调整LCD背光亮度:
mount -t debugfs none /sys/kernel/debug;
cd /sys/kernel/debug/dispdbg;
echo lcd0 > name; echo setbl > command; echo 100 > param; echo 1 > start亮度 0 - 255 写入 param, 0最亮, 255最暗。
调到最亮:
echo lcd0 > name; echo setbl > command; echo 0 > param; echo 1 > start关LCD背光:
echo lcd0 > name; echo setbl > command; echo 255 > param; echo 1 > start读当前背光:
echo getbl > command; echo lcd0 > name; echo 1 > start; cat info参考: 全志显示量产问题快速排查指南.pdf
参考: D1_Tina_Linux_Display_开发指南.pdf
AIC800 有两个LCD,如果液晶接在LCD1上面,那这么调背光(255最亮):
echo lcd1 > name; echo setbl > command; echo 255 > param; echo 1 > start离线
切换HDMI到屏幕0:
echo disp0 > name; echo switch1 > command; echo 4 10 0 0 0x4 0x101 0 0 0 8 > param; echo 1 > start;切换TV到屏幕0(但没有成功):
echo disp0 > name; echo switch1 > command; echo 2 11 > param; echo 1 > start;切换HDMI到屏幕1:
echo disp1 > name; echo switch1 > command; echo 4 10 0 0 0x4 0x101 0 0 0 8 > param; echo 1 > start;切换TV到屏幕1(但没有成功):
echo disp1 > name; echo switch1 > command; echo 2 11 > param; echo 1 > start;参考: 【DIY教程】D1的双屏异显第一弹来啦!D1同时支持两个屏幕,一共做UI交互,一边个播放视频
https://debugdump.com/topic/362
LCD0重新初始化:
echo suspend > command; echo disp0 > name; echo 1 > start
echo resume > command; echo disp0 > name; echo 1 > start
find / -name pinmux-pins |xargs cat开启 disp1,并显示colorbar:
#mount -t debugfs none /sys/kernel/debug
# disp1 切换HDMI 720p分辨率
echo disp1 > name;echo switch1 > command;echo 4 5 1 0 0x4 0x104 2 1 0 8 > param;echo 1 > start
cat /sys/class/disp/disp/attr/sys
# TCON Colorbar (disp1)
echo 1 > /sys/class/disp/disp/attr/disp; echo 1 > /sys/class/disp/disp/attr/colorbar
# DE Colorbar (disp1)
echo 1 > /sys/class/disp/disp/attr/disp; echo 8 > /sys/class/disp/disp/attr/colorbar离线
按住 s 上电启动可以进入u-boot命令行,输入两行命令可以把GPIO PD22拉高:
mw 0x02000098 0x01222222
mw 0x020000A0 0x00400000 参考: 请问 uboot 不能驱动PWM7 (PD22) 是什么原因呢?
https://debugdump.com/topic/949/share/5
disp display channel
0: disp0,
1:disp1
enhance_mode
0:standard,
1: enhance,
2: soft,
3: enahnce + demo
//设置disp0 的色彩增强的模式为增强模式
echo 0 > /sys/class/disp/disp/attr/disp;
echo 1 > /sys/class/disp/disp/attr/enhance_mode;//设置disp1 的色彩增强的模式为柔和模式
echo 2 > /sys/class/disp/disp/attr/enhance_mode;//设置disp0 的色彩增强的模式为增加模式,并且开启演示模式
echo 3 > /sys/class/disp/disp/attr/enhance_mode;离线
该接口用于设置图像的亮度/对比度/饱和度/边缘锐度/细节增强/降噪的调节幅度。
//设置disp0 的图像亮度为80
echo 80 > /sys/class/disp/disp/attr/enhance_bright;//设置disp1 的饱和度为50
echo 50 > /sys/class/disp/disp/attr/enhance_saturation;离线
获取disp0 的 X / Y 分辨率:
cd /sys/kernel/debug/dispdbg;echo getxres > command;echo disp0 > name;echo 1 > start;cat info
echo getyres > command;echo disp0 > name;echo 1 > start;cat info离线
LCD0重新初始化:
mount -t debugfs none /sys/kernel/debug; cd /sys/kernel/debug/dispdbg; echo suspend > command; echo disp0 > name; echo 1 > start echo resume > command; echo disp0 > name; echo 1 > start find / -name pinmux-pins |xargs cat
楼主,这个重新初始化,disp0的配置是从哪里读取的?比如lcd时钟设置等等。我能不能修改配置,比如lcd的旋转角度,然后再重新初始化disp0?
最近编辑记录 wuyu (2025-01-14 13:45:30)
截屏获取界面:
echo /tmp/screen2.bmp > /sys/class/disp/disp/attr/capture_dump电脑获取界面:
adb pull /tmp/screen2.bmp离线
读取色温:
cat /sys/class/disp/disp/attr/color_temperature
调整色温:
echo 120 > /sys/class/disp/disp/attr/color_temperature
&disp需要添加pwm-names=“backlight”;&lcdX需要添加lcd_pwm_name=“backlight”。
1、打开kernel config
CONFIG_BACKLIGHT_CLASS_DEVICE=y
2. 背光控制
echo 0 > /sys/class/backlight/backlight/bl_power
echo 255 > /sys/class/backlight/backlight/brightness
