资源连接
项目地址:https://github.com/YuzukiHD/Buildroot-YuzukiSBC
同步更新国内镜像:https://gitee.com/GloomyGhost/Buildroot-YuzukiSBC
文档:https://yuzukihd.gloomyghost.com/Buildroot-YuzukiSBC/#/
编译方法
下拉Buildroot
在主站和镜像站中选一个下载就可以了。
git clone https://github.com/yuzukihd/Buildroot-YuzukiSBC # 主站
git clone https://gitee.com/GloomyGhost/Buildroot-YuzukiSBC # 镜像站
cd Buildroot-YuzukiSBC
配置环境变量
Buildroot-YuzukiSBC 支持自动切换WSL2编译模式,支持WSL2与虚拟机。暂不支持WSL1
source envsetup.sh
lunch
应用配置文件
make mangopi_mq_dual_defconfig
编译
make
生成的镜像在output/images/文件夹里
测试镜像:
百度云:链接:https://pan.baidu.com/s/1dPSaKJQrOMy8X1Xs_604Dw 提取码:awol
奶牛快传:https://cowtransfer.com/s/76711e52ad304f 或 打开【奶牛快传】cowtransfer.com 使用传输口令:gl9jyq 提取;
串口是PE2,PE3
不要用PhoenixCard刷写镜像,用dd,win32imager,ether刷
相关文档
https://yuzukihd.gloomyghost.com/Buildroot-YuzukiSBC/#/?id=flashing-firmware
出现一点小插曲...
mkbootimg: not found
解决方案:
sudo apt install -y android-tools-mkbootimg
reboot 命令后无法重启,卡死在这里
# reboot
# Stopping swupdate: OK
Stopping network: OK
Stopping iptables: OK
Stopping system message bus: done
Saving random seed: OK
Stopping klogd: OK
Stopping syslogd: OK
umount: devtmpfs busy - remounted read-only
[ 323.862951] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
The system is going down NOW!
Sent SIGTERM to all processes
Sent SI[ 325.876597] reboot_callback(): empty arg
[ 325.881037] [ohci1-controller]: ohci shutdown start
[ 325.886538] [ohci1-controller]: ohci shutdown end
[ 325.891879] [ehci1-controller]: ehci shutdown start
[ 325.897336] [ehci1-controller]: ehci shutdown end
[ 325.902617] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
[ 325.911163] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
[ 325.931933] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 326.722147] reboot: Restarting system
我的imx6ul执行reboot也无法实现重启。
网上搜过,有的说是和硬件看门狗冲突,有的说uboot里设置个命令就行。
在坑网看到过这么一个帖子:今天确定了一件事情, linux的reboot命令到最后会调用看门狗的restart函数重启
最近编辑记录 Gentlepig (2022-05-05 11:40:55)
请问您视频硬解码试过吗?
一样的板子。 一样的屏幕 单拍5寸电阻屏旧,480*272分辨率,电阻触摸,外观旧
结果怎么差别这么大.
T113 WiFi速度能达到多少M
这个支持wifi吗? uboot是通过patch 支持T113吗? 要改Uboot,在哪里改? 合并补丁有点麻烦啊
