configuration, 0-input, 1-output, 2+: special funciton for modules
; pull up/down: 1-pull up, 2-pull down
; driver level: 0,1,2,3. 2 is recommended
; default value: default output value when this IO is configured as an output IO
[product]
version = "100"
machine = "tiger-ipc"
[platform]
eraseflag   = 0
;[target]  system bootup configuration
;boot_clock	= CPU boot frequency, Unit: MHz
;storage_type	= boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan
;speed_mod    0 : normal read ; 1 dual line fast read
[target]
boot_clock   	= 1008
storage_type  	= -1
[boot_spi_board0]
boot_spi_speed_hz = 60000000
speed_mod         = 1
[key_detect_en]
keyen_flag = 0
;dcdc1_vol	---set dcdc1 voltage,mV,1600-3400,100mV/step
;dcdc2_vol	---set dcdc2 voltage,mV,600-1540,20mV/step
;dcdc3_vol	---set dcdc3 voltage,mV,600-1860,20mV/step
;dcdc4_vol	---set dcdc4 voltage,mV,600-1540,20mV/step
;dcdc5_vol	---set dcdc5 voltage,mV,1000-2550,50mV/step
;aldo2_vol	---set aldo2 voltage,mV,700-3300,100mV/step
;aldo3_vol	---set aldo3 voltage,mV,700-3300,100mV/step
[power_sply]
dcdc2_vol       = 1250
dcdc3_vol       = 3300
aldo2_vol       = 2500
aldo3_vol       = 3000
ldo1_vol        = 3300
ldo2_vol        = 3000
ldo3_vol        =
;[power_sply]
;dcdc2_vol       = 1100
;dcdc3_vol       = 1800
;aldo2_vol       = 2500
;aldo3_vol       = 3000
;ldo1_vol        = 3300
;ldo2_vol        = 3000
;ldo3_vol        = 3000
;[axp15_para]
;dcdc1_vol       = 3300
;dcdc2_vol       = 1100
;dcdc3_vol       = 1800
;dcdc4_vol       = 1800
;aldo1_vol       = 3000
;aldo2_vol       = 3300
;dldo1_vol       = 3300
;card boot
[card_boot]
logical_start   = 40960
sprite_gpio0    =
;[cardx_boot_para] boot card configuration
;card_ctrl 	 = boot card NO. 0 or 2
;card_high_speed = speed mode, 0-normal mode(up to 25MHz), 1-high speed mode(up to 50MHz)
;card_line       = boot card buswidth(1 or 4)
[card0_boot_para]
card_ctrl       = 0
card_high_speed = 1
card_line       = 4
sdc_d1          = port:PF0<2><1><default><default>
sdc_d0          = port:PF1<2><1><default><default>
sdc_clk         = port:PF2<2><1><default><default>
sdc_cmd         = port:PF3<2><1><default><default>
sdc_d3          = port:PF4<2><1><default><default>
sdc_d2          = port:PF5<2><1><default><default>
;[card2_boot_para]
;card_ctrl       = 2
;card_high_speed = 1
;card_line       = 4
;sdc_cmd         = port:PC00<2><1><2><default>
;sdc_clk         = port:PC01<2><1><2><default>
;sdc_d0          = port:PC03<2><1><2><default>
;sdc_d1          = port:PC04<2><1><2><default>
;sdc_d2          = port:PC05<2><1><2><default>
;sdc_d3          = port:PC06<2><1><2><default>
;[twi_para] twi for boot code
;twi_port	= twi controller ID
[twi_para]
twi_port        = 0
twi_scl         = port:PB06<2><default><default><default>
twi_sda         = port:PB07<2><default><default><default>
;twi_port        = 1
;twi_scl         = port:PB08<2><default><default><default>
;twi_sda         = port:PB09<2><default><default><default>
;[uart_para] boot debug port configuration
;uart_debug_port = uart port ID for boot debug
;origin
;[uart_para]
;uart_debug_port = 1
;uart_debug_tx   = port:PE21<4><1><default><default>
;uart_debug_rx   = port:PE22<4><1><default><default>
[uart_para]
;uart_debug_port = 0
;uart_debug_tx   = port:PB08<3><1><default><default>
;uart_debug_rx   = port:PB09<3><1><default><default>
uart_debug_port = 2
uart_debug_tx   = port:PB00<2><1><default><default>
uart_debug_rx   = port:PB01<2><1><default><default>
;card print
;uart_debug_tx    = port:PF02<3><1><default><default>
;uart_debug_rx    = port:PF04<3><1><default><default>
;[jtag_para] jtag configuration
;jtag_enable     = 0-disable jtag, 1-enable jtag
[jtag_para]
jtag_enable     = 0
jtag_ms         = port:PF00<3><default><default><default>
jtag_ck         = port:PF05<3><default><default><default>
jtag_do         = port:PF03<3><default><default><default>
jtag_di         = port:PF01<3><default><default><default>
;[clock] pll configuration
[clock]
pll3            = 297
pll4            = 300
pll6            = 600
pll8            = 360
pll9            = 480
pll10           = 297
pll_ve          = 360
pll_isp         = 360
;[pm_para] power management
;standby_mode = 0-normal standby, 1-super standby
[pm_para]
standby_mode		= 1
;sys_pwr_dm_para
;this para is used to change default sys_pwr_dm config when necessary.
;   allowed sys_pwr_dm is such as follow:
;		vdd-cpua
; 		vdd-cpub
; 		vdd-gpu
; 		vcc-dram
; 		vdd-sys
; 		which is compatible with pmu regu config. see: [pmu1_regu] for more info.
;   value: 0: del the pwr_dm from sys_pwr_dm_mask;
;	   1: add the pwr_dm into sys_pwr_dm_mask;
[sys_pwr_dm_para]
vdd-cpua = 1
vdd-sys  = 1
;dynamic_standby_para
;   enable:
;	value: 0: all config is ignored.
;	       1: all config is effective.
;   dram_selfresh_flag:
;	value: 0: dram will not enter selfresh,
;		    this config is used for stop dram entering selfresh, in case of dram memory have bug.
;	       1: dram will enter slefresh.
[dynamic_standby_para]
enable = 0
dram_selfresh_flag = 1
vdd_cpua_vol     = 1200
vdd_sys_vol      = 1200
;sdram configuration
[dram_para]
dram_clk        = 408
dram_type       = 2
dram_zq         = 0x39bb
dram_odt_en     = 0
dram_para1      = 0x10E20000
dram_para2      = 0x0000
dram_mr0        = 0x1840
dram_mr1        = 0x4
dram_mr2        = 0x18
dram_mr3        = 0x4
dram_tpr0       = 0x00832087
dram_tpr1       = 0x01C24085
dram_tpr2       = 0x0002A01D
dram_tpr3       = 0x0
dram_tpr4       = 0x0
dram_tpr5       = 0x0
dram_tpr6       = 0x0
dram_tpr7       = 0x0
dram_tpr8       = 0x0
dram_tpr9       = 0x0
dram_tpr10      = 0x0
dram_tpr11      = 0x220000
dram_tpr12      = 0x78
dram_tpr13      = 0x0d000000
; if 1 == standby_mode, then support super standby;
; else, support normal standby.
[pm_para]
standby_mode		= 0
; wakeup_src_para:
;	sometimes, u would like to add more wakeup src in standby mode, these para will be
;	help;
;	u need to make sure the standby mode support the wakeup src. Also, some hw
;	condition must be guaranteed.
;	including:
;	cpu_en: power on or off.
;		1: mean power on
;		0: mean power off
;	cpu_freq: indicating lowest freq. unit is Mhz;
;	dram selfresh_en: selfresh or not.
;		1: enable enter selfresh
;		0: disable enter selfresh
;	dram_pll: if not enter selfresh, indicating lowest freq. unit is Mhz;
;	wakeup_src: to make the scenario work, the wakeup src is needed.
[wakeup_src_para]
cpu_en		= 0
cpu_freq	= 48
; (cpu:apb:ahb)
pll_ratio	= 0x111
dram_selfresh_en= 1
dram_freq	= 36
wakeup_src_wl 	= port:PL07<4><default><default><0>
wakeup_src_bt 	= port:PL09<4><default><default><0>
bb_wake_ap	= port:PL02<4><default><default><0>
;i2c configuration
; twi_used = twix enable    ;; twi0->use pmu axp209 ,  twi1->use gsenor
[twi0]
twi_used        = 0
[twi1]
twi_used        = 1
;uart configuration
;uart_used = uart x enable
;uart_port = x; x is order number of ttySx
;uart_type       = 2:2 wire,4:4 wire,8:8 wire, full function
[uart0]
uart_used       = 0
uart_port       = 0
uart_type       = 2
uart_tx         = port:PB08<3><1><default><default>
uart_rx         = port:PB09<3><1><default><default>
;card print
;uart_tx         = port:PF02<3><1><default><default>
;uart_rx         = port:PF04<3><1><default><default>
[uart1]
uart_used       = 0
uart_port	    = 0
uart_type       = 2
uart_tx         = port:PE21<4><1><default><default>
uart_rx         = port:PE22<4><1><default><default>
[uart2]
uart_used       = 1
uart_port	    = 0
uart_type       = 2
uart_tx         = port:PB00<2><1><default><default>
uart_rx         = port:PB01<2><1><default><default>
;SPI controller configuration
;spi_used       = SPIx enable
;spi_cs_bitmap  = SPI bit mapping
[spi0]
spi_used       = 1
spi_cs_bitmap  = 1
spi_mosi       = port:PC03<3><default><default><default>
spi_miso       = port:PC00<3><default><default><default>
spi_sclk       = port:PC01<3><default><default><default>
spi_cs0        = port:PC02<3><1><default><default>
;SPI device configuration
;spi_dev_num: number of spi devices
[spi_devices]
spi_dev_num = 1
;[spi_board0] spi device configuration
;modalias      = spi device name
;max_speed_hz  = max transfer speed
;bus_num       = bus ID
;chip_select   = chip select, 0,1
;mode          = SPI transfer mode
; sflash_size- 16 : 16M nor flash size , 8 : 8M nor flash size
[spi_board0]
modalias      = "mx25l12835f"
max_speed_hz  = 50000000
bus_num       = 0
chip_select   = 0
mode          = 0
sflash_size   = 16
;capacitor tp configuration
;ctp_twi_id : twi controller ID
;ctp_twi_addr : I2C slave address, 7bit
;ctp_screen_max_x/_y : resolution of touch panel
;ctp_revert_x/_y_flag : whether need to revert x/y
;ctp_exchange_x_y_flag: whether need to exchange the value of x and y
;ctp_int_port : port for tp's interrupt signal
;ctp_wakeup : port for wakeup tp
[ctp_para]
ctp_used            = 0
ctp_name            = "gt911_m785q6"
ctp_twi_id          = 1
ctp_twi_addr        = 0x5d
ctp_screen_max_x    = 800
ctp_screen_max_y    = 480
ctp_revert_x_flag   = 0
ctp_revert_y_flag   = 0
ctp_exchange_x_y_flag = 1
ctp_int_port        = port:PG04<6><default><default><default>
ctp_wakeup          = port:PG03<1><default><default><1>
; CTP automatic detection configuration
;ctp_detect_used  --- Whether startup automatic inspection function. 1:used,0:unused
;Module name postposition 1 said detection, 0 means no detection.
[ctp_list_para]
ctp_det_used              = 0
gt911_ts                  = 1
ft5x_ts                   = 1
gt82x                     = 1
gslX680                   = 1
gt9xx_ts                  = 1
gt811                     = 1
zet622x                   = 1
aw5306_ts                 = 1
;touch key configuration
;tkey_twi_id : twi controller ID
;tkey_twi_addr : I2C slave address, 7bit
;tkey_int : port for touch key's interrupt signal
[tkey_para]
tkey_used           = 0
tkey_twi_id         =
tkey_twi_addr       =
tkey_int            =
;motor configuration
;motor_shake : port for making the moto shaking
[motor_para]
motor_used          = 0
motor_shake         = port:power3<1><default><default><1>
;cooler_table  cooler_count <=32
[cooler_table]
cooler_count = 4
cooler0 = "1340000 4 4294967295 0"
cooler1 = "1200000 4 4294967295 0"
cooler2 = "1008000 4 4294967295 0"
cooler3 =  "648000 4 4294967295 0"
;disp init configuration
;disp_mode             (0:screen0<screen0,fb0>)
;screenx_output_type   (0:none; 1:lcd; 3:hdmi;)
;screenx_output_mode   (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50)
;                      (5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60)
;fbx format            (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444)
;fbx pixel sequence    (0:ARGB 1:BGRA 2:ABGR 3:RGBA)
;fb0_scaler_mode_enable(scaler mode enable, used FE)
;fbx_width,fbx_height  (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0)
;lcdx_backlight        (lcd init backlight,the range:[0,256],default:197
;lcdx_yy               (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50)
;lcd0_contrast         (LCD contrast, 0~100)
;lcd0_saturation       (LCD saturation, 0~100)
;lcd0_hue              (LCD hue, 0~100)
[disp_init]
disp_init_enable         = 0
disp_mode                = 0
screen0_output_type      = 1
screen0_output_mode      = 4
screen1_output_type      = 1
screen1_output_mode      = 4
fb0_format               = 0
fb0_pixel_sequence       = 0
fb0_scaler_mode_enable   = 0
fb0_width                = 0
fb0_height               = 0
fb1_format               = 0
fb1_pixel_sequence       = 0
fb1_scaler_mode_enable   = 0
fb1_width                = 0
fb1_height               = 0
lcd0_backlight           = 200
lcd1_backlight           = 50
lcd0_bright              = 50
lcd0_contrast            = 50
lcd0_saturation          = 57
lcd0_hue                 = 50
lcd1_bright              = 50
lcd1_contrast            = 50
lcd1_saturation          = 57
lcd1_hue                 = 50
;lcd0 configuration
;lcd_if:               0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_x:                lcd horizontal resolution
;lcd_y:                lcd vertical resolution
;lcd_width:            width of lcd in mm
;lcd_height:           height of lcd in mm
;lcd_dclk_freq:        in MHZ unit
;lcd_pwm_freq:         in HZ unit
;lcd_pwm_pol:          lcd backlight PWM polarity
;lcd_pwm_max_limit     lcd backlight PWM max limit(<=255)
;lcd_hbp:              hsync back porch
;lcd_ht:               hsync total cycle
;lcd_vbp:              vsync back porch
;lcd_vt:               vysnc total cycle
;lcd_hspw:             hsync plus width
;lcd_vspw:             vysnc plus width
;lcd_lvds_if:          0:single link;  1:dual link
;lcd_lvds_colordepth:  0:8bit; 1:6bit
;lcd_lvds_mode:        0:NS mode; 1:JEIDA mode
;lcd_frm:              0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase:         0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
;                      8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en          lcd gamma correction enable
;lcd_bright_curve_en   lcd bright curve correction enable
;lcd_cmap_en           lcd color map function enable
;deu_mode              0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep:         Smart Backlight parameter, lcd gamma vale * 10;
;                      decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color           90:normal lcd screen 65:retina lcd screen(9.7inch)
[lcd0_para]
lcd_used            = 0
lcd_driver_name     = "t27p06"
lcd_if              = 0
lcd_x               = 320
lcd_y               = 480
lcd_width           = 108
lcd_height          = 64
lcd_dclk_freq       = 48
lcd_pwm_used        = 1
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 1
lcd_pwm_max_limit   = 255
lcd_hbp             = 40
lcd_ht              = 1440
lcd_hspw            = 1
lcd_vbp             = 42
lcd_vt              = 525
lcd_vspw            = 1
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity = 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 1
lcd_cmap_en         = 0
lcd_hv_if	    	= 11
lcd_hv_srgb_seq	    = 0
lcd_rb_swap			= 0
lcdgamma4iep        = 22
lcd_bl_en           = port:PE13<1><0><default><1>
lcd_power           = ""
lcd_gpio_3          = port:PE14<1><0><default><1>
lcd_gpio_0          = port:PE15<1><0><default><1>
;lcd_gpio_1          = port:PE17<1><0><default><1>
lcd_gpio_2          = port:PE16<1><0><default><1>
;lcdd2               = port:PE0<3><0><default><default>
lcdd3               = port:PE5<3><0><default><default>
lcdd4               = port:PE6<3><0><default><default>
lcdd5                = port:PE7<3><0><default><default>
lcdd6                = port:PE8<3><0><default><default>
lcdd7                = port:PE9<3><0><default><default>
lcdd10               = port:PE10<3><0><default><default>
lcdd11               = port:PE11<3><0><default><default>
lcdd12               = port:PE12<3><0><default><default>
;lcdd13              = port:PD9<2><0><default><default>
;lcdd14              = port:PD10<2><0><default><default>
;lcdd15              = port:PD11<2><0><default><default>
;lcdd18              = port:PD12<2><0><default><default>
;lcdd19              = port:PD13<2><0><default><default>
;lcdd20              = port:PD14<2><0><default><default>
;lcdd21              = port:PD15<2><0><default><default>
;lcdd22              = port:PD16<2><0><default><default>
;lcdd23              = port:PD17<2><0><default><default>
lcdclk               = port:PE0<3><0><3><default>
;lcdde               = port:PD19<2><0><3><default>
lcdhsync             = port:PE2<3><0><3><default>
lcdvsync             = port:PE3<3><0><3><default>
;pwm config
[pwm0_para]
pwm_used            = 0
pwm_positive        = port:PB04<2><0><default><default>
[pwm1_para]
pwm_used            = 0
pwm_positive        = port:PH01<2><0><default><default>
; 10/100/100Mbps Ethernet MAC Controller Configure                             ;
;   Options:        ;
;   gmac_used  ---  0: not used, 1: external phy, 2: internal phy              ;
;   gmac_powerx --  A[:B] A: axp channel, B: voltage value                     ;
:       If set gamc_phy to use internal PHY, do not config port                ;
;         MII        RMII         MII        RMII         MII        RMII      ;
;   PD00  *                 PD06   *           *    PD12   *           *       ;
;   PD01  *                 PD07   *                PD13   *           *       ;
;   PD02  *            *    PD08   *                PD14   *                   ;
;   PD03  *            *    PD09   *           *    PD15   *                   ;
;   PD04  *                 PD10   *           *    PD16   *           *       ;
;   PD05  *                 PD11   *           *    PD17   *           *       ;
[gmac0]
gmac_used          = 2
gmac_power1        =
;vip (video input port) configuration
;vip_used: 0:disable 1:enable
;vip_mode: 0:sample one interface to one buffer 1:sample two interface to one buffer
;vip_dev_qty: The quantity of devices linked to capture bus
;vip_define_sensor_list: If you want use sensor detect function, please set vip_define_sensor_list = 1, and
;                                    verify that file /system/etc/hawkview/sensor_list_cfg.ini is properly configured!
;vip_dev(x)_pos: sensor position, "rear" or "front", if vip_define_sensor_list = 1,vip_dev(x)_pos must be configured!
;vip_dev(x)_isp_used 0:not use isp 1:use isp
;vip_dev(x)_fmt: 0:yuv 1:bayer raw rgb
;vip_dev(x)_stby_mode: 0:not shut down power at standby 1:shut down power at standby
;vip_dev(x)_vflip: flip in vertical direction 0:disable 1:enable
;vip_dev(x)_hflip: flip in horizontal direction 0:disable 1:enable
;vip_dev(x)_iovdd: camera module io power handle string, pmu power supply
;vip_dev(x)_iovdd_vol: camera module io power voltage, pmu power supply
;vip_dev(x)_avdd: camera module analog power handle string, pmu power supply
;vip_dev(x)_avdd_vol: camera module analog power voltage, pmu power supply
;vip_dev(x)_dvdd: camera module core power handle string, pmu power supply
;vip_dev(x)_dvdd_vol: camera module core power voltage, pmu power supply
;vip_dev(x)_afvdd: camera module vcm power handle string, pmu power supply
;vip_dev(x)_afvdd_vol: camera module vcm power voltage, pmu power supply
;x indicates the index of the devices which are linked to the same capture bus
;fill voltage in uV, e.g. iovdd = 2.8V, vip_devx_iovdd_vol = 2800000
;fill handle string as below:
;axp22_eldo3
;axp22_dldo4
;axp22_eldo2
;fill handle string "" when not using any pmu power supply
[csi0]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_define_sensor_list   = 0
vip_csi_mck              = port:PE20<3><default><default><default>
vip_csi_sck              = port:PE21<2><default><default><default>
vip_csi_sda              = port:PE22<2><default><default><default>
vip_dev0_mname           = "ov2710_mipi"
vip_dev0_pos             = "rear"
vip_dev0_lane            = 1
vip_dev0_twi_id          = 0
vip_dev0_twi_addr        = 0x6c
vip_dev0_isp_used        = 1
vip_dev0_fmt             = 1
vip_dev0_stby_mode       = 0
vip_dev0_vflip           = 1
vip_dev0_hflip           = 1
vip_dev0_iovdd           = "axp15_dldo1"
;3300000
vip_dev0_iovdd_vol       = 3300000
vip_dev0_avdd            = "axp15_aldo2"
vip_dev0_avdd_vol        = 2800000
vip_dev0_dvdd            = "axp15_dcdc4"
vip_dev0_dvdd_vol        = 1800000
vip_dev0_afvdd           = ""
vip_dev0_afvdd_vol       = 2800000
vip_dev0_power_en        =
vip_dev0_reset           = port:PG0<1><default><default><default>
vip_dev0_pwdn            = port:PG1<1><default><default><default>
vip_dev0_flash_en        =
vip_dev0_flash_mode      =
vip_dev0_af_pwdn         =
vip_dev0_act_used        = 0
vip_dev0_act_name        = "dw9714_act"
vip_dev0_act_slave       = 0x18
vip_dev1_mname           = ""
vip_dev1_pos                 = "front"
vip_dev1_lane            = 1
vip_dev1_twi_id          = 0
vip_dev1_twi_addr        =
vip_dev1_isp_used        = 0
vip_dev1_fmt             = 1
vip_dev1_stby_mode       = 0
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_iovdd_vol       = 2800000
vip_dev1_avdd            = ""
vip_dev1_avdd_vol        = 2800000
vip_dev1_dvdd            = ""
vip_dev1_dvdd_vol        = 1500000
vip_dev1_afvdd           = ""
vip_dev1_afvdd_vol       = 2800000
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
vip_dev1_flash_mode      =
vip_dev1_af_pwdn         =
[csi1]
vip_used                 = 0
vip_mode                 = 0
vip_dev_qty              = 1
vip_csi_pck              = port:PE00<2><default><default><default>
vip_csi_mck              = port:PE01<2><default><default><default>
vip_csi_hsync            = port:PE02<2><default><default><default>
vip_csi_vsync            = port:PE03<2><default><default><default>
vip_csi_d0               = port:PE04<2><default><default><default>
vip_csi_d1               = port:PE05<2><default><default><default>
vip_csi_d2               = port:PE06<2><default><default><default>
vip_csi_d3               = port:PE07<2><default><default><default>
vip_csi_d4               = port:PE08<2><default><default><default>
vip_csi_d5               = port:PE09<2><default><default><default>
vip_csi_d6               = port:PE10<2><default><default><default>
vip_csi_d7               = port:PE11<2><default><default><default>
vip_csi_d8               = port:PE12<2><default><default><default>
;vip_csi_d9               = port:PE13<2><default><default><default>
vip_csi_d10               = port:PE14<2><default><default><default>
vip_csi_d11               = port:PE15<2><default><default><default>
vip_dev0_mname           = "ov5640"
vip_dev0_pos             = "front"
vip_dev0_twi_id          = 4
vip_dev0_twi_addr        = 0x78
vip_dev0_isp_used        = 0
vip_dev0_fmt             = 0
vip_dev0_vflip           = 0
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_iovdd_vol       = 2800000
vip_dev0_avdd            = ""
vip_dev0_dvdd            = ""
vip_dev0_dvdd_vol        = 1500000
vip_dev0_afvdd           = ""
vip_dev0_power_en        =
vip_dev0_reset           = port:PE23<1><default><default><default>
vip_dev0_pwdn            = port:PE24<1><default><default><default>
vip_dev0_flash_en        =
vip_dev0_af_pwdn         =
vip_dev0_act_name        = "ad5820_act"
vip_dev1_mname           = "gc2035"
vip_dev1_lane            = 1
vip_dev1_twi_id          = 4
vip_dev1_twi_addr        = 0x78
vip_dev1_fmt             = 1
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_avdd            = ""
vip_dev1_dvdd            = ""
vip_dev1_afvdd           = ""
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
vip_dev1_af_pwdn         =
;   mmc configuration
;   Config Guide
;   sdc_used:      1-enable card, 0-disable card
;   sdc_detmode:   card detect mode
;                  1-detect card by gpio polling
;                  2-detect card by gpio irq(must use IO with irq function)
;                  3-no detect, always in for boot card
;                  4-manually insert and remove by /proc/driver/sunxi-mmc.x/insert
;   sdc_buswidth:  card bus width, 1-1bit, 4-4bit, 8-8bit
;   sdc_use_wp:    1-with write protect IO, 0-no write protect IO
;   sdc_isio:      for sdio card
;   sdc_regulator: power control.if card supports UHS-I/DDR and HS200 timing for
;                  SD3.0 or eMMC4.5, regulator must be configured. the value is
;                  the ldo name of AXP221, eg: sdc_regulator = "axp22_eldo2"
;   other: GPIO Mapping configuration
;   Note:
;   1 if detmode=2, sdc_det's config=6
;     else if detmode=1, sdc_det's config=0
;     else sdc_det IO is not necessary
;   2 if the customer wants to support UHS-I and HS200 features, he must provide
;     an independent power supply for the card. This is only used in platforms
;     that supports SD3.0 cards and eMMC4.4+ flashes
[mmc0_para]
sdc_used          = 1
sdc_detmode       = 1
sdc_buswidth      = 4
sdc_d1            = port:PF00<2><1><2><default>
sdc_d0            = port:PF01<2><1><2><default>
sdc_clk           = port:PF02<2><1><2><default>
sdc_cmd           = port:PF03<2><1><2><default>
sdc_d3            = port:PF04<2><1><2><default>
sdc_d2            = port:PF05<2><1><2><default>
sdc_det           = port:PF06<0><1><default><default>
sdc_use_wp        = 0
sdc_wp            =
sdc_isio          = 0
sdc_regulator     = "none"
[mmc1_para]
sdc_used          = 1
sdc_detmode       = 4
sdc_buswidth      = 4
sdc_clk           = port:PG00<2><1><2><default>
sdc_cmd           = port:PG01<2><1><2><default>
sdc_d0            = port:PG02<2><1><2><default>
sdc_d1            = port:PG03<2><1><2><default>
sdc_d2            = port:PG04<2><1><2><default>
sdc_d3            = port:PG05<2><1><2><default>
sdc_det           =
sdc_use_wp        = 0
sdc_wp            =
sdc_isio          = 1
[mmc2_para]
sdc_used          = 0
sdc_detmode       = 3
sdc_buswidth      = 8
sdc_clk           = port:PC00<2><1><2><default>
sdc_cmd           = port:PC01<2><1><2><default>
sdc_d4            = port:PC07<2><1><2><default>
sdc_d5            = port:PC08<2><1><2><default>
sdc_d6            = port:PC09<2><1><2><default>
sdc_d7            = port:PC10<2><1><2><default>
emmc_rst          = port:PC02<2><1><2><default>
sdc_det           =
sdc_use_wp        = 0
sdc_wp            =
sdc_isio          = 0
;usb configuration
;usb_used:          usb controller enable, 0-disable, 1-enable
;usb_port_type:     usb mode: 0-device, 1-host, 2-otg
;usb_detect_type:   usb hotplug detect mode, 0-none, 1-vbus/id detect, 2-id/dpdm detect
;usb_id_gpio:       usb id detect IO
;usb_det_vbus_gpio: usb vbus detect IO, "axp_ctrl" for axp
;usb_drv_vbus_gpio: usb dirve vbus IO
;usb_restrict_gpio: usb current restrict IO
;usb_restric_flag:  usb current restrict flag
[usbc0]
usb_used = 1
usb_port_type = 1
usb_detect_type = 1
usb_id_gpio =
usb_det_vbus_gpio =
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_host_init_state = 1
usb_restric_flag = 0
usb_restric_voltage = 3550000
usb_restric_capacity= 5
usb_regulator_io = "nocare"
usb_regulator_vol = 0
usb_not_suspend = 0
; USB Device vendor Info.
[usb_feature]
vendor_id           = 0x18D1
mass_storage_id     = 0x0001
adb_id              = 0x0002
manufacturer_name   = "USB Developer"
product_name        = "Android"
serial_number       = "20080411"
[msc_feature]
vendor_name         = "USB 2.0"
product_name        = "USB Flash Driver"
release             = 100
luns                = 1
[serial_feature]
serial_unique       = 0
; G sensor configuration
; gs_twi_id	---  TWI ID for controlling Gsensor (0: TWI0, 1: TWI1, 2: TWI2)
[gsensor_para]
gsensor_used        = 0
gsensor_twi_id      = 1
;gsensor_twi_addr    = 0x18
gsensor_twi_addr    = 0x27
gsensor_int1        =
gsensor_int2        =
; G sensor automatic detection configuration
;gsensor_detect_used  --- Whether startup automatic inspection function. 1:used,0:unused
[gsensor_list_para]
gsensor_det_used          = 0
bma250                    = 1
da380					  = 1
mma8452                   = 1
mma7660                   = 1
mma865x                   = 1
afa750                    = 1
lis3de_acc                = 1
lis3dh_acc                = 1
kxtik                     = 1
dmard10                   = 0
dmard06                   = 1
mxc622x                   = 1
fxos8700                  = 1
lsm303d                   = 1
; gps gpio configuration
; gps_spi_id:     the index of SPI controller. 0: SPI0, 1: SPI1, 2: SPI2, 15: no SPI used
; gps_spi_cs_num: the chip select number of SPI controller. 0: SPI CS0, 1: SPI CS1
; gps_lradc:      the lradc number for GPS used. 0 and 1 is valid, set 2 if not use lradc
[gps_para]
[module_para]
module_num          = 1
module_power0       =
module_power0_vol   =
module_power1       =
module_power1_vol   =
module_power2       =
module_power2_vol   =
module_power3       =
module_power3_vol   =
chip_en             =
;wifi configuration
;wifi_sdc_id:    0- SDC0, 1- SDC1, 2- SDC2, 3- SDC3
;wifi_usbc_id:   0- USB0, 1- USB1, 2- USB2
;wifi_usbc_type: 1- EHCI(speed 2.0), 2- OHCI(speed 1.0)
;wifi_mod_sel:   0- none, 1- ap6181, 2- ap6210(wifi+bt),
;                3 - rtl8188eu, 4- rtl8723au(wifi+bt)
[wifi_para]
wifi_used             = 1
wifi_sdc_id           = 1
wifi_usbc_id          = 0
wifi_usbc_type        = 1
wifi_mod_sel          = 1
wl_reg_on             = port:PE17<1><default><default><0>
;wl_host_wake          = port:PE16<0><default><default><0>
wl_host_wake_invert   = 0
;light sensor
[ls_para]
ls_used             = 0
ls_twi_id           = 1
ls_twi_addr         = 0x23
ls_int              = port:PB07<4><1><default><default>
; lsensor automatic detection configuration
;ls_detect_used  --- Whether startup automatic inspection function. 1:used,0:unused
[ls_list_para]
ls_det_used          = 0
ltr_501als           = 1
jsa1212              = 1
;compass
[compass_para]
compass_used        = 0
compass_twi_id      = 1
compass_twi_addr    = 0x0d
compass_int         =
;daudio_master:1: SND_SOC_DAIFMT_CBM_CFM(codec clk & FRM master)        use
;			2: SND_SOC_DAIFMT_CBS_CFM(codec clk slave & FRM master)  not use
;			3: SND_SOC_DAIFMT_CBM_CFS(codec clk master & frame slave) not use
;			4: SND_SOC_DAIFMT_CBS_CFS(codec clk & FRM slave)         use
;daudio_select:0 is pcm.1 is i2s
;audio_format: 1:SND_SOC_DAIFMT_I2S(standard i2s format).            use
;			   2:SND_SOC_DAIFMT_RIGHT_J(right justfied format).
;			   3:SND_SOC_DAIFMT_LEFT_J(left justfied format)
;			   4:SND_SOC_DAIFMT_DSP_A(pcm. MSB is available on 2nd BCLK rising edge after LRC rising edge). use
;			   5:SND_SOC_DAIFMT_DSP_B(pcm. MSB is available on 1nd BCLK rising edge after LRC rising edge)
;signal_inversion:1:SND_SOC_DAIFMT_NB_NF(normal bit clock + frame)  use
;				  2:SND_SOC_DAIFMT_NB_IF(normal BCLK + inv FRM)
;				  3:SND_SOC_DAIFMT_IB_NF(invert BCLK + nor FRM)  use
;				  4:SND_SOC_DAIFMT_IB_IF(invert BCLK + FRM)
;over_sample_rate: support 128fs/192fs/256fs/384fs/512fs/768fs
;sample_resolution	:16bits/20bits/24bits
;word_select_size 	:16bits/20bits/24bits/32bits
;pcm_sync_period 	:16/32/64/128/256
;msb_lsb_first 		:0: msb first; 1: lsb first
;sign_extend 		:0: zero pending; 1: sign extend
;slot_index 		:slot index: 0: the 1st slot - 3: the 4th slot
;slot_width 		:8 bit width / 16 bit width
;frame_width 		:0: long frame = 2 clock width;  1: short frame
;tx_data_mode 		:0: 16bit linear PCM; 1: 8bit linear PCM; 2: 8bit u-law; 3: 8bit a-law
;rx_data_mode 		:0: 16bit linear PCM; 1: 8bit linear PCM; 2: 8bit u-law; 3: 8bit a-law
[tdm0]
daudio_used         = 0
daudio_master       = 4
daudio_select       = 1
audio_format        = 1
signal_inversion    = 1
mclk_fs             = 512
sample_resolution   = 16
slot_width_select   = 16
pcm_lrck_period     = 32
pcm_lrckr_period    = 1
msb_lsb_first 	    = 0
sign_extend         = 0
slot_index          = 0
slot_width          = 16
frame_width         = 1
tx_data_mode        = 0
rx_data_mode        = 0
;i2s_mclk           = port:PB08<2><1><default><default>
i2s_bclk            = port:PG11<2><1><default><default>
i2s_lrclk           = port:PG10<2><1><default><default>
i2s_dout0           = port:PG12<2><1><default><default>
i2s_dout1           =
i2s_dout2           =
i2s_dout3           =
i2s_din             = port:PG13<2><1><default><default>
;pa_single_vol,pa_double_vol: 31 level,1.5db/step.0x1f is the large volume.
;cap_val:use for system record,0x0--0db,0x1--24db,0x2--27db,0x3--30db,0x4--33db,0x5--36db,0x6--39db,0x7--42db
;headphone_vol,earpiece_vol: must least than 0x3b. 0x1 is a step.
;headset_mic_vol: headset mic(mic2) vol,use for phone headset mic call
;main_mic_vol: main mic(mic1) vol,use for phone main mic call
;version_v3_used : 1:v3,0:v3s
[audio0]
;audio_used           = 1
headphone_vol			= 0x3b
cap_vol					= 0x5
Differential_output    = 1
pa_single_vol			= 0x3f
pa_double_used			= 0
pa_double_vol			= 0x1f
headphone_direct_used	= 0
phone_mic_vol = 0x6
version_v3_used = 0
headphone_mute_used = 0
audio_hp_ldo       =none
;v3s
audio_pa_ctrl         = port:PE18<1><default><default><0>
adcagc_used       = 0
adcdrc_used       = 0
dacdrc_used       = 0
adchpf_used       = 0
dachpf_used       = 0
;ir --- infra remote configuration
[s_ir0]
ir_used             = 0
ir_rx               = port:PL04<2><1><default><default>
;ir_cut --- configuration
; if  iradc_reg_select = 0,select adc register data0  ; else iradc_reg_select = 1, select adc register data1
[ir_cut_para]
ir_cut_used = 1
lradc_vol_day_val = 19
ir_cut_led            = port:PG3<1><1><default><default>
ir_cut_ctl            = port:PG1<1><1><default><default>
;ir_cut_led            = port:PB8<1><1><default><default>
;ir_cut_ctl            = port:PB9<1><1><default><default>
[reset_key_para]
reset_key_used  =  1
reset_key_ctl         = port:PE19<0><1><default><default>
;pmu_used                    ---0:not used,1:used
;pmu_id                      ---0:axp19x,1:axp209,2:axp22x,3:axp806,4:axp808,5:axp809,6:axp803,7:axp813
;pmu_twi_addr                ---slave address
;pmu_twi_id                  ---i2c bus number (0 TWI0, 1 TWI2, 2 TWI3)
;pmu_irq_id		     ---irq number (0 irq0,1 irq1,…â€?
;pmu_battery_rdc             ---battery initial resistance
;pmu_battery_cap             ---battery capability,mAh
;pmu_batdeten		     ---battery detect en;0:disable 1:enable
;pmu_runtime_chgcur          ---set initial charging current limite,mAï¼?00/450/600/750/900/1050/1200/1350/1500/1650/1800/1950/
;pmu_earlysuspend_chgcur     ---set earlysuspend charging current limite,mAï¼?00/450/600/750/900/1050/1200/1350/1500/1650/1800/1950/
;pmu_suspend_chgcur          ---set suspend charging current limite,mAï¼?00/450/600/750/900/1050/1200/1350/1500/1650/1800/1950/
;pmu_shutdown_chgcur         ---set shutdown charging current limite,mAï¼?00/450/600/750/900/1050/1200/1350/1500/1650/1800/1950/
;pmu_init_chgvol             ---set initial charing target voltage,mV,4100/4220/4200/4240
;pmu_init_chgend_rate        ---set initial charing end current  rate,10/15
;pmu_init_chg_enabled        ---set initial charing enabled,0:disable,1:enable
;pmu_init_adc_freq           ---set initial adc frequency,Hz,100/200/400/800
;pmu_init_adcts_freq         ---set initial adc TS,Hz,100/200/400/800
;pmu_init_chg_pretime        ---set initial pre-charging time,min,40/50/60/70
;pmu_init_chg_csttime        ---set initial constance-charging time,min,360/480/600/720
;pmu_batt_cap_correct	     ---correct the battery capacity or not when one charge cycle 0:not correct 1:correct
;pmu_bat_regu_en			 ---bat regulator is enable or not when charge done 0:disable 1:enable
;pmu_bat_para1 		     			 ---battery indication at 3.13V
;pmu_bat_para2               ---battery indication at 3.27V
;pmu_bat_para3               ---battery indication at 3.34V
;pmu_bat_para4               ---battery indication at 3.41V
;pmu_bat_para5               ---battery indication at 3.48V
;pmu_bat_para6               ---battery indication at 3.52V
;pmu_bat_para7               ---battery indication at 3.55V
;pmu_bat_para8               ---battery indication at 3.57V
;pmu_bat_para9               ---battery indication at 3.59V
;pmu_bat_para10              ---battery indication at 3.61V
;pmu_bat_para11              ---battery indication at 3.63V
;pmu_bat_para12              ---battery indication at 3.64V
;pmu_bat_para13              ---battery indication at 3.66V
;pmu_bat_para14              ---battery indication at 3.7V
;pmu_bat_para15              ---battery indication at 3.73V
;pmu_bat_para16              ---battery indication at 3.77V
;pmu_bat_para17              ---battery indication at 3.78V
;pmu_bat_para18              ---battery indication at 3.8V
;pmu_bat_para19              ---battery indication at 3.82V
;pmu_bat_para20              ---battery indication at 3.84V
;pmu_bat_para21              ---battery indication at 3.85V
;pmu_bat_para22              ---battery indication at 3.87V
;pmu_bat_para23              ---battery indication at 3.91V
;pmu_bat_para24              ---battery indication at 3.94V
;pmu_bat_para25              ---battery indication at 3.98V
;pmu_bat_para26              ---battery indication at 4.01V
;pmu_bat_para27              ---battery indication at 4.05V
;pmu_bat_para28              ---battery indication at 4.08V
;pmu_bat_para29              ---battery indication at 4.1V
;pmu_bat_para30              ---battery indication at 4.12V
;pmu_bat_para31              ---battery indication at 4.14V
;pmu_bat_para32              ---battery indication at 4.15V
;pmu_usbvol_limit            ---set usb-ac limited voltage enable,1:enableï¼?:disable
;pmu_usbcur_limit            ---set usb-ac limited current enable,1:enableï¼?:disable
;pmu_usbvol                  ---set usb-ac limited voltage level,mV,4000/4100/4200/4300/4400/4500/4600/4700,0 - not limite
;pmu_usbcur                  ---set usb-ac limited current level,mA,500/900, 0 - not limite
;pmu_usbvol_pc	             ---set usb-pc limited voltage level,mV,4000/4100/4200/4300/4400/4500/4600/4700,0 - not limite
;pmu_usbcur_pc               ---set usb-pc limited current level,mA,500/900, 0 - not limite
;pmu_pwroff_vol              ---set protect voltage when system start up,mV,2600/2700/2800/2900/3000/3100/3200/3300
;pmu_pwron_vol               ---set protect voltage after system start up,mV,2600/2700/2800/2900/3000/3100/3200/3300
;pmu_pekoff_time             ---set pek off time,ms, 4000/6000/8000/10000
;pmu_pekoff_func             ---set pek off func, 0:shutdown,1:restart
;pmu_pekoff_en		     ---set pek offlevel powerdown or not, 0:not powerdown,1:powerdown
;pmu_peklong_time            ---set pek pek long irq time,ms,1000/1500/2000/2500
;pmu_pekon_time              ---set pek on time,ms,128/1000/2000/3000
;pmu_pwrok_time              ---set pmu pwrok delay time,ms,8/16/32/64
;pmu_battery_warning_level1  ---low power warning high level,5%-20%,1%/step
;pmu_battery_warning_level2  ---low power warning low level,0%-15%,1%/step
;pmu_restvol_time            ---battery indicaton reflash time,30/60/120/
;pmu_ocv_cou_adjust_time     ---ocv battery indication reflash time,60/120/30
;pmu_chgled_func             ---CHGKED pin controlï¼?:controlled by pmu,1:controlled by Charger
;pmu_chgled_type             ---CHGLED Type select when pmu_chgled_func=0,0:Type Aï¼?:Type B
;pmu_vbusen_func	     ---N_VBUSEN function select,0:as an output,1:as an input
;pmu_reset                   ---when power key press longer than 16's,PMU reset or not.0:not reset 1:reset
;pmu_IRQ_wakeup		     ---press IRQ wakeup or not when sleep or power down.0:not wakeup 1:wakeup
;pmu_hot_shutdowm            ---when PMU over temperature protect or not;0:disable 1:enable
;pmu_inshort		     ---ACIN and VBUS inshort or not by software;0:auto detect 1:inshort
;pmu_temp_enable             ---temp detect enable
;pmu_charge_ltf              ---charge temp low threshold voltage
;pmu_charge_htf              ---charge temp high threshold voltage
;pmu_discharge_ltf           ---shutdown temp low threshold voltage
;pmu_discharge_htf           ---shutdown temp high threshold voltage
;pmu_temp_para1              --- temp -25 voltage
;pmu_temp_para2              --- temp -15 voltage
;pmu_temp_para3              --- temp -10 voltage
;pmu_temp_para4              --- temp -5  voltage
;pmu_temp_para5              --- temp  0  voltage
;pmu_temp_para6              --- temp  5  voltage
;pmu_temp_para7              --- temp  10 voltage
;pmu_temp_para8              --- temp  20 voltage
;pmu_temp_para9              --- temp  30 voltage
;pmu_temp_para10             --- temp  40 voltage
;pmu_temp_para11             --- temp  45 voltage
;pmu_temp_para12             --- temp  50 voltage
;pmu_temp_para13             --- temp  55 voltage
;pmu_temp_para14             --- temp  60 voltage
;pmu_temp_para15             --- temp  70 voltage
;pmu_temp_para16             --- temp  80 voltage
[pmu1_para]
pmu_used                   = 1
pmu_id                     = 1
pmu_twi_addr               = 0x34
pmu_twi_id                 = 0
pmu_irq_id                 = 64
pmu_irq_gpio		   = port:PG05<6><default><default><default>
pmu_battery_rdc            = 249
pmu_battery_cap            = 183
pmu_batdeten               = 1
pmu_runtime_chgcur         = 300
pmu_earlysuspend_chgcur    = 300
pmu_suspend_chgcur         = 300
pmu_shutdown_chgcur        = 300
pmu_init_chgvol            = 4200
pmu_init_chgend_rate       = 15
pmu_init_chg_enabled       = 1
pmu_init_adc_freq          = 100
pmu_init_chg_pretime       = 50
pmu_init_chg_csttime       = 720
pmu_bat_para1=0
pmu_bat_para2=0
pmu_bat_para3=0
pmu_bat_para4=0
pmu_bat_para5=8
pmu_bat_para6=16
pmu_bat_para7=25
pmu_bat_para8=37
pmu_bat_para9=47
pmu_bat_para10=55
pmu_bat_para11=61
pmu_bat_para12=68
pmu_bat_para13=79
pmu_bat_para14=87
pmu_bat_para15=94
pmu_bat_para16=100
pmu_usbvol_limit           = 1
pmu_usbcur_limit           = 0
pmu_usbvol                 = 4000
pmu_usbcur                 = 0
pmu_usbvol_pc            = 4000
pmu_usbcur_pc            = 0
pmu_pwroff_vol             = 3300
pmu_pwron_vol            = 2900
pmu_pekoff_time            = 6000
pmu_pekoff_en              = 1
pmu_peklong_time           = 1500
pmu_pekon_time             = 1000
pmu_pwrok_time             = 64
pmu_pwrnoe_time          = 2000
pmu_hot_shutdown            = 1
pmu_suspendpwroff_vol    = 3500
power_start              = 3
[pmu1_regu]
regulator_count = 7
regulator1      = "axp20_dcdc2 none vdd-sys vdd-cpu vdd-ephy"
regulator2      = "axp20_dcdc3 none vcc-io hpvcc vcc-pd vcc-usb vcc-ephy vcc-mcsi vcc-lcd vcc-wifi vcc-device vcc-csi vcc-ctp"
regulator3      = "axp20_ldo1 none vcc-rtc"
regulator4      = "axp20_ldo2 none  vcc-avcc vcc-pll"
regulator5      = "axp20_ldo3 none vcc-pe csi-avdd"
regulator6      = "axp20_ldo4 none csi-dvdd"
regulator7      = "axp20_ldoio0 none"
; dvfs voltage-frequency table configuration
; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk
;                     1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator
; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz
; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz
; LV_count: count of LV_freq/LV_volt, must be < 16
; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz,  1536Mhz]
; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz,  1296Mhz]
; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz,  1200Mhz]
; LV4: core vdd is 1.20v if cpu frequency is (816Mhz,   1008Mhz]
; LV5: core vdd is 1.10v if cpu frequency is (648Mhz,    816Mhz]
; LV6: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
; LV7: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
; LV8: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
[dvfs_table]
extremity_freq = 1008000000
max_freq = 1008000000
min_freq = 60000000
LV_count = 8
LV1_freq = 1008000000
LV1_volt = 1200
LV2_freq = 1008000000
LV2_volt = 1200
LV3_freq = 940000000
LV3_volt = 1200
LV4_freq = 940000000
LV4_volt = 1200
LV5_freq = 816000000
LV5_volt = 1100
LV6_freq = 648000000
LV6_volt = 1040
LV7_freq = 0
LV7_volt = 1040
LV8_freq = 0
LV8_volt = 1040
;virtual device
;virtual device for pinctrl testing
;device have pin PA1 PA2
[Vdevice]
Vdevice_used        = 1
Vdevice_0           = port:PA01<5><1><2><default>
Vdevice_1           = port:PA02<5><1><2><default>
; dram dvfs voltage-frequency table configuration
; LV1: core vdd is 1.1v if dram frequency is (360Mhz, 552Mhz]
; LV2: core vdd is 1.0v if dram frequency is (  0Mhz, 360Mhz]
; LV3: core vdd is 1.0v if dram frequency is (  0Mhz, 360Mhz]
[dram_dvfs_table]
LV_count = 3
LV1_freq = 552000000
LV1_volt = 1100
LV2_freq = 360000000
LV2_volt = 1000
LV3_freq = 0
LV3_volt = 1000
;[fel_key]
;fel_key_used =  1
;fel_key_min  =  0
;fel_key_max  = 	60
[leds_para]
leds_used = 1
led_0 = port:PG04<1><default><default><0>
led_0_active_low = 0
;led_1 = port:PB09<1><default><default><0>
;led_1_active_low = 0
;led_2 = port:PA00<1><default><default><0>
;led_2_active_low = 0
;led_3 = port:PA00<1><default><default><0>
;led_3_active_low = 0
;led_4 = port:PA00<1><default><default><0>
;led_4_active_low = 0
;led_5 = port:PA00<1><default><default><0>
;led_5_active_low = 0
;led_6 = port:PA00<1><default><default><0>
;led_6_active_low = 0
;led_7 = port:PA00<1><default><default><0>
;led_7_active_low = 0
路过大佬帮忙看看
#1 2021-07-30 21:06:44
所在地: 你猜
已发帖子: 3,380
Re: V3s 一直重复启动 boot 大佬帮忙看看
dram_type       = 2
这里改成
dram_type       = 3
试一试
#2 2021-07-30 21:23:31
所在地: 你猜
已发帖子: 3,380
dram_type       = 2
这里改成
dram_type       = 3
试一试
貌似ddr其他参数还要改,找下s3 sdk ddr3 的参数。
#3 2021-07-30 21:51:14
所在地: 你猜
已发帖子: 3,380
缺这个,没有读出boot1
① 确认有没有写进去
② 检查DDR电压?给DDR降频
③ 用主线uboot或者xfel测试ddr工作是否正常
楼主 #4 2021-08-13 14:19:31
xiaoqianxiansheng
已发帖子: 35
找到问题了,SZQ的电阻不对,导致 初始化dram失败。
