楼主 # 2021-08-07 19:57:55
XIVN1987
已发帖子: 237
dw-apb-uart ff0a0000.serial: set rate:3686400, but get rate:3428572
linux console设置波特率115200,逻辑分析仪实测为107142,,开机打印信息如下:
[    0.199149] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    0.201430] console [ttyS0] disabled
[    0.201514] ff0a0000.serial: ttyS0 at MMIO 0xff0a0000 (irq = 10, base_baud = 1500000) is a 16550A
[    0.201693] clk_uart0_frac parent_rate(24000000) is low than rate(3686400)*20, fractional div is not allowed
[    0.201789] clk_uart0_frac parent_rate(24000000) is low than rate(3760128)*20, fractional div is not allowed
[    0.201811] dw-apb-uart ff0a0000.serial: set rate:3686400, but get rate:3428572
[    1.240605] console [ttyS0] enabled
是不是因为UART0时钟除以115200波特率商不是整数导致的?如果换个其他波特率的话,应该能得到准确波特率
不过如果希望继续用115200的话,,请问应该怎么设置?
楼主 #1 2021-09-02 22:32:53
XIVN1987
已发帖子: 237
Re: dw-apb-uart ff0a0000.serial: set rate:3686400, but get rate:3428572
问题解决了,,解决方法:
将 drivers/tty/serial/8250/8250_dw.c 中函数 dw8250_set_termios() 里面的
#ifdef CONFIG_ARCH_ROCKCHIP
	if ((baud * 16) <= 4000000) {
		 * Make sure uart sclk is high enough
		div = 4000000 / baud / 16;
		rate = baud * 16 * div;
	} else {
		rate = baud * 16;
	ret = clk_set_rate(d->clk, rate);
	rate_temp = clk_get_rate(d->clk);
	diff = rate * 20 / 1000;
	 * If rate_temp is not equal to rate, is means fractional frequency
	 * division is failed. Then use Integer frequency division, and
	 * the buad rate error must be under -+2%
	if ((rate_temp < rate) && ((rate - rate_temp) > diff)) {
		ret = clk_set_rate(d->clk, rate + diff);
			dev_info(p->dev, "set rate:%d, but get rate:%d\n",
				 rate, rate_temp);
		else if ((rate < rate_temp) && ((rate_temp - rate) > diff))
				 rate, rate_temp);
#else
替换为:
	rate = clk_get_rate(clk_get_parent(d->clk));
#else
