续前贴: https://bbs.aw-ol.com/topic/311/
当时使用D1开发板驱动了,因D1的mipi是30pin,需要转接才能接树莓DSI屏。
麻雀设计的时候考虑到这点,直接板载的15Pin,所以直接接上就好。
效果:
固件:
tina_d1s_mipi_rpi_uart0.img
代码:只涉及board.dts和uboot-board.dts
&lcd0 {
lcd_used = <1>;
lcd_driver_name = "tft08006";
lcd_backlight = <100>;
lcd_if = <4>;
lcd_x = <800>;
lcd_y = <480>;
lcd_width = <52>;
lcd_height = <52>;
lcd_dclk_freq = <33>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <2>;
lcd_pwm_freq = <1000>;
lcd_pwm_pol = <0>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <32>;
lcd_ht = <868>;
lcd_hspw = <4>;
lcd_vbp = <12>;
lcd_vt = <500>;
lcd_vspw = <4>;
lcd_hbp = <32>;
lcd_ht = <868>;
lcd_hspw = <4>;
lcd_vbp = <10>;
lcd_vt = <520>;
lcd_vspw = <4>;
lcd_dsi_if = <0>;
lcd_dsi_lane = <1>;
lcd_lvds_if = <0>;
lcd_lvds_colordepth = <0>;
lcd_lvds_mode = <0>;
lcd_frm = <0>;
lcd_hv_clk_phase = <0>;
lcd_hv_sync_polarity= <0>;
lcd_io_phase = <0x0000>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
lcd_fsync_en = <0>;
lcd_fsync_act_time = <1000>;
lcd_fsync_dis_time = <1000>;
lcd_fsync_pol = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
/* lcd_gpio_0 = <&pio PG 13 GPIO_ACTIVE_HIGH>;*/
pinctrl-0 = <&dsi4lane_pins_a>;
pinctrl-1 = <&dsi4lane_pins_b>;
};歪朵拉开源硬件: https://widora.cn
我烧了你的镜像文件显示不正常
Run unmodified tina_d1s_mipi_rpi_uart0.img - uart shown this:
[00.395]line:714 init_clocks
__clk_init: clk pll_periph0x2 already initialized
register fix_factor clk error
[00.406]drv_disp_init
request pwm success, pwm2:pwm2:0x2000c00.
[00.422]drv_disp_init finish
[00.425]boot_gui_init:start
[00.428]set disp.dev2_output_type fail. using defval=0
[00.620]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read in 1 ms (52.7 KiB/s)
[00.989]bmp_name=bootlogo.bmp size 307254
307254 bytes read in 28 ms (10.5 MiB/s)
[01.031]LCD open finishWhy disp.dev2_output_type fail ?
Display not shown anything. Backlight turned on by hardware.
最近编辑记录 GenaSPB (2024-04-28 15:14:47)
