楼主 # 2023-06-16 15:39:47
tangloong
已发帖子: 213
F1C100S在linux下通过 sysfs 方式控制操作IO 点灯 不需要了解寄存器
应用层通过/sys/class/gpio文件操作gpio口
不需要写驱动 不需要改设备树 不需要了解寄存器
本来想做一个LED 翻转效果的,就是在读取灯亮的时候灭灯,灭灯的时候亮灯的
结果发现在设置IO为in的时候,GPIO给拉低了造成读一直是0,实现不了想要的效果了
但是我在终端敲命令  echo in > /sys/class/gpio/gpio137/direction 设置为输入模式就不会拉低
不知道为啥
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#define SYSFS_GPIO_DIR  "/sys/class/gpio"
#define MAX_BUF        64
//#define BOARD_SSD201
//uart device name
#ifdef BOARD_SSD201
#define LED_GPIO     85 //PAD_GPIO85    =》 SSD201
#else
#define LED_GPIO     137 //#define LED0  GPIO_PORT_E,GPIO_PIN_9  (A0 B1 C2 D3 E4 F5)=> PE9 = 32*4+9=137   F1C100S
 * function: gpio export
int ss_gpio_export(unsigned int gpio){
    int fd, len;
    char buf[MAX_BUF];
    fd = open(SYSFS_GPIO_DIR "/export", O_WRONLY);
    if (fd < 0) {
        perror("gpio/export");
        return fd;
    len = snprintf(buf, sizeof(buf), "%d", gpio);
    write(fd, buf, len);
    close(fd);
 * function: gpio unexport
int ss_gpio_unexport(unsigned int gpio){
    int fd, len;
    char buf[MAX_BUF];
    fd = open(SYSFS_GPIO_DIR "/unexport", O_WRONLY);
    if (fd < 0) {
        return fd;
    close(fd);
 * function:  gpio set direction
 * parameter: out_flag = 1 -- out
 *            out_flag = 0 -- in
int ss_gpio_set_dir(unsigned int gpio, unsigned int out_flag){
    int fd;
    char buf[MAX_BUF];
    snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR  "/gpio%d/direction", gpio);
    fd = open(buf, O_WRONLY);
    if (fd < 0) {
        perror("gpio/direction");
        return fd;
    if (out_flag)
        write(fd, "out", 4);
        write(fd, "in", 3);
    close(fd);
 * function:  gpio set value
 * parameter: value = 1 -- high
 *            value = 0 -- low
int ss_gpio_set_value(unsigned int gpio, unsigned int value){
    int fd;
    char buf[MAX_BUF];
    snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR "/gpio%d/value", gpio);
    if (fd < 0) {
        perror("gpio/set-value");
        return fd;
    if (value)
        write(fd, "1", 2);
        write(fd, "0", 2);
    close(fd);
 * function: gpio get value
int ss_gpio_get_value(unsigned int gpio, unsigned int *value){
    int fd;
    char buf[MAX_BUF];
    char ch;
    fd = open(buf, O_RDONLY);
    if (fd < 0) {
        perror("gpio/get-value");
        return fd;
    read(fd, &ch, 1);
    if (ch != '0') {
        *value = 1;
    } else {
        *value = 0;
    close(fd);
 * function:  gpio_set edge
 * parameter: edge = "none", "rising", "falling", "both"
int ss_gpio_set_edge(unsigned int gpio, char *edge){
    int fd;
    char buf[MAX_BUF];
    snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR "/gpio%d/edge", gpio);
    if (fd < 0) {
        perror("gpio/set-edge");
        return fd;
    write(fd, edge, strlen(edge) + 1);
    close(fd);
 * function: gpio open fd
int ss_gpio_open(unsigned int gpio){
    int fd;
    char buf[MAX_BUF];
    fd = open(buf, O_RDONLY | O_NONBLOCK);
    if (fd < 0) {
        perror("gpio/fd_open");
    return fd;
 * function: gpio close fd
int ss_gpio_close(int fd){
    return close(fd);
void led_switch(){
	int value = 0;
	ss_gpio_export(LED_GPIO); //
        ss_gpio_set_dir(LED_GPIO, 0);//  不能通过读取IO值,因为设置读会拉低IO
	ss_gpio_get_value(LED_GPIO, &value);
    	printf("gpio[%d] value = %d\n", LED_GPIO, value);
	ss_gpio_set_dir(LED_GPIO, 1);// set LEDIO putput
	if(value == 0){
		ss_gpio_set_value(LED_GPIO, 1);
	}else{
		ss_gpio_set_value(LED_GPIO, 0);
	ss_gpio_unexport(LED_GPIO);
#if 1
int main(int argc, char *argv[]){
    int fd = -1, value = 0;
    if (argc < 2){
        printf("eg:./gpio_main input\n");
        printf("eg:./gpio_main output 1\n");
        return -1;
    if (!strcmp(argv[1], "input")){
        ss_gpio_set_dir(LED_GPIO, 0);// set input then pin low ??
    }else if (!strcmp(argv[1], "output")){
        if (argc < 3){
            return -1;
        value = atoi(argv[2]);
        ss_gpio_set_value(LED_GPIO, value);
    }else{
        printf("unknown commamd\n");
//    led_switch();
