楼主 #1 2017-09-07 09:07:17
codehunter
Python的编程哲学是什么?
The Zen of Python, by Tim Peters
Beautiful is better than ugly.
美丽优于丑陋;
Explicit is better than implicit.
清楚优于含糊;
Simple is better than complex.
简单优于复杂;
Complex is better than complicated.
复杂优于繁琐;
Flat is better than nested.
平坦优于曲折;
Sparse is better than dense.
宽松优于密集;
Readability counts.
重要的是可读性;
Special cases aren’t special enough to break the rules.
特殊的案例不足以特殊到破坏规则;
Although practicality beats purity.
尽管实践可以打破真理;
Errors should never pass silently.
错误却不可置之不理;
Unless explicitly silenced.
除非另有明确要求;
In the face of ambiguity, refuse the temptation to guess.
面对模棱两可,拒绝猜测;
There should be one– and preferably only one –obvious way to do it.
总会有一个 —— 最好是只有一个 —— 显而易见的方式来明辨;
Although that way may not be obvious at first unless you’re Dutch.
哪怕这种方式在开始的时候可能并不明显 —— 除非你是荷兰人;
Now is better than never.
现在有比没有好;
Although never is often better than right now.
尽管没有经常好于现在;
If the implementation is hard to explain, it’s a bad idea.
如果如何实现很难被解释清楚,那么这个想法就是一个坏想法;
If the implementation is easy to explain, it may be a good idea.
如果如何实现可以被很好的解释,那么这是一个好想法;
Namespaces are one honking great idea — let’s do more of those!
命名空间就是一个非常好的想法 —— 让我们在这方面多做些工作吧!
#2 2017-09-07 09:41:39
Re: Python的编程哲学是什么?
学习
#3 2017-09-07 10:13:01
尧哥
Re: Python的编程哲学是什么?
学习了
#4 2017-09-07 10:20:54
强哥
Re: Python的编程哲学是什么?
qiang.
#5 2017-09-07 10:26:19
Plus C
Re: Python的编程哲学是什么?
膜拜ZA大神
#6 2017-09-07 10:28:39
军哥
Re: Python的编程哲学是什么?
大神
#7 2017-09-07 10:32:15
熊哥哥
Re: Python的编程哲学是什么?
大神就是大神
#8 2018-04-16 18:56:12
lcfmax
已发帖子: 330
Re: Python的编程哲学是什么?
向大神学习
