楼主 # 2023-05-09 15:55:10
mysteryli
已发帖子: 511
求助,触摸事件上报导致内核崩溃
核心代码如下,内核报错内容晚点贴上,这么写看起来应该没啥问题吧
	input = devm_input_allocate_device(dev);
	if (!input)
		return -ENOMEM;
	ts_data->input_dev = input;
	input->name = client->name;
	input->id.bustype = BUS_I2C;
	set_bit(EV_ABS, input->evbit);
	set_bit(EV_KEY, input->evbit);
	set_bit(BTN_TOUCH, input->keybit);
	input_set_abs_params(ts_data->input_dev, ABS_X,
			     0, 240, 0, 0);
	input_set_abs_params(ts_data->input_dev, ABS_Y,
			     0, 280, 0, 0);
	input_set_abs_params(ts_data->input_dev, ABS_PRESSURE,
			     0, 1, 0, 0);
	err = input_register_device(input);
	if (err) {
		dev_err(dev, "failed to register input device: %d\n", err);
		return err;
static void cst3xx_touch_report1(struct work_struct *work)
	u8 buf[5];
	struct delayed_work *dw =
		container_of(work, struct delayed_work, work);
	struct hynitron_ts_data *ts_data =
		container_of(dw, struct hynitron_ts_data, poll_work);
	if( touch_flag ){
		touch_flag = 0;
		// int err = cst3xx_i2c_read_register(ts_data->client, 0x02,
		// 	buf, 5);
		// if ( err ){
		// 	dev_err(&ts_data->client->dev, "cst3xx touch read failure %d\n",err);
		// printk("touch data is 0x%2x 0x%2x 0x%2x 0x%2x\r\n",buf[1],buf[2],buf[3],buf[4]);
		cst3xx_touch_report(ts_data->client);
	schedule_delayed_work(&ts_data->poll_work,
			msecs_to_jiffies(80));
	INIT_DELAYED_WORK(&ts_data->poll_work, cst3xx_touch_report1);
	//INIT_DELAYED_WORK(&poll_work, hyn_interrupt_handler);
	input_report_abs(ts_data->input_dev,ABS_X, 10);
	input_report_abs(ts_data->input_dev,ABS_Y, 10);
	input_report_abs(ts_data->input_dev,ABS_PRESSURE, 1);
	input_report_key(ts_data->input_dev,BTN_TOUCH,1);
	// //input_mt_sync_frame(ts_data->input_dev);
	input_sync(ts_data->input_dev);
	input_report_abs(ts_data->input_dev,ABS_PRESSURE, 0);
	input_report_key(ts_data->input_dev,BTN_TOUCH,0);
楼主 #1 2023-05-09 21:42:40
mysteryli
已发帖子: 511
Re: 求助,触摸事件上报导致内核崩溃
内核报错
root@TinaLinux:/# [  837.170196] hyn_probe twi3
[  837.173363] hyn_probe test 8 98
[  837.257179] i2c_lock_bus
[  837.260569] i2c_unlock_bus
[  837.263799] hyn Chip id b5 ProjID  0 FW Version  1 FactoryID  4
[  837.270840] input: cst340 as /devices/platform/soc/twi3/i2c-3/3-0015/input/in        put1
[  837.279573] hyn_probe test 11 98
[  837.365597] i2c_lock_bus
[  837.369022] i2c_unlock_bus
[  837.372251] touch data is x 0 y 0
[  837.376105] ------------[ cut here ]------------
[  837.381290] WARNING: CPU: 0 PID: 366 at kernel/workqueue.c:1534 __queue_delay        ed_work+0x80/0x14c
[  837.391025] Modules linked in: hynitron_cstxxx vin_v4l2 gc2053_mipi vin_io vi        deobuf2_v4l2 videobuf2_dma_contig videobuf2_memops videobuf2_core xradio_wlan xr        adio_core xradio_mac
[  837.408791] CPU: 0 PID: 366 Comm: kworker/0:1 Not tainted 4.9.191 #99
[  837.415993] Hardware name: sun8iw21
[  837.419905] Workqueue: events cst3xx_touch_report1 [hynitron_cstxxx]
[  837.427037] [<c010d5a0>] (unwind_backtrace) from [<c010a694>] (show_stack+0x1        0/0x14)
[  837.435716] [<c010a694>] (show_stack) from [<c0118904>] (__warn+0xc8/0xf8)
[  837.443415] [<c0118904>] (__warn) from [<c01189d8>] (warn_slowpath_null+0x1c/        0x24)
[  837.451894] [<c01189d8>] (warn_slowpath_null) from [<c012cd28>] (__queue_dela        yed_work+0x80/0x14c)
[  837.461827] [<c012cd28>] (__queue_delayed_work) from [<c012ce2c>] (queue_dela        yed_work_on+0x38/0x44)
[  837.471959] [<c012ce2c>] (queue_delayed_work_on) from [<c012cb2c>] (process_o        ne_work+0x1dc/0x318)
[  837.481890] [<c012cb2c>] (process_one_work) from [<c012d81c>] (worker_thread+        0x318/0x464)
[  837.491050] [<c012d81c>] (worker_thread) from [<c0131d64>] (kthread+0xcc/0xe4        )
[  837.499134] [<c0131d64>] (kthread) from [<c0106e08>] (ret_from_fork+0x14/0x2c        )
[  837.507218] ---[ end trace 2ca1c3d30aa0844a ]---
[  837.512379] ------------[ cut here ]------------
[  837.517545] WARNING: CPU: 0 PID: 366 at kernel/workqueue.c:1536 __queue_delay        ed_work+0xe4/0x14c
[  837.527278] Modules linked in: hynitron_cstxxx vin_v4l2 gc2053_mipi vin_io vi        deobuf2_v4l2 videobuf2_dma_contig videobuf2_memops videobuf2_core xradio_wlan xr        adio_core xradio_mac
[  837.545036] CPU: 0 PID: 366 Comm: kworker/0:1 Tainted: G        W       4.9.1        91 #99
[  837.553597] Hardware name: sun8iw21
[  837.557501] Workqueue: events cst3xx_touch_report1 [hynitron_cstxxx]
[  837.564619] [<c010d5a0>] (unwind_backtrace) from [<c010a694>] (show_stack+0x1        0/0x14)
[  837.573293] [<c010a694>] (show_stack) from [<c0118904>] (__warn+0xc8/0xf8)
[  837.580989] [<c0118904>] (__warn) from [<c01189d8>] (warn_slowpath_null+0x1c/        0x24)
[  837.589468] [<c01189d8>] (warn_slowpath_null) from [<c012cd8c>] (__queue_dela        yed_work+0xe4/0x14c)
[  837.599400] [<c012cd8c>] (__queue_delayed_work) from [<c012ce2c>] (queue_dela        yed_work_on+0x38/0x44)
[  837.609532] [<c012ce2c>] (queue_delayed_work_on) from [<c012cb2c>] (process_o        ne_work+0x1dc/0x318)
[  837.619463] [<c012cb2c>] (process_one_work) from [<c012d81c>] (worker_thread+        0x318/0x464)
[  837.628621] [<c012d81c>] (worker_thread) from [<c0131d64>] (kthread+0xcc/0xe4        )
[  837.636704] [<c0131d64>] (kthread) from [<c0106e08>] (ret_from_fork+0x14/0x2c        )
[  837.644781] ---[ end trace 2ca1c3d30aa0844b ]---
[  837.649955] ------------[ cut here ]------------
[  837.655119] kernel BUG at kernel/time/timer.c:973!
[  837.660474] Internal error: Oops - BUG: 0 [#1] PREEMPT ARM
[  837.666610] Modules linked in: hynitron_cstxxx vin_v4l2 gc2053_mipi vin_io vi        deobuf2_v4l2 videobuf2_dma_contig videobuf2_memops videobuf2_core xradio_wlan xr        adio_core xradio_mac
[  837.684366] CPU: 0 PID: 366 Comm: kworker/0:1 Tainted: G        W       4.9.1        91 #99
[  837.692927] Hardware name: sun8iw21
[  837.696832] Workqueue: events cst3xx_touch_report1 [hynitron_cstxxx]
[  837.703940] task: c36d2f00 task.stack: c3686000
[  837.709008] PC is at mod_timer+0xc/0x26c
[  837.713393] LR is at queue_delayed_work_on+0x38/0x44
[  837.718949] pc : [<c01556e0>]    lr : [<c012ce2c>]    psr: 60000093
[  837.718949] sp : c3687f08  ip : 00000000  fp : c373b318
[  837.731789] r10: c0a12980  r9 : 00000000  r8 : c0a0daf4
[  837.737635] r7 : c3b3b100  r6 : c205b181  r5 : 60000093  r4 : 60000013
[  837.744938] r3 : 00000000  r2 : 00000000  r1 : 0000d1f1  r0 : c205bd10
[  837.752244] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment non        e
[  837.760321] Control: 10c5387d  Table: 42244059  DAC: 00000051
[  837.766746] Process kworker/0:1 (pid: 366, stack limit = 0xc3686208)
[  837.773852] Stack: (0xc3687f08 to 0xc3688000)
[  837.778727] 7f00:                   c373b300 c205bda8 00000000 c012cb2c c373b        300 c205bda8
[  837.787884] 7f20: c373b300 c0a0daf4 c0a0daf4 c3686000 ffffe000 c0a0db08 c0a12        980 c012d81c
[  837.797040] 7f40: c373b300 40000013 c36d2f00 c3787400 00000000 c373b300 c012d        504 00000000
[  837.806191] 7f60: 00000000 00000000 00000000 c0131d64 c3687f94 00000000 00000        000 c373b300
[  837.815348] 7f80: 00000000 c3687f84 c3687f84 00000000 c3687f90 c3687f90 c3787        400 c3787400
[  837.824503] 7fa0: c0131c98 00000000 00000000 c0106e08 00000000 00000000 00000        000 00000000
[  837.833653] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[  837.842808] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000        000 00000000
[  837.851968] [<c01556e0>] (mod_timer) from [<c3686000>] (0xc3686000)
[  837.858986] Code: c0a11880 e590300c e3530000 1a000000 (e7f001f2)
[  837.865802] ---[ end trace 2ca1c3d30aa0844c ]---
[  837.871282] Unable to handle kernel paging request at virtual address fffffff        0
[  837.879362] pgd = c0004000
[  837.882385] [fffffff0] *pgd=43bfd861, *pte=00000000, *ppte=00000000
[  837.889410] Internal error: Oops: 37 [#2] PREEMPT ARM
[  837.895056] Modules linked in: hynitron_cstxxx vin_v4l2 gc2053_mipi vin_io vi        deobuf2_v4l2 videobuf2_dma_contig videobuf2_memops videobuf2_core xradio_wlan xr        adio_core xradio_mac
[  837.912816] CPU: 0 PID: 366 Comm: kworker/0:1 Tainted: G      D W       4.9.1        91 #99
[  837.921377] Hardware name: sun8iw21
[  837.925281] task: c36d2f00 task.stack: c3686000
[  837.930349] PC is at kthread_data+0x4/0xc
[  837.934834] LR is at wq_worker_sleeping+0x8/0xb4
[  837.939997] pc : [<c01327b0>]    lr : [<c012dc98>]    psr: 00000093
[  837.939997] sp : c3687d98  ip : 00000000  fp : c3687dc4
[  837.952831] r10: 00000000  r9 : c36d30cc  r8 : c36d3158
[  837.958672] r7 : 00000000  r6 : c0a0e4b0  r5 : ffffe000  r4 : c36d2f00
[  837.965967] r3 : 00000000  r2 : 0004a73b  r1 : 00000001  r0 : c36d2f00
[  837.973267] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment non        e
[  837.981345] Control: 10c5387d  Table: 42244059  DAC: 00000051
[  837.987769] Process kworker/0:1 (pid: 366, stack limit = 0xc3686208)
[  837.994874] Stack: (0xc3687d98 to 0xc3688000)
[  837.999746] 7d80:                                                       c36d2        f00 c06575f0
[  838.008898] 7da0: c36d2f00 c01197a4 c36d2f00 c3687bf0 c3444000 c3687dd8 00000        000 c36d30cc
[  838.018049] 7dc0: c3687dcc c0137330 c373b318 c011a098 0000000b 00000001 c3687        dd8 c3687dd8
[  838.027200] 7de0: 0000000b 60000093 c373b318 c010a8b4 c3686208 0000000b e7f00        1f2 c3687eb8
[  838.036351] 7e00: c01556e0 00000000 60000093 c010b0b8 c3686000 c01010a4 00000        006 00000024
[  838.045502] 7e20: 00000004 00000000 00030001 c01556e0 00000000 00000000 00000        000 00000000
[  838.054653] 7e40: c0a4ad56 00000024 00000000 00000000 60000093 c0106e08 00000        000 c3687eac
[  838.063804] 7e60: c0145968 00000000 00000009 c012cd8c 00000600 c0a12980 c373b        318 c0145984
[  838.072956] 7e80: c07b2747 c3687eac 00000000 c01707d4 c07b2747 c3687eac 0aa08        44b 00000000
[  838.082107] 7ea0: c01556e4 00000000 c010b558 00000000 e7100000 c010b0b8 c205b        d10 0000d1f1
[  838.091258] 7ec0: 00000000 00000000 60000013 60000093 c205b181 c3b3b100 c0a0d        af4 00000000
[  838.100409] 7ee0: c0a12980 c373b318 00000000 c3687f08 c012ce2c c01556e0 60000        093 ffffffff
[  838.109560] 7f00: 00000051 00000000 c373b300 c205bda8 00000000 c012cb2c c373b        300 c205bda8
[  838.118712] 7f20: c373b300 c0a0daf4 c0a0daf4 c3686000 ffffe000 c0a0db08 c0a12        980 c012d81c
[  838.127863] 7f40: c373b300 40000013 c36d2f00 c3787400 00000000 c373b300 c012d        504 00000000
[  838.137014] 7f60: 00000000 00000000 00000000 c0131d64 c3687f94 00000000 00000        000 c373b300
[  838.146165] 7f80: 00000000 c3687f84 c3687f84 00000001 c3687f90 c3687f90 c3787        400 c3787400
[  838.155315] 7fa0: c0131c98 00000000 00000000 c0106e08 00000000 00000000 00000        000 00000000
[  838.164465] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[  838.173616] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000        000 00000000
[  838.182775] [<c01327b0>] (kthread_data) from [<c012dc98>] (wq_worker_sleeping        +0x8/0xb4)
[  838.191736] [<c012dc98>] (wq_worker_sleeping) from [<c06575f0>] (__schedule+0        xdc/0x3d0)
[  838.200698] [<c06575f0>] (__schedule) from [<c0137330>] (do_task_dead+0x40/0x        48)
[  838.208980] [<c0137330>] (do_task_dead) from [<c011a098>] (do_exit+0x8d4/0x90        c)
[  838.217166] [<c011a098>] (do_exit) from [<c010a8b4>] (die+0x21c/0x254)
[  838.224474] [<c010a8b4>] (die) from [<c01010a4>] (do_undefinstr+0xa0/0x1f4)
[  838.232260] [<c01010a4>] (do_undefinstr) from [<c010b0b8>] (__und_svc_finish+        0x0/0x48)
[  838.241115] Exception stack(0xc3687eb8 to 0xc3687f00)
[  838.246763] 7ea0:                                                       c205b        d10 0000d1f1
[  838.255908] 7ec0: 00000000 00000000 60000013 60000093 c205b181 c3b3b100 c0a0d        af4 00000000
[  838.265053] 7ee0: c0a12980 c373b318 00000000 c3687f08 c012ce2c c01556e0 60000        093 ffffffff
[  838.274202] [<c010b0b8>] (__und_svc_finish) from [<c01556e0>] (mod_timer+0xc/        0x26c)
[  838.282771] [<c01556e0>] (mod_timer) from [<c3686000>] (0xc3686000)
[  838.289784] Code: eaffffed e3e00025 e8bd8070 e5903224 (e5130010)
[  838.296599] ---[ end trace 2ca1c3d30aa0844d ]---
[  838.301760] Fixing recursive fault but reboot is needed!
[  838.307705] Unable to handle kernel paging request at virtual address fffffff        0
[  838.315781] pgd = c0004000
[  838.318802] [fffffff0] *pgd=43bfd861, *pte=00000000, *ppte=00000000
[  838.325825] Internal error: Oops: 37 [#3] PREEMPT ARM
[  838.331471] Modules linked in: hynitron_cstxxx vin_v4l2 gc2053_mipi vin_io vi        deobuf2_v4l2 videobuf2_dma_contig videobuf2_memops videobuf2_core xradio_wlan xr        adio_core xradio_mac
[  838.349227] CPU: 0 PID: 366 Comm: kworker/0:1 Tainted: G      D W       4.9.1        91 #99
[  838.357788] Hardware name: sun8iw21
[  838.361691] task: c36d2f00 task.stack: c3686000
[  838.366755] PC is at kthread_data+0x4/0xc
[  838.371238] LR is at wq_worker_sleeping+0x8/0xb4
[  838.376401] pc : [<c01327b0>]    lr : [<c012dc98>]    psr: 00000193
[  838.376401] sp : c3687be0  ip : 00000000  fp : c3687c0c
[  838.389242] r10: 00000037  r9 : c07b0695  r8 : c36d3158
[  838.395083] r7 : 00000000  r6 : c0a0e4b0  r5 : c3686000  r4 : c36d2f00
[  838.402383] r3 : 00000000  r2 : 0004a73b  r1 : 00000001  r0 : c36d2f00
[  838.409682] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment non        e
[  838.417760] Control: 10c5387d  Table: 42244059  DAC: 00000051
[  838.424184] Process kworker/0:1 (pid: 366, stack limit = 0xc3686208)
[  838.431289] Stack: (0xc3687be0 to 0xc3688000)
[  838.436163] 7be0: c36d2f00 c06575f0 c07b28eb c3687c14 c3686000 0000000b c3686        000 60000193
[  838.445315] 7c00: bf000000 c07b0695 c3687c1c c0657990 c36d2f00 0000000b c3687        dc4 c01198c4
#2 2023-07-17 14:34:26
资本家大善人
已发帖子: 193
Re: 求助,触摸事件上报导致内核崩溃
开下开关 生成coredump文件
用GDB可以直接分析到出问题的代码行数
最近编辑记录 资本家大善人 (2023-07-17 14:40:27)
#3 2023-07-18 13:23:03
海石生风
已发帖子: 788
Re: 求助,触摸事件上报导致内核崩溃
问题的源头应该是 cst3xx_touch_report1 函数
楼主 #4 2023-08-01 08:11:06
mysteryli
已发帖子: 511
Re: 求助,触摸事件上报导致内核崩溃
是的,发现在中断中上报坐标就会如此,已经改为周期轮询上报了
