晚上更新
启用了secureboot,给bootloader做了toc0签名
主板焊接了rtl8723ds sdio模块
启动只需要1.5秒!!比上午的实验还少了0.5秒~
也许是因为上午实验时没有焊接sdio模块,导致mmc部分初始化等待比较久。
下面是securecrt带时间戳的串口日志
[22-06-09.354]BOOTROM elapsed 0 ms (118 ticks)
[22-06-09.354]
[22-06-09.354]
[22-06-09.354]-Hardcore Boot-
[22-06-09.354]
[22-06-09.354]Rev 13, Build Dec 8 2021 21:53:43
[22-06-09.354]mengxp works 2021
[22-06-09.354]
[22-06-09.369]CPU: Allwinner R328-S3
[22-06-09.428]DRAM: DDR3 128 MB, 792 MHz
[22-06-09.428]NOR: C22018(JEDEC ID)
[22-06-09.428]
[22-06-09.428]> Setup MMU
[22-06-09.428]> Load Optee
[22-06-09.428]> Load DeviceTree
[22-06-09.428]> Load Kernel
[22-06-09.780]> Open FDT
[22-06-09.781]> Setup FDT
[22-06-09.781]> Boot kernel
[22-06-09.818]Uncompressing Linux... done, booting the kernel.
[22-06-09.818][ 0.000000] Booting Linux on physical CPU 0x0
[22-06-09.818][ 0.000000] Linux version 4.9.118 (meng@u14aw) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #5 SMP Wed Dec 8 12:55:35 CST 2021
[22-06-09.833][ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[22-06-09.833][ 0.000000] CPU: div instructions available: patching division code
[22-06-09.850][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[22-06-09.850][ 0.000000] OF: fdt:Machine model: sun8iw18
[22-06-09.885][ 0.000000] bootconsole [earlycon0] enabled
[22-06-09.901][ 0.001130] /cpus/cpu@0 missing clock-frequency property
[22-06-09.901][ 0.007077] /cpus/cpu@1 missing clock-frequency property
[22-06-10.199][ 0.288531] mmc:failed to get gpios
[22-06-10.234][ 0.346803] sunxi_get_str_of_property()1561 - failed to get the string of propname led_regulator!
[22-06-10.246][ 0.361193] sunxi-mmc sdc1: smc 0 p1 err, cmd 8, RTO !!
[22-06-10.290][ 0.394617] sunxi-rtc rtc: hctosys: unable to read the hardware clock
[22-06-10.290]
[22-06-10.684]
[22-06-10.849]Starting fstab.
[22-06-10.890]Starting syslogd.
[22-06-10.890]Starting lo.
[22-06-10.890]
[22-06-10.890]Processing /etc/profile...
[22-06-10.902]root@r328:/#
[22-06-10.903]root@r328:/# 下面是dmesg的日志
root@r328:/# dmesg
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat c05a68c0, node_mem_map c7ef8000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 13 pages/cpu @c7eb5000 s21196 r8192 d23860 u53248
[ 0.000000] pcpu-alloc: s21196 r8192 d23860 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 console=ttyS0,115200 printk.time=1 quiet mtdparts=spi0.0:384k(uboot),64k(env),64k(dtb),7168k(kernel),8704k(rootfs) root=/dev/mtdblock4 rootfstype=cramfs rootwait
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 120580K/131072K available (4185K kernel code, 165K rwdata, 1012K rodata, 252K init, 168K bss, 10492K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] .text : 0xc0008000 - 0xc041e7ec (4186 kB)
[ 0.000000] .init : 0xc053f000 - 0xc057e000 ( 252 kB)
[ 0.000000] .data : 0xc057e000 - 0xc05a7738 ( 166 kB)
[ 0.000000] .bss : 0xc05a7738 - 0xc05d17f8 ( 169 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000014] Switching to timer-based delay loop, resolution 41ns
[ 0.000119] Console: colour dummy device 80x30
[ 0.000135] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000144] pid_max: default: 32768 minimum: 301
[ 0.000300] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000306] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000828] CPU: Testing write buffer coherency: ok
[ 0.013054] CPU0: update cpu_capacity 1024
[ 0.013060] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.013107] Setting up static identity map for 0x400082c0 - 0x40008318
[ 0.015428] CPU1: update cpu_capacity 1024
[ 0.015434] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.015532] Brought up 2 CPUs
[ 0.015540] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.015544] CPU: All CPU(s) started in SVC mode.
[ 0.016173] devtmpfs: initialized
[ 0.034403] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.034886] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.034905] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.035104] atomic64_test: passed
[ 0.035109] pinctrl core: initialized pinctrl subsystem
[ 0.035717] NET: Registered protocol family 16
[ 0.036010] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.037230] dump_class_init,861, success
[ 0.075556] cpuidle: using governor menu
[ 0.083309] sun8iw18p1-pinctrl pio: initialized sunXi PIO driver
[ 0.126659] pwm module init!
[ 0.129252] sunxi-pm debug v3.10
[ 0.129728] sunxi_spi_probe()2281 - [spi0] SPI MASTER MODE
[ 0.129791] sunxi_spi_request_gpio()1909 - [spi0] Pinctrl init spi0
[ 0.129846] sunxi_spi_clk_init()1959 - [spi0] mclk 100000000
[ 0.130315] spi spi0: master is unqueued, this is deprecated
[ 0.130653] sunxi_spi_probe()2362 - [spi0]: driver probe succeed, base c8858000, irq 161
[ 0.130984] sunxi_spi_probe()2281 - [spi1] SPI MASTER MODE
[ 0.131042] sunxi_spi_request_gpio()1909 - [spi1] Pinctrl init spi1
[ 0.131108] sunxi_spi_clk_init()1959 - [spi1] mclk 100000000
[ 0.131564] spi spi1: master is unqueued, this is deprecated
[ 0.131589] sunxi_spi_probe()2362 - [spi1]: driver probe succeed, base c885a000, irq 162
[ 0.131997] usbcore: registered new interface driver usbfs
[ 0.132084] usbcore: registered new interface driver hub
[ 0.132186] usbcore: registered new device driver usb
[ 0.134569] Bluetooth: Core ver 2.22
[ 0.134653] NET: Registered protocol family 31
[ 0.134657] Bluetooth: HCI device and connection manager initialized
[ 0.134672] Bluetooth: HCI socket layer initialized
[ 0.134681] Bluetooth: L2CAP socket layer initialized
[ 0.134712] Bluetooth: SCO socket layer initialized
[ 0.135934] clocksource: Switched to clocksource arch_sys_counter
[ 0.149998] get androidboot.mode fail
[ 0.150011] sunxi_i2c_adap_init()2476 - init
[ 0.150855] NET: Registered protocol family 2
[ 0.151499] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.151520] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.151539] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.151588] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.151615] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.151813] NET: Registered protocol family 1
[ 0.152001] sunxi budget cooling probe start !
[ 0.152019] CPU freq cooling register Success
[ 0.152029] CPU hotplug cooling register Success
[ 0.152248] CPU budget cooling register Success
[ 0.154117] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.163241] io scheduler noop registered
[ 0.163475] io scheduler cfq registered (default)
[ 0.172248] uart0: ttyS0 at MMIO 0x5000000 (irq = 157, base_baud = 1500000) is a SUNXI
[ 0.172275] sw_console_setup()1724 - console setup baud 115200 parity n bits 8, flow n
[ 0.172318] console [ttyS0] enabled
[ 0.172323] bootconsole [earlycon0] disabled
[ 0.173182] misc dump reg init
[ 0.174276] m25p80 spi0.0: mx25l12835f (16384 Kbytes) normal
[ 0.174298] 5 cmdlinepart partitions found on MTD device spi0.0
[ 0.174303] Creating 5 MTD partitions on "spi0.0":
[ 0.174312] 0x000000000000-0x000000060000 : "uboot"
[ 0.175715] 0x000000060000-0x000000070000 : "env"
[ 0.177132] 0x000000070000-0x000000080000 : "dtb"
[ 0.178454] 0x000000080000-0x000000780000 : "kernel"
[ 0.179842] 0x000000780000-0x000001000000 : "rootfs"
[ 0.181199] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.181372] get drv_vbus is fail, 84
[ 0.181377] get ehci0-controller, regulator_io is no nocare
[ 0.181381] get ehci0-controller wakeup-source is fail.
[ 0.181491] sunxi ehci0-controller don't init wakeup source
[ 0.181502] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc05c96f8, 0x:c886a000, irq_no:9f
[ 0.181555] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.181590] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 0.181718] sunxi-ehci 5101000.ehci0-controller: irq 159, io mem 0xc056d83c
[ 0.206121] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 0.207193] hub 1-0:1.0: USB hub found
[ 0.207237] hub 1-0:1.0: 1 port detected
[ 0.207691] [ehci0-controller]: sunxi_usb_disable_ehci
[ 0.207699] [sunxi-ehci0]: remove, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc05c96f8
[ 0.207717] sunxi-ehci 5101000.ehci0-controller: remove, state 1
[ 0.207737] usb usb1: USB disconnect, device number 1
[ 0.208791] sunxi-ehci 5101000.ehci0-controller: USB bus 1 deregistered
[ 0.209099] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.209290] get drv_vbus is fail, 84
[ 0.209295] get ohci0-controller, regulator_io is no nocare
[ 0.209299] get ohci0-controller wakeup-source is fail.
[ 0.209398] sunxi ohci0-controller don't init wakeup source
[ 0.209455] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc05c8e98
[ 0.209504] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 0.209539] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assigned bus number 1
[ 0.209607] sunxi-ohci 5101000.ohci0-controller: irq 160, io mem 0xc04420a4
[ 0.280912] hub 1-0:1.0: USB hub found
[ 0.280956] hub 1-0:1.0: 1 port detected
[ 0.281382] [ohci0-controller]: sunxi_usb_disable_ohci
[ 0.281390] [sunxi-ohci0]: remove, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc05c8e98
[ 0.281396] sunxi-ohci 5101000.ohci0-controller: remove, state 1
[ 0.281420] usb usb1: USB disconnect, device number 1
[ 0.282222] sunxi-ohci 5101000.ohci0-controller: USB bus 1 deregistered
[ 0.282576] usb_serial_number:20080411
[ 0.283491] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.284598] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 0.284607] sunxi-rtc rtc: RTC enabled
[ 0.285248] i2c /dev entries driver
[ 0.285315] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
[ 0.285320] Bluetooth: HCI H4 protocol initialized
[ 0.285324] Bluetooth: HCI Realtek H5 protocol initialized
[ 0.286644] cpuidle: enable-method property 'psci' found operations
[ 0.286978] cpuidle: enable-method property 'psci' found operations
[ 0.288043] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.29 2019-8-6 19:27)
[ 0.288139] sunxi-mmc sdc1: Can't get vmmc regulator string
[ 0.288145] sunxi-mmc sdc1: Can't get vqmmc regulator string
[ 0.288150] sunxi-mmc sdc1: Can't get vdmmc regulator string
[ 0.288155] sunxi-mmc sdc1: Can't get vdmmc33sw regulator string
[ 0.288159] sunxi-mmc sdc1: Can't get vdmmc18sw regulator string
[ 0.288164] sunxi-mmc sdc1: Can't get vqmmc33sw regulator string
[ 0.288168] sunxi-mmc sdc1: Can't get vqmmc18sw regulator string
[ 0.288173] sunxi-mmc sdc1: Failed getting OCR mask: 0
[ 0.288482] sunxi-mmc sdc1: set host busy
[ 0.288488] sunxi-mmc sdc1: ***set host ocr***
[ 0.292641] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.316042] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.345953] sunxi-mmc sdc1: detmode:manually by software
[ 0.356835] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.359302] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 0.367459] sunxi-mmc sdc1: card claims to support voltages below defined range
[ 0.377489] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 0.377589] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 0.377713] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 0.378483] mmc0: new high speed SDIO card at address 0001
[ 0.385576] sunxi_led_probe()1759 - finish
[ 0.385900] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.386201] usbcore: registered new interface driver usbhid
[ 0.386205] usbhid: USB HID core driver
[ 0.386272] Netfilter messages via NETLINK v0.30.
[ 0.386454] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 0.386721] ctnetlink v0.93: registering with nfnetlink.
[ 0.386901] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 0.387559] gre: GRE over IPv4 demultiplexor driver
[ 0.387565] ip_gre: GRE over IPv4 tunneling driver
[ 0.388990] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.389205] Initializing XFRM netlink socket
[ 0.389233] NET: Registered protocol family 17
[ 0.389311] 8021q: 802.1Q VLAN Support v1.8
[ 0.391062] Registering SWP/SWPB emulation handler
[ 0.394224] get usb_detect_mode is fail, 22
[ 0.394231] get det_vbus is fail, 84
[ 0.394234] get id is fail, 84
[ 0.408411] VFS: Mounted root (cramfs filesystem) readonly on device 31:4.
[ 0.408481] devtmpfs: mounted
[ 0.408870] Freeing unused kernel memory: 252K
[ 0.408873] This architecture does not have kernel memory protection.
[ 0.416959] random: fast init done----------------------------------------------------
以下是原始帖子内容(上午)
之前逆向了全志闭源的fes1
https://whycan.com/t_7448.html
现在已经重写出了bootloader然后实现了linux的快速启动
目前是上电 ~1.957 秒进入shell (如果不启用网络协议栈是 ~1.3秒)
由此可见全志linux是可以做到快速启动的…
他的BROM也没拖后腿(0 ms),如果是SBROM可能会长一些,后面再测
之前我在iMX6ULL上实现的是 ~1.67秒,看来全志还可以在优化优化。
平台: 全志R328-S3 (128MB DDR3)
NOR: MX25L12835F (DUAL 50MHz)
内核:Tina SDK r328_s3_std 默认kernel配置基础上,启用了 SPINOR 配置,禁用了 SPINAND。没做其他优化。
下面是带时间戳的串口日志
[13-02-20.823]BOOTROM elapsed 0 ms
[13-02-20.823]
[13-02-20.823]
[13-02-20.823]-Hardcore Boot-
[13-02-20.823]
[13-02-20.823]Rev 11, Build Dec 8 2021 11:05:25
[13-02-20.823]mengxp works 2021
[13-02-20.823]
[13-02-20.844]CPU: Allwinner R328-S3
[13-02-20.844]DRAM: DDR3 128 MB, 792 MHz
[13-02-20.844]NOR: C22018(JEDEC ID)
[13-02-20.844]
[13-02-20.861]> Setup MMU
[13-02-20.861]> Load Optee
[13-02-20.876]> Load DeviceTree
[13-02-20.876]> Load Kernel
[13-02-21.213]> Open FDT
[13-02-21.213]> Setup FDT
[13-02-21.213]> Boot kernel
[13-02-21.276]Uncompressing Linux... done, booting the kernel.
[13-02-21.287][ 0.000000] Booting Linux on physical CPU 0x0
[13-02-21.292][ 0.000000] Linux version 4.9.118 (meng@u14aw) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #5 SMP Wed Dec 8 12:55:35 CST 2021
[13-02-21.306][ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[13-02-21.319][ 0.000000] CPU: div instructions available: patching division code
[13-02-21.319][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[13-02-21.323][ 0.000000] OF: fdt:Machine model: sun8iw18
[13-02-21.341][ 0.000000] bootconsole [earlycon0] enabled
[13-02-21.357][ 0.001122] /cpus/cpu@0 missing clock-frequency property
[13-02-21.372][ 0.006547] /cpus/cpu@1 missing clock-frequency property
[13-02-21.660][ 0.306975] mmc:failed to get gpios
[13-02-21.735][ 0.375120] sunxi_get_str_of_property()1561 - failed to get the string of propname led_regulator!
[13-02-21.735][ 0.375160] sunxi-mmc sdc1: smc 0 p1 err, cmd 52, RTO !!
[13-02-21.757][ 0.391824] sunxi-mmc sdc1: smc 0 p1 err, cmd 52, RTO !!
[13-02-21.757][ 0.402291] sunxi-mmc sdc1: smc 0 p1 err, cmd 8, RTO !!
[13-02-21.767][ 0.408969] sunxi-mmc sdc1: smc 0 p1 err, cmd 5, RTO !!
[13-02-21.767][ 0.415635] sunxi-mmc sdc1: smc 0 p1 err, cmd 5, RTO !!
[13-02-21.784][ 0.422300] sunxi-mmc sdc1: smc 0 p1 err, cmd 5, RTO !!
[13-02-21.784][ 0.428973] sunxi-mmc sdc1: smc 0 p1 err, cmd 5, RTO !!
[13-02-21.788][ 0.435643] sunxi-mmc sdc1: smc 0 p1 err, cmd 55, RTO !!
[13-02-21.799][ 0.442409] sunxi-mmc sdc1: smc 0 p1 err, cmd 55, RTO !!
[13-02-21.800][ 0.449172] sunxi-mmc sdc1: smc 0 p1 err, cmd 55, RTO !!
[13-02-21.821][ 0.455936] sunxi-mmc sdc1: smc 0 p1 err, cmd 55, RTO !!
[13-02-21.837][ 0.469110] write_efuse_to_reg_ver_3:reading calibration data0 is zero
[13-02-21.837][ 0.480761] sunxi-rtc rtc: hctosys: unable to read the hardware clock
[13-02-22.398]Starting fstab.
[13-02-22.428]Starting syslogd.
[13-02-22.447]Starting lo.
[13-02-22.447]
[13-02-22.447]Processing /etc/profile...
[13-02-22.780]root@r328:/#最近编辑记录 mengxp (2021-12-08 22:11:37)
太强了,想问下重写后bootloader花了多少时间呢?
大佬,请教imx6ull是如何做到1.67启动,太牛了,感觉1.6s也就能起个uboot
重写bootloader花多少时间吗?懂原理的话也不是很费时间,就一个星期就研究出来了……
需要自己写bootloader。用uboot也行就别调用太多无关的命令和等待。
是我的描述不太清楚,一个是我想知道你打印里面有个brom时间,这个是怎么算出来的?第二就是bootloader拉起内核时间是多少呢,想看下和uboot相比有多大的优势。
brom中会初始化ARM核中的Timer,后面可以直接取值拿到CPU上电时间。
Bootloader拉起内核的时间可以看日志
Load Kernel那里是从norflash读取
boot kernel那里是开始跳转
其实主要的问题不是uboot,毕竟uboot可以裁剪。
最大的问题是 boot0 尤其是 sboot 消耗了太多的时间,有0.8秒左右。
而这个东西是不开源的,你没法优化他。
最近编辑记录 mengxp (2021-12-09 09:09:07)
@mengxp
至今我只见过D1/D1s的boot0开源。
①启用了secureboot,给bootloader做了toc0签名
②主板焊接了rtl8723ds sdio模块
启动只需要1.5秒!!
请教楼主,这是因为①,还是因为②?
启动只需要1.5秒!!请教楼主,这是因为①,还是因为②?
secureboot会更耗时因为他需要校验代码有效性
启动时间比上次实验更短了应该是因为②
那个mmc驱动会probe设备,如果找不到设备他的超时等待更长一些吧(但说实话我觉得差这么多有点离谱)
大佬,可以分享一下bootloader嘛,感觉太牛了,想学习一下
感觉这可以做裸机开发了
大佬,我有个疑问,这个fes执行完最后一步是搬运uboot么?我用了上边分享的,卡在dram初始化成功,无法加载uboot,应该怎么解决?
我想用r328-s3的sdk适配 一下 r328-s2,经过测试发现s3的boot0是可以的用于s2的,我修改了sys_config的ddr的类型为ddr2,烧写到s3是无法执行的,也就是说实际上sys_config是作用到boot0上了,但是由于原版的s3的fes有个检测,导致就算是再sys_config里 把ddr类型改为2,执行fes进行烧写的时候也无法初始化s2的内存,导致无法烧写 ,我用上边分享的把那个检测拿掉,就可以初始化了,但是上边分享的卡在ddr初始化完成就不跑了,s2和s3都是,我想了两种办法,第一种是把大佬分享的那个改好,另一种就是改一下我这个原版的fes,绕过检测,但是奈何 这种方法太高端,没搞成功,大佬能帮我解答一下fes里ddr初始化完成后又做了什么么?
