楼主 # 2022-06-02 18:02:52
johnatia
problem while activating ssh on mangopi-r3 based on F1C200S
hello there
I'm trying to activate otg usb as RNDIS to communicate with MangoPi using ssh
I'm using the following buildroot linux image
buildroot-mangopi-r
by default the otg is working as storage device , I did the following steps to activate otg as RNDIS to work with ssh
 make menuconfig
Target packages --->
	Networking application --->
		[*] openssh
	Package managers --->
		[*] opkg
		[*] gnupg support
	Text editors and viewers
		[*] nano
		[*] optimize for size (NEW)
then type
make linux-menuconfig
device dervicers -->
	[*] USB support --->
		<*> USB Gadget support --->
			<*> USB Gadget precomposed configurations
				[*] RNDIS support (NEW)
				[*] Ethernet Emulation Model (EEM) support
after booting linux
check the usb RNDIS  is working by
 ip a
now, change the file the interfaces file in /etc/network/interfaces
 nano /etc/network/interfaces
auto usb0
#I tried also to comment the following line but it doesn't work.
allow-hotplug usb0
# The address, gateway and netmask are necessary.
iface usb0 inet static
    address 10.42.0.2
    netmask 255.255.255.252
    dns-search mangopi.edu
    dns-namesevers 8.8.8.8 128.83.185.40, 128.83.185.41
the total steps
I set a static ip in windows11
when trying to connect using ssh,  I got that!
also when trying
 ping 10.42.0.2
I got
 Request timed out.
What's the problem?
#1 2022-06-02 18:16:48
所在地: 你猜
已发帖子: 3,380
Re: problem while activating ssh on mangopi-r3 based on F1C200S
disabled other network card on PC?
楼主 #2 2022-06-03 01:17:36
johnatia
no but I connected my raspberrypi zero using the same way by assigning static ip and it worked for me.
so I assume the problem in the mangoPi not the pc
I also tried to connect my mangoPi to linux pc and assigning static ip but no change.
#3 2022-06-03 09:29:52
所在地: 你猜
已发帖子: 3,380
