上电(12V)↓:
背面↓:
开始自己DIY 12V电源线↓:
DIY线已成↓:
第一次拆,没有经验,应该用热风枪+真空吸盘的↓:
太难拆了↓:
开机速度比 保资的慢多了
全部启动日志:
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
[60]dram size =64
[62](GPIO_BASE_ADDR + 0x48): 0x00002222
[65](GPIO_BASE_ADDR + 0x5c): 0x00000055
[69](GPIO_BASE_ADDR + 0x64): 0x00000004
[72]CCMU_BASE_ADDR + 0x2c0 0x00104040
[76]CCMU_BASE_ADDR + 0x60 0x00104040
[79]SPIC0_BASE_ADDR+0x24: 0x00001004
[82]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 58
[87]block from 8 to 58
[568]Check is correct.
[579]Ready to disable icache.
[582]Jump to secend Boot.
U-Boot 2014.07 (Feb 21 2020 - 18:27:46) Allwinner Technology
uboot commit : 8
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[0.627]pmbus: ready
axp: get node[/soc/pmu0] error
axp_probe error
[0.633]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
key value = 4294967295, fel_key = [256,426]
DRAM: 64 MiB
Relocation Offset is: 03521000
int sunxi_dma_init---
irq enable
workmode = 0,storage type = 0
[0.710]NAND: NAND_UbootInit
[0.713]NAND_UbootInit start
[0.715]NB1: enter NAND_LogicInit
[0.720]nand0: get node offset error
[0.724]init nctri NAND PIORequest error!
[0.727]nand_physic_init, init nctri error
[0.731]nand_physic_init init_parameter error
[0.735]nand_physic_init error -1
[0.738]SpiNandHwInit: Start Nand Hardware initializing .....
[0.744]uboot: nand version: 3 6013 20180906 1300
irq enable
[0.763]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db88c8
[0.771]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83db88e8
_change_spic_clk: 0x01c05024=0x1009
_change_spic_clk_v1: mclk=0xc8
_change_spic_clk: 0x01c05024=0x1004
_change_spic_clk: 0x01c05024=0x1001
_get_spic_clk_v1: sclk0=0x32
[0.824]not burn nand partition table!
[0.828]NB1: nftl num: 1
[0.830]init nftl: 0
[1.189]NB1: NAND_LogicInit ok, result = 0x0
[1.193]NAND_UbootInit end: 0x0
used mbr [0], count = 8
sunxi secure storage is not supported
find key burned flag
env size is 256
env partition is too small!
can't enabled backup env functions
logo addr = 0x83f00000
sunxi_read_bootlogo: read bootlogo partition successful
do not find fastboot status flag
-total partitions:8-
-name- -start- -size-
bootlogo : 400000 80000
env : 480000 20000
boot : 4a0000 400000
rootfs : 8a0000 1e00000
rootfs_data : 26a0000 1400000
misc : 3aa0000 40000
private : 3ae0000 40000
UDISK : 3b20000 0
disable nand error: FDT_ERR_BADPATH
## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery exist
sunxi_bmp_logo_display
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: ARM OpenWrt Linux-3.10.65
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2881272 Bytes = 2.7 MiB
Load Address: 80008000
Entry Point: 80008000
XIP Kernel Image ... OK
reserving fdt memory region: addr=81000000 size=10000
Using Device Tree in place at 81000000, end 8100f23f
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.65 (hs@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #27 Fri Aug 28 02:48:57 UTC 2020
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: reserved 32 MiB at 82000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c05d2824, node_mem_map c0602000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/nandd init=/pseudo_init rdinit=/rdinit partitions=bootlogo@nanda:env@nandb:boot@nandc:rootfs@nandd:rootfs_data@nande:misc@nandf:private@nandg:UDISK@nandh cma=32M fb_base=0x83f00000 androidboot.serialno=0000000000000000000 boot_type=5
[ 0.000000] Memory: 64MB = 64MB total
[ 0.000000] Memory: 25836k/25836k available, 39700k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04c5f84 (4856 kB)
[ 0.000000] .init : 0xc04c6000 - 0xc04e46dc ( 122 kB)
[ 0.000000] .data : 0xc04e6000 - 0xc05d3148 ( 949 kB)
[ 0.000000] .bss : 0xc05d3148 - 0xc0601d80 ( 188 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=552000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.005314] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[ 0.075249] pid_max: default: 32768 minimum: 301
[ 0.080429] Mount-cache hash table entries: 512
[ 0.086385] CPU: Testing write buffer coherency: ok
[ 0.092156] Setting up static identity map for 0xc03ac478 - 0xc03ac4d0
[ 0.101385] devtmpfs: initialized
[ 0.107016] pinctrl core: initialized pinctrl subsystem
[ 0.119385] NET: Registered protocol family 16
[ 0.127388] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.135051] dump_class_init,844, success
[ 0.143891] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[ 0.167846] bio: create slab <bio-0> at 0
[ 0.173294] pwm module init!
[ 0.178049] SCSI subsystem initialized
[ 0.182255] usbcore: registered new interface driver usbfs
[ 0.188143] usbcore: registered new interface driver hub
[ 0.194019] usbcore: registered new device driver usb
[ 0.205249] Linux video capture interface: v2.00
[ 0.210582] Advanced Linux Sound Architecture Driver Initialized.
[ 0.218573] cfg80211: Calling CRDA to update world regulatory domain
[ 0.226134] Switching to clocksource sun3i high-res couter
[ 0.251380] get det_vbus is fail, 84
[ 0.256855] NET: Registered protocol family 2
[ 0.263486] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.270598] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.277258] TCP: Hash tables configured (established 512 bind 512)
[ 0.283828] TCP: reno registered
[ 0.287225] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.293336] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.300423] NET: Registered protocol family 1
[ 0.320699] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.327420] msgmni has been set to 114
[ 0.334721] io scheduler noop registered
[ 0.338893] io scheduler cfq registered (default)
[ 0.343870] [pm]aw_pm_init!
[ 0.347151] [pm]valid
[ 0.349554] [pm]valid
[ 0.352364] [DISP]disp_module_init
[ 0.411945] pll_freq=297000000HZ, lcd_dclk_freq=48000000HZ, clk_div=6
[ 0.419249] *******************************
[ 0.423676] ***
[ 0.425551] *** LCD Panel Parameter Check
[ 0.429705] ***
[ 0.431572] *** by guozhenjie
[ 0.435766] ***
[ 0.437637] ********************************
[ 0.442086] ***
[ 0.443956] *** Interface:
[ 0.446528] *** Parallel HV Panel
[ 0.450253] *** Lcd Frm to RGB666
[ 0.453734] ***
[ 0.455602] *** Timing:
[ 0.458175] *** lcd_x: 800
[ 0.461452] *** lcd_y: 1280
[ 0.464845] *** lcd_ht: 1000
[ 0.468211] *** lcd_hbp: 100
[ 0.471488] *** lcd_vt: 1480
[ 0.474878] *** lcd_vbp: 100
[ 0.478155] *** lcd_hspw: 50
[ 0.481343] *** lcd_vspw: 50
[ 0.484559] *** lcd_frame_frq: 32Hz
[ 0.488274] ***
[ 0.490144] *** WRN03: Recommend "lcd_dclk_frq = 88"
[ 0.495293] ***
[ 0.497164] *** LCD Panel Parameter Check End
[ 0.501671] *******************************
[ 0.506155] num_screens=1
[ 0.508913] screen_id=0
[ 0.511487] para->mclk[MOD_CLK_LCD1CH0]=0xc180c340
[ 0.516499] para->mclk[MOD_CLK_LCD1CH1]=0xc180c440
[ 0.521453] disp tv init
[ 0.524155] tcon_clk=0xc180c340, tcon_clk_parent=0x0
[ 0.529288] tcon_clk=0xc180c340, tcon_clk_parent=0xc1804400
[ 0.535069] tve_clk=0xc180c440, tve_clk_parent=0xc1804400
[ 0.540636] disp al tv init
[ 0.546363] fetch script datadisp.screen2_output_type fail
[ 0.552134] invalid screen0_output_type 0
[ 0.556622] fetch script datadisp.screen2_output_mode fail
[ 0.564997] fetch script datadisp.fb2_format fail
[ 0.570173] fetch script datadisp.fb2_scaler_mode_enable fail
[ 0.576479] fetch script datadisp.fb2_width fail
[ 0.581568] fetch script datadisp.fb2_height fail
[ 0.615960] [DISP]disp_module_init finish
[ 0.634309] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
[ 0.640632] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
[ 0.648907] console [ttyS1] enabled, bootconsole disabled
[ 0.661482] misc dump reg init
[ 0.666882] [NAND]SPIC0_BASE_ADDR f1c05000
[ 0.672214] Failed to get dragonboard_flag
[ 0.676763] [NAND]nand init start
[ 0.680443] SpiNandHwInit: Start Nand Hardware initializing Sep 6 2018 07:23:33.....
[ 0.689201] kernel: nand version: 3 6013 20180906 1300
[ 0.694945] print_level is no used
[ 0.698726] request spi gpio ok!
[ 0.702435] request tx DMA
[ 0.705444] request general tx dma channel ok!
[ 0.710366] request rx DMA
[ 0.713400] request general rx dma channel ok!
[ 0.718324] NAND_ClkRequest
[ 0.721464] NAND_ClkRequest: get pll6 rate 200000000HZ
[ 0.727290] SPI nand ID: 12c212c2 12c212c2
[ 0.731917] [SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffcfffff
[ 0.739834] id_number_ctl is no used
[ 0.743839] _UpdateExtAccessFreqPara: no para.
[ 0.749451] PHY_Scan_DelayMode: right delay mode 0x0
[ 0.755525] PHY_Scan_DelayMode: right delay mode 0x800
[ 0.761278] _get_spic_clk_v1: sclk0=0x32
[ 0.765709] PHY_Scan_DelayMode: right delay mode,clk 50 MHz, bit[13]=0,bit[11]=0
[ 0.773953] physic_info_read start!!
[ 0.777947] physic_info_get_offset start!!
[ 0.787058] physic_info_get_one_copy start!!
[ 0.792773] block 13 page 48
[ 0.796456] block 13 page 49
[ 0.800140] block 13 page 50
[ 0.803894] block 13 page 51
[ 0.807575] block 13 page 52
[ 0.811256] block 13 page 53
[ 0.815006] block 13 page 54
[ 0.818691] block 13 page 55
[ 0.822451] block 13 page 56
[ 0.826136] block 13 page 57
[ 0.829816] block 13 page 58
[ 0.833577] block 13 page 59
[ 0.837260] block 13 page 60
[ 0.840945] block 13 page 61
[ 0.844704] block 13 page 62
[ 0.848384] block 13 page 63
[ 0.852736] physic info copy is ok
[ 0.856529]
[ 0.856529]
[ 0.859826] [SCAN_DBG] ==============Nand Architecture Parameter==============
[ 0.867914] [SCAN_DBG] Nand Chip ID: 0xffff12c2 0xffffffff
[ 0.875099] [SCAN_DBG] Nand Chip Count: 0x1
[ 0.880507] [SCAN_DBG] Nand Chip Connect: 0x1
[ 0.885944] [SCAN_DBG] Sector Count Of Page: 0x4
[ 0.891352] [SCAN_DBG] Page Count Of Block: 0x40
[ 0.896884] [SCAN_DBG] Block Count Of Die: 0x400
[ 0.902510] [SCAN_DBG] Plane Count Of Die: 0x2
[ 0.907918] [SCAN_DBG] Die Count Of Chip: 0x1
[ 0.913352] [SCAN_DBG] Bank Count Of Chip: 0x1
[ 0.918759] [SCAN_DBG] Optional Operation: 0x6d
[ 0.924289] [SCAN_DBG] Access Frequence: 0x32
[ 0.929791] [SCAN_DBG] =======================================================
[ 0.929791]
[ 0.970263] secure storage updata ok!
[ 0.974423] nand secure storage ok: 58,59
[ 0.978898] start block:60
[ 0.981948] [ND]boot start
[ 0.985049] [ND]boot :0xc1940000
[ 0.988626] [ND]boot->magic :0xaa55a5a5
[ 0.992910] [ND]boot->len :0x8000
[ 0.996585] [ND]boot->no_use_block :0x21
[ 1.000931] [ND]boot->uboot_start_block :0x8
[ 1.005700] [ND]boot->uboot_next_block :0x3a
[ 1.010434] [ND]boot->logic_start_block :0x21
[ 1.015298] [ND]mbr len :4096
[ 1.018588] [ND]_PARTITION len :2560
[ 1.022577] [ND]_NAND_STORAGE_INFO len :512
[ 1.027214] [ND]_FACTORY_BLOCK len :2048
[ 1.031645] [NE]partition_num: 0,size :0x36c00,cross_talk 0
[ 1.037873] [NE]part mbr size: 0x2000 type: 0
[ 1.042741] [NE]part bootlogo size: 0x400 type: 0
[ 1.047956] [NE]part env size: 0x100 type: 0
[ 1.052722] [NE]part boot size: 0x2000 type: 0
[ 1.057650] [NE]part rootfs size: 0xf000 type: 0
[ 1.062802] [NE]part rootfs_data size: 0xa000 type: 0
[ 1.068404] [NE]part misc size: 0x200 type: 0
[ 1.073263] [NE]part private size: 0x200 type: 0
[ 1.078383] [NE]part UDISK size: 0x19300 type: 0
[ 1.083660] [ND]factory bad block:0,436 PartitionNO:0
[ 1.089281] [ND]partition->size :224256
[ 1.093568] [ND]partition->cross_talk :0
[ 1.097916] [ND]partition->attribute :0
[ 1.102195] [ND]partition->start.Chip_NO :0
[ 1.106833] [ND]partition->start.Block_NO :33
[ 1.111659] [ND]partition->end.Chip_NO :0
[ 1.116131] [ND]partition->end.Block_NO :511
[ 1.120864] [ND]partition->nand_disk[0].size :8192
[ 1.126203] [ND]partition->nand_disk[0].type :0
[ 1.131227] [ND]partition->nand_disk[1].size :1024
[ 1.136565] [ND]partition->nand_disk[1].type :0
[ 1.141588] [ND]partition->nand_disk[2].size :256
[ 1.146828] [ND]partition->nand_disk[2].type :0
[ 1.151879] [ND]partition->nand_disk[3].size :8192
[ 1.157190] [ND]partition->nand_disk[3].type :0
[ 1.162240] [ND]partition->nand_disk[4].size :61440
[ 1.167647] [ND]partition->nand_disk[4].type :0
[ 1.172696] [ND]partition->nand_disk[5].size :40960
[ 1.178102] [ND]partition->nand_disk[5].type :0
[ 1.183150] [ND]partition->nand_disk[6].size :512
[ 1.188365] [ND]partition->nand_disk[6].type :0
[ 1.193414] [ND]partition->nand_disk[7].size :512
[ 1.198628] [ND]partition->nand_disk[7].type :0
[ 1.203676] [ND]partition->nand_disk[8].size :103168
[ 1.209179] [ND]partition->nand_disk[8].type :0
[ 1.214229] [ND]partition->nand_disk[9].size :-1
[ 1.219348] [ND]partition->nand_disk[9].type :-1
[ 1.224492] [ND]partition->nand_disk[10].size :-1
[ 1.229707] [ND]partition->nand_disk[10].type :-1
[ 1.234947] [ND]partition->nand_disk[11].size :-1
[ 1.240162] [ND]partition->nand_disk[11].type :-1
[ 1.245404] [ND]partition->nand_disk[12].size :-1
[ 1.250618] [ND]partition->nand_disk[12].type :-1
[ 1.255860] [ND]partition->nand_disk[13].size :-1
[ 1.261075] [ND]partition->nand_disk[13].type :-1
[ 1.266316] [ND]partition->nand_disk[14].size :-1
[ 1.271531] [ND]partition->nand_disk[14].type :-1
[ 1.276781] [ND]partition->nand_disk[15].size :-1
[ 1.282025] [ND]partition->nand_disk[15].type :-1
[ 1.287241] [ND]partition->nand_disk[16].size :-1
[ 1.292482] [ND]partition->nand_disk[16].type :-1
[ 1.297698] [ND]partition->nand_disk[17].size :-1
[ 1.302940] [ND]partition->nand_disk[17].type :-1
[ 1.308156] [ND]partition->nand_disk[18].size :-1
[ 1.313397] [ND]partition->nand_disk[18].type :-1
[ 1.318613] [ND]partition->nand_disk[19].size :-1
[ 1.323854] [ND]partition->nand_disk[19].type :-1
[ 1.329068] [ND]partition->nand_disk[20].size :-1
[ 1.334311] [ND]partition->nand_disk[20].type :-1
[ 1.339527] [ND]partition->nand_disk[21].size :-1
[ 1.344767] [ND]partition->nand_disk[21].type :-1
[ 1.349982] [ND]partition->nand_disk[22].size :-1
[ 1.355222] [ND]partition->nand_disk[22].type :-1
[ 1.360437] [ND]partition->nand_disk[23].size :-1
[ 1.365680] [ND]partition->nand_disk[23].type :-1
[ 1.370897] [ND]phy_partition->PartitionNO :0
[ 1.375753] [ND]phy_partition->SectorNumsPerPage :8
[ 1.381160] [ND]phy_partition->PageNumsPerBlk :64
[ 1.386400] [ND]phy_partition->TotalBlkNum :479
[ 1.391422] [ND]phy_partition->FullBitmapPerPage :8
[ 1.396853] [ND]phy_partition->FreeBlock :0
[ 1.401489] [ND]phy_partition->TotalSectors :224256
[ 1.406921] [ND]phy_partition->StartBlock.Chip_NO :0
[ 1.412450] [ND]phy_partition->StartBlock.Block_NO :33
[ 1.418145] [ND]phy_partition->EndBlock.Chip_NO :0
[ 1.423483] [ND]phy_partition->EndBlock.Block_NO :511
[ 1.429082] [ND]phy_partition->next_phy_partition :0
[ 1.434613] [ND]phy_partition->PartitionNO 0 FACTORY BAD BLOCK:
[ 1.441272] [ND]BAD Chip:0;Block:436.
[ 1.445361] [ND]phy_partition->PartitionNO 0 NEW BAD BLOCK:
[ 1.451636] [ND]build 1 phy_partition !
[ 1.455918] [ND]nand_info->type :0
[ 1.459689] [ND]nand_info->SectorNumsPerPage :8
[ 1.464740] [ND]nand_info->BytesUserData :16
[ 1.469473] [ND]nand_info->PageNumsPerBlk :64
[ 1.474331] [ND]nand_info->BlkPerChip :512
[ 1.478871] [ND]nand_info->FirstBuild :0
[ 1.483244] [ND]nand_info->FullBitmap :0
[ 1.487592] [ND]nand_info->bad_block_addr.Chip_NO :0
[ 1.493123] [ND]nand_info->bad_block_addr.Block_NO :0
[ 1.498723] [ND]nand_info->mbr_block_addr.Chip_NO :0
[ 1.504255] [ND]nand_info->mbr_block_addr.Block_NO :0
[ 1.509854] [ND]nand_info->no_used_block_addr.Chip_NO :0
[ 1.515772] [ND]nand_info->no_used_block_addr.Block_NO :33
[ 1.521881] [ND]nand_info->new_bad_block_addr.Chip_NO :0
[ 1.527769] [ND]nand_info->new_bad_block_addr.Block_NO :0
[ 1.533782] [ND]nand_info->new_bad_page_addr :65535
[ 1.539188] [ND]nand_info->partition_nums :1
[ 1.543947] [ND]sizeof partition:2384
[ 1.548007] [ND]nand_info->partition:0:
[ 1.552286] [ND]size:0x36c00
[ 1.555479] [ND]cross_talk:0x0
[ 1.558861] [ND]attribute:0x0
[ 1.562177] [ND]start: chip:0 block:33
[ 1.566332] [ND]end : chip:0 block:511
[ 1.570583] [ND]boot :0xc1940000
[ 1.574188] [ND]boot->magic :0xaa55a5a5
[ 1.578440] [ND]boot->len :0x8000
[ 1.582139] [ND]boot->no_use_block :0x21
[ 1.586486] [ND]boot->uboot_start_block :0x8
[ 1.591217] [ND]boot->uboot_next_block :0x3a
[ 1.595977] [ND]boot->logic_start_block :0x21
[ 1.600805] [ND]mbr len :4096
[ 1.604119] [ND]_PARTITION len :2560
[ 1.608083] [ND]_NAND_STORAGE_INFO len :512
[ 1.612746] [ND]_FACTORY_BLOCK len :2048
[ 1.617438] [ND]nand_partition0
[ 1.621104] [ND]nftl start:479,41
[ 1.625104] [ND]first
[ 1.743499] [ND]bad block: 403
[ 1.772418] [ND]before second 478 438.
[ 2.288316] [NE]recover_phy_page_mapping no used page 56!!
[ 2.294493] [ND]recover 50 56
[ 2.297834] [ND]free block nums is 19 !
[ 2.302138] [NE]not power on gc 19!
[ 2.306005] [ND]nftl ok!
[ 2.308889] [ND]max_erase_times = 65000
[ 2.315763] nanda: unknown partition table
[ 2.323192] nandb: unknown partition table
[ 2.330451] nandc: unknown partition table
[ 2.337787] nandd: unknown partition table
[ 2.345089] nande: unknown partition table
[ 2.351246] nandf: unknown partition table
[ 2.358617] nandg:
[ 2.363717] nandh: unknown partition table
[ 2.369246] [NAND]nand init end
[ 2.373465] sunxi-wlan wlan: wlan_busnum (0)
[ 2.378229] sunxi-wlan wlan: wlan_power_num (0)
[ 2.383362] sunxi-wlan wlan: Missing wlan_io_regulator.
[ 2.389169] sunxi-wlan wlan: io_regulator_name ((null))
[ 2.395056] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
[ 2.402995] sunxi-wlan wlan: wlan_regon gpio=130 mul-sel=1 pull=3 drv_level=1 data=1
[ 2.412147] sunxi-wlan wlan: wlan_hostwake gpio=131 mul-sel=6 pull=-1 drv_level=-1 data=1
[ 2.421650] sunxi-wlan wlan: Missing clocks.
[ 2.426457] sunxi-wlan wlan: clk_name ((null))
[ 2.431426] sunxi-wlan wlan: clk not config
[ 2.436502] lradc_battery_probe:lradc_battery_probe ++++++
[ 2.442677] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
[ 2.449569] key base: f1c23400
[ 2.453142] irq num: 115 !
[ 2.456152] battery_data_hw_init:battery_data_hw_init ++++++
[ 2.462542] lradc_battery_probe:lradc_battery_probe ------
[ 2.469303] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.477170] usbcore: registered new interface driver usb-storage
[ 2.484074] usbcore: registered new interface driver usbtest
[ 2.491336] /soc/usbc0@0: could not find phandle
[ 2.496588] get regulator_io is no nocare
[ 2.501194] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 2.509214] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 2.520972] hub 1-0:1.0: USB hub found
[ 2.525313] hub 1-0:1.0: 1 port detected
[ 2.530136] wrn: hcd is not enable, need not stop hcd
[ 2.536486] rtc-pcf8563 0-0051: chip found, driver version 0.4.3
[ 2.543671] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
[ 2.552930] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[ 2.560098] rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 2.567750] sunxi cedar version 0.1
[ 2.572008] VE: install start!!!
[ 2.572008]
[ 2.577393] cedar_ve: cedar-ve the get irq is 103
[ 2.583303] VE: install end!!!
[ 2.583303]
[ 2.589857] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.600195] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v0.91 2018-5-29 14:19) Compiled in Aug 6 2020 at 14:27:00
[ 2.612682] sunxi-mmc sdc0: Can't get vmmc regulator string
[ 2.618882] sunxi-mmc sdc0: Can't get vqmmc regulator string
[ 2.625269] sunxi-mmc sdc0: Can't get vdmmc regulator string
[ 2.631558] sunxi-mmc sdc0: Failed getting OCR mask: 0
[ 2.638786] sunxi-mmc sdc0: ***set host ocr***
[ 2.644299] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.671945] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.702105] sunxi-mmc sdc0: base:0xf1c0f000 irq:107
[ 2.707564] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
[ 2.714415] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
[ 2.720413] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.731671] usbcore: registered new interface driver usbhid
[ 2.737970] usbhid: USB HID core driver
[ 2.745637] failed to get gpio-spk and gpio_num
[ 2.754540] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.766189] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
[ 2.774238] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
[ 2.782218] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
[ 2.789950] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
[ 2.797721] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker
[ 2.807997] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !!
[ 2.817594] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[ 2.826688] sunxi-codec-machine sound.2: sun3iw1codec <-> 1c23c00.cpudai0-controller mapping ok
[ 2.836653] sunxi-codec-machine sound.2: ASoC: no sink widget found for MainMic Bias
[ 2.845354] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[ 2.851196] sunxi-codec-machine sound.2: ASoC: Failed to add route External MainMic -> direct -> MainMic Bias
[ 2.862244] sunxi-codec-machine sound.2: ASoC: no source widget found for MainMic Bias
[ 2.871036] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bias -> direct -> MIC1P
[ 2.881025] sunxi-codec-machine sound.2: ASoC: no source widget found for MainMic Bias
[ 2.889853] sunxi-codec-machine sound.2: ASoC: Failed to add route MainMic Bias -> direct -> MIC1N
[ 2.900699] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[ 2.908429] ipip: IPv4 over IPv4 tunneling driver
[ 2.915013] gre: GRE over IPv4 demultiplexor driver
[ 2.920446] ip_gre: GRE over IPv4 tunneling driver
[ 2.928268] TCP: cubic registered
[ 2.932076] Initializing XFRM netlink socket
[ 2.936885] NET: Registered protocol family 17
[ 2.941973] NET: Registered protocol family 15
[ 2.947456] VFP support v0.3: not present
[ 2.952932] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
[ 2.959219] [LCD]lcd_module_init
[ 2.962953] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[ 2.969767] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[ 2.976669] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[ 2.983524] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
[ 2.989844] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.002225] enhance_en=1
[ 3.005098] matrixresult:(0x0, 0x3c4, 0x0, 0x0)
[ 3.010171] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[ 3.016364] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[ 3.022529] ERROR,DE_BE_Layer_Set_Screen_Win:175 w,h=[0,0]
[ 3.028684] pll_freq=297000000HZ, lcd_dclk_freq=48000000HZ, clk_div=6
[ 3.035905] clk_div=6
[ 3.039774] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !!
[ 3.046035] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.056596] [LCD]open, step 0 finish
[ 3.091922] [LCD]open, step 1 finish
[ 3.151901] [LCD]open, step 2 finish
[ 3.262352] close lcd backlight!
[ 3.266079] [LCD]open, step 3 finish
[ 3.272374] [LCD]lcd_module_init finish
[ 3.277176] usb_serial_number:20080411
[ 3.282185] file system registered
[ 3.288859] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.296643] android_usb gadget: Number of LUNs=3
[ 3.301865] lun0: LUN: removable file: (no medium)
[ 3.307284] lun1: LUN: removable file: (no medium)
[ 3.312763] lun2: LUN: removable file: (no medium)
[ 3.319110] android_usb gadget: android_usb ready
[ 3.324892] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
[ 3.334181] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
[ 3.340859] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
[ 3.348772] ALSA device list:
[ 3.352166] #0: audiocodec
[ 3.362991] VFS: Mounted root (squashfs filesystem) readonly on device 93:48.
[ 3.375825] devtmpfs: mounted
[ 3.380286] Freeing unused kernel memory: 120K (c04c6000 - c04e4000)
mount: mounting none on /dev failed: Resource busy
mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
[ 4.271994]
[ 4.271994] insmod_device_driver
[ 4.271994]
[ 4.279138] device_chose finished 77!
[ 4.345483] EXT4-fs (nande): mounted filesystem with ordered data mode. Opts: (null)
-- run rc.preboot --
-- run hanshow config --
copy mac.txt to /tmp/xr_wifi.conf success!
copy SN.txt to /usr/product_id success!
-- end --
[ 4.980236] EXT4-fs (nandh): mounted filesystem with ordered data mode. Opts: (null)
[ 5.721997] sunxi-wlan wlan: bus_index: 0
[ 5.740747] ======== XRADIO WIFI OPEN ========
[ 5.745891] [XRADIO] Driver Label:XR_V02.15.40 Aug 5 2020 01:58:31
[ 5.762084] [XRADIO] Allocated hw_priv @ c1916fa0
[ 5.767494] [XRADIO_ERR] MACADDR=98:6d:35:71:0a:d4
[ 5.892044] [XRADIO] Detect SDIO card 0
[ 5.906658] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.931986] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.962717] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.976981] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.990544] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 6.012291] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 6.023874] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 6.035970] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 6.048990] mmc0: new high speed SDIO card at address 0001
[ 6.063315] [SBUS] XRadio Device:sdio clk=50000000
[ 6.093496] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 6.220667] [XRADIO] Bootloader complete
[ 6.319094] [XRADIO] Firmware completed.
[ 6.342007] [WSM] Firmware Label:XR_C01.08.52.11 Jan 24 2017 10:15:58
[ 6.349325] [XRADIO] Firmware Startup Done.
[ 6.402417] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
-- run rc.final --
insmod F1C200s-board
-- wifi connect --
insmod wifi kernel module --------------------
insmod: can't insert '/lib/modules/3.10.65/xradio_wlan.ko': File exists
start wpa_supplicant ------------------------
[ 6.876975] android_usb: already disabled
[ 7.010137] adb_open
[ 7.015855] adb_bind_config
[ 7.282968] android_work: sent uevent USB_STATE=CONNECTED
[ 7.303179] android_usb gadget: high-speed config #1: android
[ 7.313770] android_work: sent uevent USB_STATE=CONFIGURED
rfkill: Cannot open RFKILL control device
[ 7.834642] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0
nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory)
start udhcpc ----------------
mkdir: can't create directory '/mnt/focus': File exists
udhcpc: started, v1.27.2
[ 9.127895] EXT4-fs (nandh): mounted filesystem with ordered data mode. Opts: (null)
udhcpc: sending discover
vm.panic_on_oom = 1
kernel.panic = 10
-- end --
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 5C1C9C53)
root@TinaLinux:/# [ 9.662510] [STA_WRN] Freq 2437 (wsm ch: 6) prev: 3.
[ 9.668826] wlan0: authenticate with 72:3d:d6:25:ac:3b (try 1)
[ 9.732324] wlan0: authenticated
[ 9.738048] wlan0: associate with 72:3d:d6:25:ac:3b (try 1)
[ 9.785057] wlan0: RX AssocResp from 72:3d:d6:25:ac:3b (capab=0x1031 status=0 aid=26)
[ 9.793942] wlan0: associated
[ 9.808514] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 9.842624] wlan0: deauthenticating from 72:3d:d6:25:ac:3b by local choice (reason=3)
[ 9.851925] [WSM_WRN] Issue unjoin command(TX).
[ 9.878660] cfg80211: Calling CRDA to update world regulatory domain
creat test file ok
read len test_len:70
ssid_str:hanshow
pwd_str:12345678
/mnt/focus/etc/focus.conf is exist, use ssid:hanshow & pwd:12345678 to connect ap!
==============TEST WIFI=========Connecting to the network(hanshow)......
[ 20.498302] wlan0: authenticate with 72:3d:d6:25:ac:3b (try 1)
[ 20.544013] wlan0: authenticated
[ 20.549450] wlan0: associate with 72:3d:d6:25:ac:3b (try 1)
[ 20.597111] wlan0: RX AssocResp from 72:3d:d6:25:ac:3b (capab=0x1031 status=0 aid=9)
[ 20.605853] wlan0: associated
[ 20.620389] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 20.657714] wlan0: deauthenticating from 72:3d:d6:25:ac:3b by local choice (reason=3)
[ 20.668770] [WSM_WRN] Issue unjoin command(TX).
[ 20.675168] [WSM_WRN] STA mode, send_deauth_to_self
[ 20.680615] [TXRX_WRN] Issue unjoin command(TX) by self.
[ 20.690874] cfg80211: Calling CRDA to update world regulatory domain
Disconnected,the reason:WSE_NETWORK_NOT_EXIST
Wifi connect ap : Failure!
step2: run focus!
root@TinaLinux:/#
root@TinaLinux:/# ifconfig
[ 44.830688] [NE]gc_one ok!
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 98:6D:35:71:0A:D4
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:3 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:403 (403.0 B) TX bytes:308 (308.0 B)
root@TinaLinux:/# [ 49.242617] wlan0: authenticate with 72:3d:d6:25:ac:3b (try 1)
[ 49.282580] wlan0: authenticated
[ 49.288391] wlan0: associate with 72:3d:d6:25:ac:3b (try 1)
[ 49.337798] wlan0: RX AssocResp from 72:3d:d6:25:ac:3b (capab=0x1031 status=0 aid=15)
[ 49.346689] wlan0: associated
[ 49.373311] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 49.404939] wlan0: deauthenticating from 72:3d:d6:25:ac:3b by local choice (reason=3)
[ 49.417097] [WSM_WRN] Issue unjoin command(TX).
[ 49.439137] cfg80211: Calling CRDA to update world regulatory domain
[ 51.209049] [NE]gc_one ok!
[ 51.335095] [NE]gc_one ok!
[ 51.464408] [NE]gc_one ok!
[ 52.063651] [NE]gc_one ok!
[ 60.005530] Open the lcd backlight!
[ 60.386106] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[ 60.395490] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[ 60.404695] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[ 60.413958] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[ 60.423233] sid_get_vir_base()215 - Failed to find "allwinner,sunxi-chipid" in dts.
[ 70.005221] Open the lcd backlight!
root@TinaLinux:/#
root@TinaLinux:/#
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:516 (516.0 B) TX bytes:461 (461.0 B)
root@TinaLinux:/#离线
mac地址来源:
root@TinaLinux:/#
root@TinaLinux:/# ifconfig wlan0
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /mnt/private/ULI/factory/SN.txt
213010089003800139root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /mnt/private/ULI/factory/mac.txt
98:6D:35:71:0A:D4root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#离线
开机自动运行脚本 cat /etc/init.d/rc.final
#!/bin/sh
echo "-- run rc.final --"
wifi_connect1()
#example for setting mac address,The actual production needs to be revised.
#cp /etc/xr_wifi.conf /tmp/
#echo 4 > /proc/sys/kernel/printk
echo "insmod wifi kernel module --------------------"
insmod /lib/modules/3.10.65/xradio_wlan.ko
echo "start wpa_supplicant ------------------------"
wpa_supplicant -Dnl80211 -iwlan0 -c /etc/wpa_supplicant.conf -B
sleep 1
echo "start udhcpc ----------------"
udhcpc -iwlan0 &
wifi_connect2()
count=0
wpa_supplicant -iwlan0 -Dnl80211 -c/etc/wpa_supplicant.conf > /tmp/wifi.log &
sleep 1
while true
do
usleep 500
let count++
grep "CTRL-EVENT-CONNECTED" /tmp/wifi.log && {
/sbin/udhcpc -i wlan0 &
return
if [ $count -eq 500 ]; then
echo "wifi connect fail!!!!!!!!!!!!!!!!!!!!!!"
return
fi
done
echo "insmod F1C200s-board"
if [ -f "/usr/bin/F1C200s-board" ]; then
/usr/bin/F1C200s-board > /dev/null 2>&1 &
sleep 3
echo "app start..."
fi
echo "-- wifi connect --"
wifi_connect1
#[ ! -f "/mnt/UDISK/etc/focus.conf" ] && ( mkdir -p /mnt/focus; mkdir -p /mnt/UDISK/etc; cp /etc/focus.conf /mnt/UDISK/etc )
mkdir /mnt/focus
[ -d "/mnt/focus" ] && ( umount /mnt/UDISK; mount -t ext4 /dev/nandh /mnt/focus)
# for update app
[ -f "/usr/bin/focus.new" ] && ( mv /usr/bin/focus.new /usr/bin/focus; chmod +x /usr/bin/focus )
[ -f "/usr/bin/hanshow_player.new" ] && ( mv /usr/bin/hanshow_player.new /usr/bin/hanshow_player; chmod +x /usr/bin/hanshow_player )
sysctl -w vm.panic_on_oom=1
sysctl -w kernel.panic=10
#export FOCUS_HOME=/mnt/focus
#/usr/bin/focus > /dev/null 2>&1 &
/usr/bin/hanshow_auto_focus &
echo "-- end --"离线
