楼主 # 2023-01-03 18:33:57
wisdom-xubaoguo
全志T3主线代码下LVDS设备树怎样配置
目前使用的全志T3,用的主线代码linux5.15版本,调试LVDS液晶驱动,设备树用的sun8i-r40-bananapi-m2-ultra.dts、sun8i-r40.dtsi;请问一下在设备树下应该怎样配置?对下面这部分不太了解:
        tcon_top: tcon-top@1c70000 {
            compatible = "allwinner,sun8i-r40-tcon-top";
            reg = <0x01c70000 0x1000>;
            clocks = <&ccu CLK_BUS_TCON_TOP>,
                 <&ccu CLK_TCON_TV0>,
                 <&ccu CLK_TVE0>,
                 <&ccu CLK_TCON_TV1>,
                 <&ccu CLK_TVE1>,
                 <&ccu CLK_DSI_DPHY>;
            clock-names = "bus",
                      "tcon-tv0",
                      "tve0",
                      "tcon-tv1",
                      "tve1",
                      "dsi";
            clock-output-names = "tcon-top-tv0",
                         "tcon-top-tv1",
                         "tcon-top-dsi";
            resets = <&ccu RST_BUS_TCON_TOP>;
            #clock-cells = <1>;
            ports {
                #address-cells = <1>;
                #size-cells = <0>;
                tcon_top_mixer0_in: port@0 {
                    reg = <0>;
                    tcon_top_mixer0_in_mixer0: endpoint {
                        remote-endpoint = <&mixer0_out_tcon_top>;
                tcon_top_mixer0_out: port@1 {
                    #size-cells = <0>;
                    reg = <1>;
                    tcon_top_mixer0_out_tcon_lcd0: endpoint@0 {
                        reg = <0>;
                    tcon_top_mixer0_out_tcon_lcd1: endpoint@1 {
                        reg = <1>;
                    tcon_top_mixer0_out_tcon_tv0: endpoint@2 {
                        reg = <2>;
                        remote-endpoint = <&tcon_tv0_in_tcon_top_mixer0>;
                    tcon_top_mixer0_out_tcon_tv1: endpoint@3 {
                        reg = <3>;
                        remote-endpoint = <&tcon_tv1_in_tcon_top_mixer0>;
                tcon_top_mixer1_in: port@2 {
                    #size-cells = <0>;
                    reg = <2>;
                    tcon_top_mixer1_in_mixer1: endpoint@1 {
                        reg = <1>;
                        remote-endpoint = <&mixer1_out_tcon_top>;
                tcon_top_mixer1_out: port@3 {
                    #size-cells = <0>;
                    reg = <3>;
                    tcon_top_mixer1_out_tcon_lcd0: endpoint@0 {
                        reg = <0>;
                    tcon_top_mixer1_out_tcon_lcd1: endpoint@1 {
                        reg = <1>;
                    tcon_top_mixer1_out_tcon_tv0: endpoint@2 {
                        reg = <2>;
                        remote-endpoint = <&tcon_tv0_in_tcon_top_mixer1>;
                    tcon_top_mixer1_out_tcon_tv1: endpoint@3 {
                        reg = <3>;
                        remote-endpoint = <&tcon_tv1_in_tcon_top_mixer1>;
                tcon_top_hdmi_in: port@4 {
                    #size-cells = <0>;
                    reg = <4>;
                    tcon_top_hdmi_in_tcon_tv0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&tcon_tv0_out_tcon_top>;
                    tcon_top_hdmi_in_tcon_tv1: endpoint@1 {
                        reg = <1>;
                        remote-endpoint = <&tcon_tv1_out_tcon_top>;
                tcon_top_hdmi_out: port@5 {
                    reg = <5>;
                    tcon_top_hdmi_out_hdmi: endpoint {
                        remote-endpoint = <&hdmi_in_tcon_top>;
        tcon_tv0: lcd-controller@1c73000 {
            compatible = "allwinner,sun8i-r40-tcon-tv";
            reg = <0x01c73000 0x1000>;
            interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
            clocks = <&ccu CLK_BUS_TCON_TV0>, <&tcon_top CLK_TCON_TOP_TV0>;
            clock-names = "ahb", "tcon-ch1";
            resets = <&ccu RST_BUS_TCON_TV0>;
            reset-names = "lcd";
            status = "disabled";
            ports {
                #size-cells = <0>;
                tcon_tv0_in: port@0 {
                    #size-cells = <0>;
                    reg = <0>;
                    tcon_tv0_in_tcon_top_mixer0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&tcon_top_mixer0_out_tcon_tv0>;
                    tcon_tv0_in_tcon_top_mixer1: endpoint@1 {
                        reg = <1>;
                        remote-endpoint = <&tcon_top_mixer1_out_tcon_tv0>;
                tcon_tv0_out: port@1 {
                    #size-cells = <0>;
                    reg = <1>;
                    tcon_tv0_out_tcon_top: endpoint@1 {
                        reg = <1>;
                        remote-endpoint = <&tcon_top_hdmi_in_tcon_tv0>;
官方驱动linux-3.10中,设备树配置如下:
        disp: disp@01000000 {
            compatible = "allwinner,sun50i-disp";
            reg = <0x0 0x01000000 0x0 0x00300000>,/*de*/
                <0x0 0x01c70000 0x0 0xfff>,/*tcon top*/
                <0x0 0x01c71000 0x0 0xfff>,/*tcon0*/
                <0x0 0x01c72000 0x0 0xfff>,/*tcon1*/
                <0x0 0x01c73000 0x0 0xfff>,/*tcon2*/
                <0x0 0x01c74000 0x0 0xfff>,/*tcon3*/
                <0x0 0x01ca0000 0x0 0x10fc>;/*dsi*/
            interrupts = <GIC_SPI 44 0x0104>, <GIC_SPI 45 0x0104>,
                <GIC_SPI 51 0x0104>, <GIC_SPI 52 0x0104>,
                <GIC_SPI 57 0x0104>;/* for dsi */
            clocks = <&clk_de>,<&clk_tcon_top>,
                        <&clk_tcon0>,<&clk_tcon1>,
                        <&clk_tcon_tv0>,<&clk_tcon_tv1>,<&clk_lvds>,<&clk_mipidsi>;
            boot_disp = <0>;
            fb_base = <0>;
