楼主 #1 2018-04-06 11:08:03
已发帖子: 9,366
【github项目】全志A20平台使用ffmpeg把CVBS(TV)输入采集到mpg文件.
项目地址: https://github.com/meantone/sunxi-tvin
README:
These are the TV-in drivers for the Allwinner A20.
* sun7i_tvd-linux-3.3: This is the driver as found in Linux 3.3 for Cubieboard
(https://github.com/cubieboard2/linux-sunxi/tree/sunxi-3.3-cb2)
* sun7i_tvd-lichee-android-linux3.3: The working driver distributed in Android 4.2 for MarsBoard
(http://www.haoyuelectronics.com/service/A10-A20/A20-android-source-code/)
* sun7i_tvd-linux-3.4-working: Barebones porting to Linux 3.4
The Cubieboard and Android versions have some slight differences in the registers initialized and
in clock initialization code. My porting is pretty rough but can capture images:
* I "added" some missing #defines form missing files (this should be done in a better way)
* I forced the video field to be returned V4L2_FIELD_NONE as the docs specify
* I fixed the returned video dimensions (so ffmpeg is happy for example)
To have it working add the following lines to Kconfig
source "drivers/media/video/sun7i_tvd/Kconfig"
and Makefile
obj-$(CONFIG_SUN7I_TVD) += sun7i_tvd/
in the /drivers/media/video directory
To use the TV input:
* Get https://github.com/ebutera/sunxi-tvin, compile it and run it as sudo
  If you have a HDMI display it should mirror the input on the display (I
  do not have one so I could not see the result). This program initializes
  all the private structures for the v4l2 driver, which seem not to be
  cleared on exit.
* After you ran this program you should be able to capture from "normal"
  programs also
Test with ffmpeg
ffmpeg -f v4l2 -s 720x576 -pix_fmt nv12 -r 24 -t 10 -i /dev/video1 m.mpg
#2 2018-04-13 14:57:31
KingJin
已发帖子: 106
Re: 【github项目】全志A20平台使用ffmpeg把CVBS(TV)输入采集到mpg文件.
录像机?
