各位大佬们,本人是刚入坑全志,自己做了一块T113S3的板子 SDK是之前课程送的,我是在此基础上 给板子重新适配了新屏幕 因为用不到WIFI 怕占用启动时间我就从 kernel_menuconfig取消了勾选 但是好像还是有检测的报错
还望各位大佬指点一下
如下是设备的启动日志
[27]HELLO! BOOT0 is starting!
[30]BOOT0 commit : 1417090655
[33]set pll start
[39]periph0 has been enabled
[42]set pll end
[43][pmu]: bus read error
[46]board init ok
[48]enable_jtag
[50]ZQ value = 0x2f
[51]get_pmu_exist() = -1
[54]DRAM BOOT DRIVE INFO: V0.33
[57]DRAM CLK = 792 MHz
[59]DRAM Type = 3 (2:DDR2,3:DDR3)
[62]DRAMC read ODT off.
[65]DRAM ODT value: 0x42.
[68]ddr_efuse_type: 0xa
[71]DRAM SIZE =128 M
[73]dram_tpr4:0x0
[74]PLL_DDR_CTRL_REG:0xf8004100
[78]DRAM_CLK_REG:0xc0000000
[80][TIMING DEBUG] MR2= 0x18
[88]DRAM simple test OK.
[90]rtc standby flag is 0x0, super standby flag is 0x0
[96]dram size =128
[98]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[103]block from 8 to 32
[217]Check is correct.
[219]dma 0x2ac4c int is not used yet
[223]dma 0x2ac4c int is free, you do not need to free it again
[228]Entry_name = u-boot
[235]Entry_name = optee
[240]Entry_name = dtb
[242]Jump to second Boot.
M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
U-Boot 2018.07 (Nov 28 2025 - 11:48:02 +0800) Allwinner Technology
[00.293]CPU: Allwinner Family
[00.296]Model: sun8iw20
[00.298]DRAM: 128 MiB
[00.302]Relocation Offset is: 04ecc000
[00.328]secure enable bit: 0
E/TC:0 fdt_getprop_u32:343 prop trace_level not found
[00.341]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.348]gic: sec monitor mode
sunxi flash map init
SPI ALL: ready
[00.355]flash init start
[00.357]workmode = 0,storage type = 0
[00.363]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1b
device nand0 <nand>, # parts = 4
#: name size offset mask_flags
0: boot0 0x00100000 0x00000000 1
1: uboot 0x00300000 0x00100000 1
2: secure_storage 0x00100000 0x00400000 1
3: sys 0x07b00000 0x00500000 0
active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
defaults:
mtdids : nand0=nand
mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
[00.480]ubi0: attaching mtd4
[00.587]ubi0: scanning is finished
[00.593]ubi0: attached mtd4 (name "sys", size 123 MiB)
[00.598]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[00.604]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[00.611]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[00.617]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[00.622]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
[00.629]ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 0
[00.637]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[00.645]sunxi flash init ok
[00.648]line:703 init_clocks
[00.651]drv_disp_init
[00.655]handle_num : 6
request pwm success, pwm7:pwm7:0x2000c00.
[00.666]drv_disp_init finish
[00.745]Loading Environment from SUNXI_FLASH... OK
[00.766]boot_gui_init:start
[00.769]set disp.dev2_output_type fail. using defval=0
[00.773]=====================lcd_open_flow
[00.778]=====================lcd_power_on
[00.977]set disp.fb0_rot_used fail. using defval=0
[00.982]set disp.fb0_rot_degree fail. using defval=0
[00.988]boot_gui_init:finish
partno erro : can't find partition bootloader
[01.006]bmp_name=bootlogo.bmp size 432054
[01.039]Item0 (Map) magic is bad
[01.042]usb burn from boot
delay time 0
weak:otg_phy_config
[01.053]usb prepare ok
[01.681]overtime
[01.685]do_burn_from_boot usb : no usb exist
partno erro : can't find partition private
[01.831]update bootcmd
[01.847]change working_fdt 0x45e8be70 to 0x45e6be70
[01.866]update dts
[01.921]=====================lcd_bl_open
[01.926]LCD open finish
[02.114]no vendor_boot partition is found
Android's image name: sun8i_arm
ERROR: reserving fdt memory region failed (addr=41900000 size=200000)
ERROR: reserving fdt memory region failed (addr=41c00000 size=400000)
ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
ERROR: reserving fdt memory region failed (addr=45f0f000 size=473100)
ERROR: reserving fdt memory region failed (addr=42000000 size=100000)
ERROR: reserving fdt memory region failed (addr=42240000 size=2000)
ERROR: reserving fdt memory region failed (addr=42242000 size=2000)
ERROR: reserving fdt memory region failed (addr=42100000 size=10000)
[02.197]Starting kernel ...
▒[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.61 (dai@DAI) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #6 SMP PREEMPT Fri Nov 28 11:50:14 CST 2025
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 4 MiB at 0x47c00000
[ 0.000000] On node 0 totalpages: 32420
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32420 pages, LIFO batch:7
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30784 r8192 d22464 u61440
[ 0.000000] pcpu-alloc: s30784 r8192 d22464 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32164
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:UDISK@ubi0_6: cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07(11/28/2025-11:48:02) mbr_offset=1032192 disp_reserve=4665600,0x45f0f000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 100564K/129680K available (6144K kernel code, 303K rwdata, 2176K rodata, 1024K init, 1164K bss, 25020K reserved, 4096K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x25c/0x3dc with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000017] Switching to timer-based delay loop, resolution 41ns
[ 0.000189] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000804] Console: colour dummy device 80x30
[ 0.000844] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000857] pid_max: default: 32768 minimum: 301
[ 0.000984] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000996] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001604] CPU: Testing write buffer coherency: ok
[ 0.001940] /cpus/cpu@0 missing clock-frequency property
[ 0.001960] /cpus/cpu@1 missing clock-frequency property
[ 0.001972] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002517] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002629] rcu: Hierarchical SRCU implementation.
[ 0.003068] smp: Bringing up secondary CPUs ...
[ 0.004259] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004391] smp: Brought up 1 node, 2 CPUs
[ 0.004404] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.004410] CPU: All CPU(s) started in SVC mode.
[ 0.004872] devtmpfs: initialized
[ 0.016621] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.017193] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017219] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.017568] pinctrl core: initialized pinctrl subsystem
[ 0.018891] NET: Registered protocol family 16
[ 0.020456] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.056770] rtc_ccu: sunxi ccu init OK
[ 0.059072] ccu: sunxi ccu init OK
[ 0.059578] r_ccu: sunxi ccu init OK
[ 0.092029] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.095688] iommu: Default domain type: Translated
[ 0.095918] sunxi iommu: irq = 24
[ 0.097035] SCSI subsystem initialized
[ 0.097411] usbcore: registered new interface driver usbfs
[ 0.097498] usbcore: registered new interface driver hub
[ 0.097621] usbcore: registered new device driver usb
[ 0.097850] videodev: Linux video capture interface: v2.00
[ 0.099484] Advanced Linux Sound Architecture Driver Initialized.
[ 0.100200] Bluetooth: Core ver 2.22
[ 0.100288] NET: Registered protocol family 31
[ 0.100297] Bluetooth: HCI device and connection manager initialized
[ 0.100315] Bluetooth: HCI socket layer initialized
[ 0.100326] Bluetooth: L2CAP socket layer initialized
[ 0.100354] Bluetooth: SCO socket layer initialized
[ 0.100616] pwm module init!
[ 0.102181] g2d 5410000.g2d: Adding to iommu group 0
[ 0.102598] G2D: rcq version initialized.major:250
[ 0.103732] clocksource: Switched to clocksource arch_sys_counter
[ 0.112522] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.127846] thermal_sys: Registered thermal governor 'step_wise'
[ 0.127853] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.128337] NET: Registered protocol family 2
[ 0.128876] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.128903] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.128925] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.128946] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.129039] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.129072] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.129282] NET: Registered protocol family 1
[ 0.130717] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.131268] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.131464] sunxi_spi_resource_get()2259 - [spi0] SPI MASTER MODE
[ 0.131519] sunxi_spi_resource_get()2306 - sample_mode:1 sample_delay:27
[ 0.131552] sunxi_spi_request_dma()988 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.131610] sunxi_spi_clk_init()2356 - [spi0] mclk 100000000
[ 0.132392] sunxi_spi_probe()2809 - [spi0]: driver probe succeed, base c881f000, irq 42
[ 0.134473] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.140333] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.140541] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.140789] fuse: init (API version 7.31)
[ 0.171723] io scheduler mq-deadline registered
[ 0.171738] io scheduler kyber registered
[ 0.174523] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.175304] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.175658] [DISP]disp_module_init
[ 0.176247] disp 5000000.disp: Adding to iommu group 0
[ 0.176786] [DISP] disp_init,line:2331:
[ 0.176790] smooth display screen:0 type:1 mode:4
[ 0.192840] [DISP] disp_sys_pwm_request,line:442:
[ 0.192846] disp_sys_pwm_request pwm 7 fail! -16
[ 0.192860] [DISP] disp_sys_pwm_config,line:509:
[ 0.192863] disp_sys_pwm_Config, handle is NULL!
[ 0.193219] display_fb_request,fb_id:0
[ 0.205313] disp_al_manager_apply ouput_type:1
[ 0.205483] [DISP] lcd_clk_config,line:777:
[ 0.205494] disp 0, clk: pll(498000000),clk(498000000),dclk(83000000) dsi_rate(83000000)
[ 0.205494] clk real:pll(492000000),clk(492000000),dclk(123000000) dsi_rate(150000000)
[ 0.205525] [DISP] disp_sys_pwm_request,line:442:
[ 0.205528] disp_sys_pwm_request pwm 7 fail! -16
[ 0.205859] [DISP]disp_module_init finish
[ 0.207097] sunxi_sid_init()783 - insmod ok
[ 0.210254] Freeing logo buffer memory: 4560K
[ 0.211401] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.211769] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.212111] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.212817] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.213164] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.213459] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.214137] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.214477] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.214793] uart3: ttyS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
[ 0.214820] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 1.223694] printk: console [ttyS3] enabled
[ 1.229265] uart uart4: uart4 supply uart not found, using dummy regulator
[ 1.237372] uart4: ttyS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
[ 1.247057] uart uart5: uart5 supply uart not found, using dummy regulator
[ 1.255139] uart5: ttyS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
[ 1.265117] misc dump reg init
[ 1.269936] dma-buf: Running sanitycheck
[ 1.274376] dma-buf: Running dma_fence
[ 1.278578] sizeof(dma_fence)=48
[ 1.282354] dma-buf: Running dma_fence/sanitycheck
[ 1.287760] dma-buf: Running dma_fence/test_signaling
[ 1.293426] dma-buf: Running dma_fence/test_add_callback
[ 1.299410] dma-buf: Running dma_fence/test_late_add_callback
[ 1.305864] dma-buf: Running dma_fence/test_rm_callback
[ 1.311723] dma-buf: Running dma_fence/test_late_rm_callback
[ 1.318089] dma-buf: Running dma_fence/test_status
[ 1.323461] dma-buf: Running dma_fence/test_error
[ 1.328744] dma-buf: Running dma_fence/test_wait
[ 1.333939] dma-buf: Running dma_fence/test_wait_timeout
[ 1.373749] dma-buf: Running dma_fence/test_stub
[ 1.378947] dma-buf: Running dma_fence/race_signal_callback
[ 1.453764] thread_signal_callback[0] completed 35687 passes, 98 misses
[ 1.461214] thread_signal_callback[1] completed 35645 passes, 55 misses
[ 1.533750] thread_signal_callback[0] completed 42156 passes, 42155 misses
[ 1.541490] thread_signal_callback[1] completed 42139 passes, 42139 misses
[ 1.549808] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 1.557143] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.565031] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.572454] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.579118] sunxi-spinand-phy: get phy info from fdt fail
[ 1.585262] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.591897] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.599443] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.606485] sunxi-spinand-phy: ========== arch info ==========
[ 1.613025] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.619772] sunxi-spinand-phy: Munufacture: Winbond
[ 1.626029] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.631691] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.637655] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.643414] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.649091] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.654861] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.660717] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.666583] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.672635] sunxi-spinand-phy: EccFlag: 0x0
[ 1.678500] sunxi-spinand-phy: EccType: 2
[ 1.684171] sunxi-spinand-phy: EccProtectedType: 3
[ 1.689832] sunxi-spinand-phy: ========================================
[ 1.697257] sunxi-spinand-phy:
[ 1.700773] sunxi-spinand-phy: ========== physical info ==========
[ 1.707712] sunxi-spinand-phy: TotalSize: 128 M
[ 1.713081] sunxi-spinand-phy: SectorSize: 512 B
[ 1.718459] sunxi-spinand-phy: PageSize: 2 K
[ 1.723634] sunxi-spinand-phy: BlockSize: 128 K
[ 1.729015] sunxi-spinand-phy: OOBSize: 64 B
[ 1.734302] sunxi-spinand-phy: ========================================
[ 1.741717] sunxi-spinand-phy:
[ 1.745254] sunxi-spinand-phy: ========== logical info ==========
[ 1.752087] sunxi-spinand-phy: TotalSize: 128 M
[ 1.757467] sunxi-spinand-phy: SectorSize: 512 B
[ 1.762836] sunxi-spinand-phy: PageSize: 4 K
[ 1.768021] sunxi-spinand-phy: BlockSize: 256 K
[ 1.773390] sunxi-spinand-phy: OOBSize: 128 B
[ 1.778768] sunxi-spinand-phy: ========================================
[ 1.786276] sunxi-spinand-phy: block lock register: 0x00
[ 1.792320] sunxi-spinand-phy: feature register: 0x19
[ 1.798003] sunxi-spinand-phy: sunxi physic nand init end
[ 1.804464] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.810626] 0x000000000000-0x000000100000 : "boot0"
[ 1.824676] 0x000000100000-0x000000400000 : "uboot"
[ 1.832476] random: fast init done
[ 1.844756] 0x000000400000-0x000000500000 : "secure_storage"
[ 1.854805] 0x000000500000-0x000008000000 : "sys"
[ 1.965369] libphy: Fixed MDIO Bus: probed
[ 1.970087] usbcore: registered new interface driver asix
[ 1.976275] usbcore: registered new interface driver ax88179_178a
[ 1.983167] usbcore: registered new interface driver cdc_ether
[ 1.989811] usbcore: registered new interface driver net1080
[ 1.996243] usbcore: registered new interface driver cdc_subset
[ 2.002959] usbcore: registered new interface driver zaurus
[ 2.009311] usbcore: registered new interface driver cdc_ncm
[ 2.015678] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.023013] sunxi-ehci: EHCI SUNXI driver
[ 2.027937] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.034930] sunxi-ohci: OHCI SUNXI driver
[ 2.041492] sunxi-rtc 7090000.rtc: registered as rtc0
[ 2.047346] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:28:11 UTC (1691)
[ 2.056596] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 2.062538] i2c /dev entries driver
[ 2.066644] IR NEC protocol handler initialized
[ 2.072237] usbcore: registered new interface driver uvcvideo
[ 2.078756] USB Video Class driver (1.1.1)
[ 2.083349] sunxi cedar version 1.1
[ 2.087491] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.093851] VE: sunxi_cedar_probe power-domain init!!!
[ 2.099618] VE: install start!!!
[ 2.099618]
[ 2.105245] VE: cedar-ve the get irq is 43
[ 2.105245]
[ 2.111711] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 2.111711]
[ 2.121044] VE: install end!!!
[ 2.121044]
[ 2.126136] VE: sunxi_cedar_probe
[ 2.131139] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.140368] Bluetooth: HCI UART driver ver 2.3
[ 2.145379] Bluetooth: HCI UART protocol H4 registered
[ 2.151142] Bluetooth: HCI UART protocol (null) registered
[ 2.157319] Bluetooth: HCI Realtek H5 protocol initialized
[ 2.165142] usbcore: registered new interface driver usbhid
[ 2.171431] usbhid: USB HID core driver
[ 2.175755] exFAT: Version 1.3.0
[ 2.179790] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[ 2.187436] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[ 2.195415] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.1.2
[ 2.202481] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 2.210333] remoteproc remoteproc0: dsp_rproc is available
[ 2.216681] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 2.225011] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 2.235941] sunxi-rpbuf-controller rpbuf_controller@0: rpbuf_register_ctrl_dev:827
[ 2.247775] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s0 on pin PE14
[ 2.256433] sun8iw20-pinctrl 2000000.pinctrl: unsupported function i2s0 on pin PE13
[ 2.265442] sunxi-daudio 2032000.daudio: regulator missing or invalid
[ 2.273179] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.273179]
[ 2.290395] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.301788] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[ 2.311132] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 2.321001] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.328267] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 2.339419] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
[ 2.351555] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.359651] NET: Registered protocol family 17
[ 2.364682] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 2.372223] Bluetooth: RFCOMM TTY layer initialized
[ 2.377735] Bluetooth: RFCOMM socket layer initialized
[ 2.383522] Bluetooth: RFCOMM ver 1.11
[ 2.388414] Registering SWP/SWPB emulation handler
[ 2.408444] sunxi-i2c 2502400.twi: 2502400.twi supply twi not found, using dummy regulator
[ 2.418638] sunxi-i2c 2502400.twi: probe success
[ 2.424855] sunxi-thermal 2009400.ths: sun8iw20 cp version:24
[ 2.464597] sunxi-audio-card 20320a0.sounddaudio0: use dummy codec for simple card.
[ 2.473365] debugfs: Directory '2032000.daudio' with parent 'snddaudio0' already present!
[ 2.483074] sunxi-audio-card 20320a0.sounddaudio0: snd-soc-dummy-dai <-> 2032000.daudio mapping ok
[ 2.494612] get drvvbus-en is fail, 22
[ 2.498822] get ehci0-controller wakeup-source is fail.
[ 2.504826] sunxi ehci0-controller don't init wakeup source
[ 2.511080] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c68348, 0x:c88a7000, irq_no:39
[ 2.523090] [sunxi-ehci0]: Not init ehci0
[ 2.527973] get drvvbus-en is fail, 22
[ 2.532181] get ohci0-controller wakeup-source is fail.
[ 2.538164] sunxi ohci0-controller don't init wakeup source
[ 2.544431] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c685f8
[ 2.554097] [sunxi-ohci0]: Not init ohci0
[ 2.559665] ubi0: attaching mtd3
[ 2.736875] ubi0: scanning is finished
[ 2.748187] ubi0: attached mtd3 (name "sys", size 123 MiB)
[ 2.754370] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 2.762081] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[ 2.769705] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.777520] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[ 2.784263] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
[ 2.792363] ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 0
[ 2.801738] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[ 2.812100] ubi0: background thread "ubi_bgt0d" started, PID 1006
[ 2.820190] block ubiblock0_5: created from ubi0:5(rootfs)
[ 2.826870] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 2.840860] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.843788] clk: Not disabling unused clocks
[ 2.850590] cfg80211: failed to load regulatory.db
[ 2.855467] ALSA device list:
[ 2.864064] #0: audiocodec
[ 2.867292] #1: snddaudio0
[ 2.870525] alloc_fd: slot 0 not NULL!
[ 2.878410] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 2.889581] devtmpfs: mounted
[ 2.894767] Freeing unused kernel memory: 1024K
[ 2.943875] Run /init as init process
mount: mounting none on /dev failed: Device or resource busy
[ 3.662612] UBIFS (ubi0:6): Mounting in unauthenticated mode
[ 3.669165] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 1043
[ 3.678217] random: crng init done
[ 3.721477] UBIFS (ubi0:6): recovery needed
[ 3.866476] UBIFS (ubi0:6): recovery completed
[ 3.871660] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "UDISK"
[ 3.879918] UBIFS (ubi0:6): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.891063] UBIFS (ubi0:6): FS size: 78188544 bytes (74 MiB, 303 LEBs), journal size 3870720 bytes (3 MiB, 15 LEBs)
[ 3.902795] UBIFS (ubi0:6): reserved for root: 3693038 bytes (3606 KiB)
[ 3.910264] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID 7B5276FF-372A-4458-B2B9-E85C3F896D86, small LPT model
init started: BusyBox v1.33.2 (2023-05-19 09:43:20 UTC)
starting pid 1059, tty '': '/etc/preinit'
can't run '/etc/preinit': No such file or directory
starting pid 1060, tty '': '/bin/mount -t proc proc /proc'
mount: mounting proc on /proc failed: Device or resource busy
starting pid 1062, tty '': '/bin/mount -t tmpfs tmpfs /run'
mount: mounting tmpfs on /run failed: No such file or directory
starting pid 1064, tty '': '/bin/mount -o remount,rw /'
starting pid 1065, tty '': '/bin/mkdir -p /dev/pts'
starting pid 1066, tty '': '/bin/mkdir -p /dev/shm'
starting pid 1067, tty '': '/bin/mount -a'
starting pid 1068, tty '': '/bin/hostname -F /etc/hostname'
hostname: can't open '/etc/hostname': No such file or directory
starting pid 1069, tty '': '/etc/init.d/rcS boot'
------run rc.preboot file-----
[ 4.367147] ubi0 error: ubi_open_volume: cannot open device 0, volume 6, error -16
Error: cannot open the UBI volume '/dev/ubi0_6'
Device or resource busy (error 16)
------run rc.modules file-----
[ 4.503670] usbcore: registered new interface driver usb-storage
[ 4.517160] get ctp_power is fail, -22
[ 4.521370] get ctp_power_ldo_vol is fail, -22
[ 4.526496] sunxi_ctp_startup: ctp_power_io is invalid.
[ 4.532419] get ctp_gesture_wakeup fail, no gesture wakeup
[ 4.538629] gt9xxnew_ts 1-0014: 1-0014 supply ctp not found, using dummy regulator
[ 4.733979] input: gt9xxnew_ts as /devices/virtual/input/input1
[ 5.157922] 8723ds: Unknown symbol sunxi_mmc_rescan_card (err -2)
[ 5.164934] 8723ds: Unknown symbol sunxi_wlan_get_bus_index (err -2)
[ 5.172222] 8723ds: Unknown symbol sunxi_wlan_set_power (err -2)
failed to insert /lib/modules/5.4.61/8723ds.ko
------run rc.final file-----
Trying to connect to SWUpdate...
numid=30,iface=MIXER,name='Headphone Switch'
; type=BOOLEAN,access=rw------,values=1
: values=on
[ 5.717795] file system registered
[ 5.781818] configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
[ 5.868403] read descriptors
[ 5.871659] read strings
dbus[1127]: Unknown group "lp" in message bus configuration file
[ 6.714022] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
device_chose finished!
------run rc.final file end-----
: values=on
: values=on
numid=17,iface=MIXER,name='Headphone volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=7,step=0
: values=6
| dBscale-min=-42.00dB,step=6.00dB,mute=0
numid=5,iface=MIXER,name='DAC volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=255,step=0
: values=180,180
| dBscale-min=-119.25dB,step=0.75dB,mute=0
numid=29,iface=MIXER,name='ADC3 Input MIC3 Boost Switch'
: values=on
numid=31,iface=MIXER,name='HpSpeaker Switch'
: values=on
ln: /etc/localtime: File exists
[ 6.850429] android_work: did not send uevent (0 0 00000000)
starting pid 1194, tty '/dev/ttyS3': '-/bin/sh'
BusyBox v1.33.2 (2023-05-19 09:43:20 UTC) built-in shell (ash)
------run profile file-----
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (5.0, unknown)
nodev debugfs
root@TinaLinux:/# [ 7.151615] android_work: sent uevent USB_STATE=CONNECTED
open file error
em_hal_brightness_get_value = 100
get_audio_vol 180
wh=1080x1080, vwh=1080x2160, bpp=32, rotated=2
[ 7.303610] VE: enable hw clock
1screensize = 9331200 finfo.line_length = 4320 vinfo.yres = 1080
Turn on double buffering.
Turn on 2d hardware acceleration.
[ 7.307891] enable_cedar_hw_clk,552
Turn on 2d hardware acceleration fill.
Turn on 2d hardware acceleration blit.
Turn on 2d hardware acceleration blend.
Turn on 2d hardware acceleration scale.
Turn on 2d hardware acceleration rotate.
init end 1
device_timer_init
Audio amplifier enabled (GPIO34 set to 0)
Running in T113 mode.111
is a tty success!Protocol UART buffer flushed
Protocol message queue created: ID=1, key=456 (new)
Protocol read thread started
Protocol serial initialized successfully on /dev/ttyS4
Protocol handler: Current volume is 90%
Protocol handle thread STARTED
Queue ID: 1, waiting for messages...
[HANDLE #1] Waiting for message from queue...
: values=0,180
set_audio_vol amixer -D hw:audiocodec cset name='DAC volume' 0,180,ret 0
Protocol handler: System volume set to 90%
Protocol frame callback set
Protocol handler initialized and registered
em_hal_brightness_set_value = 180
[ 7.823928] configfs-gadget gadget: high-speed config #1: c
[ 7.830331] android_work: sent uevent USB_STATE=CONFIGURED离线
我最近打算用这个做项目,请问这些报错有影响吗? 我应该怎么修改呢:)
