求助,新手第一次自己尝试手动编译uboot,内核和roofs,用的板子是Mq-Quad H616。参考大佬的帖子将内核和uboot成功运行了起来,rootfs是自己用debootstrap制作的,第一次没有在lib目录下放内核编译的modules,成功启动了。启动后发现log里有报错,发现是没有把modules放到lib目录下。后面重新将modules文件放进去后,内核启动就会卡住。卡住的log如下。
U-Boot SPL 2023.10-00938-g25edd247a8-dirty (Oct 15 2023 - 12:36:03 +0800)
pmic id is 0x4b
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE: BL31: v2.9.0(debug):v2.9.0-852-gad4e97877
NOTICE: BL31: Built : 23:05:10, Oct 14 2023
NOTICE: BL31: Detected Allwinner H616 SoC (1823)
NOTICE: BL31: Found U-Boot DTB at 0x4a0b2df0, model: OrangePi Zero2
INFO: ARM GICv2 driver initialized
INFO: Configuring SPC Controller
INFO: PMIC: Probing AXP305 on RSB
ERROR: RSB: set run-time address: 0x10003
INFO: Could not init RSB: -65539
INFO: BL31: Platform setup done
INFO: BL31: Initializing runtime services
INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO: PSCI: Suspend is unavailable
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x4a000000
INFO: SPSR = 0x3c9
INFO: Changed devicetree.
U-Boot 2023.10-00938-g25edd247a8-dirty (Oct 15 2023 - 12:36:03 +0800) Allwinner Technology
CPU: Allwinner H616 (SUN50I)
Model: OrangePi Zero2
DRAM: 1 GiB
Core: 52 devices, 21 uclasses, devicetree: separate
WDT: Not starting watchdog@30090a0
MMC: mmc@4020000: 0
Loading Environment from FAT... OK
In: serial@5000000
Out: serial@5000000
Err: serial@5000000
Net: Could not get PHY for ethernet@5020000: addr 1
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
eth1: usb_ether
Bus usb@5200000: USB EHCI 1.00
Bus usb@5200400: USB OHCI 1.0
scanning bus usb@5200000 for devices... 1 USB Device(s) found
scanning bus usb@5200400 for devices... 1 USB Device(s) found
22532104 bytes read in 934 ms (23 MiB/s)
33502 bytes read in 3 ms (10.6 MiB/s)
## Flattened Device Tree blob at 4fa00000
Booting using the fdt blob at 0x4fa00000
Working FDT set to 4fa00000
Loading Device Tree to 0000000049ff4000, end 0000000049fff2dd ... OK
Working FDT set to 49ff4000
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.19.4+ (limesea@limesea) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111, GNU ld (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 2.37.20220122) #1 SMP Mon Oct 16 21:07:58 CST 2023
[ 0.000000] Machine model: MangoPi Mcore
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7fdd1040-0x7fdd2fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff]
[ 0.000000] node 0: [mem 0x0000000040080000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] cma: Reserved 128 MiB at 0x0000000076c00000
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 19 pages/cpu s37672 r8192 d31960 u77824
[ 0.000000] pcpu-alloc: s37672 r8192 d31960 u77824 alloc=19*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw init=/sbin/init debug panic=30
[ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] printk: log_buf_len min size: 16384 bytes
[ 0.000000] printk: log_buf_len: 32768 bytes
[ 0.000000] printk: early log buf free: 14344(87%)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Memory: 873884K/1048576K available (14080K kernel code, 1076K rwdata, 4156K rodata, 2560K init, 389K bss, 43620K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000470] Console: colour dummy device 80x25
[ 0.000559] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.000573] pid_max: default: 32768 minimum: 301
[ 0.000641] LSM: Security Framework initializing
[ 0.000674] Yama: becoming mindful.
[ 0.000767] AppArmor: AppArmor initialized
[ 0.000871] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000886] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002498] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002516] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002688] rcu: Hierarchical SRCU implementation.
[ 0.002694] rcu: Max phase no-delay instances is 1000.
[ 0.004134] smp: Bringing up secondary CPUs ...
[ 0.004666] Detected VIPT I-cache on CPU1
[ 0.004748] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005400] Detected VIPT I-cache on CPU2
[ 0.005467] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006084] Detected VIPT I-cache on CPU3
[ 0.006152] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006244] smp: Brought up 1 node, 4 CPUs
[ 0.006252] SMP: Total of 4 processors activated.
[ 0.006257] CPU features: detected: 32-bit EL0 Support
[ 0.006262] CPU features: detected: CRC32 instructions
[ 0.006630] CPU: All CPU(s) started at EL2
[ 0.006647] alternatives: patching kernel code
[ 0.008045] devtmpfs: initialized
[ 0.013740] Registered cp15_barrier emulation handler
[ 0.013762] Registered setend emulation handler
[ 0.013949] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.013969] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.019165] pinctrl core: initialized pinctrl subsystem
[ 0.020564] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.021927] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.022247] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.022379] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.022454] audit: initializing netlink subsys (disabled)
[ 0.022700] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[ 0.023207] thermal_sys: Registered thermal governor 'fair_share'
[ 0.023214] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.023218] thermal_sys: Registered thermal governor 'step_wise'
[ 0.023221] thermal_sys: Registered thermal governor 'user_space'
[ 0.023673] cpuidle: using governor menu
[ 0.023852] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.023972] ASID allocator initialised with 65536 entries
[ 0.023982] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.023988] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
[ 0.023993] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.023997] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
[ 0.024239] Serial: AMBA PL011 UART driver
[ 0.033310] platform 6510000.tcon-top: Fixing up cyclic dependency with 6000000.hdmi
[ 0.033558] platform 6515000.lcd-controller: Fixing up cyclic dependency with 6510000.tcon-top
[ 0.034504] platform connector: Fixing up cyclic dependency with 6000000.hdmi
[ 0.041644] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.041661] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.041667] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.041672] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.042345] cryptd: max_cpu_qlen set to 1000
[ 0.108363] raid6: neonx8 gen() 1806 MB/s
[ 0.176442] raid6: neonx4 gen() 1846 MB/s
[ 0.244525] raid6: neonx2 gen() 1752 MB/s
[ 0.312609] raid6: neonx1 gen() 1507 MB/s
[ 0.380691] raid6: int64x8 gen() 1148 MB/s
[ 0.448766] raid6: int64x4 gen() 1345 MB/s
[ 0.516845] raid6: int64x2 gen() 1174 MB/s
[ 0.584916] raid6: int64x1 gen() 870 MB/s
[ 0.584921] raid6: using algorithm neonx4 gen() 1846 MB/s
[ 0.652979] raid6: .... xor() 1313 MB/s, rmw enabled
[ 0.652985] raid6: using neon recovery algorithm
[ 0.654338] iommu: Default domain type: Translated
[ 0.654354] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.654693] SCSI subsystem initialized
[ 0.654883] usbcore: registered new interface driver usbfs
[ 0.654917] usbcore: registered new interface driver hub
[ 0.654949] usbcore: registered new device driver usb
[ 0.655300] pps_core: LinuxPPS API ver. 1 registered
[ 0.655305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.655318] PTP clock support registered
[ 0.655782] ARM FF-A: FFA_VERSION returned not supported
[ 0.656197] Advanced Linux Sound Architecture Driver Initialized.
[ 0.656857] NetLabel: Initializing
[ 0.656863] NetLabel: domain hash size = 128
[ 0.656867] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.656938] NetLabel: unlabeled traffic allowed by default
[ 0.656942] mctp: management component transport protocol core
[ 0.656947] NET: Registered PF_MCTP protocol family
[ 0.657555] clocksource: Switched to clocksource arch_sys_counter
[ 0.657810] VFS: Disk quotas dquot_6.6.0
[ 0.657853] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.658423] AppArmor: AppArmor Filesystem Enabled
[ 0.665250] NET: Registered PF_INET protocol family
[ 0.665476] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.666738] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.666768] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.666780] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.666850] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.666997] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.667140] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.667174] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.667370] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.668464] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.670207] Initialise system trusted keyrings
[ 0.670285] Key type blacklist registered
[ 0.670567] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[ 0.675869] zbud: loaded
[ 0.677446] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.679710] integrity: Platform Keyring initialized
[ 0.722603] xor: automatically using best checksumming function 32regs
[ 0.722615] async_tx: api initialized (async)
[ 0.722623] Key type asymmetric registered
[ 0.722628] Asymmetric key parser 'x509' registered
[ 0.724183] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.724306] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.724448] io scheduler mq-deadline registered
[ 0.724453] io scheduler kyber registered
[ 0.724591] io scheduler bfq registered
[ 0.736895] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.742670] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.747826] loop: module loaded
[ 0.750049] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.750103] ehci-platform: EHCI generic platform driver
[ 0.750232] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.750248] ohci-platform: OHCI generic platform driver
[ 0.750642] usbcore: registered new interface driver usb-storage
[ 0.751178] mousedev: PS/2 mouse device common for all mice
[ 0.752313] sun6i-rtc 7000000.rtc: registered as rtc0
[ 0.752358] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T00:00:06 UTC (86406)
[ 0.752463] sun6i-rtc 7000000.rtc: RTC enabled
[ 0.752576] i2c_dev: i2c /dev entries driver
[ 0.753350] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.754686] sun50i-cpufreq-nvmem: probe of sun50i-cpufreq-nvmem failed with error -2
[ 0.755167] sdhci: Secure Digital Host Controller Interface driver
[ 0.755175] sdhci: Copyright(c) Pierre Ossman
[ 0.755197] Synopsys Designware Multimedia Card Interface Driver
[ 0.755790] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.756330] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.756660] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000
[ 0.757052] hid: raw HID events driver (C) Jiri Kosina
[ 0.757157] usbcore: registered new interface driver usbhid
[ 0.757161] usbhid: USB HID core driver
[ 0.767929] NET: Registered PF_INET6 protocol family
[ 0.770653] Segment Routing with IPv6
[ 0.770728] In-situ OAM (IOAM) with IPv6
[ 0.770824] NET: Registered PF_PACKET protocol family
[ 0.770965] 8021q: 802.1Q VLAN Support v1.8
[ 0.771116] 9pnet: Installing 9P2000 support
[ 0.771198] Key type dns_resolver registered
[ 0.771704] registered taskstats version 1
[ 0.771732] Loading compiled-in X.509 certificates
[ 0.775485] Loaded X.509 cert 'Build time autogenerated kernel key: dde8308c153b63d774a4b6b65b43d7a4b965c283'
[ 0.778954] zswap: loaded using pool zstd/z3fold
[ 0.779584] Key type ._fscrypt registered
[ 0.779596] Key type .fscrypt registered
[ 0.779599] Key type fscrypt-provisioning registered
[ 0.780730] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 0.781142] Key type encrypted registered
[ 0.781161] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.781205] ima: No TPM chip found, activating TPM-bypass!
[ 0.781230] ima: Allocated hash algorithm: sha1
[ 0.781264] ima: No architecture policies found
[ 0.781318] evm: Initialising EVM extended attributes:
[ 0.781321] evm: security.selinux
[ 0.781325] evm: security.SMACK64
[ 0.781328] evm: security.SMACK64EXEC
[ 0.781331] evm: security.SMACK64TRANSMUTE
[ 0.781334] evm: security.SMACK64MMAP
[ 0.781337] evm: security.apparmor
[ 0.781340] evm: security.ima
[ 0.781343] evm: security.capability
[ 0.781346] evm: HMAC attrs: 0x1
[ 0.798184] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top
[ 0.807285] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 0.808885] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 0.809623] printk: console [ttyS0] disabled
[ 0.809711] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 284, base_baud = 1500000) is a 16550A
[ 2.085522] printk: console [ttyS0] enabled
[ 2.090568] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pg not found, using dummy regulator
[ 2.099991] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 285, base_baud = 1500000) is a 16550A
[ 2.108963] serial serial0: tty port ttyS1 registered
[ 2.114466] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator
[ 2.123810] 5000800.serial: ttyS2 at MMIO 0x5000800 (irq = 286, base_baud = 1500000) is a 16550A
[ 2.134183] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 2.143299] sun6i-spi 5010000.spi: Failed to request TX DMA channel
[ 2.149589] sun6i-spi 5010000.spi: Failed to request RX DMA channel
[ 2.156520] spi-nor spi0.0: supply vdd not found, using dummy regulator
[ 2.177787] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 2.185772] sun6i-spi 5011000.spi: Failed to request TX DMA channel
[ 2.192080] sun6i-spi 5011000.spi: Failed to request RX DMA channel
[ 2.200378] ehci-platform 5200000.usb: EHCI Host Controller
[ 2.201099] ehci-platform 5310000.usb: EHCI Host Controller
[ 2.201983] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[ 2.202123] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
[ 2.202694] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 2.202719] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 2.203048] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.203061] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.203068] usb usb1: Product: MUSB HDRC host driver
[ 2.203074] usb usb1: Manufacturer: Linux 5.19.4+ musb-hcd
[ 2.203081] usb usb1: SerialNumber: musb-hdrc.2.auto
[ 2.203755] hub 1-0:1.0: USB hub found
[ 2.203801] hub 1-0:1.0: 1 port detected
[ 2.203846] ehci-platform 5311000.usb: EHCI Host Controller
[ 2.204233] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 2
[ 2.204383] ehci-platform 5311000.usb: irq 292, io mem 0x05311000
[ 2.204836] ohci-platform 5200400.usb: Generic Platform OHCI controller
[ 2.204858] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 3
[ 2.204988] ohci-platform 5200400.usb: irq 293, io mem 0x05200400
[ 2.206043] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 4
[ 2.206090] ohci-platform 5310400.usb: Generic Platform OHCI controller
[ 2.206109] ohci-platform 5310400.usb: new USB bus registered, assigned bus number 5
[ 2.206240] ohci-platform 5310400.usb: irq 294, io mem 0x05310400
[ 2.207808] ohci-platform 5311400.usb: Generic Platform OHCI controller
[ 2.207839] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[ 2.207975] ohci-platform 5311400.usb: irq 296, io mem 0x05311400
[ 2.209786] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.211342] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[ 2.211637] ehci-platform 5310000.usb: new USB bus registered, assigned bus number 7
[ 2.213097] ALSA device list:
[ 2.213111] No soundcards found.
[ 2.213473] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.217574] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[ 2.217886] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.217898] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.217905] usb usb2: Product: EHCI Host Controller
[ 2.217911] usb usb2: Manufacturer: Linux 5.19.4+ ehci_hcd
[ 2.217917] usb usb2: SerialNumber: 5311000.usb
[ 2.218459] hub 2-0:1.0: USB hub found
[ 2.218500] hub 2-0:1.0: 1 port detected
[ 2.220487] ehci-platform 5200000.usb: irq 289, io mem 0x05200000
[ 2.229650] ehci-platform 5310000.usb: irq 290, io mem 0x05310000
[ 2.237855] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.249559] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
[ 2.265565] ehci-platform 5310000.usb: USB 2.0 started, EHCI 1.00
[ 2.269737] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
[ 2.291149] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.294998] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.304634] mmc0: new high speed SDHC card at address aaaa
[ 2.307694] usb usb3: Product: Generic Platform OHCI controller
[ 2.316420] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 2.321533] usb usb3: Manufacturer: Linux 5.19.4+ ohci_hcd
[ 2.321541] usb usb3: SerialNumber: 5200400.usb
[ 2.322167] hub 3-0:1.0: USB hub found
[ 2.331462] mmcblk0: p1 p2
[ 2.336013] hub 3-0:1.0: 1 port detected
[ 2.542690] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.551020] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.558254] usb usb4: Product: EHCI Host Controller
[ 2.563138] usb usb4: Manufacturer: Linux 5.19.4+ ehci_hcd
[ 2.568624] usb usb4: SerialNumber: 5200000.usb
[ 2.573802] hub 4-0:1.0: USB hub found
[ 2.577634] hub 4-0:1.0: 1 port detected
[ 2.582177] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
[ 2.590483] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.597714] usb usb6: Product: Generic Platform OHCI controller
[ 2.603637] usb usb6: Manufacturer: Linux 5.19.4+ ohci_hcd
[ 2.609142] usb usb6: SerialNumber: 5311400.usb
[ 2.614313] hub 6-0:1.0: USB hub found
[ 2.618166] hub 6-0:1.0: 1 port detected
[ 2.622716] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
[ 2.631042] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.638286] usb usb5: Product: Generic Platform OHCI controller
[ 2.644210] usb usb5: Manufacturer: Linux 5.19.4+ ohci_hcd
[ 2.649699] usb usb5: SerialNumber: 5310400.usb
[ 2.654870] hub 5-0:1.0: USB hub found
[ 2.658690] hub 5-0:1.0: 1 port detected
[ 2.663196] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.671505] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.678742] usb usb7: Product: EHCI Host Controller
[ 2.683623] usb usb7: Manufacturer: Linux 5.19.4+ ehci_hcd
[ 2.689111] usb usb7: SerialNumber: 5310000.usb
[ 2.694256] hub 7-0:1.0: USB hub found
[ 2.698085] hub 7-0:1.0: 1 port detected
[ 2.702475] md: Waiting for all devices to be available before autodetect
[ 2.709301] md: If you don't use raid, use raid=noautodetect
[ 2.714977] md: Autodetecting RAID arrays.
[ 2.719075] md: autorun ...
[ 2.721873] md: ... autorun DONE.
[ 2.936120] EXT4-fs (mmcblk0p2): recovery complete
[ 2.942768] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.951397] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.958414] devtmpfs: mounted
[ 2.962515] Freeing unused kernel memory: 2560K
[ 2.967167] Run /sbin/init as init process
[ 2.971270] with arguments:
[ 2.974243] /sbin/init
[ 2.976948] with environment:
[ 2.980091] HOME=/
[ 2.982455] TERM=linux
[ 3.477839] systemd[1]: System time before build time, advancing clock.
[ 3.586639] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.609274] systemd[1]: No virtualization found in DMI
[ 3.614437] systemd[1]: No virtualization found in CPUID
[ 3.619798] systemd[1]: Virtualization XEN not found, /proc/xen does not exist
[ 3.627225] systemd[1]: No virtualization found in /proc/device-tree/*
[ 3.634039] systemd[1]: UML virtualization not found in /proc/cpuinfo.
[ 3.640592] systemd[1]: This platform does not support /proc/sysinfo
[ 3.646957] systemd[1]: Found VM virtualization none
[ 3.651974] systemd[1]: Detected architecture arm64.
[ 3.657517] systemd[1]: Mounting cgroup to /sys/fs/cgroup/devices of type cgroup with options devices.
[ 3.667392] systemd[1]: Mounting cgroup to /sys/fs/cgroup/net_cls,net_prio of type cgroup with options net_cls,net_prio.
[ 3.678796] systemd[1]: Mounting cgroup to /sys/fs/cgroup/freezer of type cgroup with options freezer.
[ 3.688573] systemd[1]: Mounting cgroup to /sys/fs/cgroup/memory of type cgroup with options memory.
[ 3.698359] systemd[1]: Mounting cgroup to /sys/fs/cgroup/rdma of type cgroup with options rdma.
[ 3.707640] systemd[1]: Mounting cgroup to /sys/fs/cgroup/cpu,cpuacct of type cgroup with options cpu,cpuacct.
[ 3.718317] systemd[1]: Mounting cgroup to /sys/fs/cgroup/hugetlb of type cgroup with options hugetlb.
[ 3.728233] systemd[1]: Mounting cgroup to /sys/fs/cgroup/perf_event of type cgroup with options perf_event.
[ 3.738507] systemd[1]: Mounting cgroup to /sys/fs/cgroup/cpuset of type cgroup with options cpuset.
[ 3.761916] systemd[1]: Mounting cgroup to /sys/fs/cgroup/blkio of type cgroup with options blkio.
[ 3.771515] systemd[1]: Mounting cgroup to /sys/fs/cgroup/pids of type cgroup with options pids.
Welcome to Ubuntu 20.04.6 LTS!
[ 3.802738] systemd[1]: Set hostname to <limesea-h616>.
[ 3.809996] systemd[1]: Successfully added address 127.0.0.1 to loopback interface
[ 3.817665] systemd[1]: Successfully added address ::1 to loopback interface
[ 3.824755] systemd[1]: Successfully brought loopback interface up
[ 3.831341] systemd[1]: Setting 'fs/file-max' to '9223372036854775807'.
[ 3.846355] systemd[1]: Found cgroup2 on /sys/fs/cgroup/unified, unified hierarchy for systemd controller
[ 3.856299] systemd[1]: Found cgroup2 on /sys/fs/cgroup/unified, unified hierarchy for systemd controller
[ 3.865892] systemd[1]: Unified cgroup hierarchy is located at /sys/fs/cgroup/unified. Controllers are on legacy hierarchies.
[ 3.887102] systemd[1]: Got EBADF when using BPF_F_ALLOW_MULTI, which indicates it is supported. Yay!
[ 3.896612] systemd[1]: Controller 'cpu' supported: yes
[ 3.901905] systemd[1]: Controller 'cpuacct' supported: yes
[ 3.907502] systemd[1]: Controller 'cpuset' supported: no
[ 3.912948] systemd[1]: Controller 'io' supported: no
[ 3.918010] systemd[1]: Controller 'blkio' supported: yes
[ 3.923416] systemd[1]: Controller 'memory' supported: yes
[ 3.928916] systemd[1]: Controller 'devices' supported: yes
[ 3.934498] systemd[1]: Controller 'pids' supported: yes
[ 3.939817] systemd[1]: Controller 'bpf-firewall' supported: yes
[ 3.945829] systemd[1]: Controller 'bpf-devices' supported: yes
[ 3.951813] systemd[1]: Set up TFD_TIMER_CANCEL_ON_SET timerfd.
[ 3.958882] systemd[1]: Enabling (yes) showing of status (commandline).
[ 3.967323] systemd[1]: Successfully forked off '(sd-executor)' as PID 185.
[ 3.972965] systemd[185]: Successfully forked off '(direxec)' as PID 186.
[ 3.982196] systemd[185]: Successfully forked off '(direxec)' as PID 187.
[ 3.990193] systemd[185]: Successfully forked off '(direxec)' as PID 188.
[ 3.998461] systemd[185]: Successfully forked off '(direxec)' as PID 189.
[ 4.003412] systemd-bless-boot-generator[187]: Skipping generator, not an EFI boot.
[ 4.006529] systemd[185]: Successfully forked off '(direxec)' as PID 191.
[ 4.020894] systemd[185]: Successfully forked off '(direxec)' as PID 192.
[ 4.028954] systemd[185]: Successfully forked off '(direxec)' as PID 193.
[ 4.037375] systemd[185]: Successfully forked off '(direxec)' as PID 194.
[ 4.045698] systemd[185]: Successfully forked off '(direxec)' as PID 195.
[ 4.051947] systemd-fstab-generator[191]: Parsing /etc/fstab...
[ 4.054064] systemd[185]: Successfully forked off '(direxec)' as PID 196.
[ 4.066133] systemd-getty-generator[192]: Automatically adding serial getty for /dev/ttyS0.
[ 4.066794] systemd[185]: Successfully forked off '(direxec)' as PID 197.
[ 4.069346] systemd-fstab-generator[191]: Found entry what=/dev/mmcblk0p2 where=/ type=ext4 makefs=no growfs=no noauto=no nofail=no
[ 4.083314] systemd-hibernate-resume-generator[194]: Not running in an initrd, quitting.
[ 4.085488] systemd-gpt-auto-generator[193]: Disabling root partition auto-detection, root= is defined.
[ 4.085873] systemd-gpt-auto-generator[193]: Failed to chase block device '/', ignoring: No such file or directory
[ 4.087403] systemd-gpt-auto-generator[193]: mmcblk0p2: Root device /dev/mmcblk0.
[ 4.094748] systemd[185]: Successfully forked off '(direxec)' as PID 198.
[ 4.100073] systemd-rc-local-generator[195]: /etc/rc.local does not exist, skipping.
[ 4.112772] systemd-fstab-generator[191]: Found entry what=/dev/mmcblk0p1 where=/boot/uboot type=vfat makefs=no growfs=no noauto=no nofail=no
[ 4.122488] systemd[185]: Successfully forked off '(direxec)' as PID 199.
[ 4.163331] systemd[185]: /usr/lib/systemd/system-generators/systemd-hibernate-resume-generator succeeded.
[ 4.195537] systemd-sysv-generator[198]: Native unit for nfs-common.service already exists, skipping.
[ 4.216261] systemd-sysv-generator[198]: Native unit for console-setup.service already exists, skipping.
[ 4.226272] systemd-sysv-generator[198]: Native unit for hwclock.service already exists, skipping.
[ 4.236433] systemd-sysv-generator[198]: Native unit for ssh.service already exists, skipping.
[ 4.247244] systemd-sysv-generator[198]: Native unit for procps.service already exists, skipping.
[ 4.257610] systemd-sysv-generator[198]: Native unit for rpcbind.service already exists, skipping.
[ 4.267781] systemd-sysv-generator[198]: Native unit for resolvconf.service already exists, skipping.
[ 4.278210] systemd-sysv-generator[198]: Native unit for pppd-dns.service already exists, skipping.
[ 4.286030] systemd-gpt-auto-generator[193]: No suitable partition table found, ignoring.
[ 4.289227] systemd-sysv-generator[198]: Native unit for kmod.service already exists, skipping.
[ 4.297926] systemd[185]: /usr/lib/systemd/system-generators/systemd-gpt-auto-generator succeeded.
[ 4.306259] systemd-sysv-generator[198]: Native unit for network-manager.service already exists, skipping.
[ 4.313268] systemd[185]: /usr/lib/systemd/system-generators/systemd-rc-local-generator succeeded.
[ 4.323836] systemd-sysv-generator[198]: Native unit for networking.service already exists, skipping.
[ 4.342003] systemd-sysv-generator[198]: Native unit for rsyslog.service already exists, skipping.
[ 4.351906] systemd-sysv-generator[198]: Native unit for dbus.service already exists, skipping.
[ 4.361587] systemd-sysv-generator[198]: Native unit for keyboard-setup.service already exists, skipping.
[ 4.373713] systemd-sysv-generator[198]: Native unit for udev.service already exists, skipping.
[ 4.383371] systemd-sysv-generator[198]: Native unit for cron.service already exists, skipping.
[ 4.393917] systemd-sysv-generator[198]: Ignoring S01console-setup.sh symlink in rc2.d, not generating console-setup.service.
[ 4.405278] systemd-sysv-generator[198]: Ignoring S01dbus symlink in rc2.d, not generating dbus.service.
[ 4.414773] systemd-sysv-generator[198]: Ignoring S01rsyslog symlink in rc2.d, not generating rsyslog.service.
[ 4.424784] systemd-sysv-generator[198]: Ignoring S01ssh symlink in rc2.d, not generating ssh.service.
[ 4.434097] systemd-sysv-generator[198]: Ignoring S01cron symlink in rc2.d, not generating cron.service.
[ 4.444610] systemd-sysv-generator[198]: Ignoring S01console-setup.sh symlink in rc3.d, not generating console-setup.service.
[ 4.456152] systemd-sysv-generator[198]: Ignoring S01dbus symlink in rc3.d, not generating dbus.service.
[ 4.465660] systemd-sysv-generator[198]: Ignoring S01rsyslog symlink in rc3.d, not generating rsyslog.service.
[ 4.475672] systemd-sysv-generator[198]: Ignoring S01ssh symlink in rc3.d, not generating ssh.service.
[ 4.484989] systemd-sysv-generator[198]: Ignoring S01cron symlink in rc3.d, not generating cron.service.
[ 4.495526] systemd-sysv-generator[198]: Ignoring S01console-setup.sh symlink in rc4.d, not generating console-setup.service.
[ 4.506901] systemd-sysv-generator[198]: Ignoring S01dbus symlink in rc4.d, not generating dbus.service.
[ 4.516394] systemd-sysv-generator[198]: Ignoring S01rsyslog symlink in rc4.d, not generating rsyslog.service.
[ 4.526409] systemd-sysv-generator[198]: Ignoring S01ssh symlink in rc4.d, not generating ssh.service.
[ 4.535724] systemd-sysv-generator[198]: Ignoring S01cron symlink in rc4.d, not generating cron.service.
[ 4.546199] systemd-sysv-generator[198]: Ignoring S01console-setup.sh symlink in rc5.d, not generating console-setup.service.
[ 4.557559] systemd-sysv-generator[198]: Ignoring S01dbus symlink in rc5.d, not generating dbus.service.
[ 4.567051] systemd-sysv-generator[198]: Ignoring S01rsyslog symlink in rc5.d, not generating rsyslog.service.
[ 4.577060] systemd-sysv-generator[198]: Ignoring S01ssh symlink in rc5.d, not generating ssh.service.
[ 4.586374] systemd-sysv-generator[198]: Ignoring S01cron symlink in rc5.d, not generating cron.service.
[ 4.598302] systemd[185]: /usr/lib/systemd/system-generators/systemd-sysv-generator succeeded.
[ 4.607028] systemd[185]: /usr/lib/systemd/system-generators/systemd-run-generator succeeded.
[ 4.615608] systemd[185]: /usr/lib/systemd/system-generators/systemd-cryptsetup-generator succeeded.
[ 4.624798] systemd[185]: /usr/lib/systemd/system-generators/systemd-fstab-generator succeeded.
[ 4.633545] systemd[185]: /usr/lib/systemd/system-generators/systemd-veritysetup-generator succeeded.
[ 4.642833] systemd[185]: /usr/lib/systemd/system-generators/systemd-debug-generator succeeded.
[ 4.651581] systemd[185]: /usr/lib/systemd/system-generators/systemd-getty-generator succeeded.
[ 4.660320] systemd[185]: /usr/lib/systemd/system-generators/systemd-bless-boot-generator succeeded.
[ 4.669488] systemd[185]: /usr/lib/systemd/system-generators/systemd-system-update-generator succeeded.
[ 4.678900] systemd[185]: /usr/lib/systemd/system-generators/netplan succeeded.
[ 4.687269] systemd[1]: (sd-executor) succeeded.
[ 4.692097] systemd[1]: Looking for unit files in (higher priority first):
[ 4.699047] systemd[1]: /etc/systemd/system.control
[ 4.704030] systemd[1]: /run/systemd/system.control
[ 4.709015] systemd[1]: /run/systemd/transient
[ 4.713556] systemd[1]: /run/systemd/generator.early
[ 4.718613] systemd[1]: /etc/systemd/system
[ 4.722892] systemd[1]: /etc/systemd/system.attached
[ 4.727949] systemd[1]: /run/systemd/system
[ 4.732229] systemd[1]: /run/systemd/system.attached
[ 4.737286] systemd[1]: /run/systemd/generator
[ 4.741823] systemd[1]: /usr/local/lib/systemd/system
[ 4.746967] systemd[1]: /lib/systemd/system
[ 4.751245] systemd[1]: /usr/lib/systemd/system
[ 4.755871] systemd[1]: /run/systemd/generator.late
[ 4.767908] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/dbus-org.freedesktop.resolve1.service 鈫?systemd-resolved.service
[ 4.781150] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service 鈫?NetworkManager-dispatcher.service
[ 4.795513] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/dbus-org.freedesktop.timesync1.service 鈫?systemd-timesyncd.service
[ 4.808809] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/sshd.service 鈫?ssh.service
[ 4.818611] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service 鈫?ModemManager.service
[ 4.831934] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/dbus-fi.w1.wpa_supplicant1.service 鈫?wpa_supplicant.service
[ 4.844647] systemd[1]: unit_file_build_name_map: alias: /etc/systemd/system/syslog.service 鈫?rsyslog.service
[ 4.854944] systemd[1]: unit_file_build_name_map: normal unit file: /run/systemd/system/netplan-ovs-an-ovs-cleanup.service
[ 4.865487] systemd[1]: unit_file_build_name_map: normal unit file: /run/systemd/generator/boot-uboot.mount
[ 4.875269] systemd[1]: unit_file_build_name_map: normal unit file: /run/systemd/generator/-.mount
[ 4.885137] systemd[1]: unit_file_build_name_map: linked unit file: /lib/systemd/system/rc.service 鈫?/dev/null
[ 4.895388] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-udevd-kernel.socket
[ 4.905839] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/initrd-udevadm-cleanup-db.service
[ 4.916823] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sys-kernel-tracing.mount
[ 4.927013] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-time-wait-sync.service
[ 4.937719] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/network-online.target
[ 4.947647] systemd[1]: unit_file_build_name_map: normal unit file: /libb/systemd/system/systemd-update-utmp-runlevel.service
[ 4.958891] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/user-runtime-dir@.service
[ 4.969230] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ssh@.service
[ 4.978386] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/remote-fs-pre.target
[ 4.988438] systemd[1]: unit_file_build_name_map: linked unit file: /lib/systemd/system/cryptdisks.service 鈫?/dev/null
[ 4.999334] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/user@.service
[ 5.008566] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ua-timer.service
[ 5.018068] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-logind.service
[ 5.028355] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/ctrl-alt-del.target 鈫?reboot.target
[ 5.038769] systemd[1]: unit_file_build_name_map: normal l unit file: /lib/systemd/system/e2scrub_all.service
[ 5.048524] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ua-reboot-cmds.service
[ 5.058714] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/kmod.service 鈫?systemd-modules-load.service
[ 5.069781] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-sysusers.service
[ 5.079995] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-networkd-wait-online.service
[ 5.091248] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/graphical.target
[ 5.100844] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-boot-system-token.service
[ 5.111810] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/nfs-utils.service
[ 5.121386] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/usb_modeswitch@.service
[ 5.131493] systemd[[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-journald-audit.socket
[ 5.142116] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sys-kernel-config.mount
[ 5.152217] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ifupdown-wait-online.service
[ 5.162750] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/slices.target
[ 5.171987] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/apt-daily-upgrade.timer
[ 5.182086] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sockets.target
[ 5.191406] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/polkit.service
[ 5.200737] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-reboot.service
[ 5.210768] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-journal-flush.service
[ 5.221390] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/remote-cryptsetup.target
[ 5.231574] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/e2scrub@.service
[ 5.241297] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/udev.service 鈫?systemd-udevd.service
[ 5.251764] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-udev-settle.service
[ 5.262502] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/runlevel5.target 鈫?graphical.target
[ 5.272911] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/e2scrub_fail@.service
[ 5.282894] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/quotaon.service
[ 5.292301] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/boot-complete.target
[ 5.302147] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rescue.target
[ 5.311379] systemd[1[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/system-update.target
[ 5.321218] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ifupdown-pre.service
[ 5.331055] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rpcbind.socket
[ 5.340375] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-journald-dev-log.socket
[ 5.351167] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/initrd-root-fs.target
[ 5.361095] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/bluetooth.target
[ 5.370600] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/nss-user-lookup.target
[ 5.380626] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/wpa_supplicant@.service
[ 5.390726] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/shutdown.target
[ 5.400136] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/dev-hugepages.mount
[ 5.409891] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/console-getty.service
[ 5.419818] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-ask-password-console.path
[ 5.430787] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/kexec.target
[ 5.439934] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-fsckd.socket
[ 5.449771] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/fstrim.timer
[ 5.458914] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rsyslog.service
[ 5.468318] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/run-rpc_pipefs.mount
[ 5.478162] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-suspend.service
[ 5.488267] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sigpwr.target
[ 5.497500] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ifup@.service
[ 5.506735] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/container-getty@.service
[ 5.516923] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sleep.target
[ 5.526244] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/syslog.socket
[ 5.535478] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/pppd-dns.service
[ 5.544976] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-suspend-then-hibernate.service
[ 5.556376] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/local-fs.target
[ 5.565781] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-modules-load.service
[ 5.576313] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/halt.target
[ 5.585372] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-binfmt.service
[ 5.595388] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ModemManager.service
[ 5.605225] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ssh.socket
[ 5.614197] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/timers.target
[ 5.623750] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/default.target 鈫?graphical.target
[ 5.634142] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/network-manager.service 鈫?NetworkManager.service
[ 5.645643] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/wpa_supplicant-nl80211@.service
[ 5.656611] systemd[1]: unit_file_build_name_map: linked unit file: /lib/systemd/system/x11-common.service 鈫?/dev/null
[ 5.667511] systemd[1]: unit_file_build_namname_map: normal unit file: /lib/systemd/system/systemd-machine-id-commit.service
[ 5.678484] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sys-fs-fuse-connections.mount
[ 5.689105] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/NetworkManager-dispatcher.service
[ 5.700071] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-udevd.service
[ 5.710000] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/apt-daily.service
[ 5.719578] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rpcbind.target
[ 5.728904] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/blockdev@.target
[ 5.738402] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-backlight@.service
[ 5.748776] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-journald.socket
[ 5.758984] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/e2scrub_all.timer
[ 5.768569] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-boot-check-no-failures.service
[ 5.779981] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/hybrid-sleep.target
[ 5.789733] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/suspend.target
[ 5.799054] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/getty.target
[ 5.808198] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-bless-boot.service
[ 5.818554] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-rfkill.service
[ 5.828595] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/resolvconf.service
[ 5.838275] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-poweroff.service
[ 5.848472] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/logrotate.timer
[ 5.857898] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/NetworkManager.service
[ 5.867913] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/keyboard-setup.service
[ 5.878352] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/runlevel4.target 鈫?multi-user.target
[ 5.888859] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/cryptsetup.target
[ 5.898446] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/fstrim.service
[ 5.907775] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/initrd-root-device.target
[ 5.918048] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/networkd-dispatcher.service
[ 5.928493] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/dbus.socket
[ 5.937552] systemd[1]]: unit_file_build_name_map: normal unit file: /lib/systemd/system/getty-static.service
[ 5.947645] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/runlevel0.target 鈫?poweroff.target
[ 5.957937] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-udev-trigger.service
[ 5.968716] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/dbus-org.freedesktop.locale1.service 鈫?systemd-localed.service
[ 5.981439] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/proc-fs-nfsd.mount
[ 5.991110] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/time-set.target
[ 6.000529] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/debug-shell.service
[ 6.010297] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/sysinit.target
[ 6.019806] systemd[1]: unit_file_build_name_map: alias: /lib/systemd/system/procps.service 鈫?systemd-sysctlctl.service
[ 6.030529] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rpc-gssd.service
[ 6.040022] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/rc-local.service
[ 6.049518] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/nfs-idmapd.service
[ 6.059200] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/user.slice
[ 6.068173] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-tmpfiles-clean.timer
[ 6.078905] systemd[1]: unit_file_build_name_map: linked unit file: /lib/systemd/system/rcS.service 鈫?/dev/null
[ 6.089201] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-rfkill.socket
[ 6.099129] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/initrd-fs.target
[ 6.108626] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/apt-daily-upgrade.service
[ 6.118916] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/umount.target
[ 6.128163] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-timedated.service
[ 6.138438] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-resolved.service
[ 6.148626] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-journald@.service
[ 6.158915] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/resolvconf-pull-resolved.path
[ 6.169553] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-hibernate.service
[ 6.179833] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/local-fs-pre.target
[ 6.189590] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/ua-timer.timer
[ 6.198915] systemd[1]: unit_file_build_name_map: normal unit file: /lib/systemd/system/systemd-tmpfiles-setup-dev.service
[ 10.421547] random: crng init done
[ 10.428704] systemd[1]: system-modprobe.slice changed dead -> active
[ 10.435146] systemd[1]: system-modprobe.slice: Job 52 system-modprobe.slice/start finished, result=done
[ 10.444563] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 10.467256] systemd[1]: system-serial\x2dgetty.slice changed dead -> active
[ 10.474351] systemd[1]: system-serial\x2dgetty.slice: Job 103 system-serial\x2dgetty.slice/start finished, result=done
[ 10.485064] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 10.507109] systemd[1]: user.slice changed dead -> active
[ 10.512633] systemd[1]: user.slice: Job 116 user.slice/start finished, result=done
[ 10.520229] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 10.541810] systemd[1]: systemd-ask-password-console.path: ConditionPathExists=!/run/plymouth/pid succeeded.
[ 10.552021] systemd[1]: systemd-ask-password-console.path: Changed dead -> waiting
[ 10.559633] systemd[1]: systemd-ask-password-console.path: Job 44 systemd-ask-password-console.path/start finished, result=done
[ 10.571119] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password 鈥s to Console Directory Watch.
[ 10.598052] systemd[1]: systemd-ask-password-wall.path: Changed dead -> waiting
[ 10.605445] systemd[1]: systemd-ask-password-wall.path: Job 124 systemd-ask-password-wall.path/start finished, result=done
[ 10.616507] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R鈥ests to Wall Directory Watch.
[ 10.641901] systemd[1]: proc-sys-fs-binfmt_misc.automount: ConditionPathIsReadWrite=/proc/sys succeeded.
[ 10.651497] systemd[1]: proc-sys-fs-binfmt_misc.automount: ConditionPathExists=/proc/sys/fs/binfmt_misc succeeded.
[ 10.662375] systemd[1]: Autofs kernel version 1.1
[ 10.667398] systemd[1]: Autofs protocol version 5.5
[ 10.672348] systemd[1]: proc-sys-fs-binfmt_misc.automount: Changed dead -> waiting
[ 10.679941] systemd[1]: proc-sys-fs-binfmt_misc.automount: Job 49 proc-sys-fs-binfmt_misc.automount/start finished, result=done
[ 10.691424] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ OK ] Set up automount Arbitrary鈥 File System Automount Point.
[ 10.717924] systemd[1]: cryptsetup.target changed dead -> active
[ 10.724001] systemd[1]: cryptsetup.target: Job 42 cryptsetup.target/start finished, result=done
[ 10.732716] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 10.753927] systemd[1]: slices.target changed dead -> active
[ 10.759648] systemd[1]: slices.target: Job 68 slices.target/start finished, result=done
[ 10.767669] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 10.785763] systemd[1]: swap.target changed dead -> active
[ 10.791307] systemd[1]: swap.target: Job 48 swap.target/start finished, result=done
[ 10.798982] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 10.820506] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 10.831672] systemd[1]: Successfully forked off '(sd-listen)' as PID 201.
[ 10.838715] systemd[1]: (sd-listen) succeeded.
[ 10.844376] systemd[1]: Successfully forked off '(sd-listen)' as PID 202.
[ 10.851485] systemd[1]: (sd-listen) succeeded.
[ 10.857174] systemd[1]: Successfully forked off '(sd-listen)' as PID 203.
[ 10.864271] systemd[1]: (sd-listen) succeeded.
[ 10.870006] systemd[1]: Successfully forked off '(sd-listen)' as PID 204.
[ 10.877090] systemd[1]: (sd-listen) succeeded.
[ 10.881769] systemd[1]: rpcbind.socket: Changed dead -> listening
[ 10.887908] systemd[1]: rpcbind.socket: Job 66 rpcbind.socket/start finished, result=done
[ 10.896101] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 10.922489] systemd[1]: syslog.socket: Changed dead -> listening
[ 10.928581] systemd[1]: syslog.socket: Job 80 syslog.socket/start finished, result=done
[ 10.936607] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 10.958440] systemd[1]: systemd-fsckd.socket: Changed dead -> listening
[ 10.965140] systemd[1]: systemd-fsckd.socket: Job 16 systemd-fsckd.socket/start finished, result=done
[ 10.974380] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 10.998169] systemd[1]: systemd-initctl.socket: Changed dead -> listening
[ 11.005059] systemd[1]: systemd-initctl.socket: Job 67 systemd-initctl.socket/start finished, result=done
[ 11.014709] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 11.037949] systemd[1]: /proc/self/uid_map has a full 1:1 mapping
[ 11.044213] systemd[1]: /proc/self/gid_map has a full 1:1 mapping
[ 11.050421] systemd[1]: /proc/self/setgroups contains "allow", not in user namespace
[ 11.058196] systemd[1]: systemd-journald-audit.socket: ConditionVirtualization=!private-users succeeded.
[ 11.067984] systemd[1]: systemd-journald-audit.socket: ConditionCapability=CAP_AUDIT_READ succeeded.
[ 11.077267] systemd[1]: systemd-journald-audit.socket: ConditionSecurity=audit succeeded.
[ 11.086038] systemd[1]: systemd-journald-audit.socket: Changed dead -> listening
[ 11.093492] systemd[1]: systemd-journald-audit.socket: Job 21 systemd-journald-audit.socket/start finished, result=done
[ 11.104287] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 11.126383] systemd[1]: systemd-journald-dev-log.socket: Changed dead -> listening
[ 11.134062] systemd[1]: systemd-journald-dev-log.socket: Job 20 systemd-journald-dev-log.socket/start finished, result=done
[ 11.145269] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 11.166538] systemd[1]: systemd-journald.socket: Changed dead -> listening
[ 11.173547] systemd[1]: systemd-journald.socket: Job 19 systemd-journald.socket/start finished, result=done
[ 11.183306] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 11.201915] systemd[1]: systemd-udevd-control.socket: ConditionPathIsReadWrite=/sys succeeded.
[ 11.211358] systemd[1]: systemd-udevd-control.socket: Changed dead -> listening
[ 11.218738] systemd[1]: systemd-udevd-control.socket: Job 32 systemd-udevd-control.socket/start finished, result=done
[ 11.229358] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 11.249841] systemd[1]: systemd-udevd-kernel.socket: ConditionPathIsReadWrite=/sys succeeded.
[ 11.258873] systemd[1]: systemd-udevd-kernel.socket: Changed dead -> listening
[ 11.266148] systemd[1]: systemd-udevd-kernel.socket: Job 31 systemd-udevd-kernel.socket/start finished, result=done
[ 11.276592] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 11.297942] systemd[1]: /proc/self/uid_map has a full 1:1 mapping
[ 11.304172] systemd[1]: /proc/self/gid_map has a full 1:1 mapping
[ 11.310354] systemd[1]: /proc/self/setgroups contains "allow", not in user namespace
[ 11.318114] systemd[1]: dev-hugepages.mount: ConditionVirtualization=!private-users succeeded.
[ 11.327003] systemd[1]: dev-hugepages.mount: ConditionCapability=CAP_SYS_ADMIN succeeded.
[ 11.335300] systemd[1]: dev-hugepages.mount: ConditionPathExists=/sys/kernel/mm/hugepages succeeded.
[ 11.346940] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.357297] systemd[1]: dev-hugepages.mount: About to execute: /bin/mount hugetlbfs /dev/hugepages -t hugetlbfs
[ 11.368414] systemd[1]: dev-hugepages.mount: Forked /bin/mount as 205
[ 11.375554] systemd[1]: dev-hugepages.mount: Changed dead -> mounting
[ 11.382312] systemd[1]: Mounting Huge Pages File System...
[ 11.402281] systemd[1]: dev-mqueue.mount: ConditionCapability=CAP_SYS_ADMIN succeeded.
[ 11.410502] systemd[1]: dev-mqueue.mount: ConditionPathExists=/proc/sys/fs/mqueue succeeded.
[ 11.422365] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.432956] systemd[1]: dev-mqueue.mount: About to execute: /bin/mount mqueue /dev/mqueue -t mqueue -o nosuid,nodev,noexec
[ 11.445180] systemd[1]: dev-mqueue.mount: Forked /bin/mount as 206
[ 11.452194] systemd[1]: dev-mqueue.mount: Changed dead -> mounting
[ 11.458702] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.484232] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.494650] systemd[1]: run-rpc_pipefs.mount: About to execute: /bin/mount sunrpc /run/rpc_pipefs -t rpc_pipefs
[ 11.505823] systemd[1]: run-rpc_pipefs.mount: Forked /bin/mount as 207
[ 11.512972] systemd[1]: run-rpc_pipefs.mount: Changed dead -> mounting
[ 11.519755] systemd[1]: Mounting RPC Pipe File System...
[ 11.538263] systemd[1]: sys-kernel-debug.mount: ConditionCapability=CAP_SYS_RAWIO succeeded.
[ 11.546909] systemd[1]: sys-kernel-debug.mount: ConditionPathExists=/sys/kernel/debug succeeded.
[ 11.558770] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.569390] systemd[1]: sys-kernel-debug.mount: About to execute: /bin/mount debugfs /sys/kernel/debug -t debugfs -o nosuid,nodev,noexec
[ 11.582814] systemd[1]: sys-kernel-debug.mount: Forked /bin/mount as 209
[ 11.583805] RPC: Registered named UNIX socket transport module.
[ 11.590197] systemd[1]: sys-kernel-debug.mount: Changed dead -> mounting
[ 11.595554] RPC: Registered udp transport module.
[ 11.602364] systemd[1]: Mounting Kernel Debug File System...
[ 11.606969] RPC: Registered tcp transport module.
[ 11.606973] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 11.638150] systemd[1]: sys-kernel-tracing.mount: ConditionCapability=CAP_SYS_RAWIO succeeded.
[ 11.646910] systemd[1]: sys-kernel-tracing.mount: ConditionPathExists=/sys/kernel/tracing failed.
[ 11.655802] systemd[1]: sys-kernel-tracing.mount: Starting requested but condition failed. Not starting unit.
[ 11.665732] systemd[1]: sys-kernel-tracing.mount: Job 24 sys-kernel-tracing.mount/start finished, result=done
[ 11.675655] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 11.686255] systemd[1]: bpf_devices_whitelist_device: /dev/null rwm
[ 11.692703] systemd[1]: bpf_devices_whitelist_device: /dev/zero rwm
[ 11.699076] systemd[1]: bpf_devices_whitelist_device: /dev/full rwm
[ 11.705427] systemd[1]: bpf_devices_whitelist_device: /dev/random rwm
[ 11.711951] systemd[1]: bpf_devices_whitelist_device: /dev/urandom rwm
[ 11.718558] systemd[1]: bpf_devices_whitelist_device: /dev/tty rwm
[ 11.724813] systemd[1]: bpf_devices_whitelist_device: /dev/ptmx rwm
[ 11.731168] systemd[1]: bpf_devices_whitelist_device: /run/systemd/inaccessible/chr rwm
[ 11.739249] systemd[1]: bpf_devices_whitelist_device: /run/systemd/inaccessible/blk rwm
[ 11.748271] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.759204] systemd[1]: systemd-journald.service: Passing 4 fds to service
[ 11.766219] systemd[1]: systemd-journald.service: About to execute: /lib/systemd/systemd-journald
[ 11.776087] systemd[1]: systemd-journald.service: Forked /lib/systemd/systemd-journald as 212
[ 11.779199] systemd[212]: systemd-journald.service: Failed to adjust Nice setting, assuming containerized execution, ignoring: Operation not permitted
[ 11.785475] systemd[1]: systemd-journald.service: Changed dead -> start
[ 11.799371] systemd[212]: Operating on architecture: arm
[ 11.804946] systemd[1]: Starting Journal Service...
Startin[ 11.815412] systemd[212]: Operating on architecture: arm64
g Journal Service..[ 11.823788] systemd[212]: Operating on architecture: arm
[ 11.831006] systemd[212]: Operating on architecture: arm64
[ 11.837109] systemd[212]: Operating on architecture: arm
[ 11.843108] systemd[212]: Operating on architecture: arm64
[ 11.843163] systemd[1]: keyboard-setup.service: ConditionPathExists=/bin/setupcon succeeded.
[ 11.858313] systemd[212]: Failed to add filter for chmod: Numerical argument out of domain
[ 11.859764] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 11.866856] systemd[212]: Failed to add filter for mkdir: Numerical argument out of domain
[ 11.876963] systemd[1]: keyboard-setup.service: Passing 0 fds to service
[ 11.885051] systemd[212]: Failed to add filter for mknod: Numerical argument out of domain
[ 11.891566] systemd[1]: keyboard-setup.service: About to execute: /lib/console-setup/keyboard-setup.sh
[ 11.899981] systemd[212]: Failed to add filter for creat: Numerical argument out of domain
[ 11.910194] systemd[1]: keyboard-setup.service: Forked /lib/console-setup/keyboard-setup.sh as 213
[ 11.917702] systemd[212]: Failed to add filter for chmod: Numerical argument out of domain
[ 11.927274] systemd[1]: keyboard-setup.service: Changed dead -> start
[ 11.934926] systemd[212]: Failed to add filter for mkdir: Numerical argument out of domain
[ 11.941164] systemd[1]: Starting Set the console keyboard layout...
[ 11.949593] systemd[212]: Failed to add filter for mknod: Numerical argument out of domain
Startin[ 11.964165] systemd[212]: Failed to add filter for creat: Numerical argument out of domain
g Set t[ 11.974730] systemd[212]: Restricting namespace to: n/a.
he console keybo[ 11.980835] systemd[212]: Operating on architecture: arm
ard layout..[ 11.981074] systemd[212]: Blocking cgroup.
[ 11.981282] systemd[212]: Blocking ipc.
[ 11.981472] systemd[212]: Blocking net.
[ 12.000934] systemd[212]: Blocking mnt.
[ 12.001159] systemd[212]: Blocking pid.
[ 12.001366] systemd[212]: Blocking user.
[ 12.009470] systemd[1]: kmod-static-nodes.service: ConditionFileNotEmpty=/lib/modules/5.19.4+/modules.devname succeeded.
[ 12.013316] systemd[212]: Blocking uts.
[ 12.024344] systemd[1]: kmod-static-nodes.service: ConditionCapability=CAP_SYS_MODULE succeeded.
[ 12.036921] systemd[212]: Operating on architecture: arm64
[ 12.037179] systemd[212]: Blocking cgroup.
[ 12.037457] systemd[212]: Blocking ipc.
[ 12.037784] systemd[212]: Blocking net.
[ 12.039338] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.039689] systemd[1]: kmod-static-nodes.service: Passing 0 fds to service
[ 12.039741] systemd[1]: kmod-static-nodes.service: About to execute: /bin/kmod static-nodes --format=tmpfiles --output=/run/tmpfiles.d/static-nodes.conf
[ 12.040786] systemd[1]: kmod-static-nodes.service: Forked /bin/kmod as 219
[ 12.042237] systemd[1]: kmod-static-nodes.service: Changed dead -> start
[ 12.042310] systemd[1]: Starting Create list of static device nodes for the current kernel...
Startin[ 12.107824] systemd[212]: Blocking mnt.
g Creat[ 12.113337] systemd[212]: Blocking pid.
e list of st鈥[ 12.113603] systemd[212]: Blocking user.
des for the curr[ 12.113844] systemd[212]: Blocking uts.
ent kernel..[ 12.129248] systemd[212]: Operating on architecture: arm
[ 12.145967] systemd[1]: modprobe@chromeos_pstore.service: ConditionPathExists=!/sys/module/chromeos_pstore succeeded.
[ 12.157241] systemd[1]: modprobe@chromeos_pstore.service: ConditionCapability=CAP_SYS_MODULE succeeded.
[ 12.170344] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.180954] systemd[1]: modprobe@chromeos_pstore.service: Passing 0 fds to service
[ 12.181838] systemd[212]: Operating on architecture: arm64
[ 12.188680] systemd[1]: modprobe@chromeos_pstore.service: About to execute: /sbin/modprobe -abq chromeos_pstore
[ 12.205491] systemd[1]: modprobe@chromeos_pstore.service: Forked /sbin/modprobe as 225
[ 12.214918] systemd[1]: modprobe@chromeos_pstore.service: Changed dead -> start
[ 12.222555] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.245972] systemd[1]: modprobe@drm.service: ConditionPathExists=!/sys/module/drm failed.
[ 12.254579] systemd[1]: modprobe@drm.service: Starting requested but condition failed. Not starting unit.
[ 12.264386] systemd[1]: modprobe@drm.service: Job 115 modprobe@drm.service/start finished, result=done
[ 12.273900] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.275758] systemd-journald[212]: Found cgroup2 on /sys/fs/cgroup/unified, unified hierarchy for systemd controller
[ 12.282409] systemd[1]: modprobe@efi_pstore.service: ConditionPathExists=!/sys/module/efi_pstore succeeded.
[ 12.303041] systemd[1]: modprobe@efi_pstore.service: ConditionCapability=CAP_SYS_MODULE succeeded.
[ 12.304654] systemd-journald[212]: Journal effective settings seal=no compress=yes compress_threshold_bytes=512B
[ 12.314734] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.322778] systemd-journald[212]: Fixed min_use=1.9M max_use=9.8M max_size=1.2M min_size=512.0K keep_free=4.9M n_max_files=100
[ 12.332703] systemd[1]: modprobe@efi_pstore.service: Passing 0 fds to service
[ 12.345278] systemd-journald[212]: Reserving 2240 entries in hash table.
[ 12.350927] systemd[1]: modprobe@efi_pstore.service: About to execute: /sbin/modprobe -abq efi_pstore
[ 12.358002] systemd-journald[212]: Vacuuming...
[ 12.367910] systemd[1]: modprobe@efi_pstore.service: Forked /sbin/modprobe as 226
[ 12.371585] systemd-journald[212]: Vacuuming done, freed 0B of archived journals from /run/log/journal/142041ee16a4445a949c973367138ba9.
[ 12.379631] systemd[1]: modprobe@efi_pstore.service: Changed dead -> start
[ 12.391397] systemd-journald[212]: Flushing /dev/kmsg...
[ 12.398238] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.403546] systemd-journald[212]: systemd-journald running as PID 212 for the system.
[ 12.437923] systemd[1]: modprobe@pstore_blk.service: ConditionPathExists=!/sys/module/pstore_blk succeeded.
[ 12.446960] systemd-journald[212]: Sent READY=1 notification.
[ 12.448139] systemd[1]: modprobe@pstore_blk.service: ConditionCapability=CAP_SYS_MODULE succeeded.
[ 12.456086] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.464658] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.473478] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.481494] systemd[1]: modprobe@pstore_blk.service: Passing 0 fds to service
[ 12.492113] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.497010] systemd[1]: modprobe@pstore_blk.service: About to execute: /sbin/modprobe -abq pstore_blk
[ 12.507972] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.515948] systemd[1]: modprobe@pstore_blk.service: Forked /sbin/modprobe as 227
[ 12.526954] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.532096] systemd[1]: modprobe@pstore_blk.service: Changed dead -> start
[ 12.542494] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.547153] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.558246] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
Starting Load [ 12.572265] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.585021] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.609854] systemd[1]: modprobe@pstore_zone.service: ConditionPathExists=!/sys/module/pstore_zone failed.
[ 12.619629] systemd[1]: modprobe@pstore_zone.service: Starting requested but condition failed. Not starting unit.
[ 12.629926] systemd[1]: modprobe@pstore_zone.service: Job 53 modprobe@pstore_zone.service/start finished, result=done
[ 12.640561] systemd[1]: Condition check resulted in Load Kernel Module pstore_zone being skipped.
[ 12.649664] systemd[1]: modprobe@ramoops.service: ConditionPathExists=!/sys/module/ramoops succeeded.
[ 12.659318] systemd[1]: modprobe@ramoops.service: ConditionCapability=CAP_SYS_MODULE succeeded.
[ 12.670493] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.680847] systemd[1]: modprobe@ramoops.service: Passing 0 fds to service
[ 12.687835] systemd[1]: modprobe@ramoops.service: About to execute: /sbin/modprobe -abq ramoops
[ 12.697572] systemd[1]: modprobe@ramoops.service: Forked /sbin/modprobe as 228
[ 12.701157] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.706045] systemd[1]: modprobe@ramoops.service: Changed dead -> start
[ 12.720468] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.748175] systemd[1]: Failed to read pids.max attribute of cgroup root, ignoring: No such file or directory
[ 12.758558] systemd[1]: resolvconf.service: Passing 0 fds to service
[ 12.765012] systemd[1]: resolvconf.service: About to execute: /sbin/resolvconf --enable-updates
[ 12.774784] systemd[1]: resolvconf.service: Forked /sbin/resolvconf as 229
[ 12.778225] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
[ 12.782686] systemd[1]: resolvconf.service: Changed dead -> running
[ 12.796899] systemd[1]: resolvconf.service: Job 60 resolvconf.service/start finished, result=done
[ 12.805900] systemd[1]: Started Nameserver information manager.
[ OK ] Started Nameserver information manager.
[ 12.830479] systemd[1]: network-pre.target changed dead -> active
[ 12.836664] systemd[1]: network-pre.target: Job 61 network-pre.target/start finished, result=done
[ 12.845592] systemd[1]: Reached target Network (Pre).
[ OK ] Reached target Network (Pre).
[ 12.866057] systemd[1]: systemd-binfmt.service: ConditionDirectoryNotEmpty=|/run/binfmt.d failed.
[ 12.876076] systemd[1]: systemd-binfmt.service: ConditionDirectoryNotEmpty=|/etc/binfmt.d failed.
[ 12.885116] systemd[1]: systemd-binfmt.service: ConditionDirectoryNotEmpty=|/usr/local/lib/binfmt.d failed.
[ 12.895922] systemd[1]: systemd-binfmt.service: ConditionDirectoryNotEmpty=|/usr/lib/binfmt.d failed.
[ 12.905356] systemd[1]: systemd-binfmt.service: ConditionDirectoryNotEmpty=|/lib/binfmt.d failed.
[ 12.914315] systemd[1]: systemd-binfmt.service: ConditionPathIsReadWrite=/proc/sys succeeded.
[ 12.922864] systemd[1]: systemd-binfmt.service: Starting requested but condition failed. Not starting unit.
[ 12.932638] systemd[1]: systemd-binfmt.service: Job 39 systemd-binfmt.service/start finished, result=done
[ 12.942226] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Starting Load [ 12.961196] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
Kernel Modules...
Starting Remou[ 12.989431] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
nt Root and Kernel File Systems...
Starting udev [ 13.021130] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
Coldplug all Dev[ 13.021879] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
ices...
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted RPC Pipe File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Finished Set the console keyboard layout.
[ OK ] Finished Create list of st鈥?nodes for the current kernel.
[ OK ] Finished Load Kernel Module chromeos_pstore.
[ OK ] Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module pstore_blk.
[ OK ] Finished Load Kernel Module ramoops.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Remount Root and Kernel File Systems.
[ 13.325493] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
Mounting Kernel Conffiguration [ 13.339215] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
File System...
Starting Flush[ 13.379925] systemd-journald[212]: Successfully sent stream file descriptor to service manager.
Journal to Persistent Storage...
[ 13.408160] systemd-journald[212]: n/a: New incoming connection.
[ 13.414405] systemd-journald[212]: varlink-20: varlink: setting state idle-server
Starting Load/Save Random Seed...
[ 13.426187] systemd-journald[212]: varlink-20: New incoming message: {"method":"io.systemd.Journal.FlushToVar","parameters":{}}
[ 13.438745] systemd-journald[212]: varlink-20: varlink: changing state idle-server 鈫?processing-method
[ 13.448424] systemd-journald[212]: Received client request to flush runtime journal.
[ 13.458367] systemd-journald[212]: Journal effective settings seal=yes compress=yes compress_threshold_bytes=512B
[ 113.475765] systemd-journald[212]: Journal file /var/log/journal/142041ee16a4445a949c973367138ba9/system.journal is already online. Assuming unclean closing.
Starting Create System Users...
[ 13.515696] systemd-journald[212]: File /var/log/journal/142041ee16a4445a949c973367138ba9/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ OK 13.531618] systemd-journald[212]: Fixed min_use=16.0M max_use=98.9M max_size=12.3M min_size=512.0K keep_free=49.4M n_max_files=100
0m] Mounted Kernel Configuration File System.
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished udev Coldplug all Devices.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Found device /dev/ttyS0.
[ 14.875052] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 14.884411] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 14.941037] debugfs: Directory '1100000.mixer' with parent 'regmap' already present!
[ 14.948992] debugfs: Directory '1100000.mixer' with parent 'regmap' already present!
