楼主 # 2023-03-02 10:04:55
744219909
已发帖子: 31
关于荔枝派nano中将I2C添加到设备树
在按照《linux驱动入门》书中添加I2C到设备树发现nano里并没有
sys/devices/platform/soc/1c27000.i2c/i2c-0/0-0050/
I2C-0这一目录,本书甚至给出代码
&i2c0 {
  clock-frequency = <100000>; //时钟设置为 100KHz
  at24c02: at24c02@50 {
  compatible = "test,at24c0x";
  reg = <0x50>;
这样一般笔带,随后我只能开船畅游百度。
第一天无果
第二天我试图在原有的内核中找线索,我在arch/arm/boot/dts/sun4i-a10.dtsi中找到这么一串代码
i2c0: i2c@1c2ac00 {
			compatible = "allwinner,sun4i-a10-i2c";
			reg = <0x01c2ac00 0x400>;
			interrupts = <7>;
			clocks = <&ccu CLK_APB1_I2C0>;
			pinctrl-names = "default";
			pinctrl-0 = <&i2c0_pins>;
			status = "disabled";
			#address-cells = <1>;
			#size-cells = <0>;
将其拷贝粘贴debug,神奇的一幕发现了
ls sys/devices/platform/soc/1c27000.i2c/i2c-0/0-0050
已经生成了i2c-0
/ # insmod /home/zr/i2c.ko
[  144.167822] i2c: loading out-of-tree module taints kernel.
/ # ls sys/devices/platform/soc/1c27000.i2c/i2c-0/0-0050/of_node/
compatible  name        reg
at24c02     modalias    of_node/    subsystem/
driver/     name        power/      uevent
究其原因是因为compatible属性没有适配,将compatible填写成sun4i-a10-i2c就可以了。
这是我的设备树
dtsi
i2c0: i2c@1c27000 {
				reg = <0x01c27000 0x400>;
				interrupts = <7>;
				clocks = <&ccu CLK_BUS_I2C0>;
				resets = <&ccu RST_BUS_I2C0>;
				#size-cells = <0>;
dts
&i2c0 {
			at24c02@50 {
				reg = <0x50>;
下面继续调试i2c
最近编辑记录 744219909 (2023-03-02 10:08:19)
