楼主 # 2022-01-24 15:50:20
542396750@qq.com
已发帖子: 153
分享V3S播放器PCB板
v3s_player_v1.3_Dual.rar
驱动50Pin rgb接口LCD屏幕
楼主 #1 2022-01-24 15:57:33
542396750@qq.com
已发帖子: 153
Re: 分享V3S播放器PCB板
有个奇怪问题
# ./usr/bin/tinymix set 2 1
# ./usr/bin/tinymix contents
Number of controls: 13
ctl     type    num     name                                    value
0       INT     1       DAC Playback Volume                     63 (range 0->63)
1       INT     1       Headphone Playback Volume               0 (range 0->63)
2       BOOL    2       Headphone Playback Switch               Off, Off
3       INT     1       Mic1 Playback Volume                    3 (range 0->7)
4       INT     1       Mic1 Boost Volume                       4 (range 0->7)
5       INT     1       ADC Gain Capture Volume                 3 (range 0->7)
6       BOOL    2       DAC Playback Switch                     Off, Off
7       BOOL    2       DAC Reversed Playback Switch            Off, Off
8       BOOL    2       Mic1 Playback Switch                    Off, Off
9       BOOL    2       Mixer Capture Switch                    Off, Off
10      BOOL    2       Mixer Reversed Capture Switch           Off, Off
11      BOOL    2       Mic1 Capture Switch                     Off, Off
12      ENUM    2       Headphone Source Playback Route         , DACMixer, , DACMixer
tinymix set 2 1设置了,还是off
楼主 #2 2022-01-24 16:07:14
542396750@qq.com
已发帖子: 153
Re: 分享V3S播放器PCB板
同一张就卡插到zero开发板,播放音乐正常,而做的板子只有滋滋的声音
楼主 #3 2022-02-14 15:11:13
542396750@qq.com
已发帖子: 153
Re: 分享V3S播放器PCB板
542396750@qq.com 说:
重新焊接后正常
