在论坛里翻看了许多大家发的入门帖子,奈何本人十分小白,在自己编译A33 linux固件的时候启动问题,现在放出启动时串口输出,请大家闲暇之余帮我分析下问题,在这里谢谢大家了
HELLO! BOOT0 is starting!
boot0 version : 3.1.0
reg_addr 0x01f00100 =0x00000000
reg_addr 0x01f00104 =0x00000000
reg_addr 0x01f00108 =0x00000000
reg_addr 0x01f0010c =0x00000000
reg_addr 0x01f00110 =0x00000000
reg_addr 0x01f00114 =0x00000000
DRAM DRIVE INFO: V1.5
DRAM CLK =552 MHZ
DRAM simple test OK.
dram size =512
card boot number = 2
card no is 2
sdcard 2 line count 0
[mmc]: mmc driver ver 2014-07-07 16:54
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 timeout, err 0x00000100
[mmc]: mmc 2 cmd 8 err 0x00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 timeout, err 0x00000100
[mmc]: mmc 2 cmd 55 err 0x00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: MMC ver 4.0
[mmc]: SD/MMC Card: 4bit, capacity: 7456MB
[mmc]: vendor: Man 0x00150100 Snr 0x01dd06b4
[mmc]: product: 8GME4
[mmc]: revision: 5.2
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
The size of uboot is 0x000bc000.
sum=0x463dbb11
src_sum=0x463dbb11
set_mmc_para,sdly 50M 0
set_mmc_para,sdly 25M 0
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
[ 0.332]
U-Boot 2011.09-rc1-00004-ga1ab41d (Jul 28 2014 - 16:21:09) Allwinner Technology
[ 0.340]version: 1.1.0
[ 0.427]pmbus: ready
[ 0.429]PMU: AXP221
[ 0.431]PMU: AXP22x found
[ 0.435]PMU: dcdc3 1200
[ 0.438]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
set power on vol to default
dcdc1_vol = 3000
dcdc2_vol = 1100
dcdc3_vol = 1200
dcdc4_vol = 0
dcdc5_vol = 1500
aldo2_vol = 2500
aldo3_vol = 3000
dldo3_vol = 3300
find power_sply to end
no battery, limit to dc
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[ 0.488]DRAM: 512 MiB
relocation Offset is: 15b11000
smcl's set manager is NULL
workmode = 0
MMC: 2
[ 0.686][mmc]: mmc driver ver 2014-07-15 17:16:00
[ 0.691][mmc]: get sdc_2xmode ok, val = 1
[ 0.695][mmc]: get sdc_f_max fail,use default sdc_f_max 50000000
[ 0.701][mmc]: get card_line ok, card_line = 4
[ 0.706][mmc]: get sdc_ex_dly_used fail,use default dly
[ 0.711][mmc]: SUNXI SD/MMC: 2
[ 0.715][mmc]: mmc 2 2xmode config clk
[ 0.728][mmc]: ************Try SD card 2************
[ 0.733][mmc]: mmc 2 cmd 8 timeout, err 100
[ 0.738][mmc]: smc 2 err, cmd 8, RTO
[ 0.743][mmc]: mmc 2 mmc cmd 8 err 0x00000100
[ 0.747][mmc]: mmc send if cond failed
[ 0.751][mmc]: mmc 2 cmd 55 timeout, err 100
[ 0.755][mmc]: smc 2 err, cmd 55, RTO
[ 0.761][mmc]: mmc 2 mmc cmd 55 err 0x00000100
[ 0.765][mmc]: send app cmd failed
[ 0.768][mmc]: ************Try MMC card 2************
[ 0.793][mmc]: Invalid ext_csd revision 8
[ 0.797][mmc]: mmc 2 2xmode config clk
[ 0.807][mmc]: mmc 2 2xmode config clk
[ 0.817][mmc]: mmc 2 2xmode config clk
[ 0.826][mmc]: MID 000015 PSN dd06b4db
[ 0.829][mmc]: PNM 8GME4R -- 0x38-47-4d-45-34-52
[ 0.834][mmc]: PRV 0.1
[ 0.837][mmc]: MDT m-12 y-2016
[ 0.840][mmc]: MMC ver 4.0
[ 0.843][mmc]: ---------------mmc->clock 50000000-----------
[ 0.848][mmc]: ---------------mmc->bus_width 4--------------
[ 0.854][mmc]: SD/MMC Card: 4bit, capacity: 7456MB
[ 0.859][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[ 0.865][mmc]: ************SD/MMC 2 init OK!!!************
[ 0.871]sunxi flash init ok
In: serial
Out: serial
Err: serial
-total partitions:6-
-name- -start- -size-
boot-res : 1000000 1000000
env : 2000000 1000000
boot : 3000000 1000000
rootfs : 4000000 40000000
data : 44000000 40000000
UDISK : 84000000 0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
recovery key high 5, low 3
cant find fstbt value
no misc partition is found
misc_message->command = 0
to be run cmd=run setargs_mmc boot_normal
mount part name boot-res
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
sunxi_bmp_logo_display
[ 0.977][mmc]: blkcnt should not be 0
screen_id =0, screen_width =1024, screen_height =600
[ 0.988]Hit any key to stop autoboot: 0
read boot or recovery all
[ 1.573]sunxi flash read :offset 3000000, 13875259 bytes OK
no signature
[ 1.583]ready to boot
para err in disp_ioctl, cmd = 0xa,screen id = 1
[ 1.590][mmc]: mmc exit start
[ 1.594][mmc]: mmc 2 2xmode config clk
[ 1.604][mmc]: mmc 2 2xmode config clk
[ 1.616][mmc]: mmc 2 cmd 8 timeout, err 100
[ 1.621][mmc]: smc 2 err, cmd 8, RTO
[ 1.626][mmc]: mmc 2 mmc cmd 8 err 0x00000100
[ 1.630][mmc]: mmc send if cond failed
[ 1.634][mmc]: mmc 2 cmd 55 timeout, err 100
[ 1.638][mmc]: smc 2 err, cmd 55, RTO
[ 1.644][mmc]: mmc 2 mmc cmd 55 err 0x00000100
[ 1.648][mmc]: send app cmd failed
[ 1.658][mmc]: mmc 2 exit ok
[ 1.661]
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4.39 (root@sonder-virtual-machine) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #9 SMP PREEMPT Sat Aug 21 21:42:17 CST 2021
[ 0.000000] Machine: sun8i
[ 0.000000] cma: CMA: reserved 120 MiB at 58800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] script_init enter!
[ 0.000000] script_init exit!
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0fb9000 s10688 r8192 d13888 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p7 init=/init ion_cma_512m=120m ion_cma_1g=176m ion_carveout_512m=96m ion_carveout_1g=150m coherent_pool=4m loglevel=7 partitions=boot-res@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:rootfs@mmcblk0p7:data@mmcblk0p8:UDISK@mmcblk0p1 boot_type=2 config_size=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 512MB = 512MB total
[ 0.000000] Memory: 381872k/381872k available, 142416k reserved, 0K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08ea6e0 (9098 kB)
[ 0.000000] .init : 0xc08eb000 - 0xc093d9c0 ( 331 kB)
[ 0.000000] .data : 0xc093e000 - 0xc09b8bc0 ( 491 kB)
[ 0.000000] .bss : 0xc09ba098 - 0xc0b21f08 (1440 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:416
[ 0.000000] try to syncboot of clk ats
[ 0.000000] try to syncboot of clk sdmmc2
[ 0.000000] try to syncboot of clk uart0
[ 0.000000] try to syncboot of clk pll_ddr1
[ 0.000000] try to syncboot of clk debe0
[ 0.000000] try to syncboot of clk dma
[ 0.000000] try to syncboot of clk sat
[ 0.000000] try to syncboot of clk pio
[ 0.000000] try to syncboot of clk mbus
[ 0.000000] try to syncboot of clk drc0
[ 0.000000] try to syncboot of clk lcd0ch0
[ 0.000000] try to syncboot of clk axi
[ 0.000000] Architected local timer running at 24.00MHz.
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000241] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[ 0.000268] pid_max: default: 32768 minimum: 301
[ 0.000493] Security Framework initialized
[ 0.000546] SELinux: Initializing.
[ 0.000625] AppArmor: AppArmor disabled by boot time parameter
[ 0.000729] Mount-cache hash table entries: 512
[ 0.001834] Initializing cgroup subsys debug
[ 0.001853] Initializing cgroup subsys cpuacct
[ 0.001865] Initializing cgroup subsys freezer
[ 0.001910] CPU: Testing write buffer coherency: ok
[ 0.001964] ftrace: allocating 23575 entries in 70 pages
[ 0.030327] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.030348] [sunxi_smp_prepare_cpus] enter
[ 0.030395] Setting up static identity map for 0x4063a030 - 0x4063a088
[ 0.010000] CPU1: Booted secondary processor
[ 0.010000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.010000] CPU2: Booted secondary processor
[ 0.010000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010000] CPU3: Booted secondary processor
[ 0.010000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.210184] Brought up 4 CPUs
[ 0.210184] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[ 0.210432] devtmpfs: initialized
[ 0.214465] pinctrl core: initialized pinctrl subsystem
[ 0.220335] dummy:
[ 0.225472] NET: Registered protocol family 16
[ 0.242678] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.242780] script_sysfs_init success
[ 0.243098] sunxi pinctrl probe enter
[ 0.243819] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[ 0.245468] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[ 0.245694] axp_pinctrl_probe enter...
[ 0.245872] gpiochip_add: registered GPIOs 1024 to 1029 on device: axp-pinctrl
[ 0.245892] mainkey total count : 84
[ 0.245903] mainkey name : product, pin count : 0
[ 0.245913] mainkey name : platform, pin count : 0
[ 0.245923] mainkey name : target, pin count : 0
[ 0.245933] mainkey name : key_detect_en, pin count : 0
[ 0.245943] mainkey name : power_sply, pin count : 0
[ 0.245953] mainkey name : card_boot, pin count : 0
[ 0.245963] mainkey name : card0_boot_para, pin count : 6
[ 0.245976] mainkey name : card2_boot_para, pin count : 6
[ 0.245989] mainkey name : twi_para, pin count : 2
[ 0.246001] mainkey name : uart_para, pin count : 2
[ 0.246013] mainkey name : force_uart_para, pin count : 2
[ 0.246024] mainkey name : jtag_para, pin count : 4
[ 0.246035] mainkey name : clock, pin count : 0
[ 0.246045] mainkey name : pm_para, pin count : 0
[ 0.246055] mainkey name : dram_para, pin count : 0
[ 0.246065] mainkey name : pm_para, pin count : 0
[ 0.246075] mainkey name : wakeup_src_para, pin count : 2
[ 0.246085] mainkey name : twi0, pin count : 2
[ 0.246096] mainkey name : twi1, pin count : 2
[ 0.246106] mainkey name : twi2, pin count : 2
[ 0.246116] mainkey name : uart0, pin count : 2
[ 0.246127] mainkey name : uart1, pin count : 4
[ 0.246137] mainkey name : uart2, pin count : 2
[ 0.246148] mainkey name : uart3, pin count : 2
[ 0.246158] mainkey name : uart4, pin count : 4
[ 0.246169] mainkey name : spi0, pin count : 4
[ 0.246179] mainkey name : spi1, pin count : 4
[ 0.246190] mainkey name : spi_devices, pin count : 0
[ 0.246200] mainkey name : spi_board0, pin count : 0
[ 0.246210] mainkey name : ctp_para, pin count : 2
[ 0.246221] mainkey name : ctp_list_para, pin count : 0
[ 0.246232] mainkey name : tkey_para, pin count : 0
[ 0.246242] mainkey name : motor_para, pin count : 1
[ 0.246254] map mainkey [motor_para] to pinctrl, map number [2]
[ 0.246268] mainkey name : ths_para, pin count : 0
[ 0.246278] mainkey name : cooler_table, pin count : 0
[ 0.246288] mainkey name : nand0_para, pin count : 19
[ 0.246302] mainkey name : disp_init, pin count : 0
[ 0.246314] mainkey name : mipi_para, pin count : 3
[ 0.246327] map mainkey [mipi_para] to pinctrl, map number [2]
[ 0.246341] mainkey name : lvds_para, pin count : 17
[ 0.246354] map mainkey [lvds_para] to pinctrl, map number [2]
[ 0.246367] mainkey name : rgb_para, pin count : 31
[ 0.246380] map mainkey [rgb_para] to pinctrl, map number [2]
[ 0.246401] mainkey name : lcd1_para, pin count : 3
[ 0.246412] map mainkey [lcd1_para] to pinctrl, map number [2]
[ 0.246427] mainkey name : lcd0_para, pin count : 31
[ 0.246442] map mainkey [lcd0_para] to pinctrl, map number [2]
[ 0.246456] mainkey name : ad_tm7706_para, pin count : 8
[ 0.246469] mainkey name : gpio_para, pin count : 7
[ 0.246482] mainkey name : ext_rtc_para, pin count : 0
[ 0.246494] mainkey name : pwm0_para, pin count : 1
[ 0.246507] mainkey name : pwm1_para, pin count : 1
[ 0.246519] mainkey name : csi0, pin count : 16
[ 0.246532] mainkey name : mmc0_para, pin count : 7
[ 0.246545] mainkey name : mmc1_para, pin count : 6
[ 0.246557] mainkey name : mmc2_para, pin count : 11
[ 0.246570] mainkey name : usbc0, pin count : 2
[ 0.246582] map mainkey [usbc0] to pinctrl, map number [2]
[ 0.246597] mainkey name : usbc1, pin count : 0
[ 0.246609] mainkey name : usb_feature, pin count : 0
[ 0.246621] mainkey name : msc_feature, pin count : 0
[ 0.246633] mainkey name : serial_feature, pin count : 0
[ 0.246645] mainkey name : gsensor_para, pin count : 1
[ 0.246656] mainkey name : gsensor_list_para, pin count : 0
[ 0.246667] mainkey name : gps_para, pin count : 0
[ 0.246677] mainkey name : wifi_para, pin count : 8
[ 0.246689] mainkey name : bt_para, pin count : 0
[ 0.246699] mainkey name : 3g_para, pin count : 4
[ 0.246710] mainkey name : gy_para, pin count : 0
[ 0.246721] mainkey name : gy_list_para, pin count : 0
[ 0.246731] mainkey name : ls_para, pin count : 1
[ 0.246742] mainkey name : ls_list_para, pin count : 0
[ 0.246753] mainkey name : compass_para, pin count : 0
[ 0.246764] mainkey name : i2s0, pin count : 4
[ 0.246775] mainkey name : i2s1, pin count : 4
[ 0.246786] mainkey name : audio0, pin count : 1
[ 0.246796] mainkey name : pmu1_para, pin count : 0
[ 0.246807] mainkey name : pmu2_para, pin count : 0
[ 0.246818] mainkey name : recovery_key, pin count : 0
[ 0.246828] mainkey name : dvfs_table, pin count : 0
[ 0.246839] mainkey name : Vdevice, pin count : 2
[ 0.246850] mainkey name : s_uart0, pin count : 2
[ 0.246861] mainkey name : s_rsb0, pin count : 2
[ 0.246872] mainkey name : s_jtag0, pin count : 4
[ 0.246884] mainkey name : s_powchk, pin count : 0
[ 0.246894] mainkey name : mali_para, pin count : 0
[ 0.246905] mainkey name : dram_dvfs_table, pin count : 0
[ 0.246916] mainkey name : charging_type, pin count : 0
[ 0.246927] mainkey name : dram_scene_table, pin count : 0
[ 0.246938] mainkey name : leds_para, pin count : 2
[ 0.246950] map mainkey [leds_para] to pinctrl, map number [4]
[ 0.246961] axp pinctrl driver probe ok
[ 0.248456] [sunxi-module]: [sunxi-module.0] probe success
[ 0.248504] script config pll3 to 297 Mhz
[ 0.248520] script config pll4 to 300 Mhz
[ 0.248554] script config pll6 to 600 Mhz
[ 0.248568] script config pll8 to 408 Mhz
[ 0.248590] script config pll9 to 480 Mhz
[ 0.248604] script config pll10 to 297 Mhz
[ 0.248613] sunxi_default_clk_init
[ 0.248621] try to set pll6ahb1 to 200000000
[ 0.248673] try to set ahb clk source to pll6ahb1
[ 0.248682] set ahb clk source to pll6ahb1
[ 0.248694] try to set ahb1 to 200000000
[ 0.248705] try to set apb1 to 100000000
[ 0.260302] bio: create slab <bio-0> at 0
[ 0.260492] [ARISC] :sunxi-arisc driver v1.60
[ 0.293964] [ARISC] :arisc version: [v0.0.76]
[ 0.293977] [sunxi-module]: arisc register success
[ 0.513280] [ARISC] :sunxi-arisc driver v1.60 startup succeeded
[ 0.514649] SCSI subsystem initialized
[ 0.514649] usbcore: registered new interface driver usbfs
[ 0.514649] usbcore: registered new interface driver hub
[ 0.514649] usbcore: registered new device driver usb
[ 0.514649] twi_chan_cfg()350 - [twi0] has no twi_regulator.
[ 0.514649] twi_chan_cfg()350 - [twi1] has no twi_regulator.
[ 0.514649] twi_chan_cfg()350 - [twi2] has no twi_regulator.
[ 0.514649] Linux video capture interface: v2.00
[ 0.520042] axp22_board axp22_board: AXP (CHIP ID: 0x06) detected
[ 0.522059] axp22_dcdc1: 1600 <--> 3400 mV at 3000 mV
[ 0.522059] axp22_dcdc2: 600 <--> 1540 mV at 1100 mV
[ 0.522059] axp22_dcdc3: 600 <--> 1860 mV at 1200 mV
[ 0.522059] axp22_dcdc4: 600 <--> 1540 mV at 1100 mV
[ 0.522059] axp22_dcdc5: 1000 <--> 2550 mV at 1500 mV
[ 0.522059] axp22_rtc: 3000 mV
[ 0.522059] axp22_aldo1: 700 <--> 3300 mV at 3000 mV
[ 0.522059] axp22_aldo2: 700 <--> 3300 mV at 2500 mV
[ 0.522059] axp22_aldo3: 700 <--> 3300 mV at 3000 mV
[ 0.522059] axp22_dldo1: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_dldo2: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_dldo3: 700 <--> 3300 mV at 3300 mV
[ 0.522059] axp22_dldo4: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_eldo1: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_eldo1: supplied by axp22_dcdc1
[ 0.522059] axp22_eldo2: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_eldo2: supplied by axp22_dcdc1
[ 0.522059] axp22_eldo3: 700 <--> 3300 mV at 700 mV
[ 0.522059] axp22_eldo3: supplied by axp22_dcdc1
[ 0.522059] axp22_dc5ldo: 700 <--> 1400 mV at 1100 mV
[ 0.522059] axp22_ldoio0: 700 <--> 3300 mV at 3800 mV
[ 0.522059] axp22_ldoio1: 700 <--> 3300 mV at 3800 mV
[ 0.522059] axp22_dc1sw: at 700 mV
[ 0.522059] axp22_dc1sw: supplied by axp22_dcdc1
[ 0.522059] input: axp22-supplyer as /devices/platform/axp22_board/axp22-supplyer.20/input/input0
[ 0.530674] now_rest_vol = 100
[ 0.530674] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.530885] Bluetooth: Core ver 2.16
[ 0.530958] NET: Registered protocol family 31
[ 0.530971] Bluetooth: HCI device and connection manager initialized
[ 0.530985] Bluetooth: HCI socket layer initialized
[ 0.530997] Bluetooth: L2CAP socket layer initialized
[ 0.531028] Bluetooth: SCO socket layer initialized
[ 0.531318] cfg80211: Calling CRDA to update world regulatory domain
[ 0.531355] Switching to clocksource arch_sys_counter
[ 0.553536] FS-Cache: Loaded
[ 0.553892] CacheFiles: Loaded
[ 0.565166] [sunxi_hci_sunxi]: sunxi-ehci1(restrict_gpio) is invalid
[ 0.565182] [sunxi_hci_sunxi]: sunxi-ehci1(drv vbus) is invalid
[ 0.565197] [sunxi_hci_sunxi]: get usb_regulator is nocare
[ 0.565229] [sunxi_hci_sunxi]: sunxi-ohci1(restrict_gpio) is invalid
[ 0.565241] [sunxi_hci_sunxi]: sunxi-ohci1(drv vbus) is invalid
[ 0.565254] [sunxi_hci_sunxi]: get usb_regulator is nocare
[ 0.565485] [usb_manager]: CONFIG_USB_SUNXI_USB0_OTG
[ 0.565512] no usbc(0) det_vbus gpio and try to axp det_pin
[ 0.565526] get usbc0(usb_restrict pin) failed
[ 0.565924] [sw_udc]: udc_init: version 20080411
[ 0.566428] [ddrfreq] dram_clk value is 552
[ 0.566439] [ddrfreq] sunxi_ddrfreq_max=552000
[ 0.566450] [ddrfreq] dram_type value is 3
[ 0.566461] [ddrfreq] dram_zq value is 0x3bbb
[ 0.566470] [ddrfreq] dram_odt_en value is 1
[ 0.566481] [ddrfreq] dram_para1 value is 0x10f20200
[ 0.566491] [ddrfreq] dram_para2 value is 0x0
[ 0.566502] [ddrfreq] dram_mr0 value is 0x1c70
[ 0.566512] [ddrfreq] dram_mr1 value is 0x40
[ 0.566522] [ddrfreq] dram_mr2 value is 0x18
[ 0.566532] [ddrfreq] dram_mr3 value is 0x0
[ 0.566542] [ddrfreq] dram_tpr0 value is 0x47214f
[ 0.566552] [ddrfreq] dram_tpr1 value is 0x1c2294b
[ 0.566563] [ddrfreq] dram_tpr2 value is 0x61043
[ 0.566573] [ddrfreq] dram_tpr3 value is 0x0
[ 0.566583] [ddrfreq] dram_tpr4 value is 0x0
[ 0.566593] [ddrfreq] dram_tpr5 value is 0x0
[ 0.566603] [ddrfreq] dram_tpr6 value is 0x0
[ 0.566613] [ddrfreq] dram_tpr7 value is 0x0
[ 0.566623] [ddrfreq] dram_tpr8 value is 0x0
[ 0.566633] [ddrfreq] dram_tpr9 value is 0x0
[ 0.566643] [ddrfreq] dram_tpr10 value is 0x0
[ 0.566653] [ddrfreq] dram_tpr11 value is 0x0
[ 0.566664] [ddrfreq] dram_tpr12 value is 168
[ 0.566673] [ddrfreq] sunxi_ddrfreq_min=168000
[ 0.566683] [ddrfreq] dram_tpr13 value is 0x10901
[ 0.566880] [dsm] use sysconfig
[ 0.566889] [dsm] -----------Dram scene-freq Table------------
[ 0.566901] [dsm] scene = 0 frequency = 552000KHz
[ 0.566911] [dsm] scene = 1 frequency = 360000KHz
[ 0.566921] [dsm] scene = 2 frequency = 240000KHz
[ 0.566931] [dsm] scene = 3 frequency = 168000KHz
[ 0.566940] [dsm] --------------------------------------------
[ 0.567077] [ddrfreq] LV_count value is 3
[ 0.567100] [ddrfreq] ---------------Dram V-F Table---------------
[ 0.567112] [ddrfreq] voltage = 1100mv frequency = 552000KHz
[ 0.567122] [ddrfreq] voltage = 1100mv frequency = 360000KHz
[ 0.567133] [ddrfreq] voltage = 1100mv frequency = 0KHz
[ 0.567142] [ddrfreq] --------------------------------------------
[ 0.567320] [ddrfreq] last_vdd=1100
[ 0.567400] [ddrfreq] __sram_start: 0xc09b9000, __sram_end: 0xc09ba074, __sram_text_start: 0xf0000000, __sram_data_end: 0xf0001074
[ 0.567415] [ddrfreq] sunxi dramfreq probe ok!
[ 0.567761] NET: Registered protocol family 2
[ 0.568061] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.568725] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.568993] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[ 0.569235] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.569248] TCP: reno registered
[ 0.569263] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.569290] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.569626] NET: Registered protocol family 1
[ 0.570121] RPC: Registered named UNIX socket transport module.
[ 0.570133] RPC: Registered udp transport module.
[ 0.570143] RPC: Registered tcp transport module.
[ 0.570152] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.570413] Unpacking initramfs...
[ 0.748160] Freeing initrd memory: 2596K
[ 0.748641] [pm]aw_pm_init!
[ 0.748654] standby_mode = 1.
[ 0.748663] wakeup src cnt is : 2.
[ 0.748675] [exstandby]leave extended_standby_enable_wakeup_src : event 0x2000
[ 0.748687] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x80
[ 0.748700] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[ 0.748712] [exstandby]leave extended_standby_enable_wakeup_src : event 0x2000
[ 0.748724] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x280
[ 0.748736] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[ 0.748761] [wifi]: select wifi: rtl8189es !!
[ 0.749049] [rtl8189es]: exec rtl8189es_wifi_gpio_init
[ 0.749064] [rtl8189es]: module power name axp22_aldo1
[ 0.749076] [rtl8189es]: module power ext1 name axp22_dldo1
[ 0.749087] [rtl8189es]: module power ext2 name axp22_dldo2
[ 0.749099] [rtl8189es]: rtl8189es module power set by axp.
[ 0.749291] [rtl8189es]: first time
[ 0.749553] [rtl8189es]: regulator on.
[ 0.851610] gpio rtl8189es_shdn set val 0, act val 0
[ 0.851645] [wifi_pm]: wifi gpio init is OK !!
[ 0.851705] sunxi_reg_init enter
[ 0.852615] audit: initializing netlink socket (disabled)
[ 0.852680] type=2000 audit(0.850:1): initialized
[ 0.855382] NTFS driver 2.1.30 [Flags: R/W].
[ 0.855589] fuse init (API version 7.18)
[ 0.856098] msgmni has been set to 990
[ 0.858381] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.858401] io scheduler noop registered
[ 0.858411] io scheduler deadline registered
[ 0.858514] io scheduler cfq registered (default)
[ 0.858990] failed to get normal led pin assign
[ 0.859004] failed to get standby led pin assign
[ 0.859015] gpio_pin_1(39) gpio_request
[ 0.859129] gpio_pin_2(233) gpio_request
[ 0.859245] gpio_pin_3(232) gpio_request
[ 0.859354] gpio_pin_4(231) gpio_request
[ 0.859457] gpio_pin_5(230) gpio_request
[ 0.859554] gpio_pin_6(34) gpio_request
[ 0.859661] gpio_pin_7(35) gpio_request
[ 0.859816] gpio name is PB7, ret = 0
[ 0.859959] gpio name is PH9, ret = 0
[ 0.860165] gpio name is PH8, ret = 0
[ 0.860298] gpio name is PH7, ret = 0
[ 0.860426] gpio name is PH6, ret = 0
[ 0.860560] gpio name is PB2, ret = 0
[ 0.860683] gpio name is PB3, ret = 0
<4>[ 0.860819] gpio_init finish with uesd 1!
[ 0.860831] pwm module init!
[ 0.861470] sw_uart_get_devinfo()1416 - uart0 has no uart_regulator.
[ 0.861814] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 0.861838] sw_console_setup()1176 - console setup baud 115200 parity n bits 8, flow n
[ 1.014556] console [ttyS0] enabled
[ 1.115336] loop: module loaded
[ 1.301019] sunxi_spi_chan_cfg()1368 - [spi-0] has no spi_regulator.
[ 1.583363] sunxi_spi_chan_cfg()1368 - [spi-1] has no spi_regulator.
[ 1.964716] tun: Universal TUN/TAP device driver, 1.6
[ 2.060278] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.251566] PPP generic driver version 2.4.2
[ 2.442066] PPP BSD Compression module registered
[ 2.893206] PPP Deflate Compression module registered
[ 2.905533] PPP MPPE Compression module registered
[ 2.910894] NET: Registered protocol family 24
[ 2.915867] PPTP driver version 0.8.5
[ 2.920200] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.927561] [sunxi_hci_sunxi]: [sunxi-ehci1]: probe, pdev->name: sunxi-ehci, pdev->id: 1, sunxi_ehci: 0xc0a1462c
[ 2.938888] [sunxi_hci_sunxi]: [sunxi-ehci1]: open clock, is_open: 0
[ 2.965981] [sunxi_hci_sunxi]: [sunxi-ehci1]: Set USB Power ON
[ 2.972479] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.981407] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[ 2.991679] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[ 3.010035] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[ 3.017392] hub 1-0:1.0: USB hub found
[ 3.021599] hub 1-0:1.0: 1 port detected
[ 3.026416] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.033367] [sunxi_hci_sunxi]: [sunxi-ohci1]: probe, pdev->name: sunxi-ohci, pdev->id: 1, sunxi_ohci: 0xc0a14730
[ 3.044691] [sunxi_hci_sunxi]: [sunxi-ohci1]: open clock, is_open: 0
[ 3.071780] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 3.080315] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[ 3.088754] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[ 3.154660] hub 2-0:1.0: USB hub found
[ 3.158843] hub 2-0:1.0: 1 port detected
[ 3.163752] usbcore: registered new interface driver cdc_acm
[ 3.170058] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.178945] Initializing USB Mass Storage driver...
[ 3.184493] usbcore: registered new interface driver usb-storage
[ 3.191180] USB Mass Storage support registered.
[ 3.196345] usbcore: registered new interface driver ums-alauda
[ 3.202973] usbcore: registered new interface driver ums-cypress
[ 3.209679] usbcore: registered new interface driver ums-datafab
[ 3.216405] usbcore: registered new interface driver ums_eneub6250
[ 3.223325] usbcore: registered new interface driver ums-freecom
[ 3.230051] usbcore: registered new interface driver ums-isd200
[ 3.236659] usbcore: registered new interface driver ums-jumpshot
[ 3.243481] usbcore: registered new interface driver ums-karma
[ 3.249993] usbcore: registered new interface driver ums-onetouch
[ 3.256831] usbcore: registered new interface driver ums-realtek
[ 3.263615] usbcore: registered new interface driver ums-sddr09
[ 3.270252] usbcore: registered new interface driver ums-sddr55
[ 3.276874] usbcore: registered new interface driver ums-usbat
[ 3.283489] usbcore: registered new interface driver usbserial
[ 3.289968] usbserial: USB Serial Driver core
[ 3.294870] usbcore: registered new interface driver option
[ 3.301109] USB Serial support registered for GSM modem (1-port)
[ 3.308128] [sw_udc]: [sunxi_usb_udc]: binding gadget driver 'android_usb'
[ 3.315794] [sw_udc]: alloc request: ep(0xc0986f90, ep0, 64), req(0xd760e140)
[ 3.323743] sunxi_udc_set_selfpowered_2300: usb device is not active
[ 3.330811] [sw_udc]: sunxi_udc_pullup, is_on = 0
[ 3.336037] sunxi_udc_set_pullup_2317: usb device is not active
[ 3.342727] file system registered
[ 3.348480] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.356145] android_usb gadget: Number of LUNs=3
[ 3.361287] lun0: LUN: removable file: (no medium)
[ 3.366701] lun1: LUN: removable file: (no medium)
[ 3.372130] lun2: LUN: removable file: (no medium)
[ 3.377928] android_bind, serial_unique = 1
[ 3.382601] sunxi_udc_set_selfpowered_2300: usb device is not active
[ 3.389669] android_usb gadget: android_usb ready
[ 3.394923] [sw_hcd0]: usb host driver initialize........
[ 3.401020] [sw_hcd0]: open_usb_clock
[ 3.405407] [sunxi_hcd0]: host_init_state = 1
[ 3.410470] [sw_hcd0]: platform is usb host
[ 3.415167] [sw_hcd0]: sunxi_hcd_init_controller: sunxi_hcd_host0: USB Host mode controller at f1c19000 using PIO, IRQ 103
[ 3.427472] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver
[ 3.434357] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3
[ 3.444187] hub 3-0:1.0: USB hub found
[ 3.448363] hub 3-0:1.0: 1 port detected
[ 3.453118] [sw_hcd0]: sunxi_usb_host0_disable start
[ 3.458634] [sw_hcd0]: sunxi_hcd_wait_for_disconnect cnt=0
[ 3.464748] [sunxi_hcd_host0]: Set USB Power OFF
[ 3.469979] -------sunxi_hcd0_soft_disconnect---------
[ 3.475682] wrn: hcd is not enable, need not stop hcd
[ 3.481302] [sunxi_hcd_host0]: Set USB Power OFF
[ 3.486552] [sw_hcd0]: close_usb_clock
[ 3.490751] [sw_hcd0]: sunxi_usb_host0_disable end
[ 3.496468] mousedev: PS/2 mouse device common for all mice
[ 3.503238] [RTC] WARNING: Rtc time will be wrong!!
[ 3.508917] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[ 3.516423] sunxi cedar version 0.1
[ 3.520460] [cedar]: install start!!!
[ 3.524754] [cedar]: install end!!!
[ 3.531762] axp22_dcdc1: Failed to create debugfs directory
[ 3.539646] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 3.549096] Bluetooth: HCI UART driver ver 2.2
[ 3.554118] Bluetooth: HCI H4 protocol initialized
[ 3.559436] Bluetooth: HCI BCSP protocol initialized
[ 3.565053] usbcore: registered new interface driver btusb
[ 3.571159] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 3.577591] Bluetooth: MSM Sleep Mode Driver Ver 1.2
[ 3.583203] Bluetooth: get ap6xxx ap6xxx_bt_wake gpio failed
[ 3.583210]
[ 3.591152] Bluetooth: get ap6xxx ap6xxx_bt_host_wake gpio failed
[ 3.591158]
[ 3.600160] autohotplug_init init ok
[ 3.604158] sunxi_cpufreq_initcall: clocks pll=1008000000,cpu=1008000000,axi=336000000
[ 3.612977] cur: pll=1008000000, cpudiv=1, axidiv=3
[ 3.618410] axp22_dcdc3: Failed to create debugfs directory
[ 3.624629] sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 1200MHz, min freq: 120MHz
[ 3.635298] -------------------CPU V-F Table--------------------
[ 3.641980] frequency = 1536000KHz voltage = 1500mv
[ 3.647585] frequency = 1344000KHz voltage = 1460mv
[ 3.653203] frequency = 1200000KHz voltage = 1320mv
[ 3.658808] frequency = 1008000KHz voltage = 1200mv
[ 3.664428] frequency = 816000KHz voltage = 1100mv
[ 3.669937] frequency = 648000KHz voltage = 1040mv
[ 3.675459] frequency = 0KHz voltage = 1040mv
[ 3.680788] frequency = 0KHz voltage = 1040mv
[ 3.686102] -----------------------------------------------------
[ 3.695258] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.85 2014-08-01 15:11) Compiled in Aug 21 2021 at 21:42:14
[ 3.706663] [mmc]: sunxi_mci_init
[ 3.710366] [mmc]: get mmc0's power supply 'axp22_dcdc1' ok
[ 3.716543] [mmc]: get mmc0's 2xmode fail
[ 3.720998] [mmc]: get mmc0's ddrmode fail
[ 3.725537] [mmc]: get mmc0's sdc_ex_dly_used failed, use default dly
[ 3.732701] [mmc]: get mmc1's sdc_power failed
[ 3.737625] [mmc]: get mmc1's 2xmode fail
[ 3.742079] [mmc]: get mmc1's ddrmode fail
[ 3.746617] [mmc]: get mmc1's sdc_ex_dly_used failed, use default dly
[ 3.753784] [mmc]: get mmc2's power supply 'axp22_dcdc1' ok
[ 3.759962] [mmc]: get mmc2's 2xmode ok, val = 1
[ 3.765091] [mmc]: get mmc2's ddrmode fail
[ 3.769629] [mmc]: get mmc2's sdc_ex_dly_used failed, use default dly
[ 3.776783] [mmc]: MMC host used card: 0x7, boot card: 0x4, io_card 2
[ 3.784972] [mmc]: mmc not poweroff notifiy
[ 3.789615] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.800462] [mmc]: sdc2 Probe: base:0xf1c11000 irq:94 sg_cpu:d8c04000(58c04000) ret 0.
[ 3.800476] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.802008] [mmc]: sdc2 card_power_on start...
[ 3.802037] axp22_dcdc1: Failed to create debugfs directory
[ 3.802114] [mmc]: sdc2 card_power_on end ...ok
[ 3.802121] [mmc]: sdc2 card_power_on ok
[ 3.820045] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[ 3.820115] [mmc]: mclk 0xf1c20090 0xc001000e离线
A33板子内存512M,EMMC是8G的没有没内存卡
群里有大神说是mmc启动除了问题,我翻看了linux 编译的.config文件不知道在哪里能设置呢
看起来不像内核配置问题,uboot识别很正常呢,不过有点奇怪A33的emmc应该是8线的但是你的只有四线模式,
你把内核的sys_config也改为4线试下吧。
再不行就强制指定为SDR50看下
好的我尝试下,谢谢
老铁,我也遇到这个问题了,可以加个qq一起讨论一下吗?996054544
[ 3.708980] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.85 2014-08-01 15:11) Compiled in Jan 24 2022 at 10:27:58
[ 3.720387] [mmc]: sunxi_mci_init
[ 3.724077] [mmc]: get mmc0's power supply 'axp22_dcdc1' ok
[ 3.730268] [mmc]: get mmc0's 2xmode fail
[ 3.734710] [mmc]: get mmc0's ddrmode fail
[ 3.739249] [mmc]: get mmc0's sdc_ex_dly_used failed, use default dly
[ 3.746413] [mmc]: get mmc1's sdc_power failed
[ 3.751350] [mmc]: get mmc1's 2xmode fail
[ 3.755792] [mmc]: get mmc1's ddrmode fail
[ 3.760343] [mmc]: get mmc1's sdc_ex_dly_used failed, use default dly
[ 3.767488] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
