使用V831芯片 移植AC108驱动时,启动时daudio probe失败,内核驱动已经勾选上,芯片的I2C_probe成功,报错,求各位大佬帮忙看看
[ 2.227781] ac108 2-003b: i2c probe succeed.
[ 2.228361] --->sunxi_daudio_dev_probe<--- strat.
[ 2.228488] sunxi-daudio daudio0: regulator missing or invalid
[ 2.228605] --->sunxi_daudio_dev_probe<--- end.内核是4.9,board.dts如下
* Allwinner Technology CO., Ltd. sun8iw19p1 soc board.
* soc board support.
/dts-v1/;
#include "sun8iw19p1.dtsi"
dram: dram {
dram_clk = <0x000001e0>;
dram_type = <0x00000003>;
dram_zq = <0x00003bfb>;
dram_odt_en = <0x00000001>;
dram_para1 = <0x004310f2>;
dram_para2 = <0x02000000>;
dram_mr0 = <0x00001c70>;
dram_mr1 = <0x00000000>;
dram_mr2 = <0x00000018>;
dram_mr3 = <0x00000000>;
dram_tpr0 = <0x0046190d>;
dram_tpr1 = <0x0121210a>;
dram_tpr2 = <0x0005403b>;
dram_tpr3 = <0x00002006>;
dram_tpr4 = <0x05040405>;
dram_tpr5 = <0x05050302>;
dram_tpr6 = <0x90006644>;
dram_tpr7 = <0x42c21590>;
dram_tpr8 = <0xd05612c0>;
dram_tpr9 = <0x00083def>;
dram_tpr10 = <0x00000000>;
dram_tpr11 = <0x00210000>;
dram_tpr12 = <0x00000055>;
dram_tpr13 = <0x00006003>;
opp_dvfs_table:opp_dvfs_table {
cluster_num = <1>;
opp_table_count = <1>;
cpu_opp_l_table0: opp_l_table0 {
compatible = "allwinner,opp_l_table0";
opp_count = <2>;
opp-shared;
opp00 {
opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <900000>;
axi-bus-divide-ratio = <3>;
clock-latency-ns = <2000000>;
opp01 {
opp-hz = /bits/ 64 <816000000>;
soc@03000000 {
pinctrl@0300b000 {
twi0_pins_a: twi0@0 {
allwinner,pins = "PI3", "PI4";
allwinner,pname = "twi0_scl", "twi0_sda";
allwinner,function = "twi0";
allwinner,muxsel = <5>;
allwinner,drive = <1>;
allwinner,pull = <0>;
twi0_pins_b: twi0@1 {
allwinner,function = "io_disabled";
allwinner,muxsel = <7>;
twi1_pins_a: twi1@0 {
allwinner,pins = "PI1", "PI2";
allwinner,pname = "twi1_scl", "twi1_sda";
allwinner,function = "twi1";
twi1_pins_b: twi1@1 {
twi2_pins_a: twi2@0 {
allwinner,pins = "PH11", "PH12";
allwinner,pname = "twi2_scl", "twi2_sda";
allwinner,function = "twi2";
twi2_pins_b: twi2@1 {
spi0_pins_a: spi0@0 {
allwinner,pins = "PC0", "PC2", "PC3",
"PC5", "PC4";
allwinner,pname = "spi0_sclk", "spi0_mosi",
"spi0_miso", "spi0_hold", "spi0_wp";
allwinner,function = "spi0";
allwinner,muxsel = <4>;
spi0_pins_b: spi0@1 {
allwinner,pins = "PC1", "PC6";
allwinner,pname = "spi0_cs0", "spi0_cs1";
allwinner,pull = <1>; // only CS should be pulled up
spi0_pins_c: spi0@2 {
allwinner,pins = "PC0", "PC1", "PC2", "PC3",
"PC4", "PC5", "PC6";
spi1_pins_a: spi1@0 {
allwinner,pins = "PH0", "PH1", "PH2";
allwinner,pname = "spi1_sclk", "spi1_mosi",
"spi1_miso";
spi1_pins_b: spi1@1 {
allwinner,pins = "PH3";
allwinner,pname = "spi1_cs0";
spi1_pins_c: spi1@2 {
allwinner,pins = "PH0", "PH1", "PH2", "PH3";
sdc0_pins_a: sdc0@0 {
allwinner,pins = "PF0", "PF1", "PF2", "PF3",
"PF4", "PF5";
allwinner,function = "sdc0";
allwinner,muxsel = <2>;
allwinner,drive = <3>;
sdc0_pins_b: sdc0@1 {
"PF4", "PF5";
sdc1_pins_a: sdc1@0 {
allwinner,pins = "PG0", "PG1", "PG2", "PG3",
"PG4", "PG5";
allwinner,function = "sdc1";
owc0_pins_a: owc0@0 {
allwinner,pins = "PH4";
allwinner,pname = "owc0";
allwinner,function = "owc0";
owc0_pins_b: owc0_sleep@0 {
pwm0_pins_a: pwm0@0 {
allwinner,pins = "PH0";
allwinner,pname = "pwm0_positive";
allwinner,function = "pwm0";
pwm0_pins_b: pwm0@1 {
pwm1_pins_a: pwm1@0 {
allwinner,pins = "PH1";
allwinner,pname = "pwm1_positive";
allwinner,function = "pwm1";
pwm1_pins_b: pwm1@1 {
pwm2_pins_a: pwm2@0 {
allwinner,pins = "PH2";
allwinner,pname = "pwm2_positive";
allwinner,function = "pwm2";
pwm2_pins_b: pwm2@1 {
pwm3_pins_a: pwm3@0 {
allwinner,pname = "pwm3_positive";
allwinner,function = "pwm3";
pwm3_pins_b: pwm3@1 {
pwm4_pins_a: pwm4@0 {
allwinner,pname = "pwm4_positive";
allwinner,function = "pwm4";
pwm4_pins_b: pwm4@1 {
// pwm5_pins_a: pwm5@0 {
// allwinner,pins = "PH5";
// allwinner,pname = "pwm5_positive";
// allwinner,function = "pwm5";
// allwinner,muxsel = <2>;
// allwinner,drive = <1>;
// allwinner,pull = <0>;
// pwm5_pins_b: pwm5@1 {
// allwinner,function = "io_disabled";
// allwinner,muxsel = <7>;
pwm6_pins_a: pwm6@0 {
allwinner,pins = "PH6";
allwinner,pname = "pwm6_positive";
allwinner,function = "pwm6";
pwm6_pins_b: pwm6@1 {
pwm7_pins_a: pwm7@0 {
allwinner,pins = "PH7";
allwinner,pname = "pwm7_positive";
allwinner,function = "pwm7";
pwm7_pins_b: pwm7@1 {
pwm8_pins_a: pwm8@0 {
allwinner,pins = "PH8";
allwinner,pname = "pwm8_positive";
allwinner,function = "pwm8";
pwm8_pins_b: pwm8@1 {
pwm9_pins_a: pwm9@0 {
allwinner,pins = "PH9";
allwinner,pname = "pwm9_positive";
allwinner,function = "pwm9";
pwm9_pins_b: pwm9@1 {
rgb8_pins_a: rgb8@0 {
allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6",
"PD7", "PD8", "PD18", "PD19", "PD20";
allwinner,pname = "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7",
"lcdd10", "lcdd11", "lcdd12", "lcdclk", "lcdde",
"lcdhsync";
allwinner,function = "lcd0";
rgb8_pins_b: rgb8@1 {
allwinner,pins = "PD1", "PD2","PD3","PD4","PD5","PD6",
"PD7","PD8","PD18","PD19","PD20";
gpadc:gpadc{
channel_num = <1>;
channel_select = <0x01>;
channel_data_select = <0>;
channel_compare_select = <0x01>;
channel_cld_select = <0x01>;
channel_chd_select = <0x01>;
channel0_compare_lowdata = <1700000>;
channel0_compare_higdata = <1200000>;
key_cnt = <2>;
key0_vol = <0>;
key0_val = <2>; /* KEY_1 */
key1_vol = <160>;
key1_val = <3>; /* KEY_2 */
uart1: uart@05000400 {
compatible = "allwinner,sun8i-uart";
device_type = "uart1";
reg = <0x0 0x05000400 0x0 0x400>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart1>;
pinctrl-0 = <&uart1_pins_a>;
pinctrl-1 = <&uart1_pins_b>;
uart1_port = <1>;
uart1_type = <4>;
// uart3: uart@05000c00 {
// compatible = "allwinner,sun8i-uart";
// device_type = "uart3";
// reg = <0x0 0x05000c00 0x0 0x400>;
// interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
// clocks = <&clk_uart3>;
// pinctrl-names = "default", "sleep";
// pinctrl-0 = <&uart3_pins_a>;
// pinctrl-1 = <&uart3_pins_b>;
// uart3_port = <3>;
// uart3_type = <4>;
// status = "okay";
twi0: twi@0x05002000{
pinctrl-0 = <&twi0_pins_a>;
pinctrl-1 = <&twi0_pins_b>;
twi_drv_used = <1>;
status = "disable";
twi1: twi@0x05002400{
pinctrl-0 = <&twi1_pins_a>;
pinctrl-1 = <&twi1_pins_b>;
clock-frequency = <400000>;
twi2: twi@0x05002800{
pinctrl-0 = <&twi2_pins_a>;
pinctrl-1 = <&twi2_pins_b>;
ac108: ac108@3b{
#sound-dai-cells = <0>;
compatible = "Allwinner,MicArray_0";
reg = <0x3b>;
regulator_used = <0x0>;
power_voltage = <3300000>;
regulator_name = "vcc-3v3";
power_gpio_used = <0x0>;
reset_gpio_used = <0x0>;
twi_bus = <0x1>;
pga_gain = <0x1F>;
slot_width = <0x20>;
lrck_period = <0x80>;
ref_pga_used = <0x1>;
ref_pga_gain = <0x10>;
ref_channel = <0x3>;
debug_mode = <0x0>;
// ac108: ac108@35{
// compatible = "Allwinner,MicArray_1";
// reg = <0x35>;
// regulator_used = <0x0>;
// power_voltage = <3300000>;
// regulator_name = "vcc-3v3";
// power_gpio_used = <0x0>;
// reset_gpio_used = <0x0>;
// twi_bus = <0x1>;
// pga_gain = <0x1F>;
// slot_width = <0x20>;
// lrck_period = <0x80>;
// ref_pga_used = <0x1>;
// ref_pga_gain = <0x10>;
// ref_channel = <0x3>;
// debug_mode = <0x0>;
// status = "okay";
spi@05010000 {
pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
pinctrl-1 = <&spi0_pins_c>;
status = "disable";
spi_board0 {
device_type = "spi_board0";
compatible = "m25p80";
spi-max-frequency = <0x5f5e100>;
reg = <0x0>;
spi-rx-bus-width = <0x1>;
spi-tx-bus-width = <0x1>;
// spi@05011000 {
// #address-cells = <1>;
// #size-cells = <0>;
// reg = <0x0 0x05011000 0x0 0x1000>;
// interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
// clocks = <&clk_pll_periph0>, <&clk_spi1>;
// clock-frequency = <200000000>;
// pinctrl-0 = <&spi1_pins_b>;
// pinctrl-1 = <&spi1_pins_c>;
// spi1_cs_number = <2>;
// spi1_cs_bitmap = <3>;
// status = "okay";
// spi_board1 {
// device_type = "spi_board1";
// compatible = "spidev";
// spi-max-frequency = <0x5f5e100>;
// reg = <0x0>;
// spi-rx-bus-width = <0x1>;
// spi-tx-bus-width = <0x1>;
vind0:vind@0 {
vind0_clk = <270000000>;
vind0_isp = <200000000>;
actuator0:actuator@0 {
device_type = "actuator0";
actuator0_name = "ad5820_act";
actuator0_slave = <0x18>;
actuator0_af_pwdn = <>;
actuator0_afvdd = "afvcc-csi";
actuator0_afvdd_vol = <2800000>;
status = "disabled";
flash0:flash@0 {
device_type = "flash0";
flash0_type = <2>;
flash0_en = <>;
flash0_mode = <>;
flash0_flvdd = "";
flash0_flvdd_vol = <>;
device_id = <0>;
sensor0:sensor@0 {
device_type = "sensor0";
// sensor0_mname = "ov9732_mipi";
sensor0_mname = "sp2305_mipi";
sensor0_twi_cci_id = <1>;
// sensor0_twi_addr = <0x6c>;
sensor0_twi_addr = <0x78>;
sensor0_mclk_id = <0>;
sensor0_pos = "rear";
sensor0_isp_used = <1>;
sensor0_fmt = <1>;
sensor0_stby_mode = <0>;
sensor0_vflip = <0>;
sensor0_hflip = <0>;
sensor0_iovdd-supply = <>;
sensor0_iovdd_vol = <1800000>;
sensor0_avdd-supply = <>;
sensor0_avdd_vol = <2800000>;
sensor0_dvdd-supply = <>;
sensor0_dvdd_vol = <1200000>;
sensor0_power_en = <>;
/* board error, we can not use the right config. */
sensor0_reset = <&pio PE 16 1 0 1 0>;
sensor0_pwdn = <&pio PE 17 1 0 1 0>;
sensor1:sensor@1 {
device_type = "sensor1";
sensor1_mname = "ov5647";
sensor1_twi_cci_id = <0>;
sensor1_twi_addr = <0x6c>;
sensor1_mclk_id = <1>;
sensor1_pos = "front";
sensor1_isp_used = <0>;
sensor1_fmt = <0>;
sensor1_stby_mode = <0>;
sensor1_vflip = <0>;
sensor1_hflip = <0>;
sensor1_iovdd-supply = <>;
sensor1_iovdd_vol = <2800000>;
sensor1_avdd-supply = <>;
sensor1_avdd_vol = <2800000>;
sensor1_dvdd-supply = <>;
sensor1_dvdd_vol = <1500000>;
sensor1_power_en = <>;
sensor1_reset = <&pio PI 3 1 0 1 0>;
sensor1_pwdn = <&pio PI 4 1 0 1 0>;
vinc0:vinc@0 {
vinc0_csi_sel = <0>;
vinc0_mipi_sel = <0>;
vinc0_isp_sel = <0>;
vinc0_isp_tx_ch = <0>;
vinc0_rear_sensor_sel = <0>;
vinc0_front_sensor_sel = <0>;
vinc0_sensor_list = <0>;
vinc1:vinc@1 {
vinc1_csi_sel = <0>;
vinc1_mipi_sel = <0>;
vinc1_isp_sel = <0>;
vinc1_isp_tx_ch = <0>;
vinc1_rear_sensor_sel = <0>;
vinc1_front_sensor_sel = <0>;
vinc1_sensor_list = <0>;
vinc2:vinc@2 {
vinc2_csi_sel = <0>;
vinc2_mipi_sel = <0>;
vinc2_isp_sel = <0>;
vinc2_isp_tx_ch = <0>;
vinc2_rear_sensor_sel = <0>;
vinc2_front_sensor_sel = <0>;
vinc2_sensor_list = <0>;
vinc3:vinc@3 {
vinc3_csi_sel = <1>;
vinc3_mipi_sel = <0xff>;
vinc3_isp_sel = <1>;
vinc3_isp_tx_ch = <0>;
vinc3_rear_sensor_sel = <1>;
vinc3_front_sensor_sel = <1>;
vinc3_sensor_list = <0>;
s_owc0: s_owc@07040400 {
pinctrl-0 = <&owc0_pins_a>;
pinctrl-1 = <&owc0_pins_b>;
sdc0: sdmmc@04020000 {
pinctrl-0 = <&sdc0_pins_a>;
bus-width = <4>;
// cd-gpios = <&pio PF 6 0 1 3 0xffffffff>;
non-removable;
card-pwr-gpios;// = <&pio PC 4 1 1 2 0xffffffff>;
sunxi-power-save-mode;
sunxi-signal-vol-sw-without-pmu;
sd-uhs-sdr50;
sd-uhs-ddr50;
sd-uhs-sdr104;
/*sunxi-dis-signal-vol-sw;*/
max-frequency = <150000000>;
min-frequency = <100000>;
cd-used-24M;
no-sdio;
/*broken-cd;*/
ctl-spec-caps = <0x8>;
card0_boot_para {
device_type = "card0_boot_para";
card_ctrl = <0x0>;
card_high_speed = <0x1>;
card_line = <0x4>;
time_pwroff_ms = <200>;
pinctrl-1 = <&sdc0_pins_b>;
sdc1: sdmmc@04021000 {
pinctrl-0 = <&sdc1_pins_a>;
bus-width = <4>;
/*sunxi-power-save-mode;*/
/*sd-uhs-sdr12*/
/*sd-uhs-sdr25*/
/*sd-uhs-sdr50*/
/*sd-uhs-sdr104*/
cap-sdio-irq;
keep-power-in-suspend;
ignore-pm-notify;
max-frequency = <50000000>;
usbc0:usbc0@0{
usb_port_type = <0>;
usb_detect_type = <0>;
usb_detect_mode = <0>;
usb_id_gpio;
usb_det_vbus_gpio;
usb_drv_vbus_gpio;
usb_host_init_state = <0>;
disp: disp@01000000 {
disp_init_enable = <1>;
disp_mode = <0>;
screen0_output_type = <1>;
screen0_output_mode = <4>;
disp_rotation_used = <1>;
degree0 = <0>;
fb0_format = <8>;
fb0_width = <240>;
fb0_height = <240>;
// fb0_height = <320>;
lcd0_backlight = <50>;
lcd0_bright = <50>;
lcd0_contrast = <50>;
lcd0_saturation = <57>;
lcd0_hue = <50>;
lcd0: lcd0@01c0c000 {
lcd_used = <1>;
lcd_size = "1.3";
lcd_model_name = "inv";
lcd_driver_name = "st7789v_cpu";
lcd_x = <240>;
lcd_y = <240>;
lcd_width = <108>;
lcd_height = <64>;
lcd_dclk_freq = <10>;
lcd_backlight = <50>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <1>;
lcd_pwm_freq = <50000>;
lcd_pwm_pol = <1>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <60>;
lcd_ht = <298>;
lcd_hspw = <30>;
lcd_vbp = <250>;
lcd_vt = <265>;
lcd_vspw = <2>;
lcd_if = <1>;
lcd_frm = <2>;
lcd_cpu_mode = <1>;
lcd_cpu_te = <0>;
lcd_cpu_if = <14>;
lcd_io_phase = <0x0000>;
lcdgamma4iep = <22>;
lcd_gamma_en = <0>;
lcd_cmap_en = <0>;
lcd_bright_curve_en = <0>;
lcd_rb_swap = <0>;
lcd_gpio_0 = <&pio PH 5 1 0 3 0>; /* rst */
lcd_gpio_1 = <&pio PD 21 1 0 3 0>; /* cs */
pinctrl-0 = <&rgb8_pins_a>;
pinctrl-1 = <&rgb8_pins_b>;
daudio0:daudio@0x05090000 {
mclk_div = <0x0>;
frametype = <0x00>;
tdm_config = <0x01>;
sign_extend = <0x00>;
tx_data_mode = <0x00>;
rx_data_mode = <0x00>;
msb_lsb_first = <0x00>;
pcm_lrck_period = <0x80>;
slot_width_select = <0x20>;
asrc_function_en = <0x00>;
daudio_master = <0x04>;
signal_inversion = <0x01>;
audio_format = <0x01>;
daudio1:daudio@0x05091000 {
mclk_div = <0x01>;
frametype = <0x00>;
codec:codec@0x05096000 {
pa_level = <0x1>;
main_gain = <0x17>;
adcdrc_cfg = <0x00>;
adchpf_cfg = <0x01>;
dacdrc_cfg = <0x01>;
dachpf_cfg = <0x00>;
digital_vol = <0x00>;
lineout_vol = <0x1f>;
pa_msleep_time = <0xa0>;
/* gpio-spk = <&pio PH 14 1 1 1 1>; */
sndcodec:sound@0 {
snddaudio0:sound@1 {
sunxi,snddaudio-codec = "ac108.2-0035";
sunxi,snddaudio-codec-dai = "ac108-pcm1";
snddaudio-codec,cpu{
sound-dai = <&daudio0>;
daudio2_master:simple-audio-card.codec{
sound-dai = <&ac108>;
snddaudio1:sound@2 {
//wlan:wlan {
// compatible = "allwinner,sunxi-wlan";
// clocks = <&clk_losc_out>;
// wlan_busnum = <1>;
// wlan_usbnum = <3>;
// wakeup_source = <0>;
// /* wlan_power-supply = <®_dcdc1>; */
// /* io_regulator-supply = <®_dcdc5>; */
// /* wlan_power_vol = <3300000>; */
// /* io_regulator_vol = <3300000>; */
// /* wlan_en; */
// wlan_regon = <&pio PH 4 1 0 1 0>;
// /* wlan_hostwake = <&pio PG 7 0 0 1 0>; */
// wlan_hostwake;
// status = "okay";
};离线
启动日志如下:
[32]HELLO! BOOT0 is starting!
[35]BOOT0 commit : e3b2a9e
[38]board init start
[40]set pll start
[42]set pll end
[44][pmu]: bus read error
[46][pmu]: bus read error
[49]board init ok
[51]chip id check OK
[53]DRAM BOOT DRIVE INFO: V0.41
[56]DRAM CLK = 528 MHz
[58]DRAM Type = 2 (2:DDR2,3:DDR3)
[61]DRAMC read ODT off.
[64]DRAM ODT off.
[66]DRAM SIZE =64 M
[72]DRAM simple test OK.
[74]rtc standby flag is 0x0, super standby flag is 0x0
[79]dram size =64
[82]card no is 0
[84]sdcard 0 line count 4
[86][mmc]: mmc driver ver 2020-01-08 17:05
[90][mmc]: sdc0 spd mode error, 2
[93][mmc]: set f_max to 50M, set f_max_ddr to 25M
[98][mmc]: mmc 0 bias 0
[106][mmc]: Wrong media type 0x0
[109][mmc]: ***Try SD card 0***
[120][mmc]: HSSDR52/SDR25 4 bit
[123][mmc]: 50000000 Hz
[125][mmc]: 7680 MB
[127][mmc]: ***SD/MMC 0 init OK!!!***
[190]Loading boot-pkg Succeed(index=0).
[194]Entry_name = optee
[197]Entry_name = u-boot
[203]Entry_name = dtb
[206]Jump to second Boot.
MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019年 11月 21日 星期四 01:34:42 UTC arm
ERROR: [0x0] TEE-CORE:platform_standby_fdt_parse:126: no pmu node
ERROR: [0x0] TEE-CORE:sunxi_twi_parse_from_dt:84: no pmu node
U-Boot 2018.05-00008-g384031a (Jan 16 2020 - 14:12:41 +0800) Allwinner Technology
[00.278]CPU: Allwinner Family
[00.281]Model: sun8iw19
I2C: ready
[00.285]DRAM: 64 MiB
[00.288]Relocation Offset is: f9f46000
[00.309]secure enable bit: 0
[00.312]pmu_axp152_probe pmic_bus_read fail
[00.316]pmu_axp2101_probe pmic_bus_read fail
[00.320]bmu_axp152_probe pmic_bus_read fail
[00.324]bmu_axp2101_probe pmic_bus_read fail
[00.328]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=132Mhz
[00.334]gic: sec monitor mode
[00.337]flash init start
[00.339]workmode = 0,storage type = 1
[00.342]MMC: 0
[00.344]get mem for descripter OK !
card_caps:0x3000000a
host_caps:0x3000003f
[00.374]sunxi flash init ok
[00.377]Loading Environment from SUNXI_FLASH... OK
[00.400]update dts
root_partition is rootfs
set root to /dev/mmcblk0p3
[00.429]update part info
[00.455]update bootcmd
[00.457]No ethernet found.
## Booting kernel from Legacy Image at 45000000 ...
Image Name: ARM OpenWrt Linux-4.9.118
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2932432 Bytes = 2.8 MiB
Load Address: 40008000
Entry Point: 40008000
[01.830]Starting kernel ...
[01.832]mmc 2 not find, so not exit
[ 0.000000] Linux version 4.9.118 (tina@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #20 PREEMPT Thu Nov 10 07:04:28 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[ 0.000000] OF: fdt:Machine model: sun8iw19
[ 0.000000] ion_mem_reserve: err format for ion reserve list!
[ 0.000000] cma: Reserved 4 MiB at 0x43c00000
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c04bc018, node_mem_map c3b77000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p3 rootwait init=/pseudo_init rdinit=/rdinit partitions=env@mmcblk0p1:boot@mmcblk0p2:rootfs@mmcblk0p3:swap@mmcblk0p4:UDISK@mmcblk0p5 cma=4M mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=16K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw19p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-00008-g384031a(01/16/2020-14:12:41) mbr_offset=1032192 bootreason=unknow
[ 0.000000] Memory: 55480K/65536K available (3095K kernel code, 235K rwdata, 1192K rodata, 136K init, 129K bss, 5960K reserved, 4096K cma-reserved)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] modules : 0xbf800000 - 0xc0000000 ( 8 MB)
[ 0.000000] .text : 0xc0008000 - 0xc030e088 (3097 kB)
[ 0.000000] .init : 0xc0460000 - 0xc0482000 ( 136 kB)
[ 0.000000] .data : 0xc0482000 - 0xc04bcc18 ( 236 kB)
[ 0.000000] .bss : 0xc04bcc18 - 0xc04dd204 ( 130 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000137] Console: colour dummy device 80x30
[ 0.000159] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000171] pid_max: default: 32768 minimum: 301
[ 0.000322] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000333] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000840] CPU: Testing write buffer coherency: ok
[ 0.001087] Setting up static identity map for 0x400081c0 - 0x4000820c
[ 0.002330] devtmpfs: initialized
[ 0.025166] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.025491] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025516] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.025808] atomic64_test: passed
[ 0.025820] pinctrl core: initialized pinctrl subsystem
[ 0.026598] NET: Registered protocol family 16
[ 0.027727] DMA: preallocated 16 KiB pool for atomic coherent allocations
[ 0.028955] dump_class_init,857, success
[ 0.031717] sunxi iommu: irq = 23
[ 0.035530] sun8iw19p1-r-pinctrl r_pio: initialized sunXi PIO driver
[ 0.048606] use hosc , set rate 1000000
[ 0.048632] sun8iw19p1-pinctrl pio: initialized sunXi PIO driver
[ 0.050962] iommu: Adding device 1c0e000.ve to group 0
[ 0.051819] iommu: Adding device 2300000.eise to group 0
[ 0.058348] iommu: Adding device 1000000.disp to group 0
[ 0.059557] iommu: Adding device 1480000.g2d to group 0
[ 0.060888] iommu: Adding device 2400000.nna to group 0
[ 0.063715] iommu: Adding device csi0 to group 0
[ 0.064204] iommu: Adding device csi1 to group 0
[ 0.065738] iommu: Adding device 2100000.isp to group 0
[ 0.066720] iommu: Adding device 2104000.scaler to group 0
[ 0.067039] iommu: Adding device 2104400.scaler to group 0
[ 0.067350] iommu: Adding device 2104800.scaler to group 0
[ 0.067796] iommu: Adding device 2104c00.scaler to group 0
[ 0.068483] iommu: Adding device vinc0 to group 0
[ 0.069066] iommu: Adding device vinc1 to group 0
[ 0.111494] pwm module init!
[ 0.114772] SCSI subsystem initialized
[ 0.115114] usbcore: registered new interface driver usbfs
[ 0.115193] usbcore: registered new interface driver hub
[ 0.117467] usbcore: registered new device driver usb
[ 0.117725] sunxi_i2c_adap_init()2551 - init
[ 0.118251] sunxi_i2c_probe()2288 - [i2c1] twi_drv_used = 1
[ 0.118265] sunxi_i2c_probe()2292 - [i2c1] twi_pkt_interval = 0
[ 0.118282] twi1 supply twi not found, using dummy regulator
[ 0.118381] twi_request_gpio()455 - [i2c1] init name: twi1
[ 0.118663] sunxi_i2c_dma_request()1125 - [i2c1] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
[ 0.119054] sunxi_i2c_probe()2288 - [i2c2] twi_drv_used = 1
[ 0.119067] sunxi_i2c_probe()2292 - [i2c2] twi_pkt_interval = 0
[ 0.119084] twi2 supply twi not found, using dummy regulator
[ 0.119147] twi_request_gpio()455 - [i2c2] init name: twi2
[ 0.119787] sunxi_i2c_dma_request()1125 - [i2c2] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
[ 0.120459] media: Linux media interface: v0.10
[ 0.120595] Linux video capture interface: v2.00
[ 0.121723] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 0.121973] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
[ 0.122148] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 0.123320] Advanced Linux Sound Architecture Driver Initialized.
[ 0.126415] G2D: rcq version initialized.major:251
[ 0.127212] clocksource: Switched to clocksource arch_sys_counter
[ 0.146430] udc_init,0
[ 0.146587] NET: Registered protocol family 2
[ 0.147767] TCP established hash table entries: 16 (order: -6, 64 bytes)
[ 0.147782] TCP bind hash table entries: 16 (order: -6, 64 bytes)
[ 0.147791] TCP: Hash tables configured (established 16 bind 16)
[ 0.147851] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.147872] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.148021] NET: Registered protocol family 1
[ 0.150588] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.164411] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.164809] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.167718] NET: Registered protocol family 38
[ 0.167766] io scheduler noop registered
[ 0.167774] io scheduler deadline registered
[ 0.168030] io scheduler cfq registered (default)
[ 0.168807] [DISP]disp_module_init
[ 0.195631] [DISP] Fb_copy_boot_fb,line:1503:
[ 0.195644] no boot_fb0
[ 0.196081] rotation hw function is configed to zero degree
[ 0.198833] [DISP] disp_sys_pwm_config,line:618:
[ 0.198845] disp_sys_pwm_Config, handle is NULL!
[ 0.198854] [DISP] disp_sys_pwm_set_polarity,line:636:
[ 0.198859] disp_sys_pwm_Set_Polarity, handle is NULL!
[ 0.200064] [DISP]disp_module_init finish
[ 0.201917] uart uart0: get regulator failed
[ 0.201944] uart0 supply uart not found, using dummy regulator
[ 0.202120] uart uart0: uart0 error to get fifo size property
[ 0.202174] uart0: ttyS0 at MMIO 0x5000000 (irq = 294, base_baud = 1500000) is a SUNXI
[ 0.202200] sw_console_setup()1830 - console setup baud 115200 parity n bits 8, flow n
[ 0.328484] [ST7789V LCD INFO] LINE:0208-->LCD_panel_init:
[ 0.328492] [ST7789V LCD INFO] LINE:0225-->lcd_panel_st7789v_init:
[ 0.854127] [DISP] disp_lcd_pwm_enable,line:959:
[ 0.854128] pwm device hdl is NULL
[ 0.854139] [DISP] disp_device_attached_and_enable,line:221:
[ 0.854140] attached ok, mgr0<-->dev0
[ 0.854149] [DISP] disp_device_attached_and_enable,line:224:
[ 0.854150] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 1.158414] console [ttyS0] enabled
[ 1.163030] uart uart1: get regulator failed
[ 1.168034] uart1 supply uart not found, using dummy regulator
[ 1.174817] uart uart1: uart1 error to get fifo size property
[ 1.181390] uart1: ttyS1 at MMIO 0x5000400 (irq = 295, base_baud = 1500000) is a SUNXI
[ 1.191337] misc dump reg init
[ 1.196935] libphy: Fixed MDIO Bus: probed
[ 1.202547] sun8iw19p1-pinctrl pio: expect_func as:gmac0, but muxsel(5) is func:ephy
[ 1.211624] sun8iw19p1-pinctrl pio: pin PD1 already requested by soc@03000000:lcd0@01c0c000; cannot claim for 5020000.eth
[ 1.224163] sun8iw19p1-pinctrl pio: pin-97 (5020000.eth) status -22
[ 1.231275] sun8iw19p1-pinctrl pio: could not request pin 97 (PD1) from group PD1 on device pio
[ 1.241215] sunxi-gmac 5020000.eth: Error applying setting, reverse things back
[ 1.249492] sunxi-gmac: probe of 5020000.eth failed with error -22
[ 1.256684] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.264421] get drv_vbus is fail, 84
[ 1.268503] get ehci0-controller, regulator_io is no nocare
[ 1.274802] get ehci0-controller wakeup-source is fail.
[ 1.280870] sunxi ehci0-controller don't init wakeup source
[ 1.287168] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04d7658, 0x:c48dd000, irq_no:12c
[ 1.299437] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.309697] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 1.319650] sunxi-ehci 5101000.ehci0-controller: irq 300, io mem 0xc3661800
[ 1.357235] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 1.366005] hub 1-0:1.0: USB hub found
[ 1.370470] hub 1-0:1.0: 1 port detected
[ 1.375179] [ehci0-controller]: sunxi_usb_disable_ehci
[ 1.381046] [sunxi-ehci0]: remove, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04d7658
[ 1.390888] sunxi-ehci 5101000.ehci0-controller: remove, state 1
[ 1.397732] usb usb1: USB disconnect, device number 1
[ 1.404596] sunxi-ehci 5101000.ehci0-controller: USB bus 1 deregistered
[ 1.412758] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.420170] get drv_vbus is fail, 84
[ 1.424194] get ohci0-controller, regulator_io is no nocare
[ 1.430564] get ohci0-controller wakeup-source is fail.
[ 1.436601] sunxi ohci0-controller don't init wakeup source
[ 1.443070] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04d6e08
[ 1.452875] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.462739] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assigned bus number 1
[ 1.472518] sunxi-ohci 5101000.ohci0-controller: irq 301, io mem 0xc3661c00
[ 1.552145] hub 1-0:1.0: USB hub found
[ 1.556586] hub 1-0:1.0: 1 port detected
[ 1.561341] [ohci0-controller]: sunxi_usb_disable_ohci
[ 1.567123] [sunxi-ohci0]: remove, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04d6e08
[ 1.576985] sunxi-ohci 5101000.ohci0-controller: remove, state 1
[ 1.583825] usb usb1: USB disconnect, device number 1
[ 1.590219] sunxi-ohci 5101000.ohci0-controller: USB bus 1 deregistered
[ 1.598509] usbcore: registered new interface driver uas
[ 1.604830] usbcore: registered new interface driver usb-storage
[ 1.611818] usbcore: registered new interface driver ums-alauda
[ 1.618785] usbcore: registered new interface driver ums-cypress
[ 1.625773] usbcore: registered new interface driver ums-datafab
[ 1.632716] usbcore: registered new interface driver ums_eneub6250
[ 1.639881] usbcore: registered new interface driver ums-freecom
[ 1.646873] usbcore: registered new interface driver ums-isd200
[ 1.653756] usbcore: registered new interface driver ums-jumpshot
[ 1.660903] usbcore: registered new interface driver ums-karma
[ 1.667754] usbcore: registered new interface driver ums-onetouch
[ 1.674856] usbcore: registered new interface driver ums-realtek
[ 1.681805] usbcore: registered new interface driver ums-sddr09
[ 1.688720] usbcore: registered new interface driver ums-sddr55
[ 1.695598] usbcore: registered new interface driver ums-usbat
[ 1.702350] usb_serial_number:20080411
[ 1.706907] sunxi_gpadc_init,1831, success
[ 1.712230] sunxi_gpadc_setup: get channel scan data failed
[ 1.718920] input: sunxi-gpadc0 as /devices/virtual/input/input0
[ 1.726961] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.734124] sunxi-rtc rtc: RTC enabled
[ 1.738867] i2c /dev entries driver
[ 1.743456] sunxi cedar version 0.1
[ 1.747735] VE: install start!!!
[ 1.747735]
[ 1.753203] cedar_ve: cedar-ve the get irq is 291
[ 1.758696] VE: line 1811 set the sram data
[ 1.758696]
[ 1.765516] VE: ve_debug_proc_info:c04d98d0, data:c368c000, lock:c04d9958
[ 1.765516]
[ 1.775090] VE: install end!!!
[ 1.775090]
[ 1.780603] google_vp9: sunxi google vp9 version 0.1
[ 1.787308] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.798117] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
[ 1.806959] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[ 1.812625] sunxi-mmc sdc0: No vmmc regulator found
[ 1.818204] sunxi-mmc sdc0: No vqmmc regulator found
[ 1.823797] sunxi-mmc sdc0: No vdmmc regulator found
[ 1.829408] sunxi-mmc sdc0: No vd33sw regulator found
[ 1.835099] sunxi-mmc sdc0: No vd18sw regulator found
[ 1.840845] sunxi-mmc sdc0: No vq33sw regulator found
[ 1.846540] sunxi-mmc sdc0: No vq18sw regulator found
[ 1.852261] sunxi-mmc sdc0: Cann't get uart0 pinstate,check if needed
[ 1.859546] sunxi-mmc sdc0: Cann't get sleep pinstate,check if needed
[ 1.867322] sunxi-mmc sdc0: set host busy
[ 1.871921] mmc:failed to get gpios
[ 1.875860] sunxi-mmc sdc0: min-frequency:100000
[ 1.881347] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.891817] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 1.927235] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.967238] sunxi-mmc sdc0: detmode:alway in(non removable)
[ 1.967261] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.975632] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.998638] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.009658] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
[ 2.009791] sunxi-mmc sdc1: No vmmc regulator found
[ 2.009797] sunxi-mmc sdc1: No vqmmc regulator found
[ 2.009801] sunxi-mmc sdc1: No vdmmc regulator found
[ 2.009805] sunxi-mmc sdc1: No vd33sw regulator found
[ 2.009809] sunxi-mmc sdc1: No vd18sw regulator found
[ 2.009813] sunxi-mmc sdc1: No vq33sw regulator found
[ 2.009818] sunxi-mmc sdc1: No vq18sw regulator found
[ 2.009833] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
[ 2.010288] sunxi-mmc sdc1: set host busy
[ 2.010345] mmc:failed to get gpios
[ 2.010602] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.010633] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 2.041981] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.070988] sunxi-mmc sdc1: detmode:manually by software
[ 2.115968] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.129782] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[ 2.136604] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[ 2.142706] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.154080] usbcore: registered new interface driver usbhid
[ 2.154083] usbhid: USB HID core driver
[ 2.154445] mostcore: init()
[ 2.155741] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.155976] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.156049] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.156115] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.156183] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.156197] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.156260] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.156281] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.156347] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.156359] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.156421] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.156434] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162767] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162856] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162881] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162889] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162911] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162918] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162937] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162944] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162963] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162969] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.162989] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.162995] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163013] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163020] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163040] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163047] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163065] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163072] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163092] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163098] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163116] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163124] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163142] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163149] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163167] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163174] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163192] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163199] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163217] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163224] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163243] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163250] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163268] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163275] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163293] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163300] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163318] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163325] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163339] ac108 2-003b: ref_cfg.ref_channel:0x3, set ref_pga_gain:16
[ 2.163356] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163364] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163382] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163389] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163408] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163415] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163433] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163440] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163458] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163465] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163483] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163490] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163508] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163515] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.163533] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.163540] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.227481] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.227490] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.227513] sunxi_i2c_drv_core_process()1009 - [i2c2] Timeout when sending 9th SCL clk
[ 2.227520] i2c_sunxi_drv_complete()1183 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.227561] ac108 2-003b: i2c probe succeed.
[ 2.228150] --->sunxi_daudio_dev_probe<--- strat.
[ 2.228277] sunxi-daudio daudio0: regulator missing or invalid
[ 2.228396] --->sunxi_daudio_dev_probe<--- end.
[ 2.228941] digital_vol:0, lineout_vol:31, main_gain:23, pa_msleep:160, pa_level:1
[ 2.228950] adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:1, dachpf:0
[ 2.229008] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[ 2.229494] [sunxi_card_init] card init finished.
[ 2.229889] sunxi-codec-machine sndcodec: sun8iw19codec <-> codec mapping ok
[ 2.241204] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.243295] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.243409] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.243545] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.243598] mmc0: new high speed SDHC card at address 0001
[ 2.247542] mmcblk0: mmc0:0001 ASTC 7.50 GiB
[ 2.251277] mmcblk0: p1 p2 p3 p4 p5
[ 2.394786] random: fast init done
[ 2.395679] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
[ 2.397297] NET: Registered protocol family 10
[ 2.399021] NET: Registered protocol family 17
[ 2.399069] NET: Registered protocol family 15
[ 2.399727] Registering SWP/SWPB emulation handler
[ 3.075479] get det_vbus is fail, 84
[ 3.080599] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.092472] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
[ 3.098417] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.104319] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.110228] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.116131] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.122034] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.128039] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.134041] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.140042] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.140061] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.146109] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
[ 3.146140] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.174166] get id is fail, 84
[ 3.178422] sunxi-rtc rtc: setting system clock to 1970-01-01 00:26:26 UTC (1586)
[ 3.188160] ALSA device list:
[ 3.191504] #0: sun8iw19-codec
[ 3.197162] EXT4-fs (mmcblk0p3): couldn't mount as ext3 due to feature incompatibilities
[ 3.208004] EXT4-fs (mmcblk0p3): couldn't mount as ext2 due to feature incompatibilities
[ 3.222144] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[ 3.230465] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[ 3.253459] EXT4-fs warning (device mmcblk0p3): ext4_clear_journal_err:4767: Filesystem error recorded from previous mount: IO failure
[ 3.267132] EXT4-fs warning (device mmcblk0p3): ext4_clear_journal_err:4768: Marking fs in need of filesystem check.
[ 3.295223] EXT4-fs (mmcblk0p3): recovery complete
[ 3.304969] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.314224] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 3.322179] Freeing unused kernel memory: 136K
[ 3.327175] This architecture does not have kernel memory protection.
[ 3.507629] EXT4-fs (mmcblk0p3): warning: mounting fs with errors, running e2fsck is recommended
[ 3.522393] EXT4-fs error (device mmcblk0p3): ext4_has_uninit_itable:3049: comm mount: Inode table for bg 0 marked as needing zeroing
[ 3.540173] Aborting journal on device mmcblk0p3-8.
[ 3.549859] EXT4-fs (mmcblk0p3): Remounting filesystem read-only
[ 3.556641] EXT4-fs (mmcblk0p3): re-mounted. Opts: data=ordered
[ 3.568989] EXT4-fs error (device mmcblk0p3): ext4_journal_check_start:56: Detected aborted journal
[ 3.579247] EXT4-fs (mmcblk0p3): Remounting filesystem read-only
can't run '/bin/mkdir': Read-only file system
mount: mounting devpts on /dev/pts failed: No such file or directory
------run rc.preboot file-----
[ 3.841625] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.860330] Adding 81916k swap on /dev/mmcblk0p4. Priority:-1 extents:1 across:81916k SS
------run rc.modules file-----
------run rc.final file-----
Load mpp modules
[ 4.038267] [sensor_power_err]fetch sensor0_phase from device_tree failed
[ 4.097663] [VIN_ERR]registering sp2305_mipi, No such device!
Starting network...
[ 4.396332] get wifi_sdc_id failed
[ 4.526445] get wifi_sdc_id failed
insmod: can't insert '/lib/modules/4.9.118/8189fs.ko': Operation not permitted
i离线
