芒果派MangoPi MQ-Dual 购买时,无货: 单拍5寸电容屏,800*480,GT911电容触摸 购买:单拍5寸电阻屏旧,480*272分辨率,电阻触摸,外观旧
480*272分辨率 驱动异常问题。
1、屏幕没资料,尝试修改无效。
480*272分辨率 大部分都是4.3寸, 这个是5寸,疑问?
2、使用buildroot
git clone https://github.com/yuzukihd/Buildroot-YuzukiSBC # 主站
git clone https://gitee.com/GloomyGhost/Buildroot-YuzukiSBC # 镜像站
显示异常:uboot
=> disp
screen 0:
de_rate 300000000 hz, ref_fps:45
mgr0: 480x272 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[1] force_sync[0] unblank direct_show[false] iommu[0]
lcd output backlight(100) fps:87.4 480x 272
err:0 skip:0 irq:390 vsync:0 vsync_skip:0
BUF enable ch[1] lyr[0] z[0] prem[N] a[globl 255] fmt[ 0] fb[ 480, 272; 0, 0; 0, 0] crop[ 0, 0, 480, 272] frame[ 0, 0, 480, 272] addr[448ed000, 0, 0] flags[0x 0] trd[0,0]
3、尝试其它SDK 无法解决。
https://github.com/mangopi-sbc/buildroot-d1x-t113
https://mangopi.cc/d1
https://mangopi.cc/t113dev
原始SDK
链接:https://pan.baidu.com/s/1R3P5lpVzajA8w56fIRnTKA?pwd=1111 使用原始SDK pack 的img 烧录到SD无法使用。
显示异常如图:
最近编辑记录 bynce (2022-05-23 14:53:11)
咋没有大拿回复 。 痛苦
现在解决了吗?
现在解决了吗?
无解。 更换5寸其它屏幕。 可以了。
// 480x272 RGB LCD
&lcd0 {
lcd_used = <1>;
lcd_driver_name = "default_lcd";
lcd_backlight = <50>;
lcd_if = <0>;
lcd_x = <480>;
lcd_y = <272>;
lcd_width = <95>;
lcd_height = <54>;
lcd_dclk_freq = <9>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <7>;
lcd_pwm_freq = <50000>;
lcd_pwm_pol = <1>;
lcd_hbp = <43>;
lcd_ht = <525>;
lcd_hspw = <41>;
lcd_vbp = <12>;
lcd_vt = <286>;
lcd_vspw = <10>;
lcd_lvds_if = <0>;
lcd_lvds_colordepth = <1>;
lcd_lvds_mode = <0>;
lcd_frm = <0>;
lcd_io_phase = <0x0000>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
pinctrl-0 = <&rgb18_pins_a>;
pinctrl-1 = <&rgb18_pins_b>;
