楼主 # 2026-01-11 19:36:40
jflbr
xfel 真正支持 初始化 t113-s4 ddr内存 ,新增读写 GD5f4gQ6uexx 512MB spinand
[138214]fes begin commit:
[138216]set pll start
[138219]periph0 has been enabled
[138222]set pll end
[138223]board init ok
[138225]beign to init dram
[138228] _____ ___   ___   ___    ____  _____ _____ _____
[138233]|_   _|_  | |_  | |_  |  |    \| __  |  _  |     |
[138238]  | |  _| |_ _| |_|_  |  |  |  |    -|     | | | |
[138243]  |_| |_____|_____|___|  |____/|__|__|__|__|_|_|_|
[138249]=============================================================
[138255]DRAM DRIVER FOR T113-S4 256M SiP DDR3 DRAM
[138259]YuzukiTsuru <gloomyghost@gloomyghost.com>
[138264]=============================================================
[138270]DRAM BOOT DRIVE INFO: V0.24-t113-s4
[138274]DRAM CLK = 936 MHz
[138276]DRAM Type = 3 (2:DDR2,3:DDR3)
[138280]DRAMC read ODT off
[138282]ZQ value = 0x2c
[138284]DDR CLK = 1872 MHz
[138287]DDR efuse: 0xa
[138289]chip id efuse: 0x7200
[138293]single rank and full DQ!
[138296]DDR CLK = 1872 MHz
[138298]DDR efuse: 0xa
[138300]chip id efuse: 0x7200
[138304]rank 0 row = 14
[138306]para->dram_para1 = 0x10e2
[138309]rank 0 bank = 8
[138312]para->dram_para1 = 0x10e2
[138315]rank 0 page size = 2 KB
[138318]para->dram_para1 = 0x10e2
[138321]DRAM ODT value: 0x42
[138323]DDR CLK = 1872 MHz
[138326]DDR efuse: 0xa
[138328]chip id efuse: 0x7200
[138332]DRAM: size = 256MB
[138335]DRAM: simple test OK
[138338]init dram ok
xfel-windows-v1.3.5_20260111-1935.rar
楼主 #1 2026-01-11 19:38:01
jflbr
Re: xfel 真正支持 初始化 t113-s4 ddr内存 ,新增读写 GD5f4gQ6uexx 512MB spinand
记着,显示信息是串口3
楼主 #2 2026-01-18 07:28:20
jflbr
#3 2026-01-23 18:58:21
again
测试对t113m4020dc0这个无效
