楼主 #1 2018-02-20 23:00:49
已发帖子: 9,393
楼主 #2 2018-02-21 13:47:58
已发帖子: 9,393
Re: nuklear 添加中文字体支持的方法
/* nuklear - 1.32.0 - public domain */
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <stdarg.h>
#include <string.h>
#include <math.h>
#include <assert.h>
#include <math.h>
#include <limits.h>
#include <time.h>
#include <GL/glew.h>
#include <GLFW/glfw3.h>
#define NK_INCLUDE_FIXED_TYPES
#define NK_INCLUDE_STANDARD_IO
#define NK_INCLUDE_STANDARD_VARARGS
#define NK_INCLUDE_DEFAULT_ALLOCATOR
#define NK_INCLUDE_VERTEX_BUFFER_OUTPUT
#define NK_INCLUDE_FONT_BAKING
#define NK_INCLUDE_DEFAULT_FONT
#define NK_IMPLEMENTATION
#define NK_GLFW_GL3_IMPLEMENTATION
#include "../../nuklear.h"
#include "nuklear_glfw_gl3.h"
#define WINDOW_WIDTH 1200
#define WINDOW_HEIGHT 800
#define MAX_VERTEX_BUFFER 512 * 1024
#define MAX_ELEMENT_BUFFER 128 * 1024
 *                          EXAMPLE
/* This are some code examples to provide a small overview of what can be
 * done with this library. To try out an example uncomment the defines */
/*#define INCLUDE_ALL */
/*#define INCLUDE_STYLE */
/*#define INCLUDE_CALCULATOR */
/*#define INCLUDE_OVERVIEW */
/*#define INCLUDE_NODE_EDITOR */
#ifdef INCLUDE_ALL
#ifdef INCLUDE_STYLE
  #include "../style.c"
#ifdef INCLUDE_CALCULATOR
  #include "../calculator.c"
#ifdef INCLUDE_OVERVIEW
  #include "../overview.c"
#ifdef INCLUDE_NODE_EDITOR
  #include "../node_editor.c"
 *                          DEMO
static void error_callback(int e, const char *d)
{printf("Error %d: %s\n", e, d);}
int main(void)
    /* Platform */
    static GLFWwindow *win;
    int width = 0, height = 0;
    struct nk_context *ctx;
    struct nk_colorf bg;
    /* GLFW */
    glfwSetErrorCallback(error_callback);
    if (!glfwInit()) {
        fprintf(stdout, "[GFLW] failed to init!\n");
        exit(1);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
    glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
#ifdef __APPLE__
    glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GL_TRUE);
    win = glfwCreateWindow(WINDOW_WIDTH, WINDOW_HEIGHT, "Demo", NULL, NULL);
    glfwMakeContextCurrent(win);
    glfwGetWindowSize(win, &width, &height);
    /* OpenGL */
    glViewport(0, 0, WINDOW_WIDTH, WINDOW_HEIGHT);
    glewExperimental = 1;
    if (glewInit() != GLEW_OK) {
        fprintf(stderr, "Failed to setup GLEW\n");
        exit(1);
    ctx = nk_glfw3_init(win, NK_GLFW3_INSTALL_CALLBACKS);
    /* Load Fonts: if none of these are loaded a default font will be used  */
    /* Load Cursor: if you uncomment cursor loading please hide the cursor */
    {struct nk_font_atlas *atlas;
    nk_glfw3_font_stash_begin(&atlas);
        struct nk_font_config cfg = nk_font_config(22);
        //cfg.merge_mode = nk_true;
        cfg.range = nk_font_chinese_glyph_ranges();
        //cfg.coord_type = NK_COORD_PIXEL;
        struct nk_font *font = nk_font_atlas_add_from_file(atlas, "../../../extra_font/msyh.ttf", 13, &cfg);
    nk_glfw3_font_stash_end();
    nk_style_set_font(ctx, &font->handle);
    /*set_style(ctx, THEME_WHITE);*/
    /*set_style(ctx, THEME_RED);*/
    /*set_style(ctx, THEME_BLUE);*/
    /*set_style(ctx, THEME_DARK);*/
    bg.r = 0.10f, bg.g = 0.18f, bg.b = 0.24f, bg.a = 1.0f;
    while (!glfwWindowShouldClose(win))
        /* Input */
        glfwPollEvents();
        nk_glfw3_new_frame();
        /* GUI */
        if (nk_begin(ctx, "中文", nk_rect(50, 50, 230, 250),
            NK_WINDOW_BORDER|NK_WINDOW_MOVABLE|NK_WINDOW_SCALABLE|
            NK_WINDOW_MINIMIZABLE|NK_WINDOW_TITLE))
            enum {EASY, HARD};
            static int op = EASY;
            static int property = 20;
            nk_layout_row_static(ctx, 30, 80, 1);
            if (nk_button_label(ctx, "button"))
                fprintf(stdout, "button pressed\n");
            nk_layout_row_dynamic(ctx, 30, 2);
            if (nk_option_label(ctx, "easy", op == EASY)) op = EASY;
            if (nk_option_label(ctx, "hard", op == HARD)) op = HARD;
            nk_layout_row_dynamic(ctx, 25, 1);
            nk_property_int(ctx, "Compression:", 0, &property, 100, 10, 1);
            nk_layout_row_dynamic(ctx, 20, 1);
            nk_label(ctx, "background:", NK_TEXT_LEFT);
            if (nk_combo_begin_color(ctx, nk_rgb_cf(bg), nk_vec2(nk_widget_width(ctx),400))) {
                nk_layout_row_dynamic(ctx, 120, 1);
                bg = nk_color_picker(ctx, bg, NK_RGBA);
                bg.r = nk_propertyf(ctx, "#R:", 0, bg.r, 1.0f, 0.01f,0.005f);
                bg.g = nk_propertyf(ctx, "#G:", 0, bg.g, 1.0f, 0.01f,0.005f);
                bg.b = nk_propertyf(ctx, "#B:", 0, bg.b, 1.0f, 0.01f,0.005f);
                bg.a = nk_propertyf(ctx, "#A:", 0, bg.a, 1.0f, 0.01f,0.005f);
                nk_combo_end(ctx);
        nk_end(ctx);
        /* -------------- EXAMPLES ---------------- */
          calculator(ctx);
          overview(ctx);
          node_editor(ctx);
        /* Draw */
        glViewport(0, 0, width, height);
        glClear(GL_COLOR_BUFFER_BIT);
        glClearColor(bg.r, bg.g, bg.b, bg.a);
        /* IMPORTANT: `nk_glfw_render` modifies some global OpenGL state
         * with blending, scissor, face culling, depth test and viewport and
         * defaults everything back into a default state.
         * Make sure to either a.) save and restore or b.) reset your own state after
         * rendering the UI. */
        nk_glfw3_render(NK_ANTI_ALIASING_ON, MAX_VERTEX_BUFFER, MAX_ELEMENT_BUFFER);
        glfwSwapBuffers(win);
    nk_glfw3_shutdown();
    glfwTerminate();
修改几行代码,可以显示中文了, 但是用msyh字体只能12, 如果设置其它型号窗口就是黑的, 不知道为什么?
