楼主 # 2021-12-07 17:25:32
Mr.Liu
已发帖子: 29
R3 F1C200S驱动ST7565 128*64
Deicetree增加了
&spi1 {
    st7565@0 {
        compatible = "sitronix,st7565";
               reg = <0>;
               spi-max-frequency =<15000000>;        //SPI时钟32M
               rotate =<0>;                    //屏幕旋转90度
               bgr;
               fps =<10>;                      //刷新10帧率
               buswidth =<8>;                   //总线宽度8
               reset-gpios=<&pio 3 18 GPIO_ACTIVE_LOW>;   //GPIOD18
               dc-gpios  =<&pio 3 19 GPIO_ACTIVE_LOW>;   //GPIOD19
               debug =<0>;                     //不开启调试
同时也增加了SPI 节点
                spi1: spi@1c06000 {
                        compatible = "allwinner,suniv-f1c100s-spi",
                                         "allwinner,sun8i-h3-spi";
                        reg = <0x01c06000 0x1000>;
                        interrupts = <11>;
                        clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
                        clock-names = "ahb", "mod";
                        resets = <&ccu RST_BUS_SPI1>;
                        #address-cells = <1>;
                        #size-cells = <0>;
                        bias-pull-up;
                        pinctrl-names = "default";
                        pinctrl-0 = <&spi1_pins>;
同时在IO节点中申明引脚定义
                        spi1_pins: spi1-pins {
                                pins = "PE7", "PE8", "PE9", "PE10";
                                function = "spi1";
                                bias-pull-up;
设备驱动里没有
找到<*>   Generic FB driver for TFT LCD displays
增加了st7565驱动
原码来自于 https://github.com/zanaster/fbtft/blob/master/fb_st7565.c
编译后
  INSTALL drivers/staging/fbtft/fb_st7565.ko
  INSTALL drivers/staging/fbtft/fbtft.ko
没有成功
#1 2021-12-08 13:31:38
542396750@qq.com
已发帖子: 153
Re: R3 F1C200S驱动ST7565 128*64
开机log有没有输出注册fb信息?dev目录下看看有没有fb设备
