楼主 # 2022-05-13 10:37:35
笃学
已发帖子: 20
T113使用SPINAND,增加QT环境后报错
[29]HELLO! BOOT0 is starting!
[32]BOOT0 commit : 5224261
[34]set pll start
[40]periph0 has been enabled
[43]set pll end
[45][pmu]: bus read error
[47]board init ok
[49]enable_jtag
[50]ZQ value = 0x30
[52]get_pmu_exist() = -1
[55]DRAM BOOT DRIVE INFO: V0.32
[58]DRAM CLK = 792 MHz
[60]DRAM Type = 3 (2:DDR2,3:DDR3)
[63]DRAMC read ODT  off.
[66]DRAM ODT value: 0x42.
[68]ddr_efuse_type: 0xa
[70]mark_id: 0x60
[73]DRAM SIZE =128 M
[75]PLL_DDR_CTRL_REG:0xf8004100
[78]DRAM_CLK_REG:0xc0000000
[81][TIMING DEBUG] MR2= 0x18
[88]DRAM simple test OK.
[90]rtc standby flag is 0x0, super standby flag is 0x0
[95]dram size =128
[98]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[103]block from 8 to 32
[231]Check is correct.
[233]dma 0x29c4c int is not used yet
[237]dma 0x29c4c int is free, you do not need to free it again
[242]Entry_name        = u-boot
[250]Entry_name        = optee
[254]Entry_name        = dtb
[257]Jump to second Boot.
M/TC: OP-TEE version: 53fe17e2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #6 Fri Feb 18 08:54:51 UTC 2022 arm
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.61 (bj26lkl@LinuxServer2) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #3 SMP PREEMPT Wed May 11 11:53:14 CST 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
[    3.341476] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    3.350713] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #3
[    3.357325] Hardware name: Generic DT based system
[    3.362693] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[    3.371349] [<c010a894>] (show_stack) from [<c063de30>] (dump_stack+0x7c/0x98)
[    3.379428] [<c063de30>] (dump_stack) from [<c01197e8>] (panic+0x104/0x3dc)
[    3.387209] [<c01197e8>] (panic) from [<c0a01294>] (mount_block_root+0x278/0x32c)
[    3.395576] [<c0a01294>] (mount_block_root) from [<c0a01450>] (prepare_namespace+0x84/0x178)
[    3.405004] [<c0a01450>] (prepare_namespace) from [<c065250c>] (kernel_init+0x8/0x10c)
[    3.413850] [<c065250c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    3.422309] Exception stack(0xc704dfb0 to 0xc704dff8)
[    3.427949] dfa0:                                     00000000 00000000 00000000 00000000
[    3.437091] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.446223] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    3.453622] CPU1: stopping
[    3.456648] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #3
[    3.463257] Hardware name: Generic DT based system
[    3.468619] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[    3.477272] [<c010a894>] (show_stack) from [<c063de30>] (dump_stack+0x7c/0x98)
[    3.485349] [<c063de30>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
[    3.493520] [<c010c690>] (handle_IPI) from [<c0321d18>] (gic_handle_irq+0x70/0x78)
[    3.501987] [<c0321d18>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[    3.510342] Exception stack(0xc7097f80 to 0xc7097fc8)
[    3.515990] 7f80: 00009b54 c76c8534 00000000 c0114d00 00000002 c7096000 c0b03be8 c0b03c24
[    3.525126] 7fa0: 4000406a 410fc075 00000000 00000000 c0b6e8b0 c7097fd0 c0107f90 c0107f94
[    3.534265] 7fc0: 60000113 ffffffff
[    3.538165] [<c01021cc>] (__irq_svc) from [<c0107f94>] (arch_cpu_idle+0x2c/0x38)
[    3.546440] [<c0107f94>] (arch_cpu_idle) from [<c013e410>] (do_idle+0xb8/0x120)
[    3.554607] [<c013e410>] (do_idle) from [<c013e714>] (cpu_startup_entry+0x18/0x1c)
[    3.563071] [<c013e714>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[    3.570859] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
楼主 #1 2022-05-13 10:39:05
笃学
已发帖子: 20
Re: T113使用SPINAND,增加QT环境后报错
期待能得到大佬的回复
#2 2022-05-13 16:25:40
shaoxi2010
已发帖子: 367
看上去是设备不存在的问题,改下env的log等级看看完整的打印吧
楼主 #3 2022-05-13 20:12:49
笃学
已发帖子: 20
shaoxi2010 说:
好嘞,感谢提议,我去试试
楼主 #4 2022-05-13 20:56:23
笃学
已发帖子: 20
[34]set pll start
[43]set pll end
[47]board init ok
[49]enable_jtag
[50]ZQ value = 0x31
[70]mark_id: 0x60
[95]dram size =128
[236]dma 0x29c4c int is free, you do not need to free it again
[249]Entry_name        = optee
[253]Entry_name        = dtb
[256]Jump to second Boot.
[    0.000000] Linux version 5.4.61 (bj26lkl@LinuxServer2) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #4 SMP PREEMPT Fri May 13 11:58:55 CST 2022
[    0.000000] cma: Reserved 8 MiB at 0x47800000
[    0.000000] On node 0 totalpages: 32768
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
[    0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=ubi0_5 rootfstype=ubifs,rw init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:private@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g2a24076(02/22/2022-02:02:08) disp_reserve=2457600,0x44909000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Memory: 99856K/131072K available (6144K kernel code, 398K rwdata, 2052K rodata, 1024K init, 156K bss, 23024K reserved, 8192K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
[    0.008009] Switching to timer-based delay loop, resolution 41ns
[    0.014338] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.024217] Console: colour dummy device 80x30
[    0.028693] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.039060] pid_max: default: 32768 minimum: 301
[    0.044487] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.051814] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.062750] CPU: Testing write buffer coherency: ok
[    0.068860] /cpus/cpu@0 missing clock-frequency property
[    0.074234] /cpus/cpu@1 missing clock-frequency property
[    0.079561] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.087008] Setting up static identity map for 0x40100000 - 0x40100060
[    0.093846] rcu: Hierarchical SRCU implementation.
[    0.099870] smp: Bringing up secondary CPUs ...
[    0.106619] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.106782] smp: Brought up 1 node, 2 CPUs
[    0.116616] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.122814] CPU: All CPU(s) started in SVC mode.
[    0.129798] devtmpfs: initialized
[    0.300206] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.310030] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.319922] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.327249] pinctrl core: initialized pinctrl subsystem
[    0.340086] NET: Registered protocol family 16
[    0.347089] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.533617] rtc_ccu: sunxi ccu init OK
[    0.551457] ccu: sunxi ccu init OK
[    0.556670] r_ccu: sunxi ccu init OK
[    0.773428] iommu: Default domain type: Translated
[    0.779063] sunxi iommu: irq = 24
[    0.792678] SCSI subsystem initialized
[    0.798737] usbcore: registered new interface driver usbfs
[    0.804818] usbcore: registered new interface driver hub
[    0.810617] usbcore: registered new device driver usb
[    0.833127] pwm module init!
[    0.842222] input: sunxi-keyboard as /devices/virtual/input/input0
[    0.851590] clocksource: Switched to clocksource arch_sys_counter
[    0.928725] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[    1.022351] thermal_sys: Registered thermal governor 'step_wise'
[    1.022357] thermal_sys: Registered thermal governor 'user_space'
[    1.028383] thermal_sys: Registered thermal governor 'power_allocator'
[    1.039668] NET: Registered protocol family 2
[    1.054683] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.063181] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    1.070870] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    1.077954] TCP: Hash tables configured (established 1024 bind 1024)
[    1.084775] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.091359] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.099113] NET: Registered protocol family 1
[    1.108951] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[    1.120974] spi spi0: spi0 supply spi not found, using dummy regulator
[    1.129761] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[    1.136153] sunxi_spi_resource_get()2189 - Failed to get sample mode
[    1.142540] sunxi_spi_resource_get()2194 - Failed to get sample delay
[    1.148981] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[    1.157393] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[    1.166799] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 44
[    1.181963] Initialise system trusted keyrings
[    1.186854] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    1.280895] ntfs: driver 2.1.32 [Flags: R/W].
[    1.290695] NET: Registered protocol family 38
[    1.295689] Key type asymmetric registered
[    1.299801] Asymmetric key parser 'x509' registered
[    1.305083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.312522] io scheduler mq-deadline registered
[    1.317049] io scheduler kyber registered
[    1.321167] atomic64_test: passed
[    1.335102] [DISP]disp_module_init
[    1.340907] disp 5000000.disp: Adding to iommu group 0
[    1.348941] [DISP] disp_init,line:2386:
[    1.348947] smooth display screen:0 type:1 mode:4
[    1.377190] display_fb_request,fb_id:0
[    1.390114] disp_al_manager_apply ouput_type:1
[    1.395894] [DISP] lcd_clk_config,line:735:
[    1.395906] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[    1.395906]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[    1.401600] wait for new fb take effect
[    1.416719] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[    1.463652] Freeing logo buffer memory: 2400K
[    1.469826] [DISP]disp_module_init finish
[    1.476667] sunxi_sid_init()551 - insmod ok
[    1.487261] uart uart0: get regulator failed
[    1.491621] uart uart0: uart0 supply uart not found, using dummy regulator
[    1.500123] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[    1.508015] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[    1.516002] printk: console [ttyS0] enabled
[    1.524905] printk: bootconsole [earlycon0] disabled
[    1.538538] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[    1.550395] uart uart1: get regulator failed
[    1.555264] uart uart1: uart1 supply uart not found, using dummy regulator
[    1.564658] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[    1.576644] uart uart2: get regulator failed
[    1.581493] uart uart2: uart2 supply uart not found, using dummy regulator
[    1.590879] uart2: ttyS2 at MMIO 0x2500800 (irq = 36, base_baud = 1500000) is a SUNXI
[    1.602964] uart uart3: get regulator failed
[    1.607779] uart uart3: uart3 supply uart not found, using dummy regulator
[    1.617204] uart3: ttyS3 at MMIO 0x2500c00 (irq = 37, base_baud = 1500000) is a SUNXI
[    1.629167] uart uart4: get regulator failed
[    1.634035] uart uart4: uart4 supply uart not found, using dummy regulator
[    1.643496] uart4: ttyS4 at MMIO 0x2501000 (irq = 38, base_baud = 1500000) is a SUNXI
[    1.655529] uart uart5: get regulator failed
[    1.660343] uart uart5: uart5 supply uart not found, using dummy regulator
[    1.669858] uart5: ttyS5 at MMIO 0x2501400 (irq = 39, base_baud = 1500000) is a SUNXI
[    1.682748] misc dump reg init
[    1.697994] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[    1.705316] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[    1.713365] sunxi-spinand-phy: not detect any munufacture from id table
[    1.720791] sunxi-spinand-phy: get spi-nand Model from fdt fail
[    1.727469] sunxi-spinand-phy: get phy info from fdt fail
[    1.733587] sunxi-spinand-phy: not detect munufacture from fdt
[    1.740353] sunxi-spinand-phy: detect munufacture from id table: Winbond
[    1.747893] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[    1.754955] sunxi-spinand-phy: ========== arch info ==========
[    1.761496] sunxi-spinand-phy: Model:               W25N01GVZEIG
[    1.768252] sunxi-spinand-phy: Munufacture:         Winbond
[    1.774521] sunxi-spinand-phy: DieCntPerChip:       1
[    1.780184] sunxi-spinand-phy: BlkCntPerDie:        1024
[    1.786157] sunxi-spinand-phy: PageCntPerBlk:       64
[    1.791929] sunxi-spinand-phy: SectCntPerPage:      4
[    1.797591] sunxi-spinand-phy: OobSizePerPage:      64
[    1.803369] sunxi-spinand-phy: BadBlockFlag:        0x0
[    1.809227] sunxi-spinand-phy: OperationOpt:        0x7
[    1.815102] sunxi-spinand-phy: MaxEraseTimes:       65000
[    1.821157] sunxi-spinand-phy: EccFlag:             0x0
[    1.827026] sunxi-spinand-phy: EccType:             2
[    1.832706] sunxi-spinand-phy: EccProtectedType:    3
[    1.838369] sunxi-spinand-phy: ========================================
[    1.845824] sunxi-spinand-phy:
[    1.849343] sunxi-spinand-phy: ========== physical info ==========
[    1.856298] sunxi-spinand-phy: TotalSize:    128 M
[    1.861699] sunxi-spinand-phy: SectorSize:   512 B
[    1.867072] sunxi-spinand-phy: PageSize:     2 K
[    1.872267] sunxi-spinand-phy: BlockSize:    128 K
[    1.877640] sunxi-spinand-phy: OOBSize:      64 B
[    1.882924] sunxi-spinand-phy: ========================================
[    1.890347] sunxi-spinand-phy:
[    1.893877] sunxi-spinand-phy: ========== logical info ==========
[    1.900717] sunxi-spinand-phy: TotalSize:    128 M
[    1.906099] sunxi-spinand-phy: SectorSize:   512 B
[    1.911469] sunxi-spinand-phy: PageSize:     4 K
[    1.916663] sunxi-spinand-phy: BlockSize:    256 K
[    1.922048] sunxi-spinand-phy: OOBSize:      128 B
[    1.927419] sunxi-spinand-phy: ========================================
[    1.934978] sunxi-spinand-phy: block lock register: 0x00
[    1.941126] sunxi-spinand-phy: feature register: 0x19
[    1.946931] sunxi-spinand-phy: sunxi physic nand init end
[    1.957904] sunxipart: failed to parse sunxi_gpt!
[    1.963239] Creating 4 MTD partitions on "sunxi_mtd_nand":
[    1.969467] 0x000000000000-0x000000100000 : "boot0"
[    1.980550] 0x000000100000-0x000000400000 : "uboot"
[    1.989243] random: fast init done
[    1.999464] 0x000000400000-0x000000500000 : "secure_storage"
[    2.011302] 0x000000500000-0x000008000000 : "sys"
[    2.301197] libphy: Fixed MDIO Bus: probed
[    2.309375] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[    2.321169] sunxi gmac driver's version: 1.0.0
[    2.327263] gmac-power0: NULL
[    2.330595] gmac-power1: NULL
[    2.333945] gmac-power2: NULL
[    2.343425] Failed to alloc md5
[    2.346964] eth0: Use random mac address
[    2.352602] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.359937] sunxi-ehci: EHCI SUNXI driver
[    2.365110] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.372148] sunxi-ohci: OHCI SUNXI driver
[    2.378155] usbcore: registered new interface driver uas
[    2.384675] usbcore: registered new interface driver usb-storage
[    2.391924] usbcore: registered new interface driver ums-alauda
[    2.398858] usbcore: registered new interface driver ums-cypress
[    2.405893] usbcore: registered new interface driver ums-datafab
[    2.412952] usbcore: registered new interface driver ums_eneub6250
[    2.420163] usbcore: registered new interface driver ums-freecom
[    2.427202] usbcore: registered new interface driver ums-isd200
[    2.434128] usbcore: registered new interface driver ums-jumpshot
[    2.441252] usbcore: registered new interface driver ums-karma
[    2.448100] usbcore: registered new interface driver ums-onetouch
[    2.455374] usbcore: registered new interface driver ums-realtek
[    2.462424] usbcore: registered new interface driver ums-sddr09
[    2.469362] usbcore: registered new interface driver ums-sddr55
[    2.476319] usbcore: registered new interface driver ums-usbat
[    2.486044] ts probe start
[    2.488426] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[    2.501815] ts probe success
[    2.502684] sunxi_gpadc_init,2137, success
[    2.517578] sunxi-rtc 7090000.rtc: registered as rtc0
[    2.523429] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T04:48:31 UTC (17311)
[    2.532846] sunxi-rtc 7090000.rtc: sunxi rtc probed
[    2.539128] i2c /dev entries driver
[    2.543401] IR NEC protocol handler initialized
[    2.548487] IR RC5(x/sz) protocol handler initialized
[    2.555049] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[    2.567085] sunxi_ir_startup: get ir protocol failed
[    2.567107] (NULL device *): deviceless supply  not found, using dummy regulator
[    2.581469] Registered IR keymap rc_map_sunxi
[    2.587281] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[    2.597125] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[    2.609101] sunxi cedar version 1.1
[    2.613702] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    2.620066] VE: sunxi_cedar_probe power-domain init!!!
[    2.625862] VE: install start!!!
[    2.625862]
[    2.632612] VE: cedar-ve the get irq is 45
[    2.632612]
[    2.639924] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[    2.639924]
[    2.649247] VE: install end!!!
[    2.649247]
[    2.654343] VE: sunxi_cedar_probe
[    2.662279] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    2.677970] usbcore: registered new interface driver usbhid
[    2.684264] usbhid: USB HID core driver
[    2.688569] exFAT: Version 1.3.0
[    2.704482] NET: Registered protocol family 10
[    2.717405] Segment Routing with IPv6
[    2.721874] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.738495] NET: Registered protocol family 17
[    2.743617] NET: Registered protocol family 15
[    2.749505] Registering SWP/SWPB emulation handler
[    2.757198] Loading compiled-in X.509 certificates
[    2.768492] HDMI 2.0 driver init start!
[    2.772929] boot_hdmi=false
[    2.776177] ERROR: can not get hdmi_cts_compatibility
[    2.781981] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    2.790077] HDMI2.0 module init end
[    2.909529] sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
[    2.923507] sunxi-i2c sunxi-i2c1: probe success
[    2.938499] get ehci0-controller wakeup-source is fail.
[    2.944800] sunxi ehci0-controller don't init wakeup source
[    2.951089] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b82438, 0x:c8869000, irq_no:3b
[    2.963146] [sunxi-ehci0]: Not init ehci0
[    2.968571] get ohci0-controller wakeup-source is fail.
[    2.974933] sunxi ohci0-controller don't init wakeup source
[    2.981218] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b826c8
[    2.990912] [sunxi-ohci0]: Not init ohci0
[    2.996311] get ehci1-controller wakeup-source is fail.
[    3.002609] sunxi ehci1-controller don't init wakeup source
[    3.008896] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b82958, 0x:c8873000, irq_no:3d
[    3.022417] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[    3.037073] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[    3.044541] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    3.055295] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[    3.091589] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[    3.105366] hub 1-0:1.0: USB hub found
[    3.109919] hub 1-0:1.0: 1 port detected
[    3.118498] get ohci1-controller wakeup-source is fail.
[    3.124912] sunxi ohci1-controller don't init wakeup source
[    3.131173] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b82be8
[    3.142298] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[    3.155801] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[    3.163230] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[    3.173883] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[    3.261410] hub 2-0:1.0: USB hub found
[    3.265944] hub 2-0:1.0: 1 port detected
[    3.277230] ubi0: attaching mtd3
[    3.699447] random: crng init done
[    3.764456] ubi0: scanning is finished
[    3.812627] ubi0: attached mtd3 (name "sys", size 123 MiB)
[    3.818793] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[    3.826597] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[    3.834269] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    3.842106] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[    3.848843] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
[    3.856974] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[    3.866366] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[    3.876741] ubi0: background thread "ubi_bgt0d" started, PID 985
[    3.886121] get ctp_power is fail, -22
[    3.890335] get ctp_power_ldo_vol is fail, -22
[    3.897286] sunxi_ctp_startup: ctp_power_io is invalid.
[    3.903650] get ctp_gesture_wakeup fail, no gesture wakeup
[    3.909829] gt9xxnew_ts 1-0014: 1-0014 supply ctp not found, using dummy regulator
[    4.081670] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.089829] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.097513] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.105653] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.113349] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.121481] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.129162] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.137295] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.145020] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.153156] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.160782] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[    4.321570] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    4.351613] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.359744] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.367425] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.375573] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.383247] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.391385] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.399060] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.407196] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.414869] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.423008] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.430622] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[    4.591571] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    4.621613] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.629752] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.637433] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.645564] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.653247] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.661376] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.669056] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.677187] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.684866] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.692998] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.700622] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[    4.861569] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    4.891610] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.899755] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.907428] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.915570] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.923242] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.931379] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.939052] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.947189] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.954864] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    4.963000] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    4.970616] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[    5.131572] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    5.161620] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    5.169751] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    5.177472] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    5.185603] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    5.193288] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    5.201418] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    5.209101] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    5.217234] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    5.224915] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[    5.233048] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[    5.240672] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[    5.401569] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    5.431567] I2C communication ERROR!
[    5.431637] regulator-dummy: Underflow of regulator enable count
[    5.443332] gt9xxnew_ts: probe of 1-0014 failed with error -1
[    5.451266] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.465793] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.473943] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.483698] clk: Not disabling unused clocks
[    5.488537] alloc_fd: slot 0 not NULL!
[    5.493097] cfg80211: failed to load regulatory.db
[    5.505175] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -19
[    5.513769] Please append a correct "root=" boot option; here are the available partitions:
[    5.523166] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    5.532442] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #4
[    5.539078] Hardware name: Generic DT based system
[    5.544471] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[    5.553164] [<c010a894>] (show_stack) from [<c063e170>] (dump_stack+0x7c/0x98)
[    5.561272] [<c063e170>] (dump_stack) from [<c01197e8>] (panic+0x104/0x3dc)
[    5.569087] [<c01197e8>] (panic) from [<c0a01294>] (mount_block_root+0x278/0x32c)
[    5.577489] [<c0a01294>] (mount_block_root) from [<c0a01450>] (prepare_namespace+0x84/0x178)
[    5.586965] [<c0a01450>] (prepare_namespace) from [<c065284c>] (kernel_init+0x8/0x10c)
[    5.595851] [<c065284c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    5.604342] Exception stack(0xc704dfb0 to 0xc704dff8)
[    5.610008] dfa0:                                     00000000 00000000 00000000 00000000
[    5.619187] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.628365] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    5.635791] CPU1: stopping
[    5.638829] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #4
[    5.645466] Hardware name: Generic DT based system
[    5.650846] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[    5.659535] [<c010a894>] (show_stack) from [<c063e170>] (dump_stack+0x7c/0x98)
[    5.667644] [<c063e170>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
[    5.675849] [<c010c690>] (handle_IPI) from [<c0321d18>] (gic_handle_irq+0x70/0x78)
[    5.684349] [<c0321d18>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[    5.692744] Exception stack(0xc7097f80 to 0xc7097fc8)
[    5.698413] 7f80: 0000acf0 c76c8534 00000000 c0114d00 00000002 c7096000 c0b03be8 c0b03c24
[    5.707593] 7fa0: 4000406a 410fc075 00000000 00000000 c0b6e8b0 c7097fd0 c0107f90 c0107f94
[    5.716766] 7fc0: 60000113 ffffffff
[    5.720682] [<c01021cc>] (__irq_svc) from [<c0107f94>] (arch_cpu_idle+0x2c/0x38)
[    5.728987] [<c0107f94>] (arch_cpu_idle) from [<c013e410>] (do_idle+0xb8/0x120)
[    5.737194] [<c013e410>] (do_idle) from [<c013e714>] (cpu_startup_entry+0x18/0x1c)
[    5.745691] [<c013e714>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[    5.753518] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
#5 2022-05-13 21:20:23
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
对比没开Qt之前的日志,重点观察
楼主 #6 2022-05-13 22:17:15
笃学
已发帖子: 20
对比没开Qt之前的日志,重点观察
好嘞,感谢感谢
#7 2022-05-16 10:30:24
shaoxi2010
已发帖子: 367
有点怀疑你是不是没开什么选项,建议你先用带ramfs得系统启动,尝试手动挂载下看看缺少什么东西不。
楼主 #8 2022-05-16 11:39:00
笃学
已发帖子: 20
shaoxi2010 说:
OK,感谢感谢
楼主 #9 2022-05-16 11:39:45
笃学
已发帖子: 20
好像是根文件系统的空间不够导致的
#10 2022-06-21 15:52:08
hxhlb
已发帖子: 27
它支持QT?
为什么我的sdk编译的没有QT呢, 就算选上也不行, prebuilt的也不行. libgpu根本就编译不过去.
请问您是Tina SDK吗?
楼主 #11 2022-06-23 11:57:29
笃学
已发帖子: 20
hxhlb 说:
它支持QT?
请问您是Tina SDK吗?
我编的不是Tinade SDK,可以查看下qt编译的环境变量,可能路径会改动。
