楼主 # 2023-06-04 16:44:01
damifan
ubuntu20.04使用LiveSuit下载失败闪退问题 (寻求解决帮助)
ubuntu20.04(ubuntu18.04也进行了测试)LiveSuitV3.06版本进行T113的烧录时,闪退。详情如下
使用SOC 为T113
使用存储为 EMMC
windows烧录正常,可以使用
--------------Init Called------------------
workDir	/home/ubuntu/桌面/LiveSuit(Ubuntu下的烧写工具)/sunxi-livesuite-master/x86-64/LiveSuit
ImgLenHigh	0
ImgLenLow	14280704
Mode	8
hWnd	0
imgFilePath	/home/ubuntu/桌面/tina_t113-nezha_uart1_Qt.img
[TL_MSG]:Mode = 8, ImgLenHigh=0, ImgLenLow = d9e800, imgFilePath = /home/ubuntu/桌面/tina_t113-nezha_uart1_Qt.img
IMAGEWTY
ItemTableSize = 1048576
[TL_MSG]:Tools Open Img
---fun end---
--------------entry-fel2fes Called-----------
felDevName	/dev/aw_efex4
[TL_MSG]:Hi, I'm fel, dev=/dev/aw_efex4
[TL_MSG]:To down and Run fes1-1
[TL_MSG]:fes1 down addr = 0x28000, retAddr =0x28340
[TL_MSG]:tlFelDev.FelRun finish
[TL_MSG]:hasRetLog finish
[TL_MSG]:Tools_Buffer finish
[TL_FEX]:fel UP addr=0x28340, len=136
[TL_MSG]:SYS_PARA_LOG read = 0x4d415244
[TL_MSG]:dram paras[0]: 0x39c
[TL_MSG]:dram paras[1]: 0x3
[TL_MSG]:dram paras[2]: 0x7b7bfb
[TL_MSG]:dram paras[3]: 0x0
[TL_MSG]:dram paras[4]: 0x10d2
[TL_MSG]:dram paras[5]: 0x800000
[TL_MSG]:dram paras[6]: 0x1e14
[TL_MSG]:dram paras[7]: 0x42
[TL_MSG]:dram paras[8]: 0x20
[TL_MSG]:dram paras[9]: 0x0
[TL_MSG]:dram paras[10]: 0x4899d7
[TL_MSG]:dram paras[11]: 0x1c239d0
[TL_MSG]:dram paras[12]: 0xa2071
[TL_MSG]:dram paras[13]: 0xb4787896
[TL_MSG]:dram paras[14]: 0x0
[TL_MSG]:dram paras[15]: 0x48484848
[TL_MSG]:dram paras[16]: 0x48
[TL_MSG]:dram paras[17]: 0x1620121e
[TL_MSG]:dram paras[18]: 0x0
[TL_MSG]:dram paras[19]: 0x0
[TL_MSG]:dram paras[20]: 0x0
[TL_MSG]:dram paras[21]: 0x340000
[TL_MSG]:dram paras[22]: 0x46
[TL_MSG]:dram paras[23]: 0x34006103
[TL_MSG]:dram paras[24]: 0x0
[TL_MSG]:dram paras[25]: 0x0
[TL_MSG]:dram paras[26]: 0x0
[TL_MSG]:dram paras[27]: 0x0
[TL_MSG]:dram paras[28]: 0x0
[TL_MSG]:dram paras[29]: 0x0
[TL_MSG]:dram paras[30]: 0x0
[TL_MSG]:dram paras[31]: 0x0
[TL_MSG]:for tlFelDev.FelUpData finish
[TL_MSG]:To down and Run uboot
[TL_MSG]:u-boot down addr = 0x43000000
[TL_MSG]:workmode = 0x10
[TL_MSG]:dtb down addr = 0x43200000
[TL_MSG]:sysconfig down addr = 0x43300000
---fun end---
Fel Thread Finished!
Dev Plugout The Device Path is: /dev/aw_efex4
Dev Plugin The Device Path is: /dev/aw_efex4
--------------entry fes_thread Called---------
portId	0
fesDevName	/dev/aw_efex4
hubId	0
DeviceId	1
[TL_MSG]:enter FES--/dev/aw_efex4
[TL_MSG]:Verify: media crc = 0
[TL_MSG]:save item to mem :(12345678,1234567890___MBR) realLen(65536)
./buffer.cpp, pBuffer = 0x7fd2d4012084, nLen = 16380, crc32 = 4134314412[TL_MSG]:name = boot-resource, keydata = 0
[TL_MSG]:name = env, keydata = 0
[TL_MSG]:name = env-redund, keydata = 0
[TL_MSG]:name = boot, keydata = 0
[TL_MSG]:name = rootfs, keydata = 0
[TL_MSG]:name = private, keydata = 0
[TL_MSG]:name = rootfs_data, keydata = 0
[TL_MSG]:name = UDISK, keydata = 0
[TL_MSG]:name = , keydata = 0
[TL_MSG]:down mbr success!!!
[TL_MSG]:storge type is 2 (0:nand 1-2:card 3:spinor)
[TL_MSG]:dl file :save item to mem :(12345678,1234567890DLINFO) realLen(16384)
./buffer.cpp, pBuffer = 0x7fd2d461a9b4, nLen = 16380, crc32 = 2550867671[TL_MSG]:------------dlmap dump--------------
[TL_MSG]:crc32     = 0x980b26d7
[TL_MSG]:version   = 0x200
[TL_MSG]:magic     = softw411
[TL_MSG]:part_cnt  = 5
[TL_MSG]:flash size is : 15269888 Sectors
[TL_MSG]:name = boot-resource addrhi=0x0 addrlo = 0x8000  lenhi = 0x0 lenlo = 0x34e  file = BOOT-RESOURCE_FE, en=0,vf=1
[TL_MSG]:sparseFlag:false
[TL_MSG]:need verify:1,VBOOT-RESOURCE_F
[TL_FEX]:8000, 14000
[TL_MSG]:Verify:start = 8000 ,size = 14000 ,pc_crc = e6f75b5c, media crc = e6f75b5c
[TL_MSG]:name = env addrhi=0x0 addrlo = 0x834e  lenhi = 0x0 lenlo = 0x1f8  file = ENV_FEX000000000, en=0,vf=1
    BBCode: 可用 [url] 插入链接: 可用 [img] 贴图: 可用 表情: 可用 上传
[TL_MSG]:need verify:1,VENV_FEX00000000
[TL_FEX]:834e, 20000
[TL_MSG]:Verify:start = 834e ,size = 20000 ,pc_crc = adc89266, media crc = adc89266
[TL_MSG]:name = env-redund addrhi=0x0 addrlo = 0x8546  lenhi = 0x0 lenlo = 0x1f8  file = ENV_FEX000000000, en=0,vf=1
[TL_FEX]:8546, 20000
[TL_MSG]:Verify:start = 8546 ,size = 20000 ,pc_crc = adc89266, media crc = adc89266
[TL_MSG]:name = boot addrhi=0x0 addrlo = 0x873e  lenhi = 0x0 lenlo = 0x2000  file = BOOT_FEX00000000, en=0,vf=1
[TL_MSG]:need verify:1,VBOOT_FEX0000000
[TL_FEX]:873e, 3c2800
[TL_MSG]:Verify:start = 873e ,size = 3c2800 ,pc_crc = 3ebdcad9, media crc = 3ebdcad9
[TL_MSG]:name = rootfs addrhi=0x0 addrlo = 0xa73e  lenhi = 0x0 lenlo = 0xf000  file = ROOTFS_FEX000000, en=0,vf=1
[TL_MSG]:need verify:1,VROOTFS_FEX00000
free(): invalid pointer
./LiveSuit.sh:行 19: 10350 已放弃               (核心已转储) LD_LIBRARY_PATH=${TOP_DIR}/${BIN_DIR}/ ${BIN_DIR}/${APP}
以上为LiveSuit 打印的错误
上图为闪退的结点截图,
闪退后 T113没有刷如成功,刷机前选择的格式化成功了。
在windows下可以正常刷机,运行也没有问题
现在不如到如何排除问题,还望哪位大佬可以指点一二
楼主 #1 2023-06-04 16:49:51
damifan
Re: ubuntu20.04使用LiveSuit下载失败闪退问题 (寻求解决帮助)
下面是  SOC烧录时候输出的log
[2844]fes begin commit:88480af-dirty
[2848]set pll start
[2854]periph0 has been enabled
[2857]set pll end
[2859][pmu]: bus read error
[2861]board init ok
[2863]beign to init dram
[2865]ZQ value = 0x30
[2867]get_pmu_exist() = -1
[2870]ddr_efuse_type: 0xa
[2872]trefi:7.8ms
[2875][AUTO DEBUG] single rank and full DQ!
[2879]ddr_efuse_type: 0xa
[2882]trefi:7.8ms
[2884][AUTO DEBUG] rank 0 row = 13
[2887][AUTO DEBUG] rank 0 bank = 8
[2891][AUTO DEBUG] rank 0 page size = 2 KB
[2895]DRAM BOOT DRIVE INFO: V0.33
[2898]DRAM CLK = 924 MHz
[2900]DRAM Type = 3 (2:DDR2,3:DDR3)
[2903]DRAMC read ODT  off.
[2906]DRAM ODT value: 0x42.
[2909]ddr_efuse_type: 0xa
[2912]DRAM SIZE =128 M
[2914]dram_tpr4:0x0
[2916]PLL_DDR_CTRL_REG:0xf8004c00
[2919]DRAM_CLK_REG:0xc0000000
[2922][TIMING DEBUG] MR2= 0x20
[2926]DRAM simple test OK.
[2928]rtc standby flag is 0x0, super standby flag is 0x0
[2933]init dram ok
U-Boot 2018.07-ge987def5-dirty (May 25 2023 - 18:38:27 +0800) Allwinner Technoly
[05.257]CPU:   Allwinner Family
[05.259]Model: sun8iw20
I2C:   FDT ERROR:fdt_set_all_pin:[twi0]-->FDT_ERR_BADPATH
FDT ERROR:fdt_set_all_pin:[twi1]-->FDT_ERR_BADPATH
ready
[05.281]DRAM:  128 MiB
[05.284]Relocation Offset is: 04eba000
[05.310]secure enable bit: 0
[05.313]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[05.319]gic: normal mode
sunxi flash map init
[05.323]flash init start
[05.326]workmode = 16,storage type = 0
try card 2
set card number 2
get card number 2
[05.333][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[05.340][mmc]: Is not Boot mode!
[05.343][mmc]: SUNXI SDMMC Controller Version:0x50310
[05.354][mmc]: ************Try SD card 2************
[05.359][mmc]: mmc 2 cmd timeout 100 status 100
[05.363][mmc]: smc 2 err, cmd 8,  RTO
[05.367][mmc]: mmc 2 close bus gating and reset
[05.372][mmc]: mmc 2 cmd timeout 100 status 100
[05.376][mmc]: smc 2 err, cmd 55,  RTO
[05.379][mmc]: mmc 2 close bus gating and reset
[05.384][mmc]: ************Try MMC card 2************
[05.408][mmc]: mmc 2 cmd timeout 100 status 100
[05.412][mmc]: smc 2 err, cmd 8,  RTO
[05.415][mmc]: mmc 2 close bus gating and reset
[05.420][mmc]: mmc 2 cmd timeout 100 status 100
[05.424][mmc]: smc 2 err, cmd 55,  RTO
[05.428][mmc]: mmc 2 close bus gating and reset
[05.444][mmc]: gen_tuning_blk_bus8: total blk 10
[05.448][mmc]: gen_tuning_blk_bus4: total blk 6
[05.453][mmc]: Using 4 bit tuning now
[05.457][mmc]: write_tuning_try_freq: write ok
[05.461][mmc]: Pattern compare ok
[05.464][mmc]: Write tuning pattern ok
[05.468][mmc]: ================== HSSDR52_SDR25...
[05.472][mmc]: skip freq 400000
[05.475][mmc]: skip freq 25000000
[05.478][mmc]: freq: 2-50000000-64-4
[05.764][mmc]: [0-63|64]
[05.766][mmc]: ================== HSDDR52_DDR50...
[05.771][mmc]: skip freq 400000
[05.774][mmc]: freq: 1-25000000-64-4
[06.008][mmc]: freq: 2-50000000-64-4
[06.174][mmc]: [0-50|51]
[06.177][mmc]: [0-45|46]
[06.179][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
[06.183][mmc]: HSSDR52/SDR25: 0xff20ffff 0xffffffff
[06.188][mmc]: HSDDR52/DDR50: 0xff1719ff 0xffffffff
[06.192][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
[06.197][mmc]: HS400: 0xffffffff 0xffffffff
[06.201][mmc]: HS400: 0xffffffff 0xffffffff
[06.205][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[06.211]line:703 init_clocks
[06.214]init_clocks:finish
[06.217]Loading Environment from SUNXI_FLASH... OK
[06.221]try to burn key
[06.223]out of usb burn from boot: not need burn key
sunxi work mode=0x10
run usb efex
buf queue page size = 65536
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x16
set address 0x16 ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
origin_erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 8
part[0] name      :boot-resource
part[0] classname :DISK
part[0] addrlo    :0x8000
part[0] lenlo     :0x34e
part[0] user_type :32768
part[0] keydata   :0
part[0] ro        :0
part[1] name      :env
part[1] classname :DISK
part[1] addrlo    :0x834e
part[1] lenlo     :0x1f8
part[1] user_type :32768
part[1] keydata   :0
part[1] ro        :0
part[2] name      :env-redund
part[2] classname :DISK
part[2] addrlo    :0x8546
part[2] lenlo     :0x1f8
part[2] user_type :32768
part[2] keydata   :0
part[2] ro        :0
part[3] name      :boot
part[3] classname :DISK
part[3] addrlo    :0x873e
part[3] lenlo     :0x2000
part[3] user_type :32768
part[3] keydata   :0
part[3] ro        :0
part[4] name      :rootfs
part[4] classname :DISK
part[4] addrlo    :0xa73e
part[4] lenlo     :0xf000
part[4] user_type :32768
part[4] keydata   :0
part[4] ro        :0
part[5] name      :private
part[5] classname :DISK
part[5] addrlo    :0x1973e
part[5] lenlo     :0x2800
part[5] user_type :32768
part[5] keydata   :0
part[5] ro        :0
part[6] name      :rootfs_data
part[6] classname :DISK
part[6] addrlo    :0x1bf3e
part[6] lenlo     :0x200000
part[6] user_type :32768
part[6] keydata   :0
part[6] ro        :0
part[7] name      :UDISK
part[7] classname :DISK
part[7] addrlo    :0x21bf3e
part[7] lenlo     :0x0
part[7] user_type :32768
part[7] keydata   :0
part[7] ro        :0
total part: 9
mbr 0, 8000, 8000
boot-resource 1, 34e, 8000
env 2, 1f8, 8000
env-redund 3, 1f8, 8000
boot 4, 2000, 8000
rootfs 5, f000, 8000
private 6, 2800, 8000
rootfs_data 7, 200000, 8000
UDISK 8, 0, 8000
[09.697]erase all part start
need erase flash: 1
[09.702]read item0 copy0
[09.715]Item0 (Map) magic is bad
[09.718]the secure storage item0 copy0 magic is bad
[09.734]Item0 (Map) magic is bad
[09.737]the secure storage item0 copy1 magic is bad
[09.741]Item0 (Map) magic is bad
[09.744]the secure storage map is empty
[09.748]no item name set-active-boot-slot in the map
erase secure storage failed
[09.755]sunxi_secure_storage_exit err: secure storage has not been inited
private part exist
GPT:boot-resource: 12000         1234d
GPT:env         : 1234e         12545
GPT:env-redund  : 12546         1273d
GPT:boot        : 1273e         1473d
GPT:rootfs      : 1473e         2373d
GPT:private     : 2373e         25f3d
GPT:rootfs_data : 25f3e         225f3d
GPT:UDISK       : 225f3e        e8ffde
begin to store data
part 0 name boot-resource
keydata = 0x0
part 1 name env
keydata = 0x0
part 2 name env-redund
keydata = 0x0
part 3 name boot
keydata = 0x0
part 4 name rootfs
keydata = 0x0
part 5 name private
keydata = 0x0
find keypart private
keypart read start: 0x1973e, sectors 0x2800
keypart part private read  0x1973e, sectors 0x2800
part 6 name rootfs_data
keydata = 0x0
part 7 name UDISK
keydata = 0x0
begin to erase
[09.958]erase all part start
card2 erase boot0
erase env part
[09.970][mmc]: after adjust nr, no more space need to erase!!
[09.975][mmc]: after align erase group, no space need to erase, erase failed
[09.982][mmc]: mmc_mmc_erase: erase emmc fail!
[09.986][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[09.992][mmc]: --0: from74574  nr504
erase env-redund part
[10.005][mmc]: after adjust start addr, no more space need to erase!!
[10.011][mmc]: Erase addr is not erase group alignment!
[10.016][mmc]: erase failed, range 75776 - 76280
[10.021][mmc]: mmc_mmc_erase: erase emmc fail!
[10.025][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.031][mmc]: --0: from75078  nr504
erase boot part
[10.044][mmc]: erase from: 75776, to: 82943, cnt: 7168, erase_group: 1024
[10.054][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
[10.061][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.066][mmc]: --0: from75582  nr194
[10.070][mmc]: --1: from82944  nr830
erase rootfs part
[10.092][mmc]: erase from: 83968, to: 144383, cnt: 60416, erase_group: 1024
[10.102][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
[10.109][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.114][mmc]: --0: from83774  nr194
[10.118][mmc]: --1: from144384  nr830
erase private part
[10.141][mmc]: erase from: 145408, to: 154623, cnt: 9216, erase_group: 1024
[10.150][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
[10.156][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.162][mmc]: --0: from145214  nr194
[10.165][mmc]: --1: from154624  nr830
erase rootfs_data part
[10.189][mmc]: erase from: 155648, to: 2251775, cnt: 2096128, erase_group: 1024
[10.200][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x4 ms
[10.206][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.212][mmc]: --0: from155454  nr194
[10.215][mmc]: --1: from2251776  nr830
erase UDISK part
sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
[10.243][mmc]: erase from: 2252800, to: 15268863, cnt: 13016064, erase_group: 14
[10.267][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x10 ms
[10.274][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[10.279][mmc]: --0: from2252606  nr194
[10.283][mmc]: --1: from15268864  nr1023
card erase all
finish erase
rewrite
write primary GPT success
write Backup GPT success
[10.321]update partition map
keypart write start: 0x1973e, sectors 0x2800
flash exit
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
[10.491]update partition map
******Has init
flash sectors: 0xe90000
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
FEX_CMD_fes_verify_value 0xe6f75b5c
FEX_CMD_fes_verify_value, start 0x834e, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0xadc89266
FEX_CMD_fes_verify_value, start 0x8546, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value, start 0x873e, size high 0x0:low 0x3c2800
FEX_CMD_fes_verify_value 0x3ebdcad9
#2 2023-06-04 17:23:55
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
建议用windows烧录
楼主 #3 2023-06-04 17:27:17
damifan
建议用windows烧录
回复很中肯,我是想认真的解决这个问题,最开始的时候,使用ubuntu18.04是可以烧录的,后来因为某种原因,格式化了,重新安装ubuntu再配置就不能烧录了
#4 2023-06-05 09:35:15
shaoxi2010
已发帖子: 367
你这个是虚拟机还是实体的,我这个22.04都没问题
楼主 #5 2023-06-05 14:48:41
damifan
shaoxi2010 说:
物理机和虚拟机都有尝试,曾经是可以的,现在不可以了
