系统存在nor, 我现在作的是开机自启动脚本运行sd卡里面的程序, 那个程序用dfbshow显示一张图, 现在启动时间是30s左右
启动的log如下. 9s到30多秒之间也不知道在干嘛, 没有啥输出. 请问怎么优化启动时间
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 61CC0487)
root@TinaLinux:/# ** 15 printk messages dropped **
/bin/ash: bin: not found
root@TinaLinux:/# [ 0.000000] pcpu-alloc: [0] 0
ash: missing ]
root@TinaLinux:/# [ 0.000000] Built 1 zonelists, mobility grouping on. Total
pages: 16160
ash: missing ]
root@TinaLinux:/# [ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x0
2500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=
/dev/mtdblock5 rootfstype=squashfs init=/sbin/init partitions=boot-resource@mtdb
lock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@m
tdblock6 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.
hardware=sun20iw1p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018
.05-g24521d6(02/11/2022-08:52:39) mbr_offset=155
/bin/ash: syntax error: unexpected "("
root@TinaLinux:/# [ 0.000000] Dentry cache hash table entries: 8192 (order: 4
, 65536 bytes, linear)
root@TinaLinux:/# [ 0.000000] Inode-cache hash table entries: 4096 (order: 3,
32768 bytes, linear)
root@TinaLinux:/# [ 0.000000] Sorting __ex_table...
ash: missing ]
root@TinaLinux:/# [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap
free:off
ash: missing ]
root@TinaLinux:/# [ 0.000000] Memory: 48876K/65536K available (4380K kernel c
ode, 418K rwdata, 1740K rodata, 144K init, 235K bss, 8468K reserved, 8192K cma-r
eserved)
root@TinaLinux:/# [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs
=1, Nodes=1
ash: missing ]
root@TinaLinux:/# [ 0.000000] rcu: Preemptible hierarchical RCU implementatio
n.
ash: missing ]
root@TinaLinux:/# [ 0.000000] Tasks RCU enabled.
ash: missing ]
root@TinaLinux:/# [ 0.000000] rcu: RCU calculated value of scheduler-enlistme
nt delay is 10 jiffies.
ash: missing ]
root@TinaLinux:/# [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
ash: missing ]
root@TinaLinux:/# [ 0.000000] plic: mapped 200 interrupts with 1 handlers for
2 contexts.
ash: missing ]
root@TinaLinux:/# [ 0.000000] riscv_timer_init_dt: Registering clocksource cp
uid [0] hartid [0]
ash: missing ]
root@TinaLinux:/# [ 0.000000] clocksource: riscv_clocksource: mask: 0xfffffff
fffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
ash: missing ]
root@TinaLinux:/# [ 0.000007] sched_clock: 64 bits at 24MHz, resolution 41ns,
wraps every 4398046511097ns
ash: missing ]
root@TinaLinux:/# [ 0.000025] riscv_timer_clockevent depends on broadcast, bu
t no broadcast function available
ash: missing ]
root@TinaLinux:/# [ 0.000365] clocksource: timer: mask: 0xffffffff max_cycles
: 0xffffffff, max_idle_ns: 79635851949 ns
ash: missing ]
root@TinaLinux:/# [ 0.001051] Console: colour dummy device 80x25
ash: missing ]
root@TinaLinux:/# [ 0.001098] Calibrating delay loop (skipped), value calcula
ted using timer frequency.. 48.00 BogoMIPS (lpj=240000)
root@TinaLinux:/# [ 0.001115] pid_max: default: 32768 minimum: 301
ash: missing ]
root@TinaLinux:/# [ 0.001306] Mount-cache hash table entries: 512 (order: 0,
4096 bytes, linear)
root@TinaLinux:/# [ 0.001325] Mountpoint-cache hash table entries: 512 (order
: 0, 4096 bytes, linear)
root@TinaLinux:/# [ 0.003447] ASID allocator initialised with 65536 entries
ash: missing ]
root@TinaLinux:/# [ 0.003646] rcu: Hierarchical SRCU implementation.
ash: missing ]
root@TinaLinux:/# [ 0.004385] devtmpfs: initialized
ash: missing ]
root@TinaLinux:/# [ 0.018608] random: get_random_u32 called from bucket_table
_alloc.isra.27+0xfe/0x120 with crng_init=0
ash: missing ]
root@TinaLinux:/# [ 0.019555] clocksource: jiffies: mask: 0xffffffff max_cycl
es: 0xffffffff, max_idle_ns: 19112604462750000 ns
ash: missing ]
root@TinaLinux:/# [ 0.019589] futex hash table entries: 256 (order: 0, 6144 b
ytes, linear)
root@TinaLinux:/# [ 0.020233] pinctrl core: initialized pinctrl subsystem
ash: missing ]
root@TinaLinux:/# [ 0.021697] NET: Registered protocol family 16
ash: missing ]
root@TinaLinux:/# [ 0.023753] DMA: preallocated 256 KiB pool for atomic alloc
ations
ash: missing ]
root@TinaLinux:/# [ 0.024470] cpuidle: using governor menu
ash: missing ]
root@TinaLinux:/# [ 0.070414] rtc_ccu: sunxi ccu init OK
ash: missing ]
root@TinaLinux:/# [ 0.078251] clock: sunxi ccu init OK
ash: missing ]
root@TinaLinux:/# [ 0.079314] clock: sunxi ccu init OK
ash: missing ]
root@TinaLinux:/# [ 0.115356] iommu: Default domain type: Translated
ash: missing ]
root@TinaLinux:/# [ 0.115574] sunxi iommu: irq = 4
ash: missing ]
root@TinaLinux:/# [ 0.116823] SCSI subsystem initialized
ash: missing ]
root@TinaLinux:/# [ 0.117053] usbcore: registered new interface driver usbfs
ash: missing ]
root@TinaLinux:/# [ 0.117144] usbcore: registered new interface driver hub
ash: missing ]
root@TinaLinux:/# [ 0.117265] usbcore: registered new device driver usb
ash: missing ]
root@TinaLinux:/# [ 0.117435] videodev: Linux video capture interface: v2.00
ash: missing ]
root@TinaLinux:/# [ 0.118434] Advanced Linux Sound Architecture Driver Initia
lized.
ash: missing ]
root@TinaLinux:/# [ 0.119111] Bluetooth: Core ver 2.22
ash: missing ]
root@TinaLinux:/# [ 0.119201] NET: Registered protocol family 31
ash: missing ]
root@TinaLinux:/# [ 0.119212] Bluetooth: HCI device and connection manager in
itialized
ash: missing ]
root@TinaLinux:/# [ 0.119236] Bluetooth: HCI socket layer initialized
ash: missing ]
root@TinaLinux:/# [ 0.119258] Bluetooth: L2CAP socket layer initialized
ash: missing ]
root@TinaLinux:/# [ 0.119290] pwm module init!
ash: missing ]
root@TinaLinux:/# [ 0.121143] g2d 5410000.g2d: Adding to iommu group 0
ash: missing ]
root@TinaLinux:/# [ 0.121722] G2D: rcq version initialized.major:252
ash: missing ]
root@TinaLinux:/# [ 0.122635] clocksource: Switched to clocksource riscv_cloc
ksource
ash: missing ]
root@TinaLinux:/# [ 0.136605] sun8iw20-pinctrl 2000000.pinctrl: initialized s
unXi PIO driver
ash: missing ]
root@TinaLinux:/# [ 0.155365] NET: Registered protocol family 2
ash: missing ]
root@TinaLinux:/# [ 0.156283] tcp_listen_portaddr_hash hash table entries: 25
6 (order: 0, 4096 bytes, linear)
root@TinaLinux:/# [ 0.156330] TCP established hash table entries: 512 (order:
root@TinaLinux:/# [ 0.156352] TCP bind hash table entries: 512 (order: 0, 409
6 bytes, linear)
root@TinaLinux:/# [ 0.156366] TCP: Hash tables configured (established 512 bi
nd 512)
root@TinaLinux:/# [ 0.156534] UDP hash table entries: 256 (order: 1, 8192 byt
es, linear)
root@TinaLinux:/# [ 0.156579] UDP-Lite hash table entries: 256 (order: 1, 819
2 bytes, linear)
root@TinaLinux:/# [ 0.156852] NET: Registered protocol family 1
ash: missing ]
root@TinaLinux:/# [ 0.158173] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinct
rl supply vcc-pc not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 0.158783] spi spi0: spi0 supply spi not found, using dumm
y regulator
ash: missing ]
root@TinaLinux:/# [ 0.159118] sunxi_spi_resource_get()2151 - [spi0] SPI MASTE
R MODE
root@TinaLinux:/# [ 0.159188] sunxi_spi_resource_get()2189 - Failed to get sa
mple mode
root@TinaLinux:/# [ 0.159197] sunxi_spi_resource_get()2194 - Failed to get sa
mple delay
root@TinaLinux:/# [ 0.159206] sunxi_spi_resource_get()2198 - sample_mode:-143
1633921 sample_delay:-1431633921
root@TinaLinux:/# [ 0.159333] sunxi_spi_clk_init()2240 - [spi0] mclk 80000000
root@TinaLinux:/# [ 0.160140] sunxi_spi_probe()2653 - [spi0]: driver probe su
cceed, base ffffffd004058000, irq 31
root@TinaLinux:/# [ 0.162388] workingset: timestamp_bits=62 max_order=14 buck
et_order=0
ash: missing ]
root@TinaLinux:/# [ 0.168490] squashfs: version 4.0 (2009/01/31) Phillip Loug
her
root@TinaLinux:/# [ 0.168734] ntfs: driver 2.1.32 [Flags: R/W].
ash: missing ]
root@TinaLinux:/# [ 0.169046] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2
006 Red Hat, Inc.
root@TinaLinux:/# [ 0.189521] io scheduler mq-deadline registered
ash: missing ]
root@TinaLinux:/# [ 0.189536] io scheduler kyber registered
ash: missing ]
root@TinaLinux:/# [ 0.190755] [DISP]disp_module_init
ash: missing ]
root@TinaLinux:/# [ 0.191371] disp 5000000.disp: Adding to iommu group 0
ash: missing ]
root@TinaLinux:/# [ 0.220439] disp 5000000.disp: 5000000.disp supply vcc-lcd
ash: missing ]
root@TinaLinux:/# [ 0.233995] display_fb_request,fb_id:0
ash: missing ]
root@TinaLinux:/# [ 0.308338] [DISP] Fb_copy_boot_fb,line:1443:
ash: missing ]
root@TinaLinux:/# [ 0.308342] no boot_fb0
ash: missing ]
root@TinaLinux:/# [ 0.308844] disp_al_manager_apply ouput_type:0
ash: missing ]
root@TinaLinux:/# [ 0.309105] [DISP] lcd_clk_config,line:732:
ash: missing ]
root@TinaLinux:/# [ 0.309118] disp 0, clk: pll(1050000000),clk(1050000000),dc
lk(150000000) dsi_rate(1050000000)
root@TinaLinux:/# [ 0.309118] clk real:pll(1044000000),clk(1044000000),d
clk(149142857) dsi_rate(0)
root@TinaLinux:/# [ 0.309151] [DISP] disp_sys_pwm_config,line:509:
ash: missing ]
root@TinaLinux:/# [ 0.309154] disp_sys_pwm_Config, handle is NULL!
ash: missing ]
root@TinaLinux:/# [ 0.309163] [DISP] disp_sys_pwm_set_polarity,line:528:
ash: missing ]
root@TinaLinux:/# [ 0.309167] disp_sys_pwm_Set_Polarity, handle is NULL!
ash: missing ]
root@TinaLinux:/# [ 0.310565] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinct
rl supply vcc-pd not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 0.311375] [DISP]disp_module_init finish
ash: missing ]
root@TinaLinux:/# [ 0.312328] sunxi_sid_init()551 - insmod ok
root@TinaLinux:/# [ 0.313010] pwm-regulator: supplied by regulator-dummy
ash: missing ]
root@TinaLinux:/# [ 0.314919] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinct
rl supply vcc-pe not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 0.315411] uart uart0: get regulator failed
ash: missing ]
root@TinaLinux:/# [ 0.315441] uart uart0: uart0 supply uart not found, using
dummy regulator
ash: missing ]
root@TinaLinux:/# [ 0.315808] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_
baud = 1500000) is a SUNXI
root@TinaLinux:/# [ 0.315836] sw_console_setup()1808 - console setup baud 115
200 parity n bits 8, flow n
root@TinaLinux:/# [ 0.557508] [DISP] disp_lcd_pwm_enable,line:1231:
ash: missing ]
root@TinaLinux:/# [ 0.557513] pwm device hdl is NULL
ash: missing ]
root@TinaLinux:/# [ 0.557522] [DISP] disp_device_attached_and_enable,line:233
ash: missing ]
root@TinaLinux:/# [ 0.557526] attached ok, mgr0<-->dev0
/bin/ash: can't open --: no such file
root@TinaLinux:/# [ 0.557528] [DISP] disp_device_attached_and_enable,line:236
ash: missing ]
root@TinaLinux:/# [ 0.557538] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dv
i_hdmi:2, range:2 scan:0 ratio:8
ash: missing ]
root@TinaLinux:/# [ 1.069681] printk: console [ttyS0] enabled
ash: missing ]
root@TinaLinux:/# [ 1.075339] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinct
rl supply vcc-pg not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 1.086986] uart uart1: get regulator failed
ash: missing ]
root@TinaLinux:/# [ 1.091765] uart uart1: uart1 supply uart not found, using
dummy regulator
ash: missing ]
root@TinaLinux:/# [ 1.099927] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_
root@TinaLinux:/# [ 1.109830] uart uart5: get regulator failed
ash: missing ]
root@TinaLinux:/# [ 1.114669] uart uart5: uart5 supply uart not found, using
dummy regulator
ash: missing ]
root@TinaLinux:/# [ 1.122871] uart5: ttyS5 at MMIO 0x2501400 (irq = 23, base_
root@TinaLinux:/# [ 1.133045] misc dump reg init
ash: missing ]
root@TinaLinux:/# [ 1.137835] [ADDR_MGT] addr_mgt_probe: module version: v1.0
.10
ash: missing ]
root@TinaLinux:/# [ 1.145710] [ADDR_MGT] addr_mgt_probe: success.
ash: missing ]
root@TinaLinux:/# [ 1.153035] spi-nor spi0.0: w25q256jweiq (32768 Kbytes)
root@TinaLinux:/# [ 1.160279] 7 sunxipart partitions found on MTD device spi0
.0
ash: missing ]
root@TinaLinux:/# [ 1.166833] Creating 7 MTD partitions on "spi0.0":
ash: missing ]
root@TinaLinux:/# [ 1.172190] 0x000000000000-0x000000180000 : "uboot"
ash: missing ]
root@TinaLinux:/# [ 1.183605] 0x000000180000-0x0000001a0000 : "boot-resource"
ash: missing ]
root@TinaLinux:/# [ 1.203550] 0x0000001a0000-0x0000001c0000 : "env"
ash: missing ]
root@TinaLinux:/# [ 1.223531] 0x0000001c0000-0x0000001e0000 : "env-redund"
ash: missing ]
root@TinaLinux:/# [ 1.243560] 0x0000001e0000-0x000000960000 : "boot"
ash: missing ]
root@TinaLinux:/# [ 1.263551] 0x000000960000-0x000001400000 : "rootfs"
ash: missing ]
root@TinaLinux:/# [ 1.283540] 0x000001400000-0x000002000000 : "UDISK"
ash: missing ]
root@TinaLinux:/# [ 1.303734] ehci_hcd: USB 2.0 'Enhanced' Host Controller (E
HCI) Driver
root@TinaLinux:/# [ 1.311016] sunxi-ehci: EHCI SUNXI driver
ash: missing ]
root@TinaLinux:/# [ 1.316293] get ehci1-controller wakeup-source is fail.
ash: missing ]
root@TinaLinux:/# [ 1.322240] sunxi ehci1-controller don't init wakeup source
> [ 1.328514] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sun
xi_ehci: 0xffffffe0006b30d0, 0x:ffffffd004078000, irq_no:31
> [ 1.342107] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller s
upply drvvbus not found, using dummy regulator
> [ 1.354774] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller s
upply hci not found, using dummy regulator
> [ 1.367130] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
> [ 1.374423] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, as
signed bus number 1
> [ 1.384383] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
> [ 1.412701] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
> [ 1.421736] hub 1-0:1.0: USB hub found
> [ 1.426100] hub 1-0:1.0: 1 port detected
> [ 1.431528] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
> [ 1.438556] sunxi-ohci: OHCI SUNXI driver
> [ 1.443786] get ohci1-controller wakeup-source is fail.
> [ 1.449783] sunxi ohci1-controller don't init wakeup source
ash: missing ]
root@TinaLinux:/# [ 1.456057] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1
-controller, sunxi_ohci: 0xffffffe0006b3498
ash: missing ]
root@TinaLinux:/# [ 1.466560] sunxi-ohci 4200400.ohci1-controller: 4200400.oh
ci1-controller supply drvvbus not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 1.479154] sunxi-ohci 4200400.ohci1-controller: 4200400.oh
ci1-controller supply hci not found, using dummy regulator
ash: missing ]
root@TinaLinux:/# [ 1.491519] sunxi-ohci 4200400.ohci1-controller: OHCI Host
Controller
ash: missing ]
root@TinaLinux:/# [ 1.498866] sunxi-ohci 4200400.ohci1-controller: new USB bu
s registered, assigned bus number 2
ash: missing ]
root@TinaLinux:/# [ 1.508704] sunxi-ohci 4200400.ohci1-controller: irq 50, io
mem 0x04200400
ash: missing ]
root@TinaLinux:/# [ 1.587879] hub 2-0:1.0: USB hub found
ash: missing ]
root@TinaLinux:/# [ 1.592135] hub 2-0:1.0: 1 port detected
ash: missing ]
root@TinaLinux:/# [ 1.598404] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_re
g_default_value(): ALARM0_DAY_REG=0, set it to 1
root@TinaLinux:/# [ 1.610915] sunxi-rtc 7090000.rtc: registered as rtc0
ash: missing ]
root@TinaLinux:/# [ 1.616816] sunxi-rtc 7090000.rtc: setting system clock to
1970-01-01T00:00:03 UTC (3)
root@TinaLinux:/# [ 1.625717] sunxi-rtc 7090000.rtc: sunxi rtc probed
ash: missing ]
root@TinaLinux:/# [ 1.631719] i2c /dev entries driver
ash: missing ]
root@TinaLinux:/# [ 1.635727] IR NEC protocol handler initialized
ash: missing ]
root@TinaLinux:/# [ 1.644083] usbcore: registered new interface driver uvcvid
eo
ash: missing ]
root@TinaLinux:/# [ 1.650522] USB Video Class driver (1.1.1)
root@TinaLinux:/# [ 1.655136] sunxi cedar version 1.1
ash: missing ]
root@TinaLinux:/# [ 1.659376] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
ash: missing ]
root@TinaLinux:/# [ 1.665749] VE: install start!!!
ash: missing ]
ash: missing ]
root@TinaLinux:/# [ 1.671372] VE: cedar-ve the get irq is 6
ash: missing ]
ash: missing ]
root@TinaLinux:/# [ 1.677834] VE: ve_debug_proc_info:(____ptrval____), data:(
____ptrval____), lock:(____ptrval____)
ash: missing ]
root@TinaLinux:/# [ 1.689477] VE: install end!!!
ash: missing ]
ash: missing ]
root@TinaLinux:/# [ 1.694548] VE: sunxi_cedar_probe
ash: missing ]
root@TinaLinux:/# [ 1.698558] Bluetooth: HCI UART driver ver 2.3
ash: missing ]
root@TinaLinux:/# [ 1.703770] Bluetooth: HCI UART protocol H4 registered
ash: missing ]
root@TinaLinux:/# [ 1.709497] Bluetooth: HCI UART protocol BCSP registered
ash: missing ]
root@TinaLinux:/# [ 1.715516] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver
1.0.10
ash: missing ]
root@TinaLinux:/# [ 1.722919] [XR_BT_LPM] bluesleep_probe: bt_wake polarity:
1
ash: missing ]
root@TinaLinux:/# [ 1.729330] [XR_BT_LPM] bluesleep_probe: host_wake polarity
: 1
ash: missing ]
root@TinaLinux:/# [ 1.735923] [XR_BT_LPM] bluesleep_probe: wakeup source is d
isabled!
ash: missing ]
ash: missing ]
root@TinaLinux:/# [ 1.744592] [XR_BT_LPM] bluesleep_probe: uart_index(1)
root@TinaLinux:/# [ 1.753667] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Contr
oller Driver(v4.21 2021-11-18 10:02)
root@TinaLinux:/# [ 1.763781] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
ash: missing ]
root@TinaLinux:/# [ 1.769949] sunxi-mmc 4020000.sdmmc: No vmmc regulator foun
d
ash: missing ]
root@TinaLinux:/# [ 1.776304] sunxi-mmc 4020000.sdmmc: No vqmmc regulator fou
nd
ash: missing ]
root@TinaLinux:/# [ 1.782793] sunxi-mmc 4020000.sdmmc: No vdmmc regulator fou
nd
ash: missing ]
root@TinaLinux:/# [ 1.789199] sunxi-mmc 4020000.sdmmc: No vd33sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.795764] sunxi-mmc 4020000.sdmmc: No vd18sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.802264] sunxi-mmc 4020000.sdmmc: No vq33sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.808787] sunxi-mmc 4020000.sdmmc: No vq18sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.815954] sunxi-mmc 4020000.sdmmc: Got CD GPIO
ash: missing ]
root@TinaLinux:/# [ 1.821449] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fa
il
ash: missing ]
root@TinaLinux:/# [ 1.828189] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm
PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
root@TinaLinux:/# [ 1.839396] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if ther
e is regulator
ash: missing ]
root@TinaLinux:/# [ 1.859593] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000
Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
root@TinaLinux:/# [ 1.884113] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
ash: missing ]
root@TinaLinux:/# [ 1.889789] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000
root@TinaLinux:/# [ 1.902262] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Contr
root@TinaLinux:/# [ 1.912389] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
ash: missing ]
root@TinaLinux:/# [ 1.918758] sunxi-mmc 4021000.sdmmc: No vmmc regulator foun
d
ash: missing ]
root@TinaLinux:/# [ 1.925139] sunxi-mmc 4021000.sdmmc: No vqmmc regulator fou
nd
ash: missing ]
root@TinaLinux:/# [ 1.931623] sunxi-mmc 4021000.sdmmc: No vdmmc regulator fou
nd
ash: missing ]
root@TinaLinux:/# [ 1.938088] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000
root@TinaLinux:/# [ 1.949704] sunxi-mmc 4021000.sdmmc: No vd33sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.956249] sunxi-mmc 4021000.sdmmc: No vd18sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.962943] sunxi-mmc 4021000.sdmmc: No vq33sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.969492] sunxi-mmc 4021000.sdmmc: No vq18sw regulator fo
und
ash: missing ]
root@TinaLinux:/# [ 1.976012] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 8, R
TO !!
ash: missing ]
root@TinaLinux:/# [ 1.982888] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs
pinstate,check if needed
> [ 1.991921] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
> [ 2.004584] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21
> [ 2.015842] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
> [ 2.024793] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
> [ 2.036419] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
> [ 2.060802] sunxi-mmc 4021000.sdmmc: detmode:manually by software
> [ 2.068524] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
> [ 2.075824] ashmem: initialized
> [ 2.079354] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
> [ 2.086272] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
> [ 2.103245] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
> [ 2.115879] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lin
eout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
> [ 2.115879]
> [ 2.133072] mmc0: host does not support reading read-only switch, assuming
write-enable
> [ 2.142224] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adch
pf_cfg:1, dacdrc_cfg:0, dachpf:0
> [ 2.153221] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON v
dd 21 width 1 timing SD-HS(SDR25) dt B
> [ 2.165374] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe fini
shed
> [ 2.173549] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
> [ 2.180496] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON
vdd 21 width 1 timing SD-HS(SDR25) dt B
> [ 2.192147] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
> [ 2.199803] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
> [ 2.207406] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
> [ 2.214223] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0
> [ 2.225539] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON
vdd 21 width 4 timing SD-HS(SDR25) dt B
> [ 2.237353] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocod
ec' already present!
> [ 2.247378] mmc0: new high speed SD card at address 0001
> [ 2.253453] [SNDCODEC][sunxi_card_init][583]:card init finished
> [ 2.263646] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.du
mmy_cpudai mapping ok
> [ 2.274782] mmcblk0: mmc0:0001 asdfg 480 MiB
> [ 2.284454] mmcblk0: p1
> [ 2.289150] input: audiocodec sunxi Audio Jack as /devices/platform/soc@300
0000/2030340.sound/sound/card0/input0
> [ 2.301544] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
> [ 2.311416] NET: Registered protocol family 10
> [ 2.318257] Segment Routing with IPv6
> [ 2.322566] NET: Registered protocol family 17
> [ 2.356565] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using du
mmy regulator
> [ 2.372623] sunxi-i2c sunxi-i2c2: probe success
> [ 2.379928] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb
> [ 2.394696] get ehci0-controller wakeup-source is fail.
> [ 2.400642] sunxi ehci0-controller don't init wakeup source
ash: missing ]
root@TinaLinux:/# [ 2.406922] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0
-controller, sunxi_ehci: 0xffffffe0006b2940, 0x:ffffffd0054dd000, irq_no:2e
ash: missing ]
root@TinaLinux:/# [ 2.420479] [sunxi-ehci0]: Not init ehci0
ash: missing ]
root@TinaLinux:/# [ 2.425588] get ohci0-controller wakeup-source is fail.
ash: missing ]
root@TinaLinux:/# [ 2.431584] sunxi ohci0-controller don't init wakeup source
> [ 2.437853] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sun
xi_ohci: 0xffffffe0006b2d08
> [ 2.448301] [sunxi-ohci0]: Not init ohci0
> [ 2.457308] clk: Not disabling unused clocks
> [ 2.462113] ALSA device list:
> [ 2.466701] platform regulatory.0: Direct firmware load for regulatory.db f
ailed with error -2
> [ 2.476455] #0: audiocodec
> [ 2.479687] alloc_fd: slot 0 not NULL!
> [ 2.483952] cfg80211: failed to load regulatory.db
> [ 2.496513] VFS: Mounted root (squashfs filesystem) readonly on device 31:5
> [ 2.507642] random: fast init done
> [ 2.514432] devtmpfs: mounted
> [ 2.517972] Freeing unused kernel memory: 144K
> [ 2.522982] This architecture does not have kernel memory protection.
> [ 2.530191] Run /sbin/init as init process
> [ 2.989328] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch
:1
> [ 3.535825]
> [ 3.535825] insmod_device_driver
> [ 3.535825]
> [ 3.543181] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller su
pply udc not found, using dummy regulator
> [ 3.555410] device_chose finished 139!
> [ 3.752493] init: Console is alive
> [ 3.756885] init: - preinit -
> [ 4.573392] random: crng init done
> /dev/by-name/UDISK already format by jffs2
> [ 5.263853] mount_root: mounting /dev/root
> [ 5.269036] mount_root: loading kmods from internal overlay
> [ 5.294166] mount_root: failed to launch kmodloader from internal overlay
> [ 5.709128] block: attempting to load /etc/config/fstab
> [ 5.752572] block: check_filesystem: jffs2 is not supported
> [ 5.865907] jffs2: notice: (91) jffs2_build_xattr_subsystem: complete build
ing xattr subsystem, 12 of xdatum (0 unchecked, 5 orphan) and 14 of xref (5 dead
, 0 orphan) found.
> [ 5.888459] block: extroot: UUID mismatch (root: 8f933688-d2c119ea-002e208d
-9edf26c6, overlay: 1ccd5518-66194c17-815fd60d-4a18e7ff), but continue
> [ 5.913102] overlayfs: upper fs does not support tmpfile.
> [ 5.925716] mount_root: switched to extroot
> [ 5.950979] procd: - early -
> [ 6.318265] procd: - ubus -
> [ 6.322333] procd (1): /proc/103/oom_adj is deprecated, please use /proc/10
3/oom_score_adj instead.
> [ 6.649761] procd: - init -
> Please press Enter to activate this console.
> kmodloader done
> [ 8.552007] file system registered
> [ 8.721315] configfs-gadget 4100000.udc-controller: failed to start g1: -19
> [ 9.042929] read descriptors
> [ 9.046153] read strings
> [ 9.231766] sunxi_set_cur_vol_work()397 WARN: get power supply failed
> [ 9.284081] android_work: sent uevent USB_STATE=CONNECTED
> [ 9.424529] sunxi_set_cur_vol_work()397 WARN: get power supply failed
> [ 9.487029] configfs-gadget gadget: high-speed config #1: c
> [ 9.503455] android_work: sent uevent USB_STATE=CONFIGURED
> [ 9.512808] sunxi_vbus_det_work()3356 WARN: get power supply failed
> [ 9.580048] android_work: sent uevent USB_STATE=DISCONNECTED
> [ 9.912864] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some dat
a may be corrupt. Please run fsck.
> [ 9.966408] android_work: sent uevent USB_STATE=CONNECTED
> [ 32.482712] usb1-vbus: disabling离线
启用SSH了吗?看看是不是在等随机数发生器产生足够的种子
可以看看 /etc/rc.comm會去執行/etc/rc.d/Sxxxx (S開頭的所有script)沒用到可以都拿掉
是不是sshd, 看起来没有
root@TinaLinux:/# ps
PID USER VSZ STAT COMMAND
1 root 2080 S /sbin/procd
2 root 0 SW [kthreadd]
3 root 0 IW< [rcu_gp]
4 root 0 IW< [rcu_par_gp]
5 root 0 IW [kworker/0:0-mm_]
6 root 0 IW< [kworker/0:0H-kb]
7 root 0 IW [kworker/u2:0-ev]
8 root 0 IW< [mm_percpu_wq]
9 root 0 SW [ksoftirqd/0]
10 root 0 IW [rcu_preempt]
11 root 0 SW [kdevtmpfs]
12 root 0 SW [rcu_tasks_kthre]
13 root 0 IW [kworker/0:1-pm]
14 root 0 SW [oom_reaper]
15 root 0 IW< [writeback]
16 root 0 SW [kcompactd0]
46 root 0 IW< [kblockd]
47 root 0 SW [ion_system_heap]
48 root 0 SW [spi0]
49 root 0 SW [kswapd0]
51 root 0 SW [vsync proc 0]
52 root 0 SW [vsync proc 1]
53 root 0 IW [kworker/u2:1]
55 root 0 SW [irq/56-mmc0]
56 root 0 SW [irq/176-4020000]
57 root 0 SW [irq/57-mmc1]
58 root 0 IW [kworker/0:2-eve]
59 root 0 IW< [mmc_complete]
60 root 0 IW< [kworker/0:1H-kb]
61 root 0 IW< [ipv6_addrconf]
66 root 0 IW< [kworker/0:2H-kb]
91 root 0 SWN [jffs2_gcd_mtd6]
101 root 1660 S /sbin/ubusd
109 root 2672 S /bin/ash --login
110 root 1624 S /sbin/askfirst /bin/ash --login
116 root 2608 S {S94exit_sign} /bin/sh /etc/rc.common /etc/rc.d/S94e
213 root 217m S /bin/adbd -D
281 root 1760 S /sbin/netifd
344 root 1472 S /mnt/SDCARD/exit_sign
360 root 2696 S< /usr/sbin/ntpd -n -N -S /usr/sbin/ntpd-hotplug -p nt
382 root 285m S dfbshow /mnt/SDCARD/0.png
419 root 2672 R ps最近编辑记录 ghosoft (2024-08-05 08:08:19)
