楼主 # 2022-04-21 20:01:31
鱼尾
所在地: 杭州
已发帖子: 47
使用tinymix 播放音乐遇到问题
# ./tinymix contents
Number of controls: 13
ctl     type    num     name                                    value
0       INT     1       DAC Playback Volume                     63 (range 0->63)
1       INT     1       Headphone Playback Volume               0 (range 0->63)
2       BOOL    2       Headphone Playback Switch               Off, Off
3       INT     1       Mic1 Playback Volume                    3 (range 0->7)
4       INT     1       Mic1 Boost Volume                       4 (range 0->7)
5       INT     1       ADC Gain Capture Volume                 3 (range 0->7)
6       BOOL    2       DAC Playback Switch                     Off, Off
7       BOOL    2       DAC Reversed Playback Switch            Off, Off
8       BOOL    2       Mic1 Playback Switch                    Off, Off
9       BOOL    2       Mixer Capture Switch                    Off, Off
10      BOOL    2       Mixer Reversed Capture Switch           Off, Off
11      BOOL    2       Mic1 Capture Switch                     Off, Off
12      ENUM    2       Headphone Source Playback Route         , DACMixer, , DACMixer
# tinymix set1 1
unknown command 'set1' (see --help)
# tinymix set 11
Segmentation fault
# tinymix set 1 1
Error: 2 values given, but control only takes 1
# tinymix set 2 1
Segmentation fault
# tinymix set 1 1
# tinymix set 1 1
楼主 #1 2022-04-21 20:02:31
鱼尾
所在地: 杭州
已发帖子: 47
Re: 使用tinymix 播放音乐遇到问题
# tinymix set 1 1
不清楚是为什么
