楼主 # 2022-04-25 10:49:31
dml1048147924
所在地: 江苏无锡
已发帖子: 119
licheepi zero v3s 不停的重启
[    3.822091] sun4i-codec 1c22c00.codec: Failed to register our card
[    3.829579] Registering SWP/SWPB emulation handler
[    3.835460] Loading compiled-in X.509 certificates
[    3.845141] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0x(ptrval)
[    3.855788] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    3.871945] Console: switching to colour frame buffer device 100x30
[    3.885108] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    3.894089] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory
[    3.903989] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    3.913944] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:01:02 UTC (62)
[    3.922381] vcc5v0: disabling
[    3.925426] ALSA device list:
[    3.928395]   #0: V3s Audio Codec
[    3.932848] random: fast init done
[    3.957417] random: crng init done
[    5.910001] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[    5.929620] VFS: Mounted root (jffs2 filesystem) on device 31:5.
[    5.937009] devtmpfs: mounted
[    5.941312] Freeing unused kernel memory: 1024K
[    5.976180] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    5.990360] Rebooting in 5 seconds..
U-Boot SPL 2018.07 (Apr 27 2020 - 23:10:48 -0700)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2018.07 (Apr 27 2020 - 23:10:48 -0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   eth-1: ethernet@1c30000
No controllers found
device 0 offset 0x80000, size 0x150000
SF: 1376256 bytes @ 0x80000 Read: OK
device 0 offset 0x1d0000, size 0x4000
SF: 16384 bytes @ 0x1d0000 Read: OK
device 0 offset 0x1e0000, size 0x360000
#1 2022-04-25 11:26:16
已发帖子: 3,389
Re: licheepi zero v3s 不停的重启
看看你的 bootargs
#2 2022-04-25 16:35:37
unturned3
已发帖子: 272
是不是你rootfs没弄好,看看有 /sbin/init 吗
你这个rootfs是什么工具构建的?
