楼主 # 2023-03-14 16:31:43
dml1048147924
所在地: 江苏无锡
已发帖子: 119
kernel panic - not syncing: VFS: Unable to mount root fs on unknown-bl
openwrt 启动失败
0A
[    0.523542] printk: console [ttyS0] enabled
[    0.540018] printk: bootconsole [early0] disabled
[    0.559298] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.578312] spi-mt7621 10000b00.spi: sys_freq: 193333333
[    0.605792] spi-nor spi0.0: w25q128 (16384 Kbytes)
[    0.615337] mtd: spi0.0: partitioning exceeds flash size, truncating
[    0.627921] mtd: spi0.0: skipping zero sized partition
[    0.638093] mtd: spi0.0: partitioning exceeds flash size, truncating
[    0.650672] mtd: spi0.0: skipping zero sized partition
[    0.660847] 4 cmdlinepart partitions found on MTD device spi0.0
[    0.672569] Creating 4 MTD partitions on "spi0.0":
[    0.682081] 0x000000000000-0x000000030000 : "u-boot"
[    0.692905] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.704401] 0x000000040000-0x000000050000 : "art"
[    0.714768] 0x000000050000-0x000001000000 : "firmware"
[    0.727069] libphy: Fixed MDIO Bus: probed
[    0.748500] rt3050-esw 10110000.esw: link changed 0x00
[    0.759933] mtk_soc_eth 10100000.ethernet: generated random MAC address 16:6c:2c:86:f4:08
[    0.776932] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[    0.793539] PPP generic driver version 2.4.2
[    0.802276] usbcore: registered new interface driver qmi_wwan
[    0.813768] usbcore: registered new interface driver cdc_wdm
[    0.825209] usbcore: registered new interface driver usbserial_generic
[    0.838241] usbserial: USB Serial support registered for generic
[    0.850229] usbcore: registered new interface driver option
[    0.861345] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.903095] NET: Registered protocol family 10
[    0.915133] Segment Routing with IPv6
[    0.922609] NET: Registered protocol family 17
[    0.931475] 8021q: 802.1Q VLAN Support v1.8
[    0.942915] Too few erase blocks (1)
[    0.950085] List of all partitions:
[    0.957007] 1f00             192 mtdblock0
[    0.957011]  (driver?)
[    0.969961] 1f01              64 mtdblock1
[    0.969963]  (driver?)
[    0.982909] 1f02              64 mtdblock2
[    0.982912]  (driver?)
[    0.995862] 1f03           16064 mtdblock3
[    0.995864]  (driver?)
[    1.008803] No filesystem could mount root, tried:
[    1.008805]  squashfs
[    1.018461]  jffs2
[    1.022954]
[    1.029870] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
[    1.046402] Rebooting in 1 seconds..
